  4. Grohe - Sense / Guard /Blue - Adapter
    6.8k
133 Beiträge 3 Kommentatoren 7.7k Aufrufe 4 Beobachtet
    M-A-X
    erledigt. Tap Werte auf 50 / 1 -> Adapter neu drüber installiert über den github Link (Katze), dispenseTrigger gedrückt -> Wasser kam -> tap Werte wurden auf 0 gesetzt.
    grohe-smarthome.0
    2026-03-11 20:19:08.674	info	Dispensing: type=1 amount=50ml for 449183f7-11b5-4c25-a063-3361bad8b967
    grohe-smarthome.0
    2026-03-11 20:19:05.600	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1982, remaining_co2=59, remaining_co2_liters=33, timestamp=2026-03-11T20:18:55.000+01:00
    grohe-smarthome.0
    2026-03-11 20:19:05.599	info	Blue 449183f7-11b5-4c25-a063-3361bad8b967: fresh data from /details (old=2026-03-11T20:03:50.000+01:00, new=2026-03-11T20:18:55.000+01:00, remaining_filter=66, remaining_co2=59)
    grohe-smarthome.0
    2026-03-11 20:18:55.238	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1982, remaining_co2=59, remaining_co2_liters=33, timestamp=2026-03-11T20:03:50.000+01:00
    grohe-smarthome.0
    2026-03-11 20:18:55.237	debug	Triggered measurement refresh for Blue 449183f7-11b5-4c25-a063-3361bad8b967
    grohe-smarthome.0
    2026-03-11 20:18:54.920	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28120,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":114,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T20:03:50.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
    grohe-smarthome.0
    2026-03-11 20:18:54.920	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details data_latest keys: ["measurement"]
    grohe-smarthome.0
    2026-03-11 20:18:54.919	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details raw response keys: ["appliance_id","installation_date","name","serial_number","type","version","tdt","timezone","config","role","registration_complete","presharedkey","params","error","state","status","data_latest","notifications"]
    grohe-smarthome.0
    2026-03-11 20:18:54.359	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /dashboard measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28120,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":114,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T20:03:50.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
    grohe-smarthome.0
    2026-03-11 20:18:53.758	debug	Poll cycle #27 (status=false, command=true, pressure=false, consumption=false)
    • patricknitschP Online
      patricknitsch
      #66
      Danke fürs Testen. Version 0.2.6 gebe ich frei, sollte ab morgen im Latest sein. Sollte es weitere Probleme geben, gib Bescheid :)
      Systeme:
      • Proxmox 1 mit ioBroker, HomeAssistant, piHole
      • Proxmox 2 mit SOLECTRUS, Mosquitto, piHole und Frigate
      • RPi4 mit Octoprint
      Eigene Adapter: grohe-smarthome, solectrus-influxdb, schlueter-thermostat
        M-A-X
        #67
        Dank dir für die schnelle Hilfe. Ich werde die nächsten Tage ausgiebig testen. Dann sollte auch die % Zahl von Filter und CO2 sinken und ich kann berichten ob alles passt.
          M-A-X
          #68
          Als kleine Rückmeldung: das dispenseTrigger Problem scheint behoben (hab mittlerweile die 0.2.6 drauf).
          Mein Filter zeigt jedoch immernoch 66% in den Objekten, während er in der App von 63 auf 62% runter gegangen ist. CO2 ist mittlerweile von 59 auf 39 Prüzent gesunken. Das wird sowohl in der App als auch in den Iobroker Objekten korrekt angezeigt.
          Der "zuletzt geändert" Zeitstempel der Filteranzeige ist der Zeitpunkt der Adapterinstallation (11.03. Mittags).
            patricknitsch
            #69
            Das Thema höre ich jetzt schon zum zweiten Mal. Versuch es mal bitte damit :
            https://github.com/patricknitsch/ioBroker.grohe-smarthome/tree/copilot/fix-filterstatus-update
            Systeme:
              M-A-X
              schrieb am zuletzt editiert von M-A-X
              #70
              Bevor ich das installiere (kann ich von unterwegs). Die fixe von 0.2.6 sind schon drin? :)
              EDIT: bin jetzt zuhause und habe die github version mal installiert. Direkt nach dem Start bisher keine Änderung (immer noch 66%). Ich lasse ihn mal laufen (300 sekunden?)
              EDIT2: Habe getestet. sollte auf 0.2.6 aufbauen :)
                M-A-X
                #71
                Ändert sich auch beim nächsten Abfragen anscheinend nichts. Hier das Log:
                grohe-smarthome.0
                2026-03-13 12:31:08.005	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12183,"open_close_cycles_still":12857,"operating_time":28160,"power_cut_count":41,"pump_count":19680,"pump_running_time":2904,"remaining_co2":39,"remaining_filter":66,"time_since_last_withdrawal":6,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-13T12:16:04.000+01:00","water_running_time_carbonated":3290,"water_running_time_medium":24,"water_running_time_still":242,"remaining_filter_liters":1971,"remaining_co2_liters":22}
                grohe-smarthome.0
                2026-03-13 12:31:07.163	debug	Poll cycle #6 (status=false, command=true, pressure=false, consumption=false)
                grohe-smarthome.0
                2026-03-13 12:26:06.905	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1971, remaining_co2=39, remaining_co2_liters=22, timestamp=2026-03-13T12:16:04.000+01:00
                grohe-smarthome.0
                2026-03-13 12:26:06.904	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12183,"open_close_cycles_still":12857,"operating_time":28160,"power_cut_count":41,"pump_count":19680,"pump_running_time":2904,"remaining_co2":39,"remaining_filter":66,"time_since_last_withdrawal":6,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-13T12:16:04.000+01:00","water_running_time_carbonated":3290,"water_running_time_medium":24,"water_running_time_still":242,"remaining_filter_liters":1971,"remaining_co2_liters":22}
                grohe-smarthome.0
                2026-03-13 12:26:05.905	debug	Poll cycle #5 (status=true, command=false, pressure=false, consumption=true)
                grohe-smarthome.0
                2026-03-13 12:21:05.621	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1971, remaining_co2=39, remaining_co2_liters=22, timestamp=2026-03-13T12:16:04.000+01:00
                grohe-smarthome.0
                2026-03-13 12:21:05.620	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12183,"open_close_cycles_still":12857,"operating_time":28160,"power_cut_count":41,"pump_count":19680,"pump_running_time":2904,"remaining_co2":39,"remaining_filter":66,"time_since_last_withdrawal":6,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-13T12:16:04.000+01:00","water_running_time_carbonated":3290,"water_running_time_medium":24,"water_running_time_still":242,"remaining_filter_liters":1971,"remaining_co2_liters":22}
                grohe-smarthome.0
                2026-03-13 12:21:04.620	debug	Poll cycle #4 (status=false, command=false, pressure=false, consumption=false)
                grohe-smarthome.0
                2026-03-13 12:16:14.746	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1971, remaining_co2=39, remaining_co2_liters=22, timestamp=2026-03-13T12:16:04.000+01:00
                grohe-smarthome.0
                2026-03-13 12:16:14.744	info	Blue 449183f7-11b5-4c25-a063-3361bad8b967: fresh data from /details (old=2026-03-13T12:09:16.000+01:00, new=2026-03-13T12:16:04.000+01:00, remaining_filter=66, remaining_co2=39)
                grohe-smarthome.0
                2026-03-13 12:16:04.139	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1971, remaining_co2=39, remaining_co2_liters=22, timestamp=2026-03-13T12:09:16.000+01:00
                grohe-smarthome.0
                2026-03-13 12:16:04.138	debug	Triggered measurement refresh for Blue 449183f7-11b5-4c25-a063-3361bad8b967
                grohe-smarthome.0
                2026-03-13 12:16:03.864	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12183,"open_close_cycles_still":12857,"operating_time":28160,"power_cut_count":41,"pump_count":19680,"pump_running_time":2904,"remaining_co2":39,"remaining_filter":66,"time_since_last_withdrawal":0,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-13T12:09:16.000+01:00","water_running_time_carbonated":3290,"water_running_time_medium":24,"water_running_time_still":242,"remaining_filter_liters":1971,"remaining_co2_liters":22}
                grohe-smarthome.0
                2026-03-13 12:16:02.598	debug	Poll cycle #3 (status=false, command=true, pressure=false, consumption=false)
                grohe-smarthome.0
                2026-03-13 12:11:02.200	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1971, remaining_co2=39, remaining_co2_liters=22, timestamp=2026-03-13T12:09:16.000+01:00
                grohe-smarthome.0
                2026-03-13 12:11:02.199	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12183,"open_close_cycles_still":12857,"operating_time":28160,"power_cut_count":41,"pump_count":19680,"pump_running_time":2904,"remaining_co2":39,"remaining_filter":66,"time_since_last_withdrawal":0,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-13T12:09:16.000+01:00","water_running_time_carbonated":3290,"water_running_time_medium":24,"water_running_time_still":242,"remaining_filter_liters":1971,"remaining_co2_liters":22}
                grohe-smarthome.0
                2026-03-13 12:11:00.813	debug	Poll cycle #2 (status=false, command=false, pressure=false, consumption=false)
                grohe-smarthome.0
                2026-03-13 12:09:14.575	info	Dispensing: type=1 amount=50ml for 449183f7-11b5-4c25-a063-3361bad8b967
                  patricknitsch
                  schrieb am zuletzt editiert von patricknitsch
                  #72
                  Die Änderungen beziehen sich auf das neueste Release.
                  Es ist aber nur der prozentuale Anteil der nicht passt? Die Filtermenge ändert sich richtig?
                  Installiere es bitte nochmal.
                  Systeme:
                    M-A-X
                    #73
                    Ich bin leider bis heute Abend nicht mehr zuhause. Ob die Filtermenge sich ändert habe ich nicht beobachtet. Ich berichte sobald ich kann. Wird aber wahrscheinlich eher gegen 18 Uhr
                      patricknitsch
                      #74
                      Kein Problem. Ich habe in der Zwischenzeit noch etwas angepasst. Wenn du wieder da Bist, bitte mal testen und mit der App vergleichen.
                      Systeme:
                        M-A-X
                        #75
                        RemainingFilterLiters ist soeben um 1l runter gegangen. Die Prozentzahl ist unverändert bei 66%. Ich hab jetzt über den selben link die neuste Version drüber installiert. Direkt nach dem Start waren es immer noch 66%. Evtl braucht der aber ein abrufen?
                          patricknitsch
                          #76
                          Stimmt Remaining Filter Liters mit der App überein? Was ist denn eigentlich die maximale Menge, die der Filter abkann?
                          Systeme:
                            M-A-X
                            #77
                            Ehrlich gesagt weiß ich nicht wo das steht. In der App sehe ich nur Prozente.
                            Aber durch deine Frage kommt mir ein anderer Gedanke. Es verschiedene Filter die man einbauen kann (und dem entsprechend in der App einstellen muss).
                            Folgende Daten habe ich aus dem Grohe Shop:
                            Aktivkohlefilter (den hab ich) - 3000 l
                            Ultrasafe Filter - 3000 l
                            L Filter - 2500 l
                            M Filter - 1500 l
                            S Filter - 600 l
                            Magnesium & Zink Filter - 400 l
                            Evtl haben deshalb manche Probleme und manche nicht?
                              patricknitsch
                              #78
                              Kann ich nicht sicher beantworten. Aber letzten Endes muss ja jeder getauscht werden. Bei wie viel % stehst du aktuell in der App? Und wie viel Liter werden dir aktuell im Adapter angezeigt?
                              Systeme:
                                M-A-X
                                #79
                                Und hier das letzte aus dem log
                                grohe-smarthome.0
                                2026-03-13 19:38:19.008	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1966, remaining_co2=32, remaining_co2_liters=18, timestamp=2026-03-13T19:33:17.000+01:00
                                grohe-smarthome.0
                                2026-03-13 19:38:19.008	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12190,"open_close_cycles_still":12864,"operating_time":28168,"power_cut_count":41,"pump_count":19690,"pump_running_time":2906,"remaining_co2":32,"remaining_filter":66,"time_since_last_withdrawal":22,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-13T19:33:17.000+01:00","water_running_time_carbonated":3292,"water_running_time_medium":24,"water_running_time_still":242,"remaining_filter_liters":1966,"remaining_co2_liters":18}
                                grohe-smarthome.0
                                2026-03-13 19:38:17.461	debug	Poll cycle #91 (status=false, command=false, pressure=false, consumption=false)
                                grohe-smarthome.0
                                2026-03-13 19:33:27.734	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1966, remaining_co2=32, remaining_co2_liters=18, timestamp=2026-03-13T19:33:17.000+01:00
                                grohe-smarthome.0
                                2026-03-13 19:33:27.734	info	Blue 449183f7-11b5-4c25-a063-3361bad8b967: fresh data from /details (old=2026-03-13T19:18:13.000+01:00, new=2026-03-13T19:33:17.000+01:00, remaining_filter=66, remaining_co2=32)
                                grohe-smarthome.0
                                2026-03-13 19:33:17.232	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1966, remaining_co2=32, remaining_co2_liters=18, timestamp=2026-03-13T19:18:13.000+01:00
                                grohe-smarthome.0
                                2026-03-13 19:33:17.231	debug	Triggered measurement
                                Und hier das aktuelle Objekt
                                  patricknitsch
                                  #80
                                  Nächster Versuch :) Installieren, Adapter neu starten und berichten
                                  Systeme:
                                    M-A-X
                                    #81
                                    Leider trotz 300 Sekunden warten keine Änderung. Also immer noch 66% im dem Objekten und 62 in der App. Wie ich weiter oben geschrieben habe, stört mich das nicht. Aber ich helfe gerne weiter bei der Suche /beim probieren. Habe jetzt aber Besuch und werde erst morgen wieder testen können. Macht es einen Unterschied ob ich den Adapter komplett lösche oder nur drüber installiere? Letzteres mache ich immer.
                                      patricknitsch
                                      #82
                                      Kannst du gerne mal machen. Dann haben wir gleich ein sauberes Bild. Melde dich einfach, wenn du bereit bist.
                                      Systeme:
                                        M-A-X
                                        #83
                                        Es ändert sich leider nichts. Immer noch 66 %
                                        grohe-smarthome.0
                                        Zeit
                                        debug
                                        Nachricht
                                        grohe-smarthome.0
                                        2026-03-13 22:44:50.503	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1966, remaining_co2=32, remaining_co2_liters=18, timestamp=2026-03-13T22:44:40.000+01:00
                                        grohe-smarthome.0
                                        2026-03-13 22:44:50.502	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967: filter 66% from 1966l (capacity=3000l, device-reported=66%)
                                        grohe-smarthome.0
                                        2026-03-13 22:44:50.501	info	Blue 449183f7-11b5-4c25-a063-3361bad8b967: fresh data from /details (old=2026-03-13T22:39:38.000+01:00, new=2026-03-13T22:44:40.000+01:00, remaining_filter=66, remaining_co2=32)
                                        grohe-smarthome.0
                                        2026-03-13 22:44:39.803	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1966, remaining_co2=32, remaining_co2_liters=18, timestamp=2026-03-13T22:39:38.000+01:00
                                        grohe-smarthome.0
                                        2026-03-13 22:44:39.802	debug	Triggered measurement refresh for Blue 449183f7-11b5-4c25-a063-3361bad8b967
                                        grohe-smarthome.0
                                        2026-03-13 22:44:39.414	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967: filter 66% from 1966l (capacity=3000l, device-reported=66%)
                                        grohe-smarthome.0
                                        2026-03-13 22:44:39.411	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12190,"open_close_cycles_still":12864,"operating_time":28171,"power_cut_count":41,"pump_count":19690,"pump_running_time":2906,"remaining_co2":32,"remaining_filter":66,"time_since_last_withdrawal":209,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-13T22:39:38.000+01:00","water_running_time_carbonated":3292,"water_running_time_medium":24,"water_running_time_still":242,"remaining_filter_liters":1966,"remaining_co2_liters":18}
                                        grohe-smarthome.0
                                        2026-03-13 22:44:38.244	debug	Poll cycle #27 (status=false, command=true, pressure=false, consumption=false)
                                        grohe-smarthome.0
                                        2026-03-13 22:39:48.438	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1966, remaining_co2=32, remaining_co2_liters=18, timestamp=2026-03-13T22:39:38.000+01:00
                                        grohe-smarthome.0
                                        2026-03-13 22:39:48.438	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967: filter 66% from 1966l (capacity=3000l, device-reported=66%)
                                        grohe-smarthome.0
                                        2026-03-13 22:39:48.437	info	Blue 449183f7-11b5-4c25-a063-3361bad8b967: fresh data from /details (old=2026-03-13T22:34:36.000+01:00, new=2026-03-13T22:39:38.000+01:00, remaining_filter=66, remaining_co2=32)
                                        grohe-smarthome.0
                                        2026-03-13 22:39:38.020	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1966, remaining_co2=32, remaining_co2_liters=18, timestamp=2026-03-13T22:34:36.000+01:00
                                        grohe-smarthome.0
                                        2026-03-13 22:39:38.019	debug	Triggered measurement refresh for Blue 449183f7-11b5-4c25-a063-3361bad8b967
                                        grohe-smarthome.0
                                        2026-03-13 22:39:37.748	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967: filter 66% from 1966l (capacity=3000l, device-reported=66%)
                                        grohe-smarthome.0
                                        2026-03-13 22:39:37.747	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12190,"open_close_cycles_still":12864,"operating_time":28171,"power_cut_count":41,"pump_count":19690,"pump_running_time":2906,"remaining_co2":32,"remaining_filter":66,"time_since_last_withdrawal":204,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-13T22:34:36.000+01:00","water_running_time_carbonated":3292,"water_running_time_medium":24,"water_running_time_still":242,"remaining_filter_liters":1966,"remaining_co2_liters":18}
                                        grohe-smarthome.0
                                        2026-03-13 22:39:36.602	debug	Poll cycle #26 (status=false, command=false, pressure=false, consumption=false)
                                        grohe-smarthome.0
                                        2026-03-13 22:34:46.841	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1966, remaining_co2=32, remaining_co2_liters=18, timestamp=2026-03-13T22:34:36.000+01:00
                                        grohe-smarthome.0
                                        2026-03-13 22:34:46.841	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967: filter 66% from 1966l (capacity=3000l, device-reported=66%)
                                        grohe-smarthome.0
                                        2026-03-13 22:34:46.840	info	Blue 449183f7-11b5-4c25-a063-3361bad8b967: fresh data from /details (old=2026-03-13T22:29:35.000+01:00, new=2026-03-13T22:34:36.000+01:00, remaining_filter=66, remaining_co2=32)
                                        grohe-smarthome.0
                                        2026-03-13 22:34:36.326	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1966, remaining_co2=32, remaining_co2_liters=18, timestamp=2026-03-13T22:29:35.000+01:00
                                        grohe-smarthome.0
                                        2026-03-13 22:34:36.325	debug	Triggered measurement refresh for Blue 449183f7-11b5-4c25-a063-3361bad8b967
                                        grohe-smarthome.0
                                        2026-03-13 22:34:36.106	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967: filter 66% from 1966l (capacity=3000l, device-reported=66%)
                                        grohe-smarthome.0
                                        2026-03-13 22:34:36.105	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12190,"open_close_cycles_still":12864,"operating_time":28171,"power_cut_count":41,"pump_count":19690,"pump_running_time":2906,"remaining_co2":32,"remaining_filter":66,"time_since_last_withdrawal":199,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-13T22:29:35.000+01:00","water_running_time_carbonated":3292,"water_running_time_medium":24,"water_running_time_still":242,"remaining_filter_liters":1966,"remaining_co2_liters":18}
                                        grohe-smarthome.0
                                        2026-03-13 22:34:35.082	debug	[auth] token refresh successful (access: eyJhbG...QIVQ)
                                        grohe-smarthome.0
                                        2026-03-13 22:34:34.928	debug	[auth] refreshing tokens
                                        Ich habe allerdings heute auch kaum Wasser gezapft. Morgen bin ich den ganzen Tag unterwegs und nur bis ca 10 und kurz abends zuhause. Mal schauen ob sich was ändert, wenn mehr Wasser gezapft wird.
                                        Ich hatte den Adapter komplett gelöscht und neu über den github link installiert
                                          patricknitsch
                                          #84
                                          Langsam weis ich da auch nicht weiter. Vor allem warum es nur der eine Wert ist. Ich hab halt leider auch keine Blue um es selbst zu testen.
                                          Systeme:
