  3. Off Topic
  4. Pflege des Betriebssystems
  5. nodesource-Repo - OpenPGP signature verification failed
    6.8k
Geplant Angeheftet Gesperrt Verschoben Pflege des Betriebssystems
7 Beiträge 5 Kommentatoren 2.3k Aufrufe 5 Beobachtet
  • Thomas BraunT Online
    Wer bei einem
    sudo apt update
    auf diese Meldung stößt:
    W: https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease: Policy will reject signature within a year, see --audit for details
    oder (seit 01.02.2026):
    Warning: An error occurred during the signature verification. The repository is not updated and the previous index files will be used.
    OpenPGP signature verification failed: https://deb.nodesource.com/node_24.x nodistro InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F7 1F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound: No binding signature at time 2026-01-19T15:30:12Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
    Warning: Failed to fetch https://deb.nodesource.com/node_24.x/dists/nodistro/InRelease Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound: No binding signature at time 2026-01-19T15:30:12Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
    Warning: Some index files failed to download. They have been ignored, or old ones used instead.
    kann nun die alte Signatur ersetzen lassen. Dazu einfach per
    iob nodejs-update 22
    die letzte Version aus dem (derzeitig aktuellen) 22er-Zweig noch mal drüber installieren. Es kommt dann diese Rückfrage:
    Nothing to do - Your installation is using the correct paths.
    You are missinng the nodesource.list or
    you want to change your current nodejs version: v22.22.0 ?
    Press <y> to continue or any other key to quit
    Das dann einfach per 'y' bestätigen und die o.g. Meldung sollte beim nächsten Update nicht mehr angezeigt werden.
    Wichtig ist die Angabe der Hauptversion '22' im nodejs-update Befehl.
    FabioF 1 Antwort Letzte Antwort
    20
    • teletapiT Offline
      teletapiT Offline
      teletapi
      schrieb am zuletzt editiert von teletapi
      Ich war schon geneigt gestern hier im Forum zu schreiben genau wegen dieses Verhalten nach sudo apt update, hatte mir aber bereits gedacht das es in die Richtung geht und hab genau die beschriebenen Schritte benutzt und der Fehler war weg. Den Hinweiß von dir habe ich allerdings gerade erst gesehen. Danke so weiß ich das alles seine Richtigkeit hat. Vielleicht könnte man aber in der Überschrift noch etwas deutlicher werden, ich hätte das nicht gefunden wenn ich gerade eben nicht explizit nach "nodesource" gesucht hätte oder eventuell einen Verweiß im Tread "Wir empfehlen Nodejs22".
      • teletapiT teletapi
        @teletapi sagte in nodesource-Repo - OpenPGP signature verification failed:
        aber genau das steht doch in der Meldung:
        @Thomas-Braun sagte in nodesource-Repo - OpenPGP signature verification failed:
        es geht ja nicht um irgendwelche Repos (debian/ubuntu/whatelse), sondern ausschließlich um das nodesource Repo
          Wobei die Meldung auch bei anderen Repos (überwiegend natürlich von Dritten) erscheinen kann.
          Gestern war z. B. jemand hier, bei dem wurde die Quelle für syncthing angemeckert.
            Wer bei einem
            sudo apt update
            FabioF Offline
            FabioF Offline
            Fabio
            vielen Dank @thomas-braun hat super geklappt. ;-)
            Herzliche Grüße
            Fabio
            Iobroker:
            • Matter over Thread Hilfe
            • I ioBrokerMike
              Bitte sehr
              ```bash
              Script v.2026-01-31
              *** BASE SYSTEM ***
              Operating System: Debian GNU/Linux 13 (trixie)
              Static hostname: IoB
                    Icon name: computer-laptop
                      Chassis: laptop 💻
                       Kernel: Linux 6.12.57+deb13-amd64
                 Architecture: x86-64
              Hardware Vendor: GEEKOM
               Hardware Model: MiniAir 11
              Firmware Version: 2.09
                Firmware Date: Wed 2023-02-08
                 Firmware Age: 2y 11month 3w 6d
              OS is similar to:
              model name      : Intel(R) Celeron(R) N5105 @ 2.00GHz
              Docker          : false
              Virtualization  : none
              Kernel          : x86_64
              Userland        : 64 bit
              Systemuptime and Load:
              11:42:48 up 33 days, 22:33,  1 user,  load average: 0.18, 0.24, 0.20
              CPU threads: 4
              *** LIFE CYCLE STATUS ***
              Operating System is the current Debian stable version codenamed 'trixie'!
              *** TIME AND TIMEZONES ***
                            Local time: Wed 2026-02-04 11:42:48 CET
                        Universal time: Wed 2026-02-04 10:42:48 UTC
                              RTC time: Wed 2026-02-04 10:42:48
                           NTP service: active
                       RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              chef
              HOME=/home/chef
              groups: cannot find name for group ID 1000
              groups: cannot find name for group ID 4
              GROUPS=1000 4 cdrom floppy sudo audio dip video plugdev users netdev
              iobroker
              HOME=/home/iobroker
              SUDO_HOME=/home/chef
              GROUPS=iobroker tty dialout audio video plugdev
              *** DISPLAY-SERVER SETUP ***
              Display-Server:         false
              Unit display-manager.service could not be found.
              Display-Manager:
              Desktop:
              Session:                tty
              *** MEMORY ***
              Mem:             16G        2.8G         10G         10M        3.9G         13G
              Swap:           1.0G          0B        1.0G
              Total:           17G        2.8G         11G
              Active iob-Instances:   32
                     15779 M total memory
                      2708 M used memory
                      2297 M active memory
                      3268 M inactive memory
                      9716 M free memory
                      1038 M buffer memory
                      2659 M swap cache
                       975 M total swap
                         0 M used swap
                       975 M free swap
              top - 11:42:48 up 33 days, 22:33,  1 user,  load average: 0.18, 0.24, 0.20
              Tasks: 176 total,   2 running, 174 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  2.3 us,  2.3 sy,  0.0 ni, 95.5 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :  15779.1 total,   9716.2 free,   2709.4 used,   3697.6 buff/cache
              MiB Swap:    976.0 total,    976.0 free,      0.0 used.  13069.7 avail Mem
              *** FAILED SERVICES ***
              0 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              No critical errors detected
              *** FILESYSTEM ***
              udev           devtmpfs  7.7G     0  7.7G   0% /dev
              tmpfs          tmpfs     1.6G  4.8M  1.6G   1% /run
              /dev/sda2      ext4      467G   16G  428G   4% /
              tmpfs          tmpfs     7.8G     0  7.8G   0% /dev/shm
              efivarfs       efivarfs  192K   54K  134K  29% /sys/firmware/efi/efivars
              tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
              tmpfs          tmpfs     7.8G  5.6M  7.7G   1% /tmp
              /dev/sda1      vfat      511M  4.4M  507M   1% /boot/efi
              tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/getty@tty1.service
              tmpfs          tmpfs     1.0M     0  1.0M   0% /run/credentials/systemd-journald.service
              tmpfs          tmpfs     1.6G  8.0K  1.6G   1% /run/user/1000
              [Thu Jan  1 13:09:20 2026] EXT4-fs (sda2): mounted filesystem af8b48bb-103b-457d-9acb-75aa4d725884 ro with ordered data mode. Quota mode: none.
              [Thu Jan  1 13:09:20 2026] EXT4-fs (sda2): re-mounted af8b48bb-103b-457d-9acb-75aa4d725884 r/w.
              Show mounted filesystems:
              TARGET      SOURCE    FSTYPE OPTIONS
              /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
              `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
              /var:
              1003M   /var/
              708M    /var/log
              691M    /var/log/journal/2c17947119b84a11a6ec56c4463de25e
              191M    /var/lib
              Archived and active journals take up 690.6M in the file system.
              /opt/iobroker/backups:
              96M     /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              711M    /opt/iobroker/iobroker-data/
              512M    /opt/iobroker/iobroker-data/files
              160M    /opt/iobroker/iobroker-data/files/vis-2
              118M    /opt/iobroker/iobroker-data/files/vis-2/widgets
              108M    /opt/iobroker/iobroker-data/backup-objects
              33M     /opt/iobroker/iobroker-data/objects.jsonl
              32M     /opt/iobroker/iobroker-data/files/mytime.admin/custom/assets/index-B_3WOu59.js.map
              27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
              24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
              9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
              USB-Devices by-id:
              USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups,
              please always prefer the links 'by-id':
              No Devices found 'by-id'
              No nvbackup.json found.
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v22.22.0
              /usr/bin/node           v22.22.0
              /usr/bin/npm            10.9.4
              /usr/bin/npx            10.9.4
              ✓ Node.js installation is correct
              nodejs:
               Installed: 22.22.0-1nodesource1
               Candidate: 22.22.0-1nodesource1
               Version table:
              *** 22.22.0-1nodesource1 600
                  22.21.0-1nodesource1 600
                  22.20.0-1nodesource1 600
                  22.19.0-1nodesource1 600
                  22.18.0-1nodesource1 600
                  22.17.1-1nodesource1 600
                  22.17.0-1nodesource1 600
                  22.16.0-1nodesource1 600
                  22.15.1-1nodesource1 600
                  22.15.0-1nodesource1 600
                  22.14.0-1nodesource1 600
                  22.13.1-1nodesource1 600
                  22.13.0-1nodesource1 600
                  22.12.0-1nodesource1 600
                  22.11.0-1nodesource1 600
                  22.10.0-1nodesource1 600
                  22.9.0-1nodesource1 600
                  22.8.0-1nodesource1 600
                  22.7.0-1nodesource1 600
                  22.6.0-1nodesource1 600
                  22.5.1-1nodesource1 600
                  22.5.0-1nodesource1 600
                  22.4.1-1nodesource1 600
                  22.4.0-1nodesource1 600
                  22.3.0-1nodesource1 600
                  22.2.0-1nodesource1 600
                  22.1.0-1nodesource1 600
                  22.0.0-1nodesource1 600
                  20.19.2+dfsg-1 500
                     500 http://deb.debian.org/debian trixie/main amd64 Packages
              No problems detected
              Errors in npm tree: 0
              node:fs:2437
                 return binding.writeFileUtf8(
              Error: EACCES: permission denied, open '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
                 at Object.writeFileSync (node:fs:2437:20)
                 at ClientRequest.<anonymous> (/home/iobroker/node_modules/is-my-node-vulnerable/is-vulnerable.js:82:12)
                 at Object.onceWrapper (node:events:634:26)
                 at ClientRequest.emit (node:events:519:28)
                 at HTTPParser.parserOnIncomingClient [as onIncoming] (node:_http_client:772:27)
                 at HTTPParser.parserOnHeadersComplete (node:_http_common:122:17)
                 at TLSSocket.socketOnData (node:_http_client:614:22)
                 at TLSSocket.emit (node:events:519:28)
                 at addChunk (node:internal/streams/readable:561:12)
                 at readableAddChunkPushByteMode (node:internal/streams/readable:512:3) {
               errno: -13,
               code: 'EACCES',
               syscall: 'open',
               path: '/home/iobroker/node_modules/is-my-node-vulnerable/schedule.etag'
              Node.js v22.22.0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              IoB                 IoB (version: 7.0.7, hostname: IoB           , alive, uptime: 9152)
              Core adapters versions
              js-controller:  7.0.7
              admin:          7.7.22
              javascript:     9.0.11
              nodejs modules from github:     1
              +-- iobroker.vw-connect@0.7.15 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#f756508d8a444a476296f880c2ae1ac3e3010beb)
              Adapter State
              + system.adapter.admin.0                  : admin                 : IoB                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.backitup.0               : backitup              : IoB                                      -  enabled
              + system.adapter.echarts.0                : echarts               : IoB                                      -  enabled
              + system.adapter.ems-esp.0                : ems-esp               : IoB                                      -  enabled
              + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: IoB                                      -  enabled
              + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: IoB                                      -  enabled
              + system.adapter.energiefluss-erweitert.2 : energiefluss-erweitert: IoB                                      -  enabled
              + system.adapter.fullybrowser.0           : fullybrowser          : IoB                                      -  enabled
              + system.adapter.history.0                : history               : IoB                                      -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : IoB                                      -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : IoB                                      -  enabled, port: 0
              + system.adapter.hydrawise.0              : hydrawise             : IoB                                      -  enabled
               system.adapter.ical.0                   : ical                  : IoB                                      -  enabled
               system.adapter.icons-icons8.0           : icons-icons8          : IoB                                      -  enabled
               system.adapter.icons-material-png.0     : icons-material-png    : IoB                                      - disabled
               system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : IoB                                      - disabled
              + system.adapter.javascript.0             : javascript            : IoB                                      -  enabled
              + system.adapter.modbus.0                 : modbus                : IoB                                      -  enabled
              + system.adapter.modbus.1                 : modbus                : IoB                                      -  enabled
              + system.adapter.mqtt.1                   : mqtt                  : IoB                                      -  enabled, port: 1883, bind: 192.168.178.11
              + system.adapter.mqtt.2                   : mqtt                  : IoB                                      -  enabled, port: 1882, bind: 192.168.178.11
              + system.adapter.mqtt.4                   : mqtt                  : IoB                                      -  enabled, port: 1884, bind: 192.168.178.11
               system.adapter.mytime.0                 : mytime                : IoB                                      - disabled
              + system.adapter.operating-hours.0        : operating-hours       : IoB                                      -  enabled
              + system.adapter.ping.0                   : ping                  : IoB                                      -  enabled
               system.adapter.reolink.0                : reolink               : IoB                                      - disabled
               system.adapter.robonect.0               : robonect              : IoB                                      - disabled
               system.adapter.sayit.0                  : sayit                 : IoB                                      - disabled
              + system.adapter.sma-em.0                 : sma-em                : IoB                                      -  enabled
              + system.adapter.sma-ev-charger.0         : sma-ev-charger        : IoB                                      -  enabled
               system.adapter.sonoff.1                 : sonoff                : IoB                                      - disabled, port: 1886, bind: 192.168.178.11
              + system.adapter.tankerkoenig.0           : tankerkoenig          : IoB                                      -  enabled
              + system.adapter.telegram.0               : telegram              : IoB                                      -  enabled, port: 8443, bind: 0.0.0.0
              + system.adapter.tr-064.0                 : tr-064                : IoB                                      -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : IoB                                      -  enabled
               system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: IoB                                      -  enabled
               system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : IoB                                      -  enabled
               system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : IoB                                      -  enabled
               system.adapter.vis-2-widgets-icontwo.0  : vis-2-widgets-icontwo : IoB                                      -  enabled
               system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: IoB                                      -  enabled
               system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: IoB                                      -  enabled
               system.adapter.vis-2-widgets-radar-trap.0: vis-2-widgets-radar-trap: IoB                                      -  enabled
               system.adapter.vis-2-widgets-rssfeed.0  : vis-2-widgets-rssfeed : IoB                                      -  enabled
               system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: IoB                                      -  enabled
              + system.adapter.vis-2.0                  : vis-2                 : IoB                                      -  enabled
               system.adapter.vis-icontwo.0            : vis-icontwo           : IoB                                      -  enabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : IoB                                      -  enabled
              + system.adapter.vw-connect.0             : vw-connect            : IoB                                      -  enabled
              + system.adapter.weather-warnings.0       : weather-warnings      : IoB                                      -  enabled
              + system.adapter.web.0                    : web                   : IoB                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Upgrade policy: none
              Installed ioBroker-Adapters
              Used repository: stable
              Adapter    "admin"        : 7.7.22   , installed 7.7.22
              Adapter    "backitup"     : 3.3.13   , installed 3.3.13
              Adapter    "echarts"      : 1.9.2    , installed 2.0.10
              Adapter    "ems-esp"      : 6.0.1    , installed 6.0.1
              Adapter    "energiefluss-erweitert": 0.8.1, installed 0.8.1
              Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
              Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
              Adapter    "hydrawise"    : 1.0.2    , installed 1.0.2
              Adapter    "ical"         : 1.18.1   , installed 1.18.1
              Adapter    "javascript"   : 9.0.11   , installed 9.0.11
              Controller "js-controller": 7.0.7    , installed 7.0.7
              Adapter    "modbus"       : 6.3.2    , installed 6.3.2
              Adapter    "mytime"       : 2.3.2    , installed 2.3.2
              Adapter    "operating-hours": 1.4.0  , installed 1.4.0
              Adapter    "ping"         : 1.7.9    , installed 1.7.9
              Adapter    "reolink"      : 1.2.3    , installed 1.2.3
              Adapter    "robonect"     : 1.4.2    , installed 1.4.2
              Adapter    "sayit"        : 5.0.0    , installed 5.0.0
              Adapter    "sma-em"       : 1.3.0    , installed 1.3.0
              Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
              Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
              Adapter    "trashschedule": 3.3.0    , installed 3.3.0
              Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
              Adapter    "vis-2-widgets-collection": 1.8.1, installed 2.0.11
              Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
              Adapter    "vis-2-widgets-gauges": 2.0.1, installed 2.0.1
              Adapter    "vis-2-widgets-icontwo": 1.25.0, installed 1.25.0
              Adapter    "vis-2-widgets-inventwo": 0.5.5, installed 0.5.5
              Adapter    "vis-2-widgets-material": 1.4.10, installed 1.6.0
              Adapter    "vis-2-widgets-ovarious": 2.0.0, installed 2.0.0
              Adapter    "vis-2-widgets-radar-trap": 2.3.0, installed 2.3.0
              Adapter    "vis-2-widgets-rssfeed": 1.2.2, installed 1.2.2
              Adapter    "vis-2-widgets-weather-and-heating": 1.1.5, installed 1.1.5
              Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
              Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
              Adapter    "weather-warnings": 0.10.0, installed 0.10.0
              Adapter    "web"          : 7.0.8    , installed 7.0.8
              Objects and States
              Objects:        7264
              States:         5952
              W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. OpenPGP signature verification failed: https://deb.nodesource.com/node_22.x nodistro InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-01-23T18:12:38Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
              W: Failed to fetch https://deb.nodesource.com/node_22.x/dists/nodistro/InRelease  Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on 6F71F525282841EEDAF851B42F59B5F99B1BE0B4 is not bound:            No binding signature at time 2026-01-23T18:12:38Z   because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance   because: SHA1 is not considered secure since 2026-02-01T00:00:00Z
              W: Some index files failed to download. They have been ignored, or old ones used instead.
              Hit:1 http://deb.debian.org/debian trixie InRelease
              Hit:2 http://deb.debian.org/debian trixie-updates InRelease
              Hit:3 http://security.debian.org/debian-security trixie-security InRelease
              Get:4 https://deb.nodesource.com/node_22.x nodistro InRelease [12.1 kB]
              Err:4 https://deb.nodesource.com/node_22.x nodistro InRelease
              Reading package lists... Done
              Pending systemupdates: 0
              *** Listening Ports ***
              tcp        0      0 192.168.178.11:1882     0.0.0.0:*               LISTEN      1001       20616662   1654134/io.mqtt.2
              tcp        0      0 192.168.178.11:1883     0.0.0.0:*               LISTEN      1001       20616572   1654050/io.mqtt.1
              tcp        0      0 192.168.178.11:1884     0.0.0.0:*               LISTEN      1001       20616640   1654108/io.mqtt.4
              tcp        0      0 192.168.178.11:2010     0.0.0.0:*               LISTEN      1001       20616326   1653849/io.hm-rpc.0
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          306        1/systemd
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6693       937/sshd: /usr/sbin
              tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          9665       1074/smbd
              tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          9664       1074/smbd
              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          9379       949/exim4
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       20612751   1653442/iobroker.js
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20615200   1653442/iobroker.js
              tcp6       0      0 :::1984                 :::*                    LISTEN      1000       18170180   1456783/go2rtc_linu
              tcp6       0      0 :::111                  :::*                    LISTEN      0          1523       1/systemd
              tcp6       0      0 :::22                   :::*                    LISTEN      0          6703       937/sshd: /usr/sbin
              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          9380       949/exim4
              tcp6       0      0 :::139                  :::*                    LISTEN      0          9663       1074/smbd
              tcp6       0      0 :::8555                 :::*                    LISTEN      1000       18169544   1456783/go2rtc_linu
              tcp6       0      0 :::8554                 :::*                    LISTEN      1000       18168741   1456783/go2rtc_linu
              tcp6       0      0 :::445                  :::*                    LISTEN      0          9662       1074/smbd
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       20615323   1653590/io.admin.0
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20617155   1654495/io.web.0
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       20607295   1456783/go2rtc_linu
              udp        0      0 0.0.0.0:40180           0.0.0.0:*                           1000       20607300   1456783/go2rtc_linu
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          6685       637/dhclient
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          307        1/systemd
              udp        0      0 192.168.178.255:137     0.0.0.0:*                           0          9565       952/nmbd
              udp        0      0 192.168.178.11:137      0.0.0.0:*                           0          9564       952/nmbd
              udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          6725       952/nmbd
              udp        0      0 192.168.178.255:138     0.0.0.0:*                           0          9567       952/nmbd
              udp        0      0 192.168.178.11:138      0.0.0.0:*                           0          9566       952/nmbd
              udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          6726       952/nmbd
              udp        0      0 192.168.178.11:8555     0.0.0.0:*                           1000       18169548   1456783/go2rtc_linu
              udp        0      0 0.0.0.0:58289           0.0.0.0:*                           1000       20607302   1456783/go2rtc_linu
              udp        0      0 0.0.0.0:9522            0.0.0.0:*                           1001       20616253   1653790/io.sma-em.0
              udp        0      0 0.0.0.0:52689           0.0.0.0:*                           1000       20607297   1456783/go2rtc_linu
              udp6       0      0 :::5353                 :::*                                1000       20607296   1456783/go2rtc_linu
              udp6       0      0 :::111                  :::*                                0          4453       1/systemd
              udp6       0      0 :::54469                :::*                                1000       20607298   1456783/go2rtc_linu
              iob diag has finished.
              [/s]
              @ioBrokerMike sagte in nodesource-Repo - OpenPGP signature verification failed:
              chef
              HOME=/home/chef
              Da stimmt was nicht mit dem user 'chef'. Wie hast du den denn eingerichtet?
              Üblicherweise sollte ein 'chef' auch ein Chef sein und in der Chef-Gruppe 'adm' sein.
              Und gid=1000 und gid=4 sollten auch Namen haben.
              Wobei adm vermutlich die gid=4 hat.
              node:fs:2437
              Deutet auch auf fehlende Rechte / falsches Setup hin. Das könnte auch der Grund sein, warum du 'iob nodejs-update' oder 'iob diag' nicht über die Kommandos aufrufen kannst.
              So ganz durchschaue ich noch nicht was da bei dir schief ist.
              Kannst du den
              iob stop
              iob fix
              ausführen?
              • I Online
                I Online
                ioBrokerMike
                Das ist alles was zu sehen ist.
                chef@IoB:~$ iob stop
                chef@IoB:~$ iob fix
                chef@IoB:~$
                Kann es sein das ich root bin.
                Was ja nicht sein darf.
                Mfg
                IOBrokerMike
                Achtung ! Sehkraft 25% | 60% , kein scherz
                Systeme : GEEKOM MiniAir 11 | Linux : Trixie 13.6 | HMIP | OpenCCU / RasPi3 | SMA PV Anlage | Robonect Hx | RTL_433
                • HomoranH Homoran hat dieses Thema am aufgespalten
