  4. ZigBee - Aquara Türsensor lässt sich nicht mehr verbinden
    6.3k
9 Beiträge 4 Kommentatoren 230 Aufrufe 3 Beobachtet
  • R Offline
    reutli
    habe einen Aquara Türsensor, der sich aus dem ZigBee verabschiedet hat.
    Habe den Zigbee Adapter in der 3.3.5 laufen.
    Habe versucht den neu zu pairen mit folgendem Ergebnis:
    DeviceConfigure successful 0x00158d008b80561d MCCGQ11LM
    zigbee.0
    	2026-06-05 17:06:57.962	info	Configuring 0x00158d008b80561d MCCGQ11LM
    zigbee.0
    	2026-06-05 17:06:38.844	warn	DeviceAvailability:ELEVATED: Non-pingable device 0x00158d008b80561d lumi.sensor_magnet.aq2 was last seen '63.414' seconds ago.
    zigbee.0
    	2026-06-05 17:06:38.231	info	debug devices set to ["00158d008b80561d"]
    zigbee.0
    	2026-06-05 17:06:31.661	info	debug devices set to []
    zigbee.0
    	2026-06-05 17:05:59.098	info	Closed Zigbee network with 1 second remaining.
    zigbee.0
    	2026-06-05 17:05:35.431	warn	ELEVATED:I04 (73c5) value generated '-1' from device 00158d008b80561d for 'Indicates how many times the sensor was triggered (since last scheduled report)'
    zigbee.0
    	2026-06-05 17:05:35.431	warn	ELEVATED:I04 (73c5) value generated '1913' from device 00158d008b80561d for 'Number of power outages'
    zigbee.0
    	2026-06-05 17:05:35.431	warn	ELEVATED:I04 (73c5) value generated '3025' from device 00158d008b80561d for 'Voltage of the battery in millivolts'
    zigbee.0
    	2026-06-05 17:05:35.431	warn	ELEVATED:I04 (73c5) value generated '32' from device 00158d008b80561d for 'Temperature of the device'
    zigbee.0
    	2026-06-05 17:05:35.431	warn	ELEVATED:I04 (73c5) value generated 'false' from device 00158d008b80561d for 'Indicates if the contact is closed (= true) or open (= false)'
    zigbee.0
    	2026-06-05 17:05:35.431	warn	ELEVATED:I04 (73c5) value generated 'true' from device 00158d008b80561d for 'Is open'
    zigbee.0
    	2026-06-05 17:05:35.431	warn	ELEVATED:I04 (73c5) value generated '100' from device 00158d008b80561d for 'Remaining battery in %, can take up to 24 hours before reported'
    zigbee.0
    	2026-06-05 17:05:35.431	warn	ELEVATED:I03 (73c5) message received '{"voltage":3025,"battery":100,"device_temperature":32,"power_outage_count":1913,"trigger_count":-1,"contact":false}' from device 00158d008b80561d type 'MCCGQ11LM'
    zigbee.0
    	2026-06-05 17:05:35.431	warn	ELEVATED:I02.1c (73c5) candidates: [{"voltage":3025,"battery":100,"device_temperature":32,"power_outage_count":1913,"trigger_count":-1,"contact":false}] => payload {"voltage":3025,"battery":100,"device_temperature":32,"power_outage_count":1913,"trigger_count":-1,"contact":false}
    zigbee.0
    zigbee.0
    	2026-06-05 17:05:35.431	warn	ELEVATED:I02.0b (73c5) data: {"65281":{"1":3025,"3":32,"4":424,"5":1914,"6":0,"10":53263,"100":1},"modelId":"lumi.sensor_magnet.aq2"} options: {} meta:{"deviceIEEE":"0x00158d008b80561d","logger":"StatesController","state":{"state":""}} result:{}
    zigbee.0
    	2026-06-05 17:05:35.431	warn	ELEVATED:I02.1a (73c5) converter 1 : Cluster genBasic
    zigbee.0
    	2026-06-05 17:05:35.431	warn	ELEVATED:I04 (73c5) No value published for device 00158d008b80561d
    zigbee.0
    	2026-06-05 17:05:35.431	warn	ELEVATED:I03 (73c5) message received '{"temperature":0.01,"humidity":null}' from device 00158d008b80561d type 'MCCGQ11LM'
    zigbee.0
    zigbee.0
    	2026-06-05 17:05:35.430	warn	ELEVATED:I03 (73c5) message received '{"voltage":3025,"battery":100}' from device 00158d008b80561d type 'MCCGQ11LM'
    zigbee.0
    	2026-06-05 17:05:35.430	warn	ELEVATED:I02 (73c5) 1 converter available for 'MCCGQ11LM' '00158d008b80561d' with cluster 'genBasic' and type 'attributeReport'
    zigbee.0
    	2026-06-05 17:05:35.430	warn	ELEVATED:I04 (73c5) value generated '109' from device 00158d008b80561d for 'Link quality'
    zigbee.0
    	2026-06-05 17:05:35.429	warn	ELEVATED:I01 (73c5) Zigbee Event of Type attributeReport from device 0x00158d008b80561d, incoming event: {"type":"attributeReport","data":{"65281":{"1":3025,"3":32,"4":424,"5":1914,"6":0,"10":53263,"100":1},"modelId":"lumi.sensor_magnet.aq2"},"linkquality":109,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[28,95,17,5,10,5,0,66,22,108,117,109,105,46,115,101,110,115,111,114,95,109,97,103,110,101,116,46,97,113,50,1,255,66,29,1,33,209,11,3,40,32,4,33,168,1,5,33,122,7,6,36,0,0,0,0,0,10,33,15,208,100,16,1]},"zclTransactionSequenceNumber":5,"manufacturerCode":4447,"frameControl":{"frameType":0,"manufacturerSpecific":true,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
    zigbee.0
    	2026-06-05 17:05:31.167	warn	ELEVATED:I04 (631d) value generated '-1' from device 00158d008b80561d for 'Indicates how many times the sensor was triggered (since last scheduled report)'
    zigbee.0
    	2026-06-05 17:05:31.167	warn	ELEVATED:I04 (631d) value generated '1913' from device 00158d008b80561d for 'Number of power outages'
    zigbee.0
    	2026-06-05 17:05:31.167	warn	ELEVATED:I04 (631d) value generated '3025' from device 00158d008b80561d for 'Voltage of the battery in millivolts'
    zigbee.0
    	2026-06-05 17:05:31.167	warn	ELEVATED:I04 (631d) value generated '31' from device 00158d008b80561d for 'Temperature of the device'
    zigbee.0
    	2026-06-05 17:05:31.167	warn	ELEVATED:I04 (631d) value generated 'false' from device 00158d008b80561d for 'Indicates if the contact is closed (= true) or open (= false)'
    zigbee.0
    	2026-06-05 17:05:31.167	warn	ELEVATED:I04 (631d) value generated 'true' from device 00158d008b80561d for 'Is open'
    zigbee.0
    	2026-06-05 17:05:31.167	warn	ELEVATED:I04 (631d) value generated '100' from device 00158d008b80561d for 'Remaining battery in %, can take up to 24 hours before reported'
    zigbee.0
    	2026-06-05 17:05:31.167	warn	ELEVATED:I03 (631d) message received '{"voltage":3025,"battery":100,"device_temperature":31,"power_outage_count":1913,"trigger_count":-1,"contact":false}' from device 00158d008b80561d type 'MCCGQ11LM'
    zigbee.0
    	2026-06-05 17:05:31.167	warn	ELEVATED:I02.1c (631d) candidates: [{"voltage":3025,"battery":100,"device_temperature":31,"power_outage_count":1913,"trigger_count":-1,"contact":false}] => payload {"voltage":3025,"battery":100,"device_temperature":31,"power_outage_count":1913,"trigger_count":-1,"contact":false}
    zigbee.0
    zigbee.0
    	2026-06-05 17:05:31.167	warn	ELEVATED:I02.0b (631d) data: {"65281":{"1":3025,"3":31,"4":424,"5":1914,"6":0,"10":53263,"100":1},"modelId":"lumi.sensor_magnet.aq2"} options: {} meta:{"deviceIEEE":"0x00158d008b80561d","logger":"StatesController","state":{"state":""}} result:{}
    zigbee.0
    	2026-06-05 17:05:31.167	warn	ELEVATED:I02.1a (631d) converter 1 : Cluster genBasic
    zigbee.0
    	2026-06-05 17:05:31.167	warn	ELEVATED:I04 (631d) No value published for device 00158d008b80561d
    zigbee.0
    	2026-06-05 17:05:31.167	warn	ELEVATED:I03 (631d) message received '{"temperature":0.01,"humidity":null}' from device 00158d008b80561d type 'MCCGQ11LM'
    zigbee.0
    	2026-06-05 17:05:31.166	warn	ELEVATED:I04 (631d) value generated '100' from device 00158d008b80561d for 'Remaining battery in %, can take up to 24 hours before reported'
    zigbee.0
    	2026-06-05 17:05:31.166	warn	ELEVATED:I03 (631d) message received '{"voltage":3025,"battery":100}' from device 00158d008b80561d type 'MCCGQ11LM'
    zigbee.0
    	2026-06-05 17:05:31.166	warn	ELEVATED:I02 (631d) 1 converter available for 'MCCGQ11LM' '00158d008b80561d' with cluster 'genBasic' and type 'attributeReport'
    zigbee.0
    	2026-06-05 17:05:31.166	warn	ELEVATED:I04 (631d) value generated '112' from device 00158d008b80561d for 'Link quality'
    zigbee.0
    	2026-06-05 17:05:31.166	warn	ELEVATED:I01 (631d) Zigbee Event of Type attributeReport from device 0x00158d008b80561d, incoming event: {"type":"attributeReport","data":{"65281":{"1":3025,"3":31,"4":424,"5":1914,"6":0,"10":53263,"100":1},"modelId":"lumi.sensor_magnet.aq2"},"linkquality":112,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[28,95,17,4,10,5,0,66,22,108,117,109,105,46,115,101,110,115,111,114,95,109,97,103,110,101,116,46,97,113,50,1,255,66,29,1,33,209,11,3,40,31,4,33,168,1,5,33,122,7,6,36,0,0,0,0,0,10,33,15,208,100,16,1]},"zclTransactionSequenceNumber":4,"manufacturerCode":4447,"frameControl":{"frameType":0,"manufacturerSpecific":true,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
    zigbee.0
    	2026-06-05 17:05:28.762	warn	ELEVATED:I04 (59b8) value generated '-1' from device 00158d008b80561d for 'Indicates how many times the sensor was triggered (since last scheduled report)'
    zigbee.0
    	2026-06-05 17:05:28.762	warn	ELEVATED:I04 (59b8) value generated '1913' from device 00158d008b80561d for 'Number of power outages'
    zigbee.0
    	2026-06-05 17:05:28.762	warn	ELEVATED:I04 (59b8) value generated '3025' from device 00158d008b80561d for 'Voltage of the battery in millivolts'
    zigbee.0
    	2026-06-05 17:05:28.762	warn	ELEVATED:I04 (59b8) value generated '31' from device 00158d008b80561d for 'Temperature of the device'
    zigbee.0
    	2026-06-05 17:05:28.762	warn	ELEVATED:I04 (59b8) value generated 'false' from device 00158d008b80561d for 'Indicates if the contact is closed (= true) or open (= false)'
    zigbee.0
    	2026-06-05 17:05:28.762	warn	ELEVATED:I04 (59b8) value generated 'true' from device 00158d008b80561d for 'Is open'
    zigbee.0
    	2026-06-05 17:05:28.762	warn	ELEVATED:I04 (59b8) value generated '100' from device 00158d008b80561d for 'Remaining battery in %, can take up to 24 hours before reported'
    zigbee.0
    	2026-06-05 17:05:28.762	warn	ELEVATED:I03 (59b8) message received '{"voltage":3025,"battery":100,"device_temperature":31,"power_outage_count":1913,"trigger_count":-1,"contact":false}' from device 00158d008b80561d type 'MCCGQ11LM'
    zigbee.0
    	2026-06-05 17:05:28.762	warn	ELEVATED:I02.1c (59b8) candidates: [{"voltage":3025,"battery":100,"device_temperature":31,"power_outage_count":1913,"trigger_count":-1,"contact":false}] => payload {"voltage":3025,"battery":100,"device_temperature":31,"power_outage_count":1913,"trigger_count":-1,"contact":false}
    zigbee.0
    zigbee.0
    	2026-06-05 17:05:28.762	warn	ELEVATED:I02.0b (59b8) data: {"65281":{"1":3025,"3":31,"4":424,"5":1914,"6":0,"10":53263,"100":1},"modelId":"lumi.sensor_magnet.aq2"} options: {} meta:{"deviceIEEE":"0x00158d008b80561d","logger":"StatesController","state":{"state":""}} result:{}
    zigbee.0
    	2026-06-05 17:05:28.762	warn	ELEVATED:I02.1a (59b8) converter 1 : Cluster genBasic
    zigbee.0
    	2026-06-05 17:05:28.762	warn	ELEVATED:I04 (59b8) No value published for device 00158d008b80561d
    zigbee.0
    	2026-06-05 17:05:28.762	warn	ELEVATED:I03 (59b8) message received '{"temperature":0.01,"humidity":null}' from device 00158d008b80561d type 'MCCGQ11LM'
    zigbee.0
    zigbee.0
    	2026-06-05 17:05:28.762	warn	ELEVATED:I03 (59b8) message received '{"voltage":3025,"battery":100}' from device 00158d008b80561d type 'MCCGQ11LM'
    zigbee.0
    	2026-06-05 17:05:28.762	warn	ELEVATED:I02 (59b8) 1 converter available for 'MCCGQ11LM' '00158d008b80561d' with cluster 'genBasic' and type 'attributeReport'
    zigbee.0
    	2026-06-05 17:05:28.761	warn	ELEVATED:I04 (59b8) value generated '109' from device 00158d008b80561d for 'Link quality'
    zigbee.0
    	2026-06-05 17:05:28.760	warn	ELEVATED:I01 (59b8) Zigbee Event of Type attributeReport from device 0x00158d008b80561d, incoming event: {"type":"attributeReport","data":{"65281":{"1":3025,"3":31,"4":424,"5":1914,"6":0,"10":53263,"100":1},"modelId":"lumi.sensor_magnet.aq2"},"linkquality":109,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[28,95,17,3,10,5,0,66,22,108,117,109,105,46,115,101,110,115,111,114,95,109,97,103,110,101,116,46,97,113,50,1,255,66,29,1,33,209,11,3,40,31,4,33,168,1,5,33,122,7,6,36,0,0,0,0,0,10,33,15,208,100,16,1]},"zclTransactionSequenceNumber":3,"manufacturerCode":4447,"frameControl":{"frameType":0,"manufacturerSpecific":true,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
    zigbee.0
    	2026-06-05 17:05:25.690	warn	State value for 00158d008b80561d.trigger_count has value "-1" less than min "0".
    zigbee.0
    	2026-06-05 17:05:25.686	warn	ELEVATED:I04 (4db4) value generated '-1' from device 00158d008b80561d for 'Indicates how many times the sensor was triggered (since last scheduled report)'
    zigbee.0
    	2026-06-05 17:05:25.686	warn	ELEVATED:I04 (4db4) value generated '1913' from device 00158d008b80561d for 'Number of power outages'
    zigbee.0
    	2026-06-05 17:05:25.685	warn	ELEVATED:I04 (4db4) value generated '3025' from device 00158d008b80561d for 'Voltage of the battery in millivolts'
    zigbee.0
    	2026-06-05 17:05:25.685	warn	ELEVATED:I04 (4db4) value generated '32' from device 00158d008b80561d for 'Temperature of the device'
    zigbee.0
    	2026-06-05 17:05:25.685	warn	ELEVATED:I04 (4db4) value generated 'false' from device 00158d008b80561d for 'Indicates if the contact is closed (= true) or open (= false)'
    zigbee.0
    	2026-06-05 17:05:25.685	warn	ELEVATED:I04 (4db4) value generated 'true' from device 00158d008b80561d for 'Is open'
    zigbee.0
    	2026-06-05 17:05:25.685	warn	ELEVATED:I04 (4db4) value generated '100' from device 00158d008b80561d for 'Remaining battery in %, can take up to 24 hours before reported'
    zigbee.0
    	2026-06-05 17:05:25.685	warn	ELEVATED:I03 (4db4) message received '{"voltage":3025,"battery":100,"device_temperature":32,"power_outage_count":1913,"trigger_count":-1,"contact":false}' from device 00158d008b80561d type 'MCCGQ11LM'
    zigbee.0
    	2026-06-05 17:05:25.685	warn	ELEVATED:I02.1c (4db4) candidates: [{"voltage":3025,"battery":100,"device_temperature":32,"power_outage_count":1913,"trigger_count":-1,"contact":false}] => payload {"voltage":3025,"battery":100,"device_temperature":32,"power_outage_count":1913,"trigger_count":-1,"contact":false}
    zigbee.0
    zigbee.0
    	2026-06-05 17:05:25.685	warn	ELEVATED:I02.0b (4db4) data: {"65281":{"1":3025,"3":32,"4":424,"5":1914,"6":0,"10":53263,"100":1},"modelId":"lumi.sensor_magnet.aq2"} options: {} meta:{"deviceIEEE":"0x00158d008b80561d","logger":"StatesController","state":{"state":""}} result:{}
    zigbee.0
    	2026-06-05 17:05:25.685	warn	ELEVATED:I02.1a (4db4) converter 1 : Cluster genBasic
    zigbee.0
    	2026-06-05 17:05:25.685	warn	ELEVATED:I04 (4db4) No value published for device 00158d008b80561d
    zigbee.0
    	2026-06-05 17:05:25.685	warn	ELEVATED:I03 (4db4) message received '{"temperature":0.01,"humidity":null}' from device 00158d008b80561d type 'MCCGQ11LM'
    zigbee.0
    zigbee.0
    	2026-06-05 17:05:25.685	warn	ELEVATED:I03 (4db4) message received '{"voltage":3025,"battery":100}' from device 00158d008b80561d type 'MCCGQ11LM'
    zigbee.0
    	2026-06-05 17:05:25.685	warn	ELEVATED:I02 (4db4) 1 converter available for 'MCCGQ11LM' '00158d008b80561d' with cluster 'genBasic' and type 'attributeReport'
    zigbee.0
    	2026-06-05 17:05:25.685	warn	ELEVATED:I04 (4db4) value generated '109' from device 00158d008b80561d for 'Link quality'
    zigbee.0
    	2026-06-05 17:05:25.684	warn	ELEVATED:I01 (4db4) Zigbee Event of Type attributeReport from device 0x00158d008b80561d, incoming event: {"type":"attributeReport","data":{"65281":{"1":3025,"3":32,"4":424,"5":1914,"6":0,"10":53263,"100":1},"modelId":"lumi.sensor_magnet.aq2"},"linkquality":109,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[28,95,17,2,10,5,0,66,22,108,117,109,105,46,115,101,110,115,111,114,95,109,97,103,110,101,116,46,97,113,50,1,255,66,29,1,33,209,11,3,40,32,4,33,168,1,5,33,122,7,6,36,0,0,0,0,0,10,33,15,208,100,16,1]},"zclTransactionSequenceNumber":2,"manufacturerCode":4447,"frameControl":{"frameType":0,"manufacturerSpecific":true,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
    zigbee.0
    	2026-06-05 17:05:21.057	warn	ELEVATED:I04 (3b9b) value generated '0' from device 00158d008b80561d for 'Indicates how many times the sensor was triggered (since last scheduled report)'
    zigbee.0
    	2026-06-05 17:05:21.057	warn	ELEVATED:I04 (3b9b) value generated '1913' from device 00158d008b80561d for 'Number of power outages'
    zigbee.0
    	2026-06-05 17:05:21.057	warn	ELEVATED:I04 (3b9b) value generated '3025' from device 00158d008b80561d for 'Voltage of the battery in millivolts'
    zigbee.0
    	2026-06-05 17:05:21.057	warn	ELEVATED:I04 (3b9b) value generated '32' from device 00158d008b80561d for 'Temperature of the device'
    zigbee.0
    	2026-06-05 17:05:21.057	warn	ELEVATED:I04 (3b9b) value generated 'false' from device 00158d008b80561d for 'Indicates if the contact is closed (= true) or open (= false)'
    zigbee.0
    	2026-06-05 17:05:21.057	warn	ELEVATED:I04 (3b9b) value generated 'true' from device 00158d008b80561d for 'Is open'
    zigbee.0
    	2026-06-05 17:05:21.056	warn	ELEVATED:I04 (3b9b) value generated '100' from device 00158d008b80561d for 'Remaining battery in %, can take up to 24 hours before reported'
    zigbee.0
    	2026-06-05 17:05:21.056	warn	ELEVATED:I03 (3b9b) message received '{"voltage":3025,"battery":100,"device_temperature":32,"power_outage_count":1913,"trigger_count":0,"contact":false}' from device 00158d008b80561d type 'MCCGQ11LM'
    zigbee.0
    	2026-06-05 17:05:21.056	warn	ELEVATED:I02.1c (3b9b) candidates: [{"voltage":3025,"battery":100,"device_temperature":32,"power_outage_count":1913,"trigger_count":0,"contact":false}] => payload {"voltage":3025,"battery":100,"device_temperature":32,"power_outage_count":1913,"trigger_count":0,"contact":false}
    zigbee.0
    	2026-06-05 17:05:21.056	warn	ELEVATED:I04 (3b9b) value generated '3025' from device 00158d008b80561d for 'Voltage of the battery in millivolts'
    zigbee.0
    	2026-06-05 17:05:21.056	warn	ELEVATED:I02.0b (3b9b) data: {"65281":{"1":3025,"3":32,"4":424,"5":1914,"6":1,"10":53263,"100":1}} options: {} meta:{"deviceIEEE":"0x00158d008b80561d","logger":"StatesController","state":{"state":""}} result:{}
    zigbee.0
    	2026-06-05 17:05:21.056	warn	ELEVATED:I02.1a (3b9b) converter 1 : Cluster genBasic
    zigbee.0
    	2026-06-05 17:05:21.056	warn	ELEVATED:I04 (3b9b) No value published for device 00158d008b80561d
    zigbee.0
    	2026-06-05 17:05:21.056	warn	ELEVATED:I03 (3b9b) message received '{"temperature":0.01,"humidity":null}' from device 00158d008b80561d type 'MCCGQ11LM'
    zigbee.0
    zigbee.0
    	2026-06-05 17:05:21.056	warn	ELEVATED:I03 (3b9b) message received '{"voltage":3025,"battery":100}' from device 00158d008b80561d type 'MCCGQ11LM'
    zigbee.0
    	2026-06-05 17:05:21.056	warn	ELEVATED:I02 (3b9b) 1 converter available for 'MCCGQ11LM' '00158d008b80561d' with cluster 'genBasic' and type 'attributeReport'
    zigbee.0
    	2026-06-05 17:05:21.055	warn	ELEVATED:I04 (3b9b) value generated '112' from device 00158d008b80561d for 'Link quality'
    zigbee.0
    	2026-06-05 17:05:21.051	warn	ELEVATED:I01 (3b9b) Zigbee Event of Type attributeReport from device 0x00158d008b80561d, incoming event: {"type":"attributeReport","data":{"65281":{"1":3025,"3":32,"4":424,"5":1914,"6":1,"10":53263,"100":1}},"linkquality":112,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[28,95,17,1,10,1,255,66,29,1,33,209,11,3,40,32,4,33,168,1,5,33,122,7,6,36,1,0,0,0,0,10,33,15,208,100,16,1]},"zclTransactionSequenceNumber":1,"manufacturerCode":4447,"frameControl":{"frameType":0,"manufacturerSpecific":true,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
    zigbee.0
    	2026-06-05 17:05:20.889	warn	ELEVATED:I04 (3ac9) No value published for device 00158d008b80561d
    zigbee.0
    	2026-06-05 17:05:20.889	warn	ELEVATED:I03 (3ac9) message received '{}' from device 00158d008b80561d type 'MCCGQ11LM'
    zigbee.0
    	2026-06-05 17:05:20.889	warn	ELEVATED:I02.1c (3ac9) candidates: [{}] => payload {}
    zigbee.0
    	2026-06-05 17:05:20.889	warn	ELEVATED:I02.0b (3ac9) data: {"modelId":"lumi.sensor_magnet.aq2","appVersion":3} options: {} meta:{"deviceIEEE":"0x00158d008b80561d","logger":"StatesController","state":{"state":""}} result:{}
    zigbee.0
    	2026-06-05 17:05:20.889	warn	ELEVATED:I02.1a (3ac9) converter 1 : Cluster genBasic
    zigbee.0
    	2026-06-05 17:05:20.889	warn	ELEVATED:I02 (3ac9) 1 converter available for 'MCCGQ11LM' '00158d008b80561d' with cluster 'genBasic' and type 'attributeReport'
    zigbee.0
    	2026-06-05 17:05:20.889	warn	ELEVATED:I04 (3ac9) value generated '109' from device 00158d008b80561d for 'Link quality'
    zigbee.0
    	2026-06-05 17:05:20.841	warn	ELEVATED:I01 (3ac9) Zigbee Event of Type attributeReport from device 0x00158d008b80561d, incoming event: {"type":"attributeReport","data":{"modelId":"lumi.sensor_magnet.aq2","appVersion":3},"linkquality":109,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[24,0,10,5,0,66,22,108,117,109,105,46,115,101,110,115,111,114,95,109,97,103,110,101,116,46,97,113,50,1,0,32,3]},"zclTransactionSequenceNumber":0,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
    zigbee.0
    	2026-06-05 17:05:20.790	warn	ELEVATED:I04 (3a96) value generated '10' from device 00158d008b80561d for 'Link quality'
    zigbee.0
    	2026-06-05 17:05:20.790	warn	ELEVATED:I03 (3a96) message received '{"linkquality":10}' from device 00158d008b80561d type 'MCCGQ11LM'
    zigbee.0
    	2026-06-05 17:05:20.790	warn	ELEVATED:I04 (3a96) value generated 'true' from device 00158d008b80561d for 'Available'
    zigbee.0
    	2026-06-05 17:05:20.790	warn	ELEVATED:I03 (3a96) message received '{"available":true}' from device 00158d008b80561d type 'MCCGQ11LM'
    zigbee.0
    	2026-06-05 17:05:20.790	info	Device query for '0x00158d008b80561d' complete
    zigbee.0
    	2026-06-05 17:05:20.790	info	Device query for '0x00158d008b80561d' started
    zigbee.0
    	2026-06-05 17:05:20.789	warn	Device '0x00158d008b80561d' announced itself, trying to read its status
    zigbee.0
    	2026-06-05 17:05:20.789	warn	ELEVATED:Ida (3a95) Device '0x00158d008b80561d' announced itself
    Debug aus dem Adapter
    I01: Zigbee Event of Type attributeReport from device 0x00158d008b80561d, incoming event: {"type":"attributeReport","data":{"65281":{"1":3025,"3":32,"4":424,"5":1914,"6":0,"10":53263,"100":1},"modelId":"lumi.sensor_magnet.aq2"},"linkquality":109,"groupID":0,"cluster":"genBasic","meta":{"rawData":{"type":"Buffer","data":[28,95,17,5,10,5,0,66,22,108,117,109,105,46,115,101,110,115,111,114,95,109,97,103,110,101,116,46,97,113,50,1,255,66,29,1,33,209,11,3,40,32,4,33,168,1,5,33,122,7,6,36,0,0,0,0,0,10,33,15,208,100,16,1]},"zclTransactionSequenceNumber":5,"manufacturerCode":4447,"frameControl":{"frameType":0,"manufacturerSpecific":true,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
    I04: value generated '109' from device 00158d008b80561d for 'Link quality'
    I02: 1 converter available for 'MCCGQ11LM' '00158d008b80561d' with cluster 'genBasic' and type 'attributeReport'
    I03: message received '{"voltage":3025,"battery":100}' from device 00158d008b80561d type 'MCCGQ11LM'
    I04-1: value generated '100' from device 00158d008b80561d for 'Remaining battery in %, can take up to 24 hours before reported'
    I03-1: message received '{"temperature":0.01,"humidity":null}' from device 00158d008b80561d type 'MCCGQ11LM'
    I04-2: No value published for device 00158d008b80561d
    I02.1a: converter 1 : Cluster genBasic
    I02.0b: data: {"65281":{"1":3025,"3":32,"4":424,"5":1914,"6":0,"10":53263,"100":1},"modelId":"lumi.sensor_magnet.aq2"} options: {} meta:{"deviceIEEE":"0x00158d008b80561d","logger":"StatesController","state":{"state":""}} result:{}
    I04-3: value generated '3025' from device 00158d008b80561d for 'Voltage of the battery in millivolts'
    I02.1c: candidates: [{"voltage":3025,"battery":100,"device_temperature":32,"power_outage_count":1913,"trigger_count":-1,"contact":false}] => payload {"voltage":3025,"battery":100,"device_temperature":32,"power_outage_count":1913,"trigger_count":-1,"contact":false}
    I03-2: message received '{"voltage":3025,"battery":100,"device_temperature":32,"power_outage_count":1913,"trigger_count":-1,"contact":false}' from device 00158d008b80561d type 'MCCGQ11LM'
    I04-4: value generated '100' from device 00158d008b80561d for 'Remaining battery in %, can take up to 24 hours before reported'
    I04-5: value generated 'true' from device 00158d008b80561d for 'Is open'
    I04-6: value generated 'false' from device 00158d008b80561d for 'Indicates if the contact is closed (= true) or open (= false)'
    I04-7: value generated '32' from device 00158d008b80561d for 'Temperature of the device'
    I04-8: value generated '3025' from device 00158d008b80561d for 'Voltage of the battery in millivolts'
    I04-9: value generated '1913' from device 00158d008b80561d for 'Number of power outages'
    I04-10: value generated '-1' from device 00158d008b80561d for 'Indicates how many times the sensor was triggered (since last scheduled report)'
    Jetzt gibt es alle paar Sekunden im iob log:
    zigbee.0
    	2026-06-05 17:21:38.845	warn	DeviceAvailability:ELEVATED: Non-pingable device 0x00158d008b80561d lumi.sensor_magnet.aq2 was last seen '963.416' seconds ago.
    Er zeigt sich zwar als "grün" bringt aber keine neuen Werte mehr:
    iobroker in Debian-VM auf Proxmox Server (Ryzen 7 / 32GB / 1TB NVMe SSD) als Master - mehrere Raspberry Pis (3+4) als Slaves. InfluxDB V2 und Grafana auf LXC.
    *Wer freundlich ist, dem wird freundlich geholfen *
    • AsgothianA Offline
      AsgothianA Offline
      Asgothian
      Du hast den im device-debug laufen, siehe auch den grünen Käfer auf der Kachel:
      Versuch mal bitte:
      • gerät aufwecken
      • direkt (<1 s später) via dem button mit den 2 roten Pfeilen im Kreis das Gerät neu konfigurieren
      A.
      R 1 Antwort Letzte Antwort
      • AsgothianA Asgothian
        Versuch mal bitte:
        • gerät aufwecken
        A.
        reutli
        @Asgothian sagte:
        Ja, das ist/war Absicht.
        Oder meinst Du , dass daher die Einträge in iob log kommen?
        --> habe jetzt wieder Debug ausgemacht.
        Ich war ggf. zu ungeduldig:
        Nachdem re-koppeln habe ich dann später den Adapter nochmals komplett neu gestartet, dann waren bis auf ein Gerät alle erst einmal rot. Jetzt nach einiger Zeit haben sich wohl alle (inkl. dem Gegenständlichen) wieder sauber eingebucht.
        Danke trotzdem für die Hilfe!
        @Asgothian sagte:
        gerät aufwecken
        Das ginge aber nur zu zweit, wenn man das Gerät nicht neben sich liegen hat oder den Rachner nicht neben dem Gerät?!
        arteckA HomoranH AsgothianA 3 Antworten Letzte Antwort
        • R reutli
          @Asgothian sagte:
          @Asgothian sagte:
          gerät aufwecken
          arteckA Offline
          arteckA Offline
          arteck
          @reutli sagte:
          wiso... das Ding kannst du doch abnehmen.. ist doch nur geklipst
          • arteckA arteck
            @reutli sagte:
            reutli
            @arteck sagte:
            @reutli sagte:
            Ah, das ist mir ehrlich gesagt neu?! Ich hab das Ding dran geklebt und mir ist nicht klar, wo man den aus-Klipsen könnte….
            • R reutli
              @Asgothian sagte:
              @Asgothian sagte:
              gerät aufwecken
              @reutli sagte:
              Hast du kein Handy oder Tablet?
              • R reutli
                @Asgothian sagte:
                @Asgothian sagte:
                gerät aufwecken
                AsgothianA Offline
                AsgothianA Offline
                Asgothian
                @reutli sagte:
                Ja, der Device Debug ist genau für diese Meldungen gedacht - damit du sehen kannst was an Daten an das Device gehen.
                Zum Thema trennen:
                Am roten Pfeil mit dem Fingernagel (Schraubendreher geht auch) einhaken und den weissen vom grauen Teil trennen.
                Brauchst du auch wenn irgendwann mal die batterie alle wird.
                A.
                  @reutli sagte:
                  reutli
                  @Homoran sagte:
                  @reutli sagte:
                  Doch, bin aber mittlerweile „ alter Mann“ und seh nicht genug auf den kleinen Teilen ;o)
                    @reutli sagte:
                    Zum Thema trennen:
                    A.
                    reutli
                    schrieb am zuletzt editiert von reutli
                    Zum Thema trennen:
                    A.
                    Ich Depp, Danke!
