  4. Avatto TRV06 / ME167 Heizungsthermostat verstellt sich
    6.4k
Geplant Angeheftet Gesperrt Verschoben Gelöst Error/Bug
15 Beiträge 4 Kommentatoren 1.0k Aufrufe 3 Beobachtet
  • K Kraftzwerg
    @Homoran sagte in Avatto TRV06 / ME167 Heizungsthermostat verstellt sich:
    dann stimmt bei dir grundsätzlich etwas nicht!
    Ja, ich stand etwas auf dem Schlauch. iob hätte ich natürlich im docker container ausführen müssen. hier ist der Output:
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
    cat: /sys/devices/virtual/dmi/id/sys_vendor: No such file or directory
    Hardware Vendor :
    Kernel          : aarch64
    Userland        : 64 bit
    Docker          : v11.0.0
    Virtualization  : docker
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     10:51:28 up  1:10,  0 user,  load average: 1.16, 0.56, 0.42
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** TIME AND TIMEZONES ***
    Tue Jan 13 09:51:28 UTC 2026
    Tue Jan 13 10:51:28 CET 2026
    CET +0100
    Etc/UTC
    *** Users and Groups ***
    User that called 'iob diag':
    root
    HOME=/root
    GROUPS=root
    iobroker
    HOME=/opt/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    System has not been booted with systemd as init system (PID 1). Can't operate.
    Failed to connect to bus: Host is down
    Display-Manager:
    Desktop:
    Session:
    *** MEMORY ***
    Mem:            8.2G        2.7G        368M        4.6M        5.5G        5.5G
    Swap:             0B          0B          0B
    Total:          8.2G        2.7G        368M
    Active iob-Instances:   14
             7801 M total memory
             2543 M used memory
             5053 M active memory
             1928 M inactive memory
              351 M free memory
              211 M buffer memory
             5013 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    top - 10:51:28 up  1:10,  0 user,  load average: 1.16, 0.56, 0.42
    Tasks:  21 total,   1 running,  20 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   7801.4 total,    351.2 free,   2543.8 used,   5224.9 buff/cache
    MiB Swap:      0.0 total,      0.0 free,      0.0 used.   5257.6 avail Mem
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem     Type     Size  Used Avail Use% Mounted on
    overlay        overlay  118G   26G   88G  23% /
    tmpfs          tmpfs     64M     0   64M   0% /dev
    shm            tmpfs     64M     0   64M   0% /dev/shm
    /dev/sda2      ext4     118G   26G   88G  23% /opt/iobroker
    [Tue Jan 13 09:40:55 2026] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:47:45:0D vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=LABEL=writable rootfstype=ext4 elevator=deadline rootwait fixrtc quiet splash cgroup_enable=cpuset cgroup_enable=memory cgroup_memory=1 swapaccount=1
    [Tue Jan 13 09:41:00 2026] EXT4-fs (sda2): mounted filesystem 87f67789-4694-4d47-8fcd-d86ef4277f59 ro with ordered data mode. Quota mode: none.
    [Tue Jan 13 09:41:02 2026] EXT4-fs (sda2): re-mounted 87f67789-4694-4d47-8fcd-d86ef4277f59 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE        FSTYPE OPTIONS
    /opt/iobroker    /dev/sda2[/home/ubuntu/docker/iobroker/data]        ext4   rw,relatime,discard,errors=remount-ro
    /etc/resolv.conf /dev/sda2[/var/lib/docker/containers/1aabb09633f35fcd81bc06f1e95e99602a03fda4b7462fc971fa763283f6b9db/resolv.conf] ext4   rw,relatime,discard,errors=remount-ro
    /etc/hostname    /dev/sda2[/var/lib/docker/containers/1aabb09633f35fcd81bc06f1e95e99602a03fda4b7462fc971fa763283f6b9db/hostname]    ext4   rw,relatime,discard,errors=remount-ro
    /etc/hosts       /dev/sda2[/var/lib/docker/containers/1aabb09633f35fcd81bc06f1e95e99602a03fda4b7462fc971fa763283f6b9db/hosts]       ext4   rw,relatime,discard,errors=remount-ro
    /var:
    16M     /var/
    14M     /var/lib/dpkg
    14M     /var/lib
    13M     /var/lib/dpkg/info
    1.9M    /var/cache
    /opt/iobroker/backups:
    296M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    365M    /opt/iobroker/iobroker-data/
    195M    /opt/iobroker/iobroker-data/files
    142M    /opt/iobroker/iobroker-data/backup-objects
    67M     /opt/iobroker/iobroker-data/files/minuvis
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    15M     /opt/iobroker/iobroker-data/states.jsonl
    14M     /opt/iobroker/iobroker-data/objects.jsonl
    14M     /opt/iobroker/iobroker-data/files/minuvis/app/static/js/main.5531d89f.js.map
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-Djx0nwYT.js
    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
    USB-Devices by-id:
    No Devices found 'by-id'
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyUSB0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 100
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 4129)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.19
    javascript:     9.0.11
    nodejs modules from github:     0
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
      system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
    + system.adapter.squeezeboxrpc.0          : squeezeboxrpc         : iobroker                                 -  enabled, port: 9080
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.19
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.3.13   , installed 3.3.13
    Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
    Adapter    "iot"          : 5.0.7    , installed 5.0.7
    Adapter    "javascript"   : 9.0.11   , installed 9.0.11
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "lgtv"         : 2.5.0    , installed 2.5.0
    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
    Adapter    "roborock"     : 0.6.18   , installed 0.6.18
    Adapter    "socketio"     : 6.7.1    , installed 7.0.8
    Adapter    "squeezeboxrpc": 1.6.2    , installed 1.6.2
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "ws"           : 2.6.2    , installed 3.0.19
    Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
    Objects and States
    Objects:        2640
    States:         2272
    Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
    Reading package lists...
    Pending Updates: 41
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       17938      150/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       18825      150/iobroker.js-con
    tcp        0      0 127.0.0.11:35029        0.0.0.0:*               LISTEN      0          15886      -
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       18866      184/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       20588      417/io.web.0
    udp        0      0 127.0.0.11:43237        0.0.0.0:*                           0          15885      -
    udp        0      0 0.0.0.0:3483            0.0.0.0:*                           1000       20606      443/io.squeezeboxrp
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       19133      334/io.chromecast.0
    2026-01-13 10:49:51.020  - warn: zigbee.0 (292) ELEVATED:I02 (fe24) 2 converters available for 'ME167' 'a4c138b9ce8affff' with cluster 'manuSpecificTuya' and type 'commandDataReport'
    2026-01-13 10:49:51.021  - warn: zigbee.0 (292) ELEVATED:I03 (fe24) message received '{"linkquality":196}' from device a4c138b9ce8affff type 'ME167'
    2026-01-13 10:49:51.021  - warn: zigbee.0 (292) ELEVATED:I04 (fe24) value generated '196' from device a4c138b9ce8affff for 'Link quality'
    2026-01-13 10:49:51.021  - warn: zigbee.0 (292) ELEVATED:I02.1a (fe24) converter 1 : Cluster manuSpecificTuya
    2026-01-13 10:49:51.022  - warn: zigbee.0 (292) ELEVATED:I02.0b (fe24)  data: {"seq":33792,"dpValues":[{"dp":5,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,190]}}]} options: {} meta:{"deviceIEEE":"0xa4c138b9ce8affff","logger":"StatesController","state":{"state":""}} result:undefined
    2026-01-13 10:49:51.022  - warn: zigbee.0 (292) ELEVATED:I02.2a (fe24) converter 2 : Cluster manuSpecificTuya
    2026-01-13 10:49:51.022  - warn: zigbee.0 (292) ELEVATED:I02.1b (fe24)  data: {"seq":33792,"dpValues":[{"dp":5,"datatype":2,"data":{"type":"Buffer","data":[0,0,0,190]}}]} options: {} meta:{"deviceIEEE":"0xa4c138b9ce8affff","logger":"StatesController","state":{"state":""}} result:{"local_temperature":19}
    2026-01-13 10:49:51.022  - warn: zigbee.0 (292) ELEVATED:I02.2c (fe24) candidates: [{},{"local_temperature":19}] => payload {"local_temperature":19}
    2026-01-13 10:49:51.023  - warn: zigbee.0 (292) ELEVATED:I03 (fe24) message received '{"local_temperature":19}' from device a4c138b9ce8affff type 'ME167'
    2026-01-13 10:49:51.023  - warn: zigbee.0 (292) ELEVATED:I04 (fe24) value generated '19' from device a4c138b9ce8affff for 'Current temperature measured on the device'
    2026-01-13 10:50:41.060  - info: host.iobroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 3722
    2026-01-13 10:50:44.554  - info: openweathermap.0 (3722) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v22.21.0, js-controller: 7.0.7
    2026-01-13 10:50:52.010  - warn: zigbee.0 (292) ELEVATED:I01 (ec6a) Zigbee Event of Type commandDataReport from device 0xa4c138b9ce8affff, incoming event: {"type":"commandDataReport","data":{"seq":34048,"dpValues":[{"dp":3,"datatype":4,"data":{"type":"Buffer","data":[0]}}]},"linkquality":196,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,164,2,0,133,3,4,0,1,0]},"zclTransactionSequenceNumber":164,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
    2026-01-13 10:50:52.018  - warn: zigbee.0 (292) ELEVATED:I02 (ec6a) 2 converters available for 'ME167' 'a4c138b9ce8affff' with cluster 'manuSpecificTuya' and type 'commandDataReport'
    2026-01-13 10:50:52.019  - warn: zigbee.0 (292) ELEVATED:I03 (ec6a) message received '{"linkquality":196}' from device a4c138b9ce8affff type 'ME167'
    2026-01-13 10:50:52.019  - warn: zigbee.0 (292) ELEVATED:I04 (ec6a) value generated '196' from device a4c138b9ce8affff for 'Link quality'
    2026-01-13 10:50:52.020  - warn: zigbee.0 (292) ELEVATED:I02.1a (ec6a) converter 1 : Cluster manuSpecificTuya
    2026-01-13 10:50:52.020  - warn: zigbee.0 (292) ELEVATED:I02.0b (ec6a)  data: {"seq":34048,"dpValues":[{"dp":3,"datatype":4,"data":{"type":"Buffer","data":[0]}}]} options: {} meta:{"deviceIEEE":"0xa4c138b9ce8affff","logger":"StatesController","state":{"state":""}} result:undefined
    2026-01-13 10:50:52.021  - warn: zigbee.0 (292) ELEVATED:I02.2a (ec6a) converter 2 : Cluster manuSpecificTuya
    2026-01-13 10:50:52.021  - warn: zigbee.0 (292) ELEVATED:I02.1b (ec6a)  data: {"seq":34048,"dpValues":[{"dp":3,"datatype":4,"data":{"type":"Buffer","data":[0]}}]} options: {} meta:{"deviceIEEE":"0xa4c138b9ce8affff","logger":"StatesController","state":{"state":""}} result:{"running_state":"heat"}
    2026-01-13 10:50:52.022  - warn: zigbee.0 (292) ELEVATED:I02.2c (ec6a) candidates: [{},{"running_state":"heat"}] => payload {"running_state":"heat"}
    2026-01-13 10:50:52.022  - warn: zigbee.0 (292) ELEVATED:I03 (ec6a) message received '{"running_state":"heat"}' from device a4c138b9ce8affff type 'ME167'
    2026-01-13 10:50:52.022  - warn: zigbee.0 (292) ELEVATED:I04 (ec6a) value generated '"heat"' from device a4c138b9ce8affff for 'The current running state'
    2026-01-13 10:51:04.793  - info: openweathermap.0 (3722) Terminated (NO_ERROR): Without reason
    2026-01-13 10:51:05.350  - info: host.iobroker instance system.adapter.openweathermap.0 having pid 3722 terminated with code 0 (NO_ERROR)
    und hier sehe ich für zigbee:
    HINT:
    /dev/ttyUSB0
    kann das jetzt plötzlich ein Problem darstellen? Ich kann auch auf by-id umstellen, aber der Adapter wird ja unter USB0 gefunden.
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    @Kraftzwerg sagte in Avatto TRV06 / ME167 Heizungsthermostat verstellt sich:
    /dev/ttyUSB0
    Klare Aussage: NEIN. Wenn das nicht passt läuft der Zigbee Adapter gar nicht.
    Ich habe alle Scripte deaktiviert, weil ich dachte ich habe eventuell einen Fehler eingebaut. Trotzdem passiert das mehrmals am Tag.
    Ein mal ist mir im IOB Webinterface aufgefallen, dass alle Zigbee Geräte getrennt sind. Hier steckt vermutlich das Hauptproblem.
    Unwahrscheinlich. Nicht verbundene Geräte führen nicht dazu das sich Temperaturen ändern.
    Hier ist ein Auszug des Zigbee Logs für den besagten Zeitraum: (Der Adapter a4c138b9ce8affff ist nicht mehr erreichbar)
    Das gepostete Log
    • ist mit aktivem Device-Debug für das ME167 Thermostat gemacht
    • sagt nichts weiter über 'nicht verbundene Geräte aus'
    • zeigt das das Gerät prinzipiell kommuniziert
    • zeigt das die Änderung die da zu sehen ist vom Gerät initiiert wird.
    • zeigt das das Gerät den running state von sich aus auf idle wechselt.
    Das ist jedenfalls erst einmal nur bedingt hilfreich.
    Bitte folgendes machen:
    • Device Debug für das Avatto Gerät ausschalten
    • auf die entsprechenden Datenpunkte einen Trigger setzen, mit dem du die Quelle der Änderung ins Log schreibst. (siehe auch hier: https://forum.iobroker.net/topic/83555/möchte-ermitteln-wer-der-auslöser-für-dp-änderung-ist?_=1768298902629)
    • laufen lassen, und schauen was als 'ursprung' der Änderung auftaucht. Es gibt basierend auf der Antwort dann mehrere mögliche Ursachen.
    Als Schritt 2 (insbesondere wenn als Ursprung der Änderungen der Zigbee Adapter auftaucht):
    • die aktuelle latest version (3.3.3) installieren
    • Device debug wieder aktivieren, unter zu Hilfe nahme dieses Dokumentes (https://github.com/ioBroker/ioBroker.zigbee/wiki/Device-messaging-debug) gezielt die änderungen heraussuchen wo die Temperatur verstellt wird.
    A.
    • K Kraftzwerg
      • Adaptername: ZigBee-Adapter für Xiaomi (und andere) Geräte über Chip cc26xx/cc25xx
      • Link zu Adapterrepository: ?? https://www.iobroker.net/#de/adapters/adapterref/iobroker.zigbee/README.md
      • Adapterversion: 3.1.5
      • js-controller Version: 7.0.7 (scripte deaktiviert seit Problem)
      • Admin Version: 7.7.19
      • Hardwaresystem: Pi4
      • Arbeitsspeicher: 8 GB
      • Festplattenart: SSD
      • Betriebssystem: Ubuntu 24.04.3 LTS
      • Nodejs-Version: keine Ahnung (9.0.11?)
      • NPM-Version: was auch immer das sein soll
      • Installationsart: ? Docker?
      • Image, Docker genutzt: Ja
      • Ort, Name der Imagedatei: buanet/iobroker
      Linux User bitte hier den Output von iob diag einfügen.
      Script v.2025-08-09
      *** BASE SYSTEM ***
      Hardware Vendor :
      Kernel          : aarch64
      Userland        : 64 bit
      Docker          : v11.0.0
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      CET +0100
      Etc/UTC
      root
      HOME=/root
      GROUPS=root
      iobroker
      HOME=/opt/iobroker
      Display-Manager:
      Desktop:
      Session:
      *** MEMORY ***
      Swap:             0B          0B          0B
               7801 M total memory
               2543 M used memory
                351 M free memory
                211 M buffer memory
               5013 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /var:
      16M     /var/
      14M     /var/lib/dpkg
      14M     /var/lib
      1.9M    /var/cache
      USB-Devices by-id:
      HINT:
      /dev/ttyUSB0
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.19
      javascript:     9.0.11
      Adapter State
      + instance is alive
      Objects and States
      Objects:        2640
      States:         2272
      Pending Updates: 41
      Ich bin langsam am verzweifeln, weil ich hier Nachts abwechselnd erfriere, und unter Hitzewallungen leide.
      Ich habe einen Sonoff zigbee 3.0 usb dongle plus
      Daran betreibe ich unter anderem mehrere Avatto TRV06 / ME167 Heizungsthermostate Das lief Jahrelang super.
      Ich habe vor ein paar Tagen ein Firmwareupdate des Zigbee Dongels gemacht.
      • Zigbee Coordinator
        type:ZStack3x0
        version:2-1.2.7.1.
        revision:20250321
        port:/dev/ttyUSB0
        channel:11
        ------------Software versions
        adapter:3.1.5
        installed from:iobroker.zigbee@3.1.5
        ZHC / ZH:25.31.0 / 6.4.2
      Seither verstellen sich die Thermostate willkürlich.
      Z.B. um 05:56 von 17 auf 21 Grad und dann um 06:44 wieder auf 18 Grad
      2026-01-13 05:52:11.946 - warn: zigbee.0 (204538) ELEVATED:I01 (7c2a) Zigbee Event of Type read from device 0xa4c138b9ce8affff, incoming event: {"type":"read","data":["localTime"],"linkquality":196,"groupID":0,"cluster":"genTime","meta":{"rawData":{"type":"Buffer","data":[0,142,0,7,0]},"zclTransactionSequenceNumber":142,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
      2026-01-13 05:52:11.954 - warn: zigbee.0 (204538) ELEVATED:I02 (7c2a) 0 converter available for 'ME167' 'a4c138b9ce8affff' with cluster 'genTime' and type 'read'
      2026-01-13 05:52:11.954 - warn: zigbee.0 (204538) ELEVATED:NOCONV (7c2a) No converter available for 'ME167' 'a4c138b9ce8affff' with cluster 'genTime' and type 'read'
      2026-01-13 05:52:11.954 - warn: zigbee.0 (204538) ELEVATED:I03 (7c2a) message received '{"linkquality":196}' from device a4c138b9ce8affff type 'ME167'
      2026-01-13 05:52:11.955 - warn: zigbee.0 (204538) ELEVATED:I04 (7c2a) value generated '196' from device a4c138b9ce8affff for 'Link quality'
      2026-01-13 05:53:03.790 - warn: zigbee.0 (204538) DeviceAvailability:ELEVATED: Non-pingable device 0xa4c13819e21a438a TS0601 was last seen '2034.494' seconds ago.
      2026-01-13 05:53:03.798 - warn: zigbee.0 (204538) DeviceAvailability:ELEVATED: Non-pingable device 0xa4c1381f2f80da3f TS0601 was last seen '5577.253' seconds ago.
      2026-01-13 05:53:03.802 - warn: zigbee.0 (204538) DeviceAvailability:ELEVATED: Non-pingable device 0xa4c138b9ce8affff TS0601 was last seen '51.862' seconds ago.
      2026-01-13 05:53:03.809 - warn: zigbee.0 (204538) DeviceAvailability:ELEVATED: Non-pingable device 0xa4c138ea8d6265d1 TS0601 was last seen '2655.042' seconds ago.
      2026-01-13 05:53:03.813 - warn: zigbee.0 (204538) DeviceAvailability:ELEVATED: Non-pingable device 0xa4c138fc915e4816 TS0601 was last seen '4559.021' seconds ago.
      2026-01-13 05:53:03.816 - warn: zigbee.0 (204538) DeviceAvailability:ELEVATED: Non-pingable device 0xa4c138420c789578 TS0601 was last seen '510.117' seconds ago.
      2026-01-13 05:53:03.818 - warn: zigbee.0 (204538) DeviceAvailability:ELEVATED: Non-pingable device 0x0ceff6fffe730906 SNZB-04P was last seen '53.313' seconds ago.
      2026-01-13 05:53:03.819 - warn: zigbee.0 (204538) DeviceAvailability:ELEVATED: Non-pingable device 0x881a14fffeecebbc SNZB-04P was last seen '2442.158' seconds ago.
      2026-01-13 05:53:03.823 - warn: zigbee.0 (204538) DeviceAvailability:ELEVATED: Non-pingable device 0xa4c138da5418795a TS0601 was last seen '79.903' seconds ago.
      2026-01-13 05:53:28.258 - warn: zigbee.0 (204538) ELEVATED:I01 (a641) Zigbee Event of Type read from device 0xa4c1381f2f80da3f, incoming event: {"type":"read","data":["localTime"],"linkquality":134,"groupID":0,"cluster":"genTime","meta":{"rawData":{"type":"Buffer","data":[0,204,0,7,0]},"zclTransactionSequenceNumber":204,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":0,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
      2026-01-13 05:53:28.264 - warn: zigbee.0 (204538) ELEVATED:I02 (a641) 0 converter available for 'ME167' 'a4c1381f2f80da3f' with cluster 'genTime' and type 'read'
      2026-01-13 05:53:28.265 - warn: zigbee.0 (204538) ELEVATED:NOCONV (a641) No converter available for 'ME167' 'a4c1381f2f80da3f' with cluster 'genTime' and type 'read'
      2026-01-13 05:53:28.265 - warn: zigbee.0 (204538) ELEVATED:I03 (a641) message received '{"linkquality":134}' from device a4c1381f2f80da3f type 'ME167'
      2026-01-13 05:53:28.265 - warn: zigbee.0 (204538) ELEVATED:I04 (a641) value generated '134' from device a4c1381f2f80da3f for 'Link quality'
      2026-01-13 05:56:43.926 - warn: zigbee.0 (204538) ELEVATED:I01 (a295) Zigbee Event of Type commandDataReport from device 0xa4c138da5418795a, incoming event: {"type":"commandDataReport","data":{"seq":46336,"dpValues":[{"dp":3,"datatype":4,"data":{"type":"Buffer","data":[1]}}]},"linkquality":196,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,227,2,0,181,3,4,0,1,1]},"zclTransactionSequenceNumber":227,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
      2026-01-13 05:56:43.932 - warn: zigbee.0 (204538) ELEVATED:I02 (a295) 2 converters available for 'ME167' 'a4c138da5418795a' with cluster 'manuSpecificTuya' and type 'commandDataReport'
      2026-01-13 05:56:43.932 - warn: zigbee.0 (204538) ELEVATED:I03 (a295) message received '{"linkquality":196}' from device a4c138da5418795a type 'ME167'
      2026-01-13 05:56:43.933 - warn: zigbee.0 (204538) ELEVATED:I04 (a295) value generated '196' from device a4c138da5418795a for 'Link quality'
      2026-01-13 05:56:43.933 - warn: zigbee.0 (204538) ELEVATED:I02.1a (a295) converter 1 : Cluster manuSpecificTuya
      2026-01-13 05:56:43.933 - warn: zigbee.0 (204538) ELEVATED:I02.0b (a295) data: {"seq":46336,"dpValues":[{"dp":3,"datatype":4,"data":{"type":"Buffer","data":[1]}}]} options: {} meta:{"deviceIEEE":"0xa4c138da5418795a","logger":"StatesController","state":{"state":""}} result:undefined
      2026-01-13 05:56:43.933 - warn: zigbee.0 (204538) ELEVATED:I02.2a (a295) converter 2 : Cluster manuSpecificTuya
      2026-01-13 05:56:43.933 - warn: zigbee.0 (204538) ELEVATED:I02.1b (a295) data: {"seq":46336,"dpValues":[{"dp":3,"datatype":4,"data":{"type":"Buffer","data":[1]}}]} options: {} meta:{"deviceIEEE":"0xa4c138da5418795a","logger":"StatesController","state":{"state":""}} result:{"running_state":"idle"}
      2026-01-13 05:56:43.933 - warn: zigbee.0 (204538) ELEVATED:I02.2c (a295) candidates: [{},{"running_state":"idle"}] => payload {"running_state":"idle"}
      2026-01-13 05:56:43.934 - warn: zigbee.0 (204538) ELEVATED:I03 (a295) message received '{"running_state":"idle"}' from device a4c138da5418795a type 'ME167'
      2026-01-13 05:56:43.934 - warn: zigbee.0 (204538) ELEVATED:I04 (a295) value generated '"idle"' from device a4c138da5418795a for 'The current running state'
      2026-01-13 05:58:03.790 - warn: zigbee.0 (204538) DeviceAvailability:ELEVATED: Non-pingable device 0xa4c13819e21a438a TS0601 was last seen '2334.494' seconds ago.
      2026-01-13 05:58:03.798 - warn: zigbee.0 (204538) DeviceAvailability:ELEVATED: Non-pingable device 0xa4c1381f2f80da3f TS0601 was last seen '275.546' seconds ago.
      2026-01-13 05:58:03.802 - warn: zigbee.0 (204538) DeviceAvailability:ELEVATED: Non-pingable device 0xa4c138b9ce8affff TS0601 was last seen '351.862' seconds ago.
      2026-01-13 05:58:03.809 - warn: zigbee.0 (204538) DeviceAvailability:ELEVATED: Non-pingable device 0xa4c138ea8d6265d1 TS0601 was last seen '2955.042' seconds ago.
      2026-01-13 05:58:03.812 - warn: zigbee.0 (204538) DeviceAvailability:ELEVATED: Non-pingable device 0xa4c138fc915e4816 TS0601 was last seen '4859.02' seconds ago.
      2026-01-13 05:58:03.817 - warn: zigbee.0 (204538) DeviceAvailability:ELEVATED: Non-pingable device 0xa4c138420c789578 TS0601 was last seen '810.117' seconds ago.
      2026-01-13 05:58:03.818 - warn: zigbee.0 (204538) DeviceAvailability:ELEVATED: Non-pingable device 0x0ceff6fffe730906 SNZB-04P was last seen '353.313' seconds ago.
      2026-01-13 05:58:03.819 - warn: zigbee.0 (204538) DeviceAvailability:ELEVATED: Non-pingable device 0x881a14fffeecebbc SNZB-04P was last seen '2742.158' seconds ago.
      2026-01-13 05:58:03.822 - warn: zigbee.0 (204538) DeviceAvailability:ELEVATED: Non-pingable device 0xa4c138da5418795a TS0601 was last seen '79.902' seconds ago.
      Und dann tauchen solche Meldungen im Log auf, wenn die Temperatur verstellt wird. Was heißt "der current_heating_setpoint wird calibriert?" Ich stelle da feste Werte ein
      2026-01-13 06:43:47.029 - warn: zigbee.0 (204538) ELEVATED:O04 (b626) convert current_heating_setpoint with value 18 and options {} for device 0xa4c138b9ce8affff with Endpoint current_heating_setpoint
      Hat jemand eine Idee was da los sein kann?
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      Diese Meldung besagt nur, das
      • der Adapter erkannt hat das jemand dein Datenpunkt current_heating_setpoint geändert hat.
      • der Adapter den vom Benutzer angegebenen Wert entsprechend der im Code vorgegebenen Umrechnungsregel so umgerechnet hat das er an das Gerät mit der Addresse 0xa4c138b9ce8affffgeschickt werden kann.
      Sprich: Du hast was geändert, der Adapter hat es an das Gerät geschickt. Spätere Meldungen sagen Dir dann ob das Gerät das auch akzeptiert hat.
      A.
      • AsgothianA Asgothian
        /dev/ttyUSB0
        Das gepostete Log
        A.
        Kraftzwerg
        @Asgothian sagte in Avatto TRV06 / ME167 Heizungsthermostat verstellt sich:
        Ok, ich habe jetzt ein Script für die 7 Thermostate gestartet und Debug wieder abgeschaltet.
        Nur war ich um die Zeit gar nicht wach
        Ich werde das jetzt mal ein, zwei Tage im Auge behalten, und mich dann mit den Ergebnissen melden.
        Vielen Dank
        Thomas
        • K Kraftzwerg
          Vielen Dank
          Thomas
          stimmt die Zeitzone?
          CET +0100
          Etc/UTC
          sieht komisch aus
            CET +0100
            Etc/UTC
            sieht komisch aus
            Kraftzwerg
            schrieb am zuletzt editiert von Kraftzwerg
            sieht komisch aus
            Im Log sehe ich die richtige Uhrzeit. Mein Ubuntu Host läuft auch richtig, und der Docker Container hat auch die richtige Systemzeit. Wie soll es den aussehen bei Zeitzone Deutschland?
            @asgothian
            Um 6 Uhr haben sich 6 von 7 Thermostaten auf 21 grad gestellt.
            Im Log habe ich:
            2026-01-14 06:00:03.179 - warn: javascript.0 (211) script.js.debug: system.adapter.zigbee.0
            2026-01-14 06:00:34.493 - warn: javascript.0 (211) script.js.debug: system.adapter.zigbee.0
            2026-01-14 06:00:34.691 - warn: javascript.0 (211) script.js.debug: system.adapter.zigbee.0
            2026-01-14 06:00:41.643 - warn: javascript.0 (211) script.js.debug: system.adapter.zigbee.0
            2026-01-14 06:00:46.132 - warn: javascript.0 (211) script.js.debug: system.adapter.zigbee.0
            2026-01-14 06:00:49.518 - warn: javascript.0 (211) script.js.debug: system.adapter.zigbee.0
            Bedeutet das, dass der Zigbee Adapter die Werte verändert?
            Ich glaube seit dem Firmware Update schmierrt mir das Zigbee Netzwerk gelegentlich ab. Wie gesagt, im WebIf (Zigbee Panell) hatte ich ein mal gesehen, das alle Geräte rot waren.
            Ich lerne die Thermostate jetzt neu ein, und wenn die sich weiter verstellen, gehe ich auf eine alte Firmware zurück.
            LG
            Thomas
            HomoranH AsgothianA 2 Antworten Letzte Antwort
            • K Kraftzwerg
              sieht komisch aus
              @asgothian
              Im Log habe ich:
              LG
              Thomas
              irgendwas wie Timezone Berlin...
                Kraftzwerg
                Ich glaube das ist bei Ubuntu Server einfach so. CET kam mir auch komisch vor, aber zur Winterzeit haben wir tatsächlich CET. Ich habe das auch nochmal versucht neu zu setzen, aber es bleibt dabei. Europe/Berlin ist glaube ich nur ein Alias
                someuser@someserver:~$ sudo dpkg-reconfigure tzdata
                Current default time zone: 'Europe/Berlin'
                Local time is now:      Wed Jan 14 08:53:38 CET 2026.
                Universal Time is now:  Wed Jan 14 07:53:38 UTC 2026.
                someuser@someserver:~$ date
                Wed Jan 14 08:54:11 CET 2026
                • K Kraftzwerg
                  sieht komisch aus
                  @asgothian
                  Im Log habe ich:
                  LG
                  Thomas
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  Ohne Logs daraus zu schliessen das ein Firmware Update da "schuld" ist ist... mutig.
                  Auch das ist eher nicht der richtige Weg:
                  • der Weg zurück auf eine alte Firmware ist auf dem Thermostat eher nicht möglich
                  • Die installation eines älteren Zigbee Adapters ist möglich, bringt aber nichts. Der Adapter hat keine Automatisierungen für die Thermostate
                  • ein Firmware-Downgrade auf dem Zigbee-Stick wird auch nichts bringen.
                  Ich vermute:
                  • die Thermostate haben einen 'weekly shedule' gesetzt.
                  • sie sind auf 'automatik' gesetzt - so das sie die Temperatur aus dem Schedule setzen.
                  Bitte prüfen:
                  • wie ist der system_mode gesetzt ?
                  • was steht in den States schedule_xxxx ? (sollte es je einen für jeden Tag geben)
                  A.
                  • K Kraftzwerg
                    Nein, das ist im Docker-Image 'einfach so' eingebacken.
                      Ich vermute:
                      Bitte prüfen:
                      A.
                      Kraftzwerg
                      Ich vermute:
                      Bitte prüfen:
                      A.
                      Hallo Asgothian
                      Das ist mir jetzt unsagbar peinlich. Eines meiner deaktivierten Scripte hatte es dann kaputt gemacht.
                      Ich hatte ein Script gebaut, welches regestriert wenn ein Fenster geöffnet wurde, und die entsprechende Heizung in den mode off setzt.
                      Wenn das Fenster wieder zu ist, geht die Heizung auf Auto und stellt die vorherige Temperatur wieder ein. (das hatte ich so gemacht weil "komischer Weise" nach dem setzen auf mode auto, die Temperatur auf 16 grad gesetzt wurde....)
                      Ich hätte wohl heat als mode setzen sollen.
                      Die Schedule ist:
                      06:00/21.0 08:00/16.0 12:00/21.0 14:00/16.0 18:00/21.0 22:00/16.0
                      Und der mode stand noch auf Auto.
                      Vielen Dank.
                      Das Problem saß vor dem Rechner.
                      • K Kraftzwerg has marked this topic as solved on
                      • K Kraftzwerg
                        Ich vermute:
                        Bitte prüfen:
                        A.
                        Hallo Asgothian
                        Die Schedule ist:
                        Vielen Dank.
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        Muss es nicht - es war eine gute Übung in systematischer Analyse.
                        Wenn du dir die Schedules anschaust wird auch klar warum der Thermostat von sich aus die Solltemperatur anpasst:
                        Das ist eine Liste von Uhrzeiten (Schaltzeiten) und Temperaturen, basierend auf dieser doku: https://www.zigbee2mqtt.io/devices/ME167.html#schedule-tuesday-text )Link dazu bekommst du im Übrigen von der Info-Anzeige des Adapters)
                        Solange der Thermostat auf auto steht arbeitet er diese Zeitpläne ab. Und wenn von off auf auto gestellt wird, dann schaut er nach wo er sich im Zeitplan befindet und setzt die Solltemperatur entsprechend.
                        A.
