  4. Tv Steuern
    5.9k
Tv Steuern
78 Beiträge 6 Kommentatoren 11.7k Aufrufe
  • cvidalC Offline
    cvidalC Offline
    cvidal
    Forum Testing
    So hab mir mal kurz zeit genommen :)
    Versuch das mal so:
    Der Export:
    ! <xml 1999/xmlns="<URL url=" http:/www.w3.org/xhtml"="">http://www.w3.org/1999/xhtml">
    ! <block type="on_ext" id="f80aCBk|2Svf:O%Czd7~" x="-388" y="-287"><mutation items="1"></mutation>
    ! <field name="CONDITION">ne</field>
    ! <value name="OID0"><shadow type="field_oid" id="ZjX!i@w;6xW/c:2bkIbE"><field name="oid">default</field></shadow></value>
    ! <statement name="STATEMENT"><block type="controls_if" id="4e.J#lFi*#Pj~2v1^Gr"><value name="IF0"><block type="logic_compare" id="]zt.i~y6oJt#VmnD.t4@"><field name="OP">EQ</field> ! <value name="A"><block type="get_value" id="7c0Yy-PsHn#b)._,[uHW"><field name="ATTR">val</field> ! <field name="OID">ID auswählen</field></block></value> ! <value name="B"><block type="logic_boolean" id="H7^cN4()H4qIkInU?=Pr"><field name="BOOL">TRUE</field></block></value></block></value> ! <statement name="DO0"><block type="control" id="Oy!j7)WVB_QvClOF)X_4"><mutation delay_input="true"></mutation> ! <field name="OID">Object ID</field> ! <field name="WITH_DELAY">TRUE</field> ! <field name="DELAY_MS">7</field> ! <field name="UNIT">sec</field> ! <field name="CLEAR_RUNNING">FALSE</field> ! <value name="VALUE"><block type="math_number" id="D.v|[mDpnhRPsQu2txHP"><field name="NUM">2</field></block></value></block></statement></block></statement> ! <next><block type="on_ext" id="WKS4@QPil)^STV)yabh)"><mutation items="1"></mutation> ! <field name="CONDITION">ne</field> ! <value name="OID0"><shadow type="field_oid" id="S2f9,ecgc)BxVwEvPUaA"><field name="oid">default</field></shadow></value> ! <statement name="STATEMENT"><block type="controls_if" id="wT*%ZSUTgjv9yy2wnL*3"><value name="IF0"><block type="logic_compare" id="(@xQ]percl3A!+rC}=51"><field name="OP">EQ</field> ! <value name="A"><block type="get_value" id="OCL6AxN|gEUeb%,I|sxm"><field name="ATTR">val</field> ! <field name="OID">ID auswählen</field></block></value> ! <value name="B"><block type="math_number" id="roTLq:;BLR{SoV|aUIT"><field name="NUM">0</field></block></value></block></value>
    ! <statement name="DO0"><block type="control" id="0.Fc-6P!klNK?Et@)T2V"><mutation delay_input="true"></mutation>
    ! <value name="VALUE"><block type="logic_boolean" id="7v?I9v=QY(/n%]Z5kdJ2"><field name="BOOL">FALSE</field></block></value></block></statement></block></statement></block></next></block></xml>
    Gruß Christian
      Turbo
      Hier ein Beispiel von mir mit EINEM Datenpunkt - den Datenpunkt alive musst Du manuell erstellen, dann Deine Hues und Activity eintragen…
      • F Offline
        Fabster
        Was bedeutet das Alive ???
          Turbo
          Das ist ein manuell erzeugter Datenpunkt, den Du im admin unter Objekte anlegen musst (oben mit dem Plus-Zeichen) - mit Typ Logikwert.
          Den kannst Du dann in vis als Schalter anlegen.
          • F Offline
            Fabster
            Oh Oh das ist jetzt Neuland
              Turbo
              Keine Panik, kann man ja wieder löschen..
              Machs am besten im Javascript Ordner. Namen vergeben, Typ Datenpunkt, Datenpunkttyp Logikwert.
              Dann in Blockly auswählen und ab ins vis -
              • F Offline
                Fabster
                Sorry Turbo aber hab null Plan was ich wie und wo eingeben soll !
                  Turbo
                  Sieht doch gut aus. wenn Du speicherst, sollte dieser unter Objekte angelegt werden, mit true und false.
                  • F Offline
                    Fabster
                    Welches objekt ?
                    Ich muss doch ein geräte/schalter angeben oder nicht
                      Turbo
                      Den Datenpunkt!
                      • F Offline
                        Fabster
                        :roll: :roll:
                        Ähm wie gesagt kein Plan Datenpunkt -> Ist was oder was ist gemeint
                        Der Datenpunkt simuliert was oder oder ?
                        Oder für was benötige ich einen Datenpunkt ?
                        Hab gerade gegoggelt aber kommt nix passendens.
                          Turbo
                          Ich nehme an, das ist Dein Objekt "test", das Du gerade erstellt hast?
                          • F Offline
                            Fabster
                            Richtig habe es mal test genannt
                              Turbo
                              Dann ist das der Datenpunkt.
                              • F Offline
                                Fabster
                                Hab den Test eingepflegt aber funktioniert nicht !
                                  Turbo
                                  Hast Du den Test auch als Schalter im vis übernommen?
                                  • F Offline
                                    Fabster
                                    Ja hab ich.
                                    Aber sollte ja auch gehen wenn ich die funksteckdosen über die Hue app einschalte
                                    • cvidalC Offline
                                      cvidalC Offline
                                      cvidal
                                      Forum Testing
                                      @Fabster:
                                      Ja hab ich.
                                      Aber sollte ja auch gehen wenn ich die funksteckdosen über die Hue app einschalte `
                                      Das geht so nicht, du fragst den Datenpunkt "Test" ab.
                                      Funktionier es denn über die Visu?
                                      Hast du das so gemacht?
                                      Edti: Du kannst auch mit dem Steckdosen Objekt deinen "Test" Datenpunkt ändern dann würde es auch bei Steckdosen änderung gehen.
                                      • F Offline
                                        Fabster
                                        Habe beide Vorschläge nach gebaut und getestet.
                                        Hab den Test als Schalter in der VIS eingesetzt
                                        • cvidalC Offline
                                          cvidalC Offline
                                          cvidal
                                          Forum Testing
                                          Jetzt wäre es noch schön wenn du uns veraten ob da irgendwas von Fukntioniert…
                                          In deinem nachgestellten Skripte von Turbo hast du im Trigger keinen Datenpunkt angegeben, da muss "Test" rein
                                          Gruß Christian
