  4. Test Adapter Life360 NextGeneration - Latest
life360mapstandortgeo locationinventwocursor ai
317 Beiträge 18 Kommentatoren 27.6k Aufrufe 18 Beobachtet
  • A Ahnungsbefreit
    @skvarel Wow, das ging ja schnell!
    Der Adapter stürzt jetzt nicht mehr ab, ich sehe aber jetzt folgende Warnung im Log:
    Unexpected circles response: "<!DOCTYPE html>\n<!--[if lt IE 7]> <html class=\"no-js ie6 oldie\" lang=\"en-US\"> <![endif]-->\n<!--[if IE 7]> <html class=\"no-js ie7 oldie\" lang=\"en-US\"> <![endif]-->\n<!--[if IE 8]> <html class=\"no-js ie8 oldie\" lang=\"en-US\"> <![endif]-->\n<!--[if gt IE 8]><!--> <html class=\"no-js\" lang=\"en-US\"> <!--<![endif]-->\n<head>\n<title>Attention Required! | Cloudflare</title>\n<meta charset=\"UTF-8\" />\n<meta http-equiv=\"Content-Type\" content=\"text/html; charset=UTF-8\" />\n<meta http-equiv=\"X-UA-Compatible\" content=\"IE=Edge\" />\n<meta name=\"robots\" content=\"noindex, nofollow\" />\n<meta name=\"viewport\" content=\"width=device-width,initial-scale=1\" />\n<link rel=\"stylesheet\" id=\"cf_styles-css\" href=\"/cdn-cgi/styles/cf.errors.css\" />\n<!--[if lt IE 9]><link rel=\"stylesheet\" id='cf_styles-ie-css' href=\"/cdn-cgi/styles/cf.errors.ie.css\" /><![endif]-->\n<style>body{margin:0;padding:0}</style>\n\n\n<!--[if gte IE 10]><!-->\n<script>\n if (!navigator.cookieEnabled) {\n window.addEventListener('DOMContentLoaded', function () {\n var cookieEl = document.getElementById('cookie-alert');\n cookieEl.style.display = 'block';\n })\n }\n</script>\n<!--<![endif]-->\n\n</head>\n<body>\n <div id=\"cf-wrapper\">\n <div class=\"cf-alert cf-alert-error cf-cookie-error\" id=\"cookie-alert\" data-translate=\"enable_cookies\">Please enable cookies.</div>\n <div id=\"cf-error-details\" class=\"cf-error-details-wrapper\">\n <div class=\"cf-wrapper cf-header cf-error-overview\">\n <h1 data-translate=\"block_headline\">Sorry, you have been blocked</h1>\n <h2 class=\"cf-subheadline\"><span data-translate=\"unable_to_access\">You are unable to access</span> life360.com</h2>\n </div><!-- /.header -->\n\n <div class=\"cf-section cf-highlight\">\n <div class=\"cf-wrapper\">\n <div class=\"cf-screenshot-container cf-screenshot-full\">\n \n <span class=\"cf-no-screenshot error\"></span>\n \n </div>\n </div>\n </div><!-- /.captcha-container -->\n\n <div class=\"cf-section cf-wrapper\">\n <div class=\"cf-columns two\">\n <div class=\"cf-column\">\n <h2 data-translate=\"blocked_why_headline\">Why have I been blocked?</h2>\n\n <p data-translate=\"blocked_why_detail\">This website is using a security service to protect itself from online attacks. The action you just performed triggered the security solution. There are several actions that could trigger this block including submitting a certain word or phrase, a SQL command or malformed data.</p>\n </div>\n\n <div class=\"cf-column\">\n <h2 data-translate=\"blocked_resolve_headline\">What can I do to resolve this?</h2>\n\n <p data-translate=\"blocked_resolve_detail\">You can email the site owner to let them know you were blocked. Please include what you were doing when this page came up and the Cloudflare Ray ID found at the bottom of this page.</p>\n </div>\n </div>\n </div><!-- /.section -->\n\n <div class=\"cf-error-footer cf-wrapper w-240 lg:w-full py-10 sm:py-4 sm:px-8 mx-auto text-center sm:text-left border-solid border-0 border-t border-gray-300\">\n <p class=\"text-13\">\n <span class=\"cf-footer-item sm:block sm:mb-1\">Cloudflare Ray ID: <strong class=\"font-semibold\">9fbadcdb1ff1d270</strong></span>\n <span class=\"cf-footer-separator sm:hidden\">&bull;</span>\n <span id=\"cf-footer-item-ip\" class=\"cf-footer-item hidden sm:block sm:mb-1\">\n Your IP:\n <button type=\"button\" id=\"cf-footer-ip-reveal\" class=\"cf-footer-ip-reveal-btn\">Click to reveal</button>\n <span class=\"hidden\" id=\"cf-footer-ip\">86.103.50.217</span>\n <span class=\"cf-footer-separator sm:hidden\">&bull;</span>\n </span>\n <span class=\"cf-footer-item sm:block sm:mb-1\"><span>Performance &amp; security by</span> <a rel=\"noopener noreferrer\" href=\"https://www.cloudflare.com/5xx-error-landing\" id=\"brand_link\" target=\"_blank\">Cloudflare</a></span>\n \n </p>\n <script>(function(){function d(){var b=a.getElementById(\"cf-footer-item-ip\"),c=a.getElementById(\"cf-footer-ip-reveal\");b&&\"classList\"in b&&(b.classList.remove(\"hidden\"),c.addEventListener(\"click\",function(){c.classList.add(\"hidden\");a.getElementById(\"cf-footer-ip\").classList.remove(\"hidden\")}))}var a=document;document.addEventListener&&a.addEventListener(\"DOMContentLoaded\",d)})();</script>\n </div><!-- /.error-footer -->\n\n </div><!-- /#cf-error-details -->\n </div><!-- /#cf-wrapper -->\n\n <script>\n window._cf_translation = {};\n \n \n </script>\n</body>\n</html>"
    skvarelS Offline
    skvarelS Offline
    skvarel
    #197
    @Ahnungsbefreit ...
    Das ist kein Adapter-Bug — Cloudflare hat die IP des Users gesperrt (403 vom Life360-Server). Der Adapter bekommt HTML statt JSON und loggt die komplette Seite roh, was verwirrend ist.
    Ich fange das ab .... moment bitte
    #TeamInventwo
    Unsere Adapter:
    • A Ahnungsbefreit
      skvarelS Offline
      skvarelS Offline
      skvarel
      schrieb am zuletzt editiert von skvarel
      #198
      @Ahnungsbefreit .. neue Version ist auf Github
      Wie gesagt, kein Bug bei mir!
      Du hast jetzt folgende Optionen:
      • Poll-Intervall erhöhen (z.B. auf 60+ Sekunden)
      • Warten — Cloudflare-Sperren heben sich oft nach einigen Stunden selbst auf
      • Prüfen, ob das Token noch gültig ist (ein abgelaufenes Token könnte Cloudflare triggern)
      EDIT:
      Hast du eventuell mit dem Token zu oft experimentiert? .. oder es lag an dem vorherigen Bug und der Adapter ist zu oft neu gestartet ?!
      #TeamInventwo
      Unsere Adapter:
      • skvarelS skvarel
        EDIT:
        A Online
        A Online
        Ahnungsbefreit
        #199
        @skvarel ok, der Fehler wird jetzt abgefangen und eindeutig im Log reported. Ich denke, das liegt an zu vielen Neustarts des Adapters durch den Bug. Ich probiere morgen oder später noch einmal.
        Vielen Dank für die superschnelle Reaktion!
        skvarelS 2 Antworten Letzte Antwort
        • A Ahnungsbefreit
          skvarelS Offline
          skvarelS Offline
          skvarel
          #200
          @Ahnungsbefreit .. gebe mir bitte eine Rückmeldung, ob es dann klappt.
          Sorry für meinen Fehler 😕
          #TeamInventwo
          Unsere Adapter:
          A 2 Antworten Letzte Antwort
          • A Ahnungsbefreit
            skvarelS Offline
            skvarelS Offline
            skvarel
            #201
            @Ahnungsbefreit .. Copilot sagt dazu folgendes:
            Ja, sehr wahrscheinlich. Die Kausalkette:
            • Meta-Bug → Adapter crasht bei jedem Start mit UNCAUGHT_EXCEPTION
            • ioBroker-Watchdog erkennt den Crash und startet den Adapter automatisch neu
            • Jeder Neustart → Adapter verbindet sich sofort mit der Life360 API (Token-Validierung + circles-Abruf)
            • Schnelle Wiederholungen in kurzer Zeit → Cloudflare erkennt das als Bot/Flood und sperrt die IP
            Das ist ein klassischer Crash-Loop: Der Adapter ist in Sekunden gecrashed, der Watchdog hat ihn sofort neu gestartet, und das hat sich beliebig oft wiederholt — jedes Mal ein neuer API-Call gegen api.life360.com.
            #TeamInventwo
            Unsere Adapter:
            • skvarelS skvarel
              A Online
              A Online
              Ahnungsbefreit
              #202
              @skvarel Rückmeldung folgt und das ist kein Grund, sich zu entschuldigen. Die einzige Chance, keine Fehler zu machen besteht dann, wenn man nichts tut 😀
              • skvarelS Offline
                skvarelS Offline
                skvarel
                #203
                LATEST Update
                Die 1.7.0 ist auf dem Weg 🚀
                Inkl. dem Fix vom dem Bug den @ahnungsbefreit gefunden hat!
                #TeamInventwo
                Unsere Adapter:
                • skvarelS Offline
                  skvarelS Offline
                  skvarel
                  #204
                  INFO
                  Da die 1.4.0 seit gestern im Stable ist, habe ich gerade alle Versionen checken lassen. Der von @ahnungsbefreit gemeldete Bug ist erst bei der Version 1.5.1 reingerutscht. Die aktuelle Stable ist demnach NICHT betroffen! Die nächste Stable wird die 1.7.0 werden. Da ist der Bug dann gefixed.
                  Alle die zwischen der 1.5.1 und der 1.7.0 unterwegs sind, empfehle ich ein Update auf die aktuelle Latest (1.7.0)
                  #TeamInventwo
                  Unsere Adapter:
                  • skvarelS skvarel
                    A Online
                    A Online
                    Ahnungsbefreit
                    schrieb am zuletzt editiert von Ahnungsbefreit
                    #205
                    @skvarel sagte:
                    Sorry für die späte Rückmeldung, ich war verhindert. Ich habe gestern abend mehrfach versucht, den Adapter neu zu starten in der Hoffnung, dass CloudFlare nicht mehr blockiert, leider vergebens.
                    Dann habe ich es heute (mit neuer IP Adresse) noch einmal versucht, gleicher Fehler.
                    Eben mit neuem Token probiert, immer noch der selbe Fehler.
                    Was kann ich jetzt tun?
                    Edit: Ich habe mal den Log Level bei ioBroker und in der Adapter Config aus DEBUG gestellt und bekomme folgenden (wenig erhellenden) Output:
                    life360ng.0
                    2026-05-15 14:21:55.200	debug	Life360 cloud data processed.
                    life360ng.0
                    2026-05-15 14:21:55.200	debug	Published 1 MyPlaces to ioBroker.
                    life360ng.0
                    2026-05-15 14:21:55.113	debug	Circle regex pattern: Haus FB
                    life360ng.0
                    2026-05-15 14:21:55.111	debug	Pushing cloud_data to callback function
                    life360ng.0
                    2026-05-15 14:21:54.583	debug	Fetching Life360 cloud data ...
                    life360ng.0
                    2026-05-15 14:20:54.672	debug	Life360 cloud data processed.
                    life360ng.0
                    2026-05-15 14:20:54.672	debug	Published 1 MyPlaces to ioBroker.
                    life360ng.0
                    2026-05-15 14:20:54.584	debug	Circle regex pattern: Haus FB
                    life360ng.0
                    2026-05-15 14:20:54.581	debug	Pushing cloud_data to callback function
                    life360ng.0
                    2026-05-15 14:20:54.078	debug	Polling Life360 circles ... try #2
                    life360ng.0
                    2026-05-15 14:20:54.077	warn	[circles] Life360 API blocked by Cloudflare (HTTP 403). Your server's IP may be rate-limited or flagged. Try increasing the poll interval or check your Life360 token.
                    life360ng.0
                    2026-05-15 14:20:54.029	info	Connected to Life360 cloud services.
                    life360ng.0
                    2026-05-15 14:20:54.029	info	Polling enabled every 60 seconds.
                    life360ng.0
                    2026-05-15 14:20:54.029	debug	Using configured Bearer token for Life360 authentication.
                    life360ng.0
                    2026-05-15 14:20:54.028	debug	Not authenticated against Life360. Will try to connect ...
                    life360ng.0
                    2026-05-15 14:20:54.028	debug	Fetching Life360 cloud data ...
                    life360ng.0
                    2026-05-15 14:20:54.028	info	[Tracker] No persons enabled
                    life360ng.0
                    2026-05-15 14:20:54.010	debug	[Tracker] Shared map files written
                    life360ng.0
                    2026-05-15 14:20:53.975	debug	[Tracker] Config loaded from states (enabled=true)
                    life360ng.0
                    2026-05-15 14:20:53.931	debug	[Tracker] Config state synced: tracker.config.enabled = true
                    life360ng.0
                    2026-05-15 14:20:53.810	debug	[Tracker] Web adapter: https://<host>:8082
                    life360ng.0
                    2026-05-15 14:20:53.790	info	starting. Version 1.6.0 (non-npm: inventwo/ioBroker.life360ng#8096ceaa6488e88d42086ff08264fa276a1eb504) in /opt/iobroker/node_modules/iobroker.life360ng, node: v20.20.2, js-controller: 7.0.7
                    Circles, Personen und Myplaces ist sichtbar in den Objekten, aber kein Trace
                    Thomas BraunT skvarelS 3 Antworten Letzte Antwort
                    • A Ahnungsbefreit
                      @skvarel sagte:
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      life360ng.0
                      #206
                      @Ahnungsbefreit
                      Bring das JETZT auf nodejs@22.
                      Dein nodejs20 ist abgekündigt.
                      • A Ahnungsbefreit
                        @skvarel sagte:
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        life360ng.0
                        skvarelS Offline
                        skvarelS Offline
                        skvarel
                        #207
                        @Ahnungsbefreit .. ich habe Copilot dazu gefragt:
                        Aus dem Log lassen sich ein paar Dinge ablesen:
                        Was auffällt:
                        Version: Der User läuft non-npm: inventwo/ioBroker.life360ng#8096ceaa — das ist der Commit direkt vor dem 1.7.0-Release-Tag. Also kein npm-Install, sondern eine GitHub-Installation. Die Versionsnummer im io-package.json zeigt noch 1.6.0.
                        Cloudflare 403 beim ersten Request — wird von Retry #2 abgefangen und danach läuft alles durch. Das ist ein bekanntes Startup-Phänomen, kein dauerhaftes Problem.
                        [Tracker] No persons enabled — der Tracker ist aktiviert (enabled=true), aber keine einzige Person ist in der Tracker-Tabelle eingetragen oder aktiviert. Das ist eine Fehlkonfiguration seitens des Users.
                        Danach läuft alles normal — Life360 cloud data processed, Published 1 MyPlaces, Polling alle 60 s. Der Adapter funktioniert.
                        Was fehlt im Log, um das eigentliche Problem zu diagnostizieren:
                        Der Log zeigt keinerlei Fehler nach dem Start. Ohne zu wissen, was der User als "Problem" beschreibt, ist es schwer zu sagen, was genau nicht funktioniert.
                        Mögliche nächste Fragen an den User:
                        Was konkret funktioniert nicht? (Zustände werden nicht aktualisiert? Tracker-Karte leer? Eine bestimmte Person taucht nicht auf?)
                        Hat er Personen im Tracker-Tab in der Config aktiviert?
                        Welche Version hat er installiert — npm oder GitHub-Branch?
                        #TeamInventwo
                        Unsere Adapter:
                        • skvarelS Offline
                          skvarelS Offline
                          skvarel
                          #208
                          @ahnungsbefreit .. wird die Instanz Grün oder was zeigt sie an?
                          EDIT:
                          Bitte die aktuelle npm/Latest Version instrallieren
                          #TeamInventwo
                          Unsere Adapter:
                          • A Ahnungsbefreit
                            @skvarel sagte:
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            life360ng.0
                            skvarelS Offline
                            skvarelS Offline
                            skvarel
                            #209
                            @Ahnungsbefreit .. Hast du denn den Tracker aktiviert?
                            EDIT:
                            Dein Log sagt nein ;)
                            [Tracker] Config loaded from states (enabled=true)   ← globale Kontrolle AN
                            [Tracker] No persons enabled                         ← aber keine Person in der Tabelle aktiv
                            #TeamInventwo
                            Unsere Adapter:
                            • skvarelS skvarel
                              EDIT:
                              A Online
                              A Online
                              Ahnungsbefreit
                              #210
                              @skvarel Asche über mein Haupt, den Haken bei "Aktiv" hatte ich übersehen. Ich habe jetzt neu von NPM installiert und den Haken gesetzt, jetzt funktioniert es. Am Anfang kommt immer noch die 403 Meldung aber dennoch scheint es zu funktionieren.
                              Vielen Dank!
                              @thomas-braun nodejs@22 wird jetzt in Angriff genommen, habe ich übersehen.
                              • A Ahnungsbefreit
                                Vielen Dank!
                                #211
                                @Ahnungsbefreit
                                Dann schau dir den Rest von Fest auch an. Meist ist da dann ja auch noch mehr 'abgesoffen'.
                                skvarelS 1 Antwort Letzte Antwort
                                  @Ahnungsbefreit
                                  skvarelS Offline
                                  skvarelS Offline
                                  skvarel
                                  #212
                                  @Thomas-Braun .. bekommst du eigentlich direkt eine Meldung, wenn irgendwo etwas mit falschen Versionen gepostet wird? Du bist immer so schön schnell zur Stelle :)
                                  #TeamInventwo
                                  Unsere Adapter:
                                  • skvarelS skvarel
                                    #213
                                    @skvarel
                                    Ich jag jedes Forumposting hier duch ein grep:
                                    curl forum.iobroker | grep nodejs 20 | notify thomas
                                    • skvarelS Offline
                                      skvarelS Offline
                                      skvarel
                                      #214
                                      ALPHA Update:
                                      Stillstand ist Rückschritt
                                      Mal gucken ob das so klappt
                                      #TeamInventwo
                                      Unsere Adapter:
                                      • Merlin123M Offline
                                        Merlin123M Offline
                                        Merlin123
                                        #215
                                        Klappt bestimmt.... Früher oder später ....
                                        Beta-Tester
                                        • Merlin123M Merlin123
                                          skvarelS Offline
                                          skvarelS Offline
                                          skvarel
                                          #216
                                          @Merlin123 mein treuer Alpha-Tester 🤙 👍 👏
                                          #TeamInventwo
                                          Unsere Adapter:
