Unb. Widget-Typ tplMaterial2Switches über iobroker.pro
Oh ... ja das hätte ich wohl vorher tun sollen.
Sollte jetzt alles aktuell sein.
Script v.2026-01-31 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: ioBroker2025 Icon name: computer-vm Chassis: vm 🖴 Virtualization: kvm Kernel: Linux 6.12.74+deb13+1-amd64 Architecture: x86-64 Hardware Vendor: QEMU Hardware Model: Standard PC _i440FX + PIIX, 1996_ Firmware Version: rel-1.17.0-0-gb52ca86e094d-prebuilt.qemu.org Firmware Date: Tue 2014-04-01 Firmware Age: 12y 2month 2d OS is similar to: model name : QEMU Virtual CPU version 2.5+ Docker : false Virtualization : kvm Kernel : x86_64 Userland : 64 bit Systemuptime and Load: 23:17:21 up 2:32, 2 users, load average: 2.07, 1.55, 1.29 CPU threads: 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** TIME AND TIMEZONES *** Local time: Tue 2026-06-02 23:17:21 CEST Universal time: Tue 2026-06-02 21:17:21 UTC RTC time: Tue 2026-06-02 21:17:21 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': dennis HOME=/home/dennis GROUPS=dennis adm dialout cdrom floppy sudo audio dip video plugdev users netdev iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker SUDO_HOME=/home/dennis GROUPS=iobroker tty dialout audio video plugdev *** DISPLAY-SERVER SETUP *** Display-Server: false Unit display-manager.service could not be found. Display-Manager: Desktop: Session: tty *** MEMORY *** total used free shared buff/cache available Mem: 8.3G 2.0G 4.5G 6.4M 2.1G 6.3G Swap: 1.8G 0B 1.8G Total: 10G 2.0G 6.3G Active iob-Instances: 3 7947 M total memory 1954 M used memory 1575 M active memory 1681 M inactive memory 4316 M free memory 14 M buffer memory 1966 M swap cache 1721 M total swap 0 M used swap 1721 M free swap *** top - Table Of Processes *** top - 23:17:21 up 2:32, 2 users, load average: 2.07, 1.55, 1.29 Tasks: 139 total, 4 running, 135 sleeping, 0 stopped, 0 zombie %Cpu(s): 64.3 us, 2.4 sy, 0.0 ni, 33.3 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 7947.3 total, 4312.2 free, 1958.4 used, 1981.2 buff/cache MiB Swap: 1722.0 total, 1722.0 free, 0.0 used. 5988.9 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.9G 0 3.9G 0% /dev tmpfs tmpfs 795M 580K 795M 1% /run /dev/sda1 ext4 30G 8.1G 21G 29% / tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 3.9G 5.6M 3.9G 1% /tmp tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service tmpfs tmpfs 795M 8.0K 795M 1% /run/user/1000 tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service Messages concerning ext4 filesystem in dmesg: [Tue Jun 2 20:45:12 2026] EXT4-fs (sda1): orphan cleanup on readonly fs [Tue Jun 2 20:45:12 2026] EXT4-fs (sda1): mounted filesystem c05e89b3-8b22-491f-9297-88ed2de1a924 ro with ordered data mode. Quota mode: none. [Tue Jun 2 20:45:12 2026] EXT4-fs (sda1): re-mounted c05e89b3-8b22-491f-9297-88ed2de1a924 r/w. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda1 ext4 rw,relatime,errors=remount-ro Files in neuralgic directories: /var: 1.1G /var/ 489M /var/log 474M /var/log/journal/11a1848b6601495b9e5ed483f6069bbc 474M /var/log/journal 384M /var/cache Archived and active journals take up 473.3M in the file system. /opt/iobroker/backups: 656M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.4G /opt/iobroker/iobroker-data/ 575M /opt/iobroker/iobroker-data/history 548M /opt/iobroker/iobroker-data/files 153M /opt/iobroker/iobroker-data/backup-objects 109M /opt/iobroker/iobroker-data/files/vis-2 The five largest files in iobroker-data are: 103M /opt/iobroker/iobroker-data/states.jsonl 37M /opt/iobroker/iobroker-data/objects.jsonl 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 23M /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map 9.8M /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2196493-if00 *** ZigBee Settings *** ⚠ HINT: Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting: /dev/ttyACM0 No nvbackup.json found. *** NodeJS-Installation *** /usr/bin/nodejs v22.22.2 /usr/bin/node v22.22.2 /usr/bin/npm 10.9.7 /usr/bin/npx 10.9.7 ✓ Node.js installation is correct nodejs: Installed: 22.22.2-1nodesource1 Candidate: 22.22.2-1nodesource1 Version table: *** 22.22.2-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 22.22.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.22.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 20.19.2+dfsg-1+deb13u2 500 500 http://deb.debian.org/debian trixie/main amd64 Packages 500 http://security.debian.org/debian-security trixie-security/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: █████ ██ ██ ██████ ██████ ██████ ██████ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ███████ ██ ██ ██ ███ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ███████ ███████ ██████ ██████ ██████ ██████ ██ *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: ioBroker2025 ioBroker2025 (version: 7.0.7, hostname: ioBroker2025 , alive, uptime: 18) Core adapters versions js-controller: 7.0.7 admin: 7.8.23 javascript: 9.0.18 nodejs modules from github: 2 +-- iobroker.labcom@0.1.1 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#b6dc2782e6748c0c1d677e1d0a5a4c1fe1e68127) +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba) Adapter State + system.adapter.admin.1 : admin : ioBroker2025 - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alexa2.0 : alexa2 : ioBroker2025 - enabled system.adapter.alias-manager.0 : alias-manager : ioBroker2025 - disabled system.adapter.backitup.0 : backitup : ioBroker2025 - enabled system.adapter.bring.0 : bring : ioBroker2025 - enabled system.adapter.cloud.0 : cloud : ioBroker2025 - enabled system.adapter.daswetter.0 : daswetter : ioBroker2025 - enabled system.adapter.device-reminder.0 : device-reminder : ioBroker2025 - enabled system.adapter.device-watcher.0 : device-watcher : ioBroker2025 - enabled system.adapter.devices.0 : devices : ioBroker2025 - disabled system.adapter.discovery.0 : discovery : ioBroker2025 - enabled system.adapter.dwd.0 : dwd : ioBroker2025 - enabled system.adapter.echarts.0 : echarts : ioBroker2025 - enabled system.adapter.fb-checkpresence.0 : fb-checkpresence : ioBroker2025 - enabled system.adapter.flot.0 : flot : ioBroker2025 - disabled system.adapter.govee-app.0 : govee-app : ioBroker2025 - enabled system.adapter.govee-local.0 : govee-local : ioBroker2025 - enabled + system.adapter.history.0 : history : ioBroker2025 - enabled system.adapter.hmip.0 : hmip : ioBroker2025 - enabled system.adapter.ical.0 : ical : ioBroker2025 - enabled system.adapter.ical.1 : ical : ioBroker2025 - enabled system.adapter.ical.2 : ical : ioBroker2025 - enabled system.adapter.icons-mfd-png.0 : icons-mfd-png : ioBroker2025 - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : ioBroker2025 - disabled system.adapter.iot.0 : iot : ioBroker2025 - enabled system.adapter.javascript.0 : javascript : ioBroker2025 - enabled system.adapter.labcom.0 : labcom : ioBroker2025 - disabled system.adapter.plenticore.0 : plenticore : ioBroker2025 - enabled, port: 80 system.adapter.pollenflug.0 : pollenflug : ioBroker2025 - enabled system.adapter.poolcontrol.0 : poolcontrol : ioBroker2025 - enabled system.adapter.proxmox.0 : proxmox : ioBroker2025 - enabled, port: 8006 system.adapter.rickshaw.0 : rickshaw : ioBroker2025 - disabled system.adapter.roomba.0 : roomba : ioBroker2025 - disabled system.adapter.simple-api.0 : simple-api : ioBroker2025 - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.sourceanalytix.0 : sourceanalytix : ioBroker2025 - enabled system.adapter.tankerkoenig.0 : tankerkoenig : ioBroker2025 - enabled system.adapter.telegram-menu.0 : telegram-menu : ioBroker2025 - disabled system.adapter.telegram.0 : telegram : ioBroker2025 - enabled, port: 8443, bind: 0.0.0.0 system.adapter.text2command.0 : text2command : ioBroker2025 - enabled system.adapter.tr-064.0 : tr-064 : ioBroker2025 - enabled system.adapter.trashschedule.0 : trashschedule : ioBroker2025 - enabled system.adapter.tuya.0 : tuya : ioBroker2025 - enabled system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: ioBroker2025 - disabled system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker2025 - disabled system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker2025 - disabled system.adapter.vis-2.0 : vis-2 : ioBroker2025 - enabled system.adapter.vis-bars.0 : vis-bars : ioBroker2025 - disabled system.adapter.vis-history.0 : vis-history : ioBroker2025 - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : ioBroker2025 - disabled system.adapter.vis-inventwo.0 : vis-inventwo : ioBroker2025 - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : ioBroker2025 - disabled system.adapter.vis-justgage.0 : vis-justgage : ioBroker2025 - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : ioBroker2025 - disabled system.adapter.vis-metro.0 : vis-metro : ioBroker2025 - disabled system.adapter.vis-players.0 : vis-players : ioBroker2025 - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : ioBroker2025 - disabled system.adapter.vis.0 : vis : ioBroker2025 - enabled system.adapter.volvo.0 : volvo : ioBroker2025 - enabled system.adapter.web.0 : web : ioBroker2025 - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.zigbee.0 : zigbee : ioBroker2025 - enabled, port: /dev/ttyACM0 + instance is alive Enabled adapters with bindings + system.adapter.admin.1 : admin : ioBroker2025 - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.plenticore.0 : plenticore : ioBroker2025 - enabled, port: 80 system.adapter.proxmox.0 : proxmox : ioBroker2025 - enabled, port: 8006 system.adapter.simple-api.0 : simple-api : ioBroker2025 - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.telegram.0 : telegram : ioBroker2025 - enabled, port: 8443, bind: 0.0.0.0 system.adapter.web.0 : web : ioBroker2025 - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.zigbee.0 : zigbee : ioBroker2025 - enabled, port: /dev/ttyACM0 ioBroker-Repositories ┌─────────┬────────────────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼────────────────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'Beta (latest)' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴────────────────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): Stable (default) Upgrade policy: none Installed ioBroker-Adapters Used repository: Stable (default) Adapter "admin" : 7.8.23 , installed 7.8.23 Adapter "alexa2" : 3.27.4 , installed 3.27.4 Adapter "alias-manager": 2.1.0 , installed 2.1.0 Adapter "backitup" : 3.3.14 , installed 3.3.14 Adapter "bring" : 1.8.4 , installed 1.8.4 Adapter "cloud" : 6.0.1 , installed 6.0.1 Adapter "daswetter" : 4.5.3 , installed 4.5.3 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "device-watcher": 2.15.5 , installed 2.15.5 Adapter "devices" : 1.2.14 , installed 1.2.14 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 3.1.0 , installed 3.1.0 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "govee-local" : 0.4.5 , installed 0.4.5 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "hmip" : 1.27.0 , installed 1.27.0 Adapter "ical" : 1.20.0 , installed 1.20.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "iot" : 5.0.12 , installed 5.0.12 Adapter "javascript" : 9.0.18 , installed 9.0.18 Controller "js-controller": 7.0.7 , installed 7.0.7 Adapter "plenticore" : 2.2.0 , installed 2.2.0 Adapter "pollenflug" : 2.0.0 , installed 2.0.0 Adapter "proxmox" : 2.4.10 , installed 2.4.10 Adapter "rickshaw" : 1.0.0 , installed 1.0.0 Adapter "roomba" : 1.3.0 , installed 1.3.0 Adapter "simple-api" : 3.0.7 , installed 3.0.7 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 4.1.0 , installed 4.1.0 Adapter "telegram-menu": 3.2.3 , installed 3.2.3 Adapter "text2command" : 4.0.0 , installed 4.0.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "trashschedule": 5.3.0 , installed 5.3.0 Adapter "tuya" : 3.17.0 , installed 3.17.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.13.8 , installed 2.13.8 Adapter "vis-2-widgets-collection": 1.8.1, installed 1.8.1 Adapter "vis-2-widgets-inventwo": 1.0.0, installed 1.0.0 Adapter "vis-2-widgets-material": 1.6.1, installed 1.4.10 [Updatable] Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.6.1 , installed 1.6.1 Adapter "vis-inventwo" : 4.1.0 , installed 4.1.0 Adapter "vis-jqui-mfd" : 1.1.3 , installed 1.1.3 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "volvo" : 3.0.0 , installed 3.0.0 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "ws" : 4.0.0 , installed 4.0.0 Adapter "zigbee" : 3.3.5 , installed 1.10.14 [Updatable] Objects and States Please stand by - This may take a while Objects: 22695 States: 166181 *** OS-Repositories and Updates *** Hit:1 http://security.debian.org/debian-security trixie-security InRelease Hit:2 http://deb.debian.org/debian trixie InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 58346 16771/iobroker.js-c tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 57224 16771/iobroker.js-c tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 52797 9944/sshd: /usr/sbi tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 3718 1/systemd tcp6 0 0 :::22 :::* LISTEN 0 52799 9944/sshd: /usr/sbi tcp6 0 0 :::111 :::* LISTEN 0 452 1/systemd tcp6 0 0 :::8081 :::* LISTEN 1001 60486 16794/io.admin.1 udp 0 0 0.0.0.0:4002 0.0.0.0:* 1001 62347 17452/io.govee-loca udp 0 0 192.168.178.120:68 0.0.0.0:* 0 6065 811/dhcpcd: [BOOTP udp 0 0 0.0.0.0:111 0.0.0.0:* 0 3719 1/systemd udp6 0 0 :::111 :::* 0 4372 1/systemd udp6 0 0 fda5:d281:2402:0:f6:546 :::* 0 6051 776/dhcpcd: [DHCP6 udp6 0 0 2a01:41e1:1e84:3900:546 :::* 0 6011 756/dhcpcd: [DHCP6 udp6 0 0 fe80::82fa:60d3:250:546 :::* 0 5008 713/dhcpcd: [DHCP6 *** Log File - Last 25 Lines *** 2026-06-02 23:17:45.710 - info: host.ioBroker2025 instance system.adapter.ical.0 in version "1.20.0" started with pid 17518 2026-06-02 23:17:48.192 - info: ical.0 (17518) starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.0.7 2026-06-02 23:17:49.563 - info: ical.0 (17518) processing URL: Kalender Menger https://outlook.live.com/owa/calendar/8cd7b017-fa7d-4cfa-966c-0c41bcddccd7/93aaa8a3-6754-4f63-9451-bfbafe749441/cid-FDE760221FEA4657/calendar.ics 2026-06-02 23:17:51.488 - info: host.ioBroker2025 instance scheduled system.adapter.ical.1 0,30 * * * * 2026-06-02 23:17:51.492 - info: host.ioBroker2025 instance system.adapter.ical.1 in version "1.20.0" started with pid 17558 2026-06-02 23:17:57.529 - info: host.ioBroker2025 instance scheduled system.adapter.ical.2 0,30 * * * * 2026-06-02 23:17:57.534 - info: host.ioBroker2025 instance system.adapter.ical.2 in version "1.20.0" started with pid 17570 2026-06-02 23:17:57.873 - info: admin.1 (16794) <== Disconnect system.user.admin from ::ffff:192.168.178.40 2026-06-02 23:18:01.311 - info: ical.0 (17518) Terminated (NO_ERROR): Without reason 2026-06-02 23:18:01.949 - info: host.ioBroker2025 instance system.adapter.pollenflug.0 in version "2.0.0" started with pid 17582 2026-06-02 23:18:02.174 - info: cloud.0 (17339) Trying to connect as system.user.admin to cloud 2026-06-02 23:18:02.295 - info: host.ioBroker2025 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR) 2026-06-02 23:18:02.295 - info: cloud.0 (17339) Connection changed: connect 2026-06-02 23:18:02.525 - info: host.ioBroker2025 instance system.adapter.proxmox.0 in version "2.4.10" started with pid 17590 2026-06-02 23:18:02.579 - info: ical.1 (17558) starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.0.7 2026-06-02 23:18:02.866 - info: ical.2 (17570) starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.0.7 2026-06-02 23:18:03.020 - info: ical.1 (17558) processing URL: Müll https://www.awsh.de/api_v2/collection_dates/1/ort/71/strasse/150/hausnummern/0/abfallarten/R02-B02-D02-P04-W0/kalender.ics 2026-06-02 23:18:03.415 - info: ical.2 (17570) processing URL: HSV http://i.cal.to/ical/12/hsv/bundesliga-spielplan/d4c69b46.3ec5e7c4-d88aa88f.ics 2026-06-02 23:18:04.697 - info: pollenflug.0 (17582) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.pollenflug, node: v22.22.2, js-controller: 7.0.7 2026-06-02 23:18:04.715 - info: pollenflug.0 (17582) Starting Adapter pollenflug.0 in version 2.0.0 2026-06-02 23:18:04.733 - info: pollenflug.0 (17582) Requesting DWD pollen information now. 2026-06-02 23:18:04.741 - info: proxmox.0 (17590) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.proxmox, node: v22.22.2, js-controller: 7.0.7 2026-06-02 23:18:04.831 - warn: proxmox.0 (17590) Using next Proxmox API: https://192.168.178.201:8006/api2/json 2026-06-02 23:18:05.699 - info: host.ioBroker2025 instance system.adapter.tr-064.0 in version "4.3.0" started with pid 17657 2026-06-02 23:18:05.861 - info: pollenflug.0 (17582) Next DWD pollen request starts on Wed Jun 03 2026 11:00:00 GMT+0200 (Mitteleuropäische Sommerzeit) -
Script v.2026-01-31 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: ioBroker2025 Icon name: computer-vm Chassis: vm 🖴 Virtualization: kvm Kernel: Linux 6.12.74+deb13+1-amd64 Architecture: x86-64 Hardware Vendor: QEMU Hardware Model: Standard PC _i440FX + PIIX, 1996_ Firmware Version: rel-1.17.0-0-gb52ca86e094d-prebuilt.qemu.org Firmware Date: Tue 2014-04-01 Firmware Age: 12y 2month 2d OS is similar to: model name : QEMU Virtual CPU version 2.5+ Docker : false Virtualization : kvm Kernel : x86_64 Userland : 64 bit Systemuptime and Load: 23:17:21 up 2:32, 2 users, load average: 2.07, 1.55, 1.29 CPU threads: 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** TIME AND TIMEZONES *** Local time: Tue 2026-06-02 23:17:21 CEST Universal time: Tue 2026-06-02 21:17:21 UTC RTC time: Tue 2026-06-02 21:17:21 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': dennis HOME=/home/dennis GROUPS=dennis adm dialout cdrom floppy sudo audio dip video plugdev users netdev iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker SUDO_HOME=/home/dennis GROUPS=iobroker tty dialout audio video plugdev *** DISPLAY-SERVER SETUP *** Display-Server: false Unit display-manager.service could not be found. Display-Manager: Desktop: Session: tty *** MEMORY *** total used free shared buff/cache available Mem: 8.3G 2.0G 4.5G 6.4M 2.1G 6.3G Swap: 1.8G 0B 1.8G Total: 10G 2.0G 6.3G Active iob-Instances: 3 7947 M total memory 1954 M used memory 1575 M active memory 1681 M inactive memory 4316 M free memory 14 M buffer memory 1966 M swap cache 1721 M total swap 0 M used swap 1721 M free swap *** top - Table Of Processes *** top - 23:17:21 up 2:32, 2 users, load average: 2.07, 1.55, 1.29 Tasks: 139 total, 4 running, 135 sleeping, 0 stopped, 0 zombie %Cpu(s): 64.3 us, 2.4 sy, 0.0 ni, 33.3 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 7947.3 total, 4312.2 free, 1958.4 used, 1981.2 buff/cache MiB Swap: 1722.0 total, 1722.0 free, 0.0 used. 5988.9 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.9G 0 3.9G 0% /dev tmpfs tmpfs 795M 580K 795M 1% /run /dev/sda1 ext4 30G 8.1G 21G 29% / tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 3.9G 5.6M 3.9G 1% /tmp tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service tmpfs tmpfs 795M 8.0K 795M 1% /run/user/1000 tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service Messages concerning ext4 filesystem in dmesg: [Tue Jun 2 20:45:12 2026] EXT4-fs (sda1): orphan cleanup on readonly fs [Tue Jun 2 20:45:12 2026] EXT4-fs (sda1): mounted filesystem c05e89b3-8b22-491f-9297-88ed2de1a924 ro with ordered data mode. Quota mode: none. [Tue Jun 2 20:45:12 2026] EXT4-fs (sda1): re-mounted c05e89b3-8b22-491f-9297-88ed2de1a924 r/w. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda1 ext4 rw,relatime,errors=remount-ro Files in neuralgic directories: /var: 1.1G /var/ 489M /var/log 474M /var/log/journal/11a1848b6601495b9e5ed483f6069bbc 474M /var/log/journal 384M /var/cache Archived and active journals take up 473.3M in the file system. /opt/iobroker/backups: 656M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.4G /opt/iobroker/iobroker-data/ 575M /opt/iobroker/iobroker-data/history 548M /opt/iobroker/iobroker-data/files 153M /opt/iobroker/iobroker-data/backup-objects 109M /opt/iobroker/iobroker-data/files/vis-2 The five largest files in iobroker-data are: 103M /opt/iobroker/iobroker-data/states.jsonl 37M /opt/iobroker/iobroker-data/objects.jsonl 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 23M /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map 9.8M /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2196493-if00 *** ZigBee Settings *** ⚠ HINT: Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting: /dev/ttyACM0 No nvbackup.json found. *** NodeJS-Installation *** /usr/bin/nodejs v22.22.2 /usr/bin/node v22.22.2 /usr/bin/npm 10.9.7 /usr/bin/npx 10.9.7 ✓ Node.js installation is correct nodejs: Installed: 22.22.2-1nodesource1 Candidate: 22.22.2-1nodesource1 Version table: *** 22.22.2-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 22.22.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.22.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 20.19.2+dfsg-1+deb13u2 500 500 http://deb.debian.org/debian trixie/main amd64 Packages 500 http://security.debian.org/debian-security trixie-security/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: █████ ██ ██ ██████ ██████ ██████ ██████ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ███████ ██ ██ ██ ███ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ███████ ███████ ██████ ██████ ██████ ██████ ██ *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: ioBroker2025 ioBroker2025 (version: 7.0.7, hostname: ioBroker2025 , alive, uptime: 18) Core adapters versions js-controller: 7.0.7 admin: 7.8.23 javascript: 9.0.18 nodejs modules from github: 2 +-- iobroker.labcom@0.1.1 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#b6dc2782e6748c0c1d677e1d0a5a4c1fe1e68127) +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba) Adapter State + system.adapter.admin.1 : admin : ioBroker2025 - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alexa2.0 : alexa2 : ioBroker2025 - enabled system.adapter.alias-manager.0 : alias-manager : ioBroker2025 - disabled system.adapter.backitup.0 : backitup : ioBroker2025 - enabled system.adapter.bring.0 : bring : ioBroker2025 - enabled system.adapter.cloud.0 : cloud : ioBroker2025 - enabled system.adapter.daswetter.0 : daswetter : ioBroker2025 - enabled system.adapter.device-reminder.0 : device-reminder : ioBroker2025 - enabled system.adapter.device-watcher.0 : device-watcher : ioBroker2025 - enabled system.adapter.devices.0 : devices : ioBroker2025 - disabled system.adapter.discovery.0 : discovery : ioBroker2025 - enabled system.adapter.dwd.0 : dwd : ioBroker2025 - enabled system.adapter.echarts.0 : echarts : ioBroker2025 - enabled system.adapter.fb-checkpresence.0 : fb-checkpresence : ioBroker2025 - enabled system.adapter.flot.0 : flot : ioBroker2025 - disabled system.adapter.govee-app.0 : govee-app : ioBroker2025 - enabled system.adapter.govee-local.0 : govee-local : ioBroker2025 - enabled + system.adapter.history.0 : history : ioBroker2025 - enabled system.adapter.hmip.0 : hmip : ioBroker2025 - enabled system.adapter.ical.0 : ical : ioBroker2025 - enabled system.adapter.ical.1 : ical : ioBroker2025 - enabled system.adapter.ical.2 : ical : ioBroker2025 - enabled system.adapter.icons-mfd-png.0 : icons-mfd-png : ioBroker2025 - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : ioBroker2025 - disabled system.adapter.iot.0 : iot : ioBroker2025 - enabled system.adapter.javascript.0 : javascript : ioBroker2025 - enabled system.adapter.labcom.0 : labcom : ioBroker2025 - disabled system.adapter.plenticore.0 : plenticore : ioBroker2025 - enabled, port: 80 system.adapter.pollenflug.0 : pollenflug : ioBroker2025 - enabled system.adapter.poolcontrol.0 : poolcontrol : ioBroker2025 - enabled system.adapter.proxmox.0 : proxmox : ioBroker2025 - enabled, port: 8006 system.adapter.rickshaw.0 : rickshaw : ioBroker2025 - disabled system.adapter.roomba.0 : roomba : ioBroker2025 - disabled system.adapter.simple-api.0 : simple-api : ioBroker2025 - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.sourceanalytix.0 : sourceanalytix : ioBroker2025 - enabled system.adapter.tankerkoenig.0 : tankerkoenig : ioBroker2025 - enabled system.adapter.telegram-menu.0 : telegram-menu : ioBroker2025 - disabled system.adapter.telegram.0 : telegram : ioBroker2025 - enabled, port: 8443, bind: 0.0.0.0 system.adapter.text2command.0 : text2command : ioBroker2025 - enabled system.adapter.tr-064.0 : tr-064 : ioBroker2025 - enabled system.adapter.trashschedule.0 : trashschedule : ioBroker2025 - enabled system.adapter.tuya.0 : tuya : ioBroker2025 - enabled system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: ioBroker2025 - disabled system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker2025 - disabled system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker2025 - disabled system.adapter.vis-2.0 : vis-2 : ioBroker2025 - enabled system.adapter.vis-bars.0 : vis-bars : ioBroker2025 - disabled system.adapter.vis-history.0 : vis-history : ioBroker2025 - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : ioBroker2025 - disabled system.adapter.vis-inventwo.0 : vis-inventwo : ioBroker2025 - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : ioBroker2025 - disabled system.adapter.vis-justgage.0 : vis-justgage : ioBroker2025 - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : ioBroker2025 - disabled system.adapter.vis-metro.0 : vis-metro : ioBroker2025 - disabled system.adapter.vis-players.0 : vis-players : ioBroker2025 - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : ioBroker2025 - disabled system.adapter.vis.0 : vis : ioBroker2025 - enabled system.adapter.volvo.0 : volvo : ioBroker2025 - enabled system.adapter.web.0 : web : ioBroker2025 - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.zigbee.0 : zigbee : ioBroker2025 - enabled, port: /dev/ttyACM0 + instance is alive Enabled adapters with bindings + system.adapter.admin.1 : admin : ioBroker2025 - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.plenticore.0 : plenticore : ioBroker2025 - enabled, port: 80 system.adapter.proxmox.0 : proxmox : ioBroker2025 - enabled, port: 8006 system.adapter.simple-api.0 : simple-api : ioBroker2025 - enabled, port: 8087, bind: 0.0.0.0, run as: admin system.adapter.telegram.0 : telegram : ioBroker2025 - enabled, port: 8443, bind: 0.0.0.0 system.adapter.web.0 : web : ioBroker2025 - enabled, port: 8082, bind: 0.0.0.0, run as: admin system.adapter.zigbee.0 : zigbee : ioBroker2025 - enabled, port: /dev/ttyACM0 ioBroker-Repositories ┌─────────┬────────────────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼────────────────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'Beta (latest)' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴────────────────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): Stable (default) Upgrade policy: none Installed ioBroker-Adapters Used repository: Stable (default) Adapter "admin" : 7.8.23 , installed 7.8.23 Adapter "alexa2" : 3.27.4 , installed 3.27.4 Adapter "alias-manager": 2.1.0 , installed 2.1.0 Adapter "backitup" : 3.3.14 , installed 3.3.14 Adapter "bring" : 1.8.4 , installed 1.8.4 Adapter "cloud" : 6.0.1 , installed 6.0.1 Adapter "daswetter" : 4.5.3 , installed 4.5.3 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "device-watcher": 2.15.5 , installed 2.15.5 Adapter "devices" : 1.2.14 , installed 1.2.14 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 3.1.0 , installed 3.1.0 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "govee-local" : 0.4.5 , installed 0.4.5 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "hmip" : 1.27.0 , installed 1.27.0 Adapter "ical" : 1.20.0 , installed 1.20.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "iot" : 5.0.12 , installed 5.0.12 Adapter "javascript" : 9.0.18 , installed 9.0.18 Controller "js-controller": 7.0.7 , installed 7.0.7 Adapter "plenticore" : 2.2.0 , installed 2.2.0 Adapter "pollenflug" : 2.0.0 , installed 2.0.0 Adapter "proxmox" : 2.4.10 , installed 2.4.10 Adapter "rickshaw" : 1.0.0 , installed 1.0.0 Adapter "roomba" : 1.3.0 , installed 1.3.0 Adapter "simple-api" : 3.0.7 , installed 3.0.7 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 4.1.0 , installed 4.1.0 Adapter "telegram-menu": 3.2.3 , installed 3.2.3 Adapter "text2command" : 4.0.0 , installed 4.0.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "trashschedule": 5.3.0 , installed 5.3.0 Adapter "tuya" : 3.17.0 , installed 3.17.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.13.8 , installed 2.13.8 Adapter "vis-2-widgets-collection": 1.8.1, installed 1.8.1 Adapter "vis-2-widgets-inventwo": 1.0.0, installed 1.0.0 Adapter "vis-2-widgets-material": 1.6.1, installed 1.4.10 [Updatable] Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.6.1 , installed 1.6.1 Adapter "vis-inventwo" : 4.1.0 , installed 4.1.0 Adapter "vis-jqui-mfd" : 1.1.3 , installed 1.1.3 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "volvo" : 3.0.0 , installed 3.0.0 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "ws" : 4.0.0 , installed 4.0.0 Adapter "zigbee" : 3.3.5 , installed 1.10.14 [Updatable] Objects and States Please stand by - This may take a while Objects: 22695 States: 166181 *** OS-Repositories and Updates *** Hit:1 http://security.debian.org/debian-security trixie-security InRelease Hit:2 http://deb.debian.org/debian trixie InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 58346 16771/iobroker.js-c tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 57224 16771/iobroker.js-c tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 52797 9944/sshd: /usr/sbi tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 3718 1/systemd tcp6 0 0 :::22 :::* LISTEN 0 52799 9944/sshd: /usr/sbi tcp6 0 0 :::111 :::* LISTEN 0 452 1/systemd tcp6 0 0 :::8081 :::* LISTEN 1001 60486 16794/io.admin.1 udp 0 0 0.0.0.0:4002 0.0.0.0:* 1001 62347 17452/io.govee-loca udp 0 0 192.168.178.120:68 0.0.0.0:* 0 6065 811/dhcpcd: [BOOTP udp 0 0 0.0.0.0:111 0.0.0.0:* 0 3719 1/systemd udp6 0 0 :::111 :::* 0 4372 1/systemd udp6 0 0 fda5:d281:2402:0:f6:546 :::* 0 6051 776/dhcpcd: [DHCP6 udp6 0 0 2a01:41e1:1e84:3900:546 :::* 0 6011 756/dhcpcd: [DHCP6 udp6 0 0 fe80::82fa:60d3:250:546 :::* 0 5008 713/dhcpcd: [DHCP6 *** Log File - Last 25 Lines *** 2026-06-02 23:17:45.710 - info: host.ioBroker2025 instance system.adapter.ical.0 in version "1.20.0" started with pid 17518 2026-06-02 23:17:48.192 - info: ical.0 (17518) starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.0.7 2026-06-02 23:17:49.563 - info: ical.0 (17518) processing URL: Kalender Menger https://outlook.live.com/owa/calendar/8cd7b017-fa7d-4cfa-966c-0c41bcddccd7/93aaa8a3-6754-4f63-9451-bfbafe749441/cid-FDE760221FEA4657/calendar.ics 2026-06-02 23:17:51.488 - info: host.ioBroker2025 instance scheduled system.adapter.ical.1 0,30 * * * * 2026-06-02 23:17:51.492 - info: host.ioBroker2025 instance system.adapter.ical.1 in version "1.20.0" started with pid 17558 2026-06-02 23:17:57.529 - info: host.ioBroker2025 instance scheduled system.adapter.ical.2 0,30 * * * * 2026-06-02 23:17:57.534 - info: host.ioBroker2025 instance system.adapter.ical.2 in version "1.20.0" started with pid 17570 2026-06-02 23:17:57.873 - info: admin.1 (16794) <== Disconnect system.user.admin from ::ffff:192.168.178.40 2026-06-02 23:18:01.311 - info: ical.0 (17518) Terminated (NO_ERROR): Without reason 2026-06-02 23:18:01.949 - info: host.ioBroker2025 instance system.adapter.pollenflug.0 in version "2.0.0" started with pid 17582 2026-06-02 23:18:02.174 - info: cloud.0 (17339) Trying to connect as system.user.admin to cloud 2026-06-02 23:18:02.295 - info: host.ioBroker2025 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR) 2026-06-02 23:18:02.295 - info: cloud.0 (17339) Connection changed: connect 2026-06-02 23:18:02.525 - info: host.ioBroker2025 instance system.adapter.proxmox.0 in version "2.4.10" started with pid 17590 2026-06-02 23:18:02.579 - info: ical.1 (17558) starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.0.7 2026-06-02 23:18:02.866 - info: ical.2 (17570) starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.0.7 2026-06-02 23:18:03.020 - info: ical.1 (17558) processing URL: Müll https://www.awsh.de/api_v2/collection_dates/1/ort/71/strasse/150/hausnummern/0/abfallarten/R02-B02-D02-P04-W0/kalender.ics 2026-06-02 23:18:03.415 - info: ical.2 (17570) processing URL: HSV http://i.cal.to/ical/12/hsv/bundesliga-spielplan/d4c69b46.3ec5e7c4-d88aa88f.ics 2026-06-02 23:18:04.697 - info: pollenflug.0 (17582) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.pollenflug, node: v22.22.2, js-controller: 7.0.7 2026-06-02 23:18:04.715 - info: pollenflug.0 (17582) Starting Adapter pollenflug.0 in version 2.0.0 2026-06-02 23:18:04.733 - info: pollenflug.0 (17582) Requesting DWD pollen information now. 2026-06-02 23:18:04.741 - info: proxmox.0 (17590) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.proxmox, node: v22.22.2, js-controller: 7.0.7 2026-06-02 23:18:04.831 - warn: proxmox.0 (17590) Using next Proxmox API: https://192.168.178.201:8006/api2/json 2026-06-02 23:18:05.699 - info: host.ioBroker2025 instance system.adapter.tr-064.0 in version "4.3.0" started with pid 17657 2026-06-02 23:18:05.861 - info: pollenflug.0 (17582) Next DWD pollen request starts on Wed Jun 03 2026 11:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)Active iob-Instances: 3
Lass den ioBroker jetzt erstmal starten...
Hallo zusammen.
Folgende Fehlermeldung erhalte ich beim Anzeigen meiner Vis2 beim Aufruf über iobroker.pro. Beim Zugriff intern im Heimnetz funktioniert die Anzeige. Bis vor einigen Wochen hat der Zugriff über iobroker.pro noch einwandfrei funktioniert.
Ein Downgrade des Adapters "Vis 2 Widgets Material" von 1.6.1 auf 1.4.10 brachte kein Erfolg. Browsercache ebenfalls gelöscht. Kann noch jemand das Problem so bestätigen. Werden weitere Angaben benötigt?
Starte zur Sicherheit einmal noch den vis2 Adapter neu.
Wenn dann, wer nicht der ioBroker Log interessant, sondern der Browser log mit F 12
Das ist ein vis2/react Thema
========== Start marking the full check here =========== ```bash Script v.2026-01-31 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 13 (trixie) Static hostname: ioBroker2025 Icon name: computer-vm Chassis: vm 🖴 Virtualization: kvm Kernel: Linux 6.12.90+deb13.1-amd64 Architecture: x86-64 Hardware Vendor: QEMU Hardware Model: Standard PC _i440FX + PIIX, 1996_ Firmware Version: rel-1.17.0-0-gb52ca86e094d-prebuilt.qemu.org Firmware Date: Tue 2014-04-01 Firmware Age: 12y 2month 2d OS is similar to: model name : QEMU Virtual CPU version 2.5+ Docker : false Virtualization : kvm Kernel : x86_64 Userland : 64 bit Systemuptime and Load: 23:31:02 up 3 min, 1 user, load average: 0.78, 0.53, 0.22 CPU threads: 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'trixie'! *** TIME AND TIMEZONES *** Local time: Tue 2026-06-02 23:31:02 CEST Universal time: Tue 2026-06-02 21:31:02 UTC RTC time: Tue 2026-06-02 21:31:02 Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': dennis HOME=/home/dennis GROUPS=dennis adm dialout cdrom floppy sudo audio dip video plugdev users netdev iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker SUDO_HOME=/home/dennis GROUPS=iobroker tty dialout audio video plugdev *** DISPLAY-SERVER SETUP *** Display-Server: false Unit display-manager.service could not be found. Display-Manager: Desktop: Session: tty *** MEMORY *** total used free shared buff/cache available Mem: 8.3G 3.3G 4.5G 3.5M 819M 5.0G Swap: 1.8G 0B 1.8G Total: 10G 3.3G 6.3G Active iob-Instances: 34 7947 M total memory 3159 M used memory 2920 M active memory 538 M inactive memory 4245 M free memory 50 M buffer memory 730 M swap cache 1721 M total swap 0 M used swap 1721 M free swap *** top - Table Of Processes *** top - 23:31:02 up 3 min, 1 user, load average: 0.78, 0.53, 0.22 Tasks: 171 total, 1 running, 170 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 7947.3 total, 4245.5 free, 3159.7 used, 781.7 buff/cache MiB Swap: 1722.0 total, 1722.0 free, 0.0 used. 4787.6 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 3.9G 0 3.9G 0% /dev tmpfs tmpfs 795M 568K 795M 1% /run /dev/sda1 ext4 30G 8.1G 21G 29% / tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/systemd-journald.service tmpfs tmpfs 3.9G 2.8M 3.9G 1% /tmp tmpfs tmpfs 1.0M 0 1.0M 0% /run/credentials/getty@tty1.service tmpfs tmpfs 795M 8.0K 795M 1% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Tue Jun 2 23:27:45 2026] EXT4-fs (sda1): orphan cleanup on readonly fs [Tue Jun 2 23:27:45 2026] EXT4-fs (sda1): mounted filesystem c05e89b3-8b22-491f-9297-88ed2de1a924 ro with ordered data mode. Quota mode: none. [Tue Jun 2 23:27:46 2026] EXT4-fs (sda1): re-mounted c05e89b3-8b22-491f-9297-88ed2de1a924 r/w. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/sda1 ext4 rw,relatime,errors=remount-ro Files in neuralgic directories: /var: 1.1G /var/ 489M /var/log 474M /var/log/journal/11a1848b6601495b9e5ed483f6069bbc 474M /var/log/journal 384M /var/cache Archived and active journals take up 473.3M in the file system. /opt/iobroker/backups: 656M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.4G /opt/iobroker/iobroker-data/ 575M /opt/iobroker/iobroker-data/history 548M /opt/iobroker/iobroker-data/files 153M /opt/iobroker/iobroker-data/backup-objects 109M /opt/iobroker/iobroker-data/files/vis-2 The five largest files in iobroker-data are: 110M /opt/iobroker/iobroker-data/states.jsonl 31M /opt/iobroker/iobroker-data/objects.jsonl 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 23M /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map 9.8M /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2196493-if00 *** ZigBee Settings *** ⚠ HINT: Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting: /dev/ttyACM0 No nvbackup.json found. *** NodeJS-Installation *** /usr/bin/nodejs v22.22.2 /usr/bin/node v22.22.2 /usr/bin/npm 10.9.7 /usr/bin/npx 10.9.7 ✓ Node.js installation is correct nodejs: Installed: 22.22.2-1nodesource1 Candidate: 22.22.2-1nodesource1 Version table: *** 22.22.2-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 22.22.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.22.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 22.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages 20.19.2+dfsg-1+deb13u2 500 500 http://deb.debian.org/debian trixie/main amd64 Packages 500 http://security.debian.org/debian-security trixie-security/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: █████ ██ ██ ██████ ██████ ██████ ██████ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ███████ ██ ██ ██ ███ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ███████ ███████ ██████ ██████ ██████ ██████ ██ *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: ioBroker2025 ioBroker2025 (version: 7.0.7, hostname: ioBroker2025 , alive, uptime: 199) Core adapters versions js-controller: 7.0.7 admin: 7.8.23 javascript: 9.0.18 nodejs modules from github: 2 +-- iobroker.labcom@0.1.1 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#b6dc2782e6748c0c1d677e1d0a5a4c1fe1e68127) +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba) Adapter State + system.adapter.admin.1 : admin : ioBroker2025 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : ioBroker2025 - enabled system.adapter.alias-manager.0 : alias-manager : ioBroker2025 - disabled + system.adapter.backitup.0 : backitup : ioBroker2025 - enabled + system.adapter.bring.0 : bring : ioBroker2025 - enabled + system.adapter.cloud.0 : cloud : ioBroker2025 - enabled + system.adapter.daswetter.0 : daswetter : ioBroker2025 - enabled + system.adapter.device-reminder.0 : device-reminder : ioBroker2025 - enabled + system.adapter.device-watcher.0 : device-watcher : ioBroker2025 - enabled system.adapter.devices.0 : devices : ioBroker2025 - disabled + system.adapter.discovery.0 : discovery : ioBroker2025 - enabled system.adapter.dwd.0 : dwd : ioBroker2025 - enabled + system.adapter.echarts.0 : echarts : ioBroker2025 - enabled + system.adapter.fb-checkpresence.0 : fb-checkpresence : ioBroker2025 - enabled system.adapter.flot.0 : flot : ioBroker2025 - disabled + system.adapter.govee-app.0 : govee-app : ioBroker2025 - enabled + system.adapter.govee-local.0 : govee-local : ioBroker2025 - enabled + system.adapter.history.0 : history : ioBroker2025 - enabled + system.adapter.hmip.0 : hmip : ioBroker2025 - enabled system.adapter.ical.0 : ical : ioBroker2025 - enabled system.adapter.ical.1 : ical : ioBroker2025 - enabled system.adapter.ical.2 : ical : ioBroker2025 - enabled system.adapter.icons-mfd-png.0 : icons-mfd-png : ioBroker2025 - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : ioBroker2025 - disabled + system.adapter.iot.0 : iot : ioBroker2025 - enabled + system.adapter.javascript.0 : javascript : ioBroker2025 - enabled system.adapter.labcom.0 : labcom : ioBroker2025 - disabled + system.adapter.plenticore.0 : plenticore : ioBroker2025 - enabled, port: 80 + system.adapter.pollenflug.0 : pollenflug : ioBroker2025 - enabled + system.adapter.poolcontrol.0 : poolcontrol : ioBroker2025 - enabled + system.adapter.proxmox.0 : proxmox : ioBroker2025 - enabled, port: 8006 system.adapter.rickshaw.0 : rickshaw : ioBroker2025 - disabled system.adapter.roomba.0 : roomba : ioBroker2025 - disabled + system.adapter.simple-api.0 : simple-api : ioBroker2025 - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.sourceanalytix.0 : sourceanalytix : ioBroker2025 - enabled + system.adapter.tankerkoenig.0 : tankerkoenig : ioBroker2025 - enabled system.adapter.telegram-menu.0 : telegram-menu : ioBroker2025 - disabled + system.adapter.telegram.0 : telegram : ioBroker2025 - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : ioBroker2025 - enabled + system.adapter.tr-064.0 : tr-064 : ioBroker2025 - enabled + system.adapter.trashschedule.0 : trashschedule : ioBroker2025 - enabled + system.adapter.tuya.0 : tuya : ioBroker2025 - enabled system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: ioBroker2025 - disabled system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker2025 - disabled system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker2025 - disabled + system.adapter.vis-2.0 : vis-2 : ioBroker2025 - enabled system.adapter.vis-bars.0 : vis-bars : ioBroker2025 - disabled system.adapter.vis-history.0 : vis-history : ioBroker2025 - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : ioBroker2025 - disabled system.adapter.vis-inventwo.0 : vis-inventwo : ioBroker2025 - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : ioBroker2025 - disabled system.adapter.vis-justgage.0 : vis-justgage : ioBroker2025 - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : ioBroker2025 - disabled system.adapter.vis-metro.0 : vis-metro : ioBroker2025 - disabled system.adapter.vis-players.0 : vis-players : ioBroker2025 - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : ioBroker2025 - disabled system.adapter.vis.0 : vis : ioBroker2025 - enabled + system.adapter.volvo.0 : volvo : ioBroker2025 - enabled + system.adapter.web.0 : web : ioBroker2025 - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : ioBroker2025 - enabled, port: /dev/ttyACM0 + instance is alive Enabled adapters with bindings + system.adapter.admin.1 : admin : ioBroker2025 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.plenticore.0 : plenticore : ioBroker2025 - enabled, port: 80 + system.adapter.proxmox.0 : proxmox : ioBroker2025 - enabled, port: 8006 + system.adapter.simple-api.0 : simple-api : ioBroker2025 - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.telegram.0 : telegram : ioBroker2025 - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : ioBroker2025 - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : ioBroker2025 - enabled, port: /dev/ttyACM0 ioBroker-Repositories ┌─────────┬────────────────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼────────────────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'Beta (latest)' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴────────────────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): Stable (default) Upgrade policy: none Installed ioBroker-Adapters Used repository: Stable (default) Adapter "admin" : 7.8.23 , installed 7.8.23 Adapter "alexa2" : 3.27.4 , installed 3.27.4 Adapter "alias-manager": 2.1.0 , installed 2.1.0 Adapter "backitup" : 3.3.14 , installed 3.3.14 Adapter "bring" : 1.8.4 , installed 1.8.4 Adapter "cloud" : 6.0.1 , installed 6.0.1 Adapter "daswetter" : 4.5.3 , installed 4.5.3 Adapter "device-reminder": 3.1.2 , installed 3.1.2 Adapter "device-watcher": 2.15.5 , installed 2.15.5 Adapter "devices" : 1.2.14 , installed 1.2.14 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 3.1.0 , installed 3.1.0 Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2 Adapter "govee-local" : 0.4.5 , installed 0.4.5 Adapter "history" : 4.0.0 , installed 4.0.0 Adapter "hmip" : 1.27.0 , installed 1.27.0 Adapter "ical" : 1.20.0 , installed 1.20.0 Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "iot" : 5.0.12 , installed 5.0.12 Adapter "javascript" : 9.0.18 , installed 9.0.18 Controller "js-controller": 7.0.7 , installed 7.0.7 Adapter "plenticore" : 2.2.0 , installed 2.2.0 Adapter "pollenflug" : 2.0.0 , installed 2.0.0 Adapter "proxmox" : 2.4.10 , installed 2.4.10 Adapter "rickshaw" : 1.0.0 , installed 1.0.0 Adapter "roomba" : 1.3.0 , installed 1.3.0 Adapter "simple-api" : 3.0.7 , installed 3.0.7 Adapter "socketio" : 7.1.3 , installed 7.1.3 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 4.1.0 , installed 4.1.0 Adapter "telegram-menu": 3.2.3 , installed 3.2.3 Adapter "text2command" : 4.0.0 , installed 4.0.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "trashschedule": 5.3.0 , installed 5.3.0 Adapter "tuya" : 3.17.0 , installed 3.17.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.13.8 , installed 2.13.8 Adapter "vis-2-widgets-collection": 1.8.1, installed 1.8.1 Adapter "vis-2-widgets-inventwo": 1.0.0, installed 1.0.0 Adapter "vis-2-widgets-material": 1.6.1, installed 1.4.10 [Updatable] Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-history" : 1.0.0 , installed 1.0.0 Adapter "vis-hqwidgets": 1.6.1 , installed 1.6.1 Adapter "vis-inventwo" : 4.1.0 , installed 4.1.0 Adapter "vis-jqui-mfd" : 1.1.3 , installed 1.1.3 Adapter "vis-justgage" : 2.1.7 , installed 2.1.7 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-players" : 0.1.6 , installed 0.1.6 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "volvo" : 3.0.0 , installed 3.0.0 Adapter "web" : 8.0.0 , installed 8.0.0 Adapter "ws" : 4.0.0 , installed 4.0.0 Adapter "zigbee" : 3.3.5 , installed 1.10.14 [Updatable] Objects and States Please stand by - This may take a while Objects: 22695 States: 166393 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian trixie InRelease Hit:2 http://deb.debian.org/debian trixie-updates InRelease Hit:3 http://security.debian.org/debian-security trixie-security InRelease Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease Reading package lists... Pending systemupdates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 8294 670/iobroker.js-con tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 7394 670/iobroker.js-con tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 7366 683/sshd: /usr/sbin tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 1225 1/init tcp6 0 0 :::22 :::* LISTEN 0 7376 683/sshd: /usr/sbin tcp6 0 0 :::111 :::* LISTEN 0 4413 1/init tcp6 0 0 :::8087 :::* LISTEN 1001 9012 1414/io.simple-api. tcp6 0 0 :::8081 :::* LISTEN 1001 6821 788/io.admin.1 tcp6 0 0 :::8082 :::* LISTEN 1001 10771 1576/io.web.0 udp 0 0 0.0.0.0:4002 0.0.0.0:* 1001 5957 1039/io.govee-local udp 0 0 192.168.178.120:68 0.0.0.0:* 0 7440 823/dhcpcd: [BOOTP udp 0 0 0.0.0.0:111 0.0.0.0:* 0 1226 1/init udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 8790 1169/io.tuya.0 udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 8791 1169/io.tuya.0 udp6 0 0 :::111 :::* 0 507 1/init udp6 0 0 fda5:d281:2402:0:f6:546 :::* 0 7430 783/dhcpcd: [DHCP6 udp6 0 0 2a01:41e1:1e84:3900:546 :::* 0 6675 756/dhcpcd: [DHCP6 udp6 0 0 fe80::82fa:60d3:250:546 :::* 0 7392 717/dhcpcd: [DHCP6 *** Log File - Last 25 Lines *** 2026-06-02 23:30:42.158 - info: host.ioBroker2025 instance system.adapter.dwd.0 having pid 1614 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2026-06-02 23:30:50.043 - info: plenticore.0 (1398) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number" 2026-06-02 23:30:51.237 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 0(Dennis/02:F5:06:2A:7F:85) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:30:51.420 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 1(Maxi/F6:05:B8:6D:03:F6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:30:51.558 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 2(Julian/2A:21:9C:AC:90:E6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:30:51.764 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 3(Sandra/A6:40:4D:FF:65:B9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:31:02.636 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 0(Dennis/02:F5:06:2A:7F:85) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:31:02.806 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 1(Maxi/F6:05:B8:6D:03:F6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:31:02.965 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 2(Julian/2A:21:9C:AC:90:E6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:31:03.080 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 3(Sandra/A6:40:4D:FF:65:B9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:31:10.918 - info: plenticore.0 (1398) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number" 2026-06-02 23:31:13.801 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 0(Dennis/02:F5:06:2A:7F:85) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:31:13.984 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 1(Maxi/F6:05:B8:6D:03:F6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:31:14.152 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 2(Julian/2A:21:9C:AC:90:E6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:31:14.314 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 3(Sandra/A6:40:4D:FF:65:B9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:31:22.839 - info: hmip.0 (1055) Value unchanged, do not send this value 2026-06-02 23:31:25.177 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 0(Dennis/02:F5:06:2A:7F:85) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:31:25.397 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 1(Maxi/F6:05:B8:6D:03:F6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:31:25.566 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 2(Julian/2A:21:9C:AC:90:E6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:31:25.681 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 3(Sandra/A6:40:4D:FF:65:B9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:31:32.884 - info: plenticore.0 (1398) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number" 2026-06-02 23:31:36.594 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 0(Dennis/02:F5:06:2A:7F:85) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:31:36.717 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 1(Maxi/F6:05:B8:6D:03:F6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:31:36.832 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 2(Julian/2A:21:9C:AC:90:E6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500} 2026-06-02 23:31:36.943 - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 3(Sandra/A6:40:4D:FF:65:B9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}============ Mark until here for C&P =============
Wo finde ich jetzt den Browser Log bzw. was ist da jetzt relevant?
Hast du F12 gedrückt?
Dort im tab consoleHast du neu gestartet?
Geht der Material Adapter überhaupt mit vis2?
Die beiden Fehler bei Github habe ich auch gefunden gehabt. Daher hatte ich ja den Adapter Vis 2 Widgets Material wieder auf die Version 1.4.10 runtergezogen, da diese Version ja noch funktionieren soll.
Neustart ist erfolgt.
Hier der Inhalt der Konsole in Microsoft Edge.
index-BqKFant6.js:29062 iobroker.vis-2@2.13.19 index-B3-udR3a.js:8088 ██╗ ██████╗ ██████╗ ██████╗ ██████╗ ██╗ ██╗███████╗██████╗ ██║██╔═══██╗██╔══██╗██╔══██╗██╔═══██╗██║ ██╔╝██╔════╝██╔══██╗ ██║██║ ██║██████╔╝██████╔╝██║ ██║█████╔╝ █████╗ ██████╔╝ ██║██║ ██║██╔══██╗██╔══██╗██║ ██║██╔═██╗ ██╔══╝ ██╔══██╗ ██║╚██████╔╝██████╔╝██║ ██║╚██████╔╝██║ ██╗███████╗██║ ██║ ╚═╝ ╚═════╝ ╚═════╝ ╚═╝ ╚═╝ ╚═════╝ ╚═╝ ╚═╝╚══════╝╚═╝ ╚═╝ index-B3-udR3a.js:8095 Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters index-B3-udR3a.js:8095 Help us to create open source project with reactJS! index-B3-udR3a.js:8095 See you :) socket.io.js:3 WebSocket connection to 'wss://iobroker.pro/socket.io/?ws=true&EIO=3&transport=websocket&sid=FlHcdbPacSnyYg8mArxw' failed: n.doOpen @ socket.io.js:3 blob:https://iobroker.pro/8e68940d-65c3-4b4a-8390-2a4732b474ac:1 Manifest: property 'start_url' ignored, URL is invalid. blob:https://iobroker.pro/8e68940d-65c3-4b4a-8390-2a4732b474ac:1 Manifest: property 'src' ignored, URL is invalid. index-BqKFant6.js:27869 Skip script "bars" widgets/bars/js/bars.js index-BqKFant6.js:27869 Skip script "bars" widgets/bars/js/jquery.sidebar.js index-BqKFant6.js:27869 Skip script "bars" inline index-BqKFant6.js:27869 Skip script "bars" inline index-BqKFant6.js:27869 Skip script "bring" widgets/bring/js/textFit.min.js index-BqKFant6.js:27869 Skip script "bring" inline index-BqKFant6.js:27869 Skip script "bring" inline index-BqKFant6.js:27869 Skip script "dwd" inline index-BqKFant6.js:27869 Skip script "dwd" inline index-BqKFant6.js:27869 Skip script "dwd" inline index-BqKFant6.js:27869 Skip script "history" widgets/history/lib/js/jquery.sparkline.min.js index-BqKFant6.js:27869 Skip script "history" inline index-BqKFant6.js:27869 Skip script "history" inline index-BqKFant6.js:27869 Skip script "history" inline index-BqKFant6.js:27869 Skip script "hqwidgets" widgets/hqwidgets/js/jquery.knob.js index-BqKFant6.js:27869 Skip script "hqwidgets" widgets/hqwidgets/js/odometer.min.js index-BqKFant6.js:27869 Skip script "hqwidgets" widgets/hqwidgets/js/hqwidgets.js index-BqKFant6.js:27869 Skip script "hqwidgets" widgets/hqwidgets/js/hqButton.js index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "jqplot" widgets/jqplot/js/jquery.jqplot.min.js index-BqKFant6.js:27869 Skip script "jqplot" inline index-BqKFant6.js:27869 Skip script "jqplot" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui" lib/js/jquery-ui-timepicker-addon-1.6.3.js index-BqKFant6.js:27869 Skip script "jqui" inline index-BqKFant6.js:27869 Skip script "justgage" widgets/justgage/js/justgage.js index-BqKFant6.js:27869 Skip script "justgage" inline index-BqKFant6.js:27869 Skip script "justgage" inline index-BqKFant6.js:27869 Skip script "justgage" inline index-BqKFant6.js:27869 Skip script "justgage" inline index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/lib/raw/moment-with-locales.min.js index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/lib/raw/round-slider.js index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/lib.min.js index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/lib/raw/sentry/bundle.min.js index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/lib/raw/sentry/captureconsole.min.js index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/lib/raw/sentry/dedupe.min.js index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/js/materialdesign.js index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/js/widgets.min.js index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "metro" widgets/metro/js/metro.js index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "players" widgets/players/js/players.js index-BqKFant6.js:27869 Skip script "players" inline index-BqKFant6.js:27869 Skip script "players" inline index-BqKFant6.js:27869 Skip script "players" inline index-BqKFant6.js:27869 Skip script "players" inline index-BqKFant6.js:27869 Skip script "swipe" inline index-BqKFant6.js:27869 Skip script "swipe" inline index-BqKFant6.js:27869 Skip script "swipe" inline index-BqKFant6.js:27869 Skip script "tabs" inline index-BqKFant6.js:27869 Skip script "timeandweather" widgets/timeandweather/js/flipclock/flipclock.min.js index-BqKFant6.js:27869 Skip script "timeandweather" widgets/timeandweather/js/jquery.jdigiclock.js index-BqKFant6.js:27869 Skip script "timeandweather" widgets/timeandweather/js/jquery.zweatherfeed.js index-BqKFant6.js:27869 Skip script "timeandweather" widgets/timeandweather/js/coolclock.js index-BqKFant6.js:27869 Skip script "timeandweather" widgets/timeandweather/js/moreskins.js index-BqKFant6.js:27869 Skip script "timeandweather" widgets/timeandweather/js/segment-display.js index-BqKFant6.js:27869 Skip script "timeandweather" inline index-BqKFant6.js:27869 Skip script "timeandweather" inline index-BqKFant6.js:27869 Skip script "timeandweather" inline index-BqKFant6.js:27869 Skip script "timeandweather" inline index-BqKFant6.js:27869 Skip script "timeandweather" inline index-BqKFant6.js:27869 Skip script "timeandweather" inline index-BqKFant6.js:27869 Skip script "timeandweather" inline index-BqKFant6.js:27869 Skip script "timeandweather" inline index-BqKFant6.js:27869 Skip script "timeandweather" inline index-BqKFant6.js:27869 Skip script "trashschedule" widgets/trashschedule/js/trashschedule.js index-BqKFant6.js:27869 Skip script "trashschedule" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" widgets/vis-inventwo/js/iro.min.js index-BqKFant6.js:27869 Skip script "vis-inventwo" widgets/vis-inventwo/js/vis-inventwo.js index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline customWidgets.js:2 Uncaught SyntaxError: Cannot use import statement outside a module index-BqKFant6.js:7423 Cannot load i18n "echarts": Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "echarts", "entry": "https://iobroker.pro/vis-2/widgets/echarts/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "echarts" } index-BqKFant6.js:7359 Cannot load widget system.adapter.echarts.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "echarts", "entry": "https://iobroker.pro/vis-2/widgets/echarts/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "echarts" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 0) at async Promise.all (/vis-2/index 0) (anonymous) @ index-BqKFant6.js:7359 customWidgets.js:1 Uncaught SyntaxError: Cannot use import statement outside a module Cannot load i18n "vis2materialWidgets": Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__…C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__…-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__…C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__…C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__…C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 0) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 1) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 2) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 3) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 4) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 5) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 6) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 7) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 8) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 9) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 10) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 11) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 12) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 13) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 14) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 15) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 16) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 17) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-B3-udR3a.js:8970 Translate: jqui_widgetTitle index-B3-udR3a.js:8970 Translate: jqui_Write state index-B3-udR3a.js:8970 Translate: jqui_Close index-B3-udR3a.js:8970 Translate: jqui_input index-B3-udR3a.js:8970 Translate: jqui_off index-B3-udR3a.js:8970 Translate: jqui_on index-B3-udR3a.js:8970 Translate: Value index-BqKFant6.js:25856 Ignored bars/tplBarFilter because not used in project index-BqKFant6.js:25856 Ignored bars/tplBarNavigator because not used in project index-BqKFant6.js:25856 Ignored bring/tplBringShoppingList because not used in project index-BqKFant6.js:25856 Ignored dwd/tplDwdAdapterSmall because not used in project index-BqKFant6.js:25856 Ignored dwd/tplDwdAdapter because not used in project index-BqKFant6.js:25856 Ignored history/tplHistoryEventList because not used in project index-BqKFant6.js:25856 Ignored history/tplHistorySparkLIne because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqButton because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqDimmer because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqInTemp because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqOutTemp because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqShutter because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqDoor because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqLock because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqCheckbox because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqCircle because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqOdometer because not used in project index-BqKFant6.js:25856 Ignored jqplot/tplJqplotGauge because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdLight because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdLightCtrl because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdLightOnOffDialog because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdLightDialog because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdSocket because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdSocketCtrl because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdShutter because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdShutterDialog because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdBlind because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdBlindDialog because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdHeating because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdWindow because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdWindowBool because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdRoofWindowBool because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdDoor because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdGarage because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdValve because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdValveDialog because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdCustom10 because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdCustom10Dialog because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdCamSnapshot because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplValMfdCamSnapshot because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdCamMjpg because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplValMfdCamMjpg because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdCamVideo because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplValMfdCamVideo because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdCamVideoObject because not used in project index-BqKFant6.js:25856 Ignored justgage/tplJustgageJustGage because not used in project index-BqKFant6.js:25856 Ignored justgage/tplJustgageValueColored because not used in project index-BqKFant6.js:25856 Ignored justgage/tplJustgageIndicatorColored because not used in project index-BqKFant6.js:25856 Ignored justgage/tplJustgageValueIndicatorColored because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-value because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Navigation-vertical because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Link-vertical because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-State-vertical because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-State-Multi-vertical because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Adition-vertical because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Toggle-vertical because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Navigation because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Link because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-State because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-State-Multi because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Adition because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Toggle because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-Button-Navigation because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-Button-Link because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-Button-State because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-Button-State-Multi because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-Button-Adition because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-Button-Toggle because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Input because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Autocomplete because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Select because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Switch because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-CheckBox because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Vuetify-Slider because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Slider-Round because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Progress because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Progress-Circular because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Card because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-TopAppBar-Navigation because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-List because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-List because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Chart-Bar because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Chart-Line-History because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Chart-JSON because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Chart-Pie because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-ColorScheme-Preview because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Vuetify-Dialog-View because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Vuetify-Dialog-iFrame because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Table because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Masonry-Views because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Grid-Views because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Alerts because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Calendar because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Installed-Version because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroSlider because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroSliderVertical because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroValueBoolCheckbox because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroValueBoolSwitch because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileNav because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileString because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileBool because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileBoolDialog because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileList8 because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileBoolNumber because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileState because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileToggle because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileStateNumber because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileDimmer because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileDimmerDialog because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileShutter because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileShutterDialog because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileHeating because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileHeatingDialog because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileDialogStatic because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileStaticDialogNumber because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileDialogString because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileStringDialogNumber because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileDialog because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileDialogNumber because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileFrameDialogNumber because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileToggleNumber because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileDimmerDialogactiv because not used in project index-BqKFant6.js:25856 Ignored players/tplWinampPlayer because not used in project index-BqKFant6.js:25856 Ignored players/tplWinampPlaylist because not used in project index-BqKFant6.js:25856 Ignored players/tplWinampBrowser because not used in project index-BqKFant6.js:25856 Ignored players/tplSonosMobilePlayer because not used in project index-BqKFant6.js:25856 Ignored swipe/tplCarousel because not used in project index-BqKFant6.js:25856 Ignored timeandweather/tplTwSimpleDate because not used in project index-BqKFant6.js:25856 Ignored timeandweather/tplTwSimpleClock because not used in project index-BqKFant6.js:25856 Ignored timeandweather/tplTwCoolClock because not used in project index-BqKFant6.js:25856 Ignored timeandweather/tplTwFlipClock because not used in project index-BqKFant6.js:25856 Ignored timeandweather/tplTwHtcWeather because not used in project index-BqKFant6.js:25856 Ignored timeandweather/tplTwWeather because not used in project index-BqKFant6.js:25856 Ignored timeandweather/tplSvgClock because not used in project index-BqKFant6.js:25856 Ignored timeandweather/tplSegmentClock because not used in project Ignored trashschedule/tplTrashscheduleHelper because not used in project Ignored vis-inventwo/i-vis-universal because not used in project Ignored vis-inventwo/i-vis-multi because not used in project Ignored vis-inventwo/i-vis-slider-simple because not used in project Ignored vis-inventwo/i-vis-slider-simple-2 because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-slider-color-hor because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-slider-color-vert because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-color-picker because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-image-new because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-jsontable because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-radiobutton-list because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-valuelist because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-marquee because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-switch-1 because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-switch-basic because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-checkbox because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-switch because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-switch-small because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-button because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-button-small because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-navigation because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-navigation-small because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-background because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-background-small because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-image because not used in project index-CKUrMIxx.js:395 Error: <svg> attribute width: Expected length, "auto". zu @ index-CKUrMIxx.js:395 -
index-BqKFant6.js:29062 iobroker.vis-2@2.13.19 index-B3-udR3a.js:8088 ██╗ ██████╗ ██████╗ ██████╗ ██████╗ ██╗ ██╗███████╗██████╗ ██║██╔═══██╗██╔══██╗██╔══██╗██╔═══██╗██║ ██╔╝██╔════╝██╔══██╗ ██║██║ ██║██████╔╝██████╔╝██║ ██║█████╔╝ █████╗ ██████╔╝ ██║██║ ██║██╔══██╗██╔══██╗██║ ██║██╔═██╗ ██╔══╝ ██╔══██╗ ██║╚██████╔╝██████╔╝██║ ██║╚██████╔╝██║ ██╗███████╗██║ ██║ ╚═╝ ╚═════╝ ╚═════╝ ╚═╝ ╚═╝ ╚═════╝ ╚═╝ ╚═╝╚══════╝╚═╝ ╚═╝ index-B3-udR3a.js:8095 Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters index-B3-udR3a.js:8095 Help us to create open source project with reactJS! index-B3-udR3a.js:8095 See you :) socket.io.js:3 WebSocket connection to 'wss://iobroker.pro/socket.io/?ws=true&EIO=3&transport=websocket&sid=FlHcdbPacSnyYg8mArxw' failed: n.doOpen @ socket.io.js:3 blob:https://iobroker.pro/8e68940d-65c3-4b4a-8390-2a4732b474ac:1 Manifest: property 'start_url' ignored, URL is invalid. blob:https://iobroker.pro/8e68940d-65c3-4b4a-8390-2a4732b474ac:1 Manifest: property 'src' ignored, URL is invalid. index-BqKFant6.js:27869 Skip script "bars" widgets/bars/js/bars.js index-BqKFant6.js:27869 Skip script "bars" widgets/bars/js/jquery.sidebar.js index-BqKFant6.js:27869 Skip script "bars" inline index-BqKFant6.js:27869 Skip script "bars" inline index-BqKFant6.js:27869 Skip script "bring" widgets/bring/js/textFit.min.js index-BqKFant6.js:27869 Skip script "bring" inline index-BqKFant6.js:27869 Skip script "bring" inline index-BqKFant6.js:27869 Skip script "dwd" inline index-BqKFant6.js:27869 Skip script "dwd" inline index-BqKFant6.js:27869 Skip script "dwd" inline index-BqKFant6.js:27869 Skip script "history" widgets/history/lib/js/jquery.sparkline.min.js index-BqKFant6.js:27869 Skip script "history" inline index-BqKFant6.js:27869 Skip script "history" inline index-BqKFant6.js:27869 Skip script "history" inline index-BqKFant6.js:27869 Skip script "hqwidgets" widgets/hqwidgets/js/jquery.knob.js index-BqKFant6.js:27869 Skip script "hqwidgets" widgets/hqwidgets/js/odometer.min.js index-BqKFant6.js:27869 Skip script "hqwidgets" widgets/hqwidgets/js/hqwidgets.js index-BqKFant6.js:27869 Skip script "hqwidgets" widgets/hqwidgets/js/hqButton.js index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "hqwidgets" inline index-BqKFant6.js:27869 Skip script "jqplot" widgets/jqplot/js/jquery.jqplot.min.js index-BqKFant6.js:27869 Skip script "jqplot" inline index-BqKFant6.js:27869 Skip script "jqplot" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui-mfd" inline index-BqKFant6.js:27869 Skip script "jqui" lib/js/jquery-ui-timepicker-addon-1.6.3.js index-BqKFant6.js:27869 Skip script "jqui" inline index-BqKFant6.js:27869 Skip script "justgage" widgets/justgage/js/justgage.js index-BqKFant6.js:27869 Skip script "justgage" inline index-BqKFant6.js:27869 Skip script "justgage" inline index-BqKFant6.js:27869 Skip script "justgage" inline index-BqKFant6.js:27869 Skip script "justgage" inline index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/lib/raw/moment-with-locales.min.js index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/lib/raw/round-slider.js index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/lib.min.js index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/lib/raw/sentry/bundle.min.js index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/lib/raw/sentry/captureconsole.min.js index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/lib/raw/sentry/dedupe.min.js index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/js/materialdesign.js index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/js/widgets.min.js index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "materialdesign" inline index-BqKFant6.js:27869 Skip script "metro" widgets/metro/js/metro.js index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "metro" inline index-BqKFant6.js:27869 Skip script "players" widgets/players/js/players.js index-BqKFant6.js:27869 Skip script "players" inline index-BqKFant6.js:27869 Skip script "players" inline index-BqKFant6.js:27869 Skip script "players" inline index-BqKFant6.js:27869 Skip script "players" inline index-BqKFant6.js:27869 Skip script "swipe" inline index-BqKFant6.js:27869 Skip script "swipe" inline index-BqKFant6.js:27869 Skip script "swipe" inline index-BqKFant6.js:27869 Skip script "tabs" inline index-BqKFant6.js:27869 Skip script "timeandweather" widgets/timeandweather/js/flipclock/flipclock.min.js index-BqKFant6.js:27869 Skip script "timeandweather" widgets/timeandweather/js/jquery.jdigiclock.js index-BqKFant6.js:27869 Skip script "timeandweather" widgets/timeandweather/js/jquery.zweatherfeed.js index-BqKFant6.js:27869 Skip script "timeandweather" widgets/timeandweather/js/coolclock.js index-BqKFant6.js:27869 Skip script "timeandweather" widgets/timeandweather/js/moreskins.js index-BqKFant6.js:27869 Skip script "timeandweather" widgets/timeandweather/js/segment-display.js index-BqKFant6.js:27869 Skip script "timeandweather" inline index-BqKFant6.js:27869 Skip script "timeandweather" inline index-BqKFant6.js:27869 Skip script "timeandweather" inline index-BqKFant6.js:27869 Skip script "timeandweather" inline index-BqKFant6.js:27869 Skip script "timeandweather" inline index-BqKFant6.js:27869 Skip script "timeandweather" inline index-BqKFant6.js:27869 Skip script "timeandweather" inline index-BqKFant6.js:27869 Skip script "timeandweather" inline index-BqKFant6.js:27869 Skip script "timeandweather" inline index-BqKFant6.js:27869 Skip script "trashschedule" widgets/trashschedule/js/trashschedule.js index-BqKFant6.js:27869 Skip script "trashschedule" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" widgets/vis-inventwo/js/iro.min.js index-BqKFant6.js:27869 Skip script "vis-inventwo" widgets/vis-inventwo/js/vis-inventwo.js index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline index-BqKFant6.js:27869 Skip script "vis-inventwo" inline customWidgets.js:2 Uncaught SyntaxError: Cannot use import statement outside a module index-BqKFant6.js:7423 Cannot load i18n "echarts": Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "echarts", "entry": "https://iobroker.pro/vis-2/widgets/echarts/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "echarts" } index-BqKFant6.js:7359 Cannot load widget system.adapter.echarts.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "echarts", "entry": "https://iobroker.pro/vis-2/widgets/echarts/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "echarts" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 0) at async Promise.all (/vis-2/index 0) (anonymous) @ index-BqKFant6.js:7359 customWidgets.js:1 Uncaught SyntaxError: Cannot use import statement outside a module Cannot load i18n "vis2materialWidgets": Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__…C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__…-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__…C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__…C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__…C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 0) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 1) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 2) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 3) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 4) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 5) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 6) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 7) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 8) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 9) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 10) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 11) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 12) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 13) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 14) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 15) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 16) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined { "name": "vis2materialWidgets", "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js", "type": "global", "shareScope": "default", "entryGlobalName": "vis2materialWidgets" } at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123) at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10) at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14) at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14) at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92) at async Promise.all (/vis-2/index 17) at async Promise.all (/vis-2/index 3) (anonymous) @ index-BqKFant6.js:7359 index-B3-udR3a.js:8970 Translate: jqui_widgetTitle index-B3-udR3a.js:8970 Translate: jqui_Write state index-B3-udR3a.js:8970 Translate: jqui_Close index-B3-udR3a.js:8970 Translate: jqui_input index-B3-udR3a.js:8970 Translate: jqui_off index-B3-udR3a.js:8970 Translate: jqui_on index-B3-udR3a.js:8970 Translate: Value index-BqKFant6.js:25856 Ignored bars/tplBarFilter because not used in project index-BqKFant6.js:25856 Ignored bars/tplBarNavigator because not used in project index-BqKFant6.js:25856 Ignored bring/tplBringShoppingList because not used in project index-BqKFant6.js:25856 Ignored dwd/tplDwdAdapterSmall because not used in project index-BqKFant6.js:25856 Ignored dwd/tplDwdAdapter because not used in project index-BqKFant6.js:25856 Ignored history/tplHistoryEventList because not used in project index-BqKFant6.js:25856 Ignored history/tplHistorySparkLIne because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqButton because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqDimmer because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqInTemp because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqOutTemp because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqShutter because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqDoor because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqLock because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqCheckbox because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqCircle because not used in project index-BqKFant6.js:25856 Ignored hqwidgets/tplHqOdometer because not used in project index-BqKFant6.js:25856 Ignored jqplot/tplJqplotGauge because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdLight because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdLightCtrl because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdLightOnOffDialog because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdLightDialog because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdSocket because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdSocketCtrl because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdShutter because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdShutterDialog because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdBlind because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdBlindDialog because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdHeating because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdWindow because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdWindowBool because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdRoofWindowBool because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdDoor because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdGarage because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdValve because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdValveDialog because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdCustom10 because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdCustom10Dialog because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdCamSnapshot because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplValMfdCamSnapshot because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdCamMjpg because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplValMfdCamMjpg because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdCamVideo because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplValMfdCamVideo because not used in project index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdCamVideoObject because not used in project index-BqKFant6.js:25856 Ignored justgage/tplJustgageJustGage because not used in project index-BqKFant6.js:25856 Ignored justgage/tplJustgageValueColored because not used in project index-BqKFant6.js:25856 Ignored justgage/tplJustgageIndicatorColored because not used in project index-BqKFant6.js:25856 Ignored justgage/tplJustgageValueIndicatorColored because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-value because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Navigation-vertical because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Link-vertical because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-State-vertical because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-State-Multi-vertical because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Adition-vertical because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Toggle-vertical because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Navigation because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Link because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-State because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-State-Multi because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Adition because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Toggle because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-Button-Navigation because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-Button-Link because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-Button-State because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-Button-State-Multi because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-Button-Adition because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-Button-Toggle because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Input because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Autocomplete because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Select because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Switch because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-CheckBox because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Vuetify-Slider because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Slider-Round because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Progress because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Progress-Circular because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Card because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-TopAppBar-Navigation because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-List because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-List because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Chart-Bar because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Chart-Line-History because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Chart-JSON because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Chart-Pie because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-ColorScheme-Preview because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Vuetify-Dialog-View because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Vuetify-Dialog-iFrame because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Table because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Masonry-Views because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Grid-Views because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Alerts because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Calendar because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon because not used in project index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Installed-Version because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroSlider because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroSliderVertical because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroValueBoolCheckbox because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroValueBoolSwitch because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileNav because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileString because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileBool because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileBoolDialog because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileList8 because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileBoolNumber because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileState because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileToggle because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileStateNumber because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileDimmer because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileDimmerDialog because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileShutter because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileShutterDialog because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileHeating because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileHeatingDialog because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileDialogStatic because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileStaticDialogNumber because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileDialogString because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileStringDialogNumber because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileDialog because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileDialogNumber because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileFrameDialogNumber because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileToggleNumber because not used in project index-BqKFant6.js:25856 Ignored metro/tplMetroTileDimmerDialogactiv because not used in project index-BqKFant6.js:25856 Ignored players/tplWinampPlayer because not used in project index-BqKFant6.js:25856 Ignored players/tplWinampPlaylist because not used in project index-BqKFant6.js:25856 Ignored players/tplWinampBrowser because not used in project index-BqKFant6.js:25856 Ignored players/tplSonosMobilePlayer because not used in project index-BqKFant6.js:25856 Ignored swipe/tplCarousel because not used in project index-BqKFant6.js:25856 Ignored timeandweather/tplTwSimpleDate because not used in project index-BqKFant6.js:25856 Ignored timeandweather/tplTwSimpleClock because not used in project index-BqKFant6.js:25856 Ignored timeandweather/tplTwCoolClock because not used in project index-BqKFant6.js:25856 Ignored timeandweather/tplTwFlipClock because not used in project index-BqKFant6.js:25856 Ignored timeandweather/tplTwHtcWeather because not used in project index-BqKFant6.js:25856 Ignored timeandweather/tplTwWeather because not used in project index-BqKFant6.js:25856 Ignored timeandweather/tplSvgClock because not used in project index-BqKFant6.js:25856 Ignored timeandweather/tplSegmentClock because not used in project Ignored trashschedule/tplTrashscheduleHelper because not used in project Ignored vis-inventwo/i-vis-universal because not used in project Ignored vis-inventwo/i-vis-multi because not used in project Ignored vis-inventwo/i-vis-slider-simple because not used in project Ignored vis-inventwo/i-vis-slider-simple-2 because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-slider-color-hor because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-slider-color-vert because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-color-picker because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-image-new because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-jsontable because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-radiobutton-list because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-valuelist because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-marquee because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-switch-1 because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-switch-basic because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-checkbox because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-switch because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-switch-small because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-button because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-button-small because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-navigation because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-navigation-small because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-background because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-background-small because not used in project index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-image because not used in project index-CKUrMIxx.js:395 Error: <svg> attribute width: Expected length, "auto". zu @ index-CKUrMIxx.js:395Eckarts funktioniert auch nicht
Probiere mal den Material Adapter zu löschen und neu zu installieren
Echarts
