  4. Anker Solix 2.0 Adapter (v2.4.1) – Keine Verbindung
    6.3k
17 Beiträge 7 Kommentatoren 569 Aufrufe 6 Beobachtet
  • T Takahara
    @Thomas-Braun
    Anbei das aktuelle ioB log:
    2026-03-26 17:36:51.932  - info: ankersolix2.0 (3767) starting. Version 2.4.1 in /opt/iobroker/node_modules/iobroker.ankersolix2, node: v22.22.1, js-controller: 7.0.7
    2026-03-26 17:36:51.942  - silly: influxdb.0 (1195) States user redis pmessage */system.adapter.ankersolix2.0.logLevel:{"val":"info","ack":true,"ts":1774543011941,"q":0,"from":"system.adapter.ankersolix2.0","lc":1774455494760}
    2026-03-26 17:36:51.942  - silly: influxdb.0 (1195) States user redis pmessage */system.adapter.ankersolix2.0.alive:{"val":true,"ack":true,"ts":1774543011941,"q":0,"from":"system.adapter.ankersolix2.0","lc":1774543011941,"expire":true}
    2026-03-26 17:36:51.943  - silly: influxdb.0 (1195) States user redis pmessage */system.adapter.ankersolix2.0.connected:{"val":true,"ack":true,"ts":1774543011941,"q":0,"from":"system.adapter.ankersolix2.0","lc":1774543011941,"expire":true}
    2026-03-26 17:36:51.943  - silly: influxdb.0 (1195) States user redis pmessage */system.adapter.ankersolix2.0.memRss:{"val":112.67,"ack":true,"ts":1774543011942,"q":0,"from":"system.adapter.ankersolix2.0","lc":1774543011942,"expire":true}
    2026-03-26 17:36:51.943  - silly: influxdb.0 (1195) States user redis pmessage */system.adapter.ankersolix2.0.memHeapTotal:{"val":60.06,"ack":true,"ts":1774543011942,"q":0,"from":"system.adapter.ankersolix2.0","lc":1774543011942,"expire":true}
    2026-03-26 17:36:51.944  - silly: influxdb.0 (1195) States user redis pmessage */system.adapter.ankersolix2.0.memHeapUsed:{"val":27.11,"ack":true,"ts":1774543011942,"q":0,"from":"system.adapter.ankersolix2.0","lc":1774543011942,"expire":true}
    2026-03-26 17:36:51.947  - silly: influxdb.0 (1195) States user redis pmessage */system.adapter.ankersolix2.0.uptime:{"val":1,"ack":true,"ts":1774543011947,"q":0,"from":"system.adapter.ankersolix2.0","lc":1774543011947,"expire":true}
    2026-03-26 17:36:51.948  - silly: influxdb.0 (1195) States user redis pmessage */system.adapter.ankersolix2.0.inputCount:{"val":0,"ack":true,"ts":1774543011947,"q":0,"from":"system.adapter.ankersolix2.0","lc":1774542679455,"expire":true}
    2026-03-26 17:36:51.948  - silly: influxdb.0 (1195) States user redis pmessage */system.adapter.ankersolix2.0.outputCount:{"val":9,"ack":true,"ts":1774543011947,"q":0,"from":"system.adapter.ankersolix2.0","lc":1774543011947,"expire":true}
    2026-03-26 17:36:51.949  - silly: influxdb.0 (1195) States user redis pmessage */system.adapter.ankersolix2.0.compactMode:{"val":false,"ack":true,"ts":1774543011947,"q":0,"from":"system.adapter.ankersolix2.0","lc":1774455494766}
    2026-03-26 17:36:51.953  - silly: influxdb.0 (1195) States user redis pmessage */system.adapter.ankersolix2.0.cpu:{"val":0,"ack":true,"ts":1774543011953,"q":0,"from":"system.adapter.ankersolix2.0","lc":1774542994473,"expire":true}
    2026-03-26 17:36:51.954  - silly: influxdb.0 (1195) States user redis pmessage */system.adapter.ankersolix2.0.cputime:{"val":0.86,"ack":true,"ts":1774543011953,"q":0,"from":"system.adapter.ankersolix2.0","lc":1774543011953,"expire":true}
    2026-03-26 17:36:52.130  - error: ankersolix2.0 (3767) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    2026-03-26 17:36:52.130  - error: ankersolix2.0 (3767) unhandled promise rejection: Cannot read properties of null (reading 'auth_token')
    2026-03-26 17:36:52.131  - error: ankersolix2.0 (3767) TypeError: Cannot read properties of null (reading 'auth_token')
        at SolixApi.withLogin (/opt/iobroker/node_modules/iobroker.ankersolix2/build/lib/api.js:66:37)
        at Ankersolix2.loginAPI (/opt/iobroker/node_modules/iobroker.ankersolix2/build/main.js:226:43)
        at async Ankersolix2.onReady (/opt/iobroker/node_modules/iobroker.ankersolix2/build/main.js:115:26)
    2026-03-26 17:36:52.131  - error: ankersolix2.0 (3767) Cannot read properties of null (reading 'auth_token')
    2026-03-26 17:36:52.132  - info: ankersolix2.0 (3767) terminating
    2026-03-26 17:36:52.133  - warn: ankersolix2.0 (3767) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2026-03-26 17:36:52.633  - info: ankersolix2.0 (3767) terminating
    2026-03-26 17:36:52.650  - silly: influxdb.0 (1195) States user redis pmessage */system.adapter.ankersolix2.0.alive:{"val":false,"ack":true,"ts":1774543012644,"q":0,"from":"system.host.iobroker","lc":1774543012644}
    2026-03-26 17:36:52.652  - error: host.iobroker instance system.adapter.ankersolix2.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2026-03-26 17:36:52.652  - info: host.iobroker Restart adapter system.adapter.ankersolix2.0 because enabled
    2026-03-26 17:36:52.694  - silly: influxdb.0 (1195) States user redis pmessage */system.adapter.ankersolix2.0.connected:{"val":false,"ack":true,"ts":1774543012693,"q":0,"from":"system.host.iobroker","lc":1774543012693}
    Vielleicht kannst du erkennen warum sich der Adapter nicht verbinden kann. Benutzer & Passwort sind aktuell und habe ich nochmals überprüft.
    Gruß Takahara
    @Takahara
    Zeig mal die Einstellungen in der Instanz.
      @Takahara
      Takahara
      @Thomas-Braun
        Takahara
        schrieb am zuletzt editiert von Takahara
        Hallo Community,
        hat denn niemand eine Idee, was ich hier falsch mache?
        Ich habe den Datenpunkt der API Connection einmal mitgeloggt. Dabei ist mir aufgefallen, dass sich der Adapter einmal täglich für etwa 48–50 Minuten mit dem Konto verbindet, Daten synchronisiert und auch sauber herunterlädt. Danach scheint die Verbindung aber wieder abzubrechen bzw. nicht mehr zu funktionieren.
        Ich kann mir aktuell nicht erklären, woran das liegen könnte – die Konfiguration scheint soweit korrekt zu sein.
        Hat jemand ein ähnliches Verhalten schon beobachtet oder eine Idee, wo ich ansetzen könnte?
        • I Offline
          I Offline
          igor123
          @takahara Hi, hast du hier eine Lösung gefunden? Hab das selbe Problem…
          • manuxiM Offline
            manuxiM Offline
            manuxi
            Eben installiert, habe das gleiche Problem. Würde mich sehr über einen Lösungsansatz freuen.
            • manuxiM Offline
              manuxiM Offline
              manuxi
              schrieb am zuletzt editiert von manuxi
              Kann es sein, dass einem der Adapter um die Ohren fliegt, wenn man keinen Akku angegeben hat? Ich bekomme die Panels erst nächste Woche, dachte, ich könnte bereits den Stromverbrauch abgreifen... leider nein :(
              Anyways, habe mal einen Akku hinzugefügt, Adapter neu gestartet, dann wieder auf 0 gesetzt. Jetzt habe ich eine Verbindung... Aber keine Werte...
              • manuxiM manuxi
                S Abwesend
                S Abwesend
                Shadowhunter23
                schrieb am zuletzt editiert von Shadowhunter23
                @manuxi sagte:
                Leg dir ein Mitglied Account an und logg dich damit ein. Sollte das funktionieren dann gehst du wieder zurück auf dein Haupt Account. Ich hatte das auch und wusste nicht was ich tun soll. Auf Frust habe ich den beschriebenen Vorgang gemacht und siehe da es läuft.
                Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                ioBroker Backup Analyzer
                • manuxiM Offline
                  manuxiM Offline
                  manuxi
                  Danke für Deine Antwort! Ich habe allerdings auch nach längerer Suche jetzt keinen blassen Schimmer, was ein "Mitglied Account" ist und wo ich den anlegen kann. Vielleicht bin ich auch zu schnell durch die Optionen oder zu blind... App v3.19.
                  • S Abwesend
                    S Abwesend
                    Shadowhunter23
                    Profil -> System verwalten
                    Und dort ein Mitglied einladen.
                    edit
                    Sorry ist wohl zu früh oder spät :(
                    Du musst den Account vorher anlegen. Also wie wenn du eine neue Anker anlegen möchtest. Diesen neuen Account kannst du dann einladen.
                    • C Offline
                      chemieka
                      schrieb am zuletzt editiert von chemieka
                      Gleiches Problem auch bei mir mit einer Solix 3. Ging bis heute früh. Adapter auch grün aber keine Aktuellen Daten mehr. Adapter gestoppt und wollte neustarten, jetzt geht er nicht mehr Online. Ich habe bereits einen Zweitaccount für IOBROKER angelegt und genutzt.
                      Bei GitHUB findet man einen Adapter für die Solix 3 direkt von Canufarm. Nachdem er installiert ist, kommt der Fehler das ein Captcha verlangt wird. Das kann der Adapter nicht leisten, bisher. Ich könnte mir vorstellen, das Problem könnte auch beim Adapter für die Solix 2 so sein (auch wenn der Adapter für die Solix 3 auch funktioniert)
                      Einen Log kann ich noch nicht bieten, würde später nachkommen.
                      Wundert mit das der Adapter von Canufarm hier nicht zu finden ist.
                      • S Abwesend
                        S Abwesend
                        Shadowhunter23
                        Bis jetzt läuft der Adapter bei mir ( Solix 3 ), ein Captcha wurde bei mir bisher nie gefordert.
                        • M Online
                          M Online
                          MatthiasUlrich
                          Hi Das Captcha wird gefordert wenn dein dein Authentification Cache File nicht existiert. Das wird beim ersten Start angelegt im Ordner iobroker-data/anker-solix.0/authcache/<your-email>.json
                          Wenn du das nicht hast wird es schwierig. Entweder hast du eine andere Installation diedieses File erzeugt hat, dann brauchst du dieses nur in den Ordner kopieren und es sollte wieder laufen.
