backitup und influx: not found
@Alero sagte in backitup und influx: not found:
sorry das ihr es so schwer habt mit mir.
Lies dir die Grundfertigkeiten zur Navigation im Dateisystem und wie das mit den Rechten funktioniert an.
Macht den Umgang mit 'Linux' erheblich einfacher. -
ich habe aber immer noch eine FM beim erstellen des Backups:
10:38:11.523DEBUGgrafanastart Grafana backup compress ... 10:38:16.615DEBUGgrafanaBackup created: /opt/iobroker/backups/grafana_2026_03_27-10_38_11_backupiobroker.tar.gz 10:38:16.658DEBUGgrafanaTry deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp" 10:38:16.753DEBUGgrafanaGrafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted 10:38:16.755DEBUGgrafanadone 10:38:18.067DEBUGcifsused copy path: /backup/Iobroker/Standard 10:38:18.110DEBUGcifsdone [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.42.100","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=3.0","sudo":true,"cifsDomain":"","clientInodes":false,"cacheLoose":false,"deleteOldBackup":true,"ownDir":true,"dir":"/backup/Iobroker/Standard","dirMinimal":"/backup/Iobroker/Standard","user":"backup","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","timestamp":1774604269172,"influxDBEvents":[],"mySqlEvents":[],"pgSqlEvents":[],"deleteBackupAfter":0} 10:38:18.685ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors. 10:38:18.714DEBUGcleandone ´´´ -
es erscheint immer noch kein Backup von Influx unter backitup. bei iobrker und Grafana schon.
unter iobroker Benachrichtigungen erscheint folgende FM:
Ihr Backup wurde nicht vollständig erstellt. Bitte überprüfen Sie die Fehler!! influxDB: Error: Command failed: influx backup --bucket iobroker --host http://192.168.42.64:8086 -t dUdUCpI9hjy4ReSzeeh2n6_SpP0lMFN4sKSl-Ga0QGbMOnJOzVsNub1UWQnADKj-pcm1Gg80AJfiZg1zGXi6dA== "/opt/iobroker/backups/influxDB_2026_03_27-10_38_09_backupiobroker" unknown arguments: backup --bucket iobroker --host http://192.168.42.64:8086 -t dUdUCpI9hjy4ReSzeeh2n6_SpP0lMFN4sKSl-Ga0QGbMOnJOzVsNub1UWQnADKj-pcm1Gg80AJfiZg1zGXi6dA== /opt/iobroker/backups/influxDB_2026_03_27-10_38_09_backupiobroker ´´´ -
Da ich immer noch den Fehler habe , habe ich jetzt den Cleint noch einmal ausgeführt.
juergen@iobroker:~$ sudo apt install influxdb-client Installing: influxdb-client Summary: Upgrading: 0, Installing: 1, Removing: 0, Not Upgrading: 0 Download size: 2,434 kB Space needed: 7,418 kB / 88.6 GB available Get:1 http://deb.debian.org/debian trixie/main amd64 influxdb-client amd64 1.6.7~rc0-2+b12 [2,434 kB] Fetched 2,434 kB in 0s (11.8 MB/s) Selecting previously unselected package influxdb-client. (Reading database ... 51860 files and directories currently installed.) Preparing to unpack .../influxdb-client_1.6.7~rc0-2+b12_amd64.deb ... Unpacking influxdb-client (1.6.7~rc0-2+b12) ... Setting up influxdb-client (1.6.7~rc0-2+b12) ... Processing triggers for man-db (2.13.1-1) ... ´´´Du musst den passenden Client installieren.
Du ziehst da deninfluxdb-client (1.6.7~rc0-2+b12)ran, das passt aber nicht zu der (vermutlich) verwendeten influxdb2.sudo apt update apt policy influxdb2*sagt?
juergen@iobroker:~$ sudo apt update Hit:1 http://security.debian.org/debian-security trixie-security InRelease Hit:2 http://deb.debian.org/debian trixie InRelease Hit:3 http://deb.debian.org/debian trixie-updates InRelease Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease Get:5 https://repos.influxdata.com/debian stable InRelease [6,922 B] Fetched 6,922 B in 0s (29.2 kB/s) All packages are up to date. juergen@iobroker:~$ apt policy influxdc2* Notice: Unable to locate package influxdc2* Notice: Couldn't find any package by glob 'influxdc2*' juergen@iobroker:~$ ´´´ -
verstehe ich nicht ich habe doch den client installiert
Aber in einer inkomaptiblen alten Version.
apt policy influxdb2* -
haha,
juergen@iobroker:~$ apt policy influxdb2* influxdb2-cli: Installed: (none) Candidate: 2.7.5-3 Version table: 2.7.5-3 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.5-2 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.5-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.3-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.1-2 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.6.1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.6.0 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.5.0 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.4.0 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.3.0 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages influxdb2-client: Installed: (none) Candidate: 2.7.1-1 Version table: 2.7.1-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages influxdb2: Installed: (none) Candidate: 2.8.0-1 Version table: 2.8.0-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.12-3 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.12-2 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.12-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.11-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.10-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.9-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.8-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.7-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.6-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.5-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.4-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.3-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.1-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages ´´´ -
was muss ich tun?
c ist nicht b!!
haha,
juergen@iobroker:~$ apt policy influxdb2* influxdb2-cli: Installed: (none) Candidate: 2.7.5-3 Version table: 2.7.5-3 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.5-2 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.5-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.3-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.1-2 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.6.1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.6.0 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.5.0 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.4.0 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.3.0 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages influxdb2-client: Installed: (none) Candidate: 2.7.1-1 Version table: 2.7.1-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages influxdb2: Installed: (none) Candidate: 2.8.0-1 Version table: 2.8.0-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.12-3 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.12-2 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.12-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.11-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.10-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.9-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.8-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.7-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.6-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.5-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.4-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.3-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages 2.7.1-1 500 500 https://repos.influxdata.com/debian stable/main amd64 Packages ´´´@Alero sagte in backitup und influx: not found:
influxdb2-cli
Das gesuchte Paket heißt also
influxdb2-cli
Installieren:sudo apt remove influxdb-client sudo apt install influxdb2-cli -
influxdb2-cli
influxdb2-cli
Installieren:sudo apt remove influxdb-client sudo apt install influxdb2-clisagte in backitup und influx: not found:
influxdb2-cli
influxdb2-cli
Installieren:sudo apt remove influxdb-client sudo apt install influxdb2-cliHabe ich gemaacht:
juergen@iobroker:~$ sudo apt remove influxdb-client sudo apt install influxdb2-cli REMOVING: influxdb-client Summary: Upgrading: 0, Installing: 0, Removing: 1, Not Upgrading: 0 Freed space: 7,418 kB Continue? [Y/n] y (Reading database ... 51867 files and directories currently installed.) Removing influxdb-client (1.6.7~rc0-2+b12) ... Processing triggers for man-db (2.13.1-1) ... Installing: influxdb2-cli Installing dependencies: influxdata-archive-keyring Summary: Upgrading: 0, Installing: 2, Removing: 0, Not Upgrading: 0 Download size: 11.7 MB Space needed: 25.6 MB / 88.6 GB available Continue? [Y/n] y Get:1 https://repos.influxdata.com/debian stable/main amd64 influxdata-archive-keyring all 2026.01.09 [10.7 kB] Get:2 https://repos.influxdata.com/debian stable/main amd64 influxdb2-cli amd64 2.7.5-3 [11.7 MB] Fetched 11.7 MB in 1s (18.6 MB/s) Selecting previously unselected package influxdata-archive-keyring. (Reading database ... 51860 files and directories currently installed.) Preparing to unpack .../influxdata-archive-keyring_2026.01.09_all.deb ... Unpacking influxdata-archive-keyring (2026.01.09) ... Selecting previously unselected package influxdb2-cli. Preparing to unpack .../influxdb2-cli_2.7.5-3_amd64.deb ... Unpacking influxdb2-cli (2.7.5-3) ... Setting up influxdata-archive-keyring (2026.01.09) ... Setting up influxdb2-cli (2.7.5-3) ... juergen@iobroker:~$ ´´´
