  4. Alexa2 - Adapter / "Die Webseite ist nicht erreichbar"
    6.3k
27 Beiträge 7 Kommentatoren 1.6k Aufrufe 5 Beobachtet
  • samoht0403S samoht0403
    Danke, das wusste ich nicht.
    Hoffe, dass es dann so passt:
    2026-01-03 11:27:06.438  - info: host.iobroker instance system.adapter.alexa2.0 in version "3.27.4" started with pid xxxx
    2026-01-03 11:27:07.028  - debug: alexa2.0 (249760) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2026-01-03 11:27:07.056  - debug: alexa2.0 (249760) Objects client ready ... initialize now
    2026-01-03 11:27:07.058  - debug: alexa2.0 (249760) Objects create System PubSub Client
    2026-01-03 11:27:07.058  - debug: alexa2.0 (249760) Objects create User PubSub Client
    2026-01-03 11:27:07.100  - debug: alexa2.0 (249760) Objects client initialize lua scripts
    2026-01-03 11:27:07.103  - debug: alexa2.0 (249760) Objects connected to redis: 0.0.0.0:9001
    2026-01-03 11:27:07.127  - debug: alexa2.0 (249760) Redis States: Use Redis connection: 0.0.0.0:9000
    2026-01-03 11:27:07.140  - debug: alexa2.0 (249760) States create System PubSub Client
    2026-01-03 11:27:07.141  - debug: alexa2.0 (249760) States create User PubSub Client
    2026-01-03 11:27:07.211  - debug: alexa2.0 (249760) States connected to redis: 0.0.0.0:9000
    2026-01-03 11:27:07.242  - debug: alexa2.0 (249760) Plugin sentry Initialize Plugin (enabled=true)
    2026-01-03 11:27:07.521  - info: alexa2.0 (249760) starting. Version 3.27.4 in /opt/iobroker/node_modules/iobroker.alexa2, node: v22.21.0, js-controller: 7.0.7
    2026-01-03 11:27:07.541  - info: alexa2.0 (249760) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
    2026-01-03 11:27:07.542  - debug: alexa2.0 (249760) Update History Interval: 300s
    2026-01-03 11:27:07.542  - debug: alexa2.0 (249760) Update Device State Interval: 306s
    2026-01-03 11:27:07.542  - debug: alexa2.0 (249760) Update Devices Configuration Interval: 3605s
    2026-01-03 11:27:07.543  - debug: alexa2.0 (249760) Alexa-Remote: Use as User-Agent: Chrome/103.0.0.0
    2026-01-03 11:27:07.543  - debug: alexa2.0 (249760) Alexa-Remote: Use as API User-Agent Postfix: iBrokAlxa2/3.27.4
    2026-01-03 11:27:07.543  - debug: alexa2.0 (249760) Alexa-Remote: Use as Login-Amazon-URL: amazon.de
    2026-01-03 11:27:07.543  - debug: alexa2.0 (249760) Alexa-Remote: Use as Base-URL: alexa.amazon.de
    2026-01-03 11:27:07.543  - debug: alexa2.0 (249760) Alexa-Remote: No cookie given, generate one
    2026-01-03 11:27:07.615  - debug: alexa2.0 (249760) Alexa-Cookie: Use as Login-Amazon-URL: amazon.de
    2026-01-03 11:27:07.615  - debug: alexa2.0 (249760) Alexa-Cookie: Use as Base-Amazon-URL: amazon.com
    2026-01-03 11:27:07.616  - debug: alexa2.0 (249760) Alexa-Cookie: Use as Device-App-Name: ioBroker Alexa2
    2026-01-03 11:27:07.616  - debug: alexa2.0 (249760) Alexa-Cookie: Use as User-Agent: Chrome/103.0.0.0
    2026-01-03 11:27:07.616  - debug: alexa2.0 (249760) Alexa-Cookie: Use as Accept-Language: de-DE
    2026-01-03 11:27:07.616  - debug: alexa2.0 (249760) Alexa-Cookie: Proxy-Mode enabled if needed: 192.168.2.150:xxxxx to listen on 192.168.2.150
    2026-01-03 11:27:07.627  - debug: alexa2.0 (249760) Alexa-Cookie: Proxy-Server listening on port xxxxx
    2026-01-03 11:27:07.627  - debug: alexa2.0 (249760) Alexa-Remote: Error from retrieving cookies
    2026-01-03 11:27:07.628  - debug: alexa2.0 (249760) Error from Alexa init: Please open http://192.168.2.150:xxxxx/ with your browser and login to Amazon. The cookie will be output here after successfull login.
    2026-01-03 11:27:07.628  - error: alexa2.0 (249760) Error:
    2026-01-03 11:27:07.628  - error: alexa2.0 (249760) Error: Please open http://192.168.2.150:xxxxx/ with your browser and login to Amazon. The cookie will be output here after successfull login.
    2026-01-03 11:27:07.678  - info: host.iobroker stopInstance system.adapter.alexa2.0 (force=false, process=true)
    2026-01-03 11:27:07.681  - info: alexa2.0 (249760) Got terminate signal TERMINATE_YOURSELF
    2026-01-03 11:27:07.682  - info: alexa2.0 (249760) terminating
    2026-01-03 11:27:07.683  - debug: alexa2.0 (249760) Plugin sentry destroyed
    2026-01-03 11:27:07.684  - info: alexa2.0 (249760) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-01-03 11:27:07.748  - debug: alexa2.0 (249760) Router: / / GET / {"host":"192.168.2.150:xxxxx","connection":"keep-alive","upgrade-insecure-requests":"1",xxx
    2026-01-03 11:27:07.748  - debug: alexa2.0 (249760) Alexa-Cookie: Initial Page Request: https://www.amazon.com/ap/xxx
    2026-01-03 11:27:07.773  - debug: alexa2.0 (249760) Alexa-Cookie: Proxy-Request: GET /
    2026-01-03 11:27:07.773  - debug: alexa2.0 (249760) Alexa-Cookie: Headers: {"cookie":xxx}
    2026-01-03 11:27:07.774  - debug: alexa2.0 (249760) Alexa-Cookie: Headers: {"cookie":xxx}
    2026-01-03 11:27:07.780  - info: host.iobroker stopInstance system.adapter.alexa2.0 send kill signal
    2026-01-03 11:27:07.964  - debug: alexa2.0 (249760) Alexa-Cookie: Proxy Response from Host: www.amazon.com
    2026-01-03 11:27:07.965  - debug: alexa2.0 (249760) Alexa-Cookie: Cookies handled: xxx
    2026-01-03 11:27:07.986  - debug: alexa2.0 (249760) Alexa-Cookie: MODIFIED Response Body to rewrite URLs
    2026-01-03 11:27:07.987  - debug: alexa2.0 (249760)
    2026-01-03 11:27:08.151  - debug: alexa2.0 (249760) Router: /uedata/uedata?l xxx}
    2026-01-03 11:27:08.153  - debug: alexa2.0 (249760) Alexa-Cookie: Headers: {"cookie":xxx}
    2026-01-03 11:27:08.184  - info: alexa2.0 (249760) terminating
    2026-01-03 11:27:08.228  - info: host.iobroker instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2026-01-03 11:27:11.499  - info: host.iobroker instance system.adapter.alexa2.0 in version "3.27.4" started with pid xxxxx
    2026-01-03 11:27:12.121  - debug: alexa2.0 (249919) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2026-01-03 11:27:12.150  - debug: alexa2.0 (249919) Objects client ready ... initialize now
    2026-01-03 11:27:12.151  - debug: alexa2.0 (249919) Objects create System PubSub Client
    2026-01-03 11:27:12.152  - debug: alexa2.0 (249919) Objects create User PubSub Client
    2026-01-03 11:27:12.195  - debug: alexa2.0 (249919) Objects client initialize lua scripts
    2026-01-03 11:27:12.198  - debug: alexa2.0 (249919) Objects connected to redis: 0.0.0.0:9001
    2026-01-03 11:27:12.222  - debug: alexa2.0 (249919) Redis States: Use Redis connection: 0.0.0.0:9000
    2026-01-03 11:27:12.279  - debug: alexa2.0 (249919) States create System PubSub Client
    2026-01-03 11:27:12.280  - debug: alexa2.0 (249919) States create User PubSub Client
    2026-01-03 11:27:12.363  - debug: alexa2.0 (249919) States connected to redis: 0.0.0.0:9000
    2026-01-03 11:27:12.385  - debug: alexa2.0 (249919) Plugin sentry Initialize Plugin (enabled=true)
    2026-01-03 11:27:12.529  - info: alexa2.0 (249919) starting. Version 3.27.4 in /opt/iobroker/node_modules/iobroker.alexa2, node: v22.21.0, js-controller: 7.0.7
    2026-01-03 11:27:12.544  - info: alexa2.0 (249919) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
    2026-01-03 11:27:12.545  - error: alexa2.0 (249919) Adapter seems to have issues and crashed three times in a row. Disabling!! Please start again and check logs.
    2026-01-03 11:27:13.545  - debug: alexa2.0 (249919) Plugin sentry destroyed
    2026-01-03 11:27:13.546  - info: alexa2.0 (249919) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2026-01-03 11:27:14.089  - info: host.iobroker instance system.adapter.alexa2.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2026-01-03 11:27:14.089  - info: host.iobroker Do not restart adapter system.adapter.alexa2.0 because desired by instance
    @samoht0403 sagte in Alexa2 - Adapter / "Die Webseite ist nicht erreichbar":
    ich auch! 😉
    bin jetzt aber raus, weil ich sooo tief nicht drinstecke.
    Vielleicht kann @apollon77 oder jemand anders weiterhelfen
    • samoht0403S Offline
      samoht0403S Offline
      samoht0403
      schrieb am zuletzt editiert von samoht0403
      Ich danke Dir trotzdem wirklich - auch für das "auf die Finger hauen" :-)
        samoht0403S Offline
        samoht0403
        @homoran: was sagst Du, soll der Beitrag hier bleiben, wollt ihr ihn verschieben oder soll ich ihn neu eröffnen (ohne persönliche Daten ;-)) als bug beim Adapter?
          Wer sagt denn das das ein Bug und keine Fehlkonfiguration ist?
          die 3.27.4
          github:	3.27.4 for 50 days
          latest:	3.27.4 for 59 days
          stable:	3.27.4 for 59 days
          ist bereits so lange verfügbar, und du meldest es jetzt erst.
          oder hast du von github installiert?
            samoht0403S Offline
            samoht0403
            Es sagt niemand, dass das keine Fehlkonfiguration ist, aber wir (ich) wissen nicht, warum der Abruf des Cookies nicht klappt. Ich habe nicht von GitHub installiert, habe extra nochmal nachgeschaut. Warum ich das Problem erst jetzt melde: weil ich es erst jetzt habe (seit 01.01.2026). Wenn es keine Lösung gibt, spiele ich vielleicht nochmal ein Backup vom letzten Jahr auf, auch wenn ich dann paar Sachen nochmal nacharbeiten muss.
              Missverständnis!!
              Aussage war: Die Version ist bereits seit 59 Tagen in den Repos. Bei einem Bug hätte es längst Gemecker geben müssen.
              gut! Da wäre möglicherweise ein neuer Code drauf gewesen, der noch nicht getestet wurde.
              Dazu müsste jemand, der tiefer im System sitzt s7ch deine restlichen relevanten Komponenten und de7ne Konfigurationen mal näher ansehen.
              Aber ds geht nicht unbedingt in 12h
                samoht0403S Offline
                samoht0403
                ok, das verstehe und teile ich. Ich habe nur bei den Rezensionen gesehen, dass es da Ende 2025 zwei 1 Sterne - Bewertungen bei der 3.27.4 gab mit der Begründung "Anmeldung geht nicht" und bei 3.27.3 auch (die wurden aber mit 3.27.4. gefixt). Ich warte mal, ob jemand mit aufspringt auf diesen Beitrag.
                  samoht0403S Offline
                  samoht0403
                  @homoran und vielleicht auch interessant für @apollon77 und weitere Lesende: das Problem hat sich erledigt, als ich einen Windows-11-Rechner zum Einrichten des Adapters genutzt habe. Damit kam das Cookie über die im log angegebene URL
                  • H Offline
                    hellrider2001
                    Moin zusammen, ich springe mal auf den Zug mit auf. Seit gestern verbindet der Adapter nicht mehr ordentlich. Ich wollte die Cookies zurücksetzen und neu verbinden. Beim Abrufen des im Adapter aufgezeigten Links werde ich auf die IP meines ioBroker-Rechners mit Port 40345 weitergeleitet. Eine Verbidung kann dann nicht aufgebaut werden.
                    Installierter Alexa2.0 Adapter v3.27.4
                    • H hellrider2001
                      haselchenH Offline
                      haselchenH Offline
                      haselchen
                      @hellrider2001
                      Gib mal bitte
                      iob diag
                      in der Langfassung
                      Sonst müsste man alles haarklein erfragen.
                      H 1 Antwort Letzte Antwort
                      • haselchenH haselchen
                        @hellrider2001
                        Gib mal bitte
                        iob diag
                        in der Langfassung
                        hellrider2001
                        @haselchen Sorry, war eine weile offline - nachfolgend der Output.
                        Script v.2026-01-31
                        *** BASE SYSTEM ***
                        Operating System: Ubuntu 24.04.4 LTS
                         Static hostname: ubuntu-iobroker
                               Icon name: computer-laptop
                                 Chassis: laptop 💻
                                  Kernel: Linux 6.8.0-106-generic
                            Architecture: x86-64
                         Hardware Vendor: Dell Inc.
                          Hardware Model: Latitude E6430
                        Firmware Version: A24
                           Firmware Date: Thu 2019-08-08
                            Firmware Age: 6y 7month 2w 2d
                        OS is similar to: debian
                        model name	: Intel(R) Core(TM) i5-3320M CPU @ 2.60GHz
                        Docker          : false
                        Virtualization  : none
                        Kernel          : x86_64
                        Userland        : 64 bit
                        Systemuptime and Load:
                         13:36:41 up  6:17,  1 user,  load average: 0.94, 0.64, 0.38
                        CPU threads: 4
                        *** LIFE CYCLE STATUS ***
                        Operating System is the current Ubuntu LTS release codenamed 'noble'!
                        *** TIME AND TIMEZONES ***
                                       Local time: Wed 2026-03-25 13:36:41 CET
                                   Universal time: Wed 2026-03-25 12:36:41 UTC
                                         RTC time: Wed 2026-03-25 12:36:41
                                      NTP service: active
                                  RTC in local TZ: no
                        *** Users and Groups ***
                        User that called 'iob diag':
                        abcd
                        HOME=/home/abcd
                        GROUPS=abcd adm cdrom sudo dip plugdev lxd iobroker
                        iobroker
                        HOME=/home/iobroker
                        GROUPS=iobroker tty dialout audio video plugdev redis
                        *** DISPLAY-SERVER SETUP ***
                        Display-Server: 	false
                        Unit display-manager.service could not be found.
                        Display-Manager:
                        Desktop:
                        Session: 		tty
                        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                        *** MEMORY ***
                        Mem:             16G        4.2G         10G        6.0M        2.1G         12G
                        Swap:           4.3G          0B        4.3G
                        Total:           20G        4.2G         15G
                        Active iob-Instances: 	37
                                15896 M total memory
                                 4006 M used memory
                                 3926 M active memory
                                 1307 M inactive memory
                                10220 M free memory
                                  121 M buffer memory
                                 1852 M swap cache
                                 4095 M total swap
                                    0 M used swap
                                 4095 M free swap
                        top - 13:36:41 up  6:17,  1 user,  load average: 0.94, 0.64, 0.38
                        Tasks: 204 total,   1 running, 203 sleeping,   0 stopped,   0 zombie
                        %Cpu(s):  6.2 us,  4.2 sy,  0.0 ni, 87.5 id,  2.1 wa,  0.0 hi,  0.0 si,  0.0 st
                        MiB Mem :  15896.3 total,  10218.9 free,   4008.2 used,   1973.5 buff/cache
                        MiB Swap:   4096.0 total,   4096.0 free,      0.0 used.  11888.1 avail Mem
                        *** FAILED SERVICES ***
                          UNIT              LOAD   ACTIVE SUB    DESCRIPTION
                        * postfix@-.service loaded failed failed Postfix Mail Transport Agent (instance -)
                        Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                                ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                                SUB    -> The low-level unit activation state, values depend on unit type.
                        1 loaded units listed.
                        *** DMESG CRITICAL ERRORS ***
                        No critical errors detected
                        *** FILESYSTEM ***
                        Filesystem                        Type   Size  Used Avail Use% Mounted on
                        tmpfs                             tmpfs  1.6G  1.7M  1.6G   1% /run
                        /dev/mapper/ubuntu--vg-ubuntu--lv ext4    98G   21G   72G  23% /
                        tmpfs                             tmpfs  7.8G     0  7.8G   0% /dev/shm
                        tmpfs                             tmpfs  5.0M     0  5.0M   0% /run/lock
                        /dev/sda2                         ext4   2.0G  200M  1.6G  11% /boot
                        tmpfs                             tmpfs  1.6G   12K  1.6G   1% /run/user/1000
                        [Wed Mar 25 07:19:29 2026] EXT4-fs (dm-0): mounted filesystem 40aec6e3-6f2c-4033-b08c-646e16343264 ro with ordered data mode. Quota mode: none.
                        [Wed Mar 25 07:19:30 2026] EXT4-fs (dm-0): re-mounted 40aec6e3-6f2c-4033-b08c-646e16343264 r/w.
                        [Wed Mar 25 07:19:31 2026] EXT4-fs (sda2): mounted filesystem 7494b7d5-e13f-4121-950d-c0dd89c71ef1 r/w with ordered data mode. Quota mode: none.
                        Show mounted filesystems:
                        TARGET              SOURCE                            FSTYPE   OPTIONS
                        /                   /dev/mapper/ubuntu--vg-ubuntu--lv ext4     rw,relatime
                        |-/snap/core20/2686 /dev/loop0                        squashfs ro,nodev,relatime,errors=continue,threads=single
                        |-/snap/lxd/38331   /dev/loop2                        squashfs ro,nodev,relatime,errors=continue,threads=single
                        |-/snap/core20/2717 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue,threads=single
                        |-/snap/lxd/38469   /dev/loop3                        squashfs ro,nodev,relatime,errors=continue,threads=single
                        |-/snap/snapd/25935 /dev/loop4                        squashfs ro,nodev,relatime,errors=continue,threads=single
                        |-/snap/snapd/26382 /dev/loop5                        squashfs ro,nodev,relatime,errors=continue,threads=single
                        `-/boot             /dev/sda2                         ext4     rw,relatime
                        /var:
                        5.2G	/var/
                        3.8G	/var/lib
                        2.5G	/var/lib/influxdb
                        2.1G	/var/lib/influxdb/engine/data/b7b90e085e7d3d8b/autogen
                        Archived and active journals take up 1.1G in the file system.
                        /opt/iobroker/backups:
                        1.2G	/opt/iobroker/backups/
                        /opt/iobroker/iobroker-data:
                        1.4G	/opt/iobroker/iobroker-data/
                        568M	/opt/iobroker/iobroker-data/files
                        315M	/opt/iobroker/iobroker-data/backup-objects
                        253M	/opt/iobroker/iobroker-data/history
                        82M	/opt/iobroker/iobroker-data/files/vis-2
                        220M	/opt/iobroker/iobroker-data/states.jsonl
                        56M	/opt/iobroker/iobroker-data/objects.jsonl
                        27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                        24M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                        9.8M	/opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
                        USB-Devices by-id:
                        USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
                        please always prefer the links 'by-id':
                        /dev/serial/by-id/usb-Dell_DW5560_C65706FD226AA0M0-if03
                        /dev/serial/by-id/usb-Dell_DW5560_C65706FD226AA0M0-if09
                        /dev/serial/by-id/usb-Dell_DW5560_C65706FD226AA0M0-if01
                        No nvbackup.json found.
                        *** NodeJS-Installation ***
                        /usr/bin/nodejs 	v22.22.1
                        /usr/bin/node 		v22.22.1
                        /usr/bin/npm 		10.9.4
                        /usr/bin/npx 		10.9.4
                        ✓ Node.js installation is correct
                        nodejs:
                          Installed: 22.22.1-1nodesource1
                          Candidate: 22.22.1-1nodesource1
                          Version table:
                         *** 22.22.1-1nodesource1 1001
                             22.22.0-1nodesource1 1001
                             22.21.0-1nodesource1 1001
                             22.20.0-1nodesource1 1001
                             22.19.0-1nodesource1 1001
                             22.18.0-1nodesource1 1001
                             22.17.1-1nodesource1 1001
                             22.17.0-1nodesource1 1001
                             22.16.0-1nodesource1 1001
                             22.15.1-1nodesource1 1001
                             22.15.0-1nodesource1 1001
                             22.14.0-1nodesource1 1001
                             22.13.1-1nodesource1 1001
                             22.13.0-1nodesource1 1001
                             22.12.0-1nodesource1 1001
                             22.11.0-1nodesource1 1001
                             22.10.0-1nodesource1 1001
                             22.9.0-1nodesource1 1001
                             22.8.0-1nodesource1 1001
                             22.7.0-1nodesource1 1001
                             22.6.0-1nodesource1 1001
                             22.5.1-1nodesource1 1001
                             22.5.0-1nodesource1 1001
                             22.4.1-1nodesource1 1001
                             22.4.0-1nodesource1 1001
                             22.3.0-1nodesource1 1001
                             22.2.0-1nodesource1 1001
                             22.1.0-1nodesource1 1001
                             22.0.0-1nodesource1 1001
                             18.19.1+dfsg-6ubuntu5 500
                                500 http://de.archive.ubuntu.com/ubuntu noble/universe amd64 Packages
                        No problems detected
                        Errors in npm tree: 0
                        *** ioBroker-Installation ***
                        ioBroker Status
                        At least one iobroker host is running.
                        Objects type: redis
                        States  type: redis
                        Hosts:
                        ubuntu-iobroker     ubuntu-iobroker (version: 7.0.7, hostname: ubuntu-iobroker, alive, uptime: 22623)
                        Core adapters versions
                        admin: 		7.7.22
                        javascript: 	9.0.18
                        nodejs modules from github: 	1
                        +-- iobroker.roborock@0.6.19 (git+ssh://git@github.com/copystring/ioBroker.roborock.git#16d61202f5ecf4448fd6b4e59ab675662b7d0fbe)
                        Adapter State
                        + system.adapter.admin.0                  : admin                 : ubuntu-iobroker                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        + system.adapter.alexa2.0                 : alexa2                : ubuntu-iobroker                          -  enabled
                          system.adapter.alias-manager.0          : alias-manager         : ubuntu-iobroker                          -  enabled
                        + system.adapter.ankersolix2.0            : ankersolix2           : ubuntu-iobroker                          -  enabled
                        + system.adapter.backitup.0               : backitup              : ubuntu-iobroker                          -  enabled
                        + system.adapter.brightsky.0              : brightsky             : ubuntu-iobroker                          -  enabled
                        + system.adapter.daswetter.0              : daswetter             : ubuntu-iobroker                          -  enabled
                        + system.adapter.denon.0                  : denon                 : ubuntu-iobroker                          -  enabled
                        + system.adapter.discovery.0              : discovery             : ubuntu-iobroker                          -  enabled
                          system.adapter.dwd.0                    : dwd                   : ubuntu-iobroker                          -  enabled
                        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ubuntu-iobroker                          -  enabled
                          system.adapter.feiertage.0              : feiertage             : ubuntu-iobroker                          -  enabled
                          system.adapter.flot.0                   : flot                  : ubuntu-iobroker                          -  enabled
                        + system.adapter.followthesun.0           : followthesun          : ubuntu-iobroker                          -  enabled
                        + system.adapter.fritzdect.0              : fritzdect             : ubuntu-iobroker                          -  enabled
                        + system.adapter.harmony.0                : harmony               : ubuntu-iobroker                          -  enabled
                        + system.adapter.heizoel.0                : heizoel               : ubuntu-iobroker                          -  enabled
                        + system.adapter.history.0                : history               : ubuntu-iobroker                          -  enabled
                        + system.adapter.hm-rega.0                : hm-rega               : ubuntu-iobroker                          -  enabled
                        + system.adapter.hm-rpc.0                 : hm-rpc                : ubuntu-iobroker                          -  enabled, port: 0
                        + system.adapter.hm-rpc.1                 : hm-rpc                : ubuntu-iobroker                          -  enabled, port: 0
                        + system.adapter.hm-rpc.2                 : hm-rpc                : ubuntu-iobroker                          -  enabled, port: 0
                        + system.adapter.hue.0                    : hue                   : ubuntu-iobroker                          -  enabled, port: 443
                          system.adapter.ical.0                   : ical                  : ubuntu-iobroker                          -  enabled
                          system.adapter.ical.1                   : ical                  : ubuntu-iobroker                          -  enabled
                          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ubuntu-iobroker                          -  enabled
                          system.adapter.icons-icons8.0           : icons-icons8          : ubuntu-iobroker                          -  enabled
                          system.adapter.icons-material-png.0     : icons-material-png    : ubuntu-iobroker                          -  enabled
                          system.adapter.icons-material-svg.0     : icons-material-svg    : ubuntu-iobroker                          -  enabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : ubuntu-iobroker                          -  enabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ubuntu-iobroker                          -  enabled
                          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ubuntu-iobroker                          -  enabled
                          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ubuntu-iobroker                          -  enabled
                        + system.adapter.influxdb.0               : influxdb              : ubuntu-iobroker                          -  enabled, port: 8086
                        + system.adapter.info.0                   : info                  : ubuntu-iobroker                          -  enabled
                        + system.adapter.iot.0                    : iot                   : ubuntu-iobroker                          -  enabled
                        + system.adapter.javascript.0             : javascript            : ubuntu-iobroker                          -  enabled
                          system.adapter.mihome-vacuum.0          : mihome-vacuum         : ubuntu-iobroker                          - disabled, port: 54321
                        + system.adapter.netatmo.0                : netatmo               : ubuntu-iobroker                          -  enabled
                        + system.adapter.nina.0                   : nina                  : ubuntu-iobroker                          -  enabled
                          system.adapter.ping.0                   : ping                  : ubuntu-iobroker                          - disabled
                        + system.adapter.radar2.0                 : radar2                : ubuntu-iobroker                          -  enabled
                        + system.adapter.ring.0                   : ring                  : ubuntu-iobroker                          -  enabled
                        + system.adapter.roborock.0               : roborock              : ubuntu-iobroker                          -  enabled
                        + system.adapter.scenes.0                 : scenes                : ubuntu-iobroker                          -  enabled
                          system.adapter.schoolfree.0             : schoolfree            : ubuntu-iobroker                          -  enabled
                        + system.adapter.sonos.0                  : sonos                 : ubuntu-iobroker                          -  enabled
                        + system.adapter.tankerkoenig.0           : tankerkoenig          : ubuntu-iobroker                          -  enabled
                        + system.adapter.telegram.0               : telegram              : ubuntu-iobroker                          -  enabled, port: 8443, bind: 0.0.0.0
                          system.adapter.tr-064.0                 : tr-064                : ubuntu-iobroker                          - disabled
                          system.adapter.tradfri.0                : tradfri               : ubuntu-iobroker                          - disabled
                        + system.adapter.trashschedule.0          : trashschedule         : ubuntu-iobroker                          -  enabled
                          system.adapter.upnp.0                   : upnp                  : ubuntu-iobroker                          - disabled
                          system.adapter.viessmannapi.0           : viessmannapi          : ubuntu-iobroker                          - disabled
                          system.adapter.vis-bars.0               : vis-bars              : ubuntu-iobroker                          -  enabled
                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ubuntu-iobroker                          -  enabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : ubuntu-iobroker                          -  enabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ubuntu-iobroker                          -  enabled
                          system.adapter.vis-google-fonts.0       : vis-google-fonts      : ubuntu-iobroker                          -  enabled
                          system.adapter.vis-history.0            : vis-history           : ubuntu-iobroker                          -  enabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ubuntu-iobroker                          -  enabled
                          system.adapter.vis-icontwo.0            : vis-icontwo           : ubuntu-iobroker                          -  enabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : ubuntu-iobroker                          -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ubuntu-iobroker                          -  enabled
                          system.adapter.vis-justgage.0           : vis-justgage          : ubuntu-iobroker                          -  enabled
                          system.adapter.vis-lcars.0              : vis-lcars             : ubuntu-iobroker                          -  enabled
                          system.adapter.vis-map.0                : vis-map               : ubuntu-iobroker                          -  enabled
                          system.adapter.vis-materialdesign.0     : vis-materialdesign    : ubuntu-iobroker                          -  enabled
                          system.adapter.vis-metro.0              : vis-metro             : ubuntu-iobroker                          -  enabled
                          system.adapter.vis-players.0            : vis-players           : ubuntu-iobroker                          -  enabled
                          system.adapter.vis-plumb.0              : vis-plumb             : ubuntu-iobroker                          -  enabled
                          system.adapter.vis-rgraph.0             : vis-rgraph            : ubuntu-iobroker                          -  enabled
                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : ubuntu-iobroker                          -  enabled
                          system.adapter.vis-weather.0            : vis-weather           : ubuntu-iobroker                          -  enabled
                          system.adapter.vis.0                    : vis                   : ubuntu-iobroker                          -  enabled
                          system.adapter.weatherunderground.0     : weatherunderground    : ubuntu-iobroker                          -  enabled
                        + system.adapter.web.0                    : web                   : ubuntu-iobroker                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ubuntu-iobroker                          - disabled
                        + system.adapter.yahka.0                  : yahka                 : ubuntu-iobroker                          -  enabled
                        + instance is alive
                        ioBroker-Repositories
                        Active repo(s): stable
                        Upgrade policy: none
                        Installed ioBroker-Adapters
                        Used repository: stable
                        Adapter    "admin"        : 7.7.22   , installed 7.7.22
                        Adapter    "alexa2"       : 3.27.4   , installed 3.27.4
                        Adapter    "alias-manager": 2.1.0    , installed 2.1.0
                        Adapter    "ankersolix2"  : 2.4.1    , installed 2.4.1
                        Adapter    "backitup"     : 3.3.14   , installed 3.3.14
                        Adapter    "brightsky"    : 1.0.1    , installed 1.0.1
                        Adapter    "daswetter"    : 4.5.3    , installed 4.5.3
                        Adapter    "denon"        : 1.15.12  , installed 1.15.12
                        Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
                        Adapter    "feiertage"    : 1.3.0    , installed 1.3.0
                        Adapter    "followthesun" : 0.5.2    , installed 0.5.2
                        Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
                        Adapter    "harmony"      : 2.0.5    , installed 2.0.5
                        Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                        Adapter    "hue"          : 3.16.2   , installed 3.16.2
                        Adapter    "ical"         : 1.19.7   , installed 1.19.7
                        Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                        Adapter    "iot"          : 5.0.7    , installed 5.0.7
                        Adapter    "javascript"   : 9.0.18   , installed 9.0.18
                        Controller "js-controller": 7.0.7    , installed 7.0.7
                        Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
                        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                        Adapter    "nina"         : 0.0.25   , installed 0.0.25
                        Adapter    "ping"         : 1.7.9    , installed 1.7.9
                        Adapter    "radar2"       : 2.4.0    , installed 2.4.0
                        Adapter    "ring"         : 6.4.0    , installed 6.4.0
                        Adapter    "roborock"     : 0.6.18   , installed 0.6.19
                        Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                        Adapter    "schoolfree"   : 1.1.13   , installed 1.1.13
                        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                        Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
                        Adapter    "trashschedule": 3.3.0    , installed 3.3.0
                        Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                        Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
                        Adapter    "vis-icontwo"  : 2.11.1   , installed 2.11.1
                        Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
                        Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                        Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
                        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                        Adapter    "web"          : 7.0.8    , installed 7.0.8
                        Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                        Adapter    "yahka"        : 1.1.5    , installed 1.1.5
                        Objects and States
                        Objects: 	50771
                        States: 	41438
                        Hit:1 http://de.archive.ubuntu.com/ubuntu noble InRelease
                        Hit:2 http://de.archive.ubuntu.com/ubuntu noble-updates InRelease
                        Hit:3 http://de.archive.ubuntu.com/ubuntu noble-backports InRelease
                        Hit:4 http://de.archive.ubuntu.com/ubuntu noble-security InRelease
                        Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                        Get:6 https://repos.influxdata.com/debian stable InRelease [6922 B]
                        Fetched 6922 B in 1s (9826 B/s)
                        Reading package lists...
                        Pending systemupdates: 0
                        *** Listening Ports ***
                        tcp        0      0 127.0.0.1:44077         0.0.0.0:*               LISTEN      1001       87956      11190/io.alexa2.0
                        tcp        0      0 0.0.0.0:40603           0.0.0.0:*               LISTEN      1001       12536      1580/io.yahka.0
                        tcp        0      0 127.0.0.1:43817         0.0.0.0:*               LISTEN      1001       12546      1580/io.yahka.0
                        tcp        0      0 192.168.171.162:9292    0.0.0.0:*               LISTEN      1001       14460      1563/io.hm-rpc.1
                        tcp        0      0 192.168.171.162:2010    0.0.0.0:*               LISTEN      1001       13730      1716/io.hm-rpc.2
                        tcp        0      0 192.168.171.162:2001    0.0.0.0:*               LISTEN      1001       13854      1853/io.hm-rpc.0
                        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      118        9074       1153/redis-server 1
                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          5485       1/init
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11346      1/init
                        tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      102        9248       810/systemd-resolve
                        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        9246       810/systemd-resolve
                        tcp6       0      0 :::8086                 :::*                    LISTEN      119        10914      1182/influxd
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       17453      2659/io.web.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11032      1389/io.admin.0
                        tcp6       0      0 ::1:6379                :::*                    LISTEN      118        9075       1153/redis-server 1
                        tcp6       0      0 :::61991                :::*                    LISTEN      1001       13698      1670/io.harmony.0
                        tcp6       0      0 :::3500                 :::*                    LISTEN      1001       15417      1636/io.sonos.0
                        tcp6       0      0 :::111                  :::*                    LISTEN      0          5487       1/init
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          11348      1/init
                        udp        0      0 127.0.0.54:53           0.0.0.0:*                           102        9247       810/systemd-resolve
                        udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        9245       810/systemd-resolve
                        udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       12883      1890/io.radar2.0
                        udp        0      0 192.168.171.162:68      0.0.0.0:*                           101        9346       852/systemd-network
                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          5486       1/init
                        udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       13699      1670/io.harmony.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       12541      1580/io.yahka.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       12540      1580/io.yahka.0
                        udp6       0      0 :::111                  :::*                                0          5488       1/init
                        udp6       0      0 fe80::d6be:d9ff:fe7:546 :::*                                101        9344       852/systemd-network
                        2026-03-25 13:20:57.070  - info: host.ubuntu-iobroker instance system.adapter.dwd.0 having pid 10865 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2026-03-25 13:25:33.010  - info: host.ubuntu-iobroker instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 10946
                        2026-03-25 13:25:38.011  - info: host.ubuntu-iobroker instance system.adapter.weatherunderground.0 having pid 10946 terminated with code 0 (NO_ERROR)
                        2026-03-25 13:25:55.012  - info: host.ubuntu-iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 10966
                        2026-03-25 13:25:57.140  - info: host.ubuntu-iobroker instance system.adapter.dwd.0 having pid 10966 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2026-03-25 13:30:00.016  - info: host.ubuntu-iobroker instance system.adapter.ical.1 in version "1.19.7" started with pid 11039
                        2026-03-25 13:30:04.022  - info: host.ubuntu-iobroker instance system.adapter.ical.0 in version "1.19.7" started with pid 11056
                        2026-03-25 13:30:12.336  - info: host.ubuntu-iobroker instance system.adapter.ical.1 having pid 11039 terminated with code 0 (NO_ERROR)
                        2026-03-25 13:30:30.055  - info: host.ubuntu-iobroker instance system.adapter.ical.0 having pid 11056 terminated with code 0 (NO_ERROR)
                        2026-03-25 13:30:33.006  - info: host.ubuntu-iobroker instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 11087
                        2026-03-25 13:30:38.205  - info: host.ubuntu-iobroker instance system.adapter.weatherunderground.0 having pid 11087 terminated with code 0 (NO_ERROR)
                        2026-03-25 13:30:55.006  - info: host.ubuntu-iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 11108
                        2026-03-25 13:31:01.283  - info: host.ubuntu-iobroker instance system.adapter.dwd.0 having pid 11108 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2026-03-25 13:33:28.396  - info: host.ubuntu-iobroker "system.adapter.alexa2.0" enabled
                        2026-03-25 13:33:28.591  - info: host.ubuntu-iobroker instance system.adapter.alexa2.0 in version "3.27.4" started with pid 11170
                        2026-03-25 13:33:29.856  - error: alexa2.0 (11170) Adapter seems to have issues and crashed three times in a row. Disabling!! Please start again and check logs.
                        2026-03-25 13:33:31.416  - info: host.ubuntu-iobroker instance system.adapter.alexa2.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                        2026-03-25 13:33:31.417  - info: host.ubuntu-iobroker Do not restart adapter system.adapter.alexa2.0 because desired by instance
                        2026-03-25 13:34:03.517  - info: host.ubuntu-iobroker instance system.adapter.alexa2.0 in version "3.27.4" started with pid 11190
                        2026-03-25 13:34:04.865  - error: alexa2.0 (11190) Error:
                        2026-03-25 13:34:04.865  - error: alexa2.0 (11190) Error: Please open http://192.168.171.162:44077/ with your browser and login to Amazon. The cookie will be output here after successfull login.
                        2026-03-25 13:35:33.018  - info: host.ubuntu-iobroker instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 11235
                        2026-03-25 13:35:37.938  - info: host.ubuntu-iobroker instance system.adapter.weatherunderground.0 having pid 11235 terminated with code 0 (NO_ERROR)
                        2026-03-25 13:35:55.020  - info: host.ubuntu-iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 11381
                        2026-03-25 13:35:57.100  - info: host.ubuntu-iobroker instance system.adapter.dwd.0 having pid 11381 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        iob diag has finished.
                        • ilovegymI Offline
                          ilovegymI Offline
                          ilovegym
                          Check mal im Adapter den Tab Proxy was da drin steht.. wenn er die url nicht öffnen kann, liegts meist daran..
                          • ilovegymI ilovegym
                            hellrider2001
                            @ilovegym sagte in Alexa2 - Adapter / "Die Webseite ist nicht erreichbar":
                            Bingo - da wär ich nie drauf gekommen, da ich dort nie etwas eingetragen hatte. Es hatte sich, obwohl kein Proxy im Einsatz, der Netzwerkadapter verändert. Dies korrigiert, funktionierts auch wieder. Besten Dank!
                            • ilovegymI Offline
                              ilovegymI Offline
                              ilovegym
                              Gerne, war ne logische Folgerung aus Fehlermeldung und eigenen Erfahrungswerten :)
                              • apollon77A Offline
                                Ich release gerade die 3.28.2 und wenn alles ok ist geht die morgen in Stable. Damit sollten die Login und Token Probleme gelöst sein und auch die 404er mit alten 2FA Methoden besser sein.
