  4. ioBroker startet nach NodeJS Updateversuch nicht mehr
    6.3k
4 Beiträge 2 Kommentatoren 160 Aufrufe 2 Beobachtet
    Bogie11
    der Tibber Adapter wollte sich nur mit neuem NodeJS installieren lassen.
    Bei der Installation gab es einige Probleme und nun komme ich nicht mehr auf die Admin Oberfläche.
    IOB diag sagt:
    iob diag needs to be updated. Please execute 'iobroker fix' first.
    The state system.host.raspberrypi.versions.nodeNewestNext was not found!
    ioBroker fix zeigt einige laufende Prozesse:
    library: loaded
    Library version=2026-04-11
    ioBroker or some processes are still running:
    1043 iobroker.js-con
    1101 io.javascript.0
    1123 io.backitup.0
    1138 io.homee.0
    1186 io.mqtt.0
    1193 io.mqtt.1
    1213 io.netatmo.0
    1234 io.sonoff.0
    1255 io.tr-064.0
    1270 io.discovery.0
    1290 io.device-remin
    1318 io.smartgarden.
    Please stop them first and try again!
    iob Stop
    iobroker fix:
     Welcome to the ioBroker installation fixer!
        Script version: 2025-09-18
        You might need to enter your password a couple of times.
        Installing prerequisites (1/5)
    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:2 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
    Hit:3 https://apt.grafana.com stable InRelease
    Get:4 https://dl.evcc.io/public/evcc/stable/deb/raspbian bookworm InRelease
    Get:5 https://repos.influxdata.com/debian stable InRelease [6,922 B]
    Get:6 https://repos.influxdata.com/debian bookworm InRelease [12.9 kB]
    Err:6 https://repos.influxdata.com/debian bookworm InRelease
      The following signatures couldn't be verified because the public key is not av        ailable: NO_PUBKEY xxx
    Fetched 31.5 kB in 1s (25.1 kB/s)
    Reading package lists... Done
    W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY xxx
    W: Failed to fetch https://repos.influxdata.com/debian/dists/bookworm/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY xxx
    W: Some index files failed to download. They have been ignored, or old ones used instead.
        Checking ioBroker user and directory permissions (2/5)
    ACL enabled: true
        Check and cleanup npm temporary directories (3/5)
    Done.
        Database maintenance (4/5)
    Checking for uncompressed JSONL databases... This might take a while!
    usage: sudo -h | -K | -k | -V
    usage: sudo -v [-ABkNnS] [-g group] [-h host] [-p prompt] [-u user]
    usage: sudo -l [-ABkNnS] [-g group] [-h host] [-p prompt] [-U user] [-u user] [command [arg ...]]
    usage: sudo [-ABbEHkNnPS] [-r role] [-t type] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] [VAR=value] [-i | -s] [command [arg ...]]
    usage: sudo -e [-ABkNnS] [-r role] [-t type] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] file ...
    /home/iobroker/.fix.sh: line 14: [: -lt: unary operator expected
    sudo: npm: command not found
        Checking autostart (5/5)
    ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
    Authentication is required to stop 'iobroker.service'.
    Authenticating as: ,,, (xxxx)
    Password:
    ==== AUTHENTICATION COMPLETE ====
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    IOBdiag:
    [The state system.host.raspberrypi.versions.nodeNewestNext was not found!
     The state system.host.raspberrypi.versions.npmNewestNext was not found!
    ```bash
    Script v.2026-06-01
    *** BASE SYSTEM ***
    Operating System: Raspbian GNU/Linux 12 (bookworm)
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.12.87+rpt-rpi-v8
        Architecture: arm64
    OS is similar to: debian
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 32bit
    System was installed 703 days ago (on 2024-07-04).
    Outdated 32Bit architecture detected. Only a pure 64Bit-System will be supported in the future. You will have to reinstall your operating system with full 64Bit support or upgrade to more modern hardware soon.
    Systemuptime and Load:
     17:54:14 up 11 min,  3 users,  load average: 0.47, 0.64, 0.53
    CPU threads     : 4
    *** LIFE CYCLE STATUS ***
    ERROR: Package 'distro-info' is not installed. Please do:
    sudo apt update && sudo apt install distro-info
    Alternatively execute the 'iob fix'
    MOD-EDIT: Alle code-tags hinzugefügt!
    Was kann ich tun, damit es wieder läuft?
    Vielen Dank
    • B Bogie11
      IOB diag sagt:
      library: loaded
      1123 io.backitup.0
      1138 io.homee.0
      1186 io.mqtt.0
      1193 io.mqtt.1
      1213 io.netatmo.0
      1234 io.sonoff.0
      1255 io.tr-064.0
      1270 io.discovery.0
      iob Stop
      iobroker fix:
      ACL enabled: true
      Done.
      Password:
      Autostart enabled!
      IOBdiag:
      ```bash
      Script v.2026-06-01
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      Docker          : false
      Kernel          : aarch64
      Userland        : 32bit
      CPU threads     : 4
      Vielen Dank
      @Bogie11 sagte:
      Bring das in allernächster Zeit auf 13 / Trixie. Per NEUINSTALLATION, denn deine 32Bit-Installation ist tot.
      Das Zeug dann regelmäßiger auf Stand halten, dann versumpft dir das auch nicht so wie das jetzige Ding.
        Bogie11
        OK, danke. Werde ich versuchen ;-)
        • B Bogie11
          @Bogie11
          Versuch es damit:
          https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
