  4. Telegram Error nach update 1.1.2
    1.7k
33 Beiträge 10 Kommentatoren 3.8k Aufrufe
  • khgK Offline
    khgK Offline
    khg
    nach upgrade vom telegram Adapter auf 1.1.2 können keine Messages mehr gesendet werden, Empfang geht.
    <u>Logmeldung:</u>
    telegram.0 2018-03-19 10:33:05.971 error at Adapter.emit (events.js:188:7)
    telegram.0 2018-03-19 10:33:05.971 error at emitOne (events.js:96:13)
    telegram.0 2018-03-19 10:33:05.971 error at Adapter. (/opt/iobroker/node_modules/iobroker.telegram/main.js:45:14)
    telegram.0 2018-03-19 10:33:05.971 error at processMessage (/opt/iobroker/node_modules/iobroker.telegram/main.js:642:33)
    telegram.0 2018-03-19 10:33:05.971 error at sendMessage (/opt/iobroker/node_modules/iobroker.telegram/main.js:508:22)
    telegram.0 2018-03-19 10:33:05.971 error at _sendMessageHelper (/opt/iobroker/node_modules/iobroker.telegram/main.js:180:13)
    telegram.0 2018-03-19 10:33:05.971 error TypeError: Cannot read property 'chatId' of undefined
    telegram.0 2018-03-19 10:33:05.960 error pmessage messagebox.system.adapter.telegram.0 {"command":"send","message":"Rolladen","from":"system.adapter.javascript.0","_id":86663390} Cannot read property 'c
    Wollte auf telgram 1.1.3 updaten, was mir aber nicht angeboten wurden. Habe versucht es über die Konsole zu installieren.
    npm install iobroker.telegram@1.1.3 –production
    node v6.13.0
    npm ERR! npm v3.10.10
    npm ERR! code ETARGET
    npm ERR! notarget No compatible version found: iobroker.telegram@1.1.3
    npm ERR! notarget Valid install targets:
    npm ERR! notarget 1.1.2, 1.1.0, 1.0.9, 1.0.8, 1.0.6, 1.0.5, 1.0.4, 1.0.3, 1.0.2, 1.0.1, 1.0.0, 0.4.4, 0.4.3, 0.4.1, 0.2.4, 0.2.3, 0.2.2, 0.2.1, 0.2.0, 0.1.0, 0.0.2, 0.0.1
    npm ERR! notarget
    npm ERR! notarget This is most likely not a problem with npm itself.
    npm ERR! notarget In most cases you or one of your dependencies are requesting
    npm ERR! notarget a package version that doesn't exist.
    Auf GitHub steht:
    Changelog
    1.1.3 (2018-03-17)
    (BasGo) Fixed issue preventing adapter to terminate correctly
    1.1.2 (2018-03-16)
    (BasGo) Reworked configuration and translation
    Viele Grüße
    Karl-Heinz
    • khgK Offline
      khgK Offline
      khg
      habe Instanz gelöscht und neu erzeugt –> senden von Nachrichten weiterhin Fehler
      Adapter auf Version 1.1.0 installiert und eine neue Instanz --> senden von Nachrichten erfolgreich..
      Bin ich der Einzigste der Probleme mit senden von Nachrichten unter der Version 1.1.2 hat?
      mfg
      Karl-Heinz
      • wendy2702W Online
        wendy2702W Online
        Also ich habe die 1.1.2 noch nicht installiert.
        Warum machst du keinen Downgrade?
        Hast du mal versucht dem Upgrade aus dem Admin heraus zu machen?
        • lobomauL Offline
          lobomauL Offline
          lobomau
          1.1.2 macht bei mir auch Probleme.
          Downgrade auf 1.1.1. über Admin - Adapter: geht nicht
          Downgrade auf 1.1.0. über Admin - Adapter: geht , aber Fehler
          Upgrade über Admin auf 1.1.3 geht, aber:
          Handy empfängt Nachrichten, kann aber keine schicken, Query-ID invalid
          telegram.0	2018-03-19 13:24:26.828	error	Cannot send answerCallbackQuery [user - undefined]: Error: ETELEGRAM: 400 Bad Request: QUERY_ID_INVALID
          Host: NUC8i3 mit Proxmox:
          • Slave: Pi4
          • khgK Offline
            khgK Offline
            khg
            @lobomau:
            Mit der Version 1.1.0 geht Telegram. <u>Mit der Version 1.1.2 muss ein Problem bestehen</u>. Hatte es nochmal installiert und beim Senden von iobroker heraus wieder viele Fehlermeldung. Installation (downgrade aus Admin heraus funktionierte bei mir auch nicht).
            Also alle Instanzen und Adapter für Telegram gelöscht, evtl. Prozess (io.telegram.0) "gekilled" , iobroker gestoppt und mit npm install iobroker.telegram@1.1.0 –production neu installiert. Neue Instanz –-> Alles funktioniert wieder.
            mfg
            Karl-Heinz
            • wendy2702W Online
              wendy2702W Online
              Könnt ihr das auch als Github Issue posten?
              Dann bekommt derjenige der die letzten Änderungen gemacht hat das mit.
              • lobomauL Offline
                lobomauL Offline
                lobomau
                1.1.3. läuft doch bei mir. Nur bei einem Script kommt jetzt der Fehler
                Muss ich noch rausbekommen, wie man es im Script korrigiert.
                • Slave: Pi4
                • BuZZyB Offline
                  BuZZyB Offline
                  BuZZy
                  Hatte das gleiche Problem -> downgrade auf 1.1.0 hat geholfen.
                    BasGo
                    Ich würde mir das Issue gerne anschauen, könnt ihr mir einen Herleitung geben, in welchem Fall der Fehler
                    auftaucht, d.h. was ich genau tun muss?
                    Bei mir läuft v1.1.3 eigentlich recht rund, hatte auch zuletzt einen kleinen Bugfix dafür erstellt, der scheinbar auch dieses Verhalten jetzt verursachen könnte. Aber egal was ich bei mir tue (Nachricht, Nachricht mit Keyboard + Response), ich bekomme den Fehler nicht :(
                    <u>Nachtrag:</u> Die 1.1.3 gibt es noch nicht auf dem regulären Weg, Bluefox muss sie noch bei NPM publishen. Und beim Fixen hatte ich auch das Problem, dass ich die "alten" Prozesse "io.telegram.0" händisch abschießen musste .. danach lief es dann stabil(er).
                    • lobomauL Offline
                      lobomauL Offline
                      lobomau
                      @BasGo:
                      <u>Nachtrag:</u> Die 1.1.3 gibt es noch nicht auf dem regulären Weg, Bluefox muss sie noch bei NPM publishen. Und beim Fixen hatte ich auch das Problem, dass ich die "alten" Prozesse "io.telegram.0" händisch abschießen musste .. danach lief es dann stabil(er). `
                      Ich habe 1.1.3. am Laufen. Das untere Script verursacht bei mir den Fehler "Cannot send answerCallbackQuery [user - undefined]".
                      Ich kann im Handy die Trigger Wörter eintippen wie "warm", dann erscheint auch die Auswahl auf dem Handy. Wenn ich dann eine Auswahl auswähle kommt der Fehler.
                      Script:
                      on({id: 'telegram.0.communicate.request', change: 'any'}, function (obj) {
                      var stateval = getState('telegram.0.communicate.request').val; // Statevalue in Variable schreiben
                      var benutzer = stateval.substring(1,stateval.indexOf("]")); // Benutzer aus Statevalue extrahieren
                      var befehl = stateval.substring(stateval.indexOf("]")+1,stateval.length); // Befehl/Text aus Statevalue extrahieren
                      ! if (befehl.search(/(?=.*(\bTEMPERATUR\b|\bWARM\b|\bKALT\b)).+/ig) != -1) {
                      sendTo('telegram', {
                      user: benutzer,
                      text: 'Für welchen Raum möchtest du die Temperatur abfragen?',
                      reply_markup: {
                      inline_keyboard: [
                      [{ text: 'alle Räume', callback_data: '%Tempalle'},{ text: 'Draussen', callback_data: '%TempDraussen'}],
                      [{ text: 'Gästebadezimmer', callback_data: '%TempGaestebadezimmer'}],
                      [{ text: 'Wohnzimmer', callback_data: '%TempWohnzimmer'}],
                      [{ text: 'Schlafzimmer', callback_data: '%TempSchlafzimmer'},{ text: 'Badezimmer', callback_data: '%TempBadezimmer'}],
                      [{ text: 'Hobbykeller', callback_data: '%TempHobbykeller'},{ text: 'Waschkeller', callback_data: '%TempWaschkeller'}],
                      // Auswahl alle Räume oder einzeln.
                      else if (befehl === "%Tempalle") {
                      user: benutzer,
                      text: "Temperatur alle Räume angefragt",
                      answerCallbackQuery: {
                      text: 'Draussen ' + getState("hm-rpc.0.KEQ0766402.1.TEMPERATURE"/Klima_Aussen:1.TEMPERATURE/).val + '°C\nWohnzimmer ' + getState("rflink.0.channels.Baldr_1.TEMP"/Baldr_ 1 Temperature/).val + '°C\nBadezimmer ' + getState("hm-rpc.0.LEQ0998813.1.TEMPERATURE"/Klima_Bad:1.TEMPERATURE/).val + '°C\nGästebadezimmer ' + getState("hm-rpc.0.LEQ1072301.1.TEMPERATURE"/Klima_Bad_DG:1.TEMPERATURE/).val + '°C\nSchlafzimmer ' + getState("hm-rpc.2.000E9569A2407B.1.ACTUAL_TEMPERATURE"/Klima_Eltern:1.ACTUAL_TEMPERATURE/).val + '°C\nHobbykeller ' + getState("hm-rpc.0.LEQ0998792.1.TEMPERATURE"/Klima_Hobbykeller:1.TEMPERATURE/).val + '°C\nWaschkeller ' + getState("hm-rpc.0.LEQ0998786.1.TEMPERATURE"/Klima_Waschraum:1.TEMPERATURE/).val + '°C',
                      showAlert: true
                      else if (befehl === "%TempDraussen") {
                      user: benutzer,
                      text: "Temperatur Draussen angefragt",
                      text: 'Die Temperatur draußen beträgt ' + getState("hm-rpc.0.KEQ0766402.1.TEMPERATURE"/Klima_Aussen:1.TEMPERATURE/).val + '°C',
                      showAlert: true
                      else if (befehl === "%TempSchlafzimmer") {
                      user: benutzer,
                      text: "Schlafzimmertemperatur angefragt",
                      text: 'Die Temperatur im Schlafzimmer beträgt ' + getState("hm-rpc.2.000E9569A2407B.1.ACTUAL_TEMPERATURE"/Klima_Eltern:1.ACTUAL_TEMPERATURE/).val + '°C',
                      showAlert: true
                      else if (befehl === "%TempGaestebadezimmer") {
                      user: benutzer,
                      text: "Gästebadezimmertemperatur angefragt",
                      text: 'Die Temperatur im Gästebadezimmer beträgt ' + getState("hm-rpc.0.LEQ1072301.1.TEMPERATURE"/Klima_Bad_DG:1.TEMPERATURE/).val + '°C',
                      showAlert: true
                      else if (befehl === "%TempBadezimmer") {
                      user: benutzer,
                      text: "Badezimmertemperatur angefragt",
                      text: 'Die Temperatur im Bad beträgt ' + getState("hm-rpc.0.LEQ0998813.1.TEMPERATURE"/Klima_Bad:1.TEMPERATURE/).val + '°C',
                      showAlert: true
                      else if (befehl === "%TempWohnzimmer") {
                      user: benutzer,
                      text: "Wohnzimmertemperatur angefragt",
                      text: 'Die Temperatur im Wohnzimmer beträgt ' + getState("rflink.0.channels.Baldr_1.TEMP"/Baldr_ 1 Temperature/).val + '°C',
                      showAlert: true
                      else if (befehl === "%TempHobbykeller") {
                      user: benutzer,
                      text: "Hobbykellertemperatur angefragt",
                      text: 'Die Temperatur im Hobbykeller beträgt ' + getState("hm-rpc.0.LEQ0998792.1.TEMPERATURE"/Klima_Hobbykeller:1.TEMPERATURE/).val + '°C',
                      showAlert: true
                      else if (befehl === "%TempWaschkeller") {
                      user: benutzer,
                      text: "Waschkellertemperatur angefragt",
                      text: 'Die Temperatur im Waschkeller beträgt ' + getState("hm-rpc.0.LEQ0998786.1.TEMPERATURE"/Klima_Waschraum:1.TEMPERATURE/).val + '°C',
                      showAlert: true
                      • Slave: Pi4
                        BasGo
                        Der Fehler sollte nun auch gefixed sein. Pull Request für den Adapter wurde gestellt und hoffentlich gibt es danach auch eine schöne 1.1.3 per NPM-Paket. Solange bleibt nur die manuelle Installation aus meinem Fork: https://github.com/BasGo/ioBroker.telegram
                        @lobomau:
                        Ich kann im Handy die Trigger Wörter eintippen wie "warm", dann erscheint auch die Auswahl auf dem Handy. Wenn ich dann eine Auswahl auswähle kommt der Fehler. `
                        @lobomau: Übrigens ein sehr, sehr geiles Script … darf ich mir die Idee mit dem Telegram-Dialog von dir "klauen", gefällt mir! 8-)
                        • lobomauL Offline
                          lobomauL Offline
                          lobomau
                          @BasGo:
                          @lobomau:
                          @lobomau: Übrigens ein sehr, sehr geiles Script … darf ich mir die Idee mit dem Telegram-Dialog von dir "klauen", gefällt mir! 8-) `
                          Sauber. Deine Version 1.1.3 läuft wieder ohne Fehler! Vielen Dank!
                          Natürlich kannst du das Script nehmen. Hab ich doch selber geklaut :-D
                          • Slave: Pi4
                          • coyoteC Offline
                            coyoteC Offline
                            coyote
                            Ich hänge mich hier auch mal ran, ich bekomme folgende Fehlermeldung nicht mehr weg und der Adapter läuft nicht mehr.
                            Seit Update auf Version 1.1.2. Update auf 1.1.3 hab ich auch schon versucht, selbst ein komplettes löschen und neuinstallieren oder auch downgrade auf 1.1.0 geht nicht. Weiß nicht mehr was ich noch machen soll. Prozess hab ich auch schon gekillt, ohne Erfolg.
                            Auf debug umgestellt, da kommt auch nicht mehr wie der Fehler.
                            Jemand ne Idee?
                            • apollon77A Offline
                              Hey,
                              1.1.3 jetzt auf Github … morgen dann offiziell im Latest
                              • PeoplesP Offline
                                PeoplesP Offline
                                Peoples
                                @coyote:
                                Jemand ne Idee? `
                                Ging bei mir auch nicht habe den Adapter gelöscht und den iobroker neu gestartet. Nach der erneuten Installation ging alles wieder
                                • coyoteC Offline
                                  coyoteC Offline
                                  coyote
                                  Leider nicht, gerade nochmal alles deinstalliert, iobroker neu gestartet nochmal installiert, ohne Erfolg.
                                  Nach dem installieren nochmals neu gestartet, gleiches Problem
                                  • lobomauL Offline
                                    lobomauL Offline
                                    lobomau
                                    @lobomau:
                                    @BasGo:
                                    @lobomau:
                                    Natürlich kannst du das Script nehmen. Hab ich doch selber geklaut :-D `
                                    Da ist doch noch ein bug drin. Ein anderes Script wird nicht mehr ausgeführt, ein Foto sollte geschickt werden, kommt aber Fehler im log. Leider komme ich nicht mehr ans log dran nachdem ich auf 1.1.0 gegangen bin. Mit 1.1.0 läuft aber alles wieder ohne Fehler.
                                    • Slave: Pi4
                                    • lobomauL Offline
                                      lobomauL Offline
                                      lobomau
                                      @coyote:
                                      Jemand ne Idee?
                                      Telegram.PNG `
                                      Eventuell ist die Reihenfolge entscheidend!? Ich habe unter 1.1.3., zuerst die Adapter gestoppt (telegram.0 und .1), dann die beiden Prozesse gekillt (liefen nämlich noch), dann über admin downgrade auf 1.1.0 durchgeführt. Dann Adapter neugestartet. Läuft jetzt, ohne ioBroker neustarten oder Adapter löschen.
                                      • Slave: Pi4
                                        BasGo
                                        @lobomau:
                                        Da ist doch noch ein bug drin. Ein anderes Script wird nicht mehr ausgeführt, ein Foto sollte geschickt werden, kommt aber Fehler im log. Leider komme ich nicht mehr ans log dran nachdem ich auf 1.1.0 gegangen bin. Mit 1.1.0 läuft aber alles wieder ohne Fehler. `
                                        Kann den Fehler bei mir nachvollziehen, werde mich drum kümmern und hier Feedback geben.
                                        Noch vor der 1.1.2 kam irgendeine Änderung in den Code, weshalb häufig irgendwelche Instanzen als Prozess-Zomies im System geblieben sind. Bei mir musste ich auch die Prozesse von Hand killen und danach konnte ich den Adapter dann "ganz normal" starten. Mittlerweile ist die 1.1.3 auch bei NPM, allerdings ist sie (noch) nicht im Stable-Repository. Wer sich die neue Version installieren möchte, sollte entweder das "latest"-Repository verwenden oder aber über GitHub direkt gehen.
                                          BasGo
                                          @BasGo:
                                          Kann den Fehler bei mir nachvollziehen, werde mich drum kümmern und hier Feedback geben. `
                                          Bitte mal die Version von https://github.com/BasGo/ioBroker.telegram testen, das Versenden von Bildern sollte nun auch (wieder) funktionieren. Mein letzter Fix war dann doch etwas zu gründlich und ich hatte eine Passage gefixed, bei der es gar keinen Fehler gab :lol:
                                          Wenn alles OK ist, dann würde ich eine 1.1.4 als Pull Request stellen ;)
