  4. [gelöst] iob diag: Checking for nodejs vulnerability
    6.4k
14 Beiträge 3 Kommentatoren 374 Aufrufe 2 Beobachtet
  • RaspiUserR Online
    RaspiUserR Online
    RaspiUser
    schrieb am zuletzt editiert von RaspiUser
    ... in der Nacht gab es einen Stromausfall ... ;-((
    Der iobroker läuft (wieder) in einer VM auf einem QNAP NAS aber ... iob diag bringt diesen "Fehler":
    The current Node.js version (v22.22.0) is vulnerable to the following CVEs:
    CVE-2026-21637(high): A flaw in Node.js TLS error handling leaves `SNICallback` invocations unprotected against synchronous exceptions, while the equivalent ALPN and PSK callbacks were already addressed in CVE-2026-21637. This represents an incomplete fix of that prior vulnerability.
    When an `SNICallback` throws synchronously on unexpected input the exception bypasses TLS error handlers and propagates as an uncaught exception, crashing the Node.js process.
    * This vulnerability affects all Node.js versions that received the CVE-2026-21637 fix, including **20.x, 22.x, 24.x, and 25.x**, on any TLS server where `SNICallback` may throw on unexpected `servername` input.
    Patched versions: ^20.20.2 || ^22.22.2 || ^24.14.1 || ^25.8.2
    CVE-2026-21710(high): A flaw in Node.js HTTP request handling causes an uncaught `TypeError` when a request is received with a header named `__proto__` and the application accesses `req.headersDistinct`.
    When this occurs, `dest["__proto__"]` resolves to `Object.prototype` rather than `undefined`, causing `.push()` to be called on a non-array. This exception is thrown synchronously inside a property getter and cannot be intercepted by `error` event listeners, meaning it cannot be handled without wrapping every `req.headersDistinct` access in a `try/catch`.
    * This vulnerability affects all Node.js HTTP servers on **20.x, 22.x, 24.x, and v25.x**
    CVE-2026-21713(medium): A flaw in Node.js HMAC verification uses a non-constant-time comparison when validating user-provided signatures, potentially leaking timing information proportional to the number of matching bytes. Under certain threat models where high-resolution timing measurements are possible, this behavior could be exploited as a timing oracle to infer HMAC values.
    Node.js already provides timing-safe comparison primitives used elsewhere in the codebase, indicating this is an oversight rather than an intentional design decision.
    This vulnerability affects **20.x, 22.x, 24.x, and 25.x**.
    CVE-2026-21714(medium): A memory leak occurs in Node.js HTTP/2 servers when a client sends WINDOW_UPDATE frames on stream 0 (connection-level) that cause the flow control window to exceed the maximum value of 2³¹-1. The server correctly sends a GOAWAY frame, but the Http2Session object is never cleaned up.
    This vulnerability affects HTTP2 users on Node.js 20, 22, 24 and 25.
    CVE-2026-21715(low): A flaw in Node.js Permission Model filesystem enforcement leaves `fs.realpathSync.native()` without the required read permission checks, while all comparable filesystem functions correctly enforce them.
    As a result, code running under `--permission` with restricted `--allow-fs-read` can still use `fs.realpathSync.native()` to check file existence, resolve symlink targets, and enumerate filesystem paths outside of permitted directories.
    This vulnerability affects **20.x, 22.x, 24.x, and 25.x** processes using the Permission Model where `--allow-fs-read` is intentionally restricted.
    CVE-2026-21716(low): An incomplete fix for CVE-2024-36137 leaves `FileHandle.chmod()` and `FileHandle.chown()` in the promises API without the required permission checks, while their callback-based equivalents (`fs.fchmod()`, `fs.fchown()`) were correctly patched.
    As a result, code running under `--permission` with restricted `--allow-fs-write` can still use promise-based `FileHandle` methods to modify file permissions and ownership on already-open file descriptors, bypassing the intended write restrictions.
    This vulnerability affects **20.x, 22.x, 24.x, and 25.x** processes using the Permission Model where `--allow-fs-write` is intentionally restricted.
    CVE-2026-21717(medium): A flaw in V8's string hashing mechanism causes integer-like strings to be hashed to their numeric value, making hash collisions trivially predictable. By crafting a request that causes many such collisions in V8's internal string table, an attacker can significantly degrade performance of the Node.js process.
    The most common trigger is any endpoint that calls `JSON.parse()` on attacker-controlled input, as JSON parsing automatically internalizes short strings into the affected hash table.
    Alle anderen Prüfungen sind "grün" ... Was muss ich tun damit da wieder GOOD steht ?!
    Danke für die Hilfe.
    • RaspiUserR RaspiUser
      @RaspiUser sagte:
      Updaten!
      Auf
      @RaspiUser sagte:
        @RaspiUser sagte:
        Dein System auf den aktuellen Stand bringen.
        Sollte man eigentlich ohnehin machen, bevor man ein Forumsposting absetzt. Es ist oft so einfach.
        Edit: Der Punkt 'Pending Updates' war nämlich nicht grün, da muss mindestens 1 Update angezeigt worden sein.
        • RaspiUserR Online
          RaspiUserR Online
          RaspiUser
          @Thomas-Braun sagte:
          ... mache ich alle 2 Wochen: "iob stop, sudo apt update, sudo apt full-upgrade, reboot". Hat bisher immer gut funktioniert.
          ... ich habe jetzt "iob nodejs-update" ausgeführt und jetzt ist "iob diag" VERY GOOD ... Danke für eure Hilfe.
          Aber ... Verständnisfrage:
          konnte ich hier zuvor v22.22.0 mit einem Update-Kringel sehen. Den hatte ich geklickt und dann passierte (scheinbar) nix .... warum ?
          HomoranH Thomas BraunT 3 Antworten Letzte Antwort
            @RaspiUser sagte:
            Und da kam keine Error/warn Meldung?
            @RaspiUser sagte:
            Einfach so oder noch mit '22' dahinter?
            Letzteres hätte ich dir sonst geraten, um das vermutlich entgleiste nodesource Repo wieder in die Spur zu bringen
            RaspiUserR 1 Antwort Letzte Antwort
              @RaspiUser sagte:
              @RaspiUser sagte:
              RaspiUserR Online
              RaspiUserR Online
              RaspiUser
              @Homoran sagte:
              ... ich glaube mich an einige "Warnings" zu erinnern ... ;-(
              @Homoran sagte:
              Einfach so
              ja
              EDIT: Aber warum hat der "Update-Kringel" nicht funktioniert ?
                @Homoran sagte:
                @Homoran sagte:
                Einfach so
                ja
                @RaspiUser sagte:
                Das wird da
                @RaspiUser sagte:
                Gestanden haben
                • RaspiUserR Online
                  RaspiUserR Online
                  RaspiUser
                  OK ... das nächste Mal achte ich darauf ...
                    @RaspiUser sagte:
                    Solche Warnings kommen ja nicht ohne Grund.
                    Die soll man natürlich IMMER beachten!
                      @RaspiUser sagte:
                      Das ist nicht notwendig, wenn das nodesource-Repository richtig angelegt ist. Dann schwimmt auch ein Update von nodejs mit dem allgemeinen Systemupgrade-Zweisprung aus 'apt update && apt upgrade' mit.
                      Der 'iob nodejs-update'-Befehlt ist in erster Linie dazu gedacht das nodesource-Repository richtig anzulegen oder falsche Installationen zu reparieren. Dazu wird relativ agressiv vorgegangen. Mit 'apt' ist das ganze etwas sanfter.
                        @RaspiUser sagte:
                        wenn
                        Si!
                        Deswegen die Nachfrage nach den Warnings bei apt
                          @RaspiUser sagte:
                          Weil der Klick im Hintergrund auch nichts anderes tut als ein
                          apt upgrade nodejs
                          auszuführen. Leider wird da aber auch wirklich apt verwendet und nicht apt-get, was an der Stelle sinnvoller wäre, weil apt keine stabile Schnittstelle liefert und für das Handling in Skripten nicht geeignet ist. Ich muss mal suchen in welchem Adapter an welcher Stelle das programmiert worden ist und mach einen PR das wieder zurückzustellen.
                          • RaspiUserR Online
                            RaspiUserR Online
                            RaspiUser
                            ... interessant, aber für mich als einfachster User kann ich da nicht mit halten.
                            In meinem Alter lerne ich langsam aber vergesse schnell ...
                            Ich bin immer wieder froh wenn hier im Forum Wissende helfen (auch bei "einfachen" Problemen)
                            Nochmal Danke !!
                              Nochmal Danke !!
                              @RaspiUser sagte:
                              Aber lesen kannst du noch? 😉
                              Wenn du das Warning nicht verstehst, dann frag doch.
                              Dafür sind wir ja da.
                              Ignorieren ist keine Option.
