  4. eCharts - Nach update auf 2.0.7 startet Instanz nicht mehr
    2.8k
    2.9k
28 Beiträge 10 Kommentatoren 2.8k Aufrufe 9 Beobachtet
  • D drapo
    Habs soeben installiert und scheint wieder alles zu funktionieren. Besten Dank für die rasche Hilfe.
    N Offline
    N Offline
    Norb 0
    schrieb am zuletzt editiert von Norb 0
    @drapo
    Nach dem update auf 2.0.7 startet die Instanz nicht mehr. Zurück auf 2.0.6 funktioniert auch nicht mehr.
    Adapter version: 2.0.7
    JS-Controller version: 7.0.7
    Node version: v20.19.4
    2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1651
    2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
    2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: ^
    2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: Error: libcairo.so.2: ELF load command address/offset not page-aligned
    2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: at Module._extensions..node (node:internal/modules/cjs/loader:1651:18)
    2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1275:32)
    2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1096:12)
    2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1298:19)
    2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: at require (node:internal/modules/helpers:182:18)
    2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.echarts/node_modules/canvas/lib/bindings.js:3:18)
    2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1529:14)
    2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1613:10)
    2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1096:12) {
    2025-08-17 10:48:26.238 - error: host.raspberrypi Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
    2025-08-17 10:48:26.239 - error: host.raspberrypi Caught by controller[0]: }
    2025-08-17 10:48:26.239 - error: host.raspberrypi Caught by controller[0]: Node.js v20.19.4
    2025-08-17 10:48:26.239 - error: host.raspberrypi instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    • N Norb 0
      @drapo
      @norb-0 sagte in eCharts - kein sendTo nach Upgrade auf Node.js 22.x:
      Wie sieht das System sonst aus? Alles aktuell?
      Mach das aber bitte in einem separaten Thread, zumal du ja auch kein nodejs@22 laufen hast...
      Die Ausgabe von
      iob diag
      hilft dann dort weiter.
        Die Ausgabe von
        iob diag
        mcm1957M Online
        mcm1957M Online
        mcm1957
        @Homoran
        Bitte ab
        https://forum.iobroker.net/topic/81902/echarts-kein-sendto-nach-upgrade-auf-node-js-22-x/6
        in neues Topic abspalten. Erspart duplizieren des existierenden Textes.
        Support Repositoryverwaltung.
        LESEN - gute Forenbeitrage
        • mcm1957M mcm1957
          @Homoran
          Bitte ab
          @mcm1957 erledigt!
          @Norb-0 bitte einen sinnvollen Threadtitel einfügen
          • N Offline
            N Offline
            Norb 0
            Nach dem update auf 2.0.7 startet die Instanz nicht mehr, alles andere funktioniert aber noch. Zurück auf 2.0.6 funktioniert auch nicht mehr.
            Das System ist up-to-date, iob diag zeigt keine Fehlermeldungen
            Tab Diagramme sowie Diagramme als solches funktionieren:
            LOG:
            2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: node:internal/modules/cjs/loader:1651
            2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
            2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: ^
            2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: Error: libcairo.so.2: ELF load command address/offset not page-aligned
            2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: at Module._extensions..node (node:internal/modules/cjs/loader:1651:18)
            2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1275:32)
            2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1096:12)
            2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1298:19)
            2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: at require (node:internal/modules/helpers:182:18)
            2025-08-17 12:05:57.038 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.echarts/node_modules/canvas/lib/bindings.js:3:18)
            2025-08-17 12:05:57.039 - error: host.raspberrypi Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1529:14)
            2025-08-17 12:05:57.039 - error: host.raspberrypi Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1613:10)
            2025-08-17 12:05:57.039 - error: host.raspberrypi Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1275:32)
            2025-08-17 12:05:57.039 - error: host.raspberrypi Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1096:12) {
            2025-08-17 12:05:57.039 - error: host.raspberrypi Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
            2025-08-17 12:05:57.039 - error: host.raspberrypi Caught by controller[0]: }
            2025-08-17 12:05:57.039 - error: host.raspberrypi Caught by controller[0]: Node.js v20.19.4
            2025-08-17 12:05:57.039 - error: host.raspberrypi instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            GarganoG 1 Antwort Letzte Antwort
            • N Norb 0
              LOG:
              GarganoG Offline
              GarganoG Offline
              Gargano
              @norb-0 Den Fehler hab ich auch (NodeJS 20.19.4)
              • GarganoG Gargano
                @gargano
                Dann solltest auch du die Ausgabe von
                iob diag
                bekannt geben. Ich hab da eine Vermutung.
                  @gargano
                  iob diag
                  GarganoG Offline
                  GarganoG Offline
                  Gargano
                  schrieb am zuletzt editiert von Gargano
                  @thomas-braun Hier kommt der Diag:
                  Am Ende ist der Fehler mit der fehlenden Lib :
                  2025-08-17 13:04:27.534  - error: host.pi5 Caught by controller[0]: }
                  2025-08-17 13:04:27.534  - error: host.pi5 Caught by controller[0]: Node.js v20.19.4
                  2025-08-17 13:04:27.534  - error: host.pi5 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2025-08-17 13:04:27.534  - info: host.pi5 Restart adapter system.adapter.echarts.0 because enabled
                  2025-08-17 13:04:32.757  - info: host.pi5 instance system.adapter.openweathermap.0 having pid 1501 terminated with code 0 (NO_ERROR)
                  2025-08-17 13:04:58.016  - info: host.pi5 instance system.adapter.echarts.0 in version "2.0.7" started with pid 2023
                  2025-08-17 13:04:58.673  - error: host.pi5 Caught by controller[0]: node:internal/modules/cjs/loader:1651
                  2025-08-17 13:04:58.673  - error: host.pi5 Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                  2025-08-17 13:04:58.673  - error: host.pi5 Caught by controller[0]:                  ^
                  2025-08-17 13:04:58.673  - error: host.pi5 Caught by controller[0]: Error: libcairo.so.2: ELF load command address/offset not page-aligned
                  2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:     at Module._extensions..node (node:internal/modules/cjs/loader:1651:18)
                  2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1275:32)
                  2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1096:12)
                  2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1298:19)
                  2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:     at require (node:internal/modules/helpers:182:18)
                  2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                  2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1529:14)
                  2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:     at Module._extensions..js (node:internal/modules/cjs/loader:1613:10)
                  2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:     at Module._load (node:internal/modules/cjs/loader:1096:12) {
                  2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                  2025-08-17 13:04:58.674  - error: host.pi5 Caught by controller[0]: }
                  2025-08-17 13:04:58.675  - error: host.pi5 Caught by controller[0]: Node.js v20.19.4
                  2025-08-17 13:04:58.675  - error: host.pi5 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  2025-08-17 13:04:58.675  - info: host.pi5 Restart adapter system.adapter.echarts.0 because enabled
                  Full Diag :
                  ```bash
                  Script v.2025-08-09
                  *** BASE SYSTEM ***
                  cat: /sys/devices/virtual/dmi/id/sys_vendor: No such file or directory
                  Hardware Vendor :
                  Kernel          : aarch64
                  Userland        : 64 bit
                  Docker          : v10.0.0
                  Virtualization  : docker
                  Kernel          : aarch64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   13:04:42 up  1:50,  0 user,  load average: 2.74, 2.92, 1.77
                  CPU threads: 4
                  *** LIFE CYCLE STATUS ***
                  Operating System is the current Debian stable version codenamed 'bookworm'!
                  *** TIME AND TIMEZONES ***
                  Sun Aug 17 11:04:42 UTC 2025
                  Sun Aug 17 13:04:42 CEST 2025
                  CEST +0200
                  Etc/UTC
                  *** Users and Groups ***
                  User that called 'iob diag':
                  root
                  HOME=/root
                  GROUPS=root
                  iobroker
                  HOME=/opt/iobroker
                  GROUPS=iobroker tty dialout audio video plugdev redis
                  *** DISPLAY-SERVER SETUP ***
                  Display-Server:         false
                  System has not been booted with systemd as init system (PID 1). Can't operate.
                  Failed to connect to bus: Host is down
                  Display-Manager:
                  Desktop:
                  Session:
                  *** MEMORY ***
                  Mem:            8.4G        5.6G        1.2G        6.9M        1.8G        2.9G
                  Swap:           536M          0B        536M
                  Total:          9.0G        5.6G        1.7G
                  Active iob-Instances:   50
                           8052 M total memory
                           5333 M used memory
                           4276 M active memory
                           1922 M inactive memory
                           1117 M free memory
                            194 M buffer memory
                           1511 M swap cache
                            511 M total swap
                              0 M used swap
                            511 M free swap
                  top - 13:04:42 up  1:50,  0 user,  load average: 2.74, 2.92, 1.77
                  Tasks:  56 total,   1 running,  55 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):100.0 us,  0.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   8052.2 total,   1116.0 free,   5335.5 used,   1706.0 buff/cache
                  MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2716.8 avail Mem
                  *** DMESG CRITICAL ERRORS ***
                  dmesg: read kernel buffer failed: Operation not permitted
                  No critical errors detected
                  *** FILESYSTEM ***
                  Filesystem     Type     Size  Used Avail Use% Mounted on
                  overlay        overlay  235G   17G  206G   8% /
                  tmpfs          tmpfs     64M     0   64M   0% /dev
                  shm            tmpfs     64M     0   64M   0% /dev/shm
                  /dev/nvme0n1p2 ext4     235G   17G  206G   8% /opt/iobroker
                  tmpfs          tmpfs    4.0G     0  4.0G   0% /proc/asound
                  tmpfs          tmpfs    4.0G     0  4.0G   0% /sys/firmware
                  Show mounted filesystems:
                  TARGET           SOURCE        FSTYPE OPTIONS
                  /opt/iobroker    /dev/nvme0n1p2[/var/lib/docker/volumes/43efbba1a752f74678556bf2b0336400ef9e9d821f4a314275ce1b3711f60faa/_data]          ext4   rw,noatime
                  /etc/resolv.conf /dev/nvme0n1p2[/var/lib/docker/containers/4bc415f1011bbaef2ba529cd04d3c4cc883fc803d9515710b18ff1341372b4e0/resolv.conf] ext4   rw,noatime
                  /etc/hostname    /dev/nvme0n1p2[/var/lib/docker/containers/4bc415f1011bbaef2ba529cd04d3c4cc883fc803d9515710b18ff1341372b4e0/hostname]    ext4   rw,noatime
                  /etc/hosts       /dev/nvme0n1p2[/var/lib/docker/containers/4bc415f1011bbaef2ba529cd04d3c4cc883fc803d9515710b18ff1341372b4e0/hosts]       ext4   rw,noatime
                  /var:
                  40M     /var/
                  38M     /var/lib
                  19M     /var/lib/dpkg
                  19M     /var/lib/apt/lists
                  19M     /var/lib/apt
                  /opt/iobroker/backups:
                  864M    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  192M    /opt/iobroker/iobroker-data/
                  176M    /opt/iobroker/iobroker-data/files
                  158M    /opt/iobroker/iobroker-data/files/admin.admin
                  157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                  16M     /opt/iobroker/iobroker-data/objects.jsonl
                  7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
                  7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
                  7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
                  7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map
                  USB-Devices by-id:
                  /dev/serial/by-id/zigbee
                  *** ZigBee Settings ***
                  Your zigbee.0 COM-Port is matching 'by-id'. Very good!
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  *** NodeJS-Installation ***
                  /usr/bin/nodejs         v20.19.4
                  /usr/bin/node           v20.19.4
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  /usr/bin/corepack       0.32.0
                  nodejs:
                    Installed: 20.19.4-1nodesource1
                    Candidate: 20.19.4-1nodesource1
                    Version table:
                   *** 20.19.4-1nodesource1 1001
                          500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                       20.19.3-1nodesource1 1001
                       20.19.2-1nodesource1 1001
                       20.19.1-1nodesource1 1001
                       20.19.0-1nodesource1 1001
                       20.18.3-1nodesource1 1001
                       20.18.2-1nodesource1 1001
                       20.18.1-1nodesource1 1001
                       20.18.0-1nodesource1 1001
                       20.17.0-1nodesource1 1001
                       20.16.0-1nodesource1 1001
                       20.15.1-1nodesource1 1001
                       20.15.0-1nodesource1 1001
                       20.14.0-1nodesource1 1001
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                       18.19.0+dfsg-6~deb12u2 500
                          500 http://deb.debian.org/debian bookworm/main arm64 Packages
                       18.19.0+dfsg-6~deb12u1 500
                          500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                  No problems detected
                  Errors in npm tree: 0
                  *** ioBroker-Installation ***
                  ioBroker Status
                  At least one iobroker host is running.
                  Objects type: redis
                  States  type: redis
                  Hosts:
                  pi5                 pi5 (version: 7.0.7, hostname: pi5           , alive, uptime: 256)
                  Core adapters versions
                  js-controller:  7.0.7
                  admin:          7.7.2
                  javascript:     9.0.11
                  nodejs modules from github:     2
                  +-- iobroker.ap-systems-ez1@0.1.0 (git+ssh://git@github.com/exne-soptim/ioBroker.ap-systems-ez1.git#2092ad28047ec7e726de2169c1148c1a9a84ff42)
                  | `-- bluelinky@9.1.0 (git+ssh://git@github.com/arteck/bluelinky.git#1525bcfa8e98338406bd8ec207c95d19d8ac1ba8)
                  Adapter State
                  + system.adapter.admin.0                  : admin                 : pi5                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.ap-systems-ez1.0         : ap-systems-ez1        : pi5                                      -  enabled, port: 8050
                  + system.adapter.backitup.0               : backitup              : pi5                                      -  enabled
                  + system.adapter.bluelink.0               : bluelink              : pi5                                      -  enabled
                  + system.adapter.broadlink2.0             : broadlink2            : pi5                                      -  enabled
                  + system.adapter.cloud.0                  : cloud                 : pi5                                      -  enabled
                  + system.adapter.cloudless-homeconnect.0  : cloudless-homeconnect : pi5                                      -  enabled
                    system.adapter.devices.0                : devices               : pi5                                      - disabled
                  + system.adapter.discovery.0              : discovery             : pi5                                      -  enabled
                  + system.adapter.e3dc-rscp.0              : e3dc-rscp             : pi5                                      -  enabled
                  + system.adapter.easee.0                  : easee                 : pi5                                      -  enabled
                    system.adapter.echarts.0                : echarts               : pi5                                      -  enabled
                  + system.adapter.fritzbox.0               : fritzbox              : pi5                                      -  enabled
                  + system.adapter.fullybrowser.0           : fullybrowser          : pi5                                      -  enabled
                  + system.adapter.heatingcontrol.0         : heatingcontrol        : pi5                                      -  enabled
                  + system.adapter.hm-rega.0                : hm-rega               : pi5                                      -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : pi5                                      -  enabled, port: 0
                  + system.adapter.hm-rpc.1                 : hm-rpc                : pi5                                      -  enabled, port: 0
                  + system.adapter.hm-rpc.2                 : hm-rpc                : pi5                                      -  enabled, port: 0
                  + system.adapter.hm-rpc.3                 : hm-rpc                : pi5                                      -  enabled, port: 0
                    system.adapter.ical.0                   : ical                  : pi5                                      -  enabled
                    system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: pi5                                      - disabled
                    system.adapter.icons-icons8.0           : icons-icons8          : pi5                                      - disabled
                    system.adapter.icons-material-png.0     : icons-material-png    : pi5                                      - disabled
                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : pi5                                      - disabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : pi5                                      - disabled
                    system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : pi5                                      - disabled
                  + system.adapter.influxdb.0               : influxdb              : pi5                                      -  enabled, port: 8086
                  + system.adapter.javascript.0             : javascript            : pi5                                      -  enabled
                  + system.adapter.javascript.1             : javascript            : pi5                                      -  enabled
                  + system.adapter.javascript.2             : javascript            : pi5                                      -  enabled
                  + system.adapter.javascript.3             : javascript            : pi5                                      -  enabled
                  + system.adapter.javascript.4             : javascript            : pi5                                      -  enabled
                  + system.adapter.lgtv.0                   : lgtv                  : pi5                                      -  enabled
                    system.adapter.meteoalarm.0             : meteoalarm            : pi5                                      -  enabled
                  + system.adapter.mielecloudservice.0      : mielecloudservice     : pi5                                      -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : pi5                                      -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.mqtt.1                   : mqtt                  : pi5                                      -  enabled, port: 1884, bind: 0.0.0.0
                  + system.adapter.mqtt.2                   : mqtt                  : pi5                                      - disabled, port: 1885, bind: 0.0.0.0
                  + system.adapter.mqtt.3                   : mqtt                  : pi5                                      -  enabled, port: 1890, bind: 0.0.0.0
                  + system.adapter.mqtt.4                   : mqtt                  : pi5                                      -  enabled, port: 1892, bind: 192.168.178.35
                  + system.adapter.mqtt.5                   : mqtt                  : pi5                                      -  enabled, port: 1889, bind: 0.0.0.0
                    system.adapter.mqtt.6                   : mqtt                  : pi5                                      - disabled, port: 1895, bind: 0.0.0.0
                  + system.adapter.onvif.0                  : onvif                 : pi5                                      -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
                    system.adapter.openweathermap.0         : openweathermap        : pi5                                      -  enabled
                  + system.adapter.pushover.0               : pushover              : pi5                                      -  enabled
                  + system.adapter.pushover.1               : pushover              : pi5                                      -  enabled
                  + system.adapter.resol.0                  : resol                 : pi5                                      -  enabled
                  + system.adapter.rest-api.0               : rest-api              : pi5                                      -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
                  + system.adapter.rpi2.0                   : rpi2                  : pi5                                      -  enabled
                  + system.adapter.scenes.0                 : scenes                : pi5                                      -  enabled
                  + system.adapter.simple-api.0             : simple-api            : pi5                                      -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                    system.adapter.tapo.0                   : tapo                  : pi5                                      - disabled
                  + system.adapter.telegram.0               : telegram              : pi5                                      -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.tibberlink.0             : tibberlink            : pi5                                      -  enabled
                  + system.adapter.tr-064.0                 : tr-064                : pi5                                      -  enabled
                  + system.adapter.trashschedule.0          : trashschedule         : pi5                                      -  enabled
                    system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: pi5                                      - disabled
                    system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : pi5                                      - disabled
                    system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : pi5                                      - disabled
                    system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: pi5                                      - disabled
                    system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: pi5                                      - disabled
                    system.adapter.vis-2-widgets-ovarious.0 : vis-2-widgets-ovarious: pi5                                      - disabled
                    system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: pi5                                      - disabled
                  + system.adapter.vis-2.0                  : vis-2                 : pi5                                      -  enabled
                    system.adapter.vis-bars.0               : vis-bars              : pi5                                      - disabled
                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : pi5                                      - disabled
                    system.adapter.vis-google-fonts.0       : vis-google-fonts      : pi5                                      -  enabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : pi5                                      - disabled
                    system.adapter.vis-icontwo.0            : vis-icontwo           : pi5                                      - disabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : pi5                                      - disabled
                    system.adapter.vis-justgage.0           : vis-justgage          : pi5                                      - disabled
                    system.adapter.vis-material-advanced.0  : vis-material-advanced : pi5                                      - disabled
                    system.adapter.vis-material.0           : vis-material          : pi5                                      - disabled
                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : pi5                                      - disabled
                    system.adapter.vis-metro.0              : vis-metro             : pi5                                      - disabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : pi5                                      - disabled
                    system.adapter.vis.0                    : vis                   : pi5                                      -  enabled
                  + system.adapter.web.0                    : web                   : pi5                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.wiffi-wz.0               : wiffi-wz              : pi5                                      -  enabled
                  + system.adapter.worx.0                   : worx                  : pi5                                      -  enabled
                  + system.adapter.zigbee.0                 : zigbee                : pi5                                      -  enabled, port: /dev/serial/by-id/zigbee
                  + instance is alive
                  ioBroker-Repositories
                  │ (index) │ name               │ url                                                     │ auto upgrade │
                  │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
                  │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                  │ 2       │ 'Live (stable)'    │ 'http://repo.iobroker.live/sources-dist.json'           │ false        │
                  │ 3       │ 'Live (latest)'    │ 'http://repo.iobroker.live/sources-dist-latest.json'    │ false        │
                  Active repo(s): Beta (latest)
                  Upgrade policy: none
                  Installed ioBroker-Adapters
                  Used repository: Beta (latest)
                  Adapter    "admin"        : 7.7.2    , installed 7.7.2
                  Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                  Adapter    "bluelink"     : 3.1.20   , installed 3.1.20
                  Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
                  Adapter    "cloudless-homeconnect": 1.6.2, installed 1.6.2
                  Adapter    "devices"      : 1.2.8    , installed 1.2.8
                  Adapter    "e3dc-rscp"    : 1.4.2    , installed 1.4.2
                  Adapter    "easee"        : 1.0.10   , installed 1.0.10
                  Adapter    "echarts"      : 2.0.7    , installed 2.0.7
                  Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                  Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                  Adapter    "heatingcontrol": 2.12.15 , installed 2.12.15
                  Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                  Adapter    "ical"         : 1.16.2   , installed 1.16.2
                  Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
                  Adapter    "javascript"   : 9.0.11   , installed 9.0.11
                  Controller "js-controller": 7.0.7    , installed 7.0.7
                  Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
                  Adapter    "meteoalarm"   : 4.0.1    , installed 4.0.1
                  Adapter    "mielecloudservice": 6.5.11, installed 6.5.11
                  Adapter    "onvif"        : 1.1.4    , installed 1.1.4
                  Adapter    "openweathermap": 1.4.0   , installed 1.4.0
                  Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                  Adapter    "resol"        : 1.5.1    , installed 1.5.1
                  Adapter    "rest-api"     : 3.0.1    , installed 3.0.1
                  Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                  Adapter    "scenes"       : 4.0.3    , installed 4.0.3
                  Adapter    "simple-api"   : 3.0.7    , installed 3.0.7
                  Adapter    "socketio"     : 7.0.8    , installed 7.0.8
                  Adapter    "tapo"         : 0.4.8    , installed 0.4.8
                  Adapter    "tibberlink"   : 5.0.1    , installed 5.0.1
                  Adapter    "trashschedule": 4.0.1    , installed 4.0.1
                  Adapter    "vis-2"        : 2.12.12  , installed 2.12.12
                  Adapter    "vis-2-widgets-collection": 1.8.1, installed 1.8.1
                  Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                  Adapter    "vis-2-widgets-gauges": 2.0.1, installed 2.0.1
                  Adapter    "vis-2-widgets-inventwo": 0.3.5, installed 0.3.5
                  Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                  Adapter    "vis-2-widgets-ovarious": 1.0.0, installed 1.0.0
                  Adapter    "vis-2-widgets-weather-and-heating": 1.1.1, installed 1.1.1
                  Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
                  Adapter    "vis-material" : 0.2.0    , installed 0.2.0
                  Adapter    "web"          : 7.0.9    , installed 7.0.9
                  Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
                  Adapter    "worx"         : 3.2.7    , installed 3.2.7
                  Adapter    "ws"           : 3.0.19   , installed 3.0.19
                  Adapter    "zigbee"       : 3.0.3    , installed 3.0.3
                  Objects and States
                  Objects:        16625
                  States:         13444
                  Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                  Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
                  Hit:4 https://repos.influxdata.com/debian stable InRelease
                  Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      0          8484       -
                  tcp        0      0 192.168.178.35:2001     0.0.0.0:*               LISTEN      1000       107648     -
                  tcp        0      0 192.168.178.35:2000     0.0.0.0:*               LISTEN      1000       107668     -
                  tcp        0      0 192.168.178.35:2010     0.0.0.0:*               LISTEN      1000       106491     -
                  tcp        0      0 192.168.178.35:1892     0.0.0.0:*               LISTEN      1000       109716     -
                  tcp        0      0 0.0.0.0:8000            0.0.0.0:*               LISTEN      0          8395       -
                  tcp        0      0 192.168.178.35:8701     0.0.0.0:*               LISTEN      1000       107743     -
                  tcp        0      0 0.0.0.0:8086            0.0.0.0:*               LISTEN      0          9448       -
                  tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      0          8449       -
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5017       -
                  tcp        0      0 192.168.178.35:8181     0.0.0.0:*               LISTEN      1000       109317     -
                  tcp        0      0 0.0.0.0:1890            0.0.0.0:*               LISTEN      1000       107428     -
                  tcp        0      0 0.0.0.0:1891            0.0.0.0:*               LISTEN      1000       107429     -
                  tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1000       107495     -
                  tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       108745     -
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       107869     -
                  tcp        0      0 0.0.0.0:9443            0.0.0.0:*               LISTEN      0          8397       -
                  tcp6       0      0 :::3000                 :::*                    LISTEN      1000       107126     -
                  tcp6       0      0 :::6379                 :::*                    LISTEN      0          8485       -
                  tcp6       0      0 :::8000                 :::*                    LISTEN      0          8396       -
                  tcp6       0      0 :::8095                 :::*                    LISTEN      1000       108332     -
                  tcp6       0      0 :::8093                 :::*                    LISTEN      1000       109192     -
                  tcp6       0      0 :::8086                 :::*                    LISTEN      0          9449       -
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1000       108390     -
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1000       110330     -
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1000       103915     -
                  tcp6       0      0 :::9001                 :::*                    LISTEN      0          8450       -
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          5019       -
                  tcp6       0      0 :::8554                 :::*                    LISTEN      0          6504       -
                  tcp6       0      0 :::8555                 :::*                    LISTEN      0          6524       -
                  tcp6       0      0 :::1984                 :::*                    LISTEN      0          9416       -
                  tcp6       0      0 :::9443                 :::*                    LISTEN      0          8398       -
                  udp        0      0 0.0.0.0:57160           0.0.0.0:*                           1000       104231     -
                  udp        0      0 192.168.178.35:8555     0.0.0.0:*                           0          6536       -
                  udp        0      0 172.17.0.1:5353         0.0.0.0:*                           1000       110883     -
                  udp        0      0 172.18.0.1:5353         0.0.0.0:*                           1000       110882     -
                  udp        0      0 192.168.178.35:5353     0.0.0.0:*                           1000       110881     -
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5730       -
                  udp        0      0 0.0.0.0:54812           0.0.0.0:*                           104        5732       -
                  udp        0      0 0.0.0.0:46994           0.0.0.0:*                           1000       104227     -
                  udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1000       104225     -
                  udp6       0      0 fe80::2f63:151f:218:546 :::*                                0          8592       -
                  udp6       0      0 :::53860                :::*                                104        5733       -
                  udp6       0      0 :::5353                 :::*                                104        5731       -
                  iob diag has finished.
                  root@pi5:/opt/iobroker#
                  • GarganoG Gargano
                    Full Diag :
                    ```bash
                    Script v.2025-08-09
                    *** BASE SYSTEM ***
                    Hardware Vendor :
                    Kernel          : aarch64
                    Userland        : 64 bit
                    Docker          : v10.0.0
                    Kernel          : aarch64
                    Userland        : 64 bit
                    CPU threads: 4
                    CEST +0200
                    Etc/UTC
                    root
                    HOME=/root
                    GROUPS=root
                    iobroker
                    HOME=/opt/iobroker
                    Display-Manager:
                    Desktop:
                    Session:
                    *** MEMORY ***
                    Swap:           536M          0B        536M
                             8052 M total memory
                             5333 M used memory
                             1117 M free memory
                              194 M buffer memory
                             1511 M swap cache
                              511 M total swap
                                0 M used swap
                              511 M free swap
                    *** FILESYSTEM ***
                    /var:
                    40M     /var/
                    38M     /var/lib
                    19M     /var/lib/dpkg
                    19M     /var/lib/apt
                    USB-Devices by-id:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    nodejs:
                      Version table:
                    ioBroker Status
                    Objects type: redis
                    States  type: redis
                    Hosts:
                    admin:          7.7.2
                    javascript:     9.0.11
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        16625
                    States:         13444
                    Pending Updates: 0
                    @gargano sagte in eCharts - Nach update auf 2.0.7 startet Instanz nicht mehr:
                    Docker : v10.0.0
                    Da bin ich raus. Gibt es nicht mittlerweile v11.x.y ?
                      Docker : v10.0.0
                      GarganoG Offline
                      GarganoG Offline
                      Gargano
                      @thomas-braun Wie erklärst Du Dir den Fehler am Schluss ?
                      • GarganoG Gargano
                        Keine Ahnung. Von Docker lass ich die Finger.
                        • GarganoG Offline
                          GarganoG Offline
                          Gargano
                          @thomas-braun sagte in eCharts - Nach update auf 2.0.7 startet Instanz nicht mehr:
                          Ok, Danke trotzdem.
                          Ich vermute mal , es liegt am etwas älteren Nodejs. (V20.x)
                          Mal schauen, ob ich auf Docker V11 wechseln muß.
                          C 1 Antwort Letzte Antwort
                          • GarganoG Gargano
                            Ok, Danke trotzdem.
                            CommanderXXL
                            @gargano Ich nutze kein Docker und habe das gleiche Problem mit meinem echarts. Es ist zum ersten mal aufgetreten nach meinem Update auf 2.0.7 NACHDEM ich auf das neue Node 22 upgedatet habe. Seitdem hat nichts geholfen. Downgrade auf 2.0.6 bringt selben Fehler. Upgrade auf 2.0.8 hat selbes Problem. Und Node will ich nicht auf 20 downgraden. Ich habe beim Adapter einen Bug eingestellt (oder eher mich einem Bug angschlossen ;) ) https://github.com/ioBroker/ioBroker.echarts/issues/927)
                            Bisher ist mein Workaround das ECharts in den Instanzen abzuschalten um nicht alle 30 Sekunden den Log vollzuspamen. Die Diagramme im Broker selbst gehen noch, nur kein Rendering per SendTo und vielleicht andere Sachen.
                            Eduard77E 1 Antwort Letzte Antwort
                            • C CommanderXXL
                              Eduard77E Online
                              Eduard77E Online
                              Eduard77
                              schrieb am zuletzt editiert von Eduard77
                              @commanderxxl
                              hast du Canvas nach Node.js update neu gebaut?
                              cd /opt/iobroker/node_modules/canvas/
                              sudo -u iobroker npm install --omit=dev
                              bei mir hat es geholfen.
                              A C 2 Antworten Letzte Antwort
                              • Eduard77E Eduard77
                                @commanderxxl
                                amgxda
                                @eduard77
                                Bei mir tritt auch der oben beschriebene Fehler auf (nach Update auf node 22). Habe schon verschiedenes versucht (eCharts komplett neu installiert (2.0.6 bis 2.0.8), libcairo2 aus Quellen gebaut, canvas neu gebaut), bisher alles ohne Erfolg.
                                  @commanderxxl
                                  CommanderXXL
                                  @eduard77 Ja, habe ich getan. Hat aber keine Besserung gebracht. Im Ticket https://github.com/ioBroker/ioBroker.echarts/issues/927 hatte xdaamg noch einen anderen Tip mit komplette Lib von Cairo neu erstellen. Das hat er aber ausprobiert und hat ebenfalls keine Besserung gebracht.
                                  • A amgxda
                                    @eduard77
                                    Eduard77E Online
                                    Eduard77E Online
                                    Eduard77
                                    @amgxda
                                    Dann gib uns die Ausgabe von
                                    iob diag
                                    Edit: hast du die Code oben ausprobiert?
                                    • C Offline
                                      CommanderXXL
                                      Hier mal mein "iob diag" output:
                                      Script v.2025-08-09
                                      *** BASE SYSTEM ***
                                       Static hostname: IObrokerPi5
                                             Icon name: computer
                                                Kernel: Linux 6.12.34+rpt-rpi-2712
                                          Architecture: arm64
                                      OS is similar to:
                                      Model           : Raspberry Pi 5 Model B Rev 1.0
                                      Docker          : false
                                      Virtualization  : none
                                      Kernel          : aarch64
                                      Userland        : 64 bit
                                       11:55:24 up  3:44,  2 users,  load average: 0.36, 0.69, 0.48
                                      CPU threads: 4
                                      *** RASPBERRY THROTTLING ***
                                      Current issues:
                                      Previously detected issues:
                                      ~ Under-voltage has occurred
                                      ~ Arm frequency capping has occurred
                                                     Local time: Fri 2025-08-22 11:55:24 CEST
                                                 Universal time: Fri 2025-08-22 09:55:24 UTC
                                                       RTC time: Fri 2025-08-22 09:55:24
                                                    NTP service: active
                                                RTC in local TZ: no
                                      admin
                                      HOME=/home/admin
                                      GROUPS=admin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                      iobroker
                                      HOME=/home/iobroker
                                      Unit display-manager.service could not be found.
                                      Display-Manager:
                                      Desktop:
                                      Session:                tty
                                      *** MEMORY ***
                                      Mem:            8.5G        2.3G        4.9G        5.5M        1.3G        6.1G
                                      Swap:           209M          0B        209M
                                      Total:          8.7G        2.3G        5.1G
                                      Active iob-Instances:   24
                                               8063 M total memory
                                               2218 M used memory
                                               2010 M active memory
                                                834 M inactive memory
                                               4675 M free memory
                                                261 M buffer memory
                                               1001 M swap cache
                                                199 M total swap
                                                  0 M used swap
                                                199 M free swap
                                      top - 11:55:24 up  3:44,  2 users,  load average: 0.36, 0.69, 0.48
                                      Tasks: 213 total,   1 running, 212 sleeping,   0 stopped,   0 zombie
                                      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                      MiB Mem :   8063.2 total,   4674.1 free,   2219.9 used,   1262.3 buff/cache
                                      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5843.2 avail Mem
                                      *** FAILED SERVICES ***
                                      0 loaded units listed.
                                      151 CRITICAL ERRORS DETECTED!
                                      Check 'sudo dmesg --level=emerg,alert,crit -T' for details
                                      *** FILESYSTEM ***
                                      udev           devtmpfs  3.9G     0  3.9G   0% /dev
                                      tmpfs          tmpfs     1.6G  5.3M  1.6G   1% /run
                                      /dev/mmcblk0p2 ext4       59G   17G   39G  31% /
                                      tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                                      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                                      /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
                                      tmpfs          tmpfs     807M     0  807M   0% /run/user/1000
                                      [Fri Aug 22 08:10:26 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:33:7E:48 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=1773a755-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                                      [Fri Aug 22 08:10:29 2025] EXT4-fs (mmcblk0p2): mounted filesystem 7909438b-2884-423e-aa05-577fdea75c97 ro with ordered data mode. Quota mode: none.
                                      [Fri Aug 22 08:10:30 2025] EXT4-fs (mmcblk0p2): re-mounted 7909438b-2884-423e-aa05-577fdea75c97 r/w.
                                      /                /dev/mmcblk0p2 ext4   rw,noatime
                                      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                      /var:
                                      1.2G    /var/
                                      613M    /var/log
                                      612M    /var/log/journal/e004c5c494f24635be857afd2b9c7aee
                                      221M    /var/cache
                                      Archived and active journals take up 611.9M in the file system.
                                      76M     /opt/iobroker/backups/
                                      803M    /opt/iobroker/iobroker-data/
                                      456M    /opt/iobroker/iobroker-data/history
                                      252M    /opt/iobroker/iobroker-data/files
                                      79M     /opt/iobroker/iobroker-data/backup-objects
                                      52M     /opt/iobroker/iobroker-data/files/vis-2
                                      19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                                      15M     /opt/iobroker/iobroker-data/objects.jsonl
                                      9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
                                      8.8M    /opt/iobroker/iobroker-data/files/matter.admin/assets/index-CjzUbllv.js
                                      8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
                                      USB-Devices by-id:
                                      /dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0
                                      zigbee.X
                                      Extended Pan ID:
                                      *** MASKED ***
                                      Pan ID:
                                      *** MASKED ***
                                      Channel:
                                      *** MASKED ***
                                      Network Key:
                                      *** MASKED ***
                                      /usr/bin/nodejs         v22.18.0
                                      /usr/bin/node           v22.18.0
                                      /usr/bin/npm            11.5.2
                                      /usr/bin/npx            11.5.2
                                      /usr/bin/corepack       0.33.0
                                      nodejs:
                                        Installed: 22.18.0-1nodesource1
                                        Candidate: 22.18.0-1nodesource1
                                        Version table:
                                       *** 22.18.0-1nodesource1 1001
                                              500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                                           22.17.1-1nodesource1 1001
                                           22.17.0-1nodesource1 1001
                                           22.16.0-1nodesource1 1001
                                           22.15.1-1nodesource1 1001
                                           22.15.0-1nodesource1 1001
                                           22.14.0-1nodesource1 1001
                                           22.13.1-1nodesource1 1001
                                           22.13.0-1nodesource1 1001
                                           22.12.0-1nodesource1 1001
                                           22.11.0-1nodesource1 1001
                                           22.10.0-1nodesource1 1001
                                           22.9.0-1nodesource1 1001
                                           22.8.0-1nodesource1 1001
                                           22.7.0-1nodesource1 1001
                                           22.6.0-1nodesource1 1001
                                           22.5.1-1nodesource1 1001
                                           22.5.0-1nodesource1 1001
                                           22.4.1-1nodesource1 1001
                                           22.4.0-1nodesource1 1001
                                           22.3.0-1nodesource1 1001
                                           22.2.0-1nodesource1 1001
                                           22.1.0-1nodesource1 1001
                                           22.0.0-1nodesource1 1001
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      Hosts:
                                      IObrokerPi5         IObrokerPi5 (version: 7.0.7, hostname: IObrokerPi5   , alive, uptime: 376)
                                      admin:          7.7.2
                                      javascript:     9.0.11
                                      nodejs modules from github:     1
                                      +-- iobroker.deconz@2.0.7 (git+ssh://git@github.com/Jey-Cee/ioBroker.deconz.git#8af7464adc2de2241a4d0136e2189a9825d38105)
                                      Adapter State
                                      + system.adapter.admin.0                  : admin                 : IObrokerPi5                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                      + system.adapter.alexa2.0                 : alexa2                : IObrokerPi5                              -  enabled
                                      + system.adapter.backitup.0               : backitup              : IObrokerPi5                              -  enabled
                                      + system.adapter.cloud.0                  : cloud                 : IObrokerPi5                              -  enabled
                                      + system.adapter.deconz.0                 : deconz                : IObrokerPi5                              -  enabled, port: 80
                                        system.adapter.devices.0                : devices               : IObrokerPi5                              - disabled
                                      + system.adapter.discovery.0              : discovery             : IObrokerPi5                              -  enabled
                                        system.adapter.echarts.0                : echarts               : IObrokerPi5                              - disabled
                                        system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : IObrokerPi5                              - disabled
                                      + system.adapter.email.0                  : email                 : IObrokerPi5                              -  enabled
                                      + system.adapter.energiefluss.0           : energiefluss          : IObrokerPi5                              -  enabled
                                        system.adapter.eusec.0                  : eusec                 : IObrokerPi5                              - disabled
                                        system.adapter.feiertage.0              : feiertage             : IObrokerPi5                              -  enabled
                                      + system.adapter.history.0                : history               : IObrokerPi5                              -  enabled
                                      + system.adapter.hmip.0                   : hmip                  : IObrokerPi5                              -  enabled
                                        system.adapter.ical.0                   : ical                  : IObrokerPi5                              -  enabled
                                      + system.adapter.iot.0                    : iot                   : IObrokerPi5                              -  enabled
                                      + system.adapter.javascript.0             : javascript            : IObrokerPi5                              -  enabled
                                      + system.adapter.matter.0                 : matter                : IObrokerPi5                              -  enabled
                                      + system.adapter.mielecloudservice.0      : mielecloudservice     : IObrokerPi5                              -  enabled
                                      + system.adapter.mqtt.0                   : mqtt                  : IObrokerPi5                              -  enabled, port: 1883, bind: 0.0.0.0
                                      + system.adapter.pvforecast.0             : pvforecast            : IObrokerPi5                              -  enabled
                                      + system.adapter.shelly.0                 : shelly                : IObrokerPi5                              -  enabled, port: 1882, bind: 0.0.0.0
                                      + system.adapter.smartmeter.0             : smartmeter            : IObrokerPi5                              -  enabled
                                      + system.adapter.telegram.0               : telegram              : IObrokerPi5                              -  enabled, port: 8443, bind: 0.0.0.0
                                      + system.adapter.text2command.0           : text2command          : IObrokerPi5                              -  enabled
                                      + system.adapter.tr-064.0                 : tr-064                : IObrokerPi5                              -  enabled
                                        system.adapter.twinkly.0                : twinkly               : IObrokerPi5                              - disabled
                                      + system.adapter.vis-2.0                  : vis-2                 : IObrokerPi5                              -  enabled
                                        system.adapter.weatherunderground.0     : weatherunderground    : IObrokerPi5                              -  enabled
                                      + system.adapter.web.0                    : web                   : IObrokerPi5                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + instance is alive
                                      Active repo(s): beta
                                      Used repository: beta
                                      Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
                                      Adapter    "deconz"       : 1.6.4    , installed 2.0.7
                                      Adapter    "echarts"      : 2.0.8    , installed 2.0.8
                                      Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
                                      Adapter    "email"        : 2.0.4    , installed 2.0.4
                                      Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                                      Adapter    "eusec"        : 1.3.3    , installed 1.3.3
                                      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
                                      Adapter    "hmip"         : 1.27.0   , installed 1.27.0
                                      Adapter    "iot"          : 3.6.0    , installed 3.6.0
                                      Adapter    "matter"       : 0.5.2    , installed 0.5.2
                                      Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
                                      Adapter    "shelly"       : 10.1.0   , installed 10.1.0
                                      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                      Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                      Adapter    "twinkly"      : 1.0.14   , installed 1.0.14
                                      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                                      Objects and States
                                      Objects:        7118
                                      States:         5656
                                      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                      Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
                                      Pending Updates: 0
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       94899      5398/iobroker.js-co
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       94905      5398/iobroker.js-co
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6392       795/sshd: /usr/sbin
                                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       98428      5744/io.mqtt.0
                                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       100534     6160/io.shelly.0
                                      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       98429      5744/io.mqtt.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       96036      5416/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       102630     7035/io.web.0
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          6394       795/sshd: /usr/sbin
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       105124     7067/io.matter.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       105114     7067/io.matter.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       105109     7067/io.matter.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6127       664/avahi-daemon: r
                                      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       102576     6970/io.deconz.0
                                      udp        0      0 0.0.0.0:44612           0.0.0.0:*                           1001       105120     7067/io.matter.0
                                      udp        0      0 0.0.0.0:49878           0.0.0.0:*                           104        6129       664/avahi-daemon: r
                                      udp6       0      0 :::5353                 :::*                                1001       105125     7067/io.matter.0
                                      udp6       0      0 :::5353                 :::*                                1001       105115     7067/io.matter.0
                                      udp6       0      0 :::5353                 :::*                                1001       105110     7067/io.matter.0
                                      udp6       0      0 :::5353                 :::*                                104        6128       664/avahi-daemon: r
                                      udp6       0      0 :::1900                 :::*                                1001       102579     6970/io.deconz.0
                                      udp6       0      0 :::1900                 :::*                                1001       102578     6970/io.deconz.0
                                      udp6       0      0 :::1900                 :::*                                1001       102577     6970/io.deconz.0
                                      udp6       0      0 :::56347                :::*                                104        6130       664/avahi-daemon: r
                                      udp6       0      0 :::44612                :::*                                1001       105119     7067/io.matter.0
                                      udp6       0      0 fe80::e5be:3ac1:ac2:546 :::*                                0          6476       755/NetworkManager
                                      2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.erdgeschoss.command.rollosrauf"
                                      2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.hobbyraum.dimmer.licht"
                                      2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.schrank.switch.licht"
                                      2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.bastelzimmer.switch.licht"
                                      2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.gästebad.dimmer.licht"
                                      2025-08-22 11:54:09.981  - info: mqtt.0 (5744) Client [vantage2mqtt_client] subscribes on "mqtt.0.vantage.keller.gästebad.dimmer.spiegellicht"
                                      2025-08-22 11:54:20.395  - error: host.IObrokerPi5 Caught by controller[0]: node:internal/modules/cjs/loader:1846
                                      2025-08-22 11:54:20.395  - error: host.IObrokerPi5 Caught by controller[0]:   return process.dlopen(module, path.toNamespacedPath(filename));
                                      2025-08-22 11:54:20.395  - error: host.IObrokerPi5 Caught by controller[0]:                  ^
                                      2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]: Error: libcairo.so.2: ELF load command address/offset not page-aligned
                                      2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Object..node (node:internal/modules/cjs/loader:1846:18)
                                      2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Module.load (node:internal/modules/cjs/loader:1423:32)
                                      2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Function._load (node:internal/modules/cjs/loader:1246:12)
                                      2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                                      2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
                                      2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1445:12)
                                      2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at require (node:internal/modules/helpers:135:16)
                                      2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                      2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Module._compile (node:internal/modules/cjs/loader:1688:14)
                                      2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:     at Object..js (node:internal/modules/cjs/loader:1820:10) {
                                      2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]:   code: 'ERR_DLOPEN_FAILED'
                                      2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]: }
                                      2025-08-22 11:54:20.396  - error: host.IObrokerPi5 Caught by controller[0]: Node.js v22.18.0
                                      2025-08-22 11:54:20.396  - error: host.IObrokerPi5 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      2025-08-22 11:54:20.396  - info: host.IObrokerPi5 Do not restart adapter system.adapter.echarts.0 because disabled or deleted
                                        @amgxda
                                        iob diag
                                        amgxda
                                        @eduard77
                                        Die Befehle von dir habe ich eingegeben, es hat sich aber nichts geändert. iob diag erspar ich uns jetzt mal (CommanderXXL hat seins schon gepostet), da ist nichts spannendes drin (Raspberry Pi OS Debian Bookworm, alles up-to-date, iobroker latest up-to-date, keine anderen Fehler im Protokoll), nur der e-Charts-Adapter wirft seit dem Upgrade auf Node 22 und Update von 2.0.6 auf 2.0.7/2.0.8 Fehler. Ein Downgrade auf 2.0.6 behebt den Fehler nicht mehr. CoPilot hat diverse Vorschläge zur Korrektur geliefert, die aber letztendlich nichts gebracht haben (Neubauen der libcairo2, canvas).
                                        Ich musste den Adapter deaktivieren und belasse es erst mal dabei, weil die Charts trotzdem angezeigt werden. Wahrscheinlich läuft es ohnehin darauf hinaus, dass mit Debian 13 das System neu aufgesetzt wird.
                                        2025-08-22 11:20:04.481 - info: host.pi5 instance system.adapter.echarts.0 in version "2.0.8" started with pid 336084
                                        2025-08-22 11:20:05.007 - error: host.pi5 Caught by controller[0]: node:internal/modules/cjs/loader:1846
                                        2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                                        2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: ^
                                        2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: Error: libcairo.so.2: ELF load command address/offset not page-aligned
                                        2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Object..node (node:internal/modules/cjs/loader:1846:18)
                                        2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1423:32)
                                        2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Function._load (node:internal/modules/cjs/loader:1246:12)
                                        2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at TracingChannel.traceSync (node:diagnostics_channel:322:14)
                                        2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at wrapModuleLoad (node:internal/modules/cjs/loader:235:24)
                                        2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1445:12)
                                        2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at require (node:internal/modules/helpers:135:16)
                                        2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Object. (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                        2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1688:14)
                                        2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: at Object..js (node:internal/modules/cjs/loader:1820:10) {
                                        2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: code: 'ERR_DLOPEN_FAILED'
                                        2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: }
                                        2025-08-22 11:20:05.008 - error: host.pi5 Caught by controller[0]: Node.js v22.18.0
                                        2025-08-22 11:20:05.008 - error: host.pi5 instance system.adapter.echarts.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                        • C CommanderXXL
                                          Script v.2025-08-09
                                          *** BASE SYSTEM ***
                                                 Icon name: computer
                                              Architecture: arm64
                                          OS is similar to:
                                          Docker          : false
                                          Kernel          : aarch64
                                          Userland        : 64 bit
                                          CPU threads: 4
                                          Current issues:
                                                        NTP service: active
                                                    RTC in local TZ: no
                                          admin
                                          HOME=/home/admin
                                          iobroker
                                          HOME=/home/iobroker
                                          Display-Manager:
                                          Desktop:
                                          Session:                tty
                                          *** MEMORY ***
                                          Swap:           209M          0B        209M
                                                   8063 M total memory
                                                   2218 M used memory
                                                   4675 M free memory
                                                    261 M buffer memory
                                                   1001 M swap cache
                                                    199 M total swap
                                                      0 M used swap
                                                    199 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          1.2G    /var/
                                          613M    /var/log
                                          221M    /var/cache
                                          USB-Devices by-id:
                                          zigbee.X
                                          Extended Pan ID:
                                          *** MASKED ***
                                          Pan ID:
                                          *** MASKED ***
                                          Channel:
                                          *** MASKED ***
                                          Network Key:
                                          *** MASKED ***
                                          /usr/bin/npm            11.5.2
                                          /usr/bin/npx            11.5.2
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Hosts:
                                          admin:          7.7.2
                                          javascript:     9.0.11
                                          Adapter State
                                          + instance is alive
                                          Objects and States
                                          Objects:        7118
                                          States:         5656
                                          Pending Updates: 0
                                          Eduard77E Online
                                          Eduard77E Online
                                          Eduard77
                                          @commanderxxl
                                          na da hast du ein paar Baustellen, aber dazu kann @Thomas-Braun mehr sagen.
                                          ein paar davon:
                                          1.
                                          1. Wieso hast du bei NPM Version 11?
                                          /usr/bin/npm            11.5.2
                                          /usr/bin/npx            11.5.2
