  4. Unb. Widget-Typ tplMaterial2Switches über iobroker.pro
    2.1k
14 Beiträge 3 Kommentatoren 64 Aufrufe 2 Beobachtet
  • D Online
    D Online
    DennisMenger
    schrieb am zuletzt editiert von DennisMenger
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: ioBroker2025
           Icon name: computer-vm
             Chassis: vm 🖴
        AF_VSOCK CID: 1
      Virtualization: kvm
              Kernel: Linux 6.12.74+deb13+1-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.17.0-0-gb52ca86e094d-prebuilt.qemu.org
       Firmware Date: Tue 2014-04-01
        Firmware Age: 12y 2month 2d
    OS is similar to:
    model name      : QEMU Virtual CPU version 2.5+
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     23:01:54 up  2:16,  2 users,  load average: 1.26, 1.10, 1.04
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Tue 2026-06-02 23:01:54 CEST
               Universal time: Tue 2026-06-02 21:01:54 UTC
                     RTC time: Tue 2026-06-02 21:01:54
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    dennis
    HOME=/home/dennis
    GROUPS=dennis adm dialout cdrom floppy sudo audio dip video plugdev users netdev iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/dennis
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            8.3G        3.6G        3.9G        3.7M        1.1G        4.7G
    Swap:           1.8G          0B        1.8G
    Total:           10G        3.6G        5.7G
    Active iob-Instances:   34
             7947 M total memory
             3448 M used memory
             3119 M active memory
              822 M inactive memory
             3678 M free memory
               92 M buffer memory
              997 M swap cache
             1721 M total swap
                0 M used swap
             1721 M free swap
    top - 23:01:54 up  2:16,  2 users,  load average: 1.26, 1.10, 1.04
    Tasks: 163 total,   2 running, 161 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 27.9 us,  0.0 sy,  0.0 ni, 72.1 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7947.3 total,   3678.7 free,   3448.4 used,   1089.7 buff/cache
    MiB Swap:   1722.0 total,   1722.0 free,      0.0 used.   4498.9 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     795M  580K  795M   1% /run
    /dev/sda1      ext4       30G  7.8G   21G  28% /
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     3.9G  3.0M  3.9G   1% /tmp
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     795M  8.0K  795M   1% /run/user/1000
    [Tue Jun  2 20:45:12 2026] EXT4-fs (sda1): orphan cleanup on readonly fs
    [Tue Jun  2 20:45:12 2026] EXT4-fs (sda1): mounted filesystem c05e89b3-8b22-491f-9297-88ed2de1a924 ro with ordered data mode. Quota mode: none.
    [Tue Jun  2 20:45:12 2026] EXT4-fs (sda1): re-mounted c05e89b3-8b22-491f-9297-88ed2de1a924 r/w.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    963M    /var/
    488M    /var/log
    474M    /var/log/journal/11a1848b6601495b9e5ed483f6069bbc
    286M    /var/cache
    Archived and active journals take up 473.3M in the file system.
    /opt/iobroker/backups:
    656M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.4G    /opt/iobroker/iobroker-data/
    575M    /opt/iobroker/iobroker-data/history
    548M    /opt/iobroker/iobroker-data/files
    153M    /opt/iobroker/iobroker-data/backup-objects
    109M    /opt/iobroker/iobroker-data/files/vis-2
    99M     /opt/iobroker/iobroker-data/states.jsonl
    37M     /opt/iobroker/iobroker-data/objects.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    23M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
    9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2196493-if00
    *** ZigBee Settings ***
    ⚠ HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'.
    Please check your setting:
    /dev/ttyACM0
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
            500 http://security.debian.org/debian-security trixie-security/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    The current Node.js version (v22.21.0) is vulnerable to the following CVEs:
    CVE-2025-55130(high): A flaw in Node.js’s Permissions model allows attackers to bypass `--allow-fs-read` and `--allow-fs-write` restrictions using crafted relative symlink paths. By chaining directories and symlinks, a script granted access only to the current directory can escape the allowed path and read sensitive files. This breaks the expected isolation guarantees and enables arbitrary file read/write, leading to potential system compromise.
    This vulnerability affects users of the permission model on Node.js v20,  v22,  v24, and v25.
    Patched versions: ^20.20.0 || ^22.22.0 || ^24.13.0 || ^25.3.0
    CVE-2025-55131(high): A flaw in Node.js's buffer allocation logic can expose uninitialized memory when allocations are interrupted, when using the `vm` module with the timeout option. Under specific timing conditions, buffers allocated with `Buffer.alloc` and other `TypedArray` instances like `Uint8Array` may contain leftover data from previous operations, allowing in-process secrets like tokens or passwords to leak or causing data corruption. While exploitation typically requires precise timing or in-process code execution, it can become remotely exploitable when untrusted input influences workload and timeouts, leading to potential confidentiality and integrity impact.
    CVE-2025-55132(low): A flaw in Node.js's permission model allows a file's access and modification timestamps to be changed via `futimes()` even when the process has only read permissions. Unlike `utimes()`, `futimes()` does not apply the expected write-permission checks, which means file metadata can be modified in read-only directories. This behavior could be used to alter timestamps in ways that obscure activity, reducing the reliability of logs. This vulnerability affects users of the permission model on Node.js v20,  v22,  v24, and v25.
    CVE-2025-59464(medium): A memory leak in Node.js’s OpenSSL integration occurs when converting `X.509` certificate fields to UTF-8 without freeing the allocated buffer. When applications call `socket.getPeerCertificate(true)`, each certificate field leaks memory, allowing remote clients to trigger steady memory growth through repeated TLS connections. Over time this can lead to resource exhaustion and denial of service.
    CVE-2025-59465(high): A malformed `HTTP/2 HEADERS` frame with oversized, invalid `HPACK` data can cause Node.js to crash by triggering an unhandled `TLSSocket` error `ECONNRESET`. Instead of safely closing the connection, the process crashes, enabling a remote denial of service. This primarily affects applications that do not attach explicit error handlers to secure sockets, for example:
    server.on('secureConnection', socket => {
    socket.on('error', err => {
    console.log(err)
    CVE-2025-59466(medium): We have identified a bug in Node.js error handling where "Maximum call stack size exceeded" errors become uncatchable when async_hooks.createHook() is enabled. Instead of reaching process.on('uncaughtException'), the process terminates, making the crash unrecoverable. Applications that rely on AsyncLocalStorage (v22, v20) or async_hooks.createHook() (v24, v22, v20) become vulnerable to denial-of-service crashes triggered by deep recursion under specific conditions.
    CVE-2026-21637(high): A flaw in Node.js TLS error handling leaves SNICallback invocations unprotected against synchronous exceptions, while the equivalent ALPN and PSK callbacks were already addressed in CVE-2026-21637. This represents an incomplete fix of that prior vulnerability.
    When an SNICallback throws synchronously on unexpected input the exception bypasses TLS error handlers and propagates as an uncaught exception, crashing the Node.js process.
    • This vulnerability affects all Node.js versions that received the CVE-2026-21637 fix, including 20.x, 22.x, 24.x, and 25.x, on any TLS server where SNICallback may throw on unexpected servername input.
      Patched versions: ^20.20.2 || ^22.22.2 || ^24.14.1 || ^25.8.2
    CVE-2026-21710(high): A flaw in Node.js HTTP request handling causes an uncaught TypeError when a request is received with a header named __proto__ and the application accesses req.headersDistinct.
    When this occurs, dest["__proto__"] resolves to Object.prototype rather than undefined, causing .push() to be called on a non-array. This exception is thrown synchronously inside a property getter and cannot be intercepted by error event listeners, meaning it cannot be handled without wrapping every req.headersDistinct access in a try/catch.
    • This vulnerability affects all Node.js HTTP servers on 20.x, 22.x, 24.x, and v25.x
    CVE-2026-21713(medium): A flaw in Node.js HMAC verification uses a non-constant-time comparison when validating user-provided signatures, potentially leaking timing information proportional to the number of matching bytes. Under certain threat models where high-resolution timing measurements are possible, this behavior could be exploited as a timing oracle to infer HMAC values.
    Node.js already provides timing-safe comparison primitives used elsewhere in the codebase, indicating this is an oversight rather than an intentional design decision.
    This vulnerability affects 20.x, 22.x, 24.x, and 25.x.
    CVE-2026-21714(medium): A memory leak occurs in Node.js HTTP/2 servers when a client sends WINDOW_UPDATE frames on stream 0 (connection-level) that cause the flow control window to exceed the maximum value of 2³¹-1. The server correctly sends a GOAWAY frame, but the Http2Session object is never cleaned up.
    This vulnerability affects HTTP2 users on Node.js 20, 22, 24 and 25.
    CVE-2026-21715(low): A flaw in Node.js Permission Model filesystem enforcement leaves fs.realpathSync.native() without the required read permission checks, while all comparable filesystem functions correctly enforce them.
    As a result, code running under --permission with restricted --allow-fs-read can still use fs.realpathSync.native() to check file existence, resolve symlink targets, and enumerate filesystem paths outside of permitted directories.
    This vulnerability affects 20.x, 22.x, 24.x, and 25.x processes using the Permission Model where --allow-fs-read is intentionally restricted.
    CVE-2026-21716(low): An incomplete fix for CVE-2024-36137 leaves FileHandle.chmod() and FileHandle.chown() in the promises API without the required permission checks, while their callback-based equivalents (fs.fchmod(), fs.fchown()) were correctly patched.
    As a result, code running under --permission with restricted --allow-fs-write can still use promise-based FileHandle methods to modify file permissions and ownership on already-open file descriptors, bypassing the intended write restrictions.
    This vulnerability affects 20.x, 22.x, 24.x, and 25.x processes using the Permission Model where --allow-fs-write is intentionally restricted.
    CVE-2026-21717(medium): A flaw in V8's string hashing mechanism causes integer-like strings to be hashed to their numeric value, making hash collisions trivially predictable. By crafting a request that causes many such collisions in V8's internal string table, an attacker can significantly degrade performance of the Node.js process.
    The most common trigger is any endpoint that calls JSON.parse() on attacker-controlled input, as JSON parsing automatically internalizes short strings into the affected hash table.
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States type: jsonl
    Hosts:
    ioBroker2025 ioBroker2025 (version: 7.0.7, hostname: ioBroker2025 , alive, uptime: 8198)
    Core adapters versions
    js-controller: 7.0.7
    admin: 7.8.23
    javascript: 9.0.18
    nodejs modules from github: 2
    +-- iobroker.labcom@0.1.1 (git+ssh://git@github.com/100prznt/ioBroker.labcom.git#b6dc2782e6748c0c1d677e1d0a5a4c1fe1e68127)
    +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
    Adapter State
    • system.adapter.admin.1 : admin : ioBroker2025 - enabled, port: 8081, bind: 0.0.0.0, run as: admin
    • system.adapter.alexa2.0 : alexa2 : ioBroker2025 - enabled
      system.adapter.alias-manager.0 : alias-manager : ioBroker2025 - disabled
    • system.adapter.backitup.0 : backitup : ioBroker2025 - enabled
    • system.adapter.bring.0 : bring : ioBroker2025 - enabled
    • system.adapter.cloud.0 : cloud : ioBroker2025 - enabled
    • system.adapter.daswetter.0 : daswetter : ioBroker2025 - enabled
    • system.adapter.device-reminder.0 : device-reminder : ioBroker2025 - enabled
    • system.adapter.device-watcher.0 : device-watcher : ioBroker2025 - enabled
      system.adapter.devices.0 : devices : ioBroker2025 - disabled
    • system.adapter.discovery.0 : discovery : ioBroker2025 - enabled
      system.adapter.dwd.0 : dwd : ioBroker2025 - enabled
    • system.adapter.echarts.0 : echarts : ioBroker2025 - enabled
    • system.adapter.fb-checkpresence.0 : fb-checkpresence : ioBroker2025 - enabled
      system.adapter.flot.0 : flot : ioBroker2025 - disabled
    • system.adapter.govee-app.0 : govee-app : ioBroker2025 - enabled
    • system.adapter.govee-local.0 : govee-local : ioBroker2025 - enabled
    • system.adapter.history.0 : history : ioBroker2025 - enabled
    • system.adapter.hmip.0 : hmip : ioBroker2025 - enabled
      system.adapter.ical.0 : ical : ioBroker2025 - enabled
      system.adapter.ical.1 : ical : ioBroker2025 - enabled
      system.adapter.ical.2 : ical : ioBroker2025 - enabled
      system.adapter.icons-mfd-png.0 : icons-mfd-png : ioBroker2025 - disabled
      system.adapter.icons-mfd-svg.0 : icons-mfd-svg : ioBroker2025 - disabled
    • system.adapter.iot.0 : iot : ioBroker2025 - enabled
    • system.adapter.javascript.0 : javascript : ioBroker2025 - enabled
      system.adapter.labcom.0 : labcom : ioBroker2025 - disabled
    • system.adapter.plenticore.0 : plenticore : ioBroker2025 - enabled, port: 80
    • system.adapter.pollenflug.0 : pollenflug : ioBroker2025 - enabled
    • system.adapter.poolcontrol.0 : poolcontrol : ioBroker2025 - enabled
    • system.adapter.proxmox.0 : proxmox : ioBroker2025 - enabled, port: 8006
      system.adapter.rickshaw.0 : rickshaw : ioBroker2025 - disabled
      system.adapter.roomba.0 : roomba : ioBroker2025 - disabled
    • system.adapter.simple-api.0 : simple-api : ioBroker2025 - enabled, port: 8087, bind: 0.0.0.0, run as: admin
    • system.adapter.sourceanalytix.0 : sourceanalytix : ioBroker2025 - enabled
    • system.adapter.tankerkoenig.0 : tankerkoenig : ioBroker2025 - enabled
      system.adapter.telegram-menu.0 : telegram-menu : ioBroker2025 - disabled
    • system.adapter.telegram.0 : telegram : ioBroker2025 - enabled, port: 8443, bind: 0.0.0.0
    • system.adapter.text2command.0 : text2command : ioBroker2025 - enabled
    • system.adapter.tr-064.0 : tr-064 : ioBroker2025 - enabled
    • system.adapter.trashschedule.0 : trashschedule : ioBroker2025 - enabled
    • system.adapter.tuya.0 : tuya : ioBroker2025 - enabled
      system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: ioBroker2025 - disabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker2025 - disabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker2025 - disabled
    • system.adapter.vis-2.0 : vis-2 : ioBroker2025 - enabled
      system.adapter.vis-bars.0 : vis-bars : ioBroker2025 - disabled
      system.adapter.vis-history.0 : vis-history : ioBroker2025 - disabled
      system.adapter.vis-hqwidgets.0 : vis-hqwidgets : ioBroker2025 - disabled
      system.adapter.vis-inventwo.0 : vis-inventwo : ioBroker2025 - enabled
      system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : ioBroker2025 - disabled
      system.adapter.vis-justgage.0 : vis-justgage : ioBroker2025 - disabled
      system.adapter.vis-materialdesign.0 : vis-materialdesign : ioBroker2025 - disabled
      system.adapter.vis-metro.0 : vis-metro : ioBroker2025 - disabled
      system.adapter.vis-players.0 : vis-players : ioBroker2025 - disabled
      system.adapter.vis-timeandweather.0 : vis-timeandweather : ioBroker2025 - disabled
      system.adapter.vis.0 : vis : ioBroker2025 - enabled
    • system.adapter.volvo.0 : volvo : ioBroker2025 - enabled
    • system.adapter.web.0 : web : ioBroker2025 - enabled, port: 8082, bind: 0.0.0.0, run as: admin
    • system.adapter.zigbee.0 : zigbee : ioBroker2025 - enabled, port: /dev/ttyACM0
    • instance is alive
    ioBroker-Repositories
    │ (index) │ name │ url │ auto upgrade │
    │ 0 │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json' │ false │
    │ 1 │ 'Beta (latest)' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │
    Upgrade policy: none
    Installed ioBroker-Adapters
    Adapter "admin" : 7.8.23 , installed 7.8.23
    Adapter "alexa2" : 3.27.4 , installed 3.27.4
    Adapter "alias-manager": 2.1.0 , installed 2.1.0
    Adapter "backitup" : 3.3.14 , installed 3.3.14
    Adapter "bring" : 1.8.4 , installed 1.8.4
    Adapter "cloud" : 6.0.1 , installed 6.0.1
    Adapter "daswetter" : 4.5.3 , installed 4.5.3
    Adapter "device-reminder": 3.1.2 , installed 3.1.2
    Adapter "device-watcher": 2.15.5 , installed 2.15.5
    Adapter "devices" : 1.2.14 , installed 1.2.14
    Adapter "discovery" : 5.0.0 , installed 5.0.0
    Adapter "dwd" : 2.8.5 , installed 2.8.5
    Adapter "echarts" : 3.1.0 , installed 3.1.0
    Adapter "fb-checkpresence": 1.4.2 , installed 1.4.2
    Adapter "govee-local" : 0.4.5 , installed 0.4.5
    Adapter "history" : 4.0.0 , installed 4.0.0
    Adapter "hmip" : 1.27.0 , installed 1.27.0
    Adapter "ical" : 1.20.0 , installed 1.20.0
    Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1
    Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0
    Adapter "iot" : 5.0.12 , installed 5.0.12
    Adapter "javascript" : 9.0.18 , installed 9.0.18
    Controller "js-controller": 7.0.7 , installed 7.0.7
    Adapter "plenticore" : 2.2.0 , installed 2.2.0
    Adapter "pollenflug" : 2.0.0 , installed 2.0.0
    Adapter "proxmox" : 2.4.10 , installed 2.4.10
    Adapter "rickshaw" : 1.0.0 , installed 1.0.0
    Adapter "roomba" : 1.3.0 , installed 1.3.0
    Adapter "simple-api" : 3.0.7 , installed 3.0.7
    Adapter "socketio" : 7.1.3 , installed 7.1.3
    Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0
    Adapter "telegram" : 4.1.0 , installed 4.1.0
    Adapter "telegram-menu": 3.2.3 , installed 3.2.3
    Adapter "text2command" : 4.0.0 , installed 4.0.0
    Adapter "tr-064" : 4.3.0 , installed 4.3.0
    Adapter "trashschedule": 5.3.0 , installed 5.3.0
    Adapter "tuya" : 3.17.0 , installed 3.17.0
    Adapter "vis" : 1.5.6 , installed 1.5.6
    Adapter "vis-2" : 2.13.8 , installed 2.13.8
    Adapter "vis-2-widgets-collection": 1.8.1, installed 1.8.1
    Adapter "vis-2-widgets-inventwo": 1.0.0, installed 1.0.0
    Adapter "vis-2-widgets-material": 1.6.1, installed 1.4.10 [Updatable]
    Adapter "vis-bars" : 0.1.4 , installed 0.1.4
    Adapter "vis-history" : 1.0.0 , installed 1.0.0
    Adapter "vis-hqwidgets": 1.6.1 , installed 1.6.1
    Adapter "vis-inventwo" : 4.1.0 , installed 4.1.0
    Adapter "vis-jqui-mfd" : 1.1.3 , installed 1.1.3
    Adapter "vis-justgage" : 2.1.7 , installed 2.1.7
    Adapter "vis-materialdesign": 0.5.9, installed 0.5.9
    Adapter "vis-metro" : 1.2.0 , installed 1.2.0
    Adapter "vis-players" : 0.1.6 , installed 0.1.6
    Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
    Adapter "volvo" : 3.0.0 , installed 3.0.0
    Adapter "web" : 8.0.0 , installed 8.0.0
    Adapter "ws" : 4.0.0 , installed 4.0.0
    Adapter "zigbee" : 3.3.5 , installed 1.10.14 [Updatable]
    Objects and States
    Objects: 22695
    States: 166357
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://deb.nodesource.com/node_22.x nodistro InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound: No binding signature at time 2026-04-30T12:36:57Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
    W: Failed to fetch https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound: No binding signature at time 2026-04-30T12:36:57Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://security.debian.org/debian-security trixie-security InRelease
    Get:4 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
    Err:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 108
    *** Listening Ports ***
    Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
    tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 7405 677/iobroker.js-con
    tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 6633 677/iobroker.js-con
    tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 4982 690/sshd: /usr/sbin
    tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 3718 1/init
    tcp6 0 0 :::22 :::* LISTEN 0 4984 690/sshd: /usr/sbin
    tcp6 0 0 :::111 :::* LISTEN 0 452 1/init
    tcp6 0 0 :::8087 :::* LISTEN 1001 11438 1701/io.simple-api.
    tcp6 0 0 :::8082 :::* LISTEN 1001 10187 1796/io.web.0
    tcp6 0 0 :::8081 :::* LISTEN 1001 9271 916/io.admin.1
    udp 0 0 0.0.0.0:4002 0.0.0.0:* 1001 8670 1222/io.govee-local
    udp 0 0 192.168.178.120:68 0.0.0.0:* 0 6065 811/dhcpcd: [BOOTP
    udp 0 0 0.0.0.0:111 0.0.0.0:* 0 3719 1/init
    udp 0 0 0.0.0.0:6666 0.0.0.0:* 1001 10255 1378/io.tuya.0
    udp 0 0 0.0.0.0:6667 0.0.0.0:* 1001 10256 1378/io.tuya.0
    udp6 0 0 :::111 :::* 0 4372 1/init
    udp6 0 0 fda5:d281:2402:0:f6:546 :::* 0 6051 776/dhcpcd: [DHCP6
    udp6 0 0 2a01:41e1:1e84:3900:546 :::* 0 6011 756/dhcpcd: [DHCP6
    udp6 0 0 fe80::82fa:60d3:250:546 :::* 0 5008 713/dhcpcd: [DHCP6
    2026-06-02 23:01:31.249 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 3(Sandra/A6:40:4D:FF:65:B9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:01:38.397 - info: plenticore.0 (1680) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
    2026-06-02 23:01:42.176 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 0(Dennis/02:F5:06:2A:7F:85) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:01:42.362 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 1(Maxi/F6:05:B8:6D:03:F6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:01:42.546 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 2(Julian/2A:21:9C:AC:90:E6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:01:42.726 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 3(Sandra/A6:40:4D:FF:65:B9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:01:53.662 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 0(Dennis/02:F5:06:2A:7F:85) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:01:53.862 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 1(Maxi/F6:05:B8:6D:03:F6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:01:54.046 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 2(Julian/2A:21:9C:AC:90:E6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:01:54.205 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 3(Sandra/A6:40:4D:FF:65:B9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:01:59.385 - info: plenticore.0 (1680) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
    2026-06-02 23:02:05.176 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 0(Dennis/02:F5:06:2A:7F:85) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:02:05.393 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 1(Maxi/F6:05:B8:6D:03:F6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:02:05.579 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 2(Julian/2A:21:9C:AC:90:E6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:02:05.712 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 3(Sandra/A6:40:4D:FF:65:B9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:02:16.325 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 0(Dennis/02:F5:06:2A:7F:85) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:02:16.693 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 1(Maxi/F6:05:B8:6D:03:F6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:02:16.896 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 2(Julian/2A:21:9C:AC:90:E6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:02:17.084 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 3(Sandra/A6:40:4D:FF:65:B9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:02:20.391 - info: plenticore.0 (1680) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
    2026-06-02 23:02:27.758 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 0(Dennis/02:F5:06:2A:7F:85) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:02:27.960 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 1(Maxi/F6:05:B8:6D:03:F6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:02:28.232 - info: hmip.0 (1011) Value unchanged, do not send this value
    2026-06-02 23:02:28.256 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 2(Julian/2A:21:9C:AC:90:E6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    2026-06-02 23:02:28.616 - info: tr-064.0 (1348) forEachConfiguredDevice: in GetSpecificHostEntry 3(Sandra/A6:40:4D:FF:65:B9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
    • D DennisMenger
      Script v.2026-01-31
      *** BASE SYSTEM ***
               Chassis: vm 🖴
          AF_VSOCK CID: 1
        Virtualization: kvm
      OS is similar to:
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                    NTP service: active
                RTC in local TZ: no
      dennis
      HOME=/home/dennis
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
      Swap:           1.8G          0B        1.8G
               7947 M total memory
               3448 M used memory
               3678 M free memory
                 92 M buffer memory
                997 M swap cache
               1721 M total swap
                  0 M used swap
               1721 M free swap
      *** FILESYSTEM ***
      /var:
      963M    /var/
      488M    /var/log
      286M    /var/cache
      USB-Devices by-id:
      ⚠ HINT:
      /dev/ttyACM0
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      nodejs:
        Version table:
      console.log(err)
      ioBroker Status
      Objects type: jsonl
      States type: jsonl
      Hosts:
      admin: 7.8.23
      javascript: 9.0.18
      Adapter State
      • instance is alive
      Objects and States
      Objects: 22695
      States: 166357
      @DennisMenger sagte:
      Updaten. Jetzt.
      nodesource-Repo zuvor auf Stand bringen:
      iob nodejs-update 22
      (Rückfragen bejahen)
      • D Online
        D Online
        DennisMenger
        Oh ... ja das hätte ich wohl vorher tun sollen.
        Sollte jetzt alles aktuell sein.
        Script v.2026-01-31
        *** BASE SYSTEM ***
                 Chassis: vm 🖴
          Virtualization: kvm
        OS is similar to:
        Docker          : false
        Kernel          : x86_64
        Userland        : 64 bit
         23:17:21 up  2:32,  2 users,  load average: 2.07, 1.55, 1.29
        CPU threads: 4
                       Local time: Tue 2026-06-02 23:17:21 CEST
                   Universal time: Tue 2026-06-02 21:17:21 UTC
                         RTC time: Tue 2026-06-02 21:17:21
                      NTP service: active
                  RTC in local TZ: no
        dennis
        HOME=/home/dennis
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Mem:            8.3G        2.0G        4.5G        6.4M        2.1G        6.3G
        Swap:           1.8G          0B        1.8G
        Total:           10G        2.0G        6.3G
                 7947 M total memory
                 1954 M used memory
                 1575 M active memory
                 1681 M inactive memory
                 4316 M free memory
                   14 M buffer memory
                 1966 M swap cache
                 1721 M total swap
                    0 M used swap
                 1721 M free swap
        top - 23:17:21 up  2:32,  2 users,  load average: 2.07, 1.55, 1.29
        Tasks: 139 total,   4 running, 135 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 64.3 us,  2.4 sy,  0.0 ni, 33.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   7947.3 total,   4312.2 free,   1958.4 used,   1981.2 buff/cache
        MiB Swap:   1722.0 total,   1722.0 free,      0.0 used.   5988.9 avail Mem
        *** FILESYSTEM ***
        /dev/sda1      ext4       30G  8.1G   21G  29% /
        tmpfs          tmpfs     3.9G  5.6M  3.9G   1% /tmp
        /var:
        1.1G    /var/
        489M    /var/log
        384M    /var/cache
        103M    /opt/iobroker/iobroker-data/states.jsonl
        USB-Devices by-id:
        ⚠ HINT:
        /dev/ttyACM0
        /usr/bin/nodejs         v22.22.2
        /usr/bin/node           v22.22.2
        /usr/bin/npm            10.9.7
        /usr/bin/npx            10.9.7
        nodejs:
          Installed: 22.22.2-1nodesource1
          Candidate: 22.22.2-1nodesource1
          Version table:
         *** 22.22.2-1nodesource1 1001
             22.22.1-1nodesource1 1001
             22.22.0-1nodesource1 1001
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        ioBroker2025        ioBroker2025 (version: 7.0.7, hostname: ioBroker2025  , alive, uptime: 18)
        admin:          7.8.23
        javascript:     9.0.18
        Adapter State
        + system.adapter.admin.1                  : admin                 : ioBroker2025                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.history.0                : history               : ioBroker2025                             -  enabled
        + instance is alive
        Objects and States
        Objects:        22695
        States:         166181
        Hit:1 http://security.debian.org/debian-security trixie-security InRelease
        Hit:2 http://deb.debian.org/debian trixie InRelease
        Hit:3 http://deb.debian.org/debian trixie-updates InRelease
        Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
        Pending systemupdates: 0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       58346      16771/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       57224      16771/iobroker.js-c
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          52797      9944/sshd: /usr/sbi
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          3718       1/systemd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          52799      9944/sshd: /usr/sbi
        tcp6       0      0 :::111                  :::*                    LISTEN      0          452        1/systemd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       60486      16794/io.admin.1
        udp        0      0 0.0.0.0:4002            0.0.0.0:*                           1001       62347      17452/io.govee-loca
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          3719       1/systemd
        udp6       0      0 :::111                  :::*                                0          4372       1/systemd
        2026-06-02 23:17:45.710  - info: host.ioBroker2025 instance system.adapter.ical.0 in version "1.20.0" started with pid 17518
        2026-06-02 23:17:48.192  - info: ical.0 (17518) starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.0.7
        2026-06-02 23:17:49.563  - info: ical.0 (17518) processing URL: Kalender Menger https://outlook.live.com/owa/calendar/8cd7b017-fa7d-4cfa-966c-0c41bcddccd7/93aaa8a3-6754-4f63-9451-bfbafe749441/cid-FDE760221FEA4657/calendar.ics
        2026-06-02 23:17:51.488  - info: host.ioBroker2025 instance scheduled system.adapter.ical.1 0,30 * * * *
        2026-06-02 23:17:51.492  - info: host.ioBroker2025 instance system.adapter.ical.1 in version "1.20.0" started with pid 17558
        2026-06-02 23:17:57.529  - info: host.ioBroker2025 instance scheduled system.adapter.ical.2 0,30 * * * *
        2026-06-02 23:17:57.534  - info: host.ioBroker2025 instance system.adapter.ical.2 in version "1.20.0" started with pid 17570
        2026-06-02 23:17:57.873  - info: admin.1 (16794) <== Disconnect system.user.admin from ::ffff:192.168.178.40
        2026-06-02 23:18:01.311  - info: ical.0 (17518) Terminated (NO_ERROR): Without reason
        2026-06-02 23:18:01.949  - info: host.ioBroker2025 instance system.adapter.pollenflug.0 in version "2.0.0" started with pid 17582
        2026-06-02 23:18:02.174  - info: cloud.0 (17339) Trying to connect as system.user.admin to cloud
        2026-06-02 23:18:02.295  - info: host.ioBroker2025 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        2026-06-02 23:18:02.295  - info: cloud.0 (17339) Connection changed: connect
        2026-06-02 23:18:02.525  - info: host.ioBroker2025 instance system.adapter.proxmox.0 in version "2.4.10" started with pid 17590
        2026-06-02 23:18:02.579  - info: ical.1 (17558) starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.0.7
        2026-06-02 23:18:02.866  - info: ical.2 (17570) starting. Version 1.20.0 in /opt/iobroker/node_modules/iobroker.ical, node: v22.22.2, js-controller: 7.0.7
        2026-06-02 23:18:03.020  - info: ical.1 (17558) processing URL: Müll https://www.awsh.de/api_v2/collection_dates/1/ort/71/strasse/150/hausnummern/0/abfallarten/R02-B02-D02-P04-W0/kalender.ics
        2026-06-02 23:18:03.415  - info: ical.2 (17570) processing URL: HSV http://i.cal.to/ical/12/hsv/bundesliga-spielplan/d4c69b46.3ec5e7c4-d88aa88f.ics
        2026-06-02 23:18:04.697  - info: pollenflug.0 (17582) starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.pollenflug, node: v22.22.2, js-controller: 7.0.7
        2026-06-02 23:18:04.715  - info: pollenflug.0 (17582) Starting Adapter pollenflug.0 in version 2.0.0
        2026-06-02 23:18:04.733  - info: pollenflug.0 (17582) Requesting DWD pollen information now.
        2026-06-02 23:18:04.741  - info: proxmox.0 (17590) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.proxmox, node: v22.22.2, js-controller: 7.0.7
        2026-06-02 23:18:04.831  - warn: proxmox.0 (17590) Using next Proxmox API: https://192.168.178.201:8006/api2/json
        2026-06-02 23:18:05.699  - info: host.ioBroker2025 instance system.adapter.tr-064.0 in version "4.3.0" started with pid 17657
        2026-06-02 23:18:05.861  - info: pollenflug.0 (17582) Next DWD pollen request starts on Wed Jun 03 2026 11:00:00 GMT+0200 (Mitteleuropäische Sommerzeit)
        • D DennisMenger
          Script v.2026-01-31
          *** BASE SYSTEM ***
                   Chassis: vm 🖴
            Virtualization: kvm
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
                        NTP service: active
                    RTC in local TZ: no
          dennis
          HOME=/home/dennis
          iobroker
          HOME=/home/iobroker
          Display-Manager:
          Desktop:
          Session:                tty
          *** MEMORY ***
          Swap:           1.8G          0B        1.8G
                   7947 M total memory
                   1954 M used memory
                   4316 M free memory
                     14 M buffer memory
                   1966 M swap cache
                   1721 M total swap
                      0 M used swap
                   1721 M free swap
          *** FILESYSTEM ***
          /var:
          1.1G    /var/
          489M    /var/log
          384M    /var/cache
          USB-Devices by-id:
          ⚠ HINT:
          /dev/ttyACM0
          /usr/bin/npm            10.9.7
          /usr/bin/npx            10.9.7
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.8.23
          javascript:     9.0.18
          Adapter State
          + instance is alive
          Objects and States
          Objects:        22695
          States:         166181
          Lass den ioBroker jetzt erstmal starten...
          • D DennisMenger
            Hallo zusammen.
            Folgende Fehlermeldung erhalte ich beim Anzeigen meiner Vis2 beim Aufruf über iobroker.pro. Beim Zugriff intern im Heimnetz funktioniert die Anzeige. Bis vor einigen Wochen hat der Zugriff über iobroker.pro noch einwandfrei funktioniert.
            Ein Downgrade des Adapters "Vis 2 Widgets Material" von 1.6.1 auf 1.4.10 brachte kein Erfolg. Browsercache ebenfalls gelöscht. Kann noch jemand das Problem so bestätigen. Werden weitere Angaben benötigt?
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            @DennisMenger
            Starte zur Sicherheit einmal noch den vis2 Adapter neu.
            Wenn dann, wer nicht der ioBroker Log interessant, sondern der Browser log mit F 12
            Das ist ein vis2/react Thema
            Meine Adapter und Widgets
            Links im Profil
            • D Online
              D Online
              DennisMenger
              ```bash
              Script v.2026-01-31
              *** BASE SYSTEM ***
                       Chassis: vm 🖴
                Virtualization: kvm
                        Kernel: Linux 6.12.90+deb13.1-amd64
              OS is similar to:
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
               23:31:02 up 3 min,  1 user,  load average: 0.78, 0.53, 0.22
              CPU threads: 4
                             Local time: Tue 2026-06-02 23:31:02 CEST
                         Universal time: Tue 2026-06-02 21:31:02 UTC
                               RTC time: Tue 2026-06-02 21:31:02
                            NTP service: active
                        RTC in local TZ: no
              dennis
              HOME=/home/dennis
              iobroker
              HOME=/home/iobroker
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
              Mem:            8.3G        3.3G        4.5G        3.5M        819M        5.0G
              Swap:           1.8G          0B        1.8G
              Total:           10G        3.3G        6.3G
                       7947 M total memory
                       3159 M used memory
                       2920 M active memory
                        538 M inactive memory
                       4245 M free memory
                         50 M buffer memory
                        730 M swap cache
                       1721 M total swap
                          0 M used swap
                       1721 M free swap
              top - 23:31:02 up 3 min,  1 user,  load average: 0.78, 0.53, 0.22
              Tasks: 171 total,   1 running, 170 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   7947.3 total,   4245.5 free,   3159.7 used,    781.7 buff/cache
              MiB Swap:   1722.0 total,   1722.0 free,      0.0 used.   4787.6 avail Mem
              *** FILESYSTEM ***
              tmpfs          tmpfs     795M  568K  795M   1% /run
              tmpfs          tmpfs     3.9G  2.8M  3.9G   1% /tmp
              [Tue Jun  2 23:27:45 2026] EXT4-fs (sda1): orphan cleanup on readonly fs
              [Tue Jun  2 23:27:45 2026] EXT4-fs (sda1): mounted filesystem c05e89b3-8b22-491f-9297-88ed2de1a924 ro with ordered data mode. Quota mode: none.
              [Tue Jun  2 23:27:46 2026] EXT4-fs (sda1): re-mounted c05e89b3-8b22-491f-9297-88ed2de1a924 r/w.
              /var:
              1.1G    /var/
              489M    /var/log
              384M    /var/cache
              110M    /opt/iobroker/iobroker-data/states.jsonl
              31M     /opt/iobroker/iobroker-data/objects.jsonl
              USB-Devices by-id:
              ⚠ HINT:
              /dev/ttyACM0
              /usr/bin/npm            10.9.7
              /usr/bin/npx            10.9.7
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              ioBroker2025        ioBroker2025 (version: 7.0.7, hostname: ioBroker2025  , alive, uptime: 199)
              admin:          7.8.23
              javascript:     9.0.18
              Adapter State
              + system.adapter.alexa2.0                 : alexa2                : ioBroker2025                             -  enabled
              + system.adapter.backitup.0               : backitup              : ioBroker2025                             -  enabled
              + system.adapter.bring.0                  : bring                 : ioBroker2025                             -  enabled
              + system.adapter.cloud.0                  : cloud                 : ioBroker2025                             -  enabled
              + system.adapter.daswetter.0              : daswetter             : ioBroker2025                             -  enabled
              + system.adapter.device-reminder.0        : device-reminder       : ioBroker2025                             -  enabled
              + system.adapter.device-watcher.0         : device-watcher        : ioBroker2025                             -  enabled
              + system.adapter.discovery.0              : discovery             : ioBroker2025                             -  enabled
              + system.adapter.echarts.0                : echarts               : ioBroker2025                             -  enabled
              + system.adapter.fb-checkpresence.0       : fb-checkpresence      : ioBroker2025                             -  enabled
              + system.adapter.govee-app.0              : govee-app             : ioBroker2025                             -  enabled
              + system.adapter.govee-local.0            : govee-local           : ioBroker2025                             -  enabled
              + system.adapter.hmip.0                   : hmip                  : ioBroker2025                             -  enabled
              + system.adapter.iot.0                    : iot                   : ioBroker2025                             -  enabled
              + system.adapter.javascript.0             : javascript            : ioBroker2025                             -  enabled
              + system.adapter.plenticore.0             : plenticore            : ioBroker2025                             -  enabled, port: 80
              + system.adapter.pollenflug.0             : pollenflug            : ioBroker2025                             -  enabled
              + system.adapter.poolcontrol.0            : poolcontrol           : ioBroker2025                             -  enabled
              + system.adapter.proxmox.0                : proxmox               : ioBroker2025                             -  enabled, port: 8006
              + system.adapter.simple-api.0             : simple-api            : ioBroker2025                             -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
              + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker2025                             -  enabled
              + system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker2025                             -  enabled
              + system.adapter.telegram.0               : telegram              : ioBroker2025                             -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.text2command.0           : text2command          : ioBroker2025                             -  enabled
              + system.adapter.tr-064.0                 : tr-064                : ioBroker2025                             -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : ioBroker2025                             -  enabled
              + system.adapter.tuya.0                   : tuya                  : ioBroker2025                             -  enabled
              + system.adapter.vis-2.0                  : vis-2                 : ioBroker2025                             -  enabled
              + system.adapter.volvo.0                  : volvo                 : ioBroker2025                             -  enabled
              + system.adapter.web.0                    : web                   : ioBroker2025                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.zigbee.0                 : zigbee                : ioBroker2025                             -  enabled, port: /dev/ttyACM0
              + instance is alive
              Objects and States
              Objects:        22695
              States:         166393
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       8294       670/iobroker.js-con
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       7394       670/iobroker.js-con
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          7366       683/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1225       1/init
              tcp6       0      0 :::22                   :::*                    LISTEN      0          7376       683/sshd: /usr/sbin
              tcp6       0      0 :::111                  :::*                    LISTEN      0          4413       1/init
              tcp6       0      0 :::8087                 :::*                    LISTEN      1001       9012       1414/io.simple-api.
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6821       788/io.admin.1
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       10771      1576/io.web.0
              udp        0      0 0.0.0.0:4002            0.0.0.0:*                           1001       5957       1039/io.govee-local
              udp        0      0 192.168.178.120:68      0.0.0.0:*                           0          7440       823/dhcpcd: [BOOTP
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1226       1/init
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       8790       1169/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       8791       1169/io.tuya.0
              udp6       0      0 :::111                  :::*                                0          507        1/init
              udp6       0      0 fda5:d281:2402:0:f6:546 :::*                                0          7430       783/dhcpcd: [DHCP6
              udp6       0      0 2a01:41e1:1e84:3900:546 :::*                                0          6675       756/dhcpcd: [DHCP6
              udp6       0      0 fe80::82fa:60d3:250:546 :::*                                0          7392       717/dhcpcd: [DHCP6
              2026-06-02 23:30:42.158  - info: host.ioBroker2025 instance system.adapter.dwd.0 having pid 1614 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2026-06-02 23:30:50.043  - info: plenticore.0 (1398) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
              2026-06-02 23:30:51.237  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 0(Dennis/02:F5:06:2A:7F:85) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:30:51.420  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 1(Maxi/F6:05:B8:6D:03:F6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:30:51.558  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 2(Julian/2A:21:9C:AC:90:E6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:30:51.764  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 3(Sandra/A6:40:4D:FF:65:B9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:31:02.636  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 0(Dennis/02:F5:06:2A:7F:85) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:31:02.806  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 1(Maxi/F6:05:B8:6D:03:F6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:31:02.965  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 2(Julian/2A:21:9C:AC:90:E6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:31:03.080  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 3(Sandra/A6:40:4D:FF:65:B9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:31:10.918  - info: plenticore.0 (1398) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
              2026-06-02 23:31:13.801  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 0(Dennis/02:F5:06:2A:7F:85) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:31:13.984  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 1(Maxi/F6:05:B8:6D:03:F6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:31:14.152  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 2(Julian/2A:21:9C:AC:90:E6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:31:14.314  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 3(Sandra/A6:40:4D:FF:65:B9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:31:22.839  - info: hmip.0 (1055) Value unchanged, do not send this value
              2026-06-02 23:31:25.177  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 0(Dennis/02:F5:06:2A:7F:85) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:31:25.397  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 1(Maxi/F6:05:B8:6D:03:F6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:31:25.566  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 2(Julian/2A:21:9C:AC:90:E6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:31:25.681  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 3(Sandra/A6:40:4D:FF:65:B9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:31:32.884  - info: plenticore.0 (1398) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
              2026-06-02 23:31:36.594  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 0(Dennis/02:F5:06:2A:7F:85) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:31:36.717  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 1(Maxi/F6:05:B8:6D:03:F6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:31:36.832  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 2(Julian/2A:21:9C:AC:90:E6) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              2026-06-02 23:31:36.943  - info: tr-064.0 (1151) forEachConfiguredDevice: in GetSpecificHostEntry 3(Sandra/A6:40:4D:FF:65:B9) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
              • OliverIOO OliverIO
                @DennisMenger
                D Online
                D Online
                DennisMenger
                @OliverIO sagte:
                @DennisMenger
                Wo finde ich jetzt den Browser Log bzw. was ist da jetzt relevant?
                OliverIOO 2 Antworten Letzte Antwort
                • D DennisMenger
                  @OliverIO sagte:
                  @DennisMenger
                  OliverIOO Offline
                  OliverIOO Offline
                  OliverIO
                  @DennisMenger
                  Hast du F12 gedrückt?
                  Dort im tab console
                  Hast du neu gestartet?
                  Geht der Material Adapter überhaupt mit vis2?
                  Links im Profil
                  • D DennisMenger
                    @OliverIO sagte:
                    @DennisMenger
                    OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    @DennisMenger
                    Hier steht was dazu
                    https://github.com/ioBroker/ioBroker.vis-2-widgets-material/issues/612
                    Und hier
                    https://github.com/ioBroker/ioBroker.vis-2-widgets-material/issues/576
                    Links im Profil
                    • D Online
                      D Online
                      DennisMenger
                      Die beiden Fehler bei Github habe ich auch gefunden gehabt. Daher hatte ich ja den Adapter Vis 2 Widgets Material wieder auf die Version 1.4.10 runtergezogen, da diese Version ja noch funktionieren soll.
                      Neustart ist erfolgt.
                      Hier der Inhalt der Konsole in Microsoft Edge.
                      index-BqKFant6.js:29062 iobroker.vis-2@2.13.19
                      index-B3-udR3a.js:8088
                      index-B3-udR3a.js:8095 Nice to see you here! :) Join our dev community here https://github.com/ioBroker/ioBroker or here https://github.com/iobroker-community-adapters
                      index-B3-udR3a.js:8095 Help us to create open source project with reactJS!
                      index-B3-udR3a.js:8095 See you :)
                      socket.io.js:3 WebSocket connection to 'wss://iobroker.pro/socket.io/?ws=true&EIO=3&transport=websocket&sid=FlHcdbPacSnyYg8mArxw' failed:
                      n.doOpen @ socket.io.js:3
                      blob:https://iobroker.pro/8e68940d-65c3-4b4a-8390-2a4732b474ac:1 Manifest: property 'start_url' ignored, URL is invalid.
                      blob:https://iobroker.pro/8e68940d-65c3-4b4a-8390-2a4732b474ac:1 Manifest: property 'src' ignored, URL is invalid.
                      index-BqKFant6.js:27869 Skip script "bars" widgets/bars/js/bars.js
                      index-BqKFant6.js:27869 Skip script "bars" widgets/bars/js/jquery.sidebar.js
                      index-BqKFant6.js:27869 Skip script "bars" inline
                      index-BqKFant6.js:27869 Skip script "bring" widgets/bring/js/textFit.min.js
                      index-BqKFant6.js:27869 Skip script "bring" inline
                      index-BqKFant6.js:27869 Skip script "dwd" inline
                      index-BqKFant6.js:27869 Skip script "history" widgets/history/lib/js/jquery.sparkline.min.js
                      index-BqKFant6.js:27869 Skip script "history" inline
                      index-BqKFant6.js:27869 Skip script "hqwidgets" widgets/hqwidgets/js/jquery.knob.js
                      index-BqKFant6.js:27869 Skip script "hqwidgets" widgets/hqwidgets/js/odometer.min.js
                      index-BqKFant6.js:27869 Skip script "hqwidgets" widgets/hqwidgets/js/hqwidgets.js
                      index-BqKFant6.js:27869 Skip script "hqwidgets" widgets/hqwidgets/js/hqButton.js
                      index-BqKFant6.js:27869 Skip script "hqwidgets" inline
                      index-BqKFant6.js:27869 Skip script "jqplot" widgets/jqplot/js/jquery.jqplot.min.js
                      index-BqKFant6.js:27869 Skip script "jqplot" inline
                      index-BqKFant6.js:27869 Skip script "jqui-mfd" inline
                      index-BqKFant6.js:27869 Skip script "jqui" lib/js/jquery-ui-timepicker-addon-1.6.3.js
                      index-BqKFant6.js:27869 Skip script "jqui" inline
                      index-BqKFant6.js:27869 Skip script "justgage" widgets/justgage/js/justgage.js
                      index-BqKFant6.js:27869 Skip script "justgage" inline
                      index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/lib/raw/moment-with-locales.min.js
                      index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/lib/raw/round-slider.js
                      index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/lib.min.js
                      index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/lib/raw/sentry/bundle.min.js
                      index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/lib/raw/sentry/captureconsole.min.js
                      index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/lib/raw/sentry/dedupe.min.js
                      index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/js/materialdesign.js
                      index-BqKFant6.js:27869 Skip script "materialdesign" widgets/materialdesign/js/widgets.min.js
                      index-BqKFant6.js:27869 Skip script "materialdesign" inline
                      index-BqKFant6.js:27869 Skip script "metro" widgets/metro/js/metro.js
                      index-BqKFant6.js:27869 Skip script "metro" inline
                      index-BqKFant6.js:27869 Skip script "players" widgets/players/js/players.js
                      index-BqKFant6.js:27869 Skip script "players" inline
                      index-BqKFant6.js:27869 Skip script "swipe" inline
                      index-BqKFant6.js:27869 Skip script "tabs" inline
                      index-BqKFant6.js:27869 Skip script "timeandweather" widgets/timeandweather/js/flipclock/flipclock.min.js
                      index-BqKFant6.js:27869 Skip script "timeandweather" widgets/timeandweather/js/jquery.jdigiclock.js
                      index-BqKFant6.js:27869 Skip script "timeandweather" widgets/timeandweather/js/jquery.zweatherfeed.js
                      index-BqKFant6.js:27869 Skip script "timeandweather" widgets/timeandweather/js/coolclock.js
                      index-BqKFant6.js:27869 Skip script "timeandweather" widgets/timeandweather/js/moreskins.js
                      index-BqKFant6.js:27869 Skip script "timeandweather" widgets/timeandweather/js/segment-display.js
                      index-BqKFant6.js:27869 Skip script "timeandweather" inline
                      index-BqKFant6.js:27869 Skip script "trashschedule" widgets/trashschedule/js/trashschedule.js
                      index-BqKFant6.js:27869 Skip script "trashschedule" inline
                      index-BqKFant6.js:27869 Skip script "vis-inventwo" widgets/vis-inventwo/js/iro.min.js
                      index-BqKFant6.js:27869 Skip script "vis-inventwo" widgets/vis-inventwo/js/vis-inventwo.js
                      index-BqKFant6.js:27869 Skip script "vis-inventwo" inline
                      customWidgets.js:2 Uncaught SyntaxError: Cannot use import statement outside a module
                      index-BqKFant6.js:7423 Cannot load i18n "echarts": Error: [ Federation Runtime ]: remoteEntryExports is undefined
                        "name": "echarts",
                        "entry": "https://iobroker.pro/vis-2/widgets/echarts/customWidgets.js",
                        "type": "global",
                        "shareScope": "default",
                        "entryGlobalName": "echarts"
                      index-BqKFant6.js:7359 Cannot load widget system.adapter.echarts.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined
                        "name": "echarts",
                        "type": "global",
                          at error (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:599:123)
                          at assert (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:596:10)
                          at Module.getEntry (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1404:14)
                          at async Module.get (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:1410:14)
                          at async RemoteHandler.loadRemote (iobroker_vis__mf_v__runtimeInit__mf_v__-C2fBSUfm.js:2152:92)
                          at async Promise.all (/vis-2/index 0)
                      (anonymous) @ index-BqKFant6.js:7359
                      customWidgets.js:1 Uncaught SyntaxError: Cannot use import statement outside a module
                       Cannot load i18n "vis2materialWidgets": Error: [ Federation Runtime ]: remoteEntryExports is undefined
                        "name": "vis2materialWidgets",
                        "entry": "https://iobroker.pro/vis-2/widgets/vis-2-widgets-material/customWidgets.js",
                        "type": "global",
                        "entryGlobalName": "vis2materialWidgets"
                       Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined
                        "type": "global",
                          at error (iobroker_vis__mf_v__…C2fBSUfm.js:599:123)
                          at assert (iobroker_vis__mf_v__…-C2fBSUfm.js:596:10)
                          at Module.getEntry (iobroker_vis__mf_v__…C2fBSUfm.js:1404:14)
                          at async Module.get (iobroker_vis__mf_v__…C2fBSUfm.js:1410:14)
                          at async RemoteHandler.loadRemote (iobroker_vis__mf_v__…C2fBSUfm.js:2152:92)
                          at async Promise.all (/vis-2/index 3)
                      index-BqKFant6.js:7359 Cannot load widget system.adapter.vis-2-widgets-material.0: Error: [ Federation Runtime ]: remoteEntryExports is undefined
                        "type": "global",
                          at async Promise.all (/vis-2/index 1)
                        "type": "global",
                          at async Promise.all (/vis-2/index 2)
                        "type": "global",
                        "type": "global",
                          at async Promise.all (/vis-2/index 4)
                        "type": "global",
                          at async Promise.all (/vis-2/index 5)
                        "type": "global",
                          at async Promise.all (/vis-2/index 6)
                        "type": "global",
                          at async Promise.all (/vis-2/index 7)
                        "type": "global",
                          at async Promise.all (/vis-2/index 8)
                        "type": "global",
                          at async Promise.all (/vis-2/index 9)
                        "type": "global",
                          at async Promise.all (/vis-2/index 10)
                        "type": "global",
                          at async Promise.all (/vis-2/index 11)
                        "type": "global",
                          at async Promise.all (/vis-2/index 12)
                        "type": "global",
                          at async Promise.all (/vis-2/index 13)
                        "type": "global",
                          at async Promise.all (/vis-2/index 14)
                        "type": "global",
                          at async Promise.all (/vis-2/index 15)
                        "type": "global",
                          at async Promise.all (/vis-2/index 16)
                        "type": "global",
                          at async Promise.all (/vis-2/index 17)
                      index-B3-udR3a.js:8970 Translate: jqui_widgetTitle
                      index-B3-udR3a.js:8970 Translate: jqui_Write state
                      index-B3-udR3a.js:8970 Translate: jqui_Close
                      index-B3-udR3a.js:8970 Translate: jqui_input
                      index-B3-udR3a.js:8970 Translate: jqui_off
                      index-B3-udR3a.js:8970 Translate: jqui_on
                      index-B3-udR3a.js:8970 Translate: Value
                      index-BqKFant6.js:25856 Ignored bars/tplBarFilter because not used in project
                      index-BqKFant6.js:25856 Ignored bars/tplBarNavigator because not used in project
                      index-BqKFant6.js:25856 Ignored bring/tplBringShoppingList because not used in project
                      index-BqKFant6.js:25856 Ignored dwd/tplDwdAdapterSmall because not used in project
                      index-BqKFant6.js:25856 Ignored dwd/tplDwdAdapter because not used in project
                      index-BqKFant6.js:25856 Ignored history/tplHistoryEventList because not used in project
                      index-BqKFant6.js:25856 Ignored history/tplHistorySparkLIne because not used in project
                      index-BqKFant6.js:25856 Ignored hqwidgets/tplHqButton because not used in project
                      index-BqKFant6.js:25856 Ignored hqwidgets/tplHqDimmer because not used in project
                      index-BqKFant6.js:25856 Ignored hqwidgets/tplHqInTemp because not used in project
                      index-BqKFant6.js:25856 Ignored hqwidgets/tplHqOutTemp because not used in project
                      index-BqKFant6.js:25856 Ignored hqwidgets/tplHqShutter because not used in project
                      index-BqKFant6.js:25856 Ignored hqwidgets/tplHqDoor because not used in project
                      index-BqKFant6.js:25856 Ignored hqwidgets/tplHqLock because not used in project
                      index-BqKFant6.js:25856 Ignored hqwidgets/tplHqCheckbox because not used in project
                      index-BqKFant6.js:25856 Ignored hqwidgets/tplHqCircle because not used in project
                      index-BqKFant6.js:25856 Ignored hqwidgets/tplHqOdometer because not used in project
                      index-BqKFant6.js:25856 Ignored jqplot/tplJqplotGauge because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdLight because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdLightCtrl because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdLightOnOffDialog because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdLightDialog because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdSocket because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdSocketCtrl because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdShutter because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdShutterDialog because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdBlind because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdBlindDialog because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdHeating because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdWindow because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdWindowBool because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdRoofWindowBool because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdDoor because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdGarage because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdValve because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdValveDialog because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdCustom10 because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdCustom10Dialog because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdCamSnapshot because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplValMfdCamSnapshot because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdCamMjpg because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplValMfdCamMjpg because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdCamVideo because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplValMfdCamVideo because not used in project
                      index-BqKFant6.js:25856 Ignored jqui-mfd/tplMfdCamVideoObject because not used in project
                      index-BqKFant6.js:25856 Ignored justgage/tplJustgageJustGage because not used in project
                      index-BqKFant6.js:25856 Ignored justgage/tplJustgageValueColored because not used in project
                      index-BqKFant6.js:25856 Ignored justgage/tplJustgageIndicatorColored because not used in project
                      index-BqKFant6.js:25856 Ignored justgage/tplJustgageValueIndicatorColored because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-value because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Navigation-vertical because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Link-vertical because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-State-vertical because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-State-Multi-vertical because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Adition-vertical because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Toggle-vertical because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Navigation because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Link because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-State because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-State-Multi because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Adition because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Button-Toggle because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-Button-Navigation because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-Button-Link because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-Button-State because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-Button-State-Multi because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-Button-Adition because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-Button-Toggle because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Input because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Autocomplete because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Select because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Switch because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-CheckBox because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Vuetify-Slider because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Slider-Round because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Progress because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Progress-Circular because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Card because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-TopAppBar-Navigation because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-List because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon-List because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Chart-Bar because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Chart-Line-History because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Chart-JSON because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Chart-Pie because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-ColorScheme-Preview because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Vuetify-Dialog-View because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Vuetify-Dialog-iFrame because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Table because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Masonry-Views because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Grid-Views because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Alerts because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Calendar because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Icon because not used in project
                      index-BqKFant6.js:25856 Ignored materialdesign/tplVis-materialdesign-Installed-Version because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroSlider because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroSliderVertical because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroValueBoolCheckbox because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroValueBoolSwitch because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileNav because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileString because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileBool because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileBoolDialog because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileList8 because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileBoolNumber because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileState because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileToggle because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileStateNumber because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileDimmer because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileDimmerDialog because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileShutter because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileShutterDialog because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileHeating because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileHeatingDialog because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileDialogStatic because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileStaticDialogNumber because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileDialogString because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileStringDialogNumber because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileDialog because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileDialogNumber because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileFrameDialogNumber because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileToggleNumber because not used in project
                      index-BqKFant6.js:25856 Ignored metro/tplMetroTileDimmerDialogactiv because not used in project
                      index-BqKFant6.js:25856 Ignored players/tplWinampPlayer because not used in project
                      index-BqKFant6.js:25856 Ignored players/tplWinampPlaylist because not used in project
                      index-BqKFant6.js:25856 Ignored players/tplWinampBrowser because not used in project
                      index-BqKFant6.js:25856 Ignored players/tplSonosMobilePlayer because not used in project
                      index-BqKFant6.js:25856 Ignored swipe/tplCarousel because not used in project
                      index-BqKFant6.js:25856 Ignored timeandweather/tplTwSimpleDate because not used in project
                      index-BqKFant6.js:25856 Ignored timeandweather/tplTwSimpleClock because not used in project
                      index-BqKFant6.js:25856 Ignored timeandweather/tplTwCoolClock because not used in project
                      index-BqKFant6.js:25856 Ignored timeandweather/tplTwFlipClock because not used in project
                      index-BqKFant6.js:25856 Ignored timeandweather/tplTwHtcWeather because not used in project
                      index-BqKFant6.js:25856 Ignored timeandweather/tplTwWeather because not used in project
                      index-BqKFant6.js:25856 Ignored timeandweather/tplSvgClock because not used in project
                      index-BqKFant6.js:25856 Ignored timeandweather/tplSegmentClock because not used in project
                       Ignored trashschedule/tplTrashscheduleHelper because not used in project
                       Ignored vis-inventwo/i-vis-universal because not used in project
                       Ignored vis-inventwo/i-vis-multi because not used in project
                       Ignored vis-inventwo/i-vis-slider-simple because not used in project
                       Ignored vis-inventwo/i-vis-slider-simple-2 because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-slider-color-hor because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-slider-color-vert because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-color-picker because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-image-new because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-jsontable because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-radiobutton-list because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-valuelist because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-marquee because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-switch-1 because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-switch-basic because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-checkbox because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-switch because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-switch-small because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-button because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-button-small because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-navigation because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-navigation-small because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-background because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-background-small because not used in project
                      index-BqKFant6.js:25856 Ignored vis-inventwo/i-vis-image because not used in project
                      index-CKUrMIxx.js:395 Error: <svg> attribute width: Expected length, "auto".
                      zu @ index-CKUrMIxx.js:395
                      • D DennisMenger
                          "name": "echarts",
                          "type": "global",
                          "name": "echarts",
                          "type": "global",
                          "type": "global",
                          "type": "global",
                          "type": "global",
                          "type": "global",
                          "type": "global",
                          "type": "global",
                          "type": "global",
                          "type": "global",
                          "type": "global",
                          "type": "global",
                          "type": "global",
                          "type": "global",
                          "type": "global",
                          "type": "global",
                          "type": "global",
                          "type": "global",
                          "type": "global",
                          "type": "global",
                          "type": "global",
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        @DennisMenger
                        Eckarts funktioniert auch nicht
                        Probiere mal den Material Adapter zu löschen und neu zu installieren
                        Links im Profil
                        • D Online
                          D Online
                          DennisMenger
                          schrieb am zuletzt editiert von DennisMenger
                          @OliverIO sagte:
                          Was ist Eckarts?
                          Neuinstallation des Adapters brachte leider auch kein Erfolg. Inkl. Neustart des ioBrokers
                          • D DennisMenger
                            @OliverIO sagte:
                            Was ist Eckarts?
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            @DennisMenger
                            Echarts
                            Links im Profil
                            83.1k
