  4. ioBroker/Raspi stürzt 3-4min nach dem starten ab
    6.3k
21 Beiträge 3 Kommentatoren 566 Aufrufe 3 Beobachtet
  • B beetle-fan
    So, einmal System neu auf trixie gebracht, Backups eingespielt - und schon läuft wieder alles, als wäre nichts gewesen. Sachen gibt's...
    @beetle-fan
    Wie schaut jetzt ein Lauf von
    iob diag
    aus?
      beetle-fan
      Sieht gut aus:
      ```bash
      Script v.2026-06-01
      *** BASE SYSTEM ***
      Operating System: Debian GNU/Linux 13 (trixie)
       Static hostname: ioBroker
             Icon name: computer
                Kernel: Linux 6.12.75+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64bit
      System was installed 56 days ago (on 2026-04-21).
      Systemuptime and Load:
       21:23:45 up  6:34,  1 user,  load average: 1.13, 0.50, 0.32
      CPU threads     : 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'trixie'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2026-06-16 21:23:46 CEST
                 Universal time: Tue 2026-06-16 19:23:46 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users netdev gpio i2c spi render input iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server:         Unknown
      Display-Manager:        Not found
      Desktop:
      Session:                tty
      Boot Target:            multi-user.target
      *** MEMORY ***
      Mem:            4.0G        3.3G        333M        4.0M        474M        713M
      Swap:           2.1G        1.1G        1.1G
      Total:          6.1G        4.3G        1.4G
      Active iob-Instances:   36
               3796 M total memory
               3116 M used memory
               1703 M active memory
               1101 M inactive memory
                317 M free memory
                 21 M buffer memory
                431 M swap cache
               2047 M total swap
               1031 M used swap
               1016 M free swap
      top - 21:23:46 up  6:34,  1 user,  load average: 1.13, 0.50, 0.32
      Tasks: 218 total,   1 running, 217 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  4.1 sy,  0.0 ni, 93.9 id,  2.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3796.7 total,    317.0 free,   3117.3 used,    453.4 buff/cache
      MiB Swap:   2048.0 total,   1016.9 free,   1031.1 used.    679.4 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     760M   10M  750M   2% /run
      /dev/mmcblk0p2 ext4       29G  9.8G   18G  36% /
      tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
      tmpfs          tmpfs     1.9G  2.6M  1.9G   1% /tmp
      /dev/mmcblk0p1 vfat      505M   67M  439M  14% /boot/firmware
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/serial-getty@ttyS0.service
      tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
      tmpfs          tmpfs     380M  8.0K  380M   1% /run/user/1000
      Messages concerning filesystems in dmesg:
      [Tue Jun 16 14:49:07 2026] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
      [Tue Jun 16 14:49:07 2026] EXT4-fs (mmcblk0p2): mounted filesystem e634e0a4-a958-46cb-abad-862d2102573f ro with ordered data mode. Quota mode: none.
      [Tue Jun 16 14:49:09 2026] EXT4-fs (mmcblk0p2): re-mounted e634e0a4-a958-46cb-abad-862d2102573f r/w.
      Show mounted filesystems:
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.5G    /var/
      306M    /var/cache
      301M    /var/cache/apt
      183M    /var/lib
      169M    /var/cache/apt/archives
      Archived and active journals take up 8.9M in the file system.
      /opt/iobroker/backups:
      73M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      2.1G    /opt/iobroker/iobroker-data/
      1.5G    /opt/iobroker/iobroker-data/history
      541M    /opt/iobroker/iobroker-data/files
      149M    /opt/iobroker/iobroker-data/files/vis-2
      113M    /opt/iobroker/iobroker-data/files/vis
      65M     /opt/iobroker/iobroker-data/objects.jsonl
      30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
      23M     /opt/iobroker/iobroker-data/states.jsonl
      11M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js
      9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
      USB-Devices by-id:
      USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
      please always prefer the links 'by-id':
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_ca3a7c601822ec1197b220c32c86906c-if00-port0
      *** ZigBee Settings ***
      ⚠ HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'.
      Please check your setting:
      /dev/ttyUSB0
      Zigbee Network Settings on your coordinator / in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      === ZigBee Port Overview ===
      Instance        Configured Port                     Available by-id Port                Status
      zigbee.0        /dev/ttyUSB0                        ...b220c32c86906c-if00-port0        ✗ Not matching
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v22.22.3
      /usr/bin/node           v22.22.3
      /usr/bin/npm            10.9.8
      /usr/bin/npx            10.9.8
      ✓ Node.js installation is correct
      nodejs:
        Installed: 22.22.3-1nodesource1
        Candidate: 22.22.3-1nodesource1
        Version table:
       *** 22.22.3-1nodesource1 1001
              500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
           22.22.2-1nodesource1 1001
           22.22.1-1nodesource1 1001
           22.22.0-1nodesource1 1001
           22.21.0-1nodesource1 1001
           22.20.0-1nodesource1 1001
           22.19.0-1nodesource1 1001
           22.18.0-1nodesource1 1001
           22.17.1-1nodesource1 1001
           22.17.0-1nodesource1 1001
           22.16.0-1nodesource1 1001
           22.15.1-1nodesource1 1001
           22.15.0-1nodesource1 1001
           22.14.0-1nodesource1 1001
           22.13.1-1nodesource1 1001
           22.13.0-1nodesource1 1001
           22.12.0-1nodesource1 1001
           22.11.0-1nodesource1 1001
           22.10.0-1nodesource1 1001
           22.9.0-1nodesource1 1001
           22.8.0-1nodesource1 1001
           22.7.0-1nodesource1 1001
           22.6.0-1nodesource1 1001
           22.5.1-1nodesource1 1001
           22.5.0-1nodesource1 1001
           22.4.1-1nodesource1 1001
           22.4.0-1nodesource1 1001
           22.3.0-1nodesource1 1001
           22.2.0-1nodesource1 1001
           22.1.0-1nodesource1 1001
           22.0.0-1nodesource1 1001
           20.19.2+dfsg-1+deb13u2 500
              500 http://deb.debian.org/debian trixie/main arm64 Packages
              500 http://deb.debian.org/debian-security trixie-security/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      No known Vulnerabilities detected!
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      ioBroker            ioBroker (version: 7.1.2, hostname: ioBroker      , alive, uptime: 15632)
      Core adapters versions
      js-controller:  7.1.2
      admin:          7.9.1
      javascript:     9.0.18
      nodejs modules from github:     4
      +-- iobroker.frontier_silicon@0.5.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.frontier_silicon.git#ac6586bd756ba285fb9495d17fee4b3b38001152)
      +-- iobroker.mammotion@0.0.8 (git+ssh://git@github.com/DNAngelX/ioBroker.mammotion.git#f029aaddfc9b9ab3b1c41d716090ee8e5700b165)
      | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      Adapter State
      + system.adapter.admin.1                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alarm.0                  : alarm                 : ioBroker                                 - disabled
        system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
      + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
      + system.adapter.brightsky.0              : brightsky             : ioBroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
      + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
        system.adapter.devices.0                : devices               : ioBroker                                 - disabled
      + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
      + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
        system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 - disabled
      + system.adapter.eusec.0                  : eusec                 : ioBroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
      + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
      + system.adapter.frontier_silicon.0       : frontier_silicon      : ioBroker                                 -  enabled
      + system.adapter.history.0                : history               : ioBroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.3                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
      + system.adapter.homeconnect.0            : homeconnect           : ioBroker                                 -  enabled
      + system.adapter.hoymiles.0               : hoymiles              : ioBroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
        system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: ioBroker                                 - disabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
      + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
        system.adapter.logparser.0              : logparser             : ioBroker                                 - disabled
        system.adapter.mammotion.0              : mammotion             : ioBroker                                 - disabled
        system.adapter.mercedesme.0             : mercedesme            : ioBroker                                 - disabled
      + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1888, bind: 0.0.0.0
        system.adapter.mqtt.1                   : mqtt                  : ioBroker                                 - disabled, port: 1887, bind: 0.0.0.0
      + system.adapter.mqtt.2                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.mqtt.3                   : mqtt                  : ioBroker                                 - disabled, port: 1890, bind: 0.0.0.0
      + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
      + system.adapter.openligadb.0             : openligadb            : ioBroker                                 -  enabled
        system.adapter.parcel.0                 : parcel                : ioBroker                                 - disabled
      + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
      + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
      + system.adapter.sainlogic.0              : sainlogic             : ioBroker                                 -  enabled, port: 45000, bind: 0.0.0.0
        system.adapter.samsung.0                : samsung               : ioBroker                                 - disabled
        system.adapter.samsung_tizen.0          : samsung_tizen         : ioBroker                                 - disabled, port: 8002
        system.adapter.schoolfree.0             : schoolfree            : ioBroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.smartcontrol.0           : smartcontrol          : ioBroker                                 -  enabled
      + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
      + system.adapter.sonos.0                  : sonos                 : ioBroker                                 -  enabled
        system.adapter.spotify-premium.0        : spotify-premium       : ioBroker                                 - disabled
        system.adapter.sprinklecontrol.0        : sprinklecontrol       : ioBroker                                 - disabled
        system.adapter.synology.0               : synology              : ioBroker                                 - disabled, port: 5000
        system.adapter.tr-064.0                 : tr-064                : ioBroker                                 - disabled
      + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
        system.adapter.upnp.0                   : upnp                  : ioBroker                                 - disabled
        system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: ioBroker                                 - disabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 - disabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 - disabled
        system.adapter.vis-2-widgets-icontwo.0  : vis-2-widgets-icontwo : ioBroker                                 - disabled
        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 - disabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 - disabled
        system.adapter.vis-2-widgets-ovarious.0 : vis-2-widgets-ovarious: ioBroker                                 - disabled
        system.adapter.vis-2-widgets-rssfeed.0  : vis-2-widgets-rssfeed : ioBroker                                 - disabled
        system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: ioBroker                                 - disabled
      + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
        system.adapter.vis-homekittiles.0       : vis-homekittiles      : ioBroker                                 - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
        system.adapter.vis.0                    : vis                   : ioBroker                                 - disabled
      + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
        system.adapter.yahka.1                  : yahka                 : ioBroker                                 - disabled
      + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      │ (index) │ id                                                 │ name                                │ version  │ upgrade policy │
      │ 0       │ 'system.adapter.admin'                             │ 'admin'                             │ '7.9.1'  │ 'none'         │
      │ 1       │ 'system.adapter.alarm'                             │ 'alarm'                             │ '3.7.6'  │ 'none'         │
      │ 2       │ 'system.adapter.alias-manager'                     │ 'alias-manager'                     │ '2.1.0'  │ 'none'         │
      │ 3       │ 'system.adapter.backitup'                          │ 'backitup'                          │ '3.3.17' │ 'none'         │
      │ 4       │ 'system.adapter.brightsky'                         │ 'brightsky'                         │ '1.1.0'  │ 'none'         │
      │ 5       │ 'system.adapter.cloud'                             │ 'cloud'                             │ '6.0.1'  │ 'none'         │
      │ 6       │ 'system.adapter.device-reminder'                   │ 'device-reminder'                   │ '3.1.2'  │ 'none'         │
      │ 7       │ 'system.adapter.devices'                           │ 'devices'                           │ '1.2.14' │ 'none'         │
      │ 8       │ 'system.adapter.discovery'                         │ 'discovery'                         │ '5.0.0'  │ 'none'         │
      │ 9       │ 'system.adapter.dwd'                               │ 'dwd'                               │ '2.8.5'  │ 'none'         │
      │ 10      │ 'system.adapter.echarts'                           │ 'echarts'                           │ '3.1.0'  │ 'none'         │
      │ 11      │ 'system.adapter.energiefluss-erweitert'            │ 'energiefluss-erweitert'            │ '0.8.1'  │ 'none'         │
      │ 12      │ 'system.adapter.eusec'                             │ 'eusec'                             │ '2.0.3'  │ 'none'         │
      │ 13      │ 'system.adapter.feiertage'                         │ 'feiertage'                         │ '1.4.0'  │ 'none'         │
      │ 14      │ 'system.adapter.flot'                              │ 'flot'                              │ '1.12.0' │ 'none'         │
      │ 15      │ 'system.adapter.followthesun'                      │ 'followthesun'                      │ '0.5.2'  │ 'none'         │
      │ 16      │ 'system.adapter.frontier_silicon'                  │ 'frontier_silicon'                  │ '0.5.1'  │ 'none'         │
      │ 17      │ 'system.adapter.history'                           │ 'history'                           │ '4.0.0'  │ 'none'         │
      │ 18      │ 'system.adapter.hm-rega'                           │ 'hm-rega'                           │ '5.1.0'  │ 'none'         │
      │ 19      │ 'system.adapter.hm-rpc'                            │ 'hm-rpc'                            │ '3.0.1'  │ 'none'         │
      │ 20      │ 'system.adapter.homeconnect'                       │ 'homeconnect'                       │ '1.6.1'  │ 'none'         │
      │ 21      │ 'system.adapter.hoymiles'                          │ 'hoymiles'                          │ '0.3.5'  │ 'none'         │
      │ 22      │ 'system.adapter.ical'                              │ 'ical'                              │ '1.20.1' │ 'none'         │
      │ 23      │ 'system.adapter.icons-addictive-flavour-png'       │ 'icons-addictive-flavour-png'       │ '0.1.0'  │ 'none'         │
      │ 24      │ 'system.adapter.icons-eclipse-smarthome-classic'   │ 'icons-eclipse-smarthome-classic'   │ '1.0.0'  │ 'none'         │
      │ 25      │ 'system.adapter.icons-fatcow-hosting'              │ 'icons-fatcow-hosting'              │ '0.1.0'  │ 'none'         │
      │ 26      │ 'system.adapter.icons-icons8'                      │ 'icons-icons8'                      │ '0.0.1'  │ 'none'         │
      │ 27      │ 'system.adapter.icons-mfd-png'                     │ 'icons-mfd-png'                     │ '1.2.1'  │ 'none'         │
      │ 28      │ 'system.adapter.icons-ultimate-png'                │ 'icons-ultimate-png'                │ '1.0.1'  │ 'none'         │
      │ 29      │ 'system.adapter.javascript'                        │ 'javascript'                        │ '9.0.18' │ 'none'         │
      │ 30      │ 'system.adapter.logparser'                         │ 'logparser'                         │ '2.5.0'  │ 'none'         │
      │ 31      │ 'system.adapter.mammotion'                         │ 'mammotion'                         │ '0.0.8'  │ 'none'         │
      │ 32      │ 'system.adapter.mercedesme'                        │ 'mercedesme'                        │ '0.2.2'  │ 'none'         │
      │ 33      │ 'system.adapter.mqtt'                              │ 'mqtt'                              │ '6.1.4'  │ 'none'         │
      │ 34      │ 'system.adapter.notification-manager'              │ 'notification-manager'              │ '1.3.0'  │ 'none'         │
      │ 35      │ 'system.adapter.openligadb'                        │ 'openligadb'                        │ '1.9.3'  │ 'none'         │
      │ 36      │ 'system.adapter.parcel'                            │ 'parcel'                            │ '0.3.0'  │ 'none'         │
      │ 37      │ 'system.adapter.pollenflug'                        │ 'pollenflug'                        │ '2.0.0'  │ 'none'         │
      │ 38      │ 'system.adapter.pushover'                          │ 'pushover'                          │ '5.0.0'  │ 'none'         │
      │ 39      │ 'system.adapter.sainlogic'                         │ 'sainlogic'                         │ '1.2.3'  │ 'none'         │
      │ 40      │ 'system.adapter.samsung'                           │ 'samsung'                           │ '0.7.0'  │ 'none'         │
      │ 41      │ 'system.adapter.samsung_tizen'                     │ 'samsung_tizen'                     │ '1.1.0'  │ 'none'         │
      │ 42      │ 'system.adapter.schoolfree'                        │ 'schoolfree'                        │ '2.0.0'  │ 'none'         │
      │ 43      │ 'system.adapter.simple-api'                        │ 'simple-api'                        │ '3.0.7'  │ 'none'         │
      │ 44      │ 'system.adapter.smartcontrol'                      │ 'smartcontrol'                      │ '2.0.1'  │ 'none'         │
      │ 45      │ 'system.adapter.snmp'                              │ 'snmp'                              │ '3.4.0'  │ 'none'         │
      │ 46      │ 'system.adapter.socketio'                          │ 'socketio'                          │ '7.1.3'  │ 'none'         │
      │ 47      │ 'system.adapter.sonos'                             │ 'sonos'                             │ '3.0.0'  │ 'none'         │
      │ 48      │ 'system.adapter.spotify-premium'                   │ 'spotify-premium'                   │ '2.0.3'  │ 'none'         │
      │ 49      │ 'system.adapter.sprinklecontrol'                   │ 'sprinklecontrol'                   │ '0.2.19' │ 'none'         │
      │ 50      │ 'system.adapter.synology'                          │ 'synology'                          │ '3.1.0'  │ 'none'         │
      │ 51      │ 'system.adapter.tr-064'                            │ 'tr-064'                            │ '4.3.0'  │ 'none'         │
      │ 52      │ 'system.adapter.trashschedule'                     │ 'trashschedule'                     │ '5.3.0'  │ 'none'         │
      │ 53      │ 'system.adapter.upnp'                              │ 'upnp'                              │ '1.1.0'  │ 'none'         │
      │ 54      │ 'system.adapter.vis'                               │ 'vis'                               │ '1.5.6'  │ 'none'         │
      │ 55      │ 'system.adapter.vis-2'                             │ 'vis-2'                             │ '2.13.7' │ 'none'         │
      │ 56      │ 'system.adapter.vis-2-widgets-collection'          │ 'vis-2-widgets-collection'          │ '1.8.1'  │ 'none'         │
      │ 57      │ 'system.adapter.vis-2-widgets-energy'              │ 'vis-2-widgets-energy'              │ '1.0.2'  │ 'none'         │
      │ 58      │ 'system.adapter.vis-2-widgets-gauges'              │ 'vis-2-widgets-gauges'              │ '2.0.2'  │ 'none'         │
      │ 59      │ 'system.adapter.vis-2-widgets-icontwo'             │ 'vis-2-widgets-icontwo'             │ '1.40.0' │ 'none'         │
      │ 60      │ 'system.adapter.vis-2-widgets-inventwo'            │ 'vis-2-widgets-inventwo'            │ '1.0.0'  │ 'none'         │
      │ 61      │ 'system.adapter.vis-2-widgets-material'            │ 'vis-2-widgets-material'            │ '1.6.1'  │ 'none'         │
      │ 62      │ 'system.adapter.vis-2-widgets-ovarious'            │ 'vis-2-widgets-ovarious'            │ '2.0.0'  │ 'none'         │
      │ 63      │ 'system.adapter.vis-2-widgets-rssfeed'             │ 'vis-2-widgets-rssfeed'             │ '1.2.2'  │ 'none'         │
      │ 64      │ 'system.adapter.vis-2-widgets-weather-and-heating' │ 'vis-2-widgets-weather-and-heating' │ '1.3.0'  │ 'none'         │
      │ 65      │ 'system.adapter.vis-google-fonts'                  │ 'vis-google-fonts'                  │ '1.0.4'  │ 'none'         │
      │ 66      │ 'system.adapter.vis-homekittiles'                  │ 'vis-homekittiles'                  │ '0.4.6'  │ 'none'         │
      │ 67      │ 'system.adapter.vis-hqwidgets'                     │ 'vis-hqwidgets'                     │ '1.6.1'  │ 'none'         │
      │ 68      │ 'system.adapter.vis-icontwo'                       │ 'vis-icontwo'                       │ '2.11.3' │ 'none'         │
      │ 69      │ 'system.adapter.vis-jqui-mfd'                      │ 'vis-jqui-mfd'                      │ '1.1.3'  │ 'none'         │
      │ 70      │ 'system.adapter.vis-materialdesign'                │ 'vis-materialdesign'                │ '0.5.9'  │ 'none'         │
      │ 71      │ 'system.adapter.vis-plumb'                         │ 'vis-plumb'                         │ '1.0.2'  │ 'none'         │
      │ 72      │ 'system.adapter.vis-timeandweather'                │ 'vis-timeandweather'                │ '1.2.2'  │ 'none'         │
      │ 73      │ 'system.adapter.web'                               │ 'web'                               │ '8.0.0'  │ 'none'         │
      │ 74      │ 'system.adapter.ws'                                │ 'ws'                                │ '4.1.0'  │ 'none'         │
      │ 75      │ 'system.adapter.yahka'                             │ 'yahka'                             │ '1.1.5'  │ 'none'         │
      │ 76      │ 'system.adapter.zigbee'                            │ 'zigbee'                            │ '3.3.5'  │ 'none'         │
      ioBroker-Adapter Versions and update status
      Used repository: stable
      Adapter    "admin"        : 7.8.23   , installed 7.9.1
      Adapter    "alarm"        : 3.7.6    , installed 3.7.6
      Adapter    "alias-manager": 2.1.0    , installed 2.1.0
      Adapter    "backitup"     : 3.3.17   , installed 3.3.17
      Adapter    "brightsky"    : 1.0.1    , installed 1.1.0
      Adapter    "cloud"        : 6.0.1    , installed 6.0.1
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "devices"      : 1.2.14   , installed 1.2.14
      Adapter    "echarts"      : 3.1.0    , installed 3.1.0
      Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
      Adapter    "eusec"        : 2.0.3    , installed 2.0.3
      Adapter    "feiertage"    : 1.4.0    , installed 1.4.0
      Adapter    "followthesun" : 0.5.2    , installed 0.5.2
      Adapter    "frontier_silicon": 0.5.1 , installed 0.5.1
      Adapter    "history"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
      Adapter    "homeconnect"  : 1.6.1    , installed 1.6.1
      Adapter    "ical"         : 1.20.1   , installed 1.20.1
      Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
      Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
      Adapter    "javascript"   : 9.0.18   , installed 9.0.18
      Controller "js-controller": 7.1.2    , installed 7.1.2
      Adapter    "logparser"    : 2.5.0    , installed 2.5.0
      Adapter    "notification-manager": 1.3.0, installed 1.3.0
      Adapter    "openligadb"   : 1.9.3    , installed 1.9.3
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "pushover"     : 5.0.0    , installed 5.0.0
      Adapter    "sainlogic"    : 1.2.3    , installed 1.2.3
      Adapter    "samsung"      : 0.7.0    , installed 0.7.0
      Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
      Adapter    "schoolfree"   : 2.0.0    , installed 2.0.0
      Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
      Adapter    "smartcontrol" : 2.0.1    , installed 2.0.1
      Adapter    "snmp"         : 3.4.0    , installed 3.4.0
      Adapter    "socketio"     : 7.1.3    , installed 7.1.3
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "spotify-premium": 2.0.3  , installed 2.0.3
      Adapter    "sprinklecontrol": 0.2.19 , installed 0.2.19
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "trashschedule": 5.3.0    , installed 5.3.0
      Adapter    "upnp"         : 1.1.0    , installed 1.1.0
      Adapter    "vis-2"        : 2.13.8   , installed 2.13.7 [Updatable]
      Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 2.0.2, installed 2.0.2
      Adapter    "vis-2-widgets-icontwo": 1.40.0, installed 1.40.0
      Adapter    "vis-2-widgets-inventwo": 1.4.0, installed 1.0.0 [Updatable]
      Adapter    "vis-2-widgets-material": 1.6.1, installed 1.6.1
      Adapter    "vis-2-widgets-ovarious": 2.0.0, installed 2.0.0
      Adapter    "vis-2-widgets-rssfeed": 1.2.2, installed 1.2.2
      Adapter    "vis-2-widgets-weather-and-heating": 1.3.0, installed 1.3.0
      Adapter    "vis-homekittiles": 0.4.6 , installed 0.4.6
      Adapter    "vis-hqwidgets": 1.6.1    , installed 1.6.1
      Adapter    "vis-icontwo"  : 2.11.3   , installed 2.11.3
      Adapter    "vis-jqui-mfd" : 1.1.3    , installed 1.1.3
      Adapter    "web"          : 8.0.0    , installed 8.0.0
      Adapter    "ws"           : 4.1.0    , installed 4.1.0
      Adapter    "yahka"        : 1.1.5    , installed 1.1.5
      Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
      Objects and States
      Objects:        25153
      States:         18046
      Hit:1 http://deb.debian.org/debian trixie InRelease
      Hit:2 http://deb.debian.org/debian trixie-updates InRelease
      Hit:3 http://archive.raspberrypi.com/debian trixie InRelease
      Hit:4 http://deb.debian.org/debian-security trixie-security InRelease
      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
      Reading package lists...
      Pending systemupdates: 0
      *** Listening Ports ***
      Netid State  Recv-Q Send-Q              Local Address:Port          Peer Address:PortProcess
      udp   UNCONN 0      0                         0.0.0.0:mdns               0.0.0.0:*    users:(("avahi-daemon",pid=604,fd=12))
      udp   UNCONN 0      0                         0.0.0.0:42912              0.0.0.0:*    users:(("io.eusec.0",pid=32737,fd=38))
      udp   UNCONN 0      0                         0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=22820,fd=5),("systemd",pid=1,fd=169))
      udp   UNCONN 0      0                         0.0.0.0:57697              0.0.0.0:*    users:(("io.eusec.0",pid=32737,fd=36))
      udp   UNCONN 0      0                         0.0.0.0:57854              0.0.0.0:*    users:(("io.snmp.0",pid=32907,fd=35))
      udp   UNCONN 0      0                         0.0.0.0:39664              0.0.0.0:*    users:(("rpc.statd",pid=25800,fd=8))
      udp   UNCONN 0      0                         0.0.0.0:58224              0.0.0.0:*    users:(("avahi-daemon",pid=604,fd=14))
      udp   UNCONN 0      0                       127.0.0.1:960                0.0.0.0:*    users:(("rpc.statd",pid=25800,fd=5))
      udp   UNCONN 0      0                               *:mdns                     *:*    users:(("avahi-daemon",pid=604,fd=13))
      udp   UNCONN 0      0                               *:40966                    *:*    users:(("avahi-daemon",pid=604,fd=15))
      udp   UNCONN 0      0                               *:sunrpc                   *:*    users:(("rpcbind",pid=22820,fd=7),("systemd",pid=1,fd=177))
      udp   UNCONN 0      0                               *:53596                    *:*    users:(("rpc.statd",pid=25800,fd=10))
      udp   UNCONN 0      0                               *:8555                     *:*    users:(("go2rtc",pid=33273,fd=9))
      udp   UNCONN 0      0      [fe80::e65f:1ff:fe74:f61c]:dhcpv6-client            *:*    users:(("NetworkManager",pid=663,fd=34))
      tcp   LISTEN 0      511                192.168.178.59:9292               0.0.0.0:*    users:(("io.hm-rpc.3",pid=32802,fd=35))
      tcp   LISTEN 0      511                       0.0.0.0:1888               0.0.0.0:*    users:(("io.mqtt.0",pid=32818,fd=35))
      tcp   LISTEN 0      511                192.168.178.59:2001               0.0.0.0:*    users:(("io.hm-rpc.0",pid=33413,fd=35))
      tcp   LISTEN 0      511                192.168.178.59:2010               0.0.0.0:*    users:(("io.hm-rpc.1",pid=32774,fd=35))
      tcp   LISTEN 0      511                       0.0.0.0:1883               0.0.0.0:*    users:(("io.mqtt.2",pid=32825,fd=35))
      tcp   LISTEN 0      4096                      0.0.0.0:sunrpc             0.0.0.0:*    users:(("rpcbind",pid=22820,fd=4),("systemd",pid=1,fd=168))
      tcp   LISTEN 0      128                       0.0.0.0:ssh                0.0.0.0:*    users:(("sshd",pid=6425,fd=6))
      tcp   LISTEN 0      511                       0.0.0.0:35007              0.0.0.0:*    users:(("io.yahka.0",pid=32927,fd=30))
      tcp   LISTEN 0      511                192.168.178.59:8701               0.0.0.0:*    users:(("io.hm-rpc.2",pid=32781,fd=35))
      tcp   LISTEN 0      4096                      0.0.0.0:55683              0.0.0.0:*    users:(("rpc.statd",pid=25800,fd=9))
      tcp   LISTEN 0      511                     127.0.0.1:9001               0.0.0.0:*    users:(("iobroker.js-con",pid=32524,fd=23))
      tcp   LISTEN 0      511                     127.0.0.1:9000               0.0.0.0:*    users:(("iobroker.js-con",pid=32524,fd=29))
      tcp   LISTEN 0      511                             *:3500                     *:*    users:(("io.sonos.0",pid=32919,fd=31))
      tcp   LISTEN 0      4096                            *:1984                     *:*    users:(("go2rtc",pid=33273,fd=8))
      tcp   LISTEN 0      511                             *:45000                    *:*    users:(("io.sainlogic.0",pid=33090,fd=35))
      tcp   LISTEN 0      511                             *:tproxy                   *:*    users:(("io.admin.1",pid=32552,fd=36))
      tcp   LISTEN 0      511                             *:8082                     *:*    users:(("io.web.0",pid=33192,fd=35))
      tcp   LISTEN 0      511                             *:8087                     *:*    users:(("io.simple-api.0",pid=33101,fd=35))
      tcp   LISTEN 0      4096                         [::]:sunrpc                [::]:*    users:(("rpcbind",pid=22820,fd=6),("systemd",pid=1,fd=170))
      tcp   LISTEN 0      128                          [::]:ssh                   [::]:*    users:(("sshd",pid=6425,fd=7))
      tcp   LISTEN 0      4096                            *:8555                     *:*    users:(("go2rtc",pid=33273,fd=7))
      tcp   LISTEN 0      4096                            *:8554                     *:*    users:(("go2rtc",pid=33273,fd=6))
      tcp   LISTEN 0      4096                         [::]:41267                 [::]:*    users:(("rpc.statd",pid=25800,fd=11))
      2026-06-16 21:21:27.093  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:21:37.103  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:21:47.119  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:21:57.090  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:22:07.562  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:22:17.115  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:22:27.116  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:22:37.107  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:22:47.105  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:22:57.106  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:23:07.557  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:23:17.116  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:23:27.117  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:23:37.119  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:23:47.115  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:23:57.153  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:24:07.594  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:24:17.119  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:24:27.130  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:24:37.174  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:24:51.440  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:24:57.865  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:25:09.233  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:25:17.236  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      2026-06-16 21:25:27.133  - info: sainlogic.0 (33090) State value to set for "sainlogic.0.info.last_update" has to be type "number" but received type "string"
      ============= Mark until here for C&P =============
      HomoranH Thomas BraunT 3 Antworten Letzte Antwort
      • B beetle-fan
        Sieht gut aus:
        ```bash
        Script v.2026-06-01
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64bit
        CPU threads     : 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Session:                tty
        *** MEMORY ***
                 3796 M total memory
                 3116 M used memory
                  317 M free memory
                   21 M buffer memory
                  431 M swap cache
                 2047 M total swap
                 1031 M used swap
                 1016 M free swap
        *** FILESYSTEM ***
        /var:
        2.5G    /var/
        306M    /var/cache
        301M    /var/cache/apt
        183M    /var/lib
        USB-Devices by-id:
        ⚠ HINT:
        /dev/ttyUSB0
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.8
        /usr/bin/npx            10.9.8
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.9.1
        javascript:     9.0.18
        Adapter State
        + instance is alive
        Objects and States
        Objects:        25153
        States:         18046
        @beetle-fan sagte:
        Wie geht das denn?
          @beetle-fan sagte:
          Wie geht das denn?
          @Homoran sagte:
          Wie geht das denn?
          Die Aussage dazu ist etwas unscharf. Das Datum wird aus dem Installationsimage übernommen.
          • B beetle-fan
            Sieht gut aus:
            ```bash
            Script v.2026-06-01
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            OS is similar to:
            Docker          : false
            Kernel          : aarch64
            Userland        : 64bit
            CPU threads     : 4
            Current issues:
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            pi
            HOME=/home/pi
            iobroker
            HOME=/home/iobroker
            Desktop:
            Session:                tty
            *** MEMORY ***
                     3796 M total memory
                     3116 M used memory
                      317 M free memory
                       21 M buffer memory
                      431 M swap cache
                     2047 M total swap
                     1031 M used swap
                     1016 M free swap
            *** FILESYSTEM ***
            /var:
            2.5G    /var/
            306M    /var/cache
            301M    /var/cache/apt
            183M    /var/lib
            USB-Devices by-id:
            ⚠ HINT:
            /dev/ttyUSB0
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.9.8
            /usr/bin/npx            10.9.8
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            admin:          7.9.1
            javascript:     9.0.18
            Adapter State
            + instance is alive
            Objects and States
            Objects:        25153
            States:         18046
            @beetle-fan sagte:
            Sieht auch nicht gut aus!
            @beetle-fan sagte:
            /dev/ttyUSB0
            Auch hier noch Potential
            @beetle-fan sagte:
            76 instanzen erklären dann auch den mageren available RAM
            • B beetle-fan
              Sieht gut aus:
              ```bash
              Script v.2026-06-01
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64bit
              CPU threads     : 4
              Current issues:
                               RTC time: n/a
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              Desktop:
              Session:                tty
              *** MEMORY ***
                       3796 M total memory
                       3116 M used memory
                        317 M free memory
                         21 M buffer memory
                        431 M swap cache
                       2047 M total swap
                       1031 M used swap
                       1016 M free swap
              *** FILESYSTEM ***
              /var:
              2.5G    /var/
              306M    /var/cache
              301M    /var/cache/apt
              183M    /var/lib
              USB-Devices by-id:
              ⚠ HINT:
              /dev/ttyUSB0
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.9.8
              /usr/bin/npx            10.9.8
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.9.1
              javascript:     9.0.18
              Adapter State
              + instance is alive
              Objects and States
              Objects:        25153
              States:         18046
              @beetle-fan sagte:
              pi
              HOME=/home/pi
              Warum hast du nicht wie vorgesehen einen eigenen User angelegt?
              Bring das übereinander.
              Installier den frontier_silicon aus einem Repo, nicht wild aus dem GitHub.
              Bing die anderen Adapter auf Stand.
              Korrigier das.
                @beetle-fan sagte:
                @beetle-fan sagte:
                /dev/ttyUSB0
                @beetle-fan sagte:
                @Homoran
                Aber viel mehr dürfen es bei 4GB RAM auch nicht werden.
                HomoranH B 2 Antworten Letzte Antwort
                  @Homoran
                  @Thomas-Braun du änderst zu oft den output! 😉
                  Was sind denn jetzt in der liste mit 76?
                    @beetle-fan sagte:
                    pi
                    HOME=/home/pi
                    Korrigier das.
                    beetle-fan
                    @Thomas-Braun sagte:
                    Das ist doch mein User? habe ich beim aufsetzen des Systems so benannt.
                    Hm, hatte ich nicht gefunden. Hab den heute erst neu installiert.
                    Schon erledigt, bis auf den Vis-2 Adapter, da habe ich auch mit der 2.13.8 das Problem, das ich den Dark-Mode nicht deaktiviert bekomme.
                    Korrigier das.
                    Kann ich den Datenpunkt einfach auf string umstellen?
                      @Homoran
                      Das sind die insgesamt installierten Adapter. Aber davon sind ja nur 36 aktiv.
                        @Homoran
                        beetle-fan
                        @Homoran
                        Hm, dann muss ich wohl demnächst mal auf Pi5 upgraden...
                        • B beetle-fan
                          Korrigier das.
                          @beetle-fan sagte:
                          Man nennt den ersten user aber nicht mehr 'pi'.
                          GitHub ist NIE eine erste Anlaufstelle für Adapterinstallationen. Wer hat diese Unart eigentlich eingeführt?
                          github:	0.5.1
                          latest:	0.5.1 for 3 months
                          stable:	0.5.1 for 3 months
                          Ist doch überall vorhanden...
                          iob upgrade frontier_silicon@0.5.1
                            beetle-fan
                            OK, hast recht. Da habe ich wohl nicht aufgepasst, ist nun aus dem stable repo installiert.
                            Was hat das mit dem User auf sich? Ist das nicht egal, wie ich den User nenne?
                            • B beetle-fan
                              @beetle-fan sagte:
                              Man nimmt aus Sicherheitsgründen einen eigenen user name, weil 'pi' zu einfach zu erraten ist. Dann fällt schon mal ein Vektor beim LogIn weg. Wenn dann auch das Standardpasswort nicht geändert wird kannste dir die Übung auch komplett sparen...
                                beetle-fan
                                Verstanden, werde ich beizeiten anpassen (das PW ist natürlich nicht Standard).
                                ✓ Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                                Das passt also nun auch.
                                Danke Euch vielmals für die Hilfe!!!
