  4. Backitup Grafana Option sieht komisch aus
    6.4k
20 Beiträge 4 Kommentatoren 478 Aufrufe 3 Beobachtet
  • hotspot_2H hotspot_2
    Der Befehl hat nichts geholfen. Reboot habe ich auch noch gemacht.
    Hier mal der iob Diag. Ich konnte nichts erkennen.
    ```bash
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: iobroker
           Icon name: computer-container
             Chassis: container ☐
      Virtualization: lxc
              Kernel: Linux 6.17.13-4-pve
        Architecture: x86-64
    OS is similar to:
    model name      : Intel(R) Core(TM) i5-9400T CPU @ 1.80GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     17:12:55 up 20:39,  1 user,  load average: 0.59, 0.32, 0.29
    CPU threads: 2
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2026-04-26 17:12:55 CEST
               Universal time: Sun 2026-04-26 15:12:55 UTC
                     RTC time: n/a
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    marcus
    HOME=/home/marcus
    GROUPS=marcus sudo users iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/marcus
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            4.3G        2.8G        563M        2.8M        937M        1.5G
    Swap:           1.1G         51M        1.0G
    Total:          5.4G        2.8G        1.6G
    Active iob-Instances:   22
             4096 M total memory
             2667 M used memory
              898 M active memory
             2496 M inactive memory
              537 M free memory
                0 M buffer memory
              894 M swap cache
             1024 M total swap
               49 M used swap
              974 M free swap
    top - 17:12:56 up 20:39,  1 user,  load average: 0.54, 0.32, 0.29
    Tasks:  55 total,   1 running,  54 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  5.0 us,  0.0 sy,  0.0 ni, 95.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   4096.0 total,    536.3 free,   2667.8 used,    894.5 buff/cache
    MiB Swap:   1024.0 total,    974.4 free,     49.6 used.   1428.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type      Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4      246G  6.5G  227G   3% /
    none                             tmpfs     492K  4.0K  488K   1% /dev
    udev                             devtmpfs   16G     0   16G   0% /dev/fuse
    tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
    tmpfs                            tmpfs     6.3G  132K  6.3G   1% /run
    tmpfs                            tmpfs      16G  2.6M   16G   1% /tmp
    tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-networkd.service
    tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/console-getty.service
    tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/container-getty@2.service
    tmpfs                            tmpfs     1.0M     0  1.0M   0% /run/credentials/container-getty@1.service
    tmpfs                            tmpfs     3.2G  4.0K  3.2G   1% /run/user/1000
    [Sat Apr 25 14:27:29 2026] EXT4-fs (dm-1): orphan cleanup on readonly fs
    [Sat Apr 25 14:27:29 2026] EXT4-fs (dm-1): mounted filesystem f94d879d-03ef-44cc-ade8-039c52fd2a1e ro with ordered data mode. Quota mode: none.
    [Sat Apr 25 14:27:30 2026] EXT4-fs (dm-1): re-mounted f94d879d-03ef-44cc-ade8-039c52fd2a1e r/w.
    [Sat Apr 25 14:27:41 2026] EXT4-fs warning (device dm-6): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
    [Sat Apr 25 14:28:23 2026] EXT4-fs (dm-6): 1 orphan inode deleted
    [Sat Apr 25 14:28:23 2026] EXT4-fs (dm-6): recovery complete
    [Sat Apr 25 14:28:23 2026] EXT4-fs (dm-6): mounted filesystem 296045ff-9ce4-46cb-87ab-6443c1da9556 r/w with ordered data mode. Quota mode: none.
    [Sat Apr 25 15:25:05 2026] EXT4-fs (dm-7): mounted filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62 r/w with ordered data mode. Quota mode: none.
    [Sat Apr 25 15:25:08 2026] EXT4-fs (dm-7): unmounting filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62.
    [Sat Apr 25 15:26:23 2026] EXT4-fs (dm-7): mounted filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62 r/w with ordered data mode. Quota mode: none.
    [Sat Apr 25 15:27:57 2026] EXT4-fs (dm-7): unmounting filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62.
    [Sat Apr 25 15:28:02 2026] EXT4-fs (dm-7): mounted filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62 r/w with ordered data mode. Quota mode: none.
    [Sat Apr 25 15:28:30 2026] EXT4-fs (dm-7): unmounting filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62.
    [Sat Apr 25 15:30:09 2026] EXT4-fs (dm-7): mounted filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62 r/w with ordered data mode. Quota mode: none.
    [Sat Apr 25 16:07:34 2026] EXT4-fs (dm-7): unmounting filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62.
    [Sat Apr 25 16:08:15 2026] EXT4-fs (dm-7): mounted filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62 r/w with ordered data mode. Quota mode: none.
    [Sat Apr 25 16:15:51 2026] EXT4-fs (dm-7): unmounting filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62.
    [Sat Apr 25 16:15:53 2026] EXT4-fs (dm-7): mounted filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62 r/w with ordered data mode. Quota mode: none.
    [Sat Apr 25 16:22:35 2026] EXT4-fs (dm-7): unmounting filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62.
    [Sat Apr 25 16:22:36 2026] EXT4-fs (dm-7): mounted filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62 r/w with ordered data mode. Quota mode: none.
    [Sat Apr 25 16:57:56 2026] EXT4-fs (dm-7): unmounting filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62.
    [Sat Apr 25 16:58:45 2026] EXT4-fs (dm-7): orphan cleanup on readonly fs
    [Sat Apr 25 16:58:45 2026] EXT4-fs (dm-7): mounted filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62 ro with ordered data mode. Quota mode: none.
    [Sat Apr 25 16:58:46 2026] EXT4-fs (dm-8): mounted filesystem f1ccaa6b-8462-4fc4-9847-f91facaed85c r/w with ordered data mode. Quota mode: none.
    [Sat Apr 25 16:58:50 2026] EXT4-fs (dm-8): unmounting filesystem f1ccaa6b-8462-4fc4-9847-f91facaed85c.
    [Sat Apr 25 16:58:50 2026] EXT4-fs (dm-7): unmounting filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62.
    [Sat Apr 25 16:58:50 2026] EXT4-fs (dm-8): mounted filesystem f1ccaa6b-8462-4fc4-9847-f91facaed85c r/w with ordered data mode. Quota mode: none.
    [Sat Apr 25 16:58:51 2026] EXT4-fs (dm-8): unmounting filesystem f1ccaa6b-8462-4fc4-9847-f91facaed85c.
    [Sat Apr 25 17:00:32 2026] EXT4-fs (dm-8): mounted filesystem f1ccaa6b-8462-4fc4-9847-f91facaed85c r/w with ordered data mode. Quota mode: none.
    [Sat Apr 25 17:03:41 2026] EXT4-fs (dm-8): unmounting filesystem f1ccaa6b-8462-4fc4-9847-f91facaed85c.
    [Sat Apr 25 17:03:42 2026] EXT4-fs (dm-8): mounted filesystem f1ccaa6b-8462-4fc4-9847-f91facaed85c r/w with ordered data mode. Quota mode: none.
    [Sat Apr 25 17:06:24 2026] EXT4-fs (dm-7): mounted filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62 r/w with ordered data mode. Quota mode: none.
    [Sat Apr 25 17:09:48 2026] EXT4-fs (dm-7): unmounting filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62.
    [Sat Apr 25 17:09:49 2026] EXT4-fs (dm-7): mounted filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62 r/w with ordered data mode. Quota mode: none.
    [Sat Apr 25 17:59:47 2026] EXT4-fs (dm-7): unmounting filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62.
    [Sat Apr 25 17:59:48 2026] EXT4-fs (dm-7): mounted filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62 r/w with ordered data mode. Quota mode: none.
    [Sat Apr 25 18:26:17 2026] EXT4-fs (dm-7): unmounting filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62.
    [Sat Apr 25 18:26:18 2026] EXT4-fs (dm-7): mounted filesystem 2bd84c92-5767-4d12-a4c9-c9ce8cca5e62 r/w with ordered data mode. Quota mode: none.
    [Sat Apr 25 20:03:31 2026] EXT4-fs (dm-6): unmounting filesystem 296045ff-9ce4-46cb-87ab-6443c1da9556.
    [Sat Apr 25 20:03:32 2026] EXT4-fs (dm-6): mounted filesystem 296045ff-9ce4-46cb-87ab-6443c1da9556 r/w with ordered data mode. Quota mode: none.
    [Sat Apr 25 20:33:41 2026] EXT4-fs (dm-6): unmounting filesystem 296045ff-9ce4-46cb-87ab-6443c1da9556.
    [Sat Apr 25 20:33:41 2026] EXT4-fs (dm-6): mounted filesystem 296045ff-9ce4-46cb-87ab-6443c1da9556 r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE                           FSTYPE OPTIONS
    /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
    /var:
    682M    /var/
    314M    /var/cache
    310M    /var/cache/apt
    220M    /var/cache/apt/archives
    206M    /var/log
    Archived and active journals take up 8M in the file system.
    /opt/iobroker/backups:
    1.4G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    432M    /opt/iobroker/iobroker-data/
    184M    /opt/iobroker/iobroker-data/files
    111M    /opt/iobroker/iobroker-data/backup-objects
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    55M     /opt/iobroker/iobroker-data/objects.jsonl
    30M     /opt/iobroker/iobroker-data/states.jsonl
    19M     /opt/iobroker/iobroker-data/files/matter.admin/assets/index-DMt8RVCF.js
    8.2M    /opt/iobroker/iobroker-data/files/modbus.admin/assets/index-Blv_5nFZ.js
    7.5M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BeQV_TGa.js
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    No nvbackup.json found.
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.2
    /usr/bin/node           v22.22.2
    /usr/bin/npm            10.9.7
    /usr/bin/npx            10.9.7
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.2-1nodesource1
      Candidate: 22.22.2-1nodesource1
      Version table:
     *** 22.22.2-1nodesource1 1001
         22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u2 500
            500 http://security.debian.org trixie-security/main amd64 Packages
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.1.1, hostname: iobroker      , alive, uptime: 74345)
    Core adapters versions
    js-controller:  7.1.1
    admin:          7.8.20
    javascript:     9.2.0
    nodejs modules from github:     1
    +-- iobroker.jarvis@4.0.0-alpha.13 (git+ssh://git@github.com/Zefau/ioBroker.jarvis.git#56f23ff400d6411cd23a4cf9e61790dc38fb288c)
    Adapter State
    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.matter.0                 : matter                : iobroker                                 -  enabled
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled
    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.sma-em.0                 : sma-em                : iobroker                                 -  enabled
      system.adapter.solarwetter.0            : solarwetter           : iobroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: beta
    Adapter    "admin"        : 7.8.20   , installed 7.8.20
    Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
    Adapter    "backitup"     : 3.3.17   , installed 3.3.17
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "energiefluss-erweitert": 0.8.2, installed 0.8.2
    Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
    Adapter    "ical"         : 1.20.0   , installed 1.20.0
    Adapter    "iot"          : 6.0.3    , installed 6.0.3
    Adapter    "jarvis"       : 3.1.8    , installed 4.0.0-alpha.13
    Adapter    "javascript"   : 9.2.0    , installed 9.2.0
    Controller "js-controller": 7.1.1    , installed 7.1.1
    Adapter    "matter"       : 1.0.0    , installed 1.0.0
    Adapter    "modbus"       : 8.1.3    , installed 8.1.3
    Adapter    "node-red"     : 6.0.7    , installed 6.0.7
    Adapter    "ping"         : 2.1.0    , installed 2.1.0
    Adapter    "proxmox"      : 2.5.3    , installed 2.5.3
    Adapter    "pushover"     : 5.0.0    , installed 5.0.0
    Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
    Adapter    "sma-em"       : 1.3.1    , installed 1.3.1
    Adapter    "socketio"     : 7.1.3    , installed 7.1.3
    Adapter    "solarwetter"  : 1.2.0    , installed 1.2.0
    Adapter    "trashschedule": 5.3.0    , installed 5.3.0
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 8.1.0    , installed 8.1.0
    Adapter    "ws"           : 4.1.0    , installed 4.1.0
    Objects and States
    Objects:        5320
    States:         4392
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://deb.debian.org/debian trixie-updates InRelease
    Hit:3 http://security.debian.org trixie-security InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      105        3754260    8743/influxd
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1137943    288/master
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       1137320    470/node-red
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      104        1137708    131/mosquitto
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1138112    90/iobroker.js-cont
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1138812    90/iobroker.js-cont
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1135899    1/init
    tcp6       0      0 :::8400                 :::*                    LISTEN      1001       1141217    775/io.jarvis.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       1140368    808/io.simple-api.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      105        3754265    8743/influxd
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1138890    332/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       3825157    9164/io.web.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1137944    288/master
    tcp6       0      0 :::1883                 :::*                    LISTEN      104        1137709    131/mosquitto
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1135901    1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1133444    1/init
    udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1001       1140955    659/io.sma-em.0
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1135900    1/init
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1140278    791/io.matter.0
    udp        0      0 0.0.0.0:54747           0.0.0.0:*                           1001       1140281    791/io.matter.0
    udp6       0      0 :::43296                :::*                                1001       1140279    791/io.matter.0
    udp6       0      0 :::111                  :::*                                0          1135902    1/init
    udp6       0      0 :::5353                 :::*                                1001       1140280    791/io.matter.0
    2026-04-26 17:11:48.535  - info: host.iobroker "system.adapter.web.0" disabled
    2026-04-26 17:11:48.536  - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
    2026-04-26 17:11:48.540  - info: host.iobroker "system.adapter.web.0" enabled
    2026-04-26 17:11:48.540  - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
    2026-04-26 17:11:48.551  - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
    2026-04-26 17:11:48.597  - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
    2026-04-26 17:11:48.766  - info: web.0 (9146) Got terminate signal TERMINATE_YOURSELF
    2026-04-26 17:11:48.875  - info: web.0 (9146) starting. Version 8.1.0 in /opt/iobroker/node_modules/iobroker.web, node: v22.22.2, js-controller: 7.1.1
    2026-04-26 17:11:49.267  - info: web.0 (9146) terminating
    2026-04-26 17:11:49.268  - info: web.0 (9146) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-04-26 17:11:49.551  - info: host.iobroker stopInstance timeout system.adapter.web.0 killing pid 9146
    2026-04-26 17:11:49.572  - warn: host.iobroker instance system.adapter.web.0 terminated due to SIGKILL
    2026-04-26 17:11:49.573  - info: host.iobroker instance system.adapter.web.0 terminated with code null ()
    2026-04-26 17:11:50.558  - info: host.iobroker "system.adapter.web.0" disabled
    2026-04-26 17:11:50.561  - info: host.iobroker "system.adapter.web.0" enabled
    2026-04-26 17:11:50.860  - info: host.iobroker instance system.adapter.web.0 in version "8.1.0" started with pid 9164
    2026-04-26 17:11:52.094  - info: web.0 (9164) starting. Version 8.1.0 in /opt/iobroker/node_modules/iobroker.web, node: v22.22.2, js-controller: 7.1.1
    2026-04-26 17:11:52.181  - info: web.0 (9164) http server listening on port 8082
    2026-04-26 17:11:52.204  - info: web.0 (9164) socket.io server listening on port 8082
    2026-04-26 17:11:52.263  - info: web.0 (9164) Connecting extension "energiefluss-erweitert/lib/web.js"
    2026-04-26 17:11:52.264  - info: web.0 (9164) [energiefluss-erweitert.0] Sharp was found and can be used for image processing!
    2026-04-26 17:12:03.438  - info: admin.0 (332) ==> Connected system.user.admin from ::ffff:192.168.1.171
    2026-04-26 17:12:06.503  - info: admin.0 (332) <== Disconnect system.user.admin from ::ffff:192.168.1.171 backitup
    ============ Mark until here for C&P ============
    @hotspot_2 sagte:
    Dateisystem ist marode
      @hotspot_2 sagte:
      CPU threads: 2
      Gib der Kiste mal mehr Hubraum.
      Dein Dateisystem hat 'nen Schuß:
      hotspot_2H Offline
      hotspot_2H Offline
      hotspot_2
      @Thomas-Braun sagte:
      @hotspot_2 sagte:
      CPU threads: 2
      Mehr Hubraum also mehr CPUs zuweisen? 4 wäre passend?
      Was kann ich gegen das Problem im Dateisystem unternehmen?
        @hotspot_2 sagte:
        CPU threads: 2
        @hotspot_2 sagte:
        4 wäre passend?
        Der immer gerne als 'zu schwach' angesehene RaspberryPi 4 hat schon
        CPU threads: 4
        Nix, die Daten, die in dem gelöschten inode lagen konnten nicht mehr zugewiesen werden und sind daher gelöscht worden.
        • hotspot_2H Offline
          hotspot_2H Offline
          hotspot_2
          Dann weisse ich mal in Proxmox vier CPUs zu. Danke für den Tipp.
          Kann ich dann noch was tun um den BackitUP Adapter zum laufen zu bringen? Mir sind bisher noch keine weiteren Ausfälle aufgefallen am iobroker.
            @hotspot_2
            Wie schaut den ein 'Kaltstart' des Adapters im Log aus?
            Und versuch es mal mit der stabilen Version und nicht mit einer Beta.
              hotspot_2H Offline
              hotspot_2
              schrieb am zuletzt editiert von hotspot_2
              hier das Log.
              2026-04-26 18:02:54.605 - info: backitup.0 (1213) Got terminate signal TERMINATE_YOURSELF
              2026-04-26 18:02:54.606 - info: backitup.0 (1213) cleaned everything up...
              2026-04-26 18:02:54.606 - info: backitup.0 (1213) terminating
              2026-04-26 18:02:54.606 - info: backitup.0 (1213) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2026-04-26 18:02:54.646 - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
              2026-04-26 18:02:55.107 - info: backitup.0 (1213) terminating
              2026-04-26 18:02:55.108 - info: backitup.0 (1213) terminating
              2026-04-26 18:02:55.133 - info: host.iobroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2026-04-26 18:02:58.410 - info: host.iobroker instance system.adapter.backitup.0 in version "3.3.17" started with pid 1260
              2026-04-26 18:02:59.557 - info: backitup.0 (1260) starting. Version 3.3.17 in /opt/iobroker/node_modules/iobroker.backitup, node: v22.22.2, js-controller: 7.1.1
              2026-04-26 18:02:59.578 - info: backitup.0 (1260) [iobroker] backup will be activated at 9:00 every 1 day(s)
              Mit der Beta hast Du Recht, dachte mir ich frag trotzdem mal. Aber wir könn. es dann auch gerne lassen. Verstehe ich komplett.
                hier das Log.
                @hotspot_2
                Das testen auf Regressionen ist aber ja gerade Teil deines beta-testings. Daher musst du checken, ob die Beobachtung auch unter der stabilen Version nachzustellen ist. Und mit der Erkenntnis und einem Auszug aus dem Logfile kannst du dann bei GitHub ein Issue anlegen.
                hotspot_2H 1 Antwort Letzte Antwort
                • MartinPM Offline
                  MartinPM Offline
                  MartinP
                  @hotspot_2 sagte:
                  Ich würde gerne Grafana Backups (von einem separaten Server auf proxmox) mit Backitup machen.
                  Hmm - Wenn Grafana auf einem separaten Server läuft - wie soll Backitup an die zu sichernden Daten kommen?
                  • MartinPM MartinP
                    @hotspot_2 sagte:
                    @MartinP sagte:
                    Mit Pfad und token!??
                      @hotspot_2
                      hotspot_2H Offline
                      hotspot_2H Offline
                      hotspot_2
                      @hotspot_2
                      Ich verwende 3.3.17 das scheint gar keine Beta zu sein, oder? Ich habe jetzt mal ein Bug aufgemacht in Github. Ich kann sonst keine Ursache finden. Nach ein paar Checks scheint das Dateisystem grundsätzlich in Ordnung zu sein.
                        @hotspot_2
                        @hotspot_2 sagte:
                        Deswegen fehlen trotzdem irgendwo ein paar bytes.
                          @hotspot_2
                          @hotspot_2
                          Das ist aber sowas von eine Beta...
                          backitup
                          latest:	3.3.17 for 11 days
                          stable:	3.3.14 for 66 days
                          Latest = BETA.
                          Du turnst ja auch auf dem BETA-Repository herum:
                            hotspot_2H Offline
                            hotspot_2
                            Passt. Hab's auch gerade gemerkt. 3.3.14 ist die stable. Ich habe die Stable draufgemacht, dann war das Problem weg. Bin wieder auf 3.3.17 und jetzt funktioniert es auch da wieder. Geb ich mal in Github einfach so weiter.
                              @hotspot_2
                              Dann würde ich an deiner Stelle aber auch vom Beta-Repo absteigen und die stabilen Versionen verwenden.
                                @MartinP sagte:
                                MartinPM Offline
                                MartinPM Offline
                                MartinP
                                @Homoran sagte:
                                @MartinP sagte:
                                Er schrieb doch, dass Grafana auf einem anderen Server läuft..... Das hast Du geflissentlich beim Zitieren weggelassen...
                                Welches Protokoll unterstützt Backitup beim Remote Zugriff auf Daten von einem anderen Server?
                                • MartinPM MartinP
                                  @Homoran sagte:
                                  @MartinP sagte:
                                  @MartinP sagte:
                                  Ja und?
                                  Wie geht das denn mit Docker und Containern?
