  4. Test Adapter oekofen-json 2.0.x
  • Weihnachtsangebot 2025! 🎄
    2.1k
mcm1957oekofen-json
7 Beiträge 2 Kommentatoren 101 Aufrufe 2 Watching
  • mcm1957M Online
    mcm1957M Online
    mcm1957
    Aktuelle Test Version 2.0.0
    Veröffentlichungsdatum 26.11.2025
    Github Link https://github.com/iobroker-community-adapters/ioBroker.oekofen-json
    Der Adapter ioBroker.oekofen-json wurde in die iobroker-community-organisation übernommen.
    Ein ganz großes DANKE geht an Markus Feiler (chaozmc), der den Adapter ursprünglich entwickelt hat.
    Frühere Diskussionen zum Adapter finden sich hier: https://forum.iobroker.net/topic/55869/test-adapter-oekofen-json-v0-2-x-github
    Changelog
    2.0.0 (2025-11-26)
    • (mcm1957) Adapter has been migrated to iobroker-community-adapters organisation
    • (mcm1957) Adapter requires node.js >= 20, js-controller >= 6.0.11 and admin >= 7.6.17 now
    • (mcm1957) Dependencies have been updated
    Support Repositoryverwaltung.
    Wer Danke sagen will, kann nen Kaffee spendieren: https://paypal.me/mcm1957atiobroker
    LESEN - gute Forenbeitrage
    • mcm1957M Online
      mcm1957M Online
      mcm1957
      --- reserved for future use ---
        mjohn
        ich habe den update vom alten 0.2.x auf den neuen Adapter gemcht und bekomme leider immer noch folgende Fehlermeldungen
        oekofen-json.0
        	2025-12-30 16:29:26.438	info	State value to set for "oekofen-json.0.ww1.L_origin_3_timeblock" has to be type "string" but received type "number"
        oekofen-json.0
        	2025-12-30 16:29:26.438	info	State value to set for "oekofen-json.0.ww1.L_origin_2_timeblock" has to be type "string" but received type "number"
        oekofen-json.0
        	2025-12-30 16:29:26.438	info	State value to set for "oekofen-json.0.ww1.L_origin_1_timeblock" has to be type "string" but received type "number"
        oekofen-json.0
        	2025-12-30 16:29:26.438	info	State value to set for "oekofen-json.0.ww1.L_green_3_timeblock" has to be type "string" but received type "number"
        oekofen-json.0
        	2025-12-30 16:29:26.437	info	State value to set for "oekofen-json.0.ww1.L_green_2_timeblock" has to be type "string" but received type "number"
        oekofen-json.0
        	2025-12-30 16:29:26.437	info	State value to set for "oekofen-json.0.ww1.L_green_1_timeblock" has to be type "string" but received type "number"
        oekofen-json.0
        	2025-12-30 16:29:26.436	info	State value to set for "oekofen-json.0.hk2.L_origin_3_timeblock" has to be type "string" but received type "number"
        oekofen-json.0
        	2025-12-30 16:29:26.436	info	State value to set for "oekofen-json.0.hk2.L_origin_2_timeblock" has to be type "string" but received type "number"
        oekofen-json.0
        	2025-12-30 16:29:26.436	info	State value to set for "oekofen-json.0.hk2.L_origin_1_timeblock" has to be type "string" but received type "number"
        oekofen-json.0
        	2025-12-30 16:29:26.435	info	State value to set for "oekofen-json.0.hk2.L_green_3_timeblock" has to be type "string" but received type "number"
        oekofen-json.0
        	2025-12-30 16:29:26.435	info	State value to set for "oekofen-json.0.hk2.L_green_2_timeblock" has to be type "string" but received type "number"
        oekofen-json.0
        	2025-12-30 16:29:26.435	info	State value to set for "oekofen-json.0.hk2.L_green_1_timeblock" has to be type "string" but received type "number"
        Wäre super, wenn das noch korrigiert werden könnte. Oder ist das ein issue auf Github?
        Was mir persönlich feht ist die Option, den Energiebedarf (Leistung elektrisch) und die erbrachte Leistung (Leistung thermisch) in kWh gem. myPelletronic App auszuwerten. Den finde ich derzeit nur in der App für das Jahr und fortlaufend.
        Hat schon jemand einen Weg, evtl. über smartes Skript, gefunden, periodengenaue Werte zu erfassen?
        LG und Guten Rutsch
        • mcm1957M Online
          mcm1957M Online
          mcm1957
          Ich gehe mal davon aus, dass die States irgendwann mal falsch angelegt wurden.
          Stopp mal den Adapter, lösche zumidnest die States die angemsckert werden und starte den Adapter neu. Kannst auch den Adapter komplett deinstallieren und neu installieren.
          ACHTUNG: Falls du was historisierst, gehen die Verküpfungen zur Historisierung verloren. In dem Fall kannst du evrsuchen im Expertenmodus edn Typ der states manuell auf number zu ändern
            mjohn
            sorry für die späte Antwort. Bussy über die Tage...
            Ich hatte eigentlich nichts selbst angelegt, sondern die unterschiedlichen Adapter (v0.2.x von chazmc und jetzt den Release 2.0.0) installiert und auch unverändert übernommen.
            Meine Hoffnung war, dass sich die Fehler durch den neuen Adapter evtl. beheben. Schade. Ich habe mir die Types angesehen und diese sind alle type 'string'.
            Das Ökofen JSON Skript, das die Daten direkt von der IP abgreift, zeigt exemplarisch folgenden String: "06:00-17:00", gibt dies allerdings nicht weiter und zeigt statt dessen (NULL) als Wert in IOB.Objekte.
            Dass nur Heizkreis2 (HK2) die Fehler zeigt ist m.E. die Folge vom Abschalten des HK1. Die im HK2 fehlerhaften Objekte existieren derzeit nicht in HK1.
            Gibt es eine Möglichkeit, diese Fehler im Log zu unterdrücken? Abfrage 1x /Min und ich mölle ganz schön was ins Log über die Zeit.
            Oder gibt es noch ne Idee, den angezeigten String auch als String auszuwerten?
            Danke erneut.
            • M mjohn
              Danke erneut.
              mjohn
              schrieb am zuletzt editiert von mjohn
              Für alle, die das gleiche Problem haben, dass im festgelegten Abfragetakt die o.a. 12 Fehlermeldungen im Log auftauchen, hier ist die Lösung, die für mich dazu führte, dass statt des Objektwertes (null) plus Fehlermeldung im Log das im JSON ausgewiesene Zeitfenster erscheint.
              1. Entgegen der Fehlermeldung steht das Objekt auf 'string'. Der Fehler rührt daher, dass in den Objektdaten der Faktor 1 gelistet ist, der den 'string' zu einer 'number' macht.
               "type": "state",
               "common": {
                 "name": "L_origin_2_timeblock",
                 "type": "string",
                 "role": "state",
                 "read": true,
                 "write": false
               "native": {
                 "factor": 1
               "_id": "oekofen-json.0.hk2.L_origin_2_timeblock",
               "acl": {
                 "object": 1636,
                 "state": 1636,
                 "owner": "system.user.admin",
               "user": "system.user.admin",
               "ts": 17694XXXXXXX
              1. Die Objektdaten müssen umgeschrieben werden, d.h. Tab/Objekte im Expertenmodus öffnen und wie folgt bearbeiten
               "type": "state",
               "common": {
                 "type": "string",
                 "role": "state",
                 "read": true,
                 "write": false
               "native": {},
               "acl": {
                 "object": 1636,
                 "state": 1636,
               "ts": 17694XXXXXXX
              d.h. "factor": 1 komplett entfernen, damit der 'string' ein 'string' bleibt.
              Seit ich umgestellt habe, kommen Werte wie [03:00-22:00] und keine Fehlermeldungen.
              Für den Moment betrachte ich das Problem als gelöst!
              • mcm1957M Online
                mcm1957M Online
                mcm1957
                schrieb zuletzt editiert von
                Ist das Proble m in einem Issue erfasst? Bitte um eine Referenz damit man das verlinken und im Adapter beheben kann.
                32.6k
                82.1k
