  4. [gelöst] zigbee2mqtt für Zigbee-Erweiterung mit SLZB-06
    6.5k
38 Beiträge 6 Kommentatoren 2.5k Aufrufe 5 Beobachtet
    @dgr
    Und danach würde ich mir an deiner Stelle auch mal die Ausgabe von
    iob diag
    anschauen.
    DGR
    habe erstmal nur iob diag ausgeführt.
    ```bash
    Script v.2025-08-09
    *** BASE SYSTEM ***
     Static hostname: raspi2
           Icon name: computer
              Kernel: Linux 6.12.47+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     10:59:57 up 17:04,  3 users,  load average: 0.12, 0.23, 0.23
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2025-11-02 10:59:57 CET
               Universal time: Sun 2025-11-02 09:59:57 UTC
                     RTC time: Sun 2025-11-02 09:59:57
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi root adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server:         false
    Unit display-manager.service could not be found.
    Display-Manager:
    Desktop:
    Session:                tty
    *** MEMORY ***
    Mem:            8.5G        3.4G        594M         11M        4.9G        5.0G
    Swap:           536M        275M        261M
    Total:          9.0G        3.7G        855M
    Active iob-Instances:   25
             8063 M total memory
             3265 M used memory
             3065 M active memory
             3414 M inactive memory
              566 M free memory
              703 M buffer memory
             3946 M swap cache
              511 M total swap
              263 M used swap
              248 M free swap
    top - 10:59:57 up 17:04,  3 users,  load average: 0.12, 0.23, 0.23
    Tasks: 257 total,   1 running, 256 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8063.1 total,    566.1 free,   3266.1 used,   4650.0 buff/cache
    MiB Swap:    512.0 total,    248.9 free,    263.0 used.   4797.0 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs          tmpfs     807M  7.6M  799M   1% /run
    /dev/nvme0n1p2 ext4      459G   18G  418G   4% /
    tmpfs          tmpfs     4.0G  4.4M  4.0G   1% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/nvme0n1p1 vfat      510M   57M  454M  12% /boot/firmware
    /dev/nvme1n1p1 ext4      117G   78G   34G  70% /mnt/SSD2
    tmpfs          tmpfs     807M     0  807M   0% /run/user/1000
    [Sat Nov  1 17:55:51 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:4D:C4:7D vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=0e42bbc9-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Sat Nov  1 17:55:55 2025] EXT4-fs (nvme0n1p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Sat Nov  1 17:55:55 2025] EXT4-fs (nvme0n1p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w.
    [Sat Nov  1 17:55:56 2025] EXT4-fs (nvme1n1p1): mounted filesystem 10967a35-88c5-40d6-915d-5cade85cc8bd r/w with ordered data mode. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/nvme0n1p2 ext4   rw,noatime
    |-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/mnt/SSD2      /dev/nvme1n1p1 ext4   rw,nosuid,nodev,noexec,noatime
    /var:
    5.8G    /var/
    2.4G    /var/log
    2.3G    /var/log/journal/4f5e31d4652941b2b9c5a320c9035a38
    2.3G    /var/lib
    Archived and active journals take up 2.2G in the file system.
    /opt/iobroker/backups:
    2.1G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    592M    /opt/iobroker/iobroker-data/
    444M    /opt/iobroker/iobroker-data/files
    90M     /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    70M     /opt/iobroker/iobroker-data/files/vis-2
    30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    23M     /opt/iobroker/iobroker-data/objects.jsonl
    19M     /opt/iobroker/iobroker-data/files/cameras.admin/static/js/main.b371dc6f.js.map
    17M     /opt/iobroker/iobroker-data/states.jsonl
    USB-Devices by-id:
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2130518-if00
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    HINT:
    Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
    tcp
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v22.21.0
    /usr/bin/node           v22.21.0
    /usr/bin/npm            10.9.4
    /usr/bin/npx            10.9.4
    /usr/bin/corepack       0.34.0
    nodejs:
      Installed: 22.21.0-1nodesource1
      Candidate: 22.21.0-1nodesource1
      Version table:
     *** 22.21.0-1nodesource1 600
            500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
         22.20.0-1nodesource1 600
         22.19.0-1nodesource1 600
         22.18.0-1nodesource1 600
         22.17.1-1nodesource1 600
         22.17.0-1nodesource1 600
         22.16.0-1nodesource1 600
         22.15.1-1nodesource1 600
         22.15.0-1nodesource1 600
         22.14.0-1nodesource1 600
         22.13.1-1nodesource1 600
         22.13.0-1nodesource1 600
         22.12.0-1nodesource1 600
         22.11.0-1nodesource1 600
         22.10.0-1nodesource1 600
         22.9.0-1nodesource1 600
         22.8.0-1nodesource1 600
         22.7.0-1nodesource1 600
         22.6.0-1nodesource1 600
         22.5.1-1nodesource1 600
         22.5.0-1nodesource1 600
         22.4.1-1nodesource1 600
         22.4.0-1nodesource1 600
         22.3.0-1nodesource1 600
         22.2.0-1nodesource1 600
         22.1.0-1nodesource1 600
         22.0.0-1nodesource1 600
         18.20.4+dfsg-1~deb12u1 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    raspi2              raspi2 (version: 7.0.7, hostname: raspi2        , alive, uptime: 26898)
    Core adapters versions
    js-controller:  7.0.7
    admin:          7.7.2
    javascript:     8.9.2
    nodejs modules from github:     0
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspi2                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : raspi2                                   -  enabled
    + system.adapter.cameras.0                : cameras               : raspi2                                   -  enabled, port: 8200, bind: 127.0.0.1
    + system.adapter.discovery.0              : discovery             : raspi2                                   -  enabled
    + system.adapter.email.0                  : email                 : raspi2                                   -  enabled
    + system.adapter.history.0                : history               : raspi2                                   -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspi2                                   -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspi2                                   -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspi2                                   -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspi2                                   -  enabled
    + system.adapter.influxdb.0               : influxdb              : raspi2                                   -  enabled, port: 8086
    + system.adapter.javascript.0             : javascript            : raspi2                                   -  enabled
    + system.adapter.linux-control.0          : linux-control         : raspi2                                   -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : raspi2                                   -  enabled, port: 1886, bind: 0.0.0.0
      system.adapter.mqtt.1                   : mqtt                  : raspi2                                   - disabled, port: 1887, bind: 0.0.0.0
    + system.adapter.notification-manager.0   : notification-manager  : raspi2                                   -  enabled
      system.adapter.onvif.0                  : onvif                 : raspi2                                   - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
    + system.adapter.ping.0                   : ping                  : raspi2                                   -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : raspi2                                   -  enabled
    + system.adapter.signal-cmb.0             : signal-cmb            : raspi2                                   -  enabled
    + system.adapter.simple-api.0             : simple-api            : raspi2                                   -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspi2                                   -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspi2                                   -  enabled
    + system.adapter.viessmannapi.0           : viessmannapi          : raspi2                                   -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: raspi2                                   -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspi2                                   -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : raspi2                                   -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspi2                                   -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspi2                                   -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspi2                                   -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspi2                                   -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspi2                                   -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspi2                                   -  enabled
      system.adapter.vis.0                    : vis                   : raspi2                                   - disabled
    + system.adapter.web.0                    : web                   : raspi2                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : raspi2                                   -  enabled
    + system.adapter.zigbee.0                 : zigbee                : raspi2                                   -  enabled, port: /dev/ttyACM0
    + system.adapter.zigbee.1                 : zigbee                : raspi2                                   -  enabled, port: tcp://192.168.196.22:6638
      system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspi2                                   - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Adapter    "admin"        : 7.7.19   , installed 7.7.2  [Updatable]
    Adapter    "backitup"     : 3.3.5    , installed 3.3.5
    Adapter    "cameras"      : 2.1.2    , installed 2.1.2
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "javascript"   : 8.9.2    , installed 8.9.2
    Controller "js-controller": 7.0.7    , installed 7.0.7
    Adapter    "linux-control": 1.1.5    , installed 1.1.5
    Adapter    "notification-manager": 1.3.0, installed 1.3.0
    Adapter    "onvif"        : 1.1.4    , installed 1.1.4
    Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
    Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "tuya"         : 3.16.0   , installed 3.16.0
    Adapter    "viessmannapi" : 2.3.0    , installed 2.4.3
    Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
    Adapter    "vis-2-widgets-inventwo": 0.2.2, installed 0.2.2
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "web"          : 7.0.8    , installed 7.0.8
    Adapter    "wled"         : 0.7.2    , installed 0.7.2
    Adapter    "zigbee"       : 3.1.5    , installed 3.1.5
    Adapter    "zigbee2mqtt"  : 3.0.9    , installed 3.0.9
    Objects and States
    Objects:        12754
    States:         9572
    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
    Hit:6 https://repos.influxdata.com/debian stable InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:1883          0.0.0.0:*               LISTEN      108        787654     195635/mosquitto
    tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      994        4989       793/pihole-FTL
    tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          5991       816/smbd
    tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          5992       816/smbd
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      994        4988       793/pihole-FTL
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5839       725/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      994        942        793/pihole-FTL
    tcp        0      0 0.0.0.0:61999           0.0.0.0:*               LISTEN      1003       3578775    900169/nc
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       2011863    498037/iobroker.js-
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       2011871    498037/iobroker.js-
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       2017316    498938/io.mqtt.0
    tcp        0      0 127.0.0.1:8200          0.0.0.0:*               LISTEN      1001       2027634    499403/io.cameras.0
    tcp6       0      0 :::3000                 :::*                    LISTEN      106        2010798    498041/grafana
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       2011915    498567/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       2020871    499320/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        2010585    497980/influxd
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       2022298    500090/io.simple-ap
    tcp6       0      0 ::1:1883                :::*                    LISTEN      108        787655     195635/mosquitto
    tcp6       0      0 :::443                  :::*                    LISTEN      994        4991       793/pihole-FTL
    tcp6       0      0 :::445                  :::*                    LISTEN      0          5989       816/smbd
    tcp6       0      0 :::139                  :::*                    LISTEN      0          5990       816/smbd
    tcp6       0      0 :::80                   :::*                    LISTEN      994        4990       793/pihole-FTL
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5841       725/sshd: /usr/sbin
    tcp6       0      0 :::53                   :::*                    LISTEN      994        944        793/pihole-FTL
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       2019821    499052/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       2019822    499052/io.tuya.0
    udp        0      0 0.0.0.0:35990           0.0.0.0:*                           104        5771       567/avahi-daemon: r
    udp        0      0 0.0.0.0:53              0.0.0.0:*                           994        941        793/pihole-FTL
    udp        0      0 0.0.0.0:123             0.0.0.0:*                           994        6523       793/pihole-FTL
    udp        0      0 192.168.196.255:137     0.0.0.0:*                           0          4891       812/nmbd
    udp        0      0 192.168.196.163:137     0.0.0.0:*                           0          4890       812/nmbd
    udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          4878       812/nmbd
    udp        0      0 192.168.196.255:138     0.0.0.0:*                           0          4893       812/nmbd
    udp        0      0 192.168.196.163:138     0.0.0.0:*                           0          4892       812/nmbd
    udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          4879       812/nmbd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       2018999    499388/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5769       567/avahi-daemon: r
    udp6       0      0 :::40467                :::*                                104        5772       567/avahi-daemon: r
    udp6       0      0 :::53                   :::*                                994        943        793/pihole-FTL
    udp6       0      0 :::123                  :::*                                994        7728       793/pihole-FTL
    udp6       0      0 fe80::79fe:afdf:59b:546 :::*                                0          7691       611/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        5770       567/avahi-daemon: r
    2025-11-02 10:59:21.902  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Überwachung.Raspi-Temp: MIN  - IST - MAX:     58  -  62.0  - 62
    2025-11-02 10:59:27.293  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Überwachung.Raspi-Temp: MIN  - IST - MAX:     58  -  60.4  - 62
    2025-11-02 10:59:27.861  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Stromzähler.Zählerstand: 16
    2025-11-02 10:59:32.681  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Überwachung.Raspi-Temp: MIN  - IST - MAX:     58  -  60.9  - 62
    2025-11-02 10:59:36.857  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Stromzähler.Zählerstand: 17
    2025-11-02 10:59:38.065  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Überwachung.Raspi-Temp: MIN  - IST - MAX:     58  -  59.3  - 62
    2025-11-02 10:59:43.453  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Überwachung.Raspi-Temp: MIN  - IST - MAX:     58  -  60.9  - 62
    2025-11-02 10:59:44.857  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Stromzähler.Zählerstand: 18
    2025-11-02 10:59:48.845  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Überwachung.Raspi-Temp: MIN  - IST - MAX:     58  -  62.0  - 62
    2025-11-02 10:59:52.862  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Stromzähler.Zählerstand: 19
    2025-11-02 10:59:54.237  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Überwachung.Raspi-Temp: MIN  - IST - MAX:     58  -  61.5  - 62
    2025-11-02 10:59:59.644  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Überwachung.Raspi-Temp: MIN  - IST - MAX:     58  -  62.0  - 62
    2025-11-02 11:00:00.009  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Anzeige.Test5: 15.15
    2025-11-02 11:00:00.031  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Überwachung.Regenmeldung: 0
    2025-11-02 11:00:00.859  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Stromzähler.Zählerstand: 20
    2025-11-02 11:00:01.168  - info: linux-control.0 (499457) getting data from Raspi2 (192.168.196.163:22)
    2025-11-02 11:00:02.014  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Anzeige.Test5: 15.15
    2025-11-02 11:00:05.066  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Überwachung.Raspi-Temp: MIN  - IST - MAX:     58  -  64.2  - 62
    2025-11-02 11:00:06.904  - info: linux-control.0 (499457) successful received data from Raspi2 (192.168.196.163:22)
    2025-11-02 11:00:08.863  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Stromzähler.Zählerstand: 21
    2025-11-02 11:00:15.849  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Überwachung.Raspi-Temp: MIN  - IST - MAX:     58  -  63.7  - 62
    2025-11-02 11:00:16.859  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Stromzähler.Zählerstand: 22
    2025-11-02 11:00:21.786  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Überwachung.Raspi-Temp: MIN  - IST - MAX:     58  -  64.2  - 62
    2025-11-02 11:00:24.865  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Stromzähler.Zählerstand: 23
    2025-11-02 11:00:27.176  - info: javascript.0 (498609) script.js.Scripte.Meldungen.Überwachung.Raspi-Temp: MIN  - IST - MAX:     58  -  62.6  - 62
    iob diag has finished.
    D Thomas BraunT 2 Antworten Letzte Antwort
    • D DGR
      ```bash
      Script v.2025-08-09
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      pi
      HOME=/home/pi
      iobroker
      HOME=/home/iobroker
      Display-Manager:
      Desktop:
      Session:                tty
      *** MEMORY ***
               8063 M total memory
               3265 M used memory
                566 M free memory
                703 M buffer memory
               3946 M swap cache
                511 M total swap
                263 M used swap
                248 M free swap
      *** FILESYSTEM ***
      /var:
      5.8G    /var/
      2.4G    /var/log
      2.3G    /var/lib
      USB-Devices by-id:
      HINT:
      /dev/ttyACM0
      HINT:
      tcp
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.9.4
      /usr/bin/npx            10.9.4
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.7.2
      javascript:     8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects:        12754
      States:         9572
      Pending Updates: 0
      DGR
      @dgr
      pi@raspi2:~ $ sudo apt purge mosquitto
      Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
        libcamera0.3 libcamera0.4 libdlt2 libdrm-nouveau2 libunwind8 linux-headers-6.12.20+rpt-common-rpi linux-headers-6.12.20+rpt-rpi-2712 linux-headers-6.12.20+rpt-rpi-v8 linux-headers-6.12.25+rpt-common-rpi
        linux-headers-6.12.25+rpt-rpi-2712 linux-headers-6.12.25+rpt-rpi-v8 linux-headers-6.6.51+rpt-common-rpi linux-headers-6.6.62+rpt-common-rpi linux-headers-6.6.62+rpt-rpi-2712
        linux-headers-6.6.62+rpt-rpi-v8 linux-headers-6.6.74+rpt-common-rpi linux-headers-6.6.74+rpt-rpi-2712 linux-headers-6.6.74+rpt-rpi-v8 linux-image-6.12.20+rpt-rpi-2712 linux-image-6.12.20+rpt-rpi-v8
        linux-image-6.12.25+rpt-rpi-2712 linux-image-6.12.25+rpt-rpi-v8 linux-image-6.6.62+rpt-rpi-2712 linux-image-6.6.62+rpt-rpi-v8 linux-image-6.6.74+rpt-rpi-2712 linux-image-6.6.74+rpt-rpi-v8
        linux-kbuild-6.12.20+rpt linux-kbuild-6.12.25+rpt linux-kbuild-6.6.51+rpt linux-kbuild-6.6.62+rpt linux-kbuild-6.6.74+rpt rpicam-apps-lite
      Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
      Die folgenden Pakete werden ENTFERNT:
        mosquitto*
      0 aktualisiert, 0 neu installiert, 1 zu entfernen und 0 nicht aktualisiert.
      Nach dieser Operation werden 1.140 kB Plattenplatz freigegeben.
      Möchten Sie fortfahren? [J/n] j
      (Lese Datenbank ... 196663 Dateien und Verzeichnisse sind derzeit installiert.)
      Entfernen von mosquitto (2.0.11-1.2+deb12u2) ...
      Trigger für man-db (2.11.2-2) werden verarbeitet ...
      Trigger für libc-bin (2.36-9+rpt2+deb12u13) werden verarbeitet ...
      (Lese Datenbank ... 196639 Dateien und Verzeichnisse sind derzeit installiert.)
      Löschen der Konfigurationsdateien von mosquitto (2.0.11-1.2+deb12u2) ...
      pi@raspi2:~ $
      • D DGR
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
                 8063 M total memory
                 3265 M used memory
                  566 M free memory
                  703 M buffer memory
                 3946 M swap cache
                  511 M total swap
                  263 M used swap
                  248 M free swap
        *** FILESYSTEM ***
        /var:
        5.8G    /var/
        2.4G    /var/log
        2.3G    /var/lib
        USB-Devices by-id:
        HINT:
        /dev/ttyACM0
        HINT:
        tcp
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.9.4
        /usr/bin/npx            10.9.4
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.7.2
        javascript:     8.9.2
        Adapter State
        + instance is alive
        Objects and States
        Objects:        12754
        States:         9572
        Pending Updates: 0
        @dgr sagte in zigbee2mqtt für Zigbee-Erweiterung mit SLZB-06:
        Tu das baldmöglichst.
        HINT:
        /dev/ttyACM0
        Verwende den Link 'by-id'.
        Updaten...
        In den Paketquellen fehlt die Quelle für Grafana.
          HINT:
          /dev/ttyACM0
          Updaten...
          DGR
          Upgrade auf Trixie mache ich beim Wechsel auf mein derzeit ungenutztes Zweitsystem
          Admin-Adapter habe ich aktualisiert. Die Instanz Zigbee.0 läuft zwar, aber bei Channel gibt es ein gelbes (Warn)-Symbol.
          Das Zigbee2mqtt - Verzeichnis war leer. Ich habe es gelöscht.
          Grafana muß ich mir ansehen. Läuft aber eigentlich. Ich sollte ein Update machen von 11.3.1 auf aktuell 12.2
          • D DGR
            Klar läuft das. Aber du hast keine Paketquelle dafür aktiv. Und damit klemmst du dich von Updates jeglicher Art ab. Ist gefährlich, weil auch keine Sicherheitsupdates mitkommen.
              DGR
              für influx gibt es das in /etc/apt/sources.list.d (influxdb.list)
              Aber wie kann ich eine Datei grafana.list erzeugen ?
              • D DGR
                @dgr
                https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind
                • D DGR
                  HomoranH Offline
                  HomoranH Offline
                  https://forum.iobroker.net/topic/59231/phantastische-repositories-und-wo-sie-zu-finden-sind?_=1762081752638
                    @dgr
                    DGR
                    schrieb am zuletzt editiert von DGR
                    Danke, hat geklappt.
                    Grafana hat sich anschließend auch gemeldet wegen update und Update ist gelaufen.
                    Danke nochmal an alle.
                    S 1Topf1 2 Antworten Letzte Antwort
                    • D DGR
                      S Abwesend
                      S Abwesend
                      Shadowhunter23
                      schrieb am zuletzt editiert von Shadowhunter23
                      @dgr
                      Dann ändere den Titel auf am Anfang auf [erl] oder ähnliches.
                      Sorry nicht gesehen dass da schon gelöst steht.
                      Proxmox 9 HA-Cluster mit 3x HP prodesk 400 G6 i5
                      ioBroker Backup Analyzer
                      • D DGR
                        1Topf1 Offline
                        1Topf1 Offline
                        1Topf
                        @dgr Freut uns. Und siehst ja was passieren kann, wenn man auf die KI hört ... 😁
