  2. Русский
  3. ioBroker
  4. Ошибка
  5. ioBroker ошибки
  6. Разные ошибки
Разные ошибки
Geplant Angeheftet Gesperrt Verschoben ioBroker ошибки
192 Beiträge 27 Kommentatoren 82.2k Aufrufe
    koh
    #179
    подскажите, люди добрые )
    перенес c горем пополам iobroker c win на linux
    все вроде завел, а вот с драйвером S7 проблема..
    в логе такие записи
    ! host.deb 2017-11-29 19:43:28.441 error instance system.adapter.s7.0 terminated with code 0 (OK)
    ! Caught 2017-11-29 19:43:28.440 error by controller[0]: at /opt/iobroker/node_modules/iobroker.s7/main.js:1158:33
    ! Caught 2017-11-29 19:43:28.440 error by controller[0]: at /opt/iobroker/node_modules/iobroker.s7/node_modules/async/lib/async.js:44:16
    ! Caught 2017-11-29 19:43:28.440 error by controller[0]: at done (/opt/iobroker/node_modules/iobroker.s7/node_modules/async/lib/async.js:246:17)
    ! Caught 2017-11-29 19:43:28.440 error by controller[0]: at /opt/iobroker/node_modules/iobroker.s7/node_modules/async/lib/async.js:52:16
    ! Caught 2017-11-29 19:43:28.440 error by controller[0]: at /opt/iobroker/node_modules/iobroker.s7/main.js:1187:74
    ! Caught 2017-11-29 19:43:28.440 error by controller[0]: TypeError: Cannot read property 'lsb' of undefined
    ! s7.0 2017-11-29 19:43:28.432 info terminating
    ! s7.0 2017-11-29 19:43:27.929 error at /opt/iobroker/node_modules/iobroker.s7/main.js:1158:33
    ! s7.0 2017-11-29 19:43:27.929 error at /opt/iobroker/node_modules/iobroker.s7/node_modules/async/lib/async.js:44:16
    ! s7.0 2017-11-29 19:43:27.929 error at done (/opt/iobroker/node_modules/iobroker.s7/node_modules/async/lib/async.js:246:17)
    ! s7.0 2017-11-29 19:43:27.929 error at /opt/iobroker/node_modules/iobroker.s7/node_modules/async/lib/async.js:52:16
    ! s7.0 2017-11-29 19:43:27.929 error at /opt/iobroker/node_modules/iobroker.s7/main.js:1187:74
    ! s7.0 2017-11-29 19:43:27.929 error TypeError: Cannot read property 'lsb' of undefined
    ! s7.0 2017-11-29 19:43:27.929 error uncaught exception: Cannot read property 'lsb' of undefined
    ! s7.0 2017-11-29 19:43:27.927 error Writing DB. Code #TypeError: Cannot read property 'lsb' of undefined
    js-controller: 1.2.3 / node.js: v6.12.0 / npm: 3.10.10
    admin: 2.0.9
    web: 2.1.9 vis: 1.0.4
    Server: Intel i5 / linux: Debian 9-amd64
    Adapter: Siemens LOGO!8.FS4 , Modbus TCP
      koh
      #180
      поставил версию 1.0.3 с гитхаба
      драйвер заработал, но теперь каждому номеру DB может соответствовать только один адрес
      т.е. раньше было так
      DB1 0
      DB1 2
      DB1 4
      DBx y
      а после обновления драйвер с такой адресацией не работает
      только так:
      DB1 0
      DB2 2
      DB3 4
      но значение читает только DB1
      Это баг? или придется всю адресацию как-то перенастраивать?
      версия 1.0.1 работает нормально
      ! s7.0 2017-11-30 16:15:10.210 info terminating
      ! s7.0 2017-11-30 16:15:09.717 error Writing DB: {"dbID":"DBs.DB11.PI_Set_vlSP","db":"DB11","dbType":"WORD","dbOffsetByte":12,"dbOffsetBit":0,"dbLength":"","_dbLsb":0,"n":9,"bufLength":2}
      ! s7.0 2017-11-30 16:15:09.717 error Writing DB. Code #RangeError: Index out of range
      ! s7.0 2017-11-30 16:15:09.717 error Writing DB: {"dbID":"DBs.DB10.am2","db":"DB10","dbType":"WORD","dbOffsetByte":1120,"dbOffsetBit":0,"dbLength":"","_dbLsb":20,"n":8,"bufLength":2}
      ! s7.0 2017-11-30 16:15:09.716 error Writing DB: {"dbID":"DBs.DB9.NAI2","db":"DB9","dbType":"WORD","dbOffsetByte":1264,"dbOffsetBit":0,"dbLength":"","_dbLsb":4,"n":7,"bufLength":2}
      ! s7.0 2017-11-30 16:15:09.716 error Writing DB. Code #RangeError: Index out of range
      ! s7.0 2017-11-30 16:15:09.716 error Writing DB: {"dbID":"DBs.DB8.am1","db":"DB8","dbType":"WORD","dbOffsetByte":1118,"dbOffsetBit":0,"dbLength":"","_dbLsb":6,"n":6,"bufLength":2}
      ! s7.0 2017-11-30 16:15:09.716 error Writing DB: {"dbID":"DBs.DB7.OnRemaningTimeShower","db":"DB7","dbType":"WORD","dbOffsetByte":10,"dbOffsetBit":0,"dbLength":"","_dbLsb":8,"n":5,"bufLength":2}
      ! s7.0 2017-11-30 16:15:09.716 error Writing DB: {"dbID":"DBs.DB6.OnDelayShower","db":"DB6","dbType":"WORD","dbOffsetByte":8,"dbOffsetBit":0,"dbLength":"","_dbLsb":10,"n":4,"bufLength":2}
      ! s7.0 2017-11-30 16:15:09.716 error Writing DB: {"dbID":"DBs.DB4.OnRemaningTimeToilet","db":"DB4","dbType":"WORD","dbOffsetByte":6,"dbOffsetBit":0,"dbLength":"","_dbLsb":1118,"n":3,"bufLength":2}
      ! s7.0 2017-11-30 16:15:09.716 error Writing DB: {"dbID":"DBs.DB3.OnDelayToilet","db":"DB3","dbType":"WORD","dbOffsetByte":4,"dbOffsetBit":0,"dbLength":"","_dbLsb":1264,"n":2,"bufLength":2}
      ! s7.0 2017-11-30 16:15:09.716 error Writing DB: {"dbID":"DBs.DB2.OffRemaningTime","db":"DB2","dbType":"WORD","dbOffsetByte":20,"dbOffsetBit":0,"dbLength":"","_dbLsb":1120,"n":1,"bufLength":2}
      ! s7.0 2017-11-30 16:15:09.715 error Writing DB. Code #RangeError: Index out of range
      ! s7.0 2017-11-30 16:15:09.715 error Writing DB: {"dbID":"DBs.DB1.OffDelay","db":"DB1","dbType":"WORD","dbOffsetByte":0,"dbOffsetBit":0,"dbLength":"","_dbLsb":12,"n":0,"bufLength":2}
      admin: 2.0.9
        koh
        #181
        ` > 1.0.4 (2017.11.30)
        (bluefox) Fix read of DB (range error) `
        Спасибо :D
        IOBroker супер. Спасибо разработчикам. Снимаю шляпу. Давно искал решение для себя, перепробовал кучу разного софта, включая промышленные скады.
        admin: 2.0.9
        • N Offline
          N Offline
          nnprject
          #182
          Не вижу список драйверов, "Обработка.." висит бесконечно. Admin обновил, JS-controller тоже, не помогает. Что еще проверить ?
          • I Offline
            I Offline
            instalator
            #183
            @nnprject:
            Не вижу список драйверов, "Обработка.." висит бесконечно. Admin обновил, JS-controller тоже, не помогает. Что еще проверить ? `
            попробуй репозиторий сменить на latest
            Высокий уровень Децибел вреден для здоровья!
            http://blog.instalator.ru/
            • N Offline
              N Offline
              nnprject
              #184
              смена репозитория ничего не меняет (
              • I Offline
                I Offline
                instalator
                #185
                @nnprject:
                смена репозитория ничего не меняет ( `
                сменил в настройках админа? справа значек шестеренки.
                сервер обновил?
                • N Offline
                  N Offline
                  nnprject
                  #186
                  Все это делал, ничего не помогает.
                  • F Offline
                    fred17
                    #187
                    Возникли проблемы с установкой и обновлением модулей. При установке или обновление вылетает такая ошибка.
                    Пример при установки телеграм
                    ! $ ./iobroker add telegram
                    ! npm install iobroker.telegram –production --prefix "/opt/iobroker" (System call)
                    ! ../src/node_contextify.cc:254: static void node::ContextifyContext::RunInDebugContext(const v8::FunctionCallbackInfov8::value&): Assertion `!debug_context.IsEmpty()' failed.
                    ! Aborted
                    ! ERROR: host.smarthome Cannot install iobroker.telegram: 134
                    ! ERROR: process exited with code 25</v8::value>
                    До этого все обновлялось и устанавливалось без проблем из Админки или из консоли.
                    Если модуль уже установлен, то без проблемам устанавливается второй, если установленный модуль удалить полностью и попробовать его установить, вылетает ошибка.
                    Куда копать?
                    • I Offline
                      I Offline
                      instalator
                      #188
                      @fred17:
                      ! Aborted
                      Куда копать? `
                      nodejs какой версии? из админки тоже не обновляет?
                      • F Offline
                        fred17
                        #189
                        @instalator:
                        @fred17:
                        ! Aborted
                        Куда копать? `
                        nodejs какой версии? из админки тоже не обновляет? `
                        Версия node 4.7.0 из админки не обновляются. Заметил, что все это перестало работать после того как я обновил сервер с версии 1.2.1 или 1.2.2 (точно не помню какая перед этим стояла) на 1.2.3. До этого случая система работала год без сбоев.
                        • I Offline
                          I Offline
                          instalator
                          #190
                          @fred17:
                          @instalator:
                          @fred17:
                          ! Aborted
                          Куда копать? `
                          Версия node 4.7.0 из админки не обновляются. Заметил, что все это перестало работать после того как я обновил сервер с версии 1.2.1 или 1.2.2 (точно не помню какая перед этим стояла) на 1.2.3. До этого случая система работала год без сбоев. `
                          Обнови ее до 6й хотябы
                          • aurodionovA Offline
                            aurodionovA Offline
                            aurodionov
                            #191
                            при обновлении через админку, а именно кнопочкой обновить всё (Выполнение команды: $ ./iobroker upgrade) остоянно вылазит ошибка
                            • Выполнено с ошибкой: module.js:427 throw err; ^ SyntaxError: /opt/iobroker/node_modules/iobroker.vis-plumb/io-package.json: Unexpected string at Object.parse (native) at Object.Module._extensions..json (module.js:424:27) at Module.load (module.js:343:32) at Function.Module._load (module.js:300:12) at Module.require (module.js:353:17) at require (internal/module.js:12:17) at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:167:27) at Upgrade.upgradeAdapterHelper (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:30:14) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:38:26) at processImmediate [as _immediateCallback] (timers.js:396:17)
                              Как исправить ? Забить не предлагать ,из-за этой ошибки не работает скрипт обновления
                            Пишу с пульта….
                              Bosya
                              #192
                              Добрый день.
                              После очередного сиситемного обновления iobroker перестал работать нормально.
                              Драйвер javascript в постоянном ребуте.
                              Похоже одновился nodejs. Переустановка nodejs и npm ничего не дала. Смена с 4 nodejs на 6 и назад тоже не помогла. Переустановка (скриптом reinstall) не помогла. Вывод iobroker update ниже.
                              root@cubietruck:/opt/iobroker# iobroker update
                              Used repository: online
                              [Tue Apr 10 2018 18:25:56 GMT+0300 (EEST)] Timeout by read all package.json (190) seconds
                              update done
                              Adapter    "admin"         : npm error, installed 3.3.7
                              Adapter    "amazon-dash"   : npm error
                              Adapter    "artnet"        : npm error
                              Adapter    "b-control-em"  : npm error
                              Adapter    "benq"          : npm error
                              Adapter    "ble"           : npm error
                              Adapter    "bmw"           : npm error
                              Adapter    "boblight"      : npm error
                              Adapter    "bosesoundtouch": npm error
                              Adapter    "botvac"        : npm error
                              Adapter    "broadlink2"    : npm error
                              Adapter    "chromecast"    : npm error
                              Adapter    "cloud"         : npm error
                              Adapter    "cul"           : npm error
                              Adapter    "daikin"        : npm error
                              Adapter    "daswetter"     : npm error
                              Adapter    "deconz"        : npm error
                              Adapter    "discovery"     : npm error, installed 1.1.0
                              Adapter    "dwd"           : npm error
                              Adapter    "ebus"          : npm error
                              Adapter    "egigeozone"    : npm error
                              Adapter    "email"         : npm error
                              Adapter    "epson_stylus_px830": npm error
                              Adapter    "fakeroku"      : npm error
                              Adapter    "feiertage"     : npm error
                              Adapter    "fhem"          : npm error
                              Adapter    "find-my-iphone": npm error
                              Adapter    "firetv"        : npm error
                              Adapter    "flot"          : npm error, installed 1.7.7
                              Adapter    "foobar2000"    : npm error
                              Adapter    "fritzbox"      : npm error
                              Adapter    "fritzdect"     : npm error
                              Adapter    "fronius"       : npm error
                              Adapter    "fullcalendar"  : npm error
                              Adapter    "g-homa"        : npm error
                              Adapter    "geofency"      : npm error
                              Adapter    "habpanel"      : npm error
                              Adapter    "haier"         : npm error
                              Adapter    "harmony"       : npm error
                              Adapter    "hid"           : npm error
                              Adapter    "hilink"        : npm error
                              Adapter    "history"       : npm error
                              Adapter    "hm-rega"       : npm error
                              Adapter    "hm-rpc"        : npm error
                              Adapter    "hmm"           : npm error
                              Adapter    "homepilot"     : npm error
                              Adapter    "hs100"         : npm error
                              Adapter    "hue"           : npm error
                              Adapter    "hyperion"      : npm error
                              Adapter    "i2c"           : npm error
                              Adapter    "ical"          : npm error
                              Adapter    "icons-addictive-flavour-png": npm error
                              Adapter    "icons-fatcow-hosting": npm error
                              Adapter    "icons-icons8"  : npm error
                              Adapter    "icons-material-png": 0.1.1
                              Adapter    "icons-material-svg": 0.1.1
                              Adapter    "icons-mfd-png" : 1.0.2
                              Adapter    "icons-mfd-svg" : 1.0.2
                              Adapter    "icons-open-icon-library-png": 0.1.3
                              Adapter    "icons-ultimate-png": 1.0.1
                              Adapter    "influxdb"      : 1.5.2
                              Adapter    "info"          : 0.1.0
                              Adapter    "innogy-smarthome": 0.2.0
                              Adapter    "javascript"    : 3.6.4    , installed 3.6.4
                              Adapter    "jeelink"       : 0.0.4
                              Controller "js-controller" : 1.4.0    , installed 1.4.0
                              Adapter    "js2fs"         : 0.1.5
                              Adapter    "kecontact"     : 0.0.3
                              Adapter    "km200"         : 1.1.6
                              Adapter    "knx"           : 1.0.8
                              Adapter    "kodi"          : 1.0.0
                              Adapter    "landroid"      : 1.0.1
                              Adapter    "landroid-s"    : 2.0.1
                              Adapter    "lgtv"          : 1.0.4    , installed 1.0.3 [Updateable]
                              Adapter    "lgtv-rs"       : 0.0.4
                              Adapter    "lifx"          : 0.0.5
                              Adapter    "lightify"      : 0.2.16
                              Adapter    "loxone"        : 0.4.0
                              Adapter    "material"      : 0.5.7
                              Adapter    "maxcube"       : 0.1.2
                              Adapter    "maxcul"        : 0.5.3
                              Adapter    "mbus"          : 0.1.8
                              Adapter    "mclighting"    : 0.0.10
                              Adapter    "megad"         : 1.3.0    , installed 1.2.1 [Updateable]
                              Adapter    "megadd"        : 0.3.8
                              Adapter    "megaesp"       : 0.1.0    , installed 0.1.0
                              Adapter    "miele"         : 0.1.6
                              Adapter    "mihome"        : 1.0.5
                              Adapter    "mihome-lamp"   : 1.0.0
                              Adapter    "mihome-plug"   : 0.1.1
                              Adapter    "mihome-vacuum" : 1.0.1
                              Adapter    "mikrotik"      : 1.0.0
                              Adapter    "milight"       : 0.3.5
                              Adapter    "milight-smart-light": 0.1.9
                              Adapter    "mobile"        : 0.4.11   , installed 0.4.11
                              Adapter    "modbus"        : 1.1.0
                              Adapter    "mpd"           : 1.0.2
                              Adapter    "mqtt"          : 1.5.0    , installed 1.5.0
                              Adapter    "mqtt-client"   : 1.1.1
                              Adapter    "musiccast"     : 0.0.7
                              Adapter    "mysensors"     : 1.2.1
                              Adapter    "netatmo"       : 1.3.0
                              Adapter    "node-red"      : 1.5.1
                              Adapter    "noolite"       : 0.2.0
                              Adapter    "nut"           : 1.1.2
                              Adapter    "onkyo"         : 0.2.1
                              Adapter    "openhab"       : 0.2.1
                              Adapter    "owfs"          : 0.5.0
                              Adapter    "owntracks"     : 0.2.0
                              Adapter    "panasonic-viera": 0.1.0
                              Adapter    "parser"        : 1.0.1
                              Adapter    "paw"           : 0.1.7
                              Adapter    "phantomjs"     : 1.0.0
                              Adapter    "piface"        : 1.0.0
                              Adapter    "pimatic"       : 0.1.5
                              Adapter    "ping"          : 1.3.2    , installed 1.3.2
                              Adapter    "places"        : 0.6.0
                              Adapter    "plexconnect"   : 0.0.6
                              Adapter    "proxy"         : 1.0.1
                              Adapter    "pushbullet"    : 0.0.11
                              Adapter    "pushover"      : 1.0.4
                              Adapter    "pushsafer"     : 0.1.8
                              Adapter    "radar"         : 1.1.3
                              Adapter    "rflink"        : 1.2.0
                              Adapter    "rickshaw"      : 0.4.5
                              Adapter    "rpi2"          : 0.3.2
                              Adapter    "rwe-smarthome" : 0.1.11
                              Adapter    "s7"            : 1.1.3
                              Adapter    "samsung"       : 0.2.9
                              Adapter    "sayit"         : 1.6.7    , installed 1.6.7
                              Adapter    "sbfspot"       : 2.2.1
                              Adapter    "scenes"        : 1.0.2
                              Adapter    "simple-api"    : 1.6.3    , installed 1.6.2 [Updateable]
                              Adapter    "sma-em"        : 0.5.3
                              Adapter    "smartmeter"    : 1.1.2
                              Adapter    "snmp"          : 0.5.0
                              Adapter    "socketio"      : 2.0.0
                              Adapter    "solarwetter"   : 1.0.0
                              Adapter    "sonoff"        : 2.1.0
                              Adapter    "sonos"         : 1.6.2
                              Adapter    "sony-bravia"   : 0.1.0
                              Adapter    "sql"           : 1.7.4    , installed 1.7.3 [Updateable]
                              Adapter    "squeezebox"    : 0.2.1
                              Adapter    "starline"      : 1.0.0
                              Adapter    "synology"      : 0.0.3
                              Adapter    "systeminfo"    : 0.3.0
                              Adapter    "tankerkoenig"  : 1.0.5
                              Adapter    "telegram"      : 1.2.0    , installed 1.2.0
                              Adapter    "terminal"      : 0.1.2
                              Adapter    "text2command"  : 1.1.7
                              Adapter    "tr-064"        : 0.4.18
                              Adapter    "tradfri"       : 1.1.10
                              Adapter    "tvspielfilm"   : 1.0.4
                              Adapter    "unifi"         : 0.3.1
                              Adapter    "upnp"          : 0.3.7
                              Adapter    "vcard"         : 0.0.8
                              Adapter    "viessmann"     : 0.4.0
                              Adapter    "vis"           : 1.1.2    , installed 1.1.2
                              Adapter    "vis-bars"      : 0.1.4
                              Adapter    "vis-canvas-gauges": 0.1.5
                              Adapter    "vis-colorpicker": 1.1.1   , installed 1.1.1
                              Adapter    "vis-fancyswitch": 1.1.0
                              Adapter    "vis-google-fonts": 1.0.0
                              Adapter    "vis-history"   : 0.2.7
                              Adapter    "vis-hqwidgets" : 1.1.1
                              Adapter    "vis-jqui-mfd"  : 1.0.11
                              Adapter    "vis-justgage"  : 1.0.0
                              Adapter    "vis-keyboard"  : 0.0.2
                              Adapter    "vis-lcars"     : 1.0.4
                              Adapter    "vis-map"       : 1.0.1
                              Adapter    "vis-material"  : 0.1.3
                              Adapter    "vis-metro"     : 1.1.2
                              Adapter    "vis-players"   : 0.1.5
                              Adapter    "vis-plumb"     : 1.0.1
                              Adapter    "vis-rgraph"    : 0.0.2
                              Adapter    "vis-timeandweather": 1.1.7
                              Adapter    "vis-weather"   : 1.2.0
                              Adapter    "vr200"         : 0.2.0
                              Adapter    "weatherunderground": 1.1.2
                              Adapter    "web"           : 2.3.0    , installed 2.1.9 [Updateable]
                              Adapter    "wetty"         : 0.1.1
                              Adapter    "wifilight"     : 0.2.1
                              Adapter    "wm-bus"        : 0.3.1
                              Adapter    "wolf"          : 1.0.0
                              Adapter    "xs1"           : 1.0.2
                              Adapter    "yahka"         : 0.7.1
                              Adapter    "yamaha"        : 0.3.19
                              Adapter    "yr"            : 1.0.6
                              Adapter    "zont"          : 0.5.2
                              Adapter    "zwave"         : 1.0.0
                              root@cubietruck:/opt/iobroker# node -v
                              v6.14.1
                              root@cubietruck:/opt/iobroker# nodejs -v
                              v6.14.1
                              root@cubietruck:/opt/iobroker# npm -v
                              5.8.0
