  4. Kein öffnen von Iobroker oder Grafana möglich
    6.6k
grafana
56 Beiträge 6 Kommentatoren 5.7k Aufrufe 5 Beobachtet
    @sral74
    sudo apt update
    sudo apt full-upgrade
    sagt?
    Und auch mal rebooten:
    sudo reboot
    sral74
    @thomas-braun lars@iobroker:~
    ... ein paar errors tauchen auf (P.s.: wie kann consolen ausgaben/eingaben als seperaten Bereich hier ins forum Posten. also die schwarz hinterlegten Felder)
    $ sudo apt full-upgrade
    Reading package lists... Done
    Calculating upgrade... Done
    The following NEW packages will be installed:
      libdtovl0 libgpiolib0 linux-headers-6.12.34+rpt-common-rpi linux-headers-6.12.34+rpt-rpi-2712
      linux-headers-6.12.34+rpt-rpi-v8 linux-image-6.12.34+rpt-rpi-2712 linux-image-6.12.34+rpt-rpi-v8
      linux-kbuild-6.12.34+rpt
    The following packages will be upgraded:
      busybox debian-archive-keyring distro-info-data influxdb initramfs-tools initramfs-tools-core kms++-utils
      libabsl20220623 libavif15 libblockdev-crypto2 libblockdev-fs2 libblockdev-loop2 libblockdev-part-err2
      libblockdev-part2 libblockdev-swap2 libblockdev-utils2 libblockdev2 libc-l10n libcap2 libcap2-bin libgnutls30
      libgssapi-krb5-2 libk5crypto3 libkms++0 libkrb5-3 libkrb5support0 libpython3.11 libpython3.11-minimal
      libpython3.11-stdlib libqt5core5a libssl3 libudisks2-0 libwbclient0 libxml2 linux-headers-rpi-2712
      linux-headers-rpi-v8 linux-image-rpi-2712 linux-image-rpi-v8 locales net-tools openssh-client openssh-server
      openssh-sftp-server openssl pastebinit python3.11 python3.11-minimal python3.11-venv raspberrypi-sys-mods
      raspi-config raspi-firmware raspi-utils raspi-utils-core raspi-utils-dt raspi-utils-eeprom raspi-utils-otp raspinfo
      rpi-eeprom ssh sudo udisks2 wireless-regdb
    62 upgraded, 8 newly installed, 0 to remove and 0 not upgraded.
    Need to get 0 B/143 MB of archives.
    After this operation, 206 MB of additional disk space will be used.
    Do you want to continue? [Y/n] y
    Reading changelogs... Done
    Extracting templates from packages: 100%
    Preconfiguring packages ...
    (Reading database ... 82278 files and directories currently installed.)
    Preparing to unpack .../00-influxdb_1.11.8-2_arm64.deb ...
    Unpacking influxdb (1.11.8-2) over (1.6.7~rc0-1+b13) ...
    dpkg: error processing archive /tmp/apt-dpkg-install-6rVuF0/00-influxdb_1.11.8-2_arm64.deb (--unpack):
     trying to overwrite '/usr/bin/influx', which is also in package influxdb-client 1.6.7~rc0-1+b13
    dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
    Preparing to unpack .../01-libgssapi-krb5-2_1.20.1-2+deb12u3_arm64.deb ...
    Unpacking libgssapi-krb5-2:arm64 (1.20.1-2+deb12u3) over (1.20.1-2+deb12u2) ...
    Preparing to unpack .../02-libkrb5-3_1.20.1-2+deb12u3_arm64.deb ...
    Unpacking libkrb5-3:arm64 (1.20.1-2+deb12u3) over (1.20.1-2+deb12u2) ...
    Preparing to unpack .../03-libkrb5support0_1.20.1-2+deb12u3_arm64.deb ...
    Unpacking libkrb5support0:arm64 (1.20.1-2+deb12u3) over (1.20.1-2+deb12u2) ...
    Preparing to unpack .../04-libk5crypto3_1.20.1-2+deb12u3_arm64.deb ...
    Unpacking libk5crypto3:arm64 (1.20.1-2+deb12u3) over (1.20.1-2+deb12u2) ...
    Preparing to unpack .../05-libssl3_3.0.17-1~deb12u2+rpt1_arm64.deb ...
    Unpacking libssl3:arm64 (3.0.17-1~deb12u2+rpt1) over (3.0.16-1~deb12u1+rpt1) ...
    Preparing to unpack .../06-openssh-sftp-server_1%3a9.2p1-2+deb12u7_arm64.deb ...
    Unpacking openssh-sftp-server (1:9.2p1-2+deb12u7) over (1:9.2p1-2+deb12u5) ...
    Preparing to unpack .../07-openssh-server_1%3a9.2p1-2+deb12u7_arm64.deb ...
    Unpacking openssh-server (1:9.2p1-2+deb12u7) over (1:9.2p1-2+deb12u5) ...
    Preparing to unpack .../08-openssh-client_1%3a9.2p1-2+deb12u7_arm64.deb ...
    Unpacking openssh-client (1:9.2p1-2+deb12u7) over (1:9.2p1-2+deb12u5) ...
    Preparing to unpack .../09-python3.11-venv_3.11.2-6+deb12u6_arm64.deb ...
    Unpacking python3.11-venv (3.11.2-6+deb12u6) over (3.11.2-6+deb12u5) ...
    Preparing to unpack .../10-libpython3.11_3.11.2-6+deb12u6_arm64.deb ...
    Unpacking libpython3.11:arm64 (3.11.2-6+deb12u6) over (3.11.2-6+deb12u5) ...
    Preparing to unpack .../11-python3.11_3.11.2-6+deb12u6_arm64.deb ...
    Unpacking python3.11 (3.11.2-6+deb12u6) over (3.11.2-6+deb12u5) ...
    Preparing to unpack .../12-libpython3.11-stdlib_3.11.2-6+deb12u6_arm64.deb ...
    Unpacking libpython3.11-stdlib:arm64 (3.11.2-6+deb12u6) over (3.11.2-6+deb12u5) ...
    Preparing to unpack .../13-python3.11-minimal_3.11.2-6+deb12u6_arm64.deb ...
    Unpacking python3.11-minimal (3.11.2-6+deb12u6) over (3.11.2-6+deb12u5) ...
    Preparing to unpack .../14-libpython3.11-minimal_3.11.2-6+deb12u6_arm64.deb ...
    Unpacking libpython3.11-minimal:arm64 (3.11.2-6+deb12u6) over (3.11.2-6+deb12u5) ...
    Preparing to unpack .../15-raspi-firmware_1%3a1.20250430-4~bookworm_all.deb ...
    Unpacking raspi-firmware (1:1.20250430-4~bookworm) over (1:1.20250430-1) ...
    Preparing to unpack .../16-sudo_1.9.13p3-1+deb12u2_arm64.deb ...
    Unpacking sudo (1.9.13p3-1+deb12u2) over (1.9.13p3-1+deb12u1) ...
    Preparing to unpack .../17-debian-archive-keyring_2023.3+deb12u2_all.deb ...
    Unpacking debian-archive-keyring (2023.3+deb12u2) over (2023.3+deb12u1) ...
    Errors were encountered while processing:
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    • S sral74
      @sral74 sagte in Kein öffnen von Iobroker oder Grafana möglich:
      influxdb-client
      Der muss weg. Ist nicht kompatibel mit dem influxdb aus deren Repo.
      sudo apt remove influxdb-client
      Und die Ausgabe von
      sudo apt update
      möchte ich auch sehen.
        influxdb-client
        Und die Ausgabe von
        sudo apt update
        sral74
        $ sudo apt update
        Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:5 https://repos.influxdata.com/debian bookworm InRelease
        Hit:6 https://apt.grafana.com stable InRelease
        Hit:7 https://deb.nodesource.com/node_22.x nodistro InRelease
        45 packages can be upgraded. Run 'apt list --upgradable' to see them.
        • S sral74
          $ sudo apt update
          @sral74
          Ja, schmeiß influxdb-client raus.
          Siehe oben.
            @sral74
            Siehe oben.
            sral74
            schrieb am zuletzt editiert von sral74
            @thomas-braun hatte ich bereits ausgeführt
            nochmal?
            • S sral74
              nochmal?
              @sral74
              Dann nochmal
              sudo apt update
                @sral74
                Dann nochmal
                sudo apt update
                sral74
                Pending Updates: 0
                • S sral74
                  Pending Updates: 0
                  @sral74
                  Neugestartet?
                    @sral74
                    Neugestartet?
                    sral74
                    @thomas-braun Yepp
                    • S sral74
                      @thomas-braun Yepp
                      sral74
                      @sral74 Danke nochmals an alle für die Hilfe :-)
