  4. Error beim Zigbee Adapter nach Kanalwechsel
    6.8k
19 Beiträge 4 Kommentatoren 810 Aufrufe 3 Beobachtet
    Dragon
    ```bash
    Script v.2026-01-31
    *** BASE SYSTEM ***
    Operating System: Debian GNU/Linux 13 (trixie)
     Static hostname: ioBroker
           Icon name: computer-vm
             Chassis: vm 🖴
        AF_VSOCK CID: 1
      Virtualization: kvm
              Kernel: Linux 6.12.74+deb13+1-amd64
        Architecture: x86-64
     Hardware Vendor: QEMU
      Hardware Model: Standard PC _i440FX + PIIX, 1996_
    Firmware Version: rel-1.17.0-0-gb52ca86e094d-prebuilt.qemu.org
       Firmware Date: Tue 2014-04-01
        Firmware Age: 11y 11month 2w 4d
    OS is similar to:
    model name      : Common KVM processor
    Docker          : false
    Virtualization  : kvm
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     21:12:32 up 7 min,  1 user,  load average: 3.93, 3.12, 1.48
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'trixie'!
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2026-03-19 21:12:32 CET
               Universal time: Thu 2026-03-19 20:12:32 UTC
                     RTC time: Thu 2026-03-19 20:12:32
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    brokeradmin
    HOME=/home/brokeradmin
    GROUPS=brokeradmin adm dialout sudo audio video plugdev users iobroker
    iobroker
    HOME=/home/iobroker
    SUDO_HOME=/home/brokeradmin
    GROUPS=iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:             10G        5.9G        3.3G        5.8M        1.6G        4.5G
    Swap:           2.1G          0B        2.1G
    Total:           12G        5.9G        5.4G
    Active iob-Instances:   73
             9951 M total memory
             5613 M used memory
             5257 M active memory
             1170 M inactive memory
             3118 M free memory
              127 M buffer memory
             1367 M swap cache
             2047 M total swap
                0 M used swap
             2047 M free swap
    top - 21:12:32 up 7 min,  1 user,  load average: 3.93, 3.12, 1.48
    Tasks: 179 total,   7 running, 172 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 61.9 us,  9.5 sy,  0.0 ni, 28.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   9951.8 total,   3118.5 free,   5612.9 used,   1495.1 buff/cache
    MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   4338.9 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  4.9G     0  4.9G   0% /dev
    tmpfs          tmpfs     996M  548K  995M   1% /run
    /dev/sda1      ext4       54G   32G   21G  61% /
    tmpfs          tmpfs     4.9G     0  4.9G   0% /dev/shm
    tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
    tmpfs          tmpfs     4.9G  5.0M  4.9G   1% /tmp
    tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
    tmpfs          tmpfs     996M  8.0K  996M   1% /run/user/1002
    [Thu Mar 19 21:05:45 2026] EXT4-fs (sda1): mounted filesystem a6df39e5-8210-4c92-b9c8-b4b557b9e693 ro with ordered data mode. Quota mode: none.
    [Thu Mar 19 21:05:46 2026] EXT4-fs (sda1): re-mounted a6df39e5-8210-4c92-b9c8-b4b557b9e693 r/w.
    Show mounted filesystems:
    TARGET SOURCE    FSTYPE OPTIONS
    /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
    /var:
    1.4G    /var/
    994M    /var/log
    971M    /var/log/journal/58d2cc2a97184623922200d7fac194bf
    206M    /var/cache
    Archived and active journals take up 970.2M in the file system.
    /opt/iobroker/backups:
    11G     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    2.6G    /opt/iobroker/iobroker-data/
    1.3G    /opt/iobroker/iobroker-data/files
    757M    /opt/iobroker/iobroker-data/history
    309M    /opt/iobroker/iobroker-data/backup-objects
    253M    /opt/iobroker/iobroker-data/files/vis
    52M     /opt/iobroker/iobroker-data/objects.jsonl
    46M     /opt/iobroker/iobroker-data/states.jsonl
    32M     /opt/iobroker/iobroker-data/files/mytime.admin/custom/assets/index-B_3WOu59.js.map
    30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
    please always prefer the links 'by-id':
    No Devices found 'by-id'
    *** ZigBee Settings ***
    ⚠ HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'.
    Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.22.1
    /usr/bin/node           v22.22.1
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    ✓ Node.js installation is correct
    nodejs:
      Installed: 22.22.1-1nodesource1
      Candidate: 22.22.1-1nodesource1
      Version table:
     *** 22.22.1-1nodesource1 1001
         22.22.0-1nodesource1 1001
         22.21.0-1nodesource1 1001
         22.20.0-1nodesource1 1001
         22.19.0-1nodesource1 1001
         22.18.0-1nodesource1 1001
         22.17.1-1nodesource1 1001
         22.17.0-1nodesource1 1001
         22.16.0-1nodesource1 1001
         22.15.1-1nodesource1 1001
         22.15.0-1nodesource1 1001
         22.14.0-1nodesource1 1001
         22.13.1-1nodesource1 1001
         22.13.0-1nodesource1 1001
         22.12.0-1nodesource1 1001
         22.11.0-1nodesource1 1001
         22.10.0-1nodesource1 1001
         22.9.0-1nodesource1 1001
         22.8.0-1nodesource1 1001
         22.7.0-1nodesource1 1001
         22.6.0-1nodesource1 1001
         22.5.1-1nodesource1 1001
         22.5.0-1nodesource1 1001
         22.4.1-1nodesource1 1001
         22.4.0-1nodesource1 1001
         22.3.0-1nodesource1 1001
         22.2.0-1nodesource1 1001
         22.1.0-1nodesource1 1001
         22.0.0-1nodesource1 1001
         20.19.2+dfsg-1+deb13u1 500
            500 http://security.debian.org/debian-security trixie-security/main amd64 Packages
         20.19.2+dfsg-1 500
            500 http://deb.debian.org/debian trixie/main amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 414)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.22
    javascript:     9.0.18
    nodejs modules from github:     8
    +-- iobroker.apsystemsez1@0.0.7 (git+ssh://git@github.com/hefegraphie/ioBroker.apsystemsez1.git#0e771c9d92c4bb4e662b09022820f2aa48358c50)
    +-- iobroker.brightsky@1.0.0-beta.1 (git+ssh://git@github.com/ticaki/ioBroker.brightsky.git#2e3b60d2f06be529ef9f9b523a8815e43e452eea)
    +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
    +-- iobroker.nebenkosten-monitor@1.2.2 (git+ssh://git@github.com/fischi87/ioBroker.nebenkosten-monitor.git#6bcdd0aaa88e00bc9c29a312073050c5e5353b0a)
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    +-- iobroker.unifi-network@1.3.1 (git+ssh://git@github.com/Scrounger/ioBroker.unifi-network.git#334428eaab151812f80637c435a12083ffb43e51)
    +-- iobroker.utility-monitor@1.5.0 (git+ssh://git@github.com/fischi87/ioBroker.utility-monitor.git#64de59c8aaa26c92f3fcacac80c123bcc2bc9b16)
    +-- iobroker.vis-fancyswitch@1.1.0 (git+ssh://git@github.com/ioBroker/ioBroker.vis-fancyswitch.git#62fe89a9bf646392c6a53e7f91744352409135ae)
    Adapter State
    + system.adapter.adguard.0                : adguard               : ioBroker                                 -  enabled
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.apsystemsez1.0           : apsystemsez1          : ioBroker                                 -  enabled
    + system.adapter.awtrix-light.0           : awtrix-light          : ioBroker                                 -  enabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.bambulab.0               : bambulab              : ioBroker                                 -  enabled, port: 8883
    + system.adapter.brightsky.0              : brightsky             : ioBroker                                 -  enabled
    + system.adapter.broadlink2.0             : broadlink2            : ioBroker                                 -  enabled
      system.adapter.chromecast.0             : chromecast            : ioBroker                                 - disabled
    + system.adapter.cloud.0                  : cloud                 : ioBroker                                 -  enabled
    + system.adapter.countdown.0              : countdown             : ioBroker                                 -  enabled
    + system.adapter.device-reminder.0        : device-reminder       : ioBroker                                 -  enabled
    + system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 -  enabled
      system.adapter.devices.0                : devices               : ioBroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
    + system.adapter.echarts.0                : echarts               : ioBroker                                 -  enabled
    + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : ioBroker                                 -  enabled
    + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : ioBroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
    + system.adapter.fritzdect.0              : fritzdect             : ioBroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
    + system.adapter.ham.0                    : ham                   : ioBroker                                 -  enabled
    + system.adapter.history.0                : history               : ioBroker                                 -  enabled
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.3                   : ical                  : ioBroker                                 -  enabled
      system.adapter.iceroad.0                : iceroad               : ioBroker                                 -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
      system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: ioBroker                                 -  enabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
      system.adapter.icons-freepic.0          : icons-freepic         : ioBroker                                 -  enabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 - disabled
      system.adapter.icons-smarthome.0        : icons-smarthome       : ioBroker                                 -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
    + system.adapter.imap.0                   : imap                  : ioBroker                                 -  enabled
    + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
      system.adapter.logparser.0              : logparser             : ioBroker                                 - disabled
    + system.adapter.matter.0                 : matter                : ioBroker                                 -  enabled
    + system.adapter.meross.0                 : meross                : ioBroker                                 -  enabled
    + system.adapter.meross.1                 : meross                : ioBroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1890, bind: 192.168.178.3
    + system.adapter.mytime.0                 : mytime                : ioBroker                                 -  enabled
    + system.adapter.nebenkosten-monitor.0    : nebenkosten-monitor   : ioBroker                                 -  enabled
    + system.adapter.net-tools.0              : net-tools             : ioBroker                                 -  enabled
    + system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
    + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
    + system.adapter.notificationforandroidtv.0: notificationforandroidtv: ioBroker                                 -  enabled
    + system.adapter.nuki-extended.0          : nuki-extended         : ioBroker                                 -  enabled
    + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
      system.adapter.onvif.0                  : onvif                 : ioBroker                                 - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
      system.adapter.openmediavault.0         : openmediavault        : ioBroker                                 - disabled
      system.adapter.openweathermap.0         : openweathermap        : ioBroker                                 -  enabled
    + system.adapter.philips-tv.0             : philips-tv            : ioBroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
      system.adapter.rickshaw.0               : rickshaw              : ioBroker                                 - disabled
    + system.adapter.ring.0                   : ring                  : ioBroker                                 -  enabled
      system.adapter.samsung.0                : samsung               : ioBroker                                 - disabled
      system.adapter.sayit.0                  : sayit                 : ioBroker                                 - disabled
      system.adapter.schoolfree.0             : schoolfree            : ioBroker                                 -  enabled
      system.adapter.schoolfree.1             : schoolfree            : ioBroker                                 -  enabled
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1885, bind: 192.168.178.3
    + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
    + system.adapter.signal-cmb.0             : signal-cmb            : ioBroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : ioBroker                                 -  enabled, port: 1883, bind: 192.168.178.3
      system.adapter.tankerkoenig.0           : tankerkoenig          : ioBroker                                 - disabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.2               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.3               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.4               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.5               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : ioBroker                                 -  enabled
    + system.adapter.text2command.1           : text2command          : ioBroker                                 -  enabled
    + system.adapter.text2command.2           : text2command          : ioBroker                                 -  enabled
    + system.adapter.tr-064.0                 : tr-064                : ioBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
    + system.adapter.tuya.0                   : tuya                  : ioBroker                                 -  enabled
    + system.adapter.unifi-network.0          : unifi-network         : ioBroker                                 -  enabled, port: 8443
      system.adapter.unifi.0                  : unifi                 : ioBroker                                 - disabled
    + system.adapter.upnp.0                   : upnp                  : ioBroker                                 -  enabled
    + system.adapter.utility-monitor.0        : utility-monitor       : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: ioBroker                                 -  enabled
      system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: ioBroker                                 -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : ioBroker                                 - disabled
      system.adapter.vis-lcars.0              : vis-lcars             : ioBroker                                 - disabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : ioBroker                                 - disabled
      system.adapter.vis-material-webfont.0   : vis-material-webfont  : ioBroker                                 - disabled
      system.adapter.vis-material.0           : vis-material          : ioBroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
    + system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
    + system.adapter.weather-warnings.0       : weather-warnings      : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.windows-control.0        : windows-control       : ioBroker                                 -  enabled
    + system.adapter.wireguard.0              : wireguard             : ioBroker                                 -  enabled
    + system.adapter.wled.0                   : wled                  : ioBroker                                 -  enabled
    + system.adapter.ws.0                     : ws                    : ioBroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : ioBroker                                 -  enabled, port: tcp://192.168.178.222:6638
    + instance is alive
    ioBroker-Repositories
    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "adguard"      : 1.1.1    , installed 1.1.1
    Adapter    "admin"        : 7.7.22   , installed 7.7.22
    Adapter    "awtrix-light" : 3.0.0    , installed 3.0.0
    Adapter    "backitup"     : 3.3.14   , installed 3.3.14
    Adapter    "brightsky"    : 0.6.6    , installed 1.0.0-beta.1
    Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "countdown"    : 3.1.0    , installed 3.1.0
    Adapter    "device-reminder": 3.1.2  , installed 3.1.2
    Adapter    "device-watcher": 2.15.5  , installed 2.15.5
    Adapter    "devices"      : 1.2.14   , installed 1.2.14
    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
    Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
    Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
    Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
    Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "ical"         : 1.18.1   , installed 1.18.1
    Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
    Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
    Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
    Adapter    "imap"         : 0.3.0    , installed 0.3.0
    Adapter    "iot"          : 5.0.7    , installed 5.0.7
    Adapter    "javascript"   : 9.0.18   , installed 9.0.18
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "logparser"    : 2.4.0    , installed 2.4.0
    Adapter    "matter"       : 0.5.6    , installed 0.5.6
    Adapter    "meross"       : 1.17.0   , installed 1.17.0
    Adapter    "mytime"       : 2.3.2    , installed 2.3.2
    Adapter    "net-tools"    : 1.2.3    , installed 1.2.3
    Adapter    "nina"         : 0.0.25   , installed 0.0.26
    Adapter    "notification-manager": 1.3.0, installed 1.3.0
    Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "openmediavault": 1.4.2   , installed 1.4.2
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "philips-tv"   : 0.5.4    , installed 0.5.4
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "proxmox"      : 2.4.10   , installed 2.4.10
    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
    Adapter    "ring"         : 6.4.0    , installed 6.3.0  [Updatable]
    Adapter    "samsung"      : 0.7.0    , installed 0.7.0
    Adapter    "sayit"        : 5.0.0    , installed 5.0.0
    Adapter    "schoolfree"   : 1.1.13   , installed 1.1.13
    Adapter    "shelly"       : 10.5.2   , installed 10.5.2
    Adapter    "shuttercontrol": 2.0.11  , installed 2.0.11
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "text2command" : 4.0.0    , installed 4.0.0
    Adapter    "trashschedule": 3.3.0    , installed 4.0.0
    Adapter    "tuya"         : 3.16.0   , installed 3.17.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "unifi-network": 1.3.1    , installed 1.3.1
    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 2.0.1, installed 2.0.1
    Adapter    "vis-2-widgets-inventwo": 0.5.5, installed 0.5.5
    Adapter    "vis-2-widgets-jaeger-design": 1.4.18, installed 1.4.18
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-2-widgets-weather-and-heating": 1.1.5, installed 1.1.5
    Adapter    "vis-icontwo"  : 2.11.1   , installed 2.11.1
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
    Adapter    "vis-material" : 0.2.0    , installed 0.2.0
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
    Adapter    "weather-warnings": 0.10.0, installed 0.10.0
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "wireguard"    : 1.7.0    , installed 1.8.0
    Adapter    "wled"         : 0.7.3    , installed 0.7.3
    Adapter    "zigbee"       : 3.3.5    , installed 3.3.5
    Objects and States
    Objects:        30151
    States:         24936
    Hit:1 http://deb.debian.org/debian trixie InRelease
    Hit:2 http://security.debian.org/debian-security trixie-security InRelease
    Hit:3 http://deb.debian.org/debian trixie-updates InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian trixie InRelease
    Reading package lists...
    Pending systemupdates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          5985       1055/exim4
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       6890       786/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       6885       786/iobroker.js-con
    tcp        0      0 192.168.178.3:1891      0.0.0.0:*               LISTEN      1000       9069       1471/io.mqtt.0
    tcp        0      0 192.168.178.3:1890      0.0.0.0:*               LISTEN      1000       9068       1471/io.mqtt.0
    tcp        0      0 192.168.178.3:1885      0.0.0.0:*               LISTEN      1000       11255      2003/io.shelly.0
    tcp        0      0 192.168.178.3:1883      0.0.0.0:*               LISTEN      1000       9387       1609/io.sonoff.0
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          791        1/init
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5866       837/sshd: /usr/sbin
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       11637      2306/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       7299       1081/io.admin.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       12812      2382/io.simple-api.
    tcp6       0      0 :::8086                 :::*                    LISTEN      1000       12900      2394/io.ws.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1000       12791      2362/io.socketio.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          5986       1055/exim4
    tcp6       0      0 :::51989                :::*                    LISTEN      1000       12226      2643/io.nuki-extend
    tcp6       0      0 :::111                  :::*                    LISTEN      0          793        1/init
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5868       837/sshd: /usr/sbin
    udp        0      0 0.0.0.0:54087           0.0.0.0:*                           1000       7911       1304/io.broadlink2.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       17578      2671/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       14642      2671/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       14628      2671/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       14620      2671/io.matter.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       12652      2322/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       12303      1962/io.ham.0
    udp        0      0 0.0.0.0:46375           0.0.0.0:*                           1000       16073      2671/io.matter.0
    udp        0      0 0.0.0.0:5541            0.0.0.0:*                           1000       14637      2671/io.matter.0
    udp        0      0 0.0.0.0:54865           0.0.0.0:*                           1000       12435      2197/io.upnp.0
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1000       10223      1845/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1000       10224      1845/io.tuya.0
    udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       7764       1304/io.broadlink2.
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          792        1/init
    udp        0      0 0.0.0.0:49466           0.0.0.0:*                           1000       8624       1304/io.broadlink2.
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       12720      2197/io.upnp.0
    udp6       0      0 :::5353                 :::*                                1000       17579      2671/io.matter.0
    udp6       0      0 :::5353                 :::*                                1000       14643      2671/io.matter.0
    udp6       0      0 :::5353                 :::*                                1000       14631      2671/io.matter.0
    udp6       0      0 :::5353                 :::*                                1000       14623      2671/io.matter.0
    udp6       0      0 :::46375                :::*                                1000       16072      2671/io.matter.0
    udp6       0      0 :::5541                 :::*                                1000       14636      2671/io.matter.0
    udp6       0      0 :::111                  :::*                                0          794        1/init
    2026-03-19 21:10:34.418  - info: host.ioBroker instance system.adapter.weather-warnings.0 in version "0.10.0" started with pid 2562
    2026-03-19 21:10:34.656  - info: vis-2.0 (2550) starting. Version 2.13.4 in /opt/iobroker/node_modules/iobroker.vis-2, node: v22.22.1, js-controller: 7.0.7
    2026-03-19 21:10:35.160  - info: vis-2.0 (2550) vis-2 license is OK.
    2026-03-19 21:10:37.419  - info: host.ioBroker instance system.adapter.windows-control.0 in version "0.1.5" started with pid 2578
    2026-03-19 21:10:42.348  - info: host.ioBroker instance system.adapter.apsystemsez1.0 in version "0.0.7" (non-npm: hefegraphie/ioBroker.apsystemsez1#0e771c9d92c4bb4e662b09022820f2aa48358c50) started with pid 2598
    2026-03-19 21:10:43.041  - info: host.ioBroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 2606
    2026-03-19 21:10:43.977  - info: host.ioBroker stopInstance system.adapter.nuki-extended.0 (force=false, process=true)
    2026-03-19 21:10:44.245  - info: host.ioBroker stopInstance system.adapter.nuki-extended.0 send kill signal
    2026-03-19 21:10:45.729  - info: host.ioBroker instance system.adapter.nuki-extended.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2026-03-19 21:10:46.212  - info: host.ioBroker instance system.adapter.philips-tv.0 in version "0.5.4" started with pid 2623
    2026-03-19 21:10:49.194  - info: host.ioBroker instance system.adapter.nuki-extended.0 in version "2.7.0" started with pid 2643
    2026-03-19 21:10:50.026  - info: host.ioBroker instance system.adapter.text2command.1 in version "4.0.0" started with pid 2651
    2026-03-19 21:10:50.689  - error: apsystemsez1.0 (2598) Konnte maximalen Output nicht setzen
    2026-03-19 21:10:53.559  - info: host.ioBroker instance system.adapter.matter.0 in version "0.5.6" started with pid 2671
    2026-03-19 21:10:56.320  - info: host.ioBroker instance system.adapter.dwd.0 having pid 2606 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2026-03-19 21:10:58.152  - info: host.ioBroker instance system.adapter.bambulab.0 in version "0.3.4" started with pid 2692
    2026-03-19 21:10:59.114  - info: host.ioBroker instance system.adapter.openweathermap.0 terminated with code 0 (NO_ERROR)
    2026-03-19 21:11:01.710  - info: host.ioBroker instance system.adapter.unifi-network.0 in version "1.3.1" (non-npm: Scrounger/ioBroker.unifi-network) started with pid 2706
    2026-03-19 21:11:05.787  - info: host.ioBroker instance system.adapter.energiefluss-erweitert.0 in version "0.8.1" started with pid 2726
    2026-03-19 21:11:09.684  - info: host.ioBroker instance system.adapter.text2command.2 in version "4.0.0" started with pid 2746
    2026-03-19 21:11:13.616  - info: host.ioBroker instance system.adapter.nebenkosten-monitor.0 in version "1.2.2" (non-npm: fischi87/ioBroker.nebenkosten-monitor) started with pid 2762
    2026-03-19 21:11:17.623  - info: host.ioBroker instance system.adapter.utility-monitor.0 in version "1.5.0" (non-npm: fischi87/ioBroker.utility-monitor#64de59c8aaa26c92f3fcacac80c123bcc2bc9b16) started with pid 2780
    2026-03-19 21:11:21.537  - info: host.ioBroker instance system.adapter.echarts.0 in version "1.9.2" started with pid 2801
    2026-03-19 21:11:24.980  - info: echarts.0 (2801) starting. Version 1.9.2 in /opt/iobroker/node_modules/iobroker.echarts, node: v22.22.1, js-controller: 7.0.7
    2026-03-19 21:12:19.979  - info: host.ioBroker instance system.adapter.vis.0 terminated while should be started once
      Dragon
      Trotz umstellens wird bei Zigbee immer noch Kanal 11 angezeigt. Warum nimmt er das nicht wenn ich es in den Einstellungen umstelle?
        Dragon
        @arteck Habe dir einen Screenshot vom Adapterkonfig geschickt. Der Kanel steht dort auf 20, aber im diag sagt er es sei immer noch 11.
          Dragon
          Die extended PanID die im Log steht und der Kanal des Zigbee Netzwerkes aus dem Log stimmen nicht mit dem überein was in der Adapterkonfig steht...
            Dragon
            schrieb am zuletzt editiert von Dragon
            @arteck alles was persönliche Daten sind habe ich in den chat gestellt
              @Dragon sagte in Error beim Zigbee Adapter nach Kanalwechsel:
              W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://deb.nodesource.com/node_22.x nodistro InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound: No binding signature at time 2026-03-05T16:16:03Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
              Installier nodejs@22 nochmal drüber:
              iob nodejs-update 22
              Rückfragen mit y beantworten.
              Dragon
              @Thomas-Braun Fehler für Nodejs ist behoben.
                Dragon
                Das sagt die Adapterkonfig
                Network parameters: panID=6750 channel=20 extendedPanID=2f9d7b23004b1200
                Das steht im Log
                Im Diag stehen Kanal 11 und noch eine andere extendedPanID
                Auf der Kachel des Koordinators im Zigbeeadapter steht Kanal 20.
                Das ist echt verwirrend und ich habe keine Ahnung wieso...
                • D Dragon
                  Das steht im Log
                  Was steht denn da genau drin? Poste mal die Zigbee-Sektion von
                  iob diag --unmask
                    iob diag --unmask
                    Dragon
                    @Thomas-Braun
                     HINT:
                    tcp
                    zigbee.0
                    Extended Pan ID:
                    00124b00237b9d2f
                    Pan ID:
                    6750
                    Channel:
                    Network Key:
                    01030507090b0d0f00020406080a0c0d
                    ": "a493e499f8570db9b3787859d79e
                    ": "a51da20d98ba58cf080a49915895
                    ": "8bf9149bf70602949c12885bd8cf
                    ": "9e7d449597b0e667b1b4aa38805b
                    ": "0f3a946aa7a59fcda22d7ff6678a
                    ": "7b6e94ddc22ce5d3bb415d336f3b
                    ": "243c87f9bca2b3d8cfa047d6754c
                    ": "a20884336f83137762274dddc294
                    ": "fcdf2099f8c2ad65eb34bc59d70b
                    ": "964e7028904522e278e367c30c85
                    ": "e0755a69c281655b299bf77e291d
                    ": "60e6e67432e29561fc26c9bddc4f
                    ": "9c59367e298dad4055b79b69c211
                    ": "a4a97459d79ee314b342e899f857
                    ": "329bf22890d52ad6dc36e5c30c15
                    ": "ee7508c37f57e1ffc1bce66e68bc
                    ": "94ab99ddc2a7a7eb548450336fb0
                    ": "270d2a336f2a261fe722e3ddc23d
                    ": "d3267f59d7adbc14c4cde399f864
                    ": "b40408c37f57e1ff9bcde66e68bc
                    ": "5ca3503336f55133b73f901cff1b
                    ": "edefd3c30c850d2b0342c4289045
                    ": "9a14a859d7adbc148dff3499f864
                    ": "98cf8dc37f1aa36bb706636e68f1
                    ": "2ab9257432b7e6b9b6790abddc1a
                    ": "fef699bf52b817cb3ed95051ffaf
                    ": "049c5969c24e7cebcd72f47e29d2
                    ": "ca655fd675d9be1321f99ff9bc37
                    ": "14a8c991580ffb49b9bf220d9820
                    ": "4cbd01263d0dc36f8c92c8c8901a
                    ": "e2c3bb91580830494fd4500d9827
                    ": "4ab5a0c37fc3a2a3657c4e6e6828
                    ": "ad91c8c8901a28f36dbe01263d0d
                    ": "e9d57f59d7adbc14fe3ee399f864
                    ": "994108f9bc9e266c72ddc8d67570
                    ": "6e0644289080590e80ab53c30c40
                    ": "69c7eaf9bc04c004825b2ad675ea
                    ": "331b02f9bc2b91f0d887c2d675c5
                    ": "58d5e52d8a408597b349250243ae
                    ": "b4b6a659d737d67ca35d3a99f8fe
                    ": "83306da42807d89094dbf16407ce
                    ": "ff176779cf0532c3d0de89d4d8ee
                    ": "8fda3a2c8a4085976446fa0343ae
                    ": "f5efe259d7ad3014e2047e99f864
                    ": "cf80936ba7a59fcd629778f7678a
                    ": "a30c797f741bfc244890b950bdf5
                    ": "dd7da7d6757c236336e167f9bc92
                    ": "ec39d769c296762b25d77a7e290a
                    ": "1bfc72743284d431873c5dbddc29
                    ": "146a0111fe05417288aa2ed810a8
                    ": "aede5c6aa7a59fcd03c9b7f6678a
                    ": "2fd822e9851bfc24c444e2c64cf5
                    ": "860f83bddc29ae521acfac743284
                    ": "2252d538f3ea1243ccffc2d36f2a
                    ": "071e67c601eeae0328d7896b1605
                    ": "6034eaaf2807d89077df766f07ce
                    ": "bf67b6d675eae11354fb76f9bc04
                    ": "a0029769c29af9a369ec3a7e2906
                    ": "e16c4869c2083b3f2882e57e2994
                    ": "717de29158d3d6f5dc6a090d98fc
                    ": "81de6c3ef3ea12436f737bd56f2a
                    ": "02190037ba0541729ed92ffe54a8
                    ": "302891289080590ede8586c30c40
                    ": "ec0dedac17104b69411a0630d73f
                    ": "7ffe8399f831216168151f59d7f8
                    ": "4e84c2d36f2a3d8aa029d538f3ea
                    ": "705288b88bf551339bce4897421b
                    ": "757694ed1ecba6a3bc9839faf557
                    ": "d4bc27d675ed2a133f20e7f9bc03
                    ": "2bf26b0d9862520f86e58091584d
                    ": "aefbe6be96eeae03813208138105
                    ": "90b5e4336f75379b509a2dddc262
                    ": "2d5d69de6f7be2993ab6f51e40b2
                    ": "57ebe44af41bfc24bc7724653df5
                    ": "068305d67fe3c7dee82e123de323
                    ": "5d95aec30c73444fb338b92890b3
                    ": "8df38557c957668c441d284022cb
                    ": "e01b876dfd1bfc240b87474234f5
                    ": "206db742a3104b698d7a5cde633f
                    ": "d2282c7e2948d6ac1bc68169c2d4
                    ": "d50603729e5fc6e73bab1499029f
                    ": "4946f512d3104b69e4511e8e133f
                    ": "bd459a7e2996449c74ab3769c20a
                    ": "26e3996e681a82e3092a77c37ff1
                    ": "7cdabb142ab817cbbcf572fa87af
                    ": "98f5689297b0e667b73c863f805b
                    ": "cac984f71626d477032729e0fdba
                    ": "9dc8e9d67521165b765429f9bccf
                    ": "e4862a74321fae05784605bddcb2
                    ": "5bd8cdf9bc7c938cb0440dd67592
                    ": "22706369c272918beb9ece7e29ee
                    ": "b6d12e59025fc6e7587c39b29e9f
                    ": "d2c62eb85c7be299c52db27873b2
                    ": "e434187c9e57668c2ddab56b75cb
                    ": "b894bead42a8569924549164ac05
                    ": "81fac9048957668c4814641362cb
                    ": "320c80d7291bfc24d99040f8e0f5
                    ": "ba5ce5bba4eeae0395950b16b305
                    ": "5bd3213bdc5fc6e7b57e36d0409f
                    ": "e9ae26ff21a85699756e0936cf05
                    ": "1369a1448df55133f8f5616b441b
                    ": "01ce42203d0dc36fc1e18bce901a
                    ": "222f55d9674c51238f38be45a763
                    ": "0582a635805b7aa72a4b489897b0
                    ": "4942b2923d7e720780ac1f85d6e2
                    ": "16e564a42807d890010ef86407ce
                    ": "dd19ee7432b7e6b941d9c1bddc1a
                    ": "7dcb4c223d0dc36fbde485cc901a
                    ": "066d3ba93db20c341186a769127b
                    ": "eab19fddc27639632a9e56336f61
                    ": "fc77a887c7b817cb3c5861696aaf
                    ": "233a280bd6e2b228ead4851c3d7e
                    ": "762956a83d0dc36fb6069f46901a
                    ": "6ddd49431655651fadf280adbb42
                    ": "574b27ee90dc2ff39764ee003dcb
                    ": "b2bbba31940541722e7b95f87aa8
                    ": "6a1d6a8fcd1d823df6dd454623b0
                    ": "2d620ad36f2a3d8ac3cf1d38f3ea
                    ": "6e7d449597b0e66741b4aa38805b
                    ": "594c7f85d6e2b22890a2d2923d7e
                    ": "f5fb6138805b7aa7da328f9597b0
                    ": "37fe109087791c331837fe3d9092
                    ": "f6e888d26f2a3d8a18459f39f3ea
                    ": "34519a963d7e7207fdbf3781d6e2
                    ": "0023b345a76398cdad3458d9674c
                    ": "103eead0e3b20c3407d57610cc7b
                    ": "113377082b57668cd8ddda1fc0cb
                    ": "03f888933d7e7207ca162584d6e2
                    ": "a197be84d6e2b228687913933d7e
                    ": "a768294da76398cd0a7fc2d1674c
                    ": "34427e3d6acba6a3fdacd32a8157
                    ": "f264bb6e80104b695f7350f2403f
                    ": "c1df840e660541725d1fabc788a8
                    ": "5d90fcf3d10532c37259125ec6ee
                    ": "a703fcd4c49fe92e49aeeb3f585f
                    ": "7148921c119fe92e9fe585f78d5f
                    ": "07accec9901a28f3c78307273d0d
                    ": "54d2a405aa3f8287f9c54f996a10
                    ": "6e456eba663f8287c3528526a610
                    ": "ac5c8c40763f8287014b67dcb610
                    ": "e8fb888c379fe92e06569f67ab5f
                    ": "1fa9673fa9b817cbdf86aed104af
                    ": "3aadd0e111a85699a66dff28ff05
                    ": "7b53efba37f5513390cf2f95fe1b
                    ": "8986e8ddc21e4daf49a921336f09
                    ": "18ba5933d0cba6a3d154f4243b57
                    ": "f882896e68dff90fd74b67c37f34
                    ": "fe6a4428900b1b3610c753c30ccb
                    ": "d68efa0d9843fd237b991191586c
                    ": "dc8dfb6aa7a59fcd719a10f6678a
                    ": "e96b49f85af5513302f789d7931b
                    ": "9c30ff8c3e05417200f0d045d0a8
                    ": "9ffba98225f55133746769adec1b
                    ": "876bd19713a856991babfe5efd05
                    ": "b46fd00d9875417f19783b91585a
                    ": "6d9a37d06f2a3d8a8337203bf3ea
                      Dragon
                      Habe echt noch immer probleme ständig verschwinden Geräte haben oder haben dauerhaft keine Empfang mehr. Das Zigbeee Netz ist echt nervig momentan. Liegt's am Koordinator oder woran kann dieses Chaos liegen? Muss regelmäßig den Koordinator neu starten oder vom Strom trennen damit es wieder funktioniert.
                      Habe ein Zigstar Gateway hier aus dem Forum...
                      • D Dragon
                        arteckA Offline
                        arteckA Offline
                        arteck
                        welches sollte das sein ?
                        • arteckA arteck
                          @arteck sagte in Error beim Zigbee Adapter nach Kanalwechsel:
                          könnte das von dimaiv sein
                            Dragon
                            Das ist richtig. Mit Dimaiv hatte ich Kontakt.
                            Ist das nicht gut? Gibt es ein besseres was Abhilfe schaffen könnte? Ich bin echt allem gegenüber offen, weil ich echt unglücklich bin, dass es alles so unrund läuft.
