  3. Cloud Dienste
  4. Kein Anmelden am Alexa Adapter mehr möglich
    6.4k
50 Beiträge 7 Kommentatoren 6.3k Aufrufe 5 Beobachtet
  • B Balkonfarmer
    Hab ich jetzt gemacht.
    jetzt steht das drin:
    ```bash
    Script v.2025-03-08
    *** BASE SYSTEM ***
     Static hostname: PiHole
           Icon name: computer
              Kernel: Linux 6.12.34+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     21:04:58 up  2:52,  2 users,  load average: 0.61, 0.52, 0.37
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Wed 2025-07-09 21:04:58 CEST
               Universal time: Wed 2025-07-09 19:04:58 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.0G        303M        3.2G        8.5M        565M        3.7G
    Swap:           536M          0B        536M
    Total:          4.5G        303M        3.7G
    Active iob-Instances:   0
             3795 M total memory
              289 M used memory
              252 M active memory
              352 M inactive memory
             3043 M free memory
               48 M buffer memory
              490 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 21:04:59 up  2:52,  2 users,  load average: 0.61, 0.52, 0.37
    Tasks: 177 total,   1 running, 176 sleeping,   0 stopped,   0 zombie
    %Cpu(s): 20.0 us,  0.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3795.9 total,   3043.2 free,    290.0 used,    539.3 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3505.9 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs          tmpfs     380M  8.1M  372M   3% /run
    /dev/sda2      ext4       14G  3.2G   11G  25% /
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/sda1      vfat      510M   57M  454M  11% /boot/firmware
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    [Wed Jul  9 18:12:26 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:17:D0:59 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=f11aec40-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=GE
    [Wed Jul  9 18:12:30 2025] EXT4-fs (sda2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
    [Wed Jul  9 18:12:32 2025] EXT4-fs (sda2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w.
    Show mounted filesystems:
    TARGET           SOURCE    FSTYPE OPTIONS
    /                /dev/sda2 ext4   rw,noatime
    `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    885M    /var/
    205M    /var/cache
    199M    /var/cache/apt
    168M    /var/lib
    135M    /var/lib/apt/lists
    Archived and active journals take up 6.9M in the file system.
    /opt/iobroker/backups:
    2.8M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    69M     /opt/iobroker/iobroker-data/
    63M     /opt/iobroker/iobroker-data/files
    47M     /opt/iobroker/iobroker-data/files/admin.admin
    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
    5.3M    /opt/iobroker/iobroker-data/objects.jsonl
    3.7M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/assets/index-CyIqcfMJ.js
    3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
    3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-IIKn7Ixx.js
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.3
    /usr/bin/node           v20.19.3
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.32.0
    nodejs:
      Installed: 20.19.3-1nodesource1
      Candidate: 20.19.3-1nodesource1
      Version table:
     *** 20.19.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.19.2-1nodesource1 1001
         20.19.1-1nodesource1 1001
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    No connection to states 127.0.0.1:6379[redis]
    Hosts:
    Core adapters versions
    js-controller:  7.0.6
    admin:          "admin" not found
    javascript:     "javascript" not found
    nodejs modules from github:     0
    Adapter State
    ioBroker-Repositories
    Installed ioBroker-Adapters
    Objects and States
    Objects:        2
    States:         1
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4527       621/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          4529       621/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2646       478/avahi-daemon: r
    udp        0      0 0.0.0.0:48814           0.0.0.0:*                           104        2648       478/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        2647       478/avahi-daemon: r
    udp6       0      0 :::47074                :::*                                104        2649       478/avahi-daemon: r
    udp6       0      0 fe80::523d:8bd6:ead:546 :::*                                0          5567       558/NetworkManager
    2025-07-09 21:04:15.162  - info: host.PiHole iobroker _restart
    2025-07-09 21:04:21.369  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
    2025-07-09 21:04:21.375  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2025-07-09 21:04:21.376  - info: host.PiHole hostname: PiHole, node: v20.19.3
    2025-07-09 21:04:21.378  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
    2025-07-09 21:04:51.393  - error: host.PiHole No connection to databases possible, restart
    2025-07-09 21:04:51.409  - info: host.PiHole iobroker _restart
    2025-07-09 21:04:57.617  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
    2025-07-09 21:04:57.623  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2025-07-09 21:04:57.625  - info: host.PiHole hostname: PiHole, node: v20.19.3
    2025-07-09 21:04:57.626  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
    2025-07-09 21:05:27.642  - error: host.PiHole No connection to databases possible, restart
    2025-07-09 21:05:27.650  - info: host.PiHole iobroker _restart
    2025-07-09 21:05:34.095  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
    2025-07-09 21:05:34.103  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2025-07-09 21:05:34.104  - info: host.PiHole hostname: PiHole, node: v20.19.3
    2025-07-09 21:05:34.106  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
    2025-07-09 21:06:04.121  - error: host.PiHole No connection to databases possible, restart
    2025-07-09 21:06:04.129  - info: host.PiHole iobroker _restart
    2025-07-09 21:06:10.367  - info: host.PiHole iobroker.js-controller version 7.0.6 js-controller starting
    2025-07-09 21:06:10.374  - info: host.PiHole Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
    2025-07-09 21:06:10.375  - info: host.PiHole hostname: PiHole, node: v20.19.3
    2025-07-09 21:06:10.376  - info: host.PiHole ip addresses: 192.168.178.78 2001:9e8:f0b3:8a00:a18a:abdf:24fb:c54a fdd0:3d3:253b:0:e385:e5ac:14a4:3829 fe80::523d:8bd6:ead9:fd82
    2025-07-09 21:06:40.404  - error: host.PiHole No connection to databases possible, restart
    2025-07-09 21:06:40.413  - info: host.PiHole iobroker _restart
    iob diag has finished.
    kann man da noch etwas retten?
    @balkonfarmer
    Hast du auch zuvor 'redis' installiert?
    Die alte Installation lief wohl offenbar darauf.
    sudo apt update
    apt policy redis
      @balkonfarmer
      sudo apt update
      apt policy redis
      Balkonfarmer
      achso, muss ich das jetzt immer installieren, wenn ich eine Wiederherstellung mache?
      • B Balkonfarmer
        @balkonfarmer
        Wenn DU das zuvor installiert hattest...
        Ist jedenfalls nicht die Voreinstellung, hast du selber mal auf redis umgestellt.
          @balkonfarmer
          Balkonfarmer
          das kann sein. ich hab IoBroker ja schon seit mehreren Jahren. Hab das früher alles nach Anleitung eines Youtubers (teilweise auch mit seinen Skripten) installiert. Kann man das dann irgendwie wieder umstellen?
          • B Balkonfarmer
            @balkonfarmer
            Ich würde das jetzt wieder auf redis setzen, damit dein Backup da wieder drauf läuft.
            sudo apt install redis
            und dann das Backup da reinjubeln.
              @balkonfarmer
              Balkonfarmer
              @thomas-braun sagte in Kein Anmelden am Alexa Adapter mehr möglich:
              Ich bekomme bei den apt Commandos nur das angezeigt
              pi@PiHole:/ $ sudo apt update
              WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
              pi@PiHole:/ $ apt policy redis
              pi@PiHole:/ $ sudo apt install redis
              • B Balkonfarmer
                @balkonfarmer Warum stehst du da im root herum?
                cd
                  cd
                  Balkonfarmer
                  Ich habe nun ein neues Problem:
                  Gestern konnte ich mit dem Laptop und dem Raspberry Pi Imager noch ein OS auf die SSD flashen, aber seit heute habe ich nach dem Flashen keinen Zugriff mehr. Obwohl ich die Wifi-Settings etc alle korrekt eingegeben habe, verbindet sich der Raspi nicht mehr mit dem Wifi. Jetzt kann ich kein frisches OS mehr nutzen. Am Raspi kann es nicht liegen, denn mit einer anderen SSD (gestern geflasht) funktioniert es. Es ist echt zum Verzweifeln.
                  • B Balkonfarmer
                    @balkonfarmer sagte in Kein Anmelden am Alexa Adapter mehr möglich:
                    Dann verwende die?
                      Dann verwende die?
                      Balkonfarmer
                      Da ist aber die fehlerhafte Installation von IoBroker drauf, wo nichts mehr funktioniert. Ich möchte lieber mit einem sauberen OS weitermachen. Hab das Problem jetzt mal in einer Raspi-Gruppe geschildert und warte dort auf Antwort. Es muss doch irgendwie machbar sein.
                      Ro75R 1 Antwort Letzte Antwort
                      • B Balkonfarmer
                        Ro75R Offline
                        Ro75R Offline
                        Ro75
                        @balkonfarmer du hast aber eine neue, frische SD-Karte genommen?
                        Ro75.
                        • B Balkonfarmer
                          Wie kann denn auf einem frischen Flash eine krumme Installation drauf sein?
                          Also irgendwie verstehe ich überhaupt nicht was du da genau veranstaltest.
                          HomoranH B 2 Antworten Letzte Antwort
                            mir schwant fischiges
                              Balkonfarmer
                              Ja, bei mir läuft es etwas komplizierter. Ich habe 2 SSD auf einer mit 16 GB mache ich immer eine Installation und wenn die läuft, kopiere ich die auf eine andere, um diese als Notfall aufzubewahren. Auf der größeren war mehr oder weniger ein Versuch, das Backup aufzuspielen. Ich habe also auf dieser das OS geflasht, iobroker installiert und dann versucht das Backup aufzusetzen. Weil Ihr gesagt habt, ich solle länger warten, habe ich das Ganze nochmal auf der 16 GB probiert, was ebenfalls fehlschlug. Ich hatte also 2 SSD mit einem fehlerhaften IoBroker. Jetzt wollte ich auf die 16 GB wieder das OS flashen, was auch funktioniert, aber aus irgendeinem Grund flasht er die Verbindungsdaten zum WIFI nicht mehr, so dass ich nicht weiterkomme. Mit einer frischen µSD hab ich es auch versucht.
                              Da ich vor größeren Eingriffen immer ein Image von der SSD ziehe (daher die 16 GB), kann ich zur Not immer wieder zurück zum Alten. Mittlerweile habe ich auf der 16 GB wieder ein altes Image, wo ich auch den Alexa Adapter zum Laufen bekommen habe. Jetzt werde ich erstmal damit arbeiten. Ich weiß, das löst das Problem nicht, aber zumindest läuft es erstmal.
                              Um weiter zu kommen, muss ich erstmal herausfinden, warum der Raspberry Pi Imager keine Verbindungsdaten mehr mit dem OS flasht, obwohl ich das alles ausgewählt und eingegeben habe. Ich könnte auch mit LAN weitermachen, aber das ist keine Dauerlösung, weil ich dafür einen Port am Router opfern müsste.
                              Ich bin Dir auf jeden Fall dankbar, weil Du mir helfen möchtest und geholfen hast. Ich bleibe am Ball, aber derzeit muss ich mich erstmal um einen Wasserschaden im Bad kümmern.
                              • B Balkonfarmer
                                Das macht man nicht so.
                                  Balkonfarmer
                                  Ich weiß, aber anders ist es nicht möglich. Wie gesagt, ich mache mir gern ein Image und ziehe das auf eine größere SSD. Würde ich es auf der großen gleich installieren, wäre das Image dann auch größer. Auf der 16 GB SSD kann ich es nicht laufen lassen, weil ich Luftdaten aufzeichne und da wäre die SSD nach einem Jahr voll. Mit "kopieren" habe ich mich auch falsch ausgedrückt, denn ich klone die SSD ja in dem Sinne. Jedenfalls hat mir meine Methode ja nun geholfen, denn derzeit läuft es ja erstmal. Zwar mit altem OS und alten Adapterversionen, aber es funktioniert. Wenn ich dann wieder ein neues OS flashen kann, dann mache ich mit dem Backup weiter. Ich habe auch schon überlegt, alles komplett neu zu machen, aber in der VIS steckt viel Arbeit und die wollte ich nicht nochmal machen.
                                  • B Balkonfarmer
                                    Dann funktioniert es ja nicht so wie es soll...
                                    Grundsätzlich halte ich nix von der ganzen klonerei. Gibt in der Regel früher oder später Probleme.
                                    Und ich würde auch einen Server nie per Wifi anbinden. Immer Kabel.
                                      Matzeit
                                      Vielleicht wäre das ein guter Zeitpunkt den Raspberry gegen einen MiniPC (Thinkcentre Tiny, Dell 3050 etc.) zu tauschen? Darauf dann ersteinmal Proxmox drauf und dann in einer Debian VM den iobroker installieren. Somit kannst du deine VM bequem sichern.
                                      @Balkonfarmer
                                      mit SSD meinst du sicherlich SD-Karte oder?
                                      Falls es bei dir an Ports mangelt, würde ich vielleicht einen kleinen Switch mit mehr Ports kaufen und an den Router hängen. Aus Erfahrung kann ich ebenso sagen, dass es viel Last von einem nimmt, wenn man seine Hardware per LAN direkt verkabeln kann.
