  4. Test Adapter Life360 NextGeneration - Latest
    6.8k
life360mapstandortgeo locationinventwocursor ai
317 Beiträge 18 Kommentatoren 27.6k Aufrufe 18 Beobachtet
  • skvarelS Online
    skvarelS Online
    skvarel
    schrieb am zuletzt editiert von skvarel
    #275
    ALPHA Update
    • (skvarel) Added a one-time info log after the first successful poll summarizing the fetched data: number of circles, Life360 places, own places, and persons
    • (skvarel) Expanded verbose logging (adapter config option) to log circle names with member/place counts, all Life360 place names with radius, and each person's name, battery, connection state, and current location per poll cycle at info level (no log level change required)
    • (skvarel) Fixed people.<id>.disconnected and people.<id>.isConnected states always showing wrong values because the Life360 API returns the disconnected field as a string ("0"/"1") instead of a boolean, causing Boolean("0") to evaluate as true
    • (skvarel) Added notifications.lastSpokenText state that stores every notification text, allowing Blockly scripts or other automations (e.g. Sonos) to react to location events without requiring Telegram or Alexa
    • (skvarel) Added Auto-Refresh checkbox (default on) and Live Follow checkbox to tracker map hamburger menus: Auto-Refresh replaces the unconditional meta-refresh with a user-controllable JS-based page reload; Live Follow pans the map to the person's latest GPS position on every data update; in the circle map clicking a person's name in the legend focuses the map on that person's route
    EDIT:
    Aktion Auto-Refresh Live Follow
    Live Follow einschalten wird automatisch aktiviert ✔
    Live Follow ausschalten bleibt unverändert ✘
    Auto-Refresh ausschalten ✘ bleibt unverändert (aber wirkungslos)
    #TeamInventwo
    Unsere Adapter:
    • Merlin123M Offline
      Merlin123M Offline
      Merlin123
      #276
      teste es gleich mal :)
      Beta-Tester
      • B buflug453
        Herzlichen Dank, das läuft alles wie am Schnürchen :)
        Ich hätte noch ein paar Anregungen für Verbesserungen, die zumindest mir etwas helfen würden:
        • Bei der Kartensicht wäre es hilfreich, wenn ich auf eine Flagge klicke und sehe wann die Person an dem Ort zuletzt angekommen ist oder diesen verlassen hat.
        • Neben dem von Life360 übermittelten Namen man selbst einen Alias vergeben kann. Falls gesetzt soll dann dieser z.B. bei der Karte, Benachrichtigung etc. genutzt werden.
        • Für die Benachrichtigung wäre es super, wenn der zu sprechende Text zusätzlich in ein Datenpunkten gespeichert wird. Hintergrund: ich nutze keine Alexa und ich möchte auch nicht ständig am Handy Telegram Popups haben. Stattdessen soll über die Sonos bei bestimmten Orten eine Ansage kommen. Ich weiß, dass das mit Blockly lösbar ist, aber dieser Datenpunkt würde es vereinfachen.
        Das sind alles nice-to-have Wünsche :) danke @skvarel für deine Einschätzung
        skvarelS Online
        skvarelS Online
        skvarel
        #277
        @buflug453 sagte:
        Ist machbar. Allerdings bleiben die ioBroker Adapter Objekte so wie sie sind. Das würde sonst nur für Verwirrung sorgen und jeder User müsste seine Scripte und Visu ändern!
        Alles was die Karten betrifft kann ich auf den Alias ändern.
        Bei den Benachrichtigungen nutze ich den Namen eh nicht als Ausgabe. Das sind jetzt schon alles benutzerdefinerbare Textfelder.
        EDIT:
        Neues ALPHA Update kommt gleich
        Verhalten: Der Alias ersetzt den Life360-Namen nur in der Anzeige (Karten-Header, Legende). State-IDs und interne Identifikatoren bleiben unverändert.
        #TeamInventwo
        Unsere Adapter:
        • skvarelS Online
          skvarelS Online
          skvarel
          #278
          Die neue Config (Alpha):
          Auswirkungen auf die Karte:
          Keine Auswirkungen auf die Adapter Objekte!
          #TeamInventwo
          Unsere Adapter:
          • skvarelS Online
            skvarelS Online
            skvarel
            #279
            @all
            Wenn es keine Probleme mit der neuen Kartenansicht gibt, würde ich die Version spätestens am Sonntag ins Latest pushen.
            #TeamInventwo
            Unsere Adapter:
            • skvarelS skvarel
              @olivbus .. kannst du mal bitte die aktuelle Alpha installieren und mir dann den Log zeigen?
              Ich habe den Log erweitert:
              life360ng.0
              	2026-05-22 07:26:52.117	info	Life360 data: 1 circle(s), 3 Life360 place(s), 8 own place(s), 2 person(s)
              life360ng.0
              	2026-05-22 07:26:50.285	info	Connected to Life360 cloud services.
              life360ng.0
              	2026-05-22 07:26:50.284	info	Polling enabled every 60 seconds.
              life360ng.0
              	2026-05-22 07:26:50.225	info	[Tracker] Initialized (2 person(s))
              life360ng.0
              	2026-05-22 07:26:49.341	info	starting. Version 1.9.1 (non-npm: inventwo/ioBroker.life360ng#a19fa28fce15cdb0217ff48493a7a2b95c932eb9) in /opt/iobroker/node_modules/iobroker.life360ng, node: v22.22.2, js-controller: 7.1.2
              O Offline
              O Offline
              Olivbus
              schrieb am zuletzt editiert von Olivbus
              #280
              @skvarel
              @skvarel sagte:
              life360ng.0
              2026-05-22 21:38:14.853	info	Life360 data: 1 circle(s), 0 Life360 place(s), 1 own place(s), 1 person(s)
              life360ng.0
              2026-05-22 21:38:12.926	info	Connected to Life360 cloud services.
              life360ng.0
              2026-05-22 21:38:12.923	info	Polling enabled every 60 seconds.
              life360ng.0
              2026-05-22 21:38:12.827	info	[Tracker] Initialized (1 person(s))
              life360ng.0
              2026-05-22 21:38:12.104	info	starting. Version 1.9.1 (non-npm: inventwo/ioBroker.life360ng) in /opt/iobroker/node_modules/iobroker.life360ng, node: v22.22.2, js-controller: 7.0.7
              host.debian
              2026-05-22 21:38:07.934	info	instance system.adapter.life360ng.0 in version "1.9.1" (non-npm: inventwo/ioBroker.life360ng) started with pid 3633507
              Ich kann die Benachrichtigung der Places in der App nicht aktivieren. Das ist ausgegraut. Liegt es vielleicht daran, dass ich keine Person außer mir in meinem Kreis habe? Ich habe zwei Places in der App angelegt (Zuhause und Arbeit).
              skvarelS 1 Antwort Letzte Antwort
              • O Olivbus
                @skvarel
                @skvarel sagte:
                life360ng.0
                life360ng.0
                life360ng.0
                life360ng.0
                life360ng.0
                host.debian
                skvarelS Online
                skvarelS Online
                skvarel
                #281
                @Olivbus .. ok, der Log sagt so jedenfalls keine Probleme. Ich prüfe da morgen früh noch mal etwas und melde.
                Du kannst aber mal versuchen, die Version 1.1.0 zu installieren. Das ist die letzte Version vor dem Tracking. Eventuell tritt dein Fehler nur bei einer neuen Installation auf und ich habe es bei Updates nicht bemerkt.
                #TeamInventwo
                Unsere Adapter:
                O 1 Antwort Letzte Antwort
                • skvarelS skvarel
                  O Offline
                  O Offline
                  Olivbus
                  #282
                  @skvarel wie kann ich auf 1.1.0 downgraden?
                  skvarelS 2 Antworten Letzte Antwort
                  • O Olivbus
                    skvarelS Online
                    skvarelS Online
                    skvarel
                    #283
                    @Olivbus
                    EDIT:
                    Copilot hat da etwas gefuden!
                    Zitat:
                    "Die Life360-API hat zwei verschiedene Endpunkte:
                    /v4/circles → liefert Circles inklusive eingebetteter Places im Circle-Objekt
                    /v3/circles/{id}/places → separater Endpunkt nur für Places
                    Der Adapter hat beim Polling zuerst die Circles von v4 abgerufen (wobei circle.places bereits befüllt war), dann aber immer den v3-Places-Endpunkt aufgerufen und dessen Ergebnis bedingungslos überschrieben — auch wenn v3 ein leeres Array [] zurückgegeben hat.
                    Bei manchen Accounts/Regionen gibt der v3-Endpunkt schlicht {"places": []} zurück, obwohl Orte in der App vorhanden sind. Da kein Fehler oder Warning geloggt wird (ein leeres Array ist für den Code eine gültige Antwort), war der Bug unsichtbar."
                    Die Lösung:
                    In life360CloudConnector.js werden die v4-Places jetzt vor dem v3-Aufruf gesichert. Wenn der v3-Endpunkt 0 Places zurückliefert, aber die v4-Antwort Places enthielt, werden diese als Fallback verwendet. Ein debug-Log wird dabei geschrieben, damit der Fall künftig diagnostizierbar ist.
                    Bitte einmal die aktuelle ALPHA (Github) testen ... 1.9.1+624857c
                    Fixed Life360 places not being created for some accounts: the v4/circles API response already embeds places in each circle object, but they were silently overwritten by the separate v3 places endpoint which returns an empty list for some accounts/regions; the adapter now falls back to the v4 embedded places when the v3 endpoint returns 0 results
                    #TeamInventwo
                    Unsere Adapter:
                    • O Olivbus
                      skvarelS Online
                      skvarelS Online
                      skvarel
                      #284
                      @Olivbus .. es kann aber eigentlich nicht an der Version liegen.
                      Ich habe mir gerade einen ganz frischen ioBroker angelegt und die Places wurde sofort abgerufen:
                      life360ng.0
                      	2026-05-23 06:52:23.178	info	Life360 data: 1 circle(s), 3 Life360 place(s), 0 own place(s), 2 person(s)
                      life360ng.0
                      	2026-05-23 06:52:21.731	info	Connected to Life360 cloud services.
                      life360ng.0
                      	2026-05-23 06:52:21.730	info	Polling enabled every 120 seconds.
                      life360ng.0
                      	2026-05-23 06:52:21.721	info	[Tracker] Route logger disabled
                      life360ng.0
                      	2026-05-23 06:52:21.693	info	starting. Version 1.9.1 (non-npm: inventwo/ioBroker.life360ng#cc4fceaea5c90a857d05b3783ca22e6a7096f138) in C:/ioBroker/node_modules/iobroker.life360ng, node: v22.22.2, js-controller: 7.0.7
                      #TeamInventwo
                      Unsere Adapter:
                      • skvarelS skvarel
                        @Olivbus
                        EDIT:
                        Die Lösung:
                        O Offline
                        O Offline
                        Olivbus
                        #285
                        @skvarel
                        @skvarel sagte:
                        Ich habe die Version getestet. Leider weiter keine Places.
                        life360ng.0
                        2026-05-23 09:53:27.868	info	Life360 data: 1 circle(s), 0 Life360 place(s), 1 own place(s), 1 person(s)
                        life360ng.0
                        2026-05-23 09:53:25.938	info	Connected to Life360 cloud services.
                        life360ng.0
                        2026-05-23 09:53:25.935	info	Polling enabled every 60 seconds.
                        life360ng.0
                        2026-05-23 09:53:25.844	info	[Tracker] Initialized (1 person(s))
                        life360ng.0
                        2026-05-23 09:53:25.055	info	starting. Version 1.9.1 (non-npm: inventwo/ioBroker.life360ng#624857cf7799b22713636c9aeee01a5de4c45740) in /opt/iobroker/node_modules/iobroker.life360ng, node: v22.22.2, js-controller: 7.0.7
                        skvarelS 3 Antworten Letzte Antwort
                        • O Olivbus
                          @skvarel
                          @skvarel sagte:
                          life360ng.0
                          life360ng.0
                          life360ng.0
                          life360ng.0
                          life360ng.0
                          skvarelS Online
                          skvarelS Online
                          skvarel
                          #286
                          @Olivbus .. das ist echt merkwürdig! Ich recherchiere weiter!
                          #TeamInventwo
                          Unsere Adapter:
                          • O Olivbus
                            @skvarel
                            @skvarel sagte:
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            skvarelS Online
                            skvarelS Online
                            skvarel
                            #287
                            @Olivbus .. hast du die Versionsnummer im Admin kontrolliert?
                            Nicht das da etwas verschluckt wurde.
                            Hast du einen manuellen Upload gemacht?
                            #TeamInventwo
                            Unsere Adapter:
                            • skvarelS skvarel
                              O Offline
                              O Offline
                              Olivbus
                              #288
                              @skvarel
                              Wie schon geschrieben, lässt sich in meiner Life App die Benachrichtigung über die Places nicht aktivieren. Das ist ausgegraut. Vielleicht liegt es daran.
                              Ist das so o.k?
                              • O Olivbus
                                @skvarel
                                @skvarel sagte:
                                life360ng.0
                                life360ng.0
                                life360ng.0
                                life360ng.0
                                life360ng.0
                                skvarelS Online
                                skvarelS Online
                                skvarel
                                #289
                                @Olivbus ... bitte noch mal neu von Github installieren und mir den Log zeigen. Ich habe gerade noch etwas angepasst.
                                #TeamInventwo
                                Unsere Adapter:
                                • O Olivbus
                                  @skvarel
                                  Ist das so o.k?
                                  skvarelS Online
                                  skvarelS Online
                                  skvarel
                                  #290
                                  @Olivbus .. nein, daran liegt es nicht. Das war ein Gedankenfehler. Damit meldest du nur innerhalb der App an andere Kreis-Mitglieder
                                  #TeamInventwo
                                  Unsere Adapter:
                                  • skvarelS skvarel
                                    O Offline
                                    O Offline
                                    Olivbus
                                    #291
                                    @skvarel
                                    @skvarel sagte:
                                    life360ng.0
                                    2026-05-23 10:14:59.379	info	Life360 data: 1 circle(s), 0 Life360 place(s), 1 own place(s), 1 person(s)
                                    life360ng.0
                                    2026-05-23 10:14:58.941	info	All place sources (v3, embedded v4, v4 endpoint) returned 0 places for circle xxxxxxxxx-xxxxx-xxxx-xxxx-dxxxxxxxxx. Life360 may not expose places for this account via the API.
                                    life360ng.0
                                    2026-05-23 10:14:57.188	info	Connected to Life360 cloud services.
                                    life360ng.0
                                    2026-05-23 10:14:57.185	info	Polling enabled every 60 seconds.
                                    life360ng.0
                                    2026-05-23 10:14:57.094	info	[Tracker] Initialized (1 person(s))
                                    life360ng.0
                                    2026-05-23 10:14:56.449	info	starting. Version 1.9.1 (non-npm: inventwo/ioBroker.life360ng#1ff344c1830b2c5b2687c79e250222fb169b796f) in /opt/iobroker/node_modules/iobroker.life360ng, node: v22.22.2, js-controller: 7.0.7
                                    Leider keine places.
                                    • O Olivbus
                                      @skvarel
                                      @skvarel sagte:
                                      life360ng.0
                                      life360ng.0
                                      life360ng.0
                                      life360ng.0
                                      life360ng.0
                                      life360ng.0
                                      skvarelS Online
                                      skvarelS Online
                                      skvarel
                                      #292
                                      @Olivbus .. das ist ärgerlich!
                                      Laut Copilot wurde die API bei neuen Accounts 'beschnitten'. Mein Account ist rund 8 Jahre alt und liefert (noch) die Places.
                                      Der Vorteil, du kannst die Orte identisch als eigene Orte anlegen. Für die Funktion des Adapters macht es keinen Unterschied.
                                      Ich selbst nutze mittlerweile im Adapter auch nur die eigenen Orte
                                      Ich habe die Doku angepasst:
                                      > **Life360-Orte nicht verfügbar?**
                                      > Life360 hat den Zugriff auf Cloud-Orte über die API für bestimmte Accounts eingeschränkt — insbesondere EU-Accounts im Free-Tier. Wenn im Adapter-Log `All place sources returned 0 places` erscheint, liefert Life360 die Orte über keinen API-Endpunkt mehr aus.
                                      > **Lösung:** Lege deine wichtigen Orte als **Meine Orte** in diesem Tab an. Sie funktionieren unabhängig von Life360 und bieten dieselbe Anwesenheitserkennung.
                                      #TeamInventwo
                                      Unsere Adapter:
                                      • skvarelS skvarel
                                        O Offline
                                        O Offline
                                        Olivbus
                                        #293
                                        @skvarel
                                        Ich bedanke mich für Deine tolle Arbeit.
                                        Mein Account ist von 2020.
                                        Die Places werden seltsamerweise bei people/locationName, wenn ich in den Ort betrete, angezeigt.
                                        Mit dem im Iobroker angelegten Place funktioniert der Adapter super.
                                        • O Olivbus
                                          @skvarel
                                          skvarelS Online
                                          skvarelS Online
                                          skvarel
                                          #294
                                          @Olivbus sagte:
                                          Das mache ich sehr gerne :)
                                          Das gebe ich nochmal dem Copiloten als Info!
                                          #TeamInventwo
                                          Unsere Adapter:
