  4. Grohe - Sense / Guard /Blue - Adapter
    6.8k
133 Beiträge 3 Kommentatoren 7.7k Aufrufe 4 Beobachtet
  • patricknitschP Online
    patricknitsch
    dann beobachte mal, ob er beim nächsten Messimpuls ebenfalls kein Wasser mehr schickt.
    Systeme:
    • Proxmox 1 mit ioBroker, HomeAssistant, piHole
    • Proxmox 2 mit SOLECTRUS, Mosquitto, piHole und Frigate
    • RPi4 mit Octoprint
    Eigene Adapter: grohe-smarthome, solectrus-influxdb, schlueter-thermostat
      M-A-X
      schrieb am zuletzt editiert von M-A-X
      War zufällig gerade der Fall. Kein Wasser kam:
      grohe-smarthome.0
      2026-03-11 17:46:03.090	debug	Blue XXXXX raw: remaining_filter=66, remaining_filter_liters=1984, remaining_co2=63, remaining_co2_liters=35, timestamp=2026-03-11T17:45:52.000+01:00
      grohe-smarthome.0
      2026-03-11 17:46:03.089	info	Blue XXXXX: fresh data from /details (old=2026-03-11T17:45:27.000+01:00, new=2026-03-11T17:45:52.000+01:00, remaining_filter=66, remaining_co2=63)
      grohe-smarthome.0
      2026-03-11 17:45:52.619	debug	Blue XXXXX raw: remaining_filter=66, remaining_filter_liters=1984, remaining_co2=63, remaining_co2_liters=35, timestamp=2026-03-11T17:45:27.000+01:00
      grohe-smarthome.0
      2026-03-11 17:45:52.618	debug	Triggered measurement refresh for Blue XXXXX
      grohe-smarthome.0
      2026-03-11 17:45:52.219	debug	Blue XXXXX /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12160,"open_close_cycles_still":12830,"operating_time":28118,"power_cut_count":41,"pump_count":19642,"pump_running_time":2898,"remaining_co2":63,"remaining_filter":66,"time_since_last_withdrawal":3,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T17:45:27.000+01:00","water_running_time_carbonated":3283,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1984,"remaining_co2_liters":35}
      grohe-smarthome.0
      2026-03-11 17:45:52.218	debug	Blue XXXXX /details data_latest keys: ["measurement"]
      grohe-smarthome.0
      2026-03-11 17:45:52.217	debug	Blue XXXXX /details raw response keys: ["appliance_id","installation_date","name","serial_number","type","version","tdt","timezone","config","role","registration_complete","presharedkey","params","error","state","status","data_latest","notifications"]
      grohe-smarthome.0
      2026-03-11 17:45:51.881	debug	Blue XXXXX /dashboard measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12160,"open_close_cycles_still":12830,"operating_time":28118,"power_cut_count":41,"pump_count":19642,"pump_running_time":2898,"remaining_co2":63,"remaining_filter":66,"time_since_last_withdrawal":3,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T17:45:27.000+01:00","water_running_time_carbonated":3283,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1984,"remaining_co2_liters":35}
      grohe-smarthome.0
      2026-03-11 17:45:51.400	debug	Poll cycle #3 (status=false, command=true, pressure=false, consumption=false)
      grohe-smarthome.0
      2026-03-11 17:45:26.749	info	Dispensing: type=0 amount=0ml for 449183f7-11b5-4c25-a063-3361bad8b967
      Die "Tap" Werte sind immernoch 0, Zeitstempel immer noch von meiner manuellen Änderung
        patricknitsch
        Ok. Dann weis ich jetzt, wo ich ansetzen muss.
        Systeme:
          patricknitsch
          Bitte nochmal neu installieren mit der aktuellen Version. Setze davor bitte mal beide Datenpunkte auf einen Wert. Nach Neuinstallation und Neustart müssten beide Werte sofort auf 0 gehen. Dasselbe, wenn du die Wasserabgabe triggerst.
          Systeme:
            M-A-X
            Ja, passt. Hatte die auf 50 und 1 gesetzt. Nach installation (und start) waren beide auf 0.
            Manuell wieder auf 50 und 1 -> dispenseTrigger gedrückt (Wasser bezogen) -> beide wieder auf 0.
              patricknitsch
              Sehr gut! Bitte noch beobachten. Filter und CO2 stimmen mit App überein?
              Systeme:
                M-A-X
                So in etwa. App 59 / 63 % und Adapter 59 / 66 %
                  patricknitsch
                  Eine gewisse Verzögerung sind bei den Werten immer dabei. Die App zeigt die Werte direkt an, der Adapter holt sich diese ja nur alle 15 Minuten. Große Abweichungen sollten aber nicht dabei sein.
                  Systeme:
                    M-A-X
                    Ich benutze seit einiger Zeit den Hahn nicht (ca 1 Stunde). Trotzdem weichen die Filterwerte (immer noch) um 3% ab.
                    Da ich die app aber eh benutze bekomme ich nen push, wenn der fällig ist. Kann aber gerne weiter Feedback geben, wenn du was testen möchtest.
                      patricknitsch
                      Du kannst mir gerne im Debug den aktuellen Log schicken.
                      Systeme:
                        M-A-X
                        so? und muss ich diese lange Grohe Nummer immer "schwärzen" oder ist die eh unwichtig :)
                        rohe-smarthome.0
                        2026-03-11 19:23:39.230	debug	Blue XXXXX raw: remaining_filter=66, remaining_filter_liters=1982, remaining_co2=59, remaining_co2_liters=33, timestamp=2026-03-11T19:18:38.000+01:00
                        grohe-smarthome.0
                        2026-03-11 19:23:39.230	debug	Blue XXXXX /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28119,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":69,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T19:18:38.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                        grohe-smarthome.0
                        2026-03-11 19:23:39.229	debug	Blue XXXXX /details data_latest keys: ["measurement"]
                        grohe-smarthome.0
                        2026-03-11 19:23:39.228	debug	Blue XXXXX /details raw response keys: ["appliance_id","installation_date","name","serial_number","type","version","tdt","timezone","config","role","registration_complete","presharedkey","params","error","state","status","data_latest","notifications"]
                        grohe-smarthome.0
                        2026-03-11 19:23:38.746	debug	Blue XXXXX /dashboard measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28119,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":69,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T19:18:38.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                        grohe-smarthome.0
                        2026-03-11 19:23:38.169	debug	Poll cycle #16 (status=false, command=false, pressure=false, consumption=false)
                        grohe-smarthome.0
                        2026-03-11 19:18:48.196	debug	Blue XXXXX raw: remaining_filter=66, remaining_filter_liters=1982, remaining_co2=59, remaining_co2_liters=33, timestamp=2026-03-11T19:18:38.000+01:00
                        grohe-smarthome.0
                        2026-03-11 19:18:48.195	info	Blue XXXXX: fresh data from /details (old=2026-03-11T19:03:33.000+01:00, new=2026-03-11T19:18:38.000+01:00, remaining_filter=66, remaining_co2=59)
                        grohe-smarthome.0
                        2026-03-11 19:18:37.744	debug	Blue XXXXX raw: remaining_filter=66, remaining_filter_liters=1982, remaining_co2=59, remaining_co2_liters=33, timestamp=2026-03-11T19:03:33.000+01:00
                        grohe-smarthome.0
                        2026-03-11 19:18:37.743	debug	Triggered measurement refresh for Blue XXXXX
                        grohe-smarthome.0
                        2026-03-11 19:18:37.510	debug	Blue XXXXX /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28119,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":54,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T19:03:33.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                        grohe-smarthome.0
                        2026-03-11 19:18:37.510	debug	Blue XXXXX /details data_latest keys: ["measurement"]
                        grohe-smarthome.0
                        2026-03-11 19:18:37.509	debug	Blue XXXXX /details raw response keys: ["appliance_id","installation_date","name","serial_number","type","version","tdt","timezone","config","role","registration_complete","presharedkey","params","error","state","status","data_latest","notifications"]
                        grohe-smarthome.0
                        2026-03-11 19:18:37.058	debug	Blue XXXXX /dashboard measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28119,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":54,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T19:03:33.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                        grohe-smarthome.0
                        2026-03-11 19:18:36.339	debug	Poll cycle #15 (status=true, command=true, pressure=false, consumption=true)
                        grohe-smarthome.0
                        2026-03-11 19:13:35.908	debug	Blue XXXXX raw: remaining_filter=66, remaining_filter_liters=1982, remaining_co2=59, remaining_co2_liters=33, timestamp=2026-03-11T19:03:33.000+01:00
                        grohe-smarthome.0
                        2026-03-11 19:13:35.908	debug	Blue XXXXX /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28119,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":54,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T19:03:33.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                        grohe-smarthome.0
                        2026-03-11 19:13:35.907	debug	Blue XXXXX /details data_latest keys: ["measurement"]
                        grohe-smarthome.0
                        2026-03-11 19:13:35.906	debug	Blue XXXXX /details raw response keys: ["appliance_id","installation_date","name","serial_number","type","version","tdt","timezone","config","role","registration_complete","presharedkey","params","error","state","status","data_latest","notifications"]
                        grohe-smarthome.0
                        2026-03-11 19:13:35.564	debug	Blue XXXXX /dashboard measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28119,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":54,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T19:03:33.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                        grohe-smarthome.0
                        2026-03-11 19:13:35.101	debug	Poll cycle #14 (status=false, command=false, pressure=false, consumption=false)
                        grohe-smarthome.0
                        2026-03-11 19:08:34.828	debug	Blue XXXXX raw: remaining_filter=66, remaining_filter_liters=1982, remaining_co2=59, remaining_co2_liters=33, timestamp=2026-03-11T19:03:33.000+01:00
                        grohe-smarthome.0
                        2026-03-11 19:08:34.827	debug	Blue XXXXX /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28119,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":54,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T19:03:33.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                        grohe-smarthome.0
                        2026-03-11 19:08:34.826	debug	Blue XXXXX /details data_latest keys: ["measurement"]
                        grohe-smarthome.0
                        2026-03-11 19:08:34.825	debug	Blue XXXXX /details raw response keys: ["appliance_id","installation_date","name","serial_number","type","version","tdt","timezone","config","role","registration_complete","presharedkey","params","error","state","status","data_latest","notifications"]
                        grohe-smarthome.0
                        2026-03-11 19:08:34.389	debug	Blue XXXXX /dashboard measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28119,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":54,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T19:03:33.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                        grohe-smarthome.0
                        2026-03-11 19:08:33.893	debug	Poll cycle #13 (status=false, command=false, pressure=false, consumption=false)
                        grohe-smarthome.0
                        2026-03-11 19:03:43.959	debug	Blue XXXXX raw: remaining_filter=66, remaining_filter_liters=1982, remaining_co2=59, remaining_co2_liters=33, timestamp=2026-03-11T19:03:33.000+01:00
                        grohe-smarthome.0
                        2026-03-11 19:03:43.955	info	Blue XXXXX: fresh data from /details (old=2026-03-11T18:43:30.000+01:00, new=2026-03-11T19:03:33.000+01:00, remaining_filter=66, remaining_co2=59)
                        grohe-smarthome.0
                        2026-03-11 19:03:33.537	debug	Blue XXXXX raw: remaining_filter=66, remaining_filter_liters=1982, remaining_co2=59, remaining_co2_liters=33, timestamp=2026-03-11T18:43:30.000+01:00
                        grohe-smarthome.0
                        2026-03-11 19:03:33.536	debug	Triggered measurement refresh for Blue XXXXX
                        grohe-smarthome.0
                        2026-03-11 19:03:33.282	debug	Blue XXXXX /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28119,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":34,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T18:43:30.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                        grohe-smarthome.0
                        2026-03-11 19:03:33.282	debug	Blue XXXXX /details data_latest keys: ["measurement"]
                        grohe-smarthome.0
                        2026-03-11 19:03:33.281	debug	Blue XXXXX /details raw response keys: ["appliance_id","installation_date","name","serial_number","type","version","tdt","timezone","config","role","registration_complete","presharedkey","params","error","state","status","data_latest","notifications"]
                        grohe-smarthome.0
                        2026-03-11 19:03:32.891	debug	Blue XXXXX /dashboard measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28119,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":34,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T18:43:30.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                        grohe-smarthome.0
                        2026-03-11 19:03:32.356	debug	[auth] token refresh successful (access: eyJhbG...IkIg)
                        grohe-smarthome.0
                        2026-03-11 19:03:32.191	debug	[auth] refreshing tokens
                        grohe-smarthome.0
                        2026-03-11 19:03:32.190	debug	Poll cycle #12 (status=false, command=true, pressure=false, consumption=false)
                        grohe-smarthome.0
                        2026-03-11 18:58:31.969	debug	Blue XXXXX raw: remaining_filter=66, remaining_filter_liters=1982, remaining_co2=59, remaining_co2_liters=33, timestamp=2026-03-11T18:43:30.000+01:00
                        grohe-smarthome.0
                        2026-03-11 18:58:31.969	debug	Blue XXXXX /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28119,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":34,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T18:43:30.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                        grohe-smarthome.0
                        2026-03-11 18:58:31.969	debug	Blue XXXXX /details data_latest keys: ["measurement"]
                        grohe-smarthome.0
                        2026-03-11 18:58:31.968	debug	Blue XXXXX /details raw response keys: ["appliance_id","installation_date","name","serial_number","type","version","tdt","timezone","config","role","registration_complete","presharedkey","params","error","state","status","data_latest","notifications"]
                        grohe-smarthome.0
                        2026-03-11 18:58:31.390	debug	Blue XXXXX /dashboard measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28119,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":34,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T18:43:30.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                        grohe-smarthome.0
                        2026-03-11 18:58:31.386	info	Polling recovered after 1 error(s), interval reset to 300s
                        grohe-smarthome.0
                        2026-03-11 18:58:30.852	debug	Poll cycle #11 (status=false, command=false, pressure=false, consumption=false)
                        grohe-smarthome.0
                        2026-03-11 18:48:30.851	warn	Polling failed: Request failed with status code 500. Next try at 18:58:30 (interval: 600s, errors: 1)
                        grohe-smarthome.0
                        2026-03-11 18:48:30.694	debug	Poll cycle #10 (status=true, command=false, pressure=true, consumption=true)
                        grohe-smarthome.0
                        2026-03-11 18:43:40.997	debug	Blue XXXXX raw: remaining_filter=66, remaining_filter_liters=1982, remaining_co2=59, remaining_co2_liters=33, timestamp=2026-03-11T18:43:30.000+01:00
                        grohe-smarthome.0
                        2026-03-11 18:43:40.996	info	Blue XXXXX: fresh data from /details (old=2026-03-11T18:28:26.000+01:00, new=2026-03-11T18:43:30.000+01:00, remaining_filter=66, remaining_co2=59)
                        grohe-smarthome.0
                        2026-03-11 18:43:30.474	debug	Blue XXXXX raw: remaining_filter=66, remaining_filter_liters=1982, remaining_co2=59, remaining_co2_liters=33, timestamp=2026-03-11T18:28:26.000+01:00
                        grohe-smarthome.0
                        2026-03-11 18:43:30.474	debug	Triggered measurement refresh for Blue XXXXX
                        grohe-smarthome.0
                        2026-03-11 18:43:30.205	debug	Blue XXXXX /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28119,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":19,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T18:28:26.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                        grohe-smarthome.0
                        2026-03-11 18:43:30.204	debug	Blue XXXXX /details data_latest keys: ["measurement"]
                        grohe-smarthome.0
                        2026-03-11 18:43:30.203	debug	Blue XXXXX /details raw response keys: ["appliance_id","installation_date","name","serial_number","type","version","tdt","timezone","config","role","registration_complete","presharedkey","params","error","state","status","data_latest","notifications"]
                        grohe-smarthome.0
                        2026-03-11 18:43:29.749	debug	Blue XXXXX /dashboard measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28119,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":19,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T18:28:26.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                        grohe-smarthome.0
                        2026-03-11 18:43:29.345	debug	Poll cycle #9 (status=false, command=true, pressure=false, consumption=false)
                        grohe-smarthome.0
                        2026-03-11 18:38:29.116	debug	Blue XXXXX raw: remaining_filter=66, remaining_filter_liters=1982, remaining_co2=59, remaining_co2_liters=33, timestamp=2026-03-11T18:28:26.000+01:00
                        grohe-smarthome.0
                        2026-03-11 18:38:29.115	debug	Blue XXXXX /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28119,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":19,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T18:28:26.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                        grohe-smarthome.0
                        2026-03-11 18:38:29.115	debug	Blue XXXXX /details data_latest keys: ["measurement"]
                        grohe-smarthome.0
                        2026-03-11 18:38:29.114	debug	Blue XXXXX /details raw response keys: ["appliance_id","installation_date","name","serial_number","type","version","tdt","timezone","config","role","registration_complete","presharedkey","params","error","state","status","data_latest","notifications"]
                        grohe-smarthome.0
                        2026-03-11 18:38:28.469	debug	Blue XXXXX /dashboard measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28119,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":19,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T18:28:26.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                        grohe-smarthome.0
                        2026-03-11 18:38:27.878	debug	Poll cycle #8 (status=false, command=false, pressure=false, consumption=false)
                        grohe-smarthome.0
                        2026-03-11 18:33:27.637	debug	Blue XXXXX raw: remaining_filter=66, remaining_filter_liters=1982, remaining_co2=59, remaining_co2_liters=33, timestamp=2026-03-11T18:28:26.000+01:00
                        grohe-smarthome.0
                        2026-03-11 18:33:27.637	debug	Blue XXXXX /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28119,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":19,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T18:28:26.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                        grohe-smarthome.0
                        2026-03-11 18:33:27.636	debug	Blue XXXXX /details data_latest keys: ["measurement"]
                        grohe-smarthome.0
                        2026-03-11 18:33:27.635	debug	Blue XXXXX /details raw response keys: ["appliance_id","installation_date","name","serial_number","type","version","tdt","timezone","config","role","registration_complete","presharedkey","params","error","state","status","data_latest","notifications"]
                        grohe-smarthome.0
                        2026-03-11 18:33:27.089	debug	Blue XXXXX /dashboard measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28119,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":19,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T18:28:26.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                        grohe-smarthome.0
                        2026-03-11 18:33:26.641	debug	Poll cycle #7 (status=false, command=false, pressure=false, consumption=false)
                        grohe-smarthome.0
                        2026-03-11 18:28:37.059	debug	Blue XXXXX raw: remaining_filter=66, remaining_filter_liters=1982, remaining_co2=59, remaining_co2_liters=33, timestamp=2026-03-11T18:28:26.000+01:00
                        grohe-smarthome.0
                        2026-03-11 18:28:37.058	info	Blue XXXXX: fresh data from /details (old=2026-03-11T18:13:21.000+01:00, new=2026-03-11T18:28:26.000+01:00, remaining_filter=66, remaining_co2=59)
                        grohe-smarthome.0
                        2026-03-11 18:28:26.344	debug	Blue XXXXX raw: remaining_filter=66, remaining_filter_liters=1982, remaining_co2=59, remaining_co2_liters=33, timestamp=2026-03-11T18:13:21.000+01:00
                          patricknitsch
                          Passt danke. Musst du nicht unbedingt. Wichtig ist, dass deine Anmeldedaten und der Token nicht sichtbar sind.
                          Systeme:
                            M-A-X
                            Der wird ja unkenntlich gemacht im log (Es fehlen in der Mitte alle Zeichen).
                            Danke. Das spart mir das manuellen "bereinigen"
                            EDIT: Github machst du selber zu, wenn du die Version einpflegst?
                              patricknitsch
                              schrieb am zuletzt editiert von patricknitsch
                              Ja. Mach bitte nochmal einen Test mit der neuen Version(auch mit dem dispenseTrigger). Hab den Datenabruf noch etwas angepasst. Werde die Version dann aber pushen. Dein Issue mache ich zu, sobald die Version online ist.
                              Systeme:
                                M-A-X
                                erledigt. Tap Werte auf 50 / 1 -> Adapter neu drüber installiert über den github Link (Katze), dispenseTrigger gedrückt -> Wasser kam -> tap Werte wurden auf 0 gesetzt.
                                grohe-smarthome.0
                                2026-03-11 20:19:08.674	info	Dispensing: type=1 amount=50ml for 449183f7-11b5-4c25-a063-3361bad8b967
                                grohe-smarthome.0
                                2026-03-11 20:19:05.600	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1982, remaining_co2=59, remaining_co2_liters=33, timestamp=2026-03-11T20:18:55.000+01:00
                                grohe-smarthome.0
                                2026-03-11 20:19:05.599	info	Blue 449183f7-11b5-4c25-a063-3361bad8b967: fresh data from /details (old=2026-03-11T20:03:50.000+01:00, new=2026-03-11T20:18:55.000+01:00, remaining_filter=66, remaining_co2=59)
                                grohe-smarthome.0
                                2026-03-11 20:18:55.238	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 raw: remaining_filter=66, remaining_filter_liters=1982, remaining_co2=59, remaining_co2_liters=33, timestamp=2026-03-11T20:03:50.000+01:00
                                grohe-smarthome.0
                                2026-03-11 20:18:55.237	debug	Triggered measurement refresh for Blue 449183f7-11b5-4c25-a063-3361bad8b967
                                grohe-smarthome.0
                                2026-03-11 20:18:54.920	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28120,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":114,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T20:03:50.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                                grohe-smarthome.0
                                2026-03-11 20:18:54.920	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details data_latest keys: ["measurement"]
                                grohe-smarthome.0
                                2026-03-11 20:18:54.919	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /details raw response keys: ["appliance_id","installation_date","name","serial_number","type","version","tdt","timezone","config","role","registration_complete","presharedkey","params","error","state","status","data_latest","notifications"]
                                grohe-smarthome.0
                                2026-03-11 20:18:54.359	debug	Blue 449183f7-11b5-4c25-a063-3361bad8b967 /dashboard measurement: {"cleaning_count":2,"date_of_cleaning":"2025-06-14T10:39:09.000+02:00","date_of_co2_replacement":"2026-03-09T12:26:37.000+01:00","date_of_filter_replacement":"2025-10-29T17:49:00.000+01:00","filter_change_count":11,"max_idle_time":21776,"open_close_cycles_carbonated":12164,"open_close_cycles_still":12835,"operating_time":28120,"power_cut_count":41,"pump_count":19648,"pump_running_time":2899,"remaining_co2":59,"remaining_filter":66,"time_since_last_withdrawal":114,"time_since_restart":8948122,"timeoffset":60,"timestamp":"2026-03-11T20:03:50.000+01:00","water_running_time_carbonated":3284,"water_running_time_medium":24,"water_running_time_still":241,"remaining_filter_liters":1982,"remaining_co2_liters":33}
                                grohe-smarthome.0
                                2026-03-11 20:18:53.758	debug	Poll cycle #27 (status=false, command=true, pressure=false, consumption=false)
                                  patricknitsch
                                  #66
                                  Danke fürs Testen. Version 0.2.6 gebe ich frei, sollte ab morgen im Latest sein. Sollte es weitere Probleme geben, gib Bescheid :)
                                  Systeme:
                                    M-A-X
                                    #67
                                    Dank dir für die schnelle Hilfe. Ich werde die nächsten Tage ausgiebig testen. Dann sollte auch die % Zahl von Filter und CO2 sinken und ich kann berichten ob alles passt.
                                      M-A-X
                                      #68
                                      Als kleine Rückmeldung: das dispenseTrigger Problem scheint behoben (hab mittlerweile die 0.2.6 drauf).
                                      Mein Filter zeigt jedoch immernoch 66% in den Objekten, während er in der App von 63 auf 62% runter gegangen ist. CO2 ist mittlerweile von 59 auf 39 Prüzent gesunken. Das wird sowohl in der App als auch in den Iobroker Objekten korrekt angezeigt.
                                      Der "zuletzt geändert" Zeitstempel der Filteranzeige ist der Zeitpunkt der Adapterinstallation (11.03. Mittags).
                                        patricknitsch
                                        #69
                                        Das Thema höre ich jetzt schon zum zweiten Mal. Versuch es mal bitte damit :
                                        https://github.com/patricknitsch/ioBroker.grohe-smarthome/tree/copilot/fix-filterstatus-update
                                        Systeme:
                                          M-A-X
                                          #70
                                          Bevor ich das installiere (kann ich von unterwegs). Die fixe von 0.2.6 sind schon drin? :)
                                          EDIT: bin jetzt zuhause und habe die github version mal installiert. Direkt nach dem Start bisher keine Änderung (immer noch 66%). Ich lasse ihn mal laufen (300 sekunden?)
                                          EDIT2: Habe getestet. sollte auf 0.2.6 aufbauen :)
