  4. [Gelöst] nach Admin upgrade 3.3.4 keine Webseite mehr
36 Beiträge 5 Kommentatoren 6.6k Aufrufe
  • wendy2702W Online
    wendy2702W Online
    Folge Thema aus diesem Thread : viewtopic.php?f=22&t=12776&p=135902#p135679
    Admin update nach Anleitung versucht:
    cd /opt/iobroker
    npm i https://github.com/ioBroker/ioBroker.admin
    cd node_modules/iobroker.admin
    npm i gulp
    node_modules/.bin/gulp
    Der "gulp" Befehl ist hier schon der korrigierte, in den ersten logs steht noch der alte Befehl
    Admin installiert:
    root@openmediavault /opt/iobroker > npm i https://github.com/ioBroker/ioBroker.admin
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis-mywidgets/package.json'
    + iobroker.admin@3.3.4
    removed 175 packages and updated 1 package in 20.192s
    root@openmediavault /opt/iobroker > cd node_modules/iobroker.admin/
    root@openmediavault /opt/iobroker/node_modules/iobroker.admin > npm i gulp
    npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
    npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
    npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
    npm notice created a lockfile as package-lock.json. You should commit this file.
    + gulp@3.9.1
    added 272 packages from 163 contributors in 5.886s
    Und jetzt nur noch das im Browser:
    This adapter cannot be installed directly from github.
    You must install it from npm.
    Write for that "npm install iobroker.admin" in according directory.
    Der admin.0 läuft allerdings:
    root@openmediavault ~ > ps -ef |grep io.admin
    root      9036  9024  1 11:58 ?        00:00:01 io.admin.0
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      Was ist mit Schritt 5? Also "gulp" ausführen?
      • wendy2702W Online
        wendy2702W Online
        root@openmediavault /opt/iobroker/node_modules/iobroker.admin > gulp
        -bash: gulp: Kommando nicht gefunden.
        Sorry… war bei markieren scheinbar nicht dabei beim ersten mal.
          AlCalzoneA Offline
          AlCalzone
          @wendy2702:
          Kommando nicht gefunden. `
          Dann hat er wohl den letzten Befehl nicht ausgeführt. Klappt es mit
          • wendy2702W Online
            wendy2702W Online
            Sorry,
            habe gerade downgrade auf 3.3.3 gemacht.
            Muss ich gleich nochmal versuchen.
            • wendy2702W Online
              wendy2702W Online
              Kurzer test:
              root@openmediavault /opt/iobroker/node_modules/iobroker.admin > node_modules/.bin/gulp
              [13:09:15] No gulpfile found
              Sollten wir das Thema besser auftrennen?
              Hat ja nichts mit "NPM Error" zu tun und ist auch nicht "Gelöst".
              Kannst du das machen?
              • HomoranH Offline
                HomoranH Offline
                Habs getrennt, danke für den Link! ich war eben zu faul zum suchen
                  AlCalzoneA Offline
                  AlCalzone
                  @wendy2702:
                  Öhh, auf Github sehe ich definitiv ein gulpfile.js im Hauptordner. Ist die Datei bei dir in /opt/iobroker/node_modules/iobroker.admin vorhanden?
                  Alternativ könntest du folgenden Befehl probieren, der sollte das gleiche tun:
                  npm run prepublish
                  • wendy2702W Online
                    wendy2702W Online
                    @AlCalzone:
                    npm run prepublish
                    Wofür kann/soll ich diesen Befehl nehmen?
                    • wendy2702W Online
                      wendy2702W Online
                      Also ich weiß nicht was oder wohin er mit :
                      Installiert:
                      root@openmediavault /opt/iobroker > ls -la node_modules/iobroker.admin/
                      insgesamt 168
                      drwxrwxrwx   6 root root  4096 Mär 22 13:19 .
                      drwxrwxrwx 784 root root 36864 Mär 22 14:49 ..
                      drwxrwxrwx   2 root root  4096 Mär 22 13:19 admin
                      -rw-rw-rw-   1 root root 15039 Mär 22 13:19 CHANGELOG_OLD.md
                      -rw-rw-rw-   1 root root  9425 Mär 22 13:19 io-package.json
                      drwxrwxrwx   2 root root  4096 Mär 22 13:19 lib
                      -rw-rw-rw-   1 root root  1120 Mär 22 13:19 LICENSE
                      -rw-rw-rw-   1 root root 12397 Mär 22 13:19 main.js
                      drwxrwxrwx 160 root root  4096 Mär 22 13:19 node_modules
                      -rw-rw-rw-   1 root root  2971 Mär 22 13:19 package.json
                      -rw-rw-rw-   1 root root 44898 Mär 22 13:19 package-lock.json
                      -rw-rw-rw-   1 root root  8576 Mär 22 13:19 README.md
                      drwxrwxrwx   8 root root  4096 Mär 22 13:19 www
                      removed 175 packages and updated 1 package in 19.825s
                      insgesamt 116
                      drwxr-xr-x   4 root root  4096 Mär 22 17:56 .
                      drwxrwxrwx 784 root root 36864 Mär 22 17:56 ..
                      drwxr-xr-x   2 root root  4096 Mär 22 17:56 admin
                      -rw-r--r--   1 root root 14519 Mär 22 17:56 CHANGELOG_OLD.md
                      -rw-r--r--   1 root root  9740 Mär 22 17:56 io-package.json
                      drwxr-xr-x   2 root root  4096 Mär 22 17:56 lib
                      -rw-r--r--   1 root root  1099 Mär 22 17:56 LICENSE
                      -rw-r--r--   1 root root 12397 Mär 22 17:56 main.js
                      -rw-r--r--   1 root root  2976 Mär 22 17:56 package.json
                      -rw-r--r--   1 root root  8421 Mär 22 17:56 README.md
                      Aber die Files aus dem Github Package die man erhält wenn man das ZIP lädt sind nicht zu sehen.
                        AlCalzoneA Offline
                        AlCalzone
                        @wendy2702:
                        Wofür kann/soll ich diesen Befehl nehmen? `
                        Der wäre anstatt "gulp" oder "node_modules/.bin/gulp".
                        • wendy2702W Online
                          wendy2702W Online
                          OK.
                          Aber ohne die Files muss ich das garnicht weiter testen.
                            AlCalzoneA Offline
                            AlCalzone
                            @wendy2702:
                            OK.
                            Aber ohne die Files muss ich das garnicht weiter testen. `
                            Probier mal als Installationsbefehl
                            npm i https://github.com/ioBroker/ioBroker.admin/tarball/master
                            also explizit auf den Tarball verweisen.
                            • wendy2702W Online
                              wendy2702W Online
                              Kann ich erst morgen.
                              Bin heute nicht mehr lokal am Rechner und remote über Ipad will ich das nicht probieren.
                              • wendy2702W Online
                                wendy2702W Online
                                Bin ja gerne Versuchskaninchen :)
                                root@openmediavault /opt/iobroker > npm i https://github.com/ioBroker/ioBroker.admin/tarball/master
                                npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis-mywidgets/package                       .json'
                                removed 175 packages and updated 1 package in 15.442s
                                insgesamt 168
                                drwxr-xr-x   7 root root  4096 Mär 23 09:51 .
                                drwxrwxrwx 784 root root 36864 Mär 23 09:51 ..
                                drwxr-xr-x   3 root root  4096 Mär 23 09:51 admin
                                -rw-r--r--   1 root root   713 Mär 21 18:41 appveyor.yml
                                -rw-r--r--   1 root root 14519 Mär 21 18:41 CHANGELOG_OLD.md
                                -rw-r--r--   1 root root  1844 Mär 21 18:41 DEVELOPER.md
                                drwxr-xr-x   6 root root  4096 Mär 23 09:51 docs
                                -rw-r--r--   1 root root 23081 Mär 21 18:41 gulpfile.js
                                -rw-r--r--   1 root root  9740 Mär 21 18:41 io-package.json
                                drwxr-xr-x   2 root root  4096 Mär 23 09:51 lib
                                -rw-r--r--   1 root root  1099 Mär 21 18:41 LICENSE
                                -rw-r--r--   1 root root 12397 Mär 21 18:41 main.js
                                -rw-r--r--   1 root root   128 Mär 21 18:41 .npmignore
                                -rw-r--r--   1 root root  3083 Mär 23 09:51 package.json
                                -rw-r--r--   1 root root  8421 Mär 21 18:41 README.md
                                drwxr-xr-x  11 root root  4096 Mär 23 09:51 src
                                drwxr-xr-x   3 root root  4096 Mär 23 09:51 test
                                -rw-r--r--   1 root root   447 Mär 21 18:41 .travis.yml
                                npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://med                       ium.com/gulpjs/gulp-util-ca3b1f9f9ac5
                                npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future v                       ersions of Node.js
                                + gulp@3.9.1
                                added 272 packages from 163 contributors in 5.581s
                                module.js:478
                                    throw err;
                                Error: Cannot find module 'gulp-less'
                                    at Function.Module._resolveFilename (module.js:476:15)
                                    at Function.Module._load (module.js:424:25)
                                    at Module.require (module.js:504:17)
                                    at require (internal/module.js:20:19)
                                    at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.admin/gulpfile.js:3:21)
                                    at Module._compile (module.js:577:32)
                                    at Object.Module._extensions..js (module.js:586:10)
                                    at Module.load (module.js:494:32)
                                    at tryModuleLoad (module.js:453:12)
                                    at Function.Module._load (module.js:445:3)
                                root@openmediavault /opt/iobroker/node_modules/iobroker.admin ></anonymous>
                                Wenigstens sind die Dateien jetzt vorhanden.
                                Aber "gulp" lässt sich nicht ausführen.
                                Und wenn ich den Admin startet steht im Browser wieder das:
                                • wendy2702W Online
                                  wendy2702W Online
                                  Habe mal das "gulp-less" nach installiert.
                                  Dann vermisst er das nächste:
                                  module.js:478
                                      throw err;
                                  Error: Cannot find module 'gulp-sass'
                                      at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.admin/gulpfile.js:4:21)
                                  • wendy2702W Online
                                    wendy2702W Online
                                    Mal alle fehlenden und nicht automatisch installierten Pakete Manuel hinzugefügt und dann "gulp" gestartet:
                                    [10:14:23] Using gulpfile /opt/iobroker/node_modules/iobroker.admin/gulpfile.js
                                    [10:14:23] Starting 'wwwLanguages2words'...
                                    [10:14:23] Finished 'wwwLanguages2words' after 55 ms
                                    [10:14:23] Starting 'adminLanguages2words'...
                                    [10:14:23] Finished 'adminLanguages2words' after 2.93 ms
                                    [10:14:23] Starting '1_words'...
                                    [10:14:23] Finished '1_words' after 18 μs
                                    [10:14:23] Starting 'iobCSS'...
                                    [10:14:23] Starting 'adminCSS'...
                                    [10:14:23] Starting 'appCSS'...
                                    [10:14:23] Finished 'appCSS' after 2.99 ms
                                    [10:14:23] Starting 'treeTableCSS'...
                                    [10:14:23] Starting 'configCSS'...
                                    [10:14:23] Finished 'configCSS' after 1.69 ms
                                    [10:14:23] Starting 'materializeCSS'...
                                    [10:14:23] Finished 'materializeCSS' after 1.65 ms
                                    [10:14:23] Starting 'vendorJS'...
                                    [10:14:23] Starting 'materializeJS'...
                                    [10:14:23] Starting 'appJS'...
                                    [10:14:23] Starting 'fancyTreeJS'...
                                    [10:14:23] Starting 'appHTML'...
                                    [10:14:23] Starting 'aceCopy'...
                                    [10:14:23] Starting 'colorpickerCopy'...
                                    [10:14:23] Starting 'colorpick.min'...
                                    [10:14:27] Finished 'colorpick.min' after 3.67 s
                                    [10:14:27] Starting 'appCopy'...
                                    [10:14:27] Finished 'aceCopy' after 3.68 s
                                    [10:14:27] Finished 'treeTableCSS' after 3.7 s
                                    [10:14:27] Finished 'fancyTreeJS' after 3.69 s
                                    [10:14:27] Finished 'iobCSS' after 3.83 s
                                    [10:14:27] Finished 'adminCSS' after 3.82 s
                                    [10:14:27] Starting '2_css'...
                                    [10:14:27] Finished '2_css' after 2.3 μs
                                    [10:14:27] Finished 'colorpickerCopy' after 4 s
                                    events.js:160
                                          throw er; // Unhandled 'error' event
                                    ReferenceError: Unknown plugin "transform-es2015-arrow-functions" specified in "base" at 0, attempted to resolve relative to "/opt/iobroker/node_modules/iobroker.admin/src/materialize-css/js"
                                        at /opt/iobroker/node_modules/iobroker.admin/node_modules/babel-core/lib/transformation/file/options/option-manager.js:180:17
                                        at Array.map (native)
                                        at Function.normalisePlugins (/opt/iobroker/node_modules/iobroker.admin/node_modules/babel-core/lib/transformation/file/options/option-manager.js:158:20)
                                        at OptionManager.mergeOptions (/opt/iobroker/node_modules/iobroker.admin/node_modules/babel-core/lib/transformation/file/options/option-manager.js:234:36)
                                        at OptionManager.init (/opt/iobroker/node_modules/iobroker.admin/node_modules/babel-core/lib/transformation/file/options/option-manager.js:368:12)
                                        at File.initOptions (/opt/iobroker/node_modules/iobroker.admin/node_modules/babel-core/lib/transformation/file/index.js:212:65)
                                        at new File (/opt/iobroker/node_modules/iobroker.admin/node_modules/babel-core/lib/transformation/file/index.js:135:24)
                                        at Pipeline.transform (/opt/iobroker/node_modules/iobroker.admin/node_modules/babel-core/lib/transformation/pipeline.js:46:16)
                                        at DestroyableTransform._transform (/opt/iobroker/node_modules/iobroker.admin/node_modules/gulp-babel/index.js:36:22)
                                        at DestroyableTransform.Transform._read (/opt/iobroker/node_modules/iobroker.admin/node_modules/through2/node_modules/readable-stream/lib/_stream_transform.js:184:10)
                                        at DestroyableTransform.Transform._write (/opt/iobroker/node_modules/iobroker.admin/node_modules/through2/node_modules/readable-stream/lib/_stream_transform.js:172:83)
                                        at doWrite (/opt/iobroker/node_modules/iobroker.admin/node_modules/through2/node_modules/readable-stream/lib/_stream_writable.js:418:64)
                                      AlCalzoneA Offline
                                      AlCalzone
                                      @wendy2702:
                                      Mal alle fehlenden und nicht automatisch installierten Pakete Manuel hinzugefügt `
                                      Ahhh, das macht Sinn. "npm install paketname" installiert nur die dependencies, nicht die devDependencies, ganz vergessen.
                                      npm install
                                      im Ordner des Admin-Adapters sollte eigentlich alle devDependencies installieren. Das Transform-Plugin scheint er nämlich nicht installiert zu haben.
                                      • wendy2702W Online
                                        wendy2702W Online
                                        @AlCalzone:
                                        npm install
                                        :oops: Hätte ich auch drauf kommen können aber wenn man davor sitzt …. wie war das mit dem Wald und den Bäumen
                                        root@openmediavault /opt/iobroker/node_modules/iobroker.admin > npm install
                                        npm WARN prepublish-on-install As of npm@5, `prepublish` scripts are deprecated.
                                        npm WARN prepublish-on-install Use `prepare` for build steps and `prepublishOnly` for upload-only.
                                        npm WARN prepublish-on-install See the deprecation note in `npm help scripts` for more information.
                                        npm WARN lifecycle iobroker.admin@3.3.4~prepublish: cannot run in wd %s %s (wd=%s) iobroker.admin@3.3.4 node node_modules/gulp/bin/gulp default /opt/iobroker/node_modules/iobroker.admin
                                        added 161 packages from 395 contributors in 7.49s
                                        [10:34:22] Using gulpfile /opt/iobroker/node_modules/iobroker.admin/gulpfile.js
                                        [10:34:22] Starting 'wwwLanguages2words'...
                                        [10:34:22] Finished 'wwwLanguages2words' after 70 ms
                                        [10:34:22] Starting 'adminLanguages2words'...
                                        [10:34:22] Finished 'adminLanguages2words' after 2.69 ms
                                        [10:34:22] Starting '1_words'...
                                        [10:34:22] Finished '1_words' after 21 μs
                                        [10:34:22] Starting 'iobCSS'...
                                        [10:34:22] Starting 'adminCSS'...
                                        [10:34:22] Starting 'appCSS'...
                                        [10:34:22] Finished 'appCSS' after 3.22 ms
                                        [10:34:22] Starting 'treeTableCSS'...
                                        [10:34:22] Starting 'configCSS'...
                                        [10:34:22] Finished 'configCSS' after 1.89 ms
                                        [10:34:22] Starting 'materializeCSS'...
                                        [10:34:22] Finished 'materializeCSS' after 1.75 ms
                                        [10:34:22] Starting 'vendorJS'...
                                        [10:34:22] Starting 'materializeJS'...
                                        [10:34:22] Starting 'appJS'...
                                        [10:34:22] Starting 'fancyTreeJS'...
                                        [10:34:22] Starting 'appHTML'...
                                        [10:34:22] Starting 'aceCopy'...
                                        [10:34:22] Starting 'colorpickerCopy'...
                                        [10:34:22] Starting 'colorpick.min'...
                                        [10:34:26] Finished 'colorpick.min' after 3.91 s
                                        [10:34:26] Starting 'appCopy'...
                                        [10:34:26] Finished 'fancyTreeJS' after 3.91 s
                                        [10:34:26] Finished 'aceCopy' after 3.92 s
                                        [10:34:26] Finished 'treeTableCSS' after 4.02 s
                                        [10:34:26] Finished 'iobCSS' after 4.08 s
                                        [10:34:26] Finished 'adminCSS' after 4.07 s
                                        [10:34:26] Starting '2_css'...
                                        [10:34:26] Finished '2_css' after 2.56 μs
                                        [10:34:26] Finished 'colorpickerCopy' after 4.25 s
                                        [10:34:50] Finished 'vendorJS' after 27 s
                                        [10:34:50] Finished 'materializeJS' after 28 s
                                        [10:34:50] Finished 'appHTML' after 27 s
                                        [10:34:56] Finished 'appJS' after 33 s
                                        [10:34:56] Starting '3_js'...
                                        [10:34:56] Finished '3_js' after 13 μs
                                        [10:34:56] Finished 'appCopy' after 30 s
                                        [10:34:56] Starting '4_static'...
                                        [10:34:56] Finished '4_static' after 10 μs
                                        [10:34:56] Starting 'default'...
                                        [10:34:56] Finished 'default' after 1.45 μs
                                        Admin Webseite erreichbar.
                                          AlCalzoneA Offline
                                          AlCalzone
                                          Super!
                                          Zur Vollständigkeit: folgendes hat bei mir funktioniert
                                          /opt/iobroker $ npm i https://github.com/ioBroker/ioBroker.admin/tarball/master
                                          /opt/iobroker $ cd node_modules/iobroker.admin
                                          /opt/iobroker/node_modules/iobroker.admin $ npm install
                                          /opt/iobroker/node_modules/iobroker.admin $ npm run prepublish
