  4. Adapter Klipper-Moonraker
klippermoonrakeradapter update
163 Beiträge 26 Kommentatoren 33.8k Aufrufe 24 Beobachtet
  • NegaleinN Negalein
    @stenmic sagte in Adapter Klipper-Moonraker:
    so mach ich es
    ich verwende dein Thjmbnail-Blockly, aber mir wird nichts in den DP geschrieben.
    Thumb-URL = http://10.0.1.244/server/files/gcodes/.thumbs/Santa%20Cat_PLA-300x300.png?date=1765399759.793023
    NegaleinN Offline
    NegaleinN Offline
    Negalein
    #146
    funktioniert bei wem das Thumbnail Blockly?
    Mir wirft es Fehler aus und es wird nichts in den DP geschrieben.
    javascript.0 2025-12-18 10:40:16.457	error	script.js.3D-Drucker.Klipper_Thumb: at processImmediate (node:internal/timers:483:21)
    javascript.0 2025-12-18 10:40:16.457	error	script.js.3D-Drucker.Klipper_Thumb: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11138:53)
    javascript.0 2025-12-18 10:40:16.457	error	script.js.3D-Drucker.Klipper_Thumb: at JavaScript.emit (node:domain:489:12)
    javascript.0 2025-12-18 10:40:16.457	error	script.js.3D-Drucker.Klipper_Thumb: at JavaScript.emit (node:events:524:28)
    javascript.0 2025-12-18 10:40:16.457	error	script.js.3D-Drucker.Klipper_Thumb: at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
    javascript.0 2025-12-18 10:40:16.457	error	script.js.3D-Drucker.Klipper_Thumb: at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
    javascript.0 2025-12-18 10:40:16.457	error	script.js.3D-Drucker.Klipper_Thumb: at Object.<anonymous> (script.js.3D-Drucker.Klipper_Thumb:9:85)
    javascript.0 2025-12-18 10:40:16.456	error	script.js.3D-Drucker.Klipper_Thumb: Error: TypeError: Cannot read properties of null (reading 'slice')
    javascript.0 2025-12-18 10:40:16.451	error	script.js.3D-Drucker.Klipper_Thumb: Cannot parse "support-test_PLA_20m25s.gcode": SyntaxError: Unexpected token 's', "support-te"... is not valid JSON
    var text;
    on({ id: 'klipper-moonraker.0.print_stats.filename' /* Filename of the Print */, change: 'ne' }, async (obj) => {
      let value = obj.state.val;
      let oldValue = obj.oldState.val;
      text = getAttr((obj.state ? obj.state.val : ''), 'value');
      setState('0_userdata.0.3DDrucker.Snapmaker_U1.print_stats.Name' /* Name */, (text.slice(0, (text.indexOf('.gcode') + 1) - 1)), true);
      setState('0_userdata.0.3DDrucker.Snapmaker_U1.print_stats.Thumbnail' /* Thumbnail */, (['http://10.0.1.244/server/files/gcodes/.thumbs/',text.slice(0, (text.indexOf('.gcode') + 1) - 1),'.png'].join('')), true);
    ° Fixer ---> iob fix
      var text;
      NegaleinN Offline
      NegaleinN Offline
      Negalein
      #147
      Hallo Paul
      Du bist ein Blockly Guru :)
      Kannst du dir das anschaun, warum es diese Fehler gibt und warum das Blockly nicht funktioniert.
      • Merlin123M Merlin123
        @stenmic Problem gefunden :D
        Ich hatte ein x-beliebiges File kopiert...
        Bei mir werden immer 3 Thumbs erzeugt: 32x32, 100x100 und 320x320.
        Ich hab ein 32x32 kopiert ;)
        UND:
        Ich muss an den Filenamen ein
        -320x320
        anhängen.
        Damit geht es dann.
        Also vielen Dank nochmal :)
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        #148
        @Merlin123 sagte in Adapter Klipper-Moonraker:
        Damit geht es dann.
        Hallo
        bei mir steht im Link auch http://10.0.1.244/server/files/gcodes/.thumbs/support-test_PETG_1h17m-300x300.png
        Wie hast du das im Blockly gelöst, dass er an support-test_PETG_1h17m noch das -300x300 anhängt
        2025-12-24 22:47:13.222 - error: javascript.0 (1605858) script.js.3D-Drucker.Klipper_Thumb: Cannot parse "support-test_PETG_1h17m.gcode": SyntaxError: Unexpected token 's', "support-te"... is not valid JSON
        2025-12-24 22:47:13.225 - error: javascript.0 (1605858) script.js.3D-Drucker.Klipper_Thumb: Error: TypeError: Cannot read properties of null (reading 'slice')
        2025-12-24 22:47:13.226 - error: javascript.0 (1605858) script.js.3D-Drucker.Klipper_Thumb: at Object. (script.js.3D-Drucker.Klipper_Thumb:9:85)
        2025-12-24 22:47:13.226 - error: javascript.0 (1605858) script.js.3D-Drucker.Klipper_Thumb: at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
        2025-12-24 22:47:13.226 - error: javascript.0 (1605858) script.js.3D-Drucker.Klipper_Thumb: at JavaScript.onStateChange (/opt/iobroker/node_modules/iobroker.javascript/src/main.ts:752:25)
        2025-12-24 22:47:13.226 - error: javascript.0 (1605858) script.js.3D-Drucker.Klipper_Thumb: at JavaScript.emit (node:events:524:28)
        2025-12-24 22:47:13.226 - error: javascript.0 (1605858) script.js.3D-Drucker.Klipper_Thumb: at JavaScript.emit (node:domain:489:12)
        2025-12-24 22:47:13.226 - error: javascript.0 (1605858) script.js.3D-Drucker.Klipper_Thumb: at Immediate. (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11138:53)
        2025-12-24 22:47:13.226 - error: javascript.0 (1605858) script.js.3D-Drucker.Klipper_Thumb: at processImmediate (node:internal/timers:483:21)
        Merlin123M 1 Antwort Letzte Antwort
          Damit geht es dann.
          Hallo
          Merlin123M Offline
          Merlin123M Offline
          Merlin123
          #149
          @Negalein
          so :)
          Beta-Tester
            @Negalein
            so :)
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            #150
            so :)
            hab ich, aber funktioniert nicht. :(
            Name und Thumbnail DB sind String?
              so :)
              Merlin123M Offline
              Merlin123M Offline
              Merlin123
              #151
              @Negalein
              Filename ist string.
              Inhalt aktuell
              {"eventtime":101.473435832,"value":"Stand_0.15mm_PLA_Generic Klipper Printer_26m47s.gcode"}
              Ich hol das aber über die mqtt Schnittstelle
              Das Bild hol ich mir direkt vom Drucker
              Beta-Tester
                @Negalein
                Inhalt aktuell
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                #152
                wie machst du das?
                Hast du ein kurzes How-To? :)
                  wie machst du das?
                  Merlin123M Offline
                  Merlin123M Offline
                  Merlin123
                  #153
                  @Negalein Kurzfassung:
                  mqtt Server in ioBroker einrichten, dann Moonraker konfigurieren:
                  Moonraker mqtt
                  Beta-Tester
                    Moonraker mqtt
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #154
                    Moonraker mqtt
                    Danke, das hab ich vorher gefunden.
                    Ich finde nichts, was ich dort eintragen muss, um den Link zum Thumb zu bekommen.
                    Alles andere bekomm ich vom Klipper-Adapter.
                      Moonraker mqtt
                      Merlin123M Offline
                      Merlin123M Offline
                      Merlin123
                      #155
                      @Negalein Das ist mein Blockly dazu:
                        <variables>
                          <variable id="BXYL{xhaLkN~v2Ldl!%!">text</variable>
                        </variables>
                        <block type="on" id="/Z2O}ZB#,a]kn33Dz4F$" x="116" y="2253">
                          <field name="OID">mqtt.0.printer.V2.660.klipper.state.print_stats.filename</field>
                          <statement name="STATEMENT">
                            <block type="variables_set" id="y[Oc#E_92,_2BKo4(5~[">
                              <field name="VAR" id="BXYL{xhaLkN~v2Ldl!%!">text</field>
                              <value name="VALUE">
                                <block type="get_attr" id="XXR]WqWt.=HMLUr3gR}@">
                                  <value name="PATH">
                                    <shadow type="text" id="rrx*$IEHd@w{;*~Z+8`n">
                                      <field name="TEXT">value</field>
                                    </shadow>
                                  </value>
                                  <value name="OBJECT">
                                    <shadow type="get_object" id="^cMzi*_aj{`Pl0P725m~">
                                    </shadow>
                                    <block type="on_source" id="pgo{+7GzQz;]qj)e34}A">
                                    </block>
                                  </value>
                                </block>
                              </value>
                              <next>
                                <block type="update" id="bIOV@RC*Q+u,j_l+cDZ,">
                                  <field name="OID">0_userdata.0.3D_Drucker_K1_Filename</field>
                                    <block type="text_getSubstring" id=";P~^,bl^VhcaeFBrn4B7">
                                      <mutation at1="false" at2="true"></mutation>
                                      <field name="WHERE1">FIRST</field>
                                      <field name="WHERE2">FROM_START</field>
                                      <value name="STRING">
                                        <block type="variables_get" id=".)~:q(Mh|eeSdPJRu*2!">
                                        </block>
                                      </value>
                                      <value name="AT2">
                                        <block type="math_arithmetic" id="~]oa3qPRWU)spG%YB1]]">
                                          <value name="A">
                                            <shadow type="math_number" id="PqrA)w7#cW-.+R7[s$Ut">
                                              <field name="NUM">1</field>
                                            </shadow>
                                            <block type="text_indexOf" id="r51`DlwiN)v*}8k4q}5p">
                                              <field name="END">FIRST</field>
                                                <block type="variables_get" id="sqPwTzw6?t1]F1dwmj|P">
                                                </block>
                                              </value>
                                              <value name="FIND">
                                                <shadow type="text" id="NN88q$[rF?qy3R1S,=Fk">
                                                  <field name="TEXT">.gcode</field>
                                                </shadow>
                                              </value>
                                            </block>
                                          </value>
                                          <value name="B">
                                            <shadow type="math_number" id="Gp.#K1A?Y{{b4u]f,mK_">
                                            </shadow>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </value>
                                  <next>
                                    <block type="update" id="v~`h#IPc]?2X#3=M{X[a">
                                      <field name="OID">0_userdata.0.3D_Drucker_K1_Thumbnail</field>
                                        <block type="text_join" id="=uC)c{XD(`=yL3+qnM$/">
                                          <value name="ADD0">
                                            <block type="text" id="+hu6Z]DDV49vxZEG3^KI">
                                              <field name="TEXT">http://192.168.0.252:4409/server/files/gcodes/.thumbs/</field>
                                            </block>
                                          </value>
                                          <value name="ADD1">
                                            <block type="text_getSubstring" id=".jX}L{b`]tqX[lP+wIR2">
                                                <block type="variables_get" id="ZUXf!~C]B[?oTqjrU3mF">
                                                </block>
                                              </value>
                                              <value name="AT2">
                                                <block type="math_arithmetic" id="rArUrH5JD`!U0PI6`=Lt">
                                                  <value name="A">
                                                    </shadow>
                                                    <block type="text_indexOf" id="Gji4dA%oP(rS[%9W%X(m">
                                                        <block type="variables_get" id="i=BXKzmS]z$x=!47DA!B">
                                                        </block>
                                                      </value>
                                                      <value name="FIND">
                                                        <shadow type="text" id="nTgAoKx?A/?1e#g9JTXQ">
                                                        </shadow>
                                                      </value>
                                                    </block>
                                                  </value>
                                                  <value name="B">
                                                    <shadow type="math_number" id="u3_-Ii7/U+4%YQw8Az@I">
                                                    </shadow>
                                                  </value>
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                          <value name="ADD2">
                                            <block type="text" id="sn3+k)T(}R(KvqNhQ6;v">
                                              <field name="TEXT">-320x320.png</field>
                                            </block>
                                          </value>
                                        </block>
                                      </value>
                                    </block>
                                  </next>
                                </block>
                              </next>
                            </block>
                          </statement>
                        </block>
                      </xml>
                      Beta-Tester
                          <variables>
                          </variables>
                                    <value name="PATH">
                                      </shadow>
                                    </value>
                                      </shadow>
                                      </block>
                                    </value>
                                  </block>
                                </value>
                                <next>
                                          </block>
                                        </value>
                                        <value name="AT2">
                                            <value name="A">
                                              </shadow>
                                                  </block>
                                                </value>
                                                <value name="FIND">
                                                  </shadow>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="B">
                                              </shadow>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <next>
                                            <value name="ADD0">
                                              </block>
                                            </value>
                                            <value name="ADD1">
                                                  </block>
                                                </value>
                                                <value name="AT2">
                                                    <value name="A">
                                                      </shadow>
                                                          </block>
                                                        </value>
                                                        <value name="FIND">
                                                          </shadow>
                                                        </value>
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </shadow>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="ADD2">
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </next>
                                  </block>
                                </next>
                              </block>
                            </statement>
                          </block>
                        </xml>
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        #156
                        ist eigentlich ident zu meinem.
                        komisch, dass es bei mir nicht funktioniert.
                          Merlin123M Offline
                          Merlin123M Offline
                          Merlin123
                          #157
                          @Negalein hmmm... dann hab ich spontan keine idee :(
                          Beta-Tester
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            #158
                            ich bekomm diese Fehler
                            javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at processImmediate (node:internal/timers:483:21)
                            javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11138:53)
                            javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at JavaScript.emit (node:domain:489:12)
                            javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at JavaScript.emit (node:events:524:28)
                            javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at JavaScript.onStateChange (/opt/iobrokr/node_modules/iobroker.javascript/src/main.ts:752:25)
                            javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/src/lib/sandbox.ts:1772:38)
                            javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: at Object.<anonymous> (script.js.3D-Drucker.Klipper_Thumb:9:81)
                            javascript.0 2025-12-27 14:23:54.082	error	script.js.3D-Drucker.Klipper_Thumb: Error: TypeError: Cannot read properties of null (reading 'slice')
                            javascript.0 2025-12-27 14:23:54.081	error	script.js.3D-Drucker.Klipper_Thumb: Cannot parse "Emely_2.gcode": SyntaxError: Unexpected token 'E', "Emely_2.gcode" is not valid JSON
                              Merlin123M Offline
                              Merlin123M Offline
                              Merlin123
                              #159
                              @Negalein ich habe da ein JSON. Du musst dann den Text anders verarbeiten.
                              Trigger mal auf den Datenpunkt wo bei dir jetzt im Log Emely_2.gcode stand.
                              ggf. das Blockly entsprechend anpassen.
                              Beta-Tester
                              NegaleinN 2 Antworten Letzte Antwort
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                #160
                                ich bekomm weder im Adapter noch vom Script ein JSON :(
                                kennst du dich da aus?
                                  NegaleinN Offline
                                  NegaleinN Offline
                                  Negalein
                                  #161
                                  es läuft :)
                                    es läuft :)
                                    Merlin123M Offline
                                    Merlin123M Offline
                                    Merlin123
                                    #162
                                    @Negalein Klasse! Das ist leider immer irgendwie tricky.
                                    Beta-Tester
                                    • Lucifor1976L Lucifor1976
                                      Sehr schön das sich jemand um Klipper kümmert :)
                                      Gerade zwei Instanzen installiert.
                                      Was mir direkt auffällt:
                                      Progress stimmt nicht mit Klipper überein Klipper= 35% Adapter = 44%? Wobei der Progress /100 angezeigt wird?
                                      (klipper-moonraker.0.display_status.progress)
                                      Verbrauchtes Filament stimmt nicht mit Klipper überein, Klipper= 1m Adapter 1,2m
                                      (klipper-moonraker.0.print_stats.total_duration)
                                      Der Gerade gedruckte Layer wird nicht übertragen. (Null)
                                      (klipper-moonraker.0.print_stats.info.current_layer)
                                      Ebenfalls für Total Layer
                                      (klipper-moonraker.0.print_stats.info.total_layer)
                                      Ansonsten saubere Arbeit :) und Danke dafür.
                                      Enno.von.Schwerin
                                      #163
                                      @Lucifor1976 bischen her das du die Frage gepostet hast.
                                      Bei mir findet sich der "richtige" Wert unter: klipper-moonraker.1.virtual_sdcard.progress
                                      Jedenfalls ist das der Wert der mit 100 multipliziert, genau dem entspricht was ich auch bei meinem Drucker über die WebGUI sehe.
