  4. Test Adapter NSPanel-lovelace-ui v1.x.x
    6.4k
1.3k Beiträge 36 Kommentatoren 304.2k Aufrufe 36 Beobachtet
  • T TT-Tom
    @teletapi
    Datenpunkt windDirectionText
    So der fix ist jetzt online. bitte testen.
    hm_krause
    #231
    bitte um Starthilfe.
    Das Script ist installiert und läuft.
    Desired TFT Firmware: 58 / v4.9.4
    javascript.0	18:52:37.817	info
    Installed TFT Firmware: 58 / v4.9.4
    javascript.0	18:57:09.535	info
    Stopping script script.js.nspanel-lovelace-ui_0.NSPanel_1
    javascript.0	18:58:54.092	info
    Compiling TypeScript source script.js.nspanel-lovelace-ui_0.NSPanel_1
    javascript.0	18:58:54.554	info
    source code did not change, using cached compilation result...
    javascript.0	18:58:54.659	info
    --- start of NsPanelTs: 0_userdata.0.NSPanel. ---
    javascript.0	18:58:54.680	info
    setObjects enabled - create Alias Channels possible
    javascript.0	18:58:54.685	info
    weather alias for openweathermap.0. already exists
    javascript.0	18:58:54.696	info
    registered 41 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
    javascript.0	18:58:54.701	info
    No Updates for NSPanel available
    javascript.0	18:58:54.861	info
    javascript.0	18:58:54.977	info
    Debug mode disabled
    javascript.0	18:58:56.163	info
    hidden Cards disabled
    javascript.0	18:58:56.253	info
    javascript.0	18:58:57.539	info
    Start MQTT-Port-Check -------------------------------------
    -- admin.0                   - 8081
    -- hm-rpc.0                  - 0
    -- hm-rpc.1                  - 8701
    -- influxdb.0                - 8086
    -- influxdb.1                - 8086
    -- mqtt.0                    - 1883
    -- mqtt.3                    - 1883
    -- mqtt.4                    - 1886
    -- proxmox.0                 - 8006
    -- shelly.0                  - 1883
    -- shelly.1                  - 1882
    javascript.0	18:58:57.540	info
    -- simple-api.0              - 8087
    -- sonoff.0                  - 1885
    -- sun2000.0                 - 502
    -- telegram.0                - 8443
    -- web.0                     - 8082
    -- zigbee.1                  - /dev
    - MQTT-Port-Check OK: Instance of Adapter: mqtt.4 is running on Port:1886
    End MQTT-Port-Check ----------
    Der Apapter startet nicht, Fehler: No compatible config found, paused!
    Hier die Einstellungen:3.jpg 2.jpg 1.jpg
    Log:
    nspanel-lovelace-ui.0
    	2025-08-13 19:15:32.584	debug	{"command":"refreshMaintainTable","message":{"internalServerIp":"192.168.178.4"},"from":"system.adapter.admin.0","callback":{"message":{"internalServerIp":"192.168.178.4"},"id":236,"ack":false,"time":1755105332581},"_id":22998830}
    	2025-08-13 19:14:56.356	debug	{"command":"getTimeZones","message":{"ip":"192.168.178.4"},"from":"system.adapter.admin.0","callback":{"message":{"ip":"192.168.178.4"},"id":235,"ack":false,"time":1755105296355},"_id":22998829}
    	2025-08-13 19:14:56.284	debug	{"command":"getTasmotaDevices","message":{"ip":"192.168.178.4"},"from":"system.adapter.admin.0","callback":{"message":{"ip":"192.168.178.4"},"id":234,"ack":false,"time":1755105296281},"_id":22998828}
    	2025-08-13 19:00:28.147	error	No compatible config found, paused!
    	2025-08-13 19:00:28.106	info	starting. Version 0.2.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#955fb48e830b9ffc2f648d9d50adbbde0e5318ba) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v20.19.4, js-controller: 7.0.6
    	2025-08-13 19:00:27.873	debug	States connected to redis: 0.0.0.0:9000
    	2025-08-13 19:00:27.771	debug	States create User PubSub Client
    	2025-08-13 19:00:27.771	debug	States create System PubSub Client
    	2025-08-13 19:00:27.741	debug	Redis States: Use Redis connection: 0.0.0.0:9000
    	2025-08-13 19:00:27.683	debug	Objects connected to redis: 0.0.0.0:9001
    	2025-08-13 19:00:27.678	debug	Objects client initialize lua scripts
    	2025-08-13 19:00:27.578	debug	Objects create User PubSub Client
    	2025-08-13 19:00:27.578	debug	Objects create System PubSub Client
    	2025-08-13 19:00:27.577	debug	Objects client ready ... initialize now
    	2025-08-13 19:00:27.534	debug	Redis Objects: Use Redis connection: 0.0.0.0:9001
    	2025-08-13 19:00:23.080	info	terminating
    	2025-08-13 19:00:22.579	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    	2025-08-13 19:00:22.579	info	terminating
    	2025-08-13 19:00:22.578	info	Got terminate signal TERMINATE_YOURSELF
    	2025-08-13 18:59:52.362	debug	{"command":"refreshMaintainTable","message":{"internalServerIp":"192.168.178.4"},"from":"system.adapter.admin.0","callback":{"message":{"internalServerIp":"192.168.178.4"},"id":232,"ack":false,"time":1755104392359},"_id":22998826}
    Bitte um Hilfe
    • H hm_krause
      Debug mode disabled
      -- admin.0                   - 8081
      -- hm-rpc.0                  - 0
      -- hm-rpc.1                  - 8701
      -- mqtt.0                    - 1883
      -- mqtt.3                    - 1883
      -- mqtt.4                    - 1886
      -- proxmox.0                 - 8006
      -- shelly.0                  - 1883
      -- shelly.1                  - 1882
      -- sonoff.0                  - 1885
      -- sun2000.0                 - 502
      -- web.0                     - 8082
      -- zigbee.1                  - /dev
      Log:
      Bitte um Hilfe
      TT-Tom
      #232
      @hm_krause
      Hast du dir die Hilfe zur Adapter Installation durchgelesen. Und diese schrittweise abgearbeitet.
      Dann solltest du selber auf den Fehler kommen.
      Du hast ein Schritt vergessen. Bitte lesen, damit du den Ablauf verstehst.
      Wenn es dann immer noch nicht klappt, melde dich einfach noch mal.
      Edit: sehe grade das du auch ein falsches Script genommen hast. Also bitte lesen, der Link ins auf der General Seite oben.
      Gruß Tom
      Public Transport
      NSPanel Adapter Wiki
      H 1 Antwort Letzte Antwort
      • T TT-Tom
        @hm_krause
        hm_krause
        #233
        @tt-tom
        --Hm...??
        Script habe ich dieses von hier: https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/DEV/NSPanelTs.ts
        Hilfe zur Adapterinstallation mehrfach gelesen, ich finde den Fehler nicht.
        • H hm_krause
          @tt-tom
          --Hm...??
          TT-Tom
          #234
          @hm_krause
          Um ehrlich zu sein hast du so nicht richtig gelesen.
          Das Script ist vom Parallel Projekt und hat mit dem Adapter nichts zu tun.
          Wiki
          Hier wird genau gesagt welches Script du nutzen sollst.
          Es wird vom Adapter angelegt.
          Gruß Tom
          Public Transport
          teletapiT H 2 Antworten Letzte Antwort
          • T TT-Tom
            @hm_krause
            Wiki
            teletapiT Online
            teletapiT Online
            teletapi
            #235
            Nabend, ich hab heute nach der Aufforderung zum testen des neuen Scriptes den Adapter aktualisiert danach stand dann unter Maintain das das neue script zur verfügung steht. Hab dann den Butten gedrückt und ein "OK" bekommen.
            Leider ist der Fehler nach Neustart des scriptes und des Adapters immernoch vorhanden .
            Die neue script Version wird aber geladen
            avascript.0	01:00:10.698	info
            javascript.0	01:00:10.758	info
            javascript.0	01:00:10.762	info
            registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
            javascript.0	01:00:11.123	info
            Stopping script
            javascript.0	01:00:11.529	info
              'Panel for Topic: SmartHome/NSPanel_Weiss Script version 0.9.1 is correct!',
              'done'
            	2025-08-14 00:57:49.999	warn	[StatesDB] Found more as 1 state for role in /^openweathermap\.0./ with .dp: openweathermap.0.forecast.current.windDirection and .regexp: /^openweathermap\.[0-9]+\.forecast\.current\.windDirection/
            	2025-08-14 00:57:49.944	warn	[StatesDB] Found more as 1 state for role in /^openweathermap\.0./ with .dp: openweathermap.0.forecast.current.windDirection and .regexp: /^openweathermap\.[0-9]+\.forecast\.current\.windDirection/
            T T 2 Antworten Letzte Antwort
            • teletapiT teletapi
              Stopping script
                'done'
              TT-Tom
              #236
              @teletapi
              zeige mal bitte dein oben Teil Script, also alles was hier vor ist.
              Edit: hat sich erledigt
              Gruß Tom
              Public Transport
                Stopping script
                  'done'
                ticaki
                #237
                @teletapi
                Bitte nochmal aktualisieren. Die Änderung war zwar im Code, aber noch nicht kompiliert.
                Spenden
                teletapiT 1 Antwort Letzte Antwort
                • T ticaki
                  @teletapi
                  teletapiT Online
                  teletapiT Online
                  teletapi
                  #238
                  @ticaki Jawohl das hat wohl funktioniert Fehler taucht nicht mehr auf 👍 👍
                    teletapiT Online
                    teletapiT Online
                    teletapi
                    schrieb am zuletzt editiert von teletapi
                    #239
                    @TT-Tom ich glaub ich hab hier in der PagePower einen kleinen Fehler entdeckt. Beim erstellen der Pagepower hier zb. "Leistung 4" einstellen der Dezimalstellen hier geht nur eine kommastelle nicht 2: 0,1 und 0,01 ergeben beide nur eine Nachkommastelle.
                    Bei "Leistung Haus unten" funktioniert es:
                    T T 3 Antworten Letzte Antwort
                      TT-Tom
                      #240
                      @teletapi
                      Wieviele Kommastellen liefert den der Datenpunkt?
                      kWh ist aber keine aktuelle Leistung.
                      Gruß Tom
                      Public Transport
                      • T TT-Tom
                        @teletapi
                        teletapiT Online
                        teletapiT Online
                        teletapi
                        #241
                        @tt-tom der Datenpunkt liefert 4 Nachkommastellen und der Wert entspricht dem tatsächlichem Hausverbrauch pro Tag
                        • T TT-Tom
                          @hm_krause
                          Wiki
                          hm_krause
                          #242
                          @tt-tom
                          Habe jetzt nochmal Schritt für Schritt alles durchgegangen:
                          • Berry Treiber und TFT Firmware vom Adapter aus installiert.
                          • Beispiel Konfigscript gestartet
                            Fehler noch immer:
                          	2025-08-14 15:43:58.346	error	No compatible config found, paused!
                          	2025-08-14 15:43:58.345	warn	No script config found for nspanel_1
                          	2025-08-14 15:43:58.253	info	starting. Version 0.2.4 (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#955fb48e830b9ffc2f648d9d50adbbde0e5318ba) in /opt/iobroker/node_modules/iobroker.nspanel-lovelace-ui, node: v20.19.4, js-controller: 7.0.6
                          host.Iobroker
                          	2025-08-14 15:43:56.922	info	instance system.adapter.nspanel-lovelace-ui.0 in version "0.2.4" (non-npm: ticaki/ioBroker.nspanel-lovelace-ui#955fb48e830b9ffc2f648d9d50adbbde0e5318ba) started with pid 112172
                          host.Iobroker
                          	2025-08-14 15:43:53.473	info	instance system.adapter.nspanel-lovelace-ui.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          host.Iobroker
                          	2025-08-14 15:43:53.053	info	stopInstance system.adapter.nspanel-lovelace-ui.0 send kill signal
                          	2025-08-14 15:43:52.892	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          	2025-08-14 15:43:52.891	info	terminating
                          	2025-08-14 15:43:52.891	info	Got terminate signal TERMINATE_YOURSELF
                          host.Iobroker
                          	2025-08-14 15:43:52.887	info	stopInstance system.adapter.nspanel-lovelace-ui.0 (force=false, process=true)
                          javascript.0
                          	2025-08-14 15:43:46.557	info	Stopping script script.js.nspanel-lovelace-ui_0.conf
                          javascript.0
                          	2025-08-14 15:43:46.444	info	script.js.nspanel-lovelace-ui_0.conf: [ 'Panel for Topic: topic Script version 0.9.1 is correct!', 'No navigation items found! This needs to be fixed!', 'done' ]
                          	2025-08-14 15:43:46.424	error	[config-manager] No navigation items found! This needs to be fixed!
                          • H hm_krause
                            @tt-tom
                              Fehler noch immer:
                            host.Iobroker
                            host.Iobroker
                            host.Iobroker
                            host.Iobroker
                            javascript.0
                            javascript.0
                            teletapiT Online
                            teletapiT Online
                            teletapi
                            #243
                            @hm_krause genau das gleiche Problem hatte ich auch. Bis ich durch @TT-Tom und @ticaki darauf aufmeksam gemacht wurde das auch nicht den Schritt für Schritt anleitungen gefolgt bin. Wie war das noch.... Wenn alles da ist das script starten (Das script beendet sich wieder) dann in den Adapter und diesen neu starten. danach kam die Grund oder Basis config erst . dauert paar sekunden
                            Hier kannst du lesen wie mein Problem aussah.... https://forum.iobroker.net/topic/80055/betatest-nspanel-lovelace-ui-v0-2-x/174
                            Ich hab auch ne ganze Zeit gebraucht um erstmal zu kapieren wie es geht das Script bleibt nicht geöffnet. Das schließt sich nach dem neustart wieder und danach muss der Adapter neu gestartet werden um die Konfig zu laden die er durch das Starten des scriptes bekommen hat.
                            Und nach jeder Änderung muss das wieder neu gestart und der Adapter ebenfalls neu gestartet werden.
                            @TT-Tom hier könnte die Anleitung in meinen Augen durchaus ausführlicher sein bzw einfacher geschrieben werden. Mir ist das früher bei Anleitungen auch immer mal wieder passiert das (weil man es selbst sehr gut beherscht) vergisst das auf der anderen Seite relativ unbedarfte Menschen sitzen.... (So wie ich) ... ;-)
                            Und das soll keine Kritik an eurer Arbeit sein die ist hervorragend genauso wie eure Hilfestellung
                              hm_krause
                              #244
                              @teletapi
                              Was hattest Du denn für ein minimal Script genommen.
                              Das Beispiel Konfig Script läuft daurch und beendet sich ja auch.
                              Der Adapter will aber nicht starten..:-(
                              Ich weiß ja aich das der Fehler "vor" dem Monitor sitzt, aber helfen tut das nicht.
                              • H hm_krause
                                @teletapi
                                teletapiT Online
                                teletapiT Online
                                teletapi
                                #245
                                @hm_krause ich weiß war bei mir genauso. (Letztendlich hatte ich soviel probiert und getestet das ich zum Schluss als es dann startete nicht mehr sicher war was ich falsch oder richtig gemacht habe.) Hast du nach dem Start des scriptes den Adapter neu gestartet. Vielleicht zeigst du mal deine Adapter seite..?
                                teletapiT T 2 Antworten Letzte Antwort
                                  teletapiT Online
                                  teletapiT Online
                                  teletapi
                                  #246
                                  @teletapi
                                  Das minimal script ist im Basisscript enthalten da muss man nix machen. Wenn du im Adapter auf script drückst erstellt der Adapter ein JS Ordner in dem das passende script enthalten ist das einmal starten und danach den Adapter neustarten. Evtl. würde ich nochmal in den Adapter gehen und auf Tabelle aktualisieren gehn und wenn du das Panel da aufrufst muss die tasmota Version drin sein die du nutzt. Die war bei mir vorher auch nicht drin.
                                    ticaki
                                    #247
                                    @hm_krause
                                    Das letzte Mal waren die topics unterschiedlich zwischen dem Skript und der Adapter konfiguration
                                    Spenden
                                      @teletapi
                                      TT-Tom
                                      #248
                                      @teletapi
                                      Danke für deine Hinweise.
                                      @hm_krause
                                      Lege bitte mal im Script eine Seite an. uniqename muss main sein.
                                      Bin noch unterwegs und kann leider nicht besser helfen von hier.
                                      Gruß Tom
                                      Public Transport
                                      • T TT-Tom
                                        @teletapi
                                        @hm_krause
                                        hm_krause
                                        #249
                                        @teletapi
                                        Meinst Du mit Basisscript dieses:
                                        https://github.com/ticaki/ioBroker.nspanel-lovelace-ui/blob/main/script/example_sendTo_script_iobroker.ts
                                        Hier noch:
                                        • H hm_krause
                                          @teletapi
                                          Hier noch:
                                          teletapiT Online
                                          teletapiT Online
                                          teletapi
                                          #250
                                          @hm_krause Den fehler hatte ich bisher noch nicht der ist mir neu. Aber ja das ist das script was durch den Adsapter erstellt werden soll natürlich unter dem passenden Ordner. hast du mal geschaut ob deine Topics passen
