  4. Adapter Klipper-Moonraker
klippermoonrakeradapter update
163 Beiträge 26 Kommentatoren 33.8k Aufrufe 24 Beobachtet
  • NegaleinN Negalein
    @Merlin123 sagte in Adapter Klipper-Moonraker:
    Damit geht es dann.
    Hallo
    bei mir steht im Link auch http://10.0.1.244/server/files/gcodes/.thumbs/support-test_PETG_1h17m-300x300.png
    Wie hast du das im Blockly gelöst, dass er an support-test_PETG_1h17m noch das -300x300 anhängt
    2025-12-24 22:47:13.222 - error: javascript.0 (1605858) script.js.3D-Drucker.Klipper_Thumb: Cannot parse "support-test_PETG_1h17m.gcode": SyntaxError: Unexpected token 's', "support-te"... is not valid JSON
    2025-12-24 22:47:13.225 - error: javascript.0 (1605858) script.js.3D-Drucker.Klipper_Thumb: Error: TypeError: Cannot read properties of null (reading 'slice')
    2025-12-24 22:47:13.226 - error: javascript.0 (1605858) script.js.3D-Drucker.Klipper_Thumb: at Object. (script.js.3D-Drucker.Klipper_Thumb:9:85)
    2025-12-24 22:47:13.226 - error: javascript.0 (1605858) script.js.3D-Drucker.Klipper_Thumb: at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    2025-12-24 22:47:13.226 - error: javascript.0 (1605858) script.js.3D-Drucker.Klipper_Thumb: at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    2025-12-24 22:47:13.226 - error: javascript.0 (1605858) script.js.3D-Drucker.Klipper_Thumb: at JavaScript.emit (node:events:524:28)
    2025-12-24 22:47:13.226 - error: javascript.0 (1605858) script.js.3D-Drucker.Klipper_Thumb: at JavaScript.emit (node:domain:489:12)
    2025-12-24 22:47:13.226 - error: javascript.0 (1605858) script.js.3D-Drucker.Klipper_Thumb: at Immediate. (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11138:53)
    2025-12-24 22:47:13.226 - error: javascript.0 (1605858) script.js.3D-Drucker.Klipper_Thumb: at processImmediate (node:internal/timers:483:21)
    Merlin123M Offline
    Merlin123M Offline
    Merlin123
    #149
    @Negalein
    so :)
    Beta-Tester
    • Merlin123M Merlin123
      @Negalein
      so :)
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      #150
      so :)
      hab ich, aber funktioniert nicht. :(
      Name und Thumbnail DB sind String?
      ° Fixer ---> iob fix
      Merlin123M 1 Antwort Letzte Antwort
        so :)
        Merlin123M Offline
        Merlin123M Offline
        Merlin123
        #151
        @Negalein
        Filename ist string.
        Inhalt aktuell
        {"eventtime":101.473435832,"value":"Stand_0.15mm_PLA_Generic Klipper Printer_26m47s.gcode"}
        Ich hol das aber über die mqtt Schnittstelle
        Das Bild hol ich mir direkt vom Drucker
        Beta-Tester
          @Negalein
          Inhalt aktuell
          NegaleinN Offline
          NegaleinN Offline
          Negalein
          #152
          wie machst du das?
          Hast du ein kurzes How-To? :)
            wie machst du das?
            Merlin123M Offline
            Merlin123M Offline
            Merlin123
            #153
            @Negalein Kurzfassung:
            mqtt Server in ioBroker einrichten, dann Moonraker konfigurieren:
            Moonraker mqtt
            Beta-Tester
              Moonraker mqtt
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              #154
              Moonraker mqtt
              Danke, das hab ich vorher gefunden.
              Ich finde nichts, was ich dort eintragen muss, um den Link zum Thumb zu bekommen.
              Alles andere bekomm ich vom Klipper-Adapter.
                Moonraker mqtt
                Merlin123M Offline
                Merlin123M Offline
                Merlin123
                #155
                @Negalein Das ist mein Blockly dazu:
                  <variables>
                    <variable id="BXYL{xhaLkN~v2Ldl!%!">text</variable>
                  </variables>
                  <block type="on" id="/Z2O}ZB#,a]kn33Dz4F$" x="116" y="2253">
                    <field name="OID">mqtt.0.printer.V2.660.klipper.state.print_stats.filename</field>
                    <statement name="STATEMENT">
                      <block type="variables_set" id="y[Oc#E_92,_2BKo4(5~[">
                        <field name="VAR" id="BXYL{xhaLkN~v2Ldl!%!">text</field>
                        <value name="VALUE">
                          <block type="get_attr" id="XXR]WqWt.=HMLUr3gR}@">
                            <value name="PATH">
                              <shadow type="text" id="rrx*$IEHd@w{;*~Z+8`n">
                                <field name="TEXT">value</field>
                              </shadow>
                            </value>
                            <value name="OBJECT">
                              <shadow type="get_object" id="^cMzi*_aj{`Pl0P725m~">
                              </shadow>
                              <block type="on_source" id="pgo{+7GzQz;]qj)e34}A">
                              </block>
                            </value>
                          </block>
                        </value>
                        <next>
                          <block type="update" id="bIOV@RC*Q+u,j_l+cDZ,">
                            <field name="OID">0_userdata.0.3D_Drucker_K1_Filename</field>
                              <block type="text_getSubstring" id=";P~^,bl^VhcaeFBrn4B7">
                                <mutation at1="false" at2="true"></mutation>
                                <field name="WHERE1">FIRST</field>
                                <field name="WHERE2">FROM_START</field>
                                <value name="STRING">
                                  <block type="variables_get" id=".)~:q(Mh|eeSdPJRu*2!">
                                  </block>
                                </value>
                                <value name="AT2">
                                  <block type="math_arithmetic" id="~]oa3qPRWU)spG%YB1]]">
                                    <value name="A">
                                      <shadow type="math_number" id="PqrA)w7#cW-.+R7[s$Ut">
                                        <field name="NUM">1</field>
                                      </shadow>
                                      <block type="text_indexOf" id="r51`DlwiN)v*}8k4q}5p">
                                        <field name="END">FIRST</field>
                                          <block type="variables_get" id="sqPwTzw6?t1]F1dwmj|P">
                                          </block>
                                        </value>
                                        <value name="FIND">
                                          <shadow type="text" id="NN88q$[rF?qy3R1S,=Fk">
                                            <field name="TEXT">.gcode</field>
                                          </shadow>
                                        </value>
                                      </block>
                                    </value>
                                    <value name="B">
                                      <shadow type="math_number" id="Gp.#K1A?Y{{b4u]f,mK_">
                                      </shadow>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </value>
                            <next>
                              <block type="update" id="v~`h#IPc]?2X#3=M{X[a">
                                <field name="OID">0_userdata.0.3D_Drucker_K1_Thumbnail</field>
                                  <block type="text_join" id="=uC)c{XD(`=yL3+qnM$/">
                                    <value name="ADD0">
                                      <block type="text" id="+hu6Z]DDV49vxZEG3^KI">
                                        <field name="TEXT">http://192.168.0.252:4409/server/files/gcodes/.thumbs/</field>
                                      </block>
                                    </value>
                                    <value name="ADD1">
                                      <block type="text_getSubstring" id=".jX}L{b`]tqX[lP+wIR2">
                                          <block type="variables_get" id="ZUXf!~C]B[?oTqjrU3mF">
                                          </block>
                                        </value>
                                        <value name="AT2">
                                          <block type="math_arithmetic" id="rArUrH5JD`!U0PI6`=Lt">
                                            <value name="A">
                                              </shadow>
                                              <block type="text_indexOf" id="Gji4dA%oP(rS[%9W%X(m">
                                                  <block type="variables_get" id="i=BXKzmS]z$x=!47DA!B">
                                                  </block>
                                                </value>
                                                <value name="FIND">
                                                  <shadow type="text" id="nTgAoKx?A/?1e#g9JTXQ">
                                                  </shadow>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="B">
                                              <shadow type="math_number" id="u3_-Ii7/U+4%YQw8Az@I">
                                              </shadow>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <value name="ADD2">
                                      <block type="text" id="sn3+k)T(}R(KvqNhQ6;v">
                                        <field name="TEXT">-320x320.png</field>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </statement>
                  </block>
                </xml>
                Beta-Tester
                    <variables>
                    </variables>
                              <value name="PATH">
                                </shadow>
                              </value>
                                </shadow>
                                </block>
                              </value>
                            </block>
                          </value>
                          <next>
                                    </block>
                                  </value>
                                  <value name="AT2">
                                      <value name="A">
                                        </shadow>
                                            </block>
                                          </value>
                                          <value name="FIND">
                                            </shadow>
                                          </value>
                                        </block>
                                      </value>
                                      <value name="B">
                                        </shadow>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <next>
                                      <value name="ADD0">
                                        </block>
                                      </value>
                                      <value name="ADD1">
                                            </block>
                                          </value>
                                          <value name="AT2">
                                              <value name="A">
                                                </shadow>
                                                    </block>
                                                  </value>
                                                  <value name="FIND">
                                                    </shadow>
                                                  </value>
                                                </block>
                                              </value>
                                              <value name="B">
                                                </shadow>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                      <value name="ADD2">
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </next>
                        </block>
                      </statement>
                    </block>
                  </xml>
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  #156
                  ist eigentlich ident zu meinem.
                  komisch, dass es bei mir nicht funktioniert.
                    Merlin123M Offline
                    Merlin123M Offline
                    Merlin123
                    #157
                    @Negalein hmmm... dann hab ich spontan keine idee :(
                    Beta-Tester
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      #158
                      ich bekomm diese Fehler
                      javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at processImmediate (node:internal/timers:483:21)
                      javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11138:53)
                      javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at JavaScript.emit (node:domain:489:12)
                      javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at JavaScript.emit (node:events:524:28)
                      javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at JavaScript.onStateChange (/opt/iobrokr/node_modules/iobroker.javascript/src/main.ts:752:25)
                      javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
                      javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at Object.<anonymous> (script.js.3D-Drucker.Klipper_Thumb:9:81)
                      javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: Error: TypeError: Cannot read properties of null (reading 'slice')
                      javascript.0 2025-12-27 14:23:54.081	error	script.js.3D-Drucker.Klipper_Thumb: Cannot parse "Emely_2.gcode": SyntaxError: Unexpected token 'E', "Emely_2.gcode" is not valid JSON
                        Merlin123M Offline
                        Merlin123M Offline
                        Merlin123
                        #159
                        @Negalein ich habe da ein JSON. Du musst dann den Text anders verarbeiten.
                        Trigger mal auf den Datenpunkt wo bei dir jetzt im Log Emely_2.gcode stand.
                        ggf. das Blockly entsprechend anpassen.
                        Beta-Tester
                        NegaleinN 2 Antworten Letzte Antwort
                          NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          #160
                          ich bekomm weder im Adapter noch vom Script ein JSON :(
                          kennst du dich da aus?
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            #161
                            es läuft :)
                              es läuft :)
                              Merlin123M Offline
                              Merlin123M Offline
                              Merlin123
                              #162
                              @Negalein Klasse! Das ist leider immer irgendwie tricky.
                              Beta-Tester
                              • Lucifor1976L Lucifor1976
                                Sehr schön das sich jemand um Klipper kümmert :)
                                Gerade zwei Instanzen installiert.
                                Was mir direkt auffällt:
                                Progress stimmt nicht mit Klipper überein Klipper= 35% Adapter = 44%? Wobei der Progress /100 angezeigt wird?
                                (klipper-moonraker.0.display_status.progress)
                                Verbrauchtes Filament stimmt nicht mit Klipper überein, Klipper= 1m Adapter 1,2m
                                (klipper-moonraker.0.print_stats.total_duration)
                                Der Gerade gedruckte Layer wird nicht übertragen. (Null)
                                (klipper-moonraker.0.print_stats.info.current_layer)
                                Ebenfalls für Total Layer
                                (klipper-moonraker.0.print_stats.info.total_layer)
                                Ansonsten saubere Arbeit :) und Danke dafür.
                                Enno.von.Schwerin
                                #163
                                @Lucifor1976 bischen her das du die Frage gepostet hast.
                                Bei mir findet sich der "richtige" Wert unter: klipper-moonraker.1.virtual_sdcard.progress
                                Jedenfalls ist das der Wert der mit 100 multipliziert, genau dem entspricht was ich auch bei meinem Drucker über die WebGUI sehe.
