    6.4k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.4m Aufrufe 260 Beobachtet
  • MichaelFM MichaelF
    @TT-Tom sagte:
    @michaelf
    welche Adapterversion hast du? kannst du den Alias mal so anzeigen, wie ich es gemacht habe. Sprich die Rollen von den Datenpunkten und dem Channel.
    Müsste die Version v5.0.0
    let CardThermo2Test: PageType =
        type: 'cardThermo2',
        heading: 'Bad',
        thermoItems: [
            /* Center-Area of cardThermo2 */
            /* SET-Temp        */ { id: 'alias.0.NSPanel.Thermostat_Bad', minValue: 10.0, maxValue:30.0, stepValue: 0.5, unit: "°C" },
            /* Actual Temp     */ { id: 'alias.0.NSPanel.Thermostat_Bad.ACTUAL', icon: 'thermometer', onColor: Orange, unit: "°C" },
            /* Actual Humidity */ { id: 'alias.0.NSPanel.Thermostat_Bad.HUMIDITY', icon: 'water-percent', onColor: HMIOn, unit: "%" },
            /* Text State      */ { id: 'alias.0.NSPanel.Thermostat_Bad.MODE', onColor: Orange }
        items: [
            /* Max 9 Entities in cardThermo2 */
            { id: 'alias.0.NSPanel.AlexaBadLautstärke'},
            { id: 'alias.0.NSPanel.Dachfenster', name: 'Dachfenster', icon: 'window-open-variant', icon2: 'window-closed-variant', onColor: MSRed, offColor: MSGreen},
            { id: 'alias.0.NSPanel.Heizung', icon: 'heat-wave', offColor: MSRed, onColor: MSGreen, name: 'Heizung'},
            //{ navigate: true, id: null, targetPage: 'Abfall', onColor: White, name: 'Abfallkalender', icon: 'trash-can'},
            { id: 'alias.0.NSPanel.Heizung_Spiegel', icon: 'heat-pump-outline', offColor: MSRed, onColor: MSGreen, name: 'Speigelheizung'},
            { id: 'alias.0.NSPanel.Endstufe', icon: 'soundbar', offColor: MSRed, onColor: MSGreen, name: 'Endstufe'},
            { id: 'alias.0.NSPanel.Lüfter',name: 'Ventilator', icon: 'fan', onColor: On, offColor: HMIOff},
            //{ id: 'alias.0.NSPanel_1.TestTemperatur', name: 'Außentemperatur', offColor: White , onColor: White, useValue: true, suffixName: ' °C', fontSize: 1, colorScale: { 'val_min': -20, 'val_max': 40, 'val_best': 20 } },
            { id: 'alias.0.NSPanel.Fussbodenheizung', icon: 'heating-coil', offColor: MSRed, onColor: MSGreen, name: 'Fussbodenheizung'},
            { id: 'alias.0.NSPanel.Deckenbeleuchtung_Klein', icon: 'lightbulb', offColor: MSRed, onColor: MSGreen, name: 'Licht'},
            //{ id: 'delete'},
            //{ id: 'alias.0.NSPanel_EMU.TestKlimaVirtualModeList', icon: 'dots-horizontal-circle-outline', onColor: White, offColor: White, name: 'Betriebsmodus', modeList: ['Aus','Kühlen auf', 'Heizen auf']}
        alwaysOnDisplay: false
    TT-Tom
    #8017
    @MichaelF
    ach sorry das ist ja das Script, ich muss mal die umstellen. war beim Adapter und da gehts 😊
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
      @TT-Tom sagte:
      @michaelf
          heading: 'Bad',
          thermoItems: [
          items: [
              //{ id: 'delete'},
      TT-Tom
      #8018
      @MichaelF sagte:
      so habe jetzt das Script am laufen, Version 5.1.1.3 und TFT 61. Es funktioniert fast wie gewünscht. Der Datenpunkt Mute wird nicht genutzt, dafür wird der Volume auf "0" gesetzt. Die Icon ändern sich je nach Lautstarke.
      Gruß Tom
      Public Transport
      MichaelFM 1 Antwort Letzte Antwort
      • T TT-Tom
        @MichaelF sagte:
        MichaelFM Offline
        MichaelFM Offline
        MichaelF
        #8019
        @TT-Tom sagte:
        @MichaelF sagte:
        Danke für´s testen, reicht es wenn ich den unteren Teil vom Scrip aktualisiere. Oder vielleicht gleich doch auf den Adapter wechseln ?
        Grüße und Frohe Ostern.
        T T 2 Antworten Letzte Antwort
          @TT-Tom sagte:
          @MichaelF sagte:
          TT-Tom
          #8020
          @MichaelF
          du kannst den Adapter installieren und deine Seitenconfig nach und nach übernehmen. Es darf aber nur eins von beiden laufen. Beim Start musst du die MQTT und Paneleinstellungen vom Script übernehmen, damit das Script weiter funktioniert. Ich würde dir den Umstieg zum Adapter empfehlen. Wenn du Hilfe benötigst, kannst du im Wiki schon vieles nachlesen, ansonsten frage im Adapter Post nach.
          Gruß Tom
          Public Transport
            @TT-Tom sagte:
            @MichaelF sagte:
            ticaki
            #8021
            @MichaelF
            Adapter ist etwas anders - der Umzug braucht doch ein paar Anpassungen. Aber dann gehts imho einfacher - ich würde den adapter schon alleine wegen der symbolübersicht installieren :D
            Spenden
            • T ticaki
              @MichaelF
              TT-Tom
              #8022
              @ticaki @michaelf
              Dafür sind wir doch da, um bei der Migration zu helfen.
              Gruß Tom
              Public Transport
              • T TT-Tom
                @MichaelF
                MichaelFM Offline
                MichaelFM Offline
                MichaelF
                #8023
                @TT-Tom sagte:
                @MichaelF
                Danke, erst mal. Hab das Script auf die neuste Version gebracht seit dem geht eigentlich alles. Firmware vom Display wollte nicht, erst wie ich den Script ausgeschaltet habe ging es.
                Mit dem Umzug zum Adapter warte ich noch ein moment, hab 6 Displays glaub das wird dann ein wenig zeitaufwendiger. Ich denke beim Umzug kommen bestimmt einige Fragen:-). Danke nochmal und grüße.
                  @TT-Tom sagte:
                  @MichaelF
                  TT-Tom
                  #8024
                  @MichaelF sagte:
                  der Vorteil beim Adapter ist, das du Seiten die auf allen Panels gleich sind, nur einmal schreiben musst. Du musst auch nicht mit allen Panels gleichzeitig umziehen. Melde dich, wenn du den Schritt machen möchtest.
                  Gruß Tom
                  Public Transport
                  • T TT-Tom
                    @MichaelF sagte:
                    MichaelFM Offline
                    MichaelFM Offline
                    MichaelF
                    schrieb am zuletzt editiert von MichaelF
                    #8025
                    @TT-Tom sagte:
                    @MichaelF sagte:
                    Ein kleines Problem hab ich glaube ich noch, grade hat sich der Javadapter mit:
                    javascript.0
                    2026-04-06 11:19:40.044	warn	script.js.common.NsPanelWz: More than 75900 subscriptions registered. Check your script!
                    javascript.0
                    javascript.0
                    2026-04-06 11:19:40.043	warn	script.js.common.NsPanelWz: More than 75900 subscriptions registered. Check your script!
                    javascript.0
                    2026-04-06 11:19:40.035	warn	script.js.common.NsPanelWz: More than 75800 subscriptions registered. Check your script!
                    javascript.0
                    javascript.0
                    2026-04-06 11:19:40.034	warn	script.js.common.NsPanelWz: More than 75800 subscriptions registered. Check your script!
                    javascript.0
                    2026-04-06 11:19:40.026	warn	script.js.common.NsPanelWz: More than 75700 subscriptions registered. Check your script!
                    javascript.0
                    javascript.0
                    2026-04-06 11:19:40.025	warn	script.js.common.NsPanelWz: More than 75700 subscriptions registered. Check your script!
                    javascript.0
                    2026-04-06 11:19:40.016	warn	script.js.common.NsPanelWz: More than 75600 subscriptions registered. Check your script!
                    javascript.0
                    javascript.0
                    2026-04-06 11:19:40.015	warn	script.js.common.NsPanelWz: More than 75600 subscriptions registered. Check your script!
                    javascript.0
                    2026-04-06 11:19:40.005	warn	script.js.common.NsPanelWz: More than 75500 subscriptions registered. Check your script!
                    verabschiedet.
                    neu ist eigentlich nur der Abschnit:
                        heading: 'Bad',
                        thermoItems: [
                        items: [
                            { id: 'alias.0.NSPanel.TemperaturWassserSpeicher', name: 'TemperaturSpeicher', useValue: true, suffixName: '°C', fontSize: 1},
                            //{ id: 'delete'},
                    let Alexa: PageType =
                        'type': 'cardMedia',
                        'heading': 'Alexa',
                        'items': [{
                                    id: AliasPath + 'Media.PlayerAlexa',
                                    adapterPlayerInstance: 'alexa2.0.',
                                    mediaDevice: 'G0911ccccc820C1L', // Eigene Seriennummer des primären Device einstellen
                                    speakerList: ['Wohnung','Wohnraum'],
                                    //analog alexa2 Music-Provider
                                    //Mögliche Playlists:
                                    playList: ['Amazon-Music-Playlist.100',
                                               'Amazon-Music-Playlist.Onkelz',
                                               'Amazon-Music-Playlist.Punk',
                                               'Amazon-Music-Playlist.Poco',
                                               'Amazon-Music-Playlist.Rock',
                                               'Amazon-Music-Playlist.Party',
                                               'Amazon-Music-Playlist.Dance',
                                               'Amazon-Music-Playlist.Gut'],
                                    equalizerList: ['Bassboost','Klassik','Dance', 'Deep', 'Electronic', 'Flat', 'Hip-Hop', 'Rock',
                                                    'Metal', 'Jazz', 'Latin', 'Tonstärke', 'Lounge', 'Piano'],
                                    colorMediaIcon: colorAlexa,
                                    colorMediaArtist: Yellow,
                                    colorMediaTitle: Yellow,
                                    alwaysOnDisplay: true,
                                    autoCreateALias: true
                    Kann man hier vieleicht erkennen warum ?
                    Die US-Panels gehen ja beim Adapter auch?
                    • MichaelFM Offline
                      MichaelFM Offline
                      MichaelF
                      #8026
                      Ich habe es glaube ich grade gefunden, leider nur als Bild:
                      Es passiert wenn ich ein Knopf auf meinem Heizungspanel drücke.
                      javascript.0
                      2026-04-06 14:03:03.500	info	State value to set for "mqtt.3.cmnd.tasmota_A4ED44.CustomSend" has to be type "string" but received type "object"
                      javascript.0
                      2026-04-06 14:03:01.398	warn	script.js.common.NsPanelWz: More than 100 subscriptions registered. Check your script!
                      javascript.0
                      javascript.0
                      2026-04-06 14:03:01.397	warn	script.js.common.NsPanelWz: More than 100 subscriptions registered. Check your script!
                      javascript.0
                      2026-04-06 14:02:57.739	info	State value to set for "mqtt.3.cmnd.tasmota_A4ED44.CustomSend" has to be type "string" but received type "object"
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        javascript.0
                        TT-Tom
                        #8027
                        @MichaelF sagte:
                        kann dir grade nicht folgen: wo drückst du drauf?
                        in deinem Bild, kommt die Subscription Meldung vom Script/Javascript Adapter? oder von wem?
                        Gruß Tom
                        Public Transport
                        • MichaelFM Offline
                          MichaelFM Offline
                          MichaelF
                          #8028
                          Wenn ich einen von diesen Knöpfen drücke:
                          Führt er den "Knopf" aus, und danach kommt im Log :
                          javascript.0
                          Hier der Log aus der Tasmota Konsole, ich kann damit leider nicht so viel anfangen:
                          14:27:55.195 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:55.209 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:27:55.237 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:55.377 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:55.390 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:27:55.418 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:55.610 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:55.625 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:27:55.657 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:55.793 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:55.810 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:27:55.841 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:55.983 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:55.997 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:27:56.079 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:56.218 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:56.233 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:27:56.265 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:56.398 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:56.413 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:27:56.442 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:56.580 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:56.595 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:27:56.669 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:56.838 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:56.852 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:27:56.885 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:57.025 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:57.039 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:27:57.117 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:57.300 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:57.316 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:27:57.349 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:57.488 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:57.502 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:27:57.532 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:57.675 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:57.688 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:27:57.718 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:57.907 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:57.920 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:27:57.982 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:58.169 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:58.191 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:27:58.218 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:58.359 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:58.371 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:27:58.401 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:58.541 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:58.555 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:27:58.588 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:58.722 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:58.736 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:27:59.362 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:59.471 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:59.510 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:27:59.628 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:27.824 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:27.869 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:27.940 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:29.042 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:29.083 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:29.157 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:29.254 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:29.298 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:29.372 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:29.465 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:29.503 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:29.627 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:29.718 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:29.756 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:29.834 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:34.856 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,sleepReached,cardEntities"}
                          14:28:34.968 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:34.979 MQT: tele/tasmota_A4ED44/RESULT = {"CustomRecv":"event,renderCurrentPage"}
                          14:28:35.080 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:35.123 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:35.203 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:35.239 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                          14:28:35.319 MQT: stat/tasmota_A4ED44/RESULT = {"CustomSend":"Done"}
                            javascript.0
                            TT-Tom
                            #8029
                            @MichaelF sagte:
                            der Datenpunkt steht auf String, wie bei mir. Ich bekomme aber eine solche Meldung nicht. Eventuell ist beim Script kopieren etwas schief gelaufen.
                            nimm mal ein komplettes leeres Script und passe nur Punkt 1 (tasmota) und 2 (userPfad) an und starte dieses einmal.
                            @MichaelF sagte:
                            ich vermute mal eine falsche Einstellung in deiner MQTT Instanz. es werden 3 Topics abonniert und gepublisht
                            Gruß Tom
                            Public Transport
                            • R Offline
                              road_runner31
                              #8030
                              Hallo, ich hoffe, ich bin hier richtig.. ich habe heute mein NSPanel auf Tasmota (15.3.0 nspanel) geflasht und dann das Display (nach 2 Versuchen..) auf Lovelace. Nun wollte ich das Typescript zum Laufen bekommen, aber es geht schon damit los, dass mir unter dem sonoff-MQTT-Adapter diese Unterverzeichnisse TELE etc. nicht angelegt wurden, es gibt also kein RESULT-Objekt, nur ein CustomRecv.
                              Hat sich da was grundlegend geändert? Für Hilfe wäre ich echt dankbar..
                              • R road_runner31
                                TT-Tom
                                #8031
                                @road_runner31
                                hier geht es um dieses Projekt, wie im Wiki beschrieben https://github.com/joBr99/nspanel-lovelace-ui/wiki
                                hast du dich an die Instalationsroutine gehalten? https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---Basisinstallation#step-für-step---anleitung
                                Gruß Tom
                                Public Transport
                                R 1 Antwort Letzte Antwort
                                • T TT-Tom
                                  @MichaelF sagte:
                                  @MichaelF sagte:
                                  MichaelFM Offline
                                  MichaelFM Offline
                                  MichaelF
                                  #8032
                                  @TT-Tom sagte:
                                  @MichaelF sagte:
                                  @MichaelF sagte:
                                  Ich habe dies bei drei Panels, alle mit der Bad Heizung. Alle anderen Knöpfe auf anderen Seiten gehen ohne diese Meldung. Kann das wirklich am kopieren des Scrips liegen?
                                  Hier die Einstellungen meiner Java Instanz:
                                  Und hier die Seiten Config von einem Panel:
                                  //-- Anfang für eigene Seiten -- z.T. selbstdefinierte Aliase erforderlich ----------------
                                  //-- Start for your own pages -- some self-defined aliases required ----------------
                                      heading: 'Bad',
                                      thermoItems: [
                                      items: [
                                          //{ id: 'delete'},
                                  let Bad_1 = <PageEntities>
                                      'type': 'cardEntities',
                                      'heading': 'Bad',
                                      'useColor': true,
                                      'items': [
                                          <PageItem>{ id: 'alias.0.NSPanel.Deckenbeleuchtung_Gross', interpolateColor: true, name: 'Licht Gross'},
                                          <PageItem>{ id: 'alias.0.NSPanel.Deckenbeleuchtung_Klein', interpolateColor: true, name: 'Licht Klein'},
                                          <PageItem>{ id: 'alias.0.NSPanel.Lüfter', icon: 'power', offColor: MSRed, onColor: MSGreen, name: 'Lüfter'},
                                          <PageItem>{ id: 'alias.0.NSPanel.Endstufe', icon: 'power', offColor: MSRed, onColor: MSGreen, name: 'Endstufe'}
                                          //<PageItem>{ id: 'alias.0.NSPanel.Heizung_Spiegel', icon: 'power', offColor: MSRed, onColor: MSGreen, name: 'Spiegelheizung'}
                                  let Bad_2 = <PageEntities>
                                      'heading': 'Bad 2',
                                      'useColor': true,
                                      'items': [
                                          <PageItem>{ id: 'alias.0.NSPanel.Heizung_Spiegel', icon: 'power', offColor: MSRed, onColor: MSGreen, name: 'Speigelheizung'},
                                          <PageItem>{ id: 'alias.0.NSPanel.Dachfenster', onColor: White, name: 'Dach Kuppel'},
                                          <PageItem>{ id: 'alias.0.NSPanel.Heizung', icon: 'power', offColor: MSRed, onColor: MSGreen, name: 'Heizung'},
                                          <PageItem>{ id: 'alias.0.NSPanel.Fussbodenheizung', icon: 'power', offColor: MSRed, onColor: MSGreen, name: 'Fussbodenheizung'},
                                  let SensorGrid = <PageGrid>
                                      'type': 'cardGrid',
                                      'heading': 'Wetter',
                                      'useColor': true,
                                      'items': [
                                          <PageItem>{ id: 'alias.0.NSPanel.Aussentemperatur', name: 'Außentemp. °C', offColor: MSRed, onColor: MSGreen, useValue: true, colorScale: {'val_min': -20, 'val_max': 40, 'val_best': 20} },
                                          <PageItem>{ id: 'alias.0.NSPanel.Luftfeuchte', name: 'Luftfeuchte %', offColor: MSYellow, onColor: MSYellow , useValue: true, colorScale: {'val_min': 0, 'val_max': 100, 'val_best': 65} },
                                          <PageItem>{ id: 'alias.0.NSPanel.Taupunkt', name: 'Taupunkt °C', offColor: MSRed, onColor: MSGreen, useValue: true, colorScale: {'val_min': -20, 'val_max': 40, 'val_best': 20} },
                                          <PageItem>{ id: 'alias.0.NSPanel.UV_Index', name: 'UV Index', offColor: White , onColor: White, useValue: true, colorScale: {'val_min': 0, 'val_max': 12} },
                                          <PageItem>{ id: 'alias.0.NSPanel.Windgeschwindigkeit', name: 'Windstärke bft', offColor: White , onColor: White, useValue: true, colorScale: {'val_min': 0, 'val_max': 9} },
                                          <PageItem>{ id: 'alias.0.NSPanel.Luftdruck', name: 'Luftdruck hPa', offColor: White , onColor: White, useValue: true, colorScale: {'val_min': 950, 'val_max': 1050, 'val_best': 1013} },
                                  var Energie = <PagePower>
                                      "type": "cardPower",
                                      "heading": "cardPower Emulator",
                                      "useColor": true,
                                      "subPage": false,
                                      "parent": undefined,
                                      "items": [
                                  //        <PageItem>{  }, //Demomode
                                          <PageItem>{ id: "alias.0.NSPanel.PowerCard1" },
                                      'heading': 'Alexa',
                                      'items': [{
                                                  mediaDevice: 'G090Lcccccc209F3', // Eigene Seriennummer des primären Device einstellen
                                                  playList: ['Amazon-Music-Playlist.Papa',
                                                             'Amazon-Music-Playlist.Traditionshüter',
                                  //-- https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Page-%E2%80%90-Typen_How-2_Beispiele
                                  kann es was damit zu tun haben das ich die aliase öffter verwende.
                                  Hab den Java Adapter grade mal auf "alles" im Log gestellt:
                                  2026-04-06 17:46:14.605  - info: javascript.0 (10433) State value to set for "mqtt.3.cmnd.tasmota_A4ED44.CustomSend" has to be type "string" but received type "object"
                                  2026-04-06 17:46:14.608  - silly: javascript.0 (10433) States user redis pmessage */mqtt.3.cmnd.tasmota_A4ED44.CustomSend:{"val":{"ack":false},"ack":false,"ts":1775490374603,"q":0,"c":"script.js.common.NsPanelWz","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1775490374603}
                                  2026-04-06 17:46:14.590  - silly: javascript.0 (10433) States user redis pmessage */0_userdata.0.NSPanel.2.Event.Button.Action:{"val":"button","ack":true,"ts":1775490374585,"q":0,"c":"script.js.common.NsPanelWz","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1775490374585}
                                  2026-04-06 17:46:14.591  - silly: javascript.0 (10433) States user redis pmessage */0_userdata.0.NSPanel.2.Event.Button.Value:{"val":"","ack":true,"ts":1775490374585,"q":0,"c":"script.js.common.NsPanelWz","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1775490369889}
                                  2026-04-06 17:46:14.593  - silly: javascript.0 (10433) States user redis pmessage */0_userdata.0.NSPanel.2.Event.Button.Id:{"val":"alias.0.NSPanel.Heizung","ack":true,"ts":1775490374585,"q":0,"c":"script.js.common.NsPanelWz","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1775490374585}
                                  2026-04-06 17:46:13.738  - silly: javascript.0 (10433) States user redis pmessage */mqtt.3.stat.tasmota_A4ED44.LOGGING:{"val":"17:46:12.494 MQT: stat/tasmota_A4ED44/RESULT = {\"CustomSend\":\"Done\"}","ack":true,"ts":1775490373701,"q":0,"from":"system.adapter.mqtt.3","user":"system.user.admin","lc":1775490373701}
                                  2026-04-06 17:46:13.740  - silly: javascript.0 (10433) States user redis pmessage */mqtt.3.stat.tasmota_A4ED44.LOGGING:{"val":"17:46:12.550 MQT: stat/tasmota_A4ED44/RESULT = {\"CustomSend\":\"Done\"}","ack":true,"ts":1775490373701,"q":0,"from":"system.adapter.mqtt.3","user":"system.user.admin","lc":1775490373701}
                                  2026-04-06 17:46:13.742  - silly: javascript.0 (10433) States user redis pmessage */mqtt.3.stat.tasmota_A4ED44.LOGGING:{"val":"17:46:12.862 MQT: stat/tasmota_A4ED44/RESULT = {\"CustomSend\":\"Done\"}","ack":true,"ts":1775490373701,"q":0,"from":"system.adapter.mqtt.3","user":"system.user.admin","lc":1775490373701}
                                  2026-04-06 17:46:13.744  - silly: javascript.0 (10433) States user redis pmessage */mqtt.3.stat.tasmota_A4ED44.LOGGING:{"val":"17:46:12.877 MQT: tele/tasmota_A4ED44/RESULT = {\"CustomRecv\":\"event,renderCurrentPage\"}","ack":true,"ts":1775490373701,"q":0,"from":"system.adapter.mqtt.3","user":"system.user.admin","lc":1775490373701}
                                  2026-04-06 17:46:13.696  - silly: javascript.0 (10433) States user redis pmessage */mqtt.3.stat.tasmota_A4ED44.LOGGING:{"val":"17:46:12.339 MQT: tele/tasmota_A4ED44/RESULT = {\"CustomRecv\":\"event,buttonPress2,bPrev,button\"}","ack":true,"ts":1775490373601,"q":0,"from":"system.adapter.mqtt.3","user":"system.user.admin","lc":1775490373601}
                                    ticaki
                                    #8033
                                    Das d kommt vom Script. Da schreibt was ack: false ins val von einem State was Quatsch ist
                                    Spenden
                                    • T ticaki
                                      TT-Tom
                                      #8034
                                      @ticaki
                                      @michaelf
                                      Ich teste das morgen mal in der EMU, welche TFT Version hast du installiert? Ist doch ein US Panel, oder??
                                      Gruß Tom
                                      Public Transport
                                      • T TT-Tom
                                        @ticaki
                                        @michaelf
                                        MichaelFM Offline
                                        MichaelFM Offline
                                        MichaelF
                                        #8035
                                        @TT-Tom sagte:
                                        @ticaki
                                        @michaelf
                                        Die vom Script empfohlene, also die aktuelle.
                                        2 x us, 1 x eu machen alle das gleiche.
                                        Danke und Grüße
                                          @TT-Tom sagte:
                                          @ticaki
                                          @michaelf
                                          Danke und Grüße
                                          TT-Tom
                                          #8036
                                          @MichaelF
                                          ich kann deinen Fehler nicht nachstellen, weder in der US noch EU Version.
                                          Versuche mal mit einem leeren Script und nur der CardThremo als Page.
                                          Gruß Tom
                                          Public Transport
