  4. Adapter lassen sich nicht updaten
    4.5k
14 Beiträge 3 Kommentatoren 784 Aufrufe 4 Watching
  • F Offline
    Feinfinger
    Ich habe das Problem das sich mehrer Adapter nicht mehr updaten lassen.
    Hie rmal exemplarisch der Goove Adapter, die Fehlermeldungen bei den anderen Adaptern sehen ähnlich aus. Sieht mir nach npm aus.
    Vielleicht hat ja jemand ne Idee, was man da machen kann.
    $ iobroker upgrade govee-local@0.2.9
    Update govee-local from @0.2.8 to @0.2.9
    NPM version: 10.9.3
    Installing iobroker.govee-local@0.2.9... (System call)
    npm error code 7npm error path /opt/iobroker/node_modules/@stoprocent/noblenpm error command failednpm error command sh -c node-gyp-buildnpm error (node:14998) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.npm error (Use `node --trace-deprecation ...` to show where the warning was created)npm error gyp ERR! UNCAUGHT EXCEPTION npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm error gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm error gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm error gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)npm error gyp ERR! System Linux 6.14.11-1-pvenpm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblenpm error gyp ERR! node -v v22.19.0npm error gyp ERR! node-gyp -v v7.1.2npm error gyp ERR! Node-gyp failed to build your package.npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-18T05_32_13_126Z-debug-0.log
    host.ioBroker Cannot install iobroker.govee-local@0.2.9: 7
    ERROR: Process exited with code 25
    iob als LXC im Proxmox
    Node.js: v22.19.0
    NPM: 10.9.3
    js-controller 7.0.7
    • F Feinfinger
      NPM version: 10.9.3
      haus-automatisierungH Online
      @feinfinger sagte in Adapter lassen sich nicht updaten:
      Einmal den ioBroker Fixer laufen lassen und nochmal das Update anstoßen
      F 1 Antwort Letzte Antwort
        Feinfinger
        @haus-automatisierung
        Danke für die Antwort, leider bleibt der Fehler.
        Node.js: v22.19.0
        NPM: 10.9.3
        js-controller 7.0.7
        • F Feinfinger
          @feinfinger
          Dann schau dir das ganze Konstrukt an. Per
          iob diag
          am besten.
            @feinfinger
            iob diag
            am besten.
            Feinfinger
            Guten Morgen,
            Hier die Ausgabe von iob diag.
            ```bash
            Script v.2025-08-09
            *** BASE SYSTEM ***
            Operating System: Ubuntu 24.04.3 LTS
             Static hostname: ioBroker
                   Icon name: computer-container
                     Chassis: container ☐
              Virtualization: lxc
                      Kernel: Linux 6.14.11-1-pve
                Architecture: x86-64
            OS is similar to: debian
            model name      : 13th Gen Intel(R) Core(TM) i5-1340P
            Docker          : false
            Virtualization  : lxc
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             06:45:07 up 23:05,  0 user,  load average: 0.46, 1.46, 1.10
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Operating System is the current Ubuntu LTS release codenamed 'noble'!
            *** TIME AND TIMEZONES ***
                           Local time: Fri 2025-09-19 06:45:07 CEST
                       Universal time: Fri 2025-09-19 04:45:07 UTC
                             RTC time: n/a
                          NTP service: inactive
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            smarthome
            HOME=/home/smarthome
            GROUPS=smarthome sudo iobroker
            js-controller is not running
            *** DISPLAY-SERVER SETUP ***
            Display-Server:         false
            Unit display-manager.service could not be found.
            Display-Manager:
            Desktop:
            Session:
            *** MEMORY ***
            Mem:            8.6G         47M        6.1G        139K        2.4G        8.5G
            Swap:             0B          0B          0B
            Total:          8.6G         47M        6.1G
            Active iob-Instances:   1
                     8192 M total memory
                       45 M used memory
                      156 M active memory
                     1938 M inactive memory
                     5833 M free memory
                        0 M buffer memory
                     2313 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            top - 06:45:08 up 23:05,  0 user,  load average: 0.46, 1.46, 1.10
            Tasks:  30 total,   1 running,  29 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   8192.0 total,   5832.3 free,     46.7 used,   2313.1 buff/cache
            MiB Swap:      0.0 total,      0.0 free,      0.0 used.   8145.3 avail Mem
            *** FAILED SERVICES ***
              UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
            * run-rpc_pipefs.mount    loaded failed failed RPC Pipe File System
            * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
            * iobroker.service        loaded failed failed ioBroker Server
            Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                    ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                    SUB    -> The low-level unit activation state, values depend on unit type.
            3 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            dmesg: read kernel buffer failed: Operation not permitted
            No critical errors detected
            *** FILESYSTEM ***
            Filesystem                       Type      Size  Used Avail Use% Mounted on
            /dev/mapper/pve-vm--114--disk--0 ext4       16G   12G  3.2G  79% /
            none                             tmpfs     492K  4.0K  488K   1% /dev
            efivarfs                         efivarfs  192K  113K   75K  60% /sys/firmware/efi/efivars
            tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
            tmpfs                            tmpfs     6.2G  132K  6.2G   1% /run
            tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
            Show mounted filesystems:
            TARGET SOURCE                           FSTYPE OPTIONS
            /      /dev/mapper/pve-vm--114--disk--0 ext4   rw,relatime,stripe=16
            /var:
            3.2G    /var/
            1.6G    /var/log/journal/db91a8d9813048b3b0d9627361bf92a2
            1.6G    /var/log
            1.3G    /var/cache/apt
            Archived and active journals take up 90.2M in the file system.
            /opt/iobroker/backups:
            353M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            699M    /opt/iobroker/iobroker-data/
            386M    /opt/iobroker/iobroker-data/files
            236M    /opt/iobroker/iobroker-data/backup-objects
            48M     /opt/iobroker/iobroker-data/files/iot.admin
            47M     /opt/iobroker/iobroker-data/files/vis-2
            38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
            30M     /opt/iobroker/iobroker-data/files/notification-manager.admin/build/index.js.map
            28M     /opt/iobroker/iobroker-data/objects.jsonl
            24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
            22M     /opt/iobroker/iobroker-data/objects.json.migrated
            USB-Devices by-id:
            No Devices found 'by-id'
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v22.19.0
            /usr/bin/node           v22.19.0
            /usr/bin/npm            10.9.3
            /usr/bin/npx            10.9.3
            /usr/bin/corepack       0.34.0
            nodejs:
              Installed: 22.19.0-1nodesource1
              Candidate: 22.19.0-1nodesource1
              Version table:
             *** 22.19.0-1nodesource1 1001
                 22.18.0-1nodesource1 1001
                 22.17.1-1nodesource1 1001
                 22.17.0-1nodesource1 1001
                 22.16.0-1nodesource1 1001
                 22.15.1-1nodesource1 1001
                 22.15.0-1nodesource1 1001
                 22.14.0-1nodesource1 1001
                 22.13.1-1nodesource1 1001
                 22.13.0-1nodesource1 1001
                 22.12.0-1nodesource1 1001
                 22.11.0-1nodesource1 1001
                 22.10.0-1nodesource1 1001
                 22.9.0-1nodesource1 1001
                 22.8.0-1nodesource1 1001
                 22.7.0-1nodesource1 1001
                 22.6.0-1nodesource1 1001
                 22.5.1-1nodesource1 1001
                 22.5.0-1nodesource1 1001
                 22.4.1-1nodesource1 1001
                 22.4.0-1nodesource1 1001
                 22.3.0-1nodesource1 1001
                 22.2.0-1nodesource1 1001
                 22.1.0-1nodesource1 1001
                 22.0.0-1nodesource1 1001
                 18.19.1+dfsg-6ubuntu5 500
                    500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            iobroker is not running on this host.
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 481)
            Core adapters versions
            js-controller:  7.0.7
            admin:          7.7.2
            javascript:     8.9.2
            nodejs modules from github:     2
            |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
            | +-- syno@3.0.0 invalid: "git+https://git@github.com/MeisterTR/syno.git" from node_modules/iobroker.synology
            Adapter State
              system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
              system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 -  enabled
              system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
              system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
              system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
              system.adapter.ems-esp.0                : ems-esp               : ioBroker                                 -  enabled
              system.adapter.fhem.0                   : fhem                  : ioBroker                                 -  enabled, port: 7072
              system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
              system.adapter.govee-local.0            : govee-local           : ioBroker                                 -  enabled
              system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
              system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
              system.adapter.homekit-controller.0     : homekit-controller    : ioBroker                                 - disabled
              system.adapter.husqvarna-automower.0    : husqvarna-automower   : ioBroker                                 -  enabled
              system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
              system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
              system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
              system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
              system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
              system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
              system.adapter.modbus.1                 : modbus                : ioBroker                                 -  enabled
              system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
              system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
              system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
              system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
              system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
              system.adapter.sonoff.0                 : sonoff                : ioBroker                                 - disabled, port: 1883, bind: 192.168.178.61
              system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
              system.adapter.tado.0                   : tado                  : ioBroker                                 -  enabled
              system.adapter.telegram.0               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
              system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
              system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
              system.adapter.vis-plumb.0              : vis-plumb             : ioBroker                                 - disabled
              system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
              system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.178.61, run as: admin
              system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Adapters
            Used repository: stable
            Adapter    "admin"        : 7.7.2    , installed 7.7.2
            Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
            Adapter    "alias-manager": 2.0.0    , installed 2.0.0
            Adapter    "backitup"     : 3.3.5    , installed 3.3.5
            Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
            Adapter    "ems-esp"      : 6.0.0    , installed 6.0.0
            Adapter    "fhem"         : 3.0.0    , installed 3.0.0
            Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
            Adapter    "govee-local"  : 0.2.9    , installed 0.2.8  [Updatable]
            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
            Adapter    "homekit-controller": 0.5.11, installed 0.5.11
            Adapter    "ical"         : 1.16.2   , installed 1.16.2
            Adapter    "iot"          : 3.3.0    , installed 3.3.0
            Adapter    "javascript"   : 8.9.2    , installed 8.9.2
            Controller "js-controller": 7.0.7    , installed 7.0.7
            Adapter    "linux-control": 1.1.5    , installed 1.1.5
            Adapter    "modbus"       : 6.3.2    , installed 6.3.2
            Adapter    "mqtt"         : 6.1.4    , installed 6.1.2  [Updatable]
            Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
            Adapter    "notification-manager": 1.3.0, installed 1.3.0
            Adapter    "pushover"     : 4.1.0    , installed 4.1.0
            Adapter    "radar2"       : 2.4.0    , installed 2.4.0
            Adapter    "shelly"       : 10.1.0   , installed 10.1.0
            Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
            Adapter    "synology"     : 3.1.0    , installed 3.1.0
            Adapter    "tado"         : 0.7.10   , installed 0.7.10
            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
            Adapter    "vis-2"        : 2.13.4   , installed 2.13.4
            Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
            Adapter    "web"          : 7.0.8    , installed 7.0.9
            Adapter    "yahka"        : 1.1.5    , installed 1.1.5
            Objects and States
            Objects:        14243
            States:         11994
            Hit:1 https://deb.nodesource.com/node_22.x nodistro InRelease
            Hit:2 http://security.ubuntu.com/ubuntu noble-security InRelease
            Hit:3 http://archive.ubuntu.com/ubuntu noble InRelease
            Hit:4 http://archive.ubuntu.com/ubuntu noble-updates InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      102        133591972  231/systemd-resolve
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          133592326  441/master
            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      102        133591970  231/systemd-resolve
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          133581801  1/init
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          133587946  1/init
            tcp6       0      0 :::111                  :::*                    LISTEN      0          133581803  1/init
            tcp6       0      0 :::22                   :::*                    LISTEN      0          133587947  1/init
            tcp6       0      0 ::1:25                  :::*                    LISTEN      0          133592327  441/master
            udp        0      0 127.0.0.54:53           0.0.0.0:*                           102        133591971  231/systemd-resolve
            udp        0      0 127.0.0.53:53           0.0.0.0:*                           102        133591969  231/systemd-resolve
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          133581802  1/init
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        133594148  237/avahi-daemon: r
            udp        0      0 0.0.0.0:46786           0.0.0.0:*                           108        133594150  237/avahi-daemon: r
            udp6       0      0 :::47825                :::*                                108        133594151  237/avahi-daemon: r
            udp6       0      0 :::111                  :::*                                0          133581804  1/init
            udp6       0      0 :::5353                 :::*                                108        133594149  237/avahi-daemon: r
            2025-09-19 06:44:03.909  - info: discovery.0 (18819) Terminated (NO_ERROR): Without reason
            2025-09-19 06:44:03.910  - info: ems-esp.0 (18695) terminating
            2025-09-19 06:44:03.909  - info: notification-manager.0 (18757) Terminated (NO_ERROR): Without reason
            2025-09-19 06:44:03.910  - info: trashschedule.0 (18896) Terminated (NO_ERROR): Without reason
            2025-09-19 06:44:03.908  - info: govee-local.0 (18789) terminating
            2025-09-19 06:44:03.909  - info: govee-local.0 (18789) Terminated (NO_ERROR): Without reason
            2025-09-19 06:44:03.911  - info: ems-esp.0 (18695) Terminated (NO_ERROR): Without reason
            2025-09-19 06:44:03.909  - info: vis-2.0 (18881) Terminated (NO_ERROR): Without reason
            2025-09-19 06:44:04.325  - info: backitup.0 (18539) terminating
            2025-09-19 06:44:04.326  - info: pushover.0 (18506) terminating
            2025-09-19 06:44:04.327  - info: pushover.0 (18506) Terminated (NO_ERROR): Without reason
            2025-09-19 06:44:04.327  - info: synology.0 (18712) terminating
            2025-09-19 06:44:04.328  - info: modbus.0 (18680) terminating
            2025-09-19 06:44:04.328  - info: yahka.0 (18635) terminating
            2025-09-19 06:44:04.328  - info: modbus.1 (18727) terminating
            2025-09-19 06:44:04.329  - info: govee-local.0 (18789) terminating
            2025-09-19 06:44:04.329  - info: notification-manager.0 (18757) terminating
            2025-09-19 06:44:04.330  - info: vis-2.0 (18881) terminating
            2025-09-19 06:44:04.330  - info: discovery.0 (18819) terminating
            2025-09-19 06:44:04.331  - info: trashschedule.0 (18896) terminating
            2025-09-19 06:44:04.332  - info: radar2.0 (18599) terminating
            2025-09-19 06:44:04.338  - info: iot.0 (18834) terminating
            2025-09-19 06:44:04.338  - info: tado.0 (18944) terminating
            2025-09-19 06:44:04.935  - warn: host.ioBroker instance system.adapter.pushover.0 terminated due to SIGKILL
            2025-09-19 06:44:04.953  - warn: host.ioBroker instance system.adapter.web.0 terminated due to SIGKILL
            iob diag has finished.
            Wenn ich dann versuche, einen Adapter upzudaten, kommt dieses raus bei iob diag.
            Script v.2025-08-09
            *** BASE SYSTEM ***
              Virtualization: lxc
            Docker          : false
            Kernel          : x86_64
            Userland        : 64 bit
             06:51:59 up 23:12,  0 user,  load average: 2.50, 1.44, 1.13
            CPU threads: 4
                           Local time: Fri 2025-09-19 06:51:59 CEST
                       Universal time: Fri 2025-09-19 04:51:59 UTC
                             RTC time: n/a
                      RTC in local TZ: no
            smarthome
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev bluetooth
            Display-Manager:
            Desktop:
            Session:
            *** MEMORY ***
            Mem:            8.6G        2.3G        4.3G        143K        2.1G        6.3G
            Swap:             0B          0B          0B
            Total:          8.6G        2.3G        4.3G
            Active iob-Instances:   29
                     8192 M total memory
                     2146 M used memory
                     2214 M active memory
                     1557 M inactive memory
                     4090 M free memory
                        0 M buffer memory
                     1955 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            top - 06:51:59 up 23:12,  0 user,  load average: 2.50, 1.44, 1.13
            Tasks:  59 total,   1 running,  58 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni, 97.5 id,  0.0 wa,  0.0 hi,  2.5 si,  0.0 st
            MiB Mem :   8192.0 total,   4089.5 free,   2147.1 used,   1955.5 buff/cache
            MiB Swap:      0.0 total,      0.0 free,      0.0 used.   6044.9 avail Mem
            2 loaded units listed.
            *** FILESYSTEM ***
            tmpfs                            tmpfs     6.2G  136K  6.2G   1% /run
            /var:
            3.2G    /var/
            1.6G    /var/log
            1.3G    /var/cache/apt
            703M    /opt/iobroker/iobroker-data/
            31M     /opt/iobroker/iobroker-data/objects.jsonl
            USB-Devices by-id:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/npm            10.9.3
            /usr/bin/npx            10.9.3
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            ioBroker            ioBroker (version: 7.0.7, hostname: ioBroker      , alive, uptime: 286)
            admin:          7.7.2
            javascript:     8.9.2
            Adapter State
            + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
            + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
            + system.adapter.ems-esp.0                : ems-esp               : ioBroker                                 -  enabled
            + system.adapter.fhem.0                   : fhem                  : ioBroker                                 -  enabled, port: 7072
            + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
            + system.adapter.govee-local.0            : govee-local           : ioBroker                                 -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
            + system.adapter.husqvarna-automower.0    : husqvarna-automower   : ioBroker                                 -  enabled
            + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 8086
            + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
            + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
            + system.adapter.modbus.0                 : modbus                : ioBroker                                 -  enabled
            + system.adapter.modbus.1                 : modbus                : ioBroker                                 -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : ioBroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
            + system.adapter.pushover.0               : pushover              : ioBroker                                 -  enabled
            + system.adapter.radar2.0                 : radar2                : ioBroker                                 -  enabled
            + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
            + system.adapter.tado.0                   : tado                  : ioBroker                                 -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
            + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
            + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 192.168.178.61, run as: admin
            + system.adapter.yahka.0                  : yahka                 : ioBroker                                 -  enabled
            + instance is alive
            Objects and States
            Objects:        14243
            States:         12281
            Hit:1 http://archive.ubuntu.com/ubuntu noble InRelease
            Hit:2 http://archive.ubuntu.com/ubuntu noble-updates InRelease
            Hit:3 http://security.ubuntu.com/ubuntu noble-security InRelease
            Hit:4 https://deb.nodesource.com/node_22.x nodistro InRelease
            Pending Updates: 0
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       142103452  22357/iobroker.js-c
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       142127229  22357/iobroker.js-c
            tcp        0      0 192.168.178.61:42010    0.0.0.0:*               LISTEN      1000       142127710  22615/io.hm-rpc.0
            tcp        0      0 192.168.178.61:42001    0.0.0.0:*               LISTEN      1000       142129503  22695/io.hm-rpc.1
            tcp        0      0 0.0.0.0:37287           0.0.0.0:*               LISTEN      1000       142127662  22585/io.yahka.0
            tcp        0      0 127.0.0.1:36251         0.0.0.0:*               LISTEN      1000       142132584  22585/io.yahka.0
            tcp        0      0 192.168.178.61:8082     0.0.0.0:*               LISTEN      1000       142134977  22819/io.web.0
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1000       142129315  22600/io.shelly.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       142123634  22376/io.admin.0
            tcp6       0      0 :::3000                 :::*                    LISTEN      1000       142129231  22519/io.fullybrows
            udp        0      0 0.0.0.0:67              0.0.0.0:*                           1000       142127596  22549/io.radar2.0
            udp        0      0 0.0.0.0:4002            0.0.0.0:*                           1000       142128073  22742/io.govee-loca
            2025-09-19 06:51:43.283  - error: host.ioBroker iobroker npm error code 7npm error path /opt/iobroker/node_modules/@stoprocent/noblenpm error command failednpm error command sh -c node-gyp-buildnpm error (node:23128) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.npm error (Use `node --trace-deprecation ...` to show where the warning was created)npm error gyp ERR! UNCAUGHT EXCEPTION npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm error gyp ERR! stack     at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm error gyp ERR! stack     at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm error gyp ERR! stack     at FSReqCallback.oncomplete (node:fs:187:23)npm error gyp ERR! System Linux 6.14.11-1-pvenpm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblenpm error gyp ERR! node -v v22.19.0npm error gyp ERR! node-gyp -v v7.1.2npm error gyp ERR! Node-gyp failed to build your package.npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-19T04_49_25_414Z-debug-0.loghost.ioBroker Cannot install iobroker.govee-local@0.2.9: 7
            Node.js: v22.19.0
            NPM: 10.9.3
            js-controller 7.0.7
            • F Feinfinger
              Guten Morgen,
              ```bash
              Script v.2025-08-09
              *** BASE SYSTEM ***
                Virtualization: lxc
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
              CPU threads: 4
                               RTC time: n/a
                        RTC in local TZ: no
              smarthome
              Display-Manager:
              Desktop:
              Session:
              *** MEMORY ***
              Swap:             0B          0B          0B
                       8192 M total memory
                         45 M used memory
                        156 M active memory
                       5833 M free memory
                          0 M buffer memory
                       2313 M swap cache
                          0 M total swap
                          0 M used swap
                          0 M free swap
              *** FILESYSTEM ***
              /var:
              3.2G    /var/
              1.6G    /var/log
              1.3G    /var/cache/apt
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.9.3
              /usr/bin/npx            10.9.3
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.7.2
              javascript:     8.9.2
              Adapter State
              + instance is alive
              Objects and States
              Objects:        14243
              States:         11994
              Pending Updates: 0
              Script v.2025-08-09
              *** BASE SYSTEM ***
                Virtualization: lxc
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
              CPU threads: 4
                               RTC time: n/a
                        RTC in local TZ: no
              smarthome
              iobroker
              HOME=/home/iobroker
              Display-Manager:
              Desktop:
              Session:
              *** MEMORY ***
              Swap:             0B          0B          0B
                       8192 M total memory
                       2146 M used memory
                       4090 M free memory
                          0 M buffer memory
                       1955 M swap cache
                          0 M total swap
                          0 M used swap
                          0 M free swap
              *** FILESYSTEM ***
              /var:
              3.2G    /var/
              1.6G    /var/log
              1.3G    /var/cache/apt
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.9.3
              /usr/bin/npx            10.9.3
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.7.2
              javascript:     8.9.2
              Adapter State
              + instance is alive
              Objects and States
              Objects:        14243
              States:         12281
              Pending Updates: 0
              @feinfinger
              cd /opt/iobroker && npm ls noble
                @feinfinger
                Feinfinger
                @thomas-braun sagte in Adapter lassen sich nicht updaten:
                smarthome@ioBroker:~$ cd /opt/iobroker && npm ls noble
                [sudo] password for smarthome:
                iobroker.inst@2.0.3 /opt/iobroker
                `-- (empty)
                smarthome@ioBroker:/opt/iobroker$
                Node.js: v22.19.0
                NPM: 10.9.3
                js-controller 7.0.7
                • F Feinfinger
                  `-- (empty)
                  @feinfinger
                  Sorry, mein Fehler:
                  cd /opt/iobroker && npm ls @stoprocent/noble
                    @feinfinger
                    Sorry, mein Fehler:
                    Feinfinger
                    Was heißt hier sorry, ich bin so froh das es dich hier im Forum gibt :smiley:
                    smarthome@ioBroker:/opt/iobroker$ cd /opt/iobroker && npm ls @stoprocent/noble
                    +-- iobroker.homekit-controller@0.5.11
                    | `-- hap-controller@0.10.2
                    |   `-- @stoprocent/noble@1.19.1 deduped
                    `-- iobroker.radar2@2.4.0
                    Node.js: v22.19.0
                    NPM: 10.9.3
                    js-controller 7.0.7
                    • F Feinfinger
                      homekit-controller
                      radar2
                      installier die beiden Adapter mal neu.
                      F 2 Antworten Letzte Antwort
                        homekit-controller
                        radar2
                        Feinfinger
                        Radar2 lies sich ohne Probleme installieren, wenn ich den homekit-controller installieren möchte kommt dieser Fehler:
                        Weniger Protokolle
                        Detailliert
                        $ iobroker add homekit-controller --host ioBroker
                        Installing iobroker.homekit-controller@0.5.11... (System call)
                        npm error code 7npm error path /opt/iobroker/node_modules/@stoprocent/noblenpm error command failednpm error command sh -c node-gyp-buildnpm error (node:26743) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.npm error (Use `node --trace-deprecation ...` to show where the warning was created)npm error gyp ERR! UNCAUGHT EXCEPTION npm error gyp ERR! stack TypeError: Cannot assign to read only property 'cflags' of object '#<Object>'npm error gyp ERR! stack at createConfigFile (/opt/iobroker/node_modules/node-gyp/lib/configure.js:117:21)npm error gyp ERR! stack at /opt/iobroker/node_modules/node-gyp/lib/configure.js:84:9npm error gyp ERR! stack at FSReqCallback.oncomplete (node:fs:187:23)npm error gyp ERR! System Linux 6.14.11-1-pvenpm error gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm error gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noblenpm error gyp ERR! node -v v22.19.0npm error gyp ERR! node-gyp -v v7.1.2npm error gyp ERR! Node-gyp failed to build your package.npm error gyp ERR! Try to update npm and/or node-gyp and if it does not help file an issue with the package author.npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-09-19T06_33_43_583Z-debug-0.log
                        host.ioBroker Cannot install iobroker.homekit-controller@0.5.11: 7
                        Node.js: v22.19.0
                        NPM: 10.9.3
                        js-controller 7.0.7
                          homekit-controller
                          radar2
                          Feinfinger
                          Dafür lassen sich jetzt die anderen Adapter updaten.
                          Node.js: v22.19.0
                          NPM: 10.9.3
                          js-controller 7.0.7
                          • F Feinfinger
                            @feinfinger
                            Dann mach mal ein Issue drüben bei github für den homekit-controller auf.
                              @feinfinger
                              Feinfinger
                              Ok, hab ich gemacht.
                              Danke dir erstmal für deine Hilfe!
                              Node.js: v22.19.0
                              NPM: 10.9.3
                              js-controller 7.0.7
                              32.7k
                              82.5k
