  4. [gelöst] Puppeteer-Adapter läuft auf Raspi 4 nicht
    1.0k
    6.1k
4 Beiträge 2 Kommentatoren 524 Aufrufe 2 Beobachtet
  • BertDerKleineB Offline
    BertDerKleine
    schrieb am zuletzt editiert von BertDerKleine
    • Adaptername: Puppeteer
    • Link zu Adapterrepository: www.github.com...
    • Adapterversion: 0.4.0
    • js-controller Version: 7.0.6
    • Admin Version: 7.6.17
    • Hardwaresystem: Pi4
    • Arbeitsspeicher: 8 GB
    • Festplattenart: SD-Karte
    • Betriebssystem: Bullseye
    • Nodejs-Version: 20.19.3
    • NPM-Version: 10.8.2
    • Installationsart: Manuell
    • Image, Docker genutzt: Nein
    Output von iob diag
    Script v.2025-03-08
    *** BASE SYSTEM ***
       Static hostname: iobrokerpi4b
             Icon name: computer
      Operating System: Debian GNU/Linux 11 (bullseye)
                Kernel: Linux 6.1.21-v8+
          Architecture: arm64
    OS is similar to:
    Model : Raspberry Pi 4 Model B Rev 1.5
    Docker : false
    Virtualization : none
    Kernel : aarch64
    Userland : 64 bit
    Systemuptime and Load:
     09:11:15 up 34 min, 2 users, load average: 1.28, 1.36, 1.46
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-07-14 09:11:15 CEST
               Universal time: Mon 2025-07-14 07:11:15 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    PiAdmin
    XDG_CONFIG_HOME=/home/PiAdmin/.config
    HOME=/home/PiAdmin
    GROUPS=PiAdmin adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: true
    Desktop: LXDE-pi
    Terminal: x11
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
                   total used free shared buff/cache available
    Mem: 7.8G 2.2G 4.0G 73M 1.7G 5.4G
    Swap: 1.0G 0B 1.0G
    Total: 8.8G 2.2G 5.0G
    Active iob-Instances: 20
             7812 M total memory
             2192 M used memory
             2516 M active memory
              833 M inactive memory
             3950 M free memory
              181 M buffer memory
             1487 M swap cache
             1023 M total swap
                0 M used swap
             1023 M free swap
    *** top - Table Of Processes ***
    top - 09:11:16 up 34 min, 2 users, load average: 1.28, 1.36, 1.46
    Tasks: 212 total, 2 running, 210 sleeping, 0 stopped, 0 zombie
    %Cpu(s): 30.0 us, 7.1 sy, 0.0 ni, 62.9 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st
    MiB Mem : 7812.3 total, 3949.9 free, 2192.5 used, 1669.8 buff/cache
    MiB Swap: 1024.0 total, 1024.0 free, 0.0 used. 5384.2 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem Type Size Used Avail Use% Mounted on
    /dev/root ext4 30G 17G 12G 59% /
    devtmpfs devtmpfs 3.6G 0 3.6G 0% /dev
    tmpfs tmpfs 3.9G 0 3.9G 0% /dev/shm
    tmpfs tmpfs 1.6G 1.3M 1.6G 1% /run
    tmpfs tmpfs 5.0M 4.0K 5.0M 1% /run/lock
    /dev/mmcblk0p1 vfat 255M 31M 225M 13% /boot
    tmpfs tmpfs 782M 24K 782M 1% /run/user/1000
    [Mon Jul 14 08:37:00 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:F5:FF:D6 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=891597ea-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Mon Jul 14 08:37:01 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Jul 14 08:37:01 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Jul 14 08:37:03 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    Show mounted filesystems:
    TARGET SOURCE FSTYPE OPTIONS
    / /dev/mmcblk0p2 ext4 rw,noatime
    `-/boot /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    3.9G /var/
    1.5G /var/cache/apt
    1.5G /var/cache
    1.4G /var/cache/apt/archives
    1.2G /var/log/journal/f0de918bd30e4ce4bf2ed3f904044603
    Archived and active journals take up 1.1G in the file system.
    /opt/iobroker/backups:
    767M /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.6G /opt/iobroker/iobroker-data/
    779M /opt/iobroker/iobroker-data/history
    589M /opt/iobroker/iobroker-data/files
    122M /opt/iobroker/iobroker-data/backup-objects
    114M /opt/iobroker/iobroker-data/files/vis
    48M /opt/iobroker/iobroker-data/objects.jsonl
    41M /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    26M /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
    USB-Devices by-id:
    USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
    /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2692356-if00
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs v20.19.3
    /usr/bin/node v20.19.3
    /usr/bin/npm 10.8.2
    /usr/bin/npx 10.8.2
    /usr/bin/corepack 0.32.0
    nodejs:
      Installed: 20.19.3-1nodesource1
      Candidate: 20.19.3-1nodesource1
      Version table:
     *** 20.19.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         12.22.12~dfsg-1~deb11u7 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.12~dfsg-1~deb11u4 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States type: jsonl
    Hosts:
    iobrokerpi4b iobrokerpi4b (version: 7.0.6, hostname: iobrokerpi4b , alive, uptime: 873)
    Core adapters versions
    js-controller: 7.0.6
    admin: 7.6.17
    javascript: 8.9.2
    nodejs modules from github: 0
    Adapter State
    + system.adapter.admin.0 : admin : iobrokerpi4b - enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0 : backitup : iobrokerpi4b - enabled
    + system.adapter.deconz.0 : deconz : iobrokerpi4b - enabled, port: 8090
    + system.adapter.discovery.0 : discovery : iobrokerpi4b - enabled
    + system.adapter.e3oncan.0 : e3oncan : iobrokerpi4b - enabled
    + system.adapter.echarts.0 : echarts : iobrokerpi4b - enabled
    + system.adapter.email.0 : email : iobrokerpi4b - enabled
      system.adapter.flot.0 : flot : iobrokerpi4b - enabled
    + system.adapter.fritzdect.0 : fritzdect : iobrokerpi4b - enabled
    + system.adapter.history.0 : history : iobrokerpi4b - enabled
      system.adapter.icons-icons8.0 : icons-icons8 : iobrokerpi4b - enabled
      system.adapter.icons-mfd-png.0 : icons-mfd-png : iobrokerpi4b - enabled
      system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobrokerpi4b - enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobrokerpi4b - enabled
      system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobrokerpi4b - enabled
    + system.adapter.javascript.0 : javascript : iobrokerpi4b - enabled
      system.adapter.material.0 : material : iobrokerpi4b - enabled
    + system.adapter.melcloud.0 : melcloud : iobrokerpi4b - enabled
      system.adapter.modbus.0 : modbus : iobrokerpi4b - disabled
    + system.adapter.mqtt.0 : mqtt : iobrokerpi4b - enabled, port: 1883, bind: 0.0.0.0
      system.adapter.netatmo-crawler.0 : netatmo-crawler : iobrokerpi4b - enabled
      system.adapter.openweathermap.0 : openweathermap : iobrokerpi4b - enabled
    + system.adapter.shelly.0 : shelly : iobrokerpi4b - enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sma-em.0 : sma-em : iobrokerpi4b - enabled
    + system.adapter.sourceanalytix.0 : sourceanalytix : iobrokerpi4b - enabled
    + system.adapter.statistics.0 : statistics : iobrokerpi4b - enabled
    + system.adapter.viessmannapi.0 : viessmannapi : iobrokerpi4b - enabled
      system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: iobrokerpi4b - enabled
      system.adapter.vis-bars.0 : vis-bars : iobrokerpi4b - enabled
      system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobrokerpi4b - enabled
      system.adapter.vis-fancyswitch.0 : vis-fancyswitch : iobrokerpi4b - enabled
      system.adapter.vis-history.0 : vis-history : iobrokerpi4b - enabled
      system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobrokerpi4b - enabled
      system.adapter.vis-icontwo.0 : vis-icontwo : iobrokerpi4b - enabled
    + system.adapter.vis-inventwo.0 : vis-inventwo : iobrokerpi4b - enabled
      system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobrokerpi4b - enabled
      system.adapter.vis-justgage.0 : vis-justgage : iobrokerpi4b - enabled
      system.adapter.vis-lcars.0 : vis-lcars : iobrokerpi4b - enabled
      system.adapter.vis-material-advanced.0 : vis-material-advanced : iobrokerpi4b - enabled
      system.adapter.vis-material.0 : vis-material : iobrokerpi4b - enabled
      system.adapter.vis-materialdesign.0 : vis-materialdesign : iobrokerpi4b - enabled
      system.adapter.vis-plumb.0 : vis-plumb : iobrokerpi4b - enabled
      system.adapter.vis-rgraph.0 : vis-rgraph : iobrokerpi4b - enabled
      system.adapter.vis-timeandweather.0 : vis-timeandweather : iobrokerpi4b - enabled
      system.adapter.vis-weather.0 : vis-weather : iobrokerpi4b - enabled
      system.adapter.vis.0 : vis : iobrokerpi4b - enabled
    + system.adapter.web.0 : web : iobrokerpi4b - enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + instance is alive
    ioBroker-Repositories
    âââââââââââ¬âââââââââââ¬ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ¬âââââââââââââââ (index) â name â url â auto upgrade â
    âââââââââââ¼âââââââââââ¼ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ¼âââââââââââââââ¤
    â 0 â 'stable' â 'http://download.iobroker.net/sources-dist.json' â false â
    â 1 â 'beta' â 'http://download.iobroker.net/sources-dist-latest.json' â false â
    âââââââââââ´âââââââââââ´ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ´âââââââââââââââInstalled ioBroker-Adapters
    Used repository: stable
    Adapter "admin" : 7.6.17 , installed 7.6.17
    Adapter "backitup" : 3.2.2 , installed 3.2.2
    Adapter "deconz" : 1.6.4 , installed 1.6.4
    Adapter "discovery" : 5.0.0 , installed 5.0.0
    Adapter "e3oncan" : 0.10.9 , installed 0.10.9
    Adapter "echarts" : 1.9.2 , installed 1.9.2
    Adapter "email" : 2.0.4 , installed 2.0.4
    Adapter "flot" : 1.12.0 , installed 1.12.0
    Adapter "fritzdect" : 2.6.2 , installed 2.6.2
    Adapter "history" : 3.0.1 , installed 3.0.1
    Adapter "icons-icons8" : 0.0.1 , installed 0.0.1
    Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1
    Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0
    Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1
    Adapter "javascript" : 8.9.2 , installed 8.9.2
    Controller "js-controller": 7.0.6 , installed 7.0.6
    Adapter "material" : 1.3.1 , installed 1.3.1
    Adapter "melcloud" : 2.0.5 , installed 2.0.5
    Adapter "modbus" : 6.3.2 , installed 6.3.2
    Adapter "mqtt" : 6.1.2 , installed 6.1.2
    Adapter "netatmo-crawler": 1.0.0 , installed 1.0.0
    Adapter "openweathermap": 1.1.2 , installed 1.1.2
    Adapter "shelly" : 10.1.0 , installed 10.1.0
    Adapter "simple-api" : 2.8.0 , installed 2.8.0
    Adapter "sma-em" : 1.2.0 , installed 1.2.0
    Adapter "socketio" : 6.7.1 , installed 6.7.1
    Adapter "statistics" : 2.4.0 , installed 2.4.0
    Adapter "viessmannapi" : 2.3.0 , installed 2.4.0
    Adapter "vis" : 1.5.6 , installed 1.5.6
    Adapter "vis-2-widgets-weather-and-heating": 0.10.4, installed 0.10.4
    Adapter "vis-bars" : 0.1.4 , installed 0.1.4
    Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1
    Adapter "vis-fancyswitch": 1.1.0 , installed 1.1.0
    Adapter "vis-history" : 1.0.0 , installed 1.0.0
    Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1
    Adapter "vis-icontwo" : 1.12.0 , installed 1.12.0
    Adapter "vis-inventwo" : 3.3.5 , installed 3.3.5
    Adapter "vis-jqui-mfd" : 1.1.1 , installed 1.1.1
    Adapter "vis-justgage" : 2.1.7 , installed 2.1.7
    Adapter "vis-lcars" : 1.1.1 , installed 1.1.1
    Adapter "vis-material" : 0.2.0 , installed 0.2.0
    Adapter "vis-material-advanced": 1.7.4, installed 1.7.4
    Adapter "vis-materialdesign": 0.5.9, installed 0.5.9
    Adapter "vis-plumb" : 1.0.2 , installed 1.0.2
    Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2
    Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
    Adapter "vis-weather" : 2.5.12 , installed 2.5.12
    Adapter "web" : 7.0.8 , installed 7.0.8
    Adapter "ws" : 2.6.2 , installed 2.6.2
    Objects and States
    Objects: 38715
    States: 35952
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://phoscon.de/apt/deconz generic-beta InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
    tcp 0 0 0.0.0.0:8090 0.0.0.0:* LISTEN 1000 14792 407/deCONZ
    tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 1000 14916 407/deCONZ
    tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 12091 652/sshd: /usr/sbin
    tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 0 15547 556/cupsd
    tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 42187 8520/iobroker.js-co
    tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 40418 8520/iobroker.js-co
    tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 40752 8674/io.shelly.0
    tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 40689 8682/io.mqtt.0
    tcp 0 0 0.0.0.0:5900 0.0.0.0:* LISTEN 0 15564 584/vncserver-x11-c
    tcp6 0 0 ::1:631 :::* LISTEN 0 15546 556/cupsd
    tcp6 0 0 :::8081 :::* LISTEN 1001 39577 8538/io.admin.0
    tcp6 0 0 :::8082 :::* LISTEN 1001 43140 8798/io.web.0
    tcp6 0 0 :::80 :::* LISTEN 0 16176 576/java
    tcp6 0 0 :::22 :::* LISTEN 0 12093 652/sshd: /usr/sbin
    tcp6 0 0 :::5900 :::* LISTEN 0 15563 584/vncserver-x11-c
    udp 0 0 0.0.0.0:5353 0.0.0.0:* 108 14610 393/avahi-daemon: r
    udp 0 0 0.0.0.0:9522 0.0.0.0:* 1001 42527 8647/io.sma-em.0
    udp 0 0 0.0.0.0:38689 0.0.0.0:* 108 14612 393/avahi-daemon: r
    udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 39807 8681/io.deconz.0
    udp 0 0 0.0.0.0:1900 0.0.0.0:* 1000 14993 407/deCONZ
    udp 0 0 0.0.0.0:68 0.0.0.0:* 0 16437 569/dhcpcd
    udp6 0 0 :::5353 :::* 108 14611 393/avahi-daemon: r
    udp6 0 0 :::1900 :::* 1001 39808 8681/io.deconz.0
    udp6 0 0 :::48092 :::* 108 14613 393/avahi-daemon: r
      Regelstatus: AKTIV
      Betriebsmodus: LADEN
      Sollleistung: -665.2W
      Istleistung: -1199.8W
      Ãberschuss: 274W
      SOC: 86.6%
      Messwerte: 6 gespeichert
      Letzte Logs: [2025-07-14T07:02:11.332Z] [DEBUG] Steuerbefehl gesendet: -238.8W (nächstes Mal +0.1W)
      [2025-07-14T07:02:41.332Z] [DEBUG] Steuerbefehl gesendet: -407.0W (nächstes Mal Basiswert)
      [2025-07-14T07:03:11.333Z] [DEBUG] Steuerbefehl gesendet: -607.5W (nächstes Mal +0.1W)
    2025-07-14 09:06:46.868 - info: sourceanalytix.0 (8812) Device reset detected for 0_userdata.0.PV-Erzeugungszähler_WR, feature disabled (or below threshold) processing normally)
    2025-07-14 09:07:46.845 - info: sourceanalytix.0 (8812) Device reset detected for 0_userdata.0.PV-Erzeugungszähler_WR, feature disabled (or below threshold) processing normally)
    2025-07-14 09:08:36.327 - info: javascript.0 (8614) script.js.06_Schaltaufgaben.Akku-Steuerung: [2025-07-14T07:08:36.327Z] [INFO] Systemdiagnose:
      Regelstatus: AKTIV
      Sollleistung: -800.0W
      Istleistung: -1123.6W
      Ãberschuss: 48W
      SOC: 88.5%
      Letzte Logs: [2025-07-14T07:07:11.333Z] [DEBUG] Steuerbefehl gesendet: -800.0W (nächstes Mal +0.1W)
      [2025-07-14T07:07:41.334Z] [DEBUG] Steuerbefehl gesendet: -799.9W (nächstes Mal Basiswert)
      [2025-07-14T07:08:11.333Z] [DEBUG] Steuerbefehl gesendet: -800.0W (nächstes Mal +0.1W)
    2025-07-14 09:08:41.333 - info: javascript.0 (8614) script.js.06_Schaltaufgaben.Akku-Steuerung: [2025-07-14T07:08:41.333Z] [INFO] Initiale Debug-Periode beendet - Detaillogs deaktiviert
    2025-07-14 09:09:16.831 - info: sourceanalytix.0 (8812) Device reset detected for 0_userdata.0.PV-Erzeugungszähler_WR, feature disabled (or below threshold) processing normally)
    Fehler:
    $ iobroker add puppeteer auto --host iobrokerpi4b --debug
    NPM version: 10.8.2
    Installing iobroker.puppeteer@0.4.0... (System call)
    > puppeteer@23.11.1 postinstall> node install.mjs
    **INFO** Skipping Firefox download as instructed.
    Error: ERROR: Failed to set up chrome-headless-shell v131.0.6778.204! Set "PUPPETEER_SKIP_DOWNLOAD" env variable to skip download. at downloadBrowser (file:///opt/iobroker/node_modules/puppeteer/lib/esm/puppeteer/node/install.js:26:15) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Promise.all (index 1)
    at async downloadBrowsers (file:///opt/iobroker/node_modules/puppeteer/lib/esm/puppeteer/node/install.js:84:9) { [cause]: Error: Client network socket disconnected before secure TLS connection was established at TLSSocket.onConnectEnd (node:_tls_wrap:1730:19) at TLSSocket.emit (node:events:536:35) at endReadableNT (node:internal/streams/readable:1698:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21) { code: 'ECONNRESET', path: null, host: 'storage.googleapis.com', port: 443, localAddress: undefined }}
    npm error code 1npm error path /opt/iobroker/node_modules/puppeteernpm error command failednpm error command sh -c node install.mjs
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-07-14T07_01_00_877Z-debug-0.log
    Error: ERROR: Failed to set up chrome-headless-shell v131.0.6778.204! Set "PUPPETEER_SKIP_DOWNLOAD" env variable to skip download. at downloadBrowser (file:///opt/iobroker/node_modules/puppeteer/lib/esm/puppeteer/node/install.js:26:15) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Promise.all (index 1) at async downloadBrowsers (file:///opt/iobroker/node_modules/puppeteer/lib/esm/puppeteer/node/install.js:84:9) { [cause]: Error: Client network socket disconnected before secure TLS connection was established at TLSSocket.onConnectEnd (node:_tls_wrap:1730:19) at TLSSocket.emit (node:events:536:35) at endReadableNT (node:internal/streams/readable:1698:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21) { code: 'ECONNRESET', path: null, host: 'storage.googleapis.com', port: 443, localAddress: undefined }}npm error code 1npm error path /opt/iobroker/node_modules/puppeteernpm error command failednpm error command sh -c node install.mjsnpm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-07-14T07_01_00_877Z-debug-0.log
    host.iobrokerpi4b Cannot install iobroker.puppeteer@0.4.0: 1
    ERROR: Process exited with code 25
    • BertDerKleineB BertDerKleine
      Output von iob diag
      Script v.2025-03-08
      *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
      OS is similar to:
      Docker : false
      Kernel : aarch64
      Userland : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      PiAdmin
      HOME=/home/PiAdmin
      iobroker
      HOME=/home/iobroker
      Desktop: LXDE-pi
      Terminal: x11
      *** MEMORY ***
      Swap: 1.0G 0B 1.0G
               7812 M total memory
               2192 M used memory
               3950 M free memory
                181 M buffer memory
               1487 M swap cache
               1023 M total swap
                  0 M used swap
               1023 M free swap
      *** FILESYSTEM ***
      /var:
      3.9G /var/
      1.5G /var/cache/apt
      1.5G /var/cache
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm 10.8.2
      /usr/bin/npx 10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States type: jsonl
      Hosts:
      admin: 7.6.17
      javascript: 8.9.2
      Adapter State
      + instance is alive
      Objects and States
      Objects: 38715
      States: 35952
      Pending Updates: 0
        Regelstatus: AKTIV
        Ãberschuss: 274W
        SOC: 86.6%
        Regelstatus: AKTIV
        Ãberschuss: 48W
        SOC: 88.5%
      Fehler:
      NPM version: 10.8.2
      @bertderkleine
      Ja, funktioniert nicht:
      https://pptr.dev/troubleshooting
      caution
      Chrome currently does not provide arm64 binaries for Linux. There are only arm64 binaries for Mac ARM. That means that Linux binaries downloaded by default will not work on Linux arm64.
      BertDerKleineB 1 Antwort Letzte Antwort
        @bertderkleine
        caution
        BertDerKleine
        So, einen kleinen Schritt bin ich jetzt weiter:
        Die bisherigen Fehler wurden offensichtlich durch lokale DNS Blockregeln verursacht, die lustigerweise nicht verhinderten, dass vorher
        sudo apt install chromium-browser -y
        problemfrei durchlief, aber bei der Adapterinstallation für Probleme sorgen.
        Jetzt habe ich den Adapter erfolgreich installiert.
        Er läuft aber nicht:
        puppeteer.0
        	2025-07-14 09:25:57.534	info	terminating
        puppeteer.0
        	2025-07-14 09:25:57.031	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        puppeteer.0
        	2025-07-14 09:25:57.030	info	terminating
        puppeteer.0
        	2025-07-14 09:25:57.015	error	Failed to launch the browser process! undefinedTROUBLESHOOTING: https://pptr.dev/troubleshooting
        puppeteer.0
        	2025-07-14 09:25:57.014	error	Error: Failed to launch the browser process! undefinedTROUBLESHOOTING: https://pptr.dev/troubleshooting at ChildProcess.onClose (/opt/iobroker/node_modules/@puppeteer/browsers/lib/cjs/launch.js:314:24) at ChildProcess.emit (node:events:536:35) at ChildProcess._handle.onexit (node:internal/child_process:293:12)
        puppeteer.0
        	2025-07-14 09:25:57.012	error	unhandled promise rejection: Failed to launch the browser process! undefinedTROUBLESHOOTING: https://pptr.dev/troubleshooting
        puppeteer.0
        	2025-07-14 09:25:57.011	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          puppeteer.0
          puppeteer.0
          puppeteer.0
          puppeteer.0
          puppeteer.0
          puppeteer.0
          puppeteer.0
          BertDerKleine
          @bertderkleine
          Kleine Doku meiner Tests mit KI Hilfe:
          Ich habe ein Testskript erstellt:
          const puppeteer = require('puppeteer-core');
          (async () => {
              try {
                  const browser = await puppeteer.launch({
                      executablePath: '/usr/bin/chromium-browser',
                      headless: true,
                      args: ['--no-sandbox', '--disable-setuid-sandbox', '--disable-gpu']
                  const page = await browser.newPage();
                  await page.goto('https://example.com');
                  await page.screenshot({ path: 'example.png' });
                  await browser.close();
                  console.log('Erfolg!');
              } catch (error) {
                  console.error('Fehler:', error);
          Auf der Kommandozeile läuft das prima:
          $ sudo -u iobroker node test-puppeteer.js
          Erfolg!
          und
          $ node test-puppeteer.js
          Erfolg!
          Die KI meint dazu:
          Das Testskript lief sowohl als normaler Benutzer als auch als ioBroker-Benutzer erfolgreich, was bestätigt, dass:
              puppeteer-core@23.11.1 funktioniert.
              Chromium 126.0.6478.164 mit den Argumenten --no-sandbox, --disable-setuid-sandbox, --disable-gpu korrekt startet.
              Der ioBroker-Benutzer die notwendigen Berechtigungen hat.
              Alle erforderlichen Abhängigkeiten installiert sind.
          Hm. Zwischenzeitlich hat mich die KI mal eine Datei README löschen lassen
          sudo rm /etc/chromium.d/README
          Ich denke nicht, dass das wichtig war, aber hier zur Doku
          Den Test hier
          $ chromium-browser --headless --no-sandbox --disable-gpu
          [0714/095037.307664:WARNING:bluez_dbus_manager.cc(248)] Floss manager not present, cannot set Floss enable/disable.
          [0714/095037.390598:WARNING:sandbox_linux.cc(430)] InitializeSandbox() called with multiple threads in process gpu-process.
          hat die KI dann als harmlos/ok Reaktion bezeichnet.
          Und Tada (!) jetzt habe ich auch eine Lösung und der Adapter läuft grün, indem in der Adapter-Konfig die folgenden Eintragungen gemacht werden:
          Essentiell war die manuelle Eintragung des Pfads oben.
