  4. Proptokoll läuft über vom Bambu-Adapter
    2.8k
    2.9k
3 Beiträge 3 Kommentatoren 172 Aufrufe 3 Beobachtet
  • Dr.PieD Offline
    Dr.PieD Offline
    Dr.Pie
    Moin
    ich bekomme aller 2 Sekunden folgende Meldungen vom Bambu-Adapter:
    bambulab.2
    2025-11-17 22:40:55.697 info State value to set for "bambulab.2.###############.finishTime" has to be type "date" but received type "string"
    bambulab.2
    2025-11-17 22:40:55.695 info State value to set for "bambulab.2.###############.info.temp" has to be type "string" but received type "number"
    bambulab.2
    2025-11-17 22:40:55.694 info State value to set for "bambulab.2.###############.device.nozzle.info.0.id" has to be type "string" but received type "number"
    bambulab.2
    2025-11-17 22:40:55.690 info State value to set for "bambulab.2.###############.device.extruder.info.0.temp" has to be type "string" but received type "number"
    bambulab.2
    2025-11-17 22:40:55.690 info State value to set for "bambulab.2.###############.device.extruder.info.0.id" has to be type "string" but received type "number"
    bambulab.2
    2025-11-17 22:40:55.690 info State value to set for "bambulab.2.###############.device.ctc.info.temp" has to be type "string" but received type "number"
    bambulab.2
    2025-11-17 22:40:55.689 info State value to set for "bambulab.2.###############.device.bed.info.temp" has to be type "string" but received type "number"
    bambulab.2
    2025-11-17 22:40:55.689 info State value to set for "bambulab.2.###############.device.airduct.parts.3.id" has to be type "string" but received type "number"
    bambulab.2
    2025-11-17 22:40:55.689 info State value to set for "bambulab.2.###############.device.airduct.parts.2.id" has to be type "string" but received type "number"
    bambulab.2
    2025-11-17 22:40:55.689 info State value to set for "bambulab.2.###############.device.airduct.parts.1.id" has to be type "string" but received type "number"
    bambulab.2
    2025-11-17 22:40:55.689 info State value to set for "bambulab.2.###############.device.airduct.parts.0.id" has to be type "string" but received type "number"
    bambulab.2
    2025-11-17 22:40:55.681 info State value to set for "bambulab.2.###############.2D.bs.bi.0.tool_info.id" has to be type "string" but received type "number"
    Wie kann man das verhindern das immer die gleiche Meldungen kommen ?
    Ich habe 2 verschiedene Drucker aber diese Meldungen kommen von beiden Druckern.
    • Dr.PieD Dr.Pie
      Moin
      bambulab.2
      bambulab.2
      bambulab.2
      bambulab.2
      bambulab.2
      bambulab.2
      bambulab.2
      bambulab.2
      bambulab.2
      bambulab.2
      bambulab.2
      bambulab.2
      @Dr.Pie
      Am besten ein entsprechendes Issue bei GitHub eröffnen. Das müsste wohl im Adapter angepasst werden, denke ich.
      Das LogLevel kannst du dann auf Warning setzen, dann sind die Meldungen ausgeblendet.
      Edit: Welche Version fährst du da? Denn in der aktuellen könnte das gefixt sein.
      https://github.com/DrozmotiX/ioBroker.bambulab/issues/165
      • mcm1957M Online
        mcm1957M Online
        mcm1957
        Bei dem Adapter ist aber auch etwas schief gelaufen.
        Auf Github gibts ne NIEDRIGERE Version als auf npm !?!?
        ❗ [E2003] Version of package.json (0.4.2) lower than latest version on NPM (0.4.3)
        Außerdem sollte jedem Benutzer klar sein, dass der Adapter derzeit - waruma uch immer - vom Maintainer NICHT ALS STABIL eingestuft ist und nur als BETA Version zum Testen freigegeben wurde.
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
