  4. Tester wanted - Zigbee Adapter 3.1
testerzhczigbeezigbee 3.1
273 Beiträge 17 Kommentatoren 35.2k Aufrufe 16 Beobachtet
  • F Flugschüler
    @Asgothian
    I01: Zigbee Event of Type commandDataReport from device 0xa4c13886e50d0115, incoming event: {"type":"commandDataReport","data":{"seq":9472,"dpValues":[{"dp":110,"datatype":2,"data":{"type":"Buffer","data":[0,0,170,231]}}]},"linkquality":58,"groupID":0,"cluster":"manuSpecificTuya","meta":{"rawData":{"type":"Buffer","data":[9,111,2,0,37,110,2,0,4,0,0,170,231]},"zclTransactionSequenceNumber":111,"frameControl":{"frameType":1,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":false,"reservedBits":0}},"endpoint_id":1}
    I02: 2 converters available for '2CT' 'a4c13886e50d0115' with cluster 'manuSpecificTuya' and type 'commandDataReport'
    I03: message received '{"linkquality":58}' from device a4c13886e50d0115 type '2CT'
    I04: value generated '58' from device a4c13886e50d0115 for 'Link quality'
    I02.1a: converter 1 : Cluster manuSpecificTuya
    I02.0b: data: {"seq":9472,"dpValues":[{"dp":110,"datatype":2,"data":{"type":"Buffer","data":[0,0,170,231]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:undefined
    I02.2a: converter 2 : Cluster manuSpecificTuya
    I02.1b: data: {"seq":9472,"dpValues":[{"dp":110,"datatype":2,"data":{"type":"Buffer","data":[0,0,170,231]}}]} options: {} meta:{"deviceIEEE":"0xa4c13886e50d0115","logger":"StatesController","state":{"state":""}} result:{}
    I02.2c: candidates: [{},{}] => payload {}
    NOVAL: payload {} is empty
    Aber wie gesagt das Gerät funktioniert und die datenpunkte werden angezeigt.
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #144
    @flugschüler dann würde ich mir erst einmal keine Sorgen machen.
    A.
    F 1 Antwort Letzte Antwort
    • AsgothianA Asgothian
      A.
      Flugschüler
      #145
      @asgothian Super gemacht. Wird das Gerät in den neuen Zigbee Adapter integriert? Soll ich den Adapter jetzt über git installiert lassen?
      AsgothianA Thomas BraunT 2 Antworten Letzte Antwort
      • F Flugschüler
        AsgothianA Offline
        AsgothianA Offline
        Asgothian
        #146
        @flugschüler sobald die ganzen Nebeneffekte geklärt sind geht das erst ins latest, dann ins stable.
        • F Flugschüler
          #147
          @flugschüler sagte in Tester wanted - Zigbee Adapter 3.1:
          Ja. Wenn irgendwann über dein bevorzugtes Repository eine Version größer als die jetzige angeboten wird kommt die dann über deine regelmäßige Systempflege auf die Kiste.
            Flugschüler
            #148
            @thomas-braun Ihr seid die besten👍
              @dimaiv kannst du folgendes machen:
              • die aktuelle Github version installieren
              • nach dem Start eine ts0121 plug auf debug setzen
              • ein Device Query machen
              • Dann das Debug interface öffnen
              • mit dem button 1 aus dem Screenshot die Daten aktualisieren
              • in jeder Zeile bei incoming messages mit dem blauen Button 2 die Meldungen öffnen
              • aus dem Dialog heraus kopieren und hier Posten ?
              Danke.
              A.
              dimaiv
              schrieb am zuletzt editiert von dimaiv
              #149
              @asgothian sagte in Tester wanted - Zigbee Adapter 3.1:
              Danke.
              A.
              I01: Zigbee Event of Type readResponse from device 0x60a423fffe61dd4a, incoming event: {"type":"readResponse","data":{"tuyaBacklightMode":1},"linkquality":87,"groupID":0,"cluster":"genOnOff","meta":{"rawData":{"type":"Buffer","data":[24,8,1,1,128,0,48,1]},"zclTransactionSequenceNumber":8,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
              I02: 3 converters available for 'TS0121_plug' '60a423fffe61dd4a' with cluster 'genOnOff' and type 'readResponse'
              I03: message received '{"linkquality":87}' from device 60a423fffe61dd4a type 'TS0121_plug'
              I04: value generated '87' from device 60a423fffe61dd4a for 'Link quality'
              I02.1a: converter 1 : Cluster genOnOff
              I02.0b: data: {"tuyaBacklightMode":1} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:undefined
              I02.2a: converter 2 : Cluster genOnOff
              I02.1b: data: {"tuyaBacklightMode":1} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:undefined
              I02.3a: converter 3 : Cluster genOnOff
              I02.2b: data: {"tuyaBacklightMode":1} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:{"indicator_mode":"off/on"}
              I02.3c: candidates: [{},{},{"indicator_mode":"off/on"}] => payload {"indicator_mode":"off/on"}
              I03-1: message received '{"indicator_mode":"off/on"}' from device 60a423fffe61dd4a type 'TS0121_plug'
              I04-1: value generated '"off/on"' from device 60a423fffe61dd4a for 'LED indicator mode'
              I01: Zigbee Event of Type readResponse from device 0x60a423fffe61dd4a, incoming event: {"type":"readResponse","data":{"moesStartUpOnOff":0},"linkquality":87,"groupID":0,"cluster":"genOnOff","meta":{"rawData":{"type":"Buffer","data":[24,7,1,2,128,0,48,0]},"zclTransactionSequenceNumber":7,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
              I02.0b: data: {"moesStartUpOnOff":0} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:undefined
              I02.1b: data: {"moesStartUpOnOff":0} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:{"power_outage_memory":"off"}
              I02.2b: data: {"moesStartUpOnOff":0} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:undefined
              I02.3c: candidates: [{},{"power_outage_memory":"off"},{}] => payload {"power_outage_memory":"off"}
              I03-1: message received '{"power_outage_memory":"off"}' from device 60a423fffe61dd4a type 'TS0121_plug'
              I04-1: value generated '"off"' from device 60a423fffe61dd4a for 'Recover state after power outage'
              I01: Zigbee Event of Type readResponse from device 0x60a423fffe61dd4a, incoming event: {"type":"readResponse","data":{"onOff":0},"linkquality":87,"groupID":0,"cluster":"genOnOff","meta":{"rawData":{"type":"Buffer","data":[24,6,1,0,0,0,16,0]},"zclTransactionSequenceNumber":6,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
              I02.0b: data: {"onOff":0} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:{"state":"OFF"}
              I02.1b: data: {"onOff":0} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:undefined
              I02.2b: data: {"onOff":0} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:undefined
              I02.3c: candidates: [{"state":"OFF"},{},{}] => payload {"state":"OFF"}
              I03-1: message received '{"state":"OFF"}' from device 60a423fffe61dd4a type 'TS0121_plug'
              I04-1: value generated 'false' from device 60a423fffe61dd4a for 'On/off state of the switch'
              P.S.: ich glaube, die weiteren Daten bei diesen Steckdosen wurden immer gepoolt, und jetzt passiert es nicht.
              ioBroker- NUC8i3 / Proxmox / VM
              Node.js v22.21.0
              NPM v10.9.4
              JS controller 7.1.0
              Admin 7.7.20
              ZigBee Adapter 3.3.1alpha.0
              Zigbee LAN Gateway CC2652P
              Zigbee Firmware 20250321
                dimaiv
                #150
                @asgothian
                Was mir noch aufgefallen:
                Mit 3.1.2 kann ich über:
                sendToZigbee { "id": "zigbee.0.842e14fffedb8ae5", "ep": "1", "cid": "haElectricalMeasurement", "cmd": "read", "cmdType": "foundation", "zclData": { "activePower": {} } }
                Die weiteren Daten abrufen.
                Mit 3.1.3 von jetzt funktioniert es nicht.
                Das sind 2 absolut gleiche Steckdosen, unterschiedliche Installationen.
                Node.js v22.21.0
                NPM v10.9.4
                JS controller 7.1.0
                Admin 7.7.20
                • D dimaiv
                  Danke.
                  A.
                  AsgothianA Offline
                  AsgothianA Offline
                  Asgothian
                  #151
                  @dimaiv sagte in Tester wanted - Zigbee Adapter 3.1:
                  Sind die Meldungen nach einem Device_query, oder kommen die normal so ?
                  Danke für den Hinweis - ich hab im Hintergrund einiges Optimiert.
                  A.
                    A.
                    dimaiv
                    #152
                    A.
                    Die Meldungen sind nach einem Device_query, aber auch normal kommen nur die.
                    Node.js v22.21.0
                    NPM v10.9.4
                    JS controller 7.1.0
                    Admin 7.7.20
                    • D dimaiv
                      A.
                      AsgothianA Offline
                      AsgothianA Offline
                      Asgothian
                      #153
                      @dimaiv Ok, danke. Da scheint ein Konverter geändert - da muss ich im Detail graben, und Dir eine extra version machen. Wird aber etwas dauern.
                      A.
                        A.
                        AsgothianA Offline
                        AsgothianA Offline
                        Asgothian
                        #154
                        @asgothian Zumindest der Developer Tab sollte jetzt wieder funktionieren.
                        Kannst du versuchen was passiert wenn du damit versuchst die Daten abzurufen ? Ob dann eine Meldung rein kommt ?
                        Interessant ist was genau an Antwort auf den Read Request rein kommt, wenn überhaupt etwas.
                        A.
                          A.
                          dimaiv
                          #155
                          A.
                          Über Entwikler Tab funktioniert jetzt:
                          I01: Zigbee Event of Type readResponse from device 0x60a423fffe61dd4a, incoming event: {"type":"readResponse","data":{"activePower":0},"linkquality":51,"groupID":0,"cluster":"haElectricalMeasurement","meta":{"rawData":{"type":"Buffer","data":[24,8,1,11,5,0,41,0,0]},"zclTransactionSequenceNumber":8,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
                          I02: 1 converter available for 'TS0121_plug' '60a423fffe61dd4a' with cluster 'haElectricalMeasurement' and type 'readResponse'
                          I03: message received '{"linkquality":51}' from device 60a423fffe61dd4a type 'TS0121_plug'
                          I04: value generated '51' from device 60a423fffe61dd4a for 'Link quality'
                          I02.1a: converter 1 : Cluster haElectricalMeasurement
                          I02.0b: data: {"activePower":0} options: {} meta:{"deviceIEEE":"0x60a423fffe61dd4a","logger":"StatesController","state":{"state":""}} result:{"power":0}
                          I02.1c: candidates: [{"power":0}] => payload {"power":0}
                          I03-1: message received '{"power":0}' from device 60a423fffe61dd4a type 'TS0121_plug'
                          I04-1: value generated '0' from device 60a423fffe61dd4a for 'Load power'
                          Uber die Scripte stürzt aber der Adapter ab mit folgender Meldung:
                          2025-09-21 21:40:50.830 - info: javascript.0 (942) script.js.Plug_abfragen: start JavaScript (Blockly)
                          2025-09-21 21:40:50.842 - info: javascript.0 (942) script.js.Plug_abfragen: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          2025-09-21 21:40:55.849 - error: zigbee.0 (282446) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          2025-09-21 21:40:55.851 - error: zigbee.0 (282446) unhandled promise rejection: Cannot read properties of undefined (reading 'replace')
                          2025-09-21 21:40:56.167 - error: zigbee.0 (282446) TypeError: Cannot read properties of undefined (reading 'replace')
                          at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:90:45)
                          at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:49:26)
                          at Zigbee.emit (node:events:536:35)
                          at Zigbee.emit (node:domain:489:12)
                          at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11040:34)
                          at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:365:37)
                          at processImmediate (node:internal/timers:483:21)
                          2025-09-21 21:40:56.168 - error: zigbee.0 (282446) Cannot read properties of undefined (reading 'replace')
                          2025-09-21 21:40:56.193 - info: zigbee.0 (282446) Halting zigbee adapter. Restart delay is at least 30 seconds.
                          2025-09-21 21:40:56.193 - info: zigbee.0 (282446) cleaning everything up...
                          2025-09-21 21:40:56.196 - info: zigbee.0 (282446) Saved local configuration data
                          2025-09-21 21:40:56.227 - warn: zigbee.0 (282446) ELEVATED:I03 (2e22) message received '{"available":false}' from device 60a423fffe61dd4a type 'TS0121_plug'
                          2025-09-21 21:40:56.228 - warn: zigbee.0 (282446) ELEVATED:I04 (2e22) value generated 'false' from device 60a423fffe61dd4a for 'Available'
                          2025-09-21 21:40:56.229 - warn: zigbee.0 (282446) ELEVATED:I03 (2e22) message received '{"linkquality":0}' from device 60a423fffe61dd4a type 'TS0121_plug'
                          2025-09-21 21:40:56.230 - warn: zigbee.0 (282446) ELEVATED:I04 (2e22) value generated '0' from device 60a423fffe61dd4a for 'Link quality'
                          2025-09-21 21:40:56.586 - info: zigbee.0 (282446) Closing Zigbee network, 0 seconds remaining
                          2025-09-21 21:40:57.195 - warn: zigbee.0 (282446) Terminated (UNCAUGHT_EXCEPTION): Without reason
                          2025-09-21 21:40:57.783 - error: host.GartenIoB Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                          2025-09-21 21:40:57.784 - error: host.GartenIoB Caught by controller[2]: TypeError: Cannot read properties of undefined (reading 'replace')
                          2025-09-21 21:40:57.784 - error: host.GartenIoB Caught by controller[2]: at Developer.sendToZigbee (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:90:45)
                          2025-09-21 21:40:57.784 - error: host.GartenIoB Caught by controller[2]: at Developer.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/developer.js:49:26)
                          2025-09-21 21:40:57.784 - error: host.GartenIoB Caught by controller[2]: at Zigbee.emit (node:events:536:35)
                          2025-09-21 21:40:57.785 - error: host.GartenIoB Caught by controller[2]: at Zigbee.emit (node:domain:489:12)
                          2025-09-21 21:40:57.785 - error: host.GartenIoB Caught by controller[2]: at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11040:34)
                          2025-09-21 21:40:57.785 - error: host.GartenIoB Caught by controller[2]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:365:37)
                          2025-09-21 21:40:57.785 - error: host.GartenIoB Caught by controller[2]: at processImmediate (node:internal/timers:483:21)
                          2025-09-21 21:40:57.785 - error: host.GartenIoB instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                          2025-09-21 21:40:57.785 - info: host.GartenIoB Restart adapter system.adapter.zigbee.0 because enabled
                          2025-09-21 21:41:01.905 - info: javascript.0 (942) script.js.Plug_abfragen: Stopping script
                          Blockly=>JS:
                          var Intervall;
                          // Beschreibe diese Funktion …
                          async function Power() {
                            sendTo('zigbee.0', 'sendToZigbee', {
                              'parameter': { "id": "zigbee.0.60a423fffe61dd4a", "ep": "1", "cid": "haElectricalMeasurement", "cmd": "read", "cmdType": "foundation", "zclData": { "activePower": {} } },
                          Intervall = setInterval(async () => {
                            await Power();
                          }, 5000);
                          Mit 3.1.2 funktionieren beide Variante.
                          Node.js v22.21.0
                          NPM v10.9.4
                          JS controller 7.1.0
                          Admin 7.7.20
                          • AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            #156
                            @dimaiv Danke fürs Testen - ich schau mir das morgen an
                            • D dimaiv
                              A.
                              Blockly=>JS:
                              var Intervall;
                                await Power();
                              }, 5000);
                              AsgothianA Offline
                              AsgothianA Offline
                              Asgothian
                              #157
                              sendTo('zigbee.0', 'sendToZigbee', { 'parameter': { "id": "zigbee.0.60a423fffe61dd4a", "ep": "1", "cid": "haElectricalMeasurement", "cmd": "read", "cmdType": "foundation", "zclData": { "activePower": {} } }, });
                              Diese Methode die Funktion aufzurufen ist auf Dauer instabil - sie basiert darauf das interne Funktionen nicht geändert werden. Bitte teste, ob mit einer der 3.X Versionen der folgende Payload in send_payload das gewünschte Ergebnis bringt. Dieses ist als Ersatz für das 'sendToZigbee' implementiert worden
                                "read": {
                                  "cluster": "haElectricalMeasurement",
                                  "attributes": [
                                    "activePower"
                              Nachtrag:
                              bist du sicher das dieser Code in 3.0.5 wirklich geht ?
                              var Intervall;
                                 await Power();
                               }, 5000);
                              Hintergrund - es gab eine Anpassung am Blockly SendTo Block. Wo der vorher den Code
                              sendTo('zigbee.0', 'sendToZigbee', {"id": "zigbee.0.00be44fffeab0b87", "ep": "1", "cid": "haElectricalMeasurement", "cmd": "read", "cmdType": "foundation", "zclData": { "activePower": {} } },
                              als Standard erzeugt hat, macht er jetzt
                              mit dem Standard Block. Um die alte Version zurück zu bekommen muss man den Namen der Variable im Block löschen.
                              Blockly Skript zum importieren als Beispiel:
                                <block type="sendto_custom" id="+%Nw$~nnCWC@TlZQZ~]8" x="212" y="138">
                                  <mutation xmlns="http://www.w3.org/1999/xhtml" items="parameter"></mutation>
                                  <field name="INSTANCE">zigbee.0</field>
                                  <field name="COMMAND">sendToZigbee</field>
                                  <field name="LOG"></field>
                                  <field name="WITH_STATEMENT">FALSE</field>
                                  <value name="ARG0">
                                    <shadow type="text" id="](`*pMFJEuOLTeBJ5hZF">
                                      <field name="TEXT">{"id": "zigbee.0.00be44fffeab0b87", "ep": "1", "cid": "haElectricalMeasurement", "cmd": "read", "cmdType": "foundation", "zclData": { "activePower": {} } }</field>
                                    </shadow>
                                  </value>
                                  <next>
                                    <block type="sendto_custom" id="1o#t?S/@4Z_1R7G/YxW3">
                                      <mutation xmlns="http://www.w3.org/1999/xhtml" items=""></mutation>
                                      <value name="ARG0">
                                        <shadow type="text" id="O`S)U?JPvg=x#CYYZI*r">
                                        </shadow>
                                      </value>
                                    </block>
                                  </next>
                                </block>
                              </xml>
                              D AsgothianA 2 Antworten Letzte Antwort
                                  "read": {
                                    "attributes": [
                                      "activePower"
                                Nachtrag:
                                var Intervall;
                                   await Power();
                                 }, 5000);
                                    <value name="ARG0">
                                      </shadow>
                                    </value>
                                    <next>
                                        <value name="ARG0">
                                          </shadow>
                                        </value>
                                      </block>
                                    </next>
                                  </block>
                                </xml>
                                dimaiv
                                #158
                                @asgothian
                                Deine Blockly ist absolut identisch mit dem was ich oben gepostet habe, nur bei mir ist SendTo in eine funktion gepackt und anderes exportiert.
                                Aber es macht nix, beide Varianten bringen 3.1.3 zum Absturz, und mit 3.1.2 aus latest funktionieren einwandfrei.
                                Aber, das ist jetz auch egal, weil, Variante über send_payload funktioniert auch bei 3.1.3 , und ist einfacher einzurichten bei mehreren Steckdosen.
                                Hoffentlich, muss man es ab jetzt, nich dauerhaft benutzen und überall einrichten , und es wird, wie vorher, von alleine über Converter (Pooling) funktionieren .
                                P.S.: Problem mit send_payload bei SWV bin ich auch betroffen, aber ich verfolge es auf Git. Falls hier was zum testen gibt, oder du das Ventil zum debuggen haben möchtest/muss, sag Bescheid.
                                Node.js v22.21.0
                                NPM v10.9.4
                                JS controller 7.1.0
                                Admin 7.7.20
                                    "read": {
                                      "attributes": [
                                        "activePower"
                                  Nachtrag:
                                  var Intervall;
                                     await Power();
                                   }, 5000);
                                      <value name="ARG0">
                                        </shadow>
                                      </value>
                                      <next>
                                          <value name="ARG0">
                                            </shadow>
                                          </value>
                                        </block>
                                      </next>
                                    </block>
                                  </xml>
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  #159
                                  Es gibt eine neue Version auf Github: 3.1.2-alpha-4.
                                  Folgende Anpassungen sollten da drin sein:
                                  • Fix für 'onEvent' Polling: Sollte diesen Issue (GitHub link) schliessen: (sowie die Probleme vor @dimaiv)
                                  • Fix für 'no configure on pairing' - neu dem Netzwerk hinzugefügte Devices sollten automatisch Konfiguriert werden.
                                  • Netzwerk am Router öffnen - da der ZH diese Funktion wieder bietet, ist sie (hoffentlich) auch wieder verfügbar. Ich kann das nur bedingt testen.
                                  • Icon download button in der Konfiguration des Adapters. Notwendig wenn ein Upload gemacht wird ohne den Adapter neu zu starten.
                                  • Neue Optionen (grün: verifiziert, Orange: Bedarf Tests die ich mangels Gerät aktuell nicht durchführen kann)
                                    -- Active availability check. Wie in diesem Issue (GitHub link) zu sehen scheint der ZHC Ping nicht immer gut zu laufen. Deswegen gibt es jetzt im Adapter wählbare alternative Methoden (incl. 'off')
                                    -- Time between activity Checks: Dieses ist eine Maximalzeit zwischen Ping Versuchen. Es gibt interne Verrechnungen abhängig davon wie viele Devices im Netz sind, wie oft ein Device nicht erreicht werden konnte und diese Zahl. Je höher die Zahl desto seltener wird jedes Device abgefragt.
                                    -- List devices at Start: Aktiviert / Deaktivert die lange Liste an aktiven Geräten und Gruppen bei Adapter-Start.
                                    -- try to read all states at adapter start: Dient dazu beim Start des Adapters zu versuchen den Status im ioBroker mit dem der Geräte zu synchronisieren. Kann bei grossen Netzen Problematisch werden. Dazu gehört: delay in seconds - die Verzögerung zwischen Adapter-Start und dem Start des Abfrage aller Geräte.
                                    -- Read States at device announce: Wenn ein Gerät sich am Netzwerk 'zurück' meldet (xxx has announced itself) wird ein Device-Query für das Device ausgelöst um dessen Status zu ermitteln.
                                    -- use channel for complex exposes: Dies ist eine zukünftige Entwicklung. Es gibt bei bestimmten Geräten Datenpuntke die eigentlich nur gemeinsam gesetzt werden dürfen. Ein Beispiel dafür sind Farben mit r, g, b - die schon als Channels angeboten werden. Dabei passiert folgendes:
                                    -- wird einer der States im Channel verändert so wird ein timeout gestartet. Bei Ablauf des Timeout werden alle eingetragenen Werte genommen und in einem Payload an das Gerät gesandt. Dabei ist die Zeit für den Timeout abhängig davon ob die Änderung 'manuell' im Admin passiert oder nicht. Im Admin liegt der Timeout zwischen 2.5 und 5 sekunden. Ausserhalb des Admin sind es 100 - 250 ms. Durch weitere Tests können sich diese Zahlen noch ändern.
                                  • Veränderungen an der Netzwerk-Karte: Der vorherige Regenerate button (blau) wurde durch einen grünen Reload button ersetzt. Dieser lädt eine bereits generierte Map vom Adapter anstatt diese neu vom Netzwerk anzufragen. Um eine Map vollständig neu aufzubauen gibt es in den Map-Einstellungen einen eigenen Button:
                                  • via den 'zigbee subsystem error' Anzeiger kann das Zigbee-Subsystem nun direkt gestartet werden, ohne auf die Hardware-seite zu gehen. Dieser button ist auch im Tab sichtbar wenn das Zigbee-System nicht läuft aber der Adapter schon. Screenshot 2025-09-24 at 22.04.59.png
                                  • Die Koordinator-Karte zeigt jetzt nicht nur an ob der Koordinator ansprechbar ist, sondern auch ob der Haken zum automatischen Start des Zigbee Subsystems gesetzt ist:
                                    --Haken gesetzt: Screenshot 2025-09-24 at 22.10.17.png
                                    -- Haken nicht gesetzt: Screenshot 2025-09-24 at 22.11.08.png
                                  • developer modus gefixed - sollte sauber gehen.
                                  • Gruppen aus der Auswahl im Developer Modus entfernt, da die Funktionalität so nicht nutzbar ist.
                                  • D dimaiv
                                    @asgothian
                                    AsgothianA Offline
                                    AsgothianA Offline
                                    Asgothian
                                    #160
                                    @asgothian
                                    Bist du sicher das die den gleichen Code erzeugen ? Bei mir tun sie das nicht, und der von mir gepostetete code
                                    sollte auch mit der aktuellen 3.1.3 laufen.
                                    Aber:
                                    Es gibt inzwischen eine 3.1.3-alpha-4, damit sollte hoffentlich das polling wieder laufen.
                                    A.
                                      @asgothian
                                      Aber:
                                      A.
                                      dimaiv
                                      #161
                                      @asgothian
                                      Adapter 3.1.3 alpha 4 stürzt sofort ab.
                                      2025-09-24 22:25:18.298 - info: zigbee.0 (296477) 20 devices are part of the network
                                      2025-09-24 22:25:18.300 - info: zigbee.0 (296477) Zigbee started
                                      2025-09-24 22:25:18.333 - warn: zigbee.0 (296477) DeviceEvent:calling onEvent for start on 0x60a423fffe61dd4a
                                      2025-09-24 22:25:18.349 - warn: zigbee.0 (296477) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df66f
                                      2025-09-24 22:25:18.355 - warn: zigbee.0 (296477) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df516
                                      2025-09-24 22:25:18.357 - warn: zigbee.0 (296477) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df594
                                      2025-09-24 22:25:18.359 - warn: zigbee.0 (296477) DeviceEvent:calling onEvent for start on 0x881a14fffeea1db2
                                      2025-09-24 22:25:18.361 - warn: zigbee.0 (296477) DeviceEvent:calling onEvent for start on 0x28dba7fffe6df5f6
                                      2025-09-24 22:25:18.362 - warn: zigbee.0 (296477) DeviceEvent:calling onEvent for start on 0xa4c13801838effff
                                      2025-09-24 22:25:18.365 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2025-09-24 22:25:18.365 - error: zigbee.0 (296477) unhandled promise rejection: Cannot read properties of undefined (reading 'measurement_poll_interval')
                                      2025-09-24 22:25:18.537 - error: zigbee.0 (296477) TypeError: Cannot read properties of undefined (reading 'measurement_poll_interval')
                                      at onEvent (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:678:58)
                                      at Object.onEvent (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/index.ts:376:27)
                                      at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:69:26)
                                      at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                      at DeviceEvent.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:13:13)
                                      at async Promise.all (index 2)
                                      2025-09-24 22:25:18.538 - error: zigbee.0 (296477) Cannot read properties of undefined (reading 'measurement_poll_interval')
                                      2025-09-24 22:25:18.592 - info: zigbee.0 (296477) Halting zigbee adapter. Restart delay is at least 30 seconds.
                                      2025-09-24 22:25:18.592 - info: zigbee.0 (296477) cleaning everything up
                                      2025-09-24 22:25:18.596 - info: zigbee.0 (296477) Saved local configuration data
                                      2025-09-24 22:25:18.598 - info: zigbee.0 (296477) cleanup successful
                                      2025-09-24 22:25:18.599 - info: zigbee.0 (296477) terminating
                                      2025-09-24 22:25:18.602 - warn: zigbee.0 (296477) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      2025-09-24 22:25:18.610 - info: zigbee.0 (296477) zigbecontroller stopped successfully - ZH was not running
                                      2025-09-24 22:25:18.797 - info: zigbee.0 (296477) debug devices set to []
                                      2025-09-24 22:25:19.207 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.208 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.209 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.210 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.211 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.212 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.213 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.214 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.215 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.216 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.217 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.218 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.219 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.220 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.221 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.222 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.223 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.224 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.225 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.226 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.227 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.228 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.229 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.230 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.231 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.232 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.233 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.234 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.235 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.236 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.237 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.238 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.239 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.240 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.241 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.242 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.243 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.244 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.245 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.246 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.247 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.248 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.249 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.250 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.251 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.252 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.253 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.254 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.255 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.256 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.257 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.258 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.470 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.471 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.472 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.473 - warn: zigbee.0 (296477) get state error: Connection is closed.
                                      2025-09-24 22:25:19.478 - error: zigbee.0 (296477) Cannot check file existence of "cfg.f.zigbee.admin$%$img/RTCGQ11LM.png$%$data": DB closed
                                      2025-09-24 22:25:19.478 - error: zigbee.0 (296477) Cannot check file existence of "cfg.f.zigbee.admin$%$img/WSDCGQ11LM.png$%$data": DB closed
                                      2025-09-24 22:25:19.479 - error: zigbee.0 (296477) Cannot check file existence of "cfg.f.zigbee.admin$%$img/ptvo.switch.png$%$data": DB closed
                                      2025-09-24 22:25:19.479 - error: zigbee.0 (296477) Cannot check file existence of "cfg.f.zigbee.admin$%$img/MCCGQ11LM.png$%$data": DB closed
                                      2025-09-24 22:25:19.499 - error: zigbee.0 (296477) Cannot check file existence of "cfg.f.zigbee.admin$%$img/MCCGQ11LM.png$%$data": Connection is closed.
                                      2025-09-24 22:25:19.500 - error: zigbee.0 (296477) Cannot check file existence of "cfg.f.zigbee.admin$%$img/TS0121_plug.png$%$data": Connection is closed.
                                      2025-09-24 22:25:19.500 - error: zigbee.0 (296477) Cannot check file existence of "cfg.f.zigbee.admin$%$img/DIYRuZ_Flower.png$%$data": Connection is closed.
                                      2025-09-24 22:25:19.501 - error: zigbee.0 (296477) Cannot check file existence of "cfg.f.zigbee.admin$%$img/SWV.png$%$data": Connection is closed.
                                      2025-09-24 22:25:19.501 - error: zigbee.0 (296477) Cannot check file existence of "cfg.f.zigbee.admin$%$img/HG08010.png$%$data": Connection is closed.
                                      2025-09-24 22:25:19.542 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2025-09-24 22:25:19.542 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
                                      2025-09-24 22:25:19.544 - error: zigbee.0 (296477) Error: DB closed
                                      at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                      at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                      at Object.onceWrapper (node:events:639:26)
                                      at Socket.emit (node:events:524:28)
                                      at Socket.emit (node:domain:489:12)
                                      at TCP. (node:net:343:12)
                                      2025-09-24 22:25:19.544 - error: zigbee.0 (296477) DB closed
                                      2025-09-24 22:25:19.552 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2025-09-24 22:25:19.553 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
                                      2025-09-24 22:25:19.554 - error: zigbee.0 (296477) Error: DB closed
                                      2025-09-24 22:25:19.554 - error: zigbee.0 (296477) DB closed
                                      2025-09-24 22:25:19.556 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2025-09-24 22:25:19.557 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
                                      2025-09-24 22:25:19.557 - error: zigbee.0 (296477) Error: DB closed
                                      2025-09-24 22:25:19.558 - error: zigbee.0 (296477) DB closed
                                      2025-09-24 22:25:19.560 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2025-09-24 22:25:19.561 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
                                      2025-09-24 22:25:19.561 - error: zigbee.0 (296477) Error: DB closed
                                      2025-09-24 22:25:19.562 - error: zigbee.0 (296477) DB closed
                                      2025-09-24 22:25:19.564 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2025-09-24 22:25:19.564 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
                                      2025-09-24 22:25:19.565 - error: zigbee.0 (296477) Error: DB closed
                                      2025-09-24 22:25:19.565 - error: zigbee.0 (296477) DB closed
                                      2025-09-24 22:25:19.567 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2025-09-24 22:25:19.568 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
                                      2025-09-24 22:25:19.568 - error: zigbee.0 (296477) Error: DB closed
                                      2025-09-24 22:25:19.569 - error: zigbee.0 (296477) DB closed
                                      2025-09-24 22:25:19.571 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2025-09-24 22:25:19.572 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
                                      2025-09-24 22:25:19.572 - error: zigbee.0 (296477) Error: DB closed
                                      2025-09-24 22:25:19.573 - error: zigbee.0 (296477) DB closed
                                      2025-09-24 22:25:19.575 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2025-09-24 22:25:19.576 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
                                      2025-09-24 22:25:19.576 - error: zigbee.0 (296477) Error: DB closed
                                      2025-09-24 22:25:19.576 - error: zigbee.0 (296477) DB closed
                                      2025-09-24 22:25:19.579 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2025-09-24 22:25:19.580 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
                                      2025-09-24 22:25:19.580 - error: zigbee.0 (296477) Error: DB closed
                                      2025-09-24 22:25:19.581 - error: zigbee.0 (296477) DB closed
                                      2025-09-24 22:25:19.582 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2025-09-24 22:25:19.583 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
                                      2025-09-24 22:25:19.583 - error: zigbee.0 (296477) Error: DB closed
                                      2025-09-24 22:25:19.584 - error: zigbee.0 (296477) DB closed
                                      2025-09-24 22:25:19.586 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2025-09-24 22:25:19.586 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
                                      2025-09-24 22:25:19.587 - error: zigbee.0 (296477) Error: DB closed
                                      2025-09-24 22:25:19.587 - error: zigbee.0 (296477) DB closed
                                      2025-09-24 22:25:19.589 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2025-09-24 22:25:19.590 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
                                      2025-09-24 22:25:19.590 - error: zigbee.0 (296477) Error: DB closed
                                      2025-09-24 22:25:19.591 - error: zigbee.0 (296477) DB closed
                                      2025-09-24 22:25:19.592 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2025-09-24 22:25:19.593 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
                                      2025-09-24 22:25:19.594 - error: zigbee.0 (296477) Error: DB closed
                                      2025-09-24 22:25:19.595 - error: zigbee.0 (296477) DB closed
                                      2025-09-24 22:25:19.596 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2025-09-24 22:25:19.596 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
                                      2025-09-24 22:25:19.596 - error: zigbee.0 (296477) Error: DB closed
                                      2025-09-24 22:25:19.597 - error: zigbee.0 (296477) DB closed
                                      2025-09-24 22:25:19.598 - error: zigbee.0 (296477) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      2025-09-24 22:25:19.599 - error: zigbee.0 (296477) unhandled promise rejection: DB closed
                                      2025-09-24 22:25:19.599 - error: zigbee.0 (296477) Error: DB closed
                                      2025-09-24 22:25:19.600 - error: zigbee.0 (296477) DB closed
                                      2025-09-24 22:25:19.602 - info: zigbee.0 (296477) downloading https://www.zigbee2mqtt.io/images/devices/RTCGQ11LM.png to img/RTCGQ11LM.png
                                      2025-09-24 22:25:19.629 - info: zigbee.0 (296477) downloading https://www.zigbee2mqtt.io/images/devices/WSDCGQ11LM.png to img/WSDCGQ11LM.png
                                      2025-09-24 22:25:19.639 - info: zigbee.0 (296477) downloading https://www.zigbee2mqtt.io/images/devices/ptvo.switch.png to img/ptvo.switch.png
                                      2025-09-24 22:25:19.647 - info: zigbee.0 (296477) downloading https://www.zigbee2mqtt.io/images/devices/MCCGQ11LM.png to img/MCCGQ11LM.png
                                      2025-09-24 22:25:19.878 - error: host.GartenIoB Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.879 - error: host.GartenIoB Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'measurement_poll_interval')
                                      2025-09-24 22:25:19.879 - error: host.GartenIoB Caught by controller[1]: at onEvent (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/lib/modernExtend.ts:678:58)
                                      2025-09-24 22:25:19.879 - error: host.GartenIoB Caught by controller[1]: at Object.onEvent (/opt/iobroker/node_modules/zigbee-herdsman-converters/src/index.ts:376:27)
                                      2025-09-24 22:25:19.879 - error: host.GartenIoB Caught by controller[1]: at DeviceEvent.callOnEvent (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:69:26)
                                      2025-09-24 22:25:19.879 - error: host.GartenIoB Caught by controller[1]: at processTicksAndRejections (node:internal/process/task_queues:95:5)
                                      2025-09-24 22:25:19.879 - error: host.GartenIoB Caught by controller[1]: at DeviceEvent.onZigbeeStarted (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:13:13)
                                      2025-09-24 22:25:19.879 - error: host.GartenIoB Caught by controller[1]: at async Promise.all (index 2)
                                      2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[3]: Error: DB closed
                                      2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[3]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                      2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[3]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                      2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[3]: at Object.onceWrapper (node:events:639:26)
                                      2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[3]: at Socket.emit (node:events:524:28)
                                      2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[3]: at Socket.emit (node:domain:489:12)
                                      2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[3]: at TCP. (node:net:343:12)
                                      2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[4]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.880 - error: host.GartenIoB Caught by controller[5]: Error: DB closed
                                      2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[5]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                      2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[5]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                      2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[5]: at Object.onceWrapper (node:events:639:26)
                                      2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[5]: at Socket.emit (node:events:524:28)
                                      2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[5]: at Socket.emit (node:domain:489:12)
                                      2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[5]: at TCP. (node:net:343:12)
                                      2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[6]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[7]: Error: DB closed
                                      2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[7]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                      2025-09-24 22:25:19.881 - error: host.GartenIoB Caught by controller[7]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                      2025-09-24 22:25:19.882 - error: host.GartenIoB Caught by controller[7]: at Object.onceWrapper (node:events:639:26)
                                      2025-09-24 22:25:19.882 - error: host.GartenIoB Caught by controller[7]: at Socket.emit (node:events:524:28)
                                      2025-09-24 22:25:19.882 - error: host.GartenIoB Caught by controller[7]: at Socket.emit (node:domain:489:12)
                                      2025-09-24 22:25:19.882 - error: host.GartenIoB Caught by controller[7]: at TCP. (node:net:343:12)
                                      2025-09-24 22:25:19.882 - error: host.GartenIoB Caught by controller[8]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.882 - error: host.GartenIoB Caught by controller[9]: Error: DB closed
                                      2025-09-24 22:25:19.882 - error: host.GartenIoB Caught by controller[9]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                      2025-09-24 22:25:19.882 - error: host.GartenIoB Caught by controller[9]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                      2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[9]: at Object.onceWrapper (node:events:639:26)
                                      2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[9]: at Socket.emit (node:events:524:28)
                                      2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[9]: at Socket.emit (node:domain:489:12)
                                      2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[9]: at TCP. (node:net:343:12)
                                      2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[10]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[11]: Error: DB closed
                                      2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[11]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                      2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[11]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                      2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[11]: at Object.onceWrapper (node:events:639:26)
                                      2025-09-24 22:25:19.883 - error: host.GartenIoB Caught by controller[11]: at Socket.emit (node:events:524:28)
                                      2025-09-24 22:25:19.884 - error: host.GartenIoB Caught by controller[11]: at Socket.emit (node:domain:489:12)
                                      2025-09-24 22:25:19.884 - error: host.GartenIoB Caught by controller[11]: at TCP. (node:net:343:12)
                                      2025-09-24 22:25:19.884 - error: host.GartenIoB Caught by controller[12]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.884 - error: host.GartenIoB Caught by controller[13]: Error: DB closed
                                      2025-09-24 22:25:19.884 - error: host.GartenIoB Caught by controller[13]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                      2025-09-24 22:25:19.884 - error: host.GartenIoB Caught by controller[13]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                      2025-09-24 22:25:19.884 - error: host.GartenIoB Caught by controller[13]: at Object.onceWrapper (node:events:639:26)
                                      2025-09-24 22:25:19.884 - error: host.GartenIoB Caught by controller[13]: at Socket.emit (node:events:524:28)
                                      2025-09-24 22:25:19.884 - error: host.GartenIoB Caught by controller[13]: at Socket.emit (node:domain:489:12)
                                      2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[13]: at TCP. (node:net:343:12)
                                      2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[14]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[15]: Error: DB closed
                                      2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[15]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                      2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[15]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                      2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[15]: at Object.onceWrapper (node:events:639:26)
                                      2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[15]: at Socket.emit (node:events:524:28)
                                      2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[15]: at Socket.emit (node:domain:489:12)
                                      2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[15]: at TCP. (node:net:343:12)
                                      2025-09-24 22:25:19.885 - error: host.GartenIoB Caught by controller[16]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.886 - error: host.GartenIoB Caught by controller[17]: Error: DB closed
                                      2025-09-24 22:25:19.886 - error: host.GartenIoB Caught by controller[17]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                      2025-09-24 22:25:19.886 - error: host.GartenIoB Caught by controller[17]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                      2025-09-24 22:25:19.886 - error: host.GartenIoB Caught by controller[17]: at Object.onceWrapper (node:events:639:26)
                                      2025-09-24 22:25:19.886 - error: host.GartenIoB Caught by controller[17]: at Socket.emit (node:events:524:28)
                                      2025-09-24 22:25:19.886 - error: host.GartenIoB Caught by controller[17]: at Socket.emit (node:domain:489:12)
                                      2025-09-24 22:25:19.886 - error: host.GartenIoB Caught by controller[17]: at TCP. (node:net:343:12)
                                      2025-09-24 22:25:19.886 - error: host.GartenIoB Caught by controller[18]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.886 - error: host.GartenIoB Caught by controller[19]: Error: DB closed
                                      2025-09-24 22:25:19.887 - error: host.GartenIoB Caught by controller[19]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                      2025-09-24 22:25:19.887 - error: host.GartenIoB Caught by controller[19]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                      2025-09-24 22:25:19.887 - error: host.GartenIoB Caught by controller[19]: at Object.onceWrapper (node:events:639:26)
                                      2025-09-24 22:25:19.887 - error: host.GartenIoB Caught by controller[19]: at Socket.emit (node:events:524:28)
                                      2025-09-24 22:25:19.887 - error: host.GartenIoB Caught by controller[19]: at Socket.emit (node:domain:489:12)
                                      2025-09-24 22:25:19.887 - error: host.GartenIoB Caught by controller[19]: at TCP. (node:net:343:12)
                                      2025-09-24 22:25:19.887 - error: host.GartenIoB Caught by controller[20]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.888 - error: host.GartenIoB Caught by controller[21]: Error: DB closed
                                      2025-09-24 22:25:19.888 - error: host.GartenIoB Caught by controller[21]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                      2025-09-24 22:25:19.888 - error: host.GartenIoB Caught by controller[21]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                      2025-09-24 22:25:19.888 - error: host.GartenIoB Caught by controller[21]: at Object.onceWrapper (node:events:639:26)
                                      2025-09-24 22:25:19.888 - error: host.GartenIoB Caught by controller[21]: at Socket.emit (node:events:524:28)
                                      2025-09-24 22:25:19.888 - error: host.GartenIoB Caught by controller[21]: at Socket.emit (node:domain:489:12)
                                      2025-09-24 22:25:19.888 - error: host.GartenIoB Caught by controller[21]: at TCP. (node:net:343:12)
                                      2025-09-24 22:25:19.888 - error: host.GartenIoB Caught by controller[22]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.889 - error: host.GartenIoB Caught by controller[23]: Error: DB closed
                                      2025-09-24 22:25:19.889 - error: host.GartenIoB Caught by controller[23]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                      2025-09-24 22:25:19.889 - error: host.GartenIoB Caught by controller[23]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                      2025-09-24 22:25:19.889 - error: host.GartenIoB Caught by controller[23]: at Object.onceWrapper (node:events:639:26)
                                      2025-09-24 22:25:19.889 - error: host.GartenIoB Caught by controller[23]: at Socket.emit (node:events:524:28)
                                      2025-09-24 22:25:19.889 - error: host.GartenIoB Caught by controller[23]: at Socket.emit (node:domain:489:12)
                                      2025-09-24 22:25:19.889 - error: host.GartenIoB Caught by controller[23]: at TCP. (node:net:343:12)
                                      2025-09-24 22:25:19.890 - error: host.GartenIoB Caught by controller[24]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.890 - error: host.GartenIoB Caught by controller[25]: Error: DB closed
                                      2025-09-24 22:25:19.890 - error: host.GartenIoB Caught by controller[25]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                      2025-09-24 22:25:19.890 - error: host.GartenIoB Caught by controller[25]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                      2025-09-24 22:25:19.890 - error: host.GartenIoB Caught by controller[25]: at Object.onceWrapper (node:events:639:26)
                                      2025-09-24 22:25:19.890 - error: host.GartenIoB Caught by controller[25]: at Socket.emit (node:events:524:28)
                                      2025-09-24 22:25:19.890 - error: host.GartenIoB Caught by controller[25]: at Socket.emit (node:domain:489:12)
                                      2025-09-24 22:25:19.891 - error: host.GartenIoB Caught by controller[25]: at TCP. (node:net:343:12)
                                      2025-09-24 22:25:19.891 - error: host.GartenIoB Caught by controller[26]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.891 - error: host.GartenIoB Caught by controller[27]: Error: DB closed
                                      2025-09-24 22:25:19.891 - error: host.GartenIoB Caught by controller[27]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                      2025-09-24 22:25:19.891 - error: host.GartenIoB Caught by controller[27]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                      2025-09-24 22:25:19.891 - error: host.GartenIoB Caught by controller[27]: at Object.onceWrapper (node:events:639:26)
                                      2025-09-24 22:25:19.891 - error: host.GartenIoB Caught by controller[27]: at Socket.emit (node:events:524:28)
                                      2025-09-24 22:25:19.891 - error: host.GartenIoB Caught by controller[27]: at Socket.emit (node:domain:489:12)
                                      2025-09-24 22:25:19.891 - error: host.GartenIoB Caught by controller[27]: at TCP. (node:net:343:12)
                                      2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[28]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[29]: Error: DB closed
                                      2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[29]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                      2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[29]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                      2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[29]: at Object.onceWrapper (node:events:639:26)
                                      2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[29]: at Socket.emit (node:events:524:28)
                                      2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[29]: at Socket.emit (node:domain:489:12)
                                      2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[29]: at TCP. (node:net:343:12)
                                      2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[30]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.892 - error: host.GartenIoB Caught by controller[31]: Error: DB closed
                                      2025-09-24 22:25:19.893 - error: host.GartenIoB Caught by controller[31]: at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                                      2025-09-24 22:25:19.893 - error: host.GartenIoB Caught by controller[31]: at Socket. (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                                      2025-09-24 22:25:19.893 - error: host.GartenIoB Caught by controller[31]: at Object.onceWrapper (node:events:639:26)
                                      2025-09-24 22:25:19.893 - error: host.GartenIoB Caught by controller[31]: at Socket.emit (node:events:524:28)
                                      2025-09-24 22:25:19.893 - error: host.GartenIoB Caught by controller[31]: at Socket.emit (node:domain:489:12)
                                      2025-09-24 22:25:19.893 - error: host.GartenIoB Caught by controller[31]: at TCP. (node:net:343:12)
                                      2025-09-24 22:25:19.893 - error: host.GartenIoB Caught by controller[32]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.893 - error: host.GartenIoB Caught by controller[33]: Error: DB closed
                                      2025-09-24 22:25:19.894 - error: host.GartenIoB Caught by controller[33]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                      2025-09-24 22:25:19.894 - error: host.GartenIoB Caught by controller[33]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                      2025-09-24 22:25:19.894 - error: host.GartenIoB Caught by controller[33]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                                      2025-09-24 22:25:19.894 - error: host.GartenIoB Caught by controller[33]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                                      2025-09-24 22:25:19.894 - error: host.GartenIoB Caught by controller[33]: at processImmediate (node:internal/timers:485:21)
                                      2025-09-24 22:25:19.894 - error: host.GartenIoB Caught by controller[34]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.894 - error: host.GartenIoB Caught by controller[35]: Error: DB closed
                                      2025-09-24 22:25:19.894 - error: host.GartenIoB Caught by controller[35]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                      2025-09-24 22:25:19.895 - error: host.GartenIoB Caught by controller[35]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                      2025-09-24 22:25:19.895 - error: host.GartenIoB Caught by controller[35]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                                      2025-09-24 22:25:19.895 - error: host.GartenIoB Caught by controller[35]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                                      2025-09-24 22:25:19.895 - error: host.GartenIoB Caught by controller[35]: at processImmediate (node:internal/timers:485:21)
                                      2025-09-24 22:25:19.895 - error: host.GartenIoB Caught by controller[36]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.895 - error: host.GartenIoB Caught by controller[37]: Error: DB closed
                                      2025-09-24 22:25:19.895 - error: host.GartenIoB Caught by controller[37]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                      2025-09-24 22:25:19.895 - error: host.GartenIoB Caught by controller[37]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                      2025-09-24 22:25:19.896 - error: host.GartenIoB Caught by controller[37]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                                      2025-09-24 22:25:19.896 - error: host.GartenIoB Caught by controller[37]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                                      2025-09-24 22:25:19.896 - error: host.GartenIoB Caught by controller[37]: at processImmediate (node:internal/timers:485:21)
                                      2025-09-24 22:25:19.896 - error: host.GartenIoB Caught by controller[38]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.896 - error: host.GartenIoB Caught by controller[39]: Error: DB closed
                                      2025-09-24 22:25:19.896 - error: host.GartenIoB Caught by controller[39]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                      2025-09-24 22:25:19.896 - error: host.GartenIoB Caught by controller[39]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                      2025-09-24 22:25:19.896 - error: host.GartenIoB Caught by controller[39]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                                      2025-09-24 22:25:19.896 - error: host.GartenIoB Caught by controller[39]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                                      2025-09-24 22:25:19.897 - error: host.GartenIoB Caught by controller[39]: at processImmediate (node:internal/timers:485:21)
                                      2025-09-24 22:25:19.897 - error: host.GartenIoB Caught by controller[40]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.897 - error: host.GartenIoB Caught by controller[41]: Error: DB closed
                                      2025-09-24 22:25:19.897 - error: host.GartenIoB Caught by controller[41]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                      2025-09-24 22:25:19.897 - error: host.GartenIoB Caught by controller[41]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                      2025-09-24 22:25:19.897 - error: host.GartenIoB Caught by controller[41]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                                      2025-09-24 22:25:19.897 - error: host.GartenIoB Caught by controller[41]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                                      2025-09-24 22:25:19.897 - error: host.GartenIoB Caught by controller[41]: at processImmediate (node:internal/timers:485:21)
                                      2025-09-24 22:25:19.897 - error: host.GartenIoB Caught by controller[42]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.898 - error: host.GartenIoB Caught by controller[43]: Error: DB closed
                                      2025-09-24 22:25:19.898 - error: host.GartenIoB Caught by controller[43]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                      2025-09-24 22:25:19.898 - error: host.GartenIoB Caught by controller[43]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                      2025-09-24 22:25:19.898 - error: host.GartenIoB Caught by controller[43]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                                      2025-09-24 22:25:19.898 - error: host.GartenIoB Caught by controller[43]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                                      2025-09-24 22:25:19.899 - error: host.GartenIoB Caught by controller[43]: at processImmediate (node:internal/timers:485:21)
                                      2025-09-24 22:25:19.899 - error: host.GartenIoB Caught by controller[44]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.899 - error: host.GartenIoB Caught by controller[45]: Error: DB closed
                                      2025-09-24 22:25:19.899 - error: host.GartenIoB Caught by controller[45]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                      2025-09-24 22:25:19.899 - error: host.GartenIoB Caught by controller[45]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                      2025-09-24 22:25:19.899 - error: host.GartenIoB Caught by controller[45]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                                      2025-09-24 22:25:19.899 - error: host.GartenIoB Caught by controller[45]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                                      2025-09-24 22:25:19.900 - error: host.GartenIoB Caught by controller[45]: at processImmediate (node:internal/timers:485:21)
                                      2025-09-24 22:25:19.900 - error: host.GartenIoB Caught by controller[46]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.900 - error: host.GartenIoB Caught by controller[47]: Error: DB closed
                                      2025-09-24 22:25:19.900 - error: host.GartenIoB Caught by controller[47]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                      2025-09-24 22:25:19.901 - error: host.GartenIoB Caught by controller[47]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                      2025-09-24 22:25:19.901 - error: host.GartenIoB Caught by controller[47]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                                      2025-09-24 22:25:19.901 - error: host.GartenIoB Caught by controller[47]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                                      2025-09-24 22:25:19.901 - error: host.GartenIoB Caught by controller[47]: at processImmediate (node:internal/timers:485:21)
                                      2025-09-24 22:25:19.901 - error: host.GartenIoB Caught by controller[48]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.901 - error: host.GartenIoB Caught by controller[49]: Error: DB closed
                                      2025-09-24 22:25:19.902 - error: host.GartenIoB Caught by controller[49]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                      2025-09-24 22:25:19.902 - error: host.GartenIoB Caught by controller[49]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                      2025-09-24 22:25:19.902 - error: host.GartenIoB Caught by controller[49]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                                      2025-09-24 22:25:19.902 - error: host.GartenIoB Caught by controller[49]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                                      2025-09-24 22:25:19.902 - error: host.GartenIoB Caught by controller[49]: at processImmediate (node:internal/timers:485:21)
                                      2025-09-24 22:25:19.902 - error: host.GartenIoB Caught by controller[50]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.902 - error: host.GartenIoB Caught by controller[51]: Error: DB closed
                                      2025-09-24 22:25:19.903 - error: host.GartenIoB Caught by controller[51]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                      2025-09-24 22:25:19.903 - error: host.GartenIoB Caught by controller[51]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                      2025-09-24 22:25:19.903 - error: host.GartenIoB Caught by controller[51]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                                      2025-09-24 22:25:19.903 - error: host.GartenIoB Caught by controller[51]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                                      2025-09-24 22:25:19.903 - error: host.GartenIoB Caught by controller[51]: at processImmediate (node:internal/timers:485:21)
                                      2025-09-24 22:25:19.903 - error: host.GartenIoB Caught by controller[52]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.903 - error: host.GartenIoB Caught by controller[53]: Error: DB closed
                                      2025-09-24 22:25:19.903 - error: host.GartenIoB Caught by controller[53]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                      2025-09-24 22:25:19.904 - error: host.GartenIoB Caught by controller[53]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                      2025-09-24 22:25:19.904 - error: host.GartenIoB Caught by controller[53]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                                      2025-09-24 22:25:19.904 - error: host.GartenIoB Caught by controller[53]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                                      2025-09-24 22:25:19.904 - error: host.GartenIoB Caught by controller[53]: at processImmediate (node:internal/timers:485:21)
                                      2025-09-24 22:25:19.904 - error: host.GartenIoB Caught by controller[54]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.904 - error: host.GartenIoB Caught by controller[55]: Error: DB closed
                                      2025-09-24 22:25:19.904 - error: host.GartenIoB Caught by controller[55]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                      2025-09-24 22:25:19.904 - error: host.GartenIoB Caught by controller[55]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                      2025-09-24 22:25:19.905 - error: host.GartenIoB Caught by controller[55]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                                      2025-09-24 22:25:19.905 - error: host.GartenIoB Caught by controller[55]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                                      2025-09-24 22:25:19.905 - error: host.GartenIoB Caught by controller[55]: at processImmediate (node:internal/timers:485:21)
                                      2025-09-24 22:25:19.905 - error: host.GartenIoB Caught by controller[56]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.905 - error: host.GartenIoB Caught by controller[57]: Error: DB closed
                                      2025-09-24 22:25:19.905 - error: host.GartenIoB Caught by controller[57]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                      2025-09-24 22:25:19.905 - error: host.GartenIoB Caught by controller[57]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                      2025-09-24 22:25:19.905 - error: host.GartenIoB Caught by controller[57]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                                      2025-09-24 22:25:19.906 - error: host.GartenIoB Caught by controller[57]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                                      2025-09-24 22:25:19.906 - error: host.GartenIoB Caught by controller[57]: at processImmediate (node:internal/timers:485:21)
                                      2025-09-24 22:25:19.906 - error: host.GartenIoB Caught by controller[58]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.906 - error: host.GartenIoB Caught by controller[59]: Error: DB closed
                                      2025-09-24 22:25:19.906 - error: host.GartenIoB Caught by controller[59]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                      2025-09-24 22:25:19.906 - error: host.GartenIoB Caught by controller[59]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                      2025-09-24 22:25:19.906 - error: host.GartenIoB Caught by controller[59]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                                      2025-09-24 22:25:19.906 - error: host.GartenIoB Caught by controller[59]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                                      2025-09-24 22:25:19.907 - error: host.GartenIoB Caught by controller[59]: at processImmediate (node:internal/timers:485:21)
                                      2025-09-24 22:25:19.907 - error: host.GartenIoB Caught by controller[60]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.907 - error: host.GartenIoB Caught by controller[61]: Error: DB closed
                                      2025-09-24 22:25:19.907 - error: host.GartenIoB Caught by controller[61]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                      2025-09-24 22:25:19.907 - error: host.GartenIoB Caught by controller[61]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                      2025-09-24 22:25:19.907 - error: host.GartenIoB Caught by controller[61]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                                      2025-09-24 22:25:19.907 - error: host.GartenIoB Caught by controller[61]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                                      2025-09-24 22:25:19.907 - error: host.GartenIoB Caught by controller[61]: at processImmediate (node:internal/timers:485:21)
                                      2025-09-24 22:25:19.908 - error: host.GartenIoB Caught by controller[62]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.908 - error: host.GartenIoB Caught by controller[63]: Error: DB closed
                                      2025-09-24 22:25:19.908 - error: host.GartenIoB Caught by controller[63]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                      2025-09-24 22:25:19.908 - error: host.GartenIoB Caught by controller[63]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                      2025-09-24 22:25:19.908 - error: host.GartenIoB Caught by controller[63]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                                      2025-09-24 22:25:19.908 - error: host.GartenIoB Caught by controller[63]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                                      2025-09-24 22:25:19.908 - error: host.GartenIoB Caught by controller[63]: at processImmediate (node:internal/timers:485:21)
                                      2025-09-24 22:25:19.908 - error: host.GartenIoB Caught by controller[64]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.909 - error: host.GartenIoB Caught by controller[65]: Error: DB closed
                                      2025-09-24 22:25:19.909 - error: host.GartenIoB Caught by controller[65]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                      2025-09-24 22:25:19.909 - error: host.GartenIoB Caught by controller[65]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                      2025-09-24 22:25:19.909 - error: host.GartenIoB Caught by controller[65]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                                      2025-09-24 22:25:19.909 - error: host.GartenIoB Caught by controller[65]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                                      2025-09-24 22:25:19.909 - error: host.GartenIoB Caught by controller[65]: at processImmediate (node:internal/timers:485:21)
                                      2025-09-24 22:25:19.909 - error: host.GartenIoB Caught by controller[66]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
                                      2025-09-24 22:25:19.910 - error: host.GartenIoB Caught by controller[67]: Error: DB closed
                                      2025-09-24 22:25:19.910 - error: host.GartenIoB Caught by controller[67]: at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:636:24)
                                      2025-09-24 22:25:19.910 - error: host.GartenIoB Caught by controller[67]: at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:121:25)
                                      2025-09-24 22:25:19.910 - error: host.GartenIoB Caught by controller[67]: at ObjectsInRedisClient._getObject (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3011:37)
                                      2025-09-24 22:25:19.910 - error: host.GartenIoB Caught by controller[67]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-objects-redis/src/lib/objects/objectsInRedisClient.ts:3070:29)
                                      2025-09-24 22:25:19.910 - error: host.GartenIoB Caught by controller[67]: at processImmediate (node:internal/timers:485:21)
                                      2025-09-24 22:25:19.910 - error: host.GartenIoB instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                      2025-09-24 22:25:19.911 - info: host.GartenIoB Restart adapter system.adapter.zigbee.0 because enabled
                                      2025-09-24 22:25:19.911 - warn: host.GartenIoB Do not restart adapter system.adapter.zigbee.0 because restart loop detected
                                      2025-09-24 22:25:25.285 - info: host.GartenIoB "system.adapter.zigbee.0" disabled
                                      ioBroker- NUC8i3 / Proxmox / VM
                                      Node.js v22.21.0
                                      NPM v10.9.4
                                      JS controller 7.1.0
                                      Admin 7.7.20
                                      ZigBee Adapter 3.3.1alpha.0
                                      Zigbee LAN Gateway CC2652P
                                      Zigbee Firmware 20250321
                                      • D dimaiv
                                        @asgothian
                                        AsgothianA Offline
                                        AsgothianA Offline
                                        Asgothian
                                        #162
                                        @dimaiv Log bitte. Bei mir läuft der (sowohl auf dem Testsystem als auch auf dem Produktivsystem)
                                        • AsgothianA Asgothian
                                          dimaiv
                                          #163
                                          @asgothian
                                          Oben eingefügt.
                                          Node.js v22.21.0
                                          NPM v10.9.4
                                          JS controller 7.1.0
                                          Admin 7.7.20
