<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ioBroker startet nach NodeJS Updateversuch nicht mehr]]></title><description><![CDATA[<p dir="auto">Hallo,<br />
der Tibber Adapter wollte sich nur mit neuem NodeJS installieren lassen.<br />
Bei der Installation gab es einige Probleme und nun komme ich nicht mehr auf die Admin Oberfläche.<br />
IOB diag sagt:</p>
<pre><code>iob diag needs to be updated. Please execute 'iobroker fix' first.
The state system.host.raspberrypi.versions.nodeNewestNext was not found!
</code></pre>
<p dir="auto">ioBroker fix zeigt einige laufende Prozesse:</p>
<pre><code>library: loaded
Library version=2026-04-11
ioBroker or some processes are still running:
1043 iobroker.js-con
1101 io.javascript.0
1123 io.backitup.0
1138 io.homee.0
1186 io.mqtt.0
1193 io.mqtt.1
1213 io.netatmo.0
1234 io.sonoff.0
1255 io.tr-064.0
1270 io.discovery.0
1290 io.device-remin
1318 io.smartgarden.
Please stop them first and try again!
</code></pre>
<p dir="auto">iob Stop</p>
<p dir="auto">iobroker fix:</p>
<pre><code> Welcome to the ioBroker installation fixer!
    Script version: 2025-09-18
    You might need to enter your password a couple of times.
    Installing prerequisites (1/5)
Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
Hit:2 http://raspbian.raspberrypi.com/raspbian bookworm InRelease
Hit:3 https://apt.grafana.com stable InRelease
Get:4 https://dl.evcc.io/public/evcc/stable/deb/raspbian bookworm InRelease
Get:5 https://repos.influxdata.com/debian stable InRelease [6,922 B]
Get:6 https://repos.influxdata.com/debian bookworm InRelease [12.9 kB]
Err:6 https://repos.influxdata.com/debian bookworm InRelease
  The following signatures couldn't be verified because the public key is not av        ailable: NO_PUBKEY xxx
Fetched 31.5 kB in 1s (25.1 kB/s)
Reading package lists... Done
W: http://raspbian.raspberrypi.com/raspbian/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY xxx
W: Failed to fetch https://repos.influxdata.com/debian/dists/bookworm/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY xxx
W: Some index files failed to download. They have been ignored, or old ones used instead.
    Checking ioBroker user and directory permissions (2/5)
Created /etc/sudoers.d/iobroker
ACL enabled: true
    Check and cleanup npm temporary directories (3/5)
Done.
    Database maintenance (4/5)
Checking for uncompressed JSONL databases... This might take a while!
usage: sudo -h | -K | -k | -V
usage: sudo -v [-ABkNnS] [-g group] [-h host] [-p prompt] [-u user]
usage: sudo -l [-ABkNnS] [-g group] [-h host] [-p prompt] [-U user] [-u user] [command [arg ...]]
usage: sudo [-ABbEHkNnPS] [-r role] [-t type] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] [VAR=value] [-i | -s] [command [arg ...]]
usage: sudo -e [-ABkNnS] [-r role] [-t type] [-C num] [-D directory] [-g group] [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] file ...
/home/iobroker/.fix.sh: line 14: [: -lt: unary operator expected
sudo: npm: command not found
    Checking autostart (5/5)
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
Authentication is required to stop 'iobroker.service'.
Authenticating as: ,,, (xxxx)
Password:
==== AUTHENTICATION COMPLETE ====
Enabling autostart...
Autostart enabled!
IOBdiag:
[The state system.host.raspberrypi.versions.nodeNewestNext was not found!
 The state system.host.raspberrypi.versions.npmNewestNext was not found!
```bash
Script v.2026-06-01
*** BASE SYSTEM ***
Operating System: Raspbian GNU/Linux 12 (bookworm)
 Static hostname: raspberrypi
       Icon name: computer
          Kernel: Linux 6.12.87+rpt-rpi-v8
    Architecture: arm64
OS is similar to: debian
Model           : Raspberry Pi 4 Model B Rev 1.1
Docker          : false
Virtualization  : none
Kernel          : aarch64
Userland        : 32bit
System was installed 703 days ago (on 2024-07-04).
Outdated 32Bit architecture detected. Only a pure 64Bit-System will be supported in the future. You will have to reinstall your operating system with full 64Bit support or upgrade to more modern hardware soon.
Systemuptime and Load:
 17:54:14 up 11 min,  3 users,  load average: 0.47, 0.64, 0.53
CPU threads     : 4
*** LIFE CYCLE STATUS ***
ERROR: Package 'distro-info' is not installed. Please do:
sudo apt update &amp;&amp; sudo apt install distro-info
Alternatively execute the 'iob fix'
</code></pre>
<p dir="auto"><strong>MOD-EDIT: Alle code-tags hinzugefügt!</strong></p>
<p dir="auto">Was kann ich tun, damit es wieder läuft?</p>
<p dir="auto">Vielen Dank</p>
]]></description><link>https://forum.iobroker.net/topic/84719/iobroker-startet-nach-nodejs-updateversuch-nicht-mehr</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 08:23:41 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/84719.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 07 Jun 2026 15:58:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ioBroker startet nach NodeJS Updateversuch nicht mehr on Sun, 07 Jun 2026 18:28:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bogie11" aria-label="Profile: Bogie11">@<bdi>Bogie11</bdi></a></p>
<p dir="auto">Versuch es damit:</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht">https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht</a></p>
]]></description><link>https://forum.iobroker.net/post/1343231</link><guid isPermaLink="true">https://forum.iobroker.net/post/1343231</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 07 Jun 2026 18:28:01 GMT</pubDate></item><item><title><![CDATA[Reply to ioBroker startet nach NodeJS Updateversuch nicht mehr on Sun, 07 Jun 2026 18:22:32 GMT]]></title><description><![CDATA[<p dir="auto">OK, danke. Werde ich versuchen ;-)</p>
]]></description><link>https://forum.iobroker.net/post/1343230</link><guid isPermaLink="true">https://forum.iobroker.net/post/1343230</guid><dc:creator><![CDATA[Bogie11]]></dc:creator><pubDate>Sun, 07 Jun 2026 18:22:32 GMT</pubDate></item><item><title><![CDATA[Reply to ioBroker startet nach NodeJS Updateversuch nicht mehr on Sun, 07 Jun 2026 17:11:47 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bogie11" aria-label="Profile: Bogie11">@<bdi>Bogie11</bdi></a> <a href="/post/1343220">sagte</a>:</p>
<p dir="auto">Raspbian GNU/Linux 12 (bookworm)</p>
</blockquote>
<p dir="auto">Bring das in allernächster Zeit auf 13 / Trixie. Per NEUINSTALLATION, denn deine 32Bit-Installation ist tot.<br />
Das Zeug dann regelmäßiger auf Stand halten, dann versumpft dir das auch nicht so wie das jetzige Ding.</p>
]]></description><link>https://forum.iobroker.net/post/1343222</link><guid isPermaLink="true">https://forum.iobroker.net/post/1343222</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 07 Jun 2026 17:11:47 GMT</pubDate></item></channel></rss>
