  4. ADMIN-Update: failed to fetch
    6.7k
15 Beiträge 4 Kommentatoren 850 Aufrufe 4 Beobachtet
    @mwendt84
    Mit welchen Versionen unterwegs?
    Schau dir die Ausgabe von
    iob diag
    an.
    mwendt84
    @thomas-braun said in ADMIN-Update: failed to fetch:
    iob diag
    Danke für die schnelle Rückmeldung.
    Hier der Auszug aus:
    Core adapters versions
    js-controller: 6.0.11
    admin: 7.1.5
    javascript: 8.8.3
    Brauchst du weitere Infos?
    • M mwendt84
      iob diag
      admin: 7.1.5
      javascript: 8.8.3
      @mwendt84 sagte in ADMIN-Update: failed to fetch:
      die gesamte Langfassung hier als Text in code-tags posten
        mwendt84
        ```bash
        Script v.2025-03-08
        *** BASE SYSTEM ***
         Static hostname: martin-ENNS11HR
               Icon name: computer-laptop
                 Chassis: laptop 💻
        Operating System: Ubuntu 24.04.2 LTS
                  Kernel: Linux 6.8.0-62-generic
            Architecture: x86-64
         Hardware Vendor: Packard Bell
          Hardware Model: ENNS11HR
        Firmware Version: V2.19
           Firmware Date: Mon 2012-03-19
            Firmware Age: 13y 3month 1w 4d
        OS is similar to: debian
        model name      : Intel(R) Pentium(R) CPU B950 @ 2.10GHz
        Docker          : false
        Virtualization  : none
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         10:00:39 up 3 min,  2 users,  load average: 5.02, 2.64, 1.06
        CPU threads: 2
        *** LIFE CYCLE STATUS ***
        Operating System is the current Ubuntu LTS release codenamed 'noble'!
        *** TIME AND TIMEZONES ***
                       Local time: Mon 2025-06-30 10:00:39 CEST
                   Universal time: Mon 2025-06-30 08:00:39 UTC
                         RTC time: Mon 2025-06-30 08:00:39
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        martin
        HOME=/home/martin
        GROUPS=martin adm cdrom sudo dip plugdev lpadmin lxd sambashare iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth
        *** DISPLAY-SERVER SETUP ***
        Display-Server: true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            8.1G        2.7G        3.6G        127M        2.1G        5.4G
        Swap:           2.1G          0B        2.1G
        Total:           10G        2.7G        5.8G
        Active iob-Instances:   3
                 7753 M total memory
                 2572 M used memory
                 2865 M active memory
                  941 M inactive memory
                 3442 M free memory
                  109 M buffer memory
                 1925 M swap cache
                 2047 M total swap
                    0 M used swap
                 2047 M free swap
        top - 10:00:40 up 3 min,  2 users,  load average: 5.02, 2.64, 1.06
        Tasks: 252 total,   4 running, 248 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 84.0 us, 12.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  4.0 si,  0.0 st
        MiB Mem :   7753.6 total,   3432.8 free,   2581.7 used,   2035.7 buff/cache
        MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   5171.9 avail Mem
        *** FAILED SERVICES ***
          UNIT              LOAD   ACTIVE SUB    DESCRIPTION
        * motioneye.service loaded failed failed motionEye Server
        Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                SUB    -> The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        tmpfs          tmpfs     776M  1.9M  774M   1% /run
        /dev/sda2      ext4      117G   40G   71G  37% /
        tmpfs          tmpfs     3.8G  8.0K  3.8G   1% /dev/shm
        tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
        efivarfs       efivarfs   56K   15K   37K  28% /sys/firmware/efi/efivars
        /dev/sda1      vfat      511M  6.2M  505M   2% /boot/efi
        tmpfs          tmpfs     776M  104K  776M   1% /run/user/1000
        [Mon Jun 30 09:57:38 2025] EXT4-fs (sda2): mounted filesystem 70f30a5c-5bfd-4b52-aa43-9d41c3f2e7fa ro with ordered data mode. Quota mode: none.
        [Mon Jun 30 09:57:39 2025] EXT4-fs (sda2): re-mounted 70f30a5c-5bfd-4b52-aa43-9d41c3f2e7fa r/w. Quota mode: none.
        Show mounted filesystems:
        TARGET                                   SOURCE                         FSTYPE      OPTIONS
        /                                        /dev/sda2                      ext4        rw,relatime,errors=remount-ro
        |-/run/user/1000/doc                     portal                         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        |-/snap/core18/2855                      /dev/loop1                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/bare/5                           /dev/loop0                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/core18/2887                      /dev/loop3                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/core20/2582                      /dev/loop2                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/core20/2599                      /dev/loop4                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/core22/1981                      /dev/loop5                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/core22/2010                      /dev/loop6                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/dotnet-runtime-31/35             /dev/loop7                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/dotnet-runtime-31/36             /dev/loop8                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/dotnet-sdk/255                   /dev/loop9                     squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/dotnet-sdk/256                   /dev/loop11                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/firefox/6421                     /dev/loop10                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/firefox/6436                     /dev/loop12                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/firmware-updater/167             /dev/loop13                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/gnome-3-38-2004/140              /dev/loop14                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/gnome-3-38-2004/143              /dev/loop15                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/gnome-42-2204/176                /dev/loop16                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/gnome-42-2204/202                /dev/loop17                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/gtk-common-themes/1534           /dev/loop18                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/gtk-common-themes/1535           /dev/loop19                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/snap-store/1113                  /dev/loop20                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/snap-store/1216                  /dev/loop21                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/snapd/24505                      /dev/loop22                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/snapd-desktop-integration/247    /dev/loop23                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/snapd/24718                      /dev/loop24                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/snapd-desktop-integration/253    /dev/loop25                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/snap/thunderbird/737                  /dev/loop26                    squashfs    ro,nodev,relatime,errors=continue,threads=single
        |-/boot/efi                              /dev/sda1                      vfat        rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
        `-/var/snap/firefox/common/host-hunspell /dev/sda2[/usr/share/hunspell] ext4        ro,noexec,noatime,errors=remount-ro
        /var:
        17G     /var/
        12G     /var/lib
        5.3G    /var/lib/snapd
        4.7G    /var/log
        4.0G    /var/log/journal/92ed3414d92e43bdaa0a2562ec0ab83f
        Archived and active journals take up 3.9G in the file system.
        /opt/iobroker/backups:
        9.3G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.1G    /opt/iobroker/iobroker-data/
        914M    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
        24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
        19M     /opt/iobroker/iobroker-data/files/cameras.admin/static/js/main.b371dc6f.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.19.3
        /usr/bin/node           v20.19.3
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.32.0
        nodejs:
          Installed: 20.19.3-1nodesource1
          Candidate: 20.19.3-1nodesource1
          Version table:
         *** 20.19.3-1nodesource1 100
             18.19.1+dfsg-6ubuntu5 500
                500 http://de.archive.ubuntu.com/ubuntu noble/universe amd64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        martin-ENNS11HR     martin-ENNS11HR (version: 6.0.11, hostname: martin-ENNS11HR, alive, uptime: 63)
        admin:          7.1.5
        javascript:     8.8.3
        nodejs modules from github:     3
        +-- iobroker.smartthings@0.1.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#0921ba9cef4d6b62375f339126457f3429d0448f)
        +-- iobroker.vis-materialdesign@0.5.29 (git+ssh://git@github.com/Scrounger/ioBroker.vis-materialdesign.git#94d4b6799249615ba7c3d93cff0fb7515a31822a)
        +-- iobroker.vw-connect@0.7.7 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#7c8856acd031772fc619cd1ed50fc15294c6f5fb)
        Adapter State
          system.adapter.admin.0                  : admin                 : martin-ENNS11HR                          - disabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alexa2.0                 : alexa2                : martin-ENNS11HR                          -  enabled
          system.adapter.backitup.0               : backitup              : martin-ENNS11HR                          -  enabled
          system.adapter.cameras.0                : cameras               : martin-ENNS11HR                          -  enabled, port: 8200, bind: 127.0.0.1
          system.adapter.chromecast.0             : chromecast            : martin-ENNS11HR                          -  enabled
          system.adapter.daswetter.0              : daswetter             : martin-ENNS11HR                          -  enabled
          system.adapter.deyeidc.0                : deyeidc               : martin-ENNS11HR                          -  enabled, port: 8899
          system.adapter.discovery.0              : discovery             : martin-ENNS11HR                          -  enabled
        + system.adapter.email.0                  : email                 : martin-ENNS11HR                          -  enabled
          system.adapter.hm-rega.0                : hm-rega               : martin-ENNS11HR                          -  enabled
          system.adapter.hm-rpc.0                 : hm-rpc                : martin-ENNS11HR                          -  enabled, port: 0
          system.adapter.hm-rpc.1                 : hm-rpc                : martin-ENNS11HR                          -  enabled, port: 0
          system.adapter.hm-rpc.2                 : hm-rpc                : martin-ENNS11HR                          -  enabled, port: 0
          system.adapter.ical.0                   : ical                  : martin-ENNS11HR                          -  enabled
          system.adapter.icons-material-png.0     : icons-material-png    : martin-ENNS11HR                          - disabled
        + system.adapter.influxdb.0               : influxdb              : martin-ENNS11HR                          -  enabled, port: 8086
          system.adapter.iot.0                    : iot                   : martin-ENNS11HR                          -  enabled
          system.adapter.javascript.0             : javascript            : martin-ENNS11HR                          -  enabled
          system.adapter.modbus.0                 : modbus                : martin-ENNS11HR                          -  enabled
          system.adapter.mqtt.0                   : mqtt                  : martin-ENNS11HR                          -  enabled, port: 1883, bind: 192.168.0.7
          system.adapter.onvif.0                  : onvif                 : martin-ENNS11HR                          - disabled, port: 8899
          system.adapter.openweathermap.0         : openweathermap        : martin-ENNS11HR                          -  enabled
          system.adapter.ping.0                   : ping                  : martin-ENNS11HR                          -  enabled
          system.adapter.pollenflug.0             : pollenflug            : martin-ENNS11HR                          -  enabled
          system.adapter.shelly.0                 : shelly                : martin-ENNS11HR                          -  enabled, port: 1882, bind: 0.0.0.0
          system.adapter.smartthings.0            : smartthings           : martin-ENNS11HR                          -  enabled
          system.adapter.tankerkoenig.0           : tankerkoenig          : martin-ENNS11HR                          -  enabled
          system.adapter.tr-064.0                 : tr-064                : martin-ENNS11HR                          - disabled
          system.adapter.tuya.0                   : tuya                  : martin-ENNS11HR                          -  enabled
          system.adapter.upnp.0                   : upnp                  : martin-ENNS11HR                          -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : martin-ENNS11HR                          -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : martin-ENNS11HR                          - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : martin-ENNS11HR                          - disabled
          system.adapter.vis-weather.0            : vis-weather           : martin-ENNS11HR                          - disabled
          system.adapter.vis.0                    : vis                   : martin-ENNS11HR                          -  enabled
          system.adapter.vw-connect.0             : vw-connect            : martin-ENNS11HR                          -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : martin-ENNS11HR                          -  enabled
          system.adapter.web.0                    : web                   : martin-ENNS11HR                          -  enabled, port: 8083, bind: 192.168.0.7, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "admin"        : 7.6.17   , installed 7.1.5  [Updatable]
        Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
        Adapter    "backitup"     : 3.2.2    , installed 3.0.25 [Updatable]
        Adapter    "cameras"      : 2.1.2    , installed 2.1.2
        Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
        Adapter    "daswetter"    : 3.2.3    , installed 3.2.2  [Updatable]
        Adapter    "deyeidc"      : 0.2.0    , installed 0.2.0
        Adapter    "email"        : 2.0.4    , installed 1.3.1  [Updatable]
        Adapter    "followthesun" : 0.5.2    , installed 0.5.2
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
        Adapter    "ical"         : 1.16.1   , installed 1.16.1
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.9.2    , installed 8.8.3  [Updatable]
        Controller "js-controller": 7.0.6    , installed 6.0.11 [Updatable]
        Adapter    "modbus"       : 6.3.2    , installed 6.3.2
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "onvif"        : 1.1.4    , installed 1.1.4
        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
        Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
        Adapter    "pushsafer"    : 1.1.0    , installed 1.1.0
        Adapter    "shelly"       : 9.5.1    , installed 8.5.1  [Updatable]
        Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
        Adapter    "upnp"         : 1.1.0    , installed 1.1.0
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.29
        Adapter    "vis-weather"  : 2.5.12   , installed 2.5.9  [Updatable]
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "web"          : 7.0.8    , installed 6.2.5  [Updatable]
        Objects and States
        Objects:        17526
        States:         14072
        Hit:1 http://de.archive.ubuntu.com/ubuntu noble InRelease
        Hit:2 http://de.archive.ubuntu.com/ubuntu noble-updates InRelease
        Hit:3 http://de.archive.ubuntu.com/ubuntu noble-backports InRelease
        Hit:4 http://security.ubuntu.com/ubuntu noble-security InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        9563       627/systemd-resolve
        tcp        0      0 127.0.0.1:8200          0.0.0.0:*               LISTEN      1001       28024      4138/io.cameras.0
        tcp        0      0 192.168.0.7:8083        0.0.0.0:*               LISTEN      1001       26583      4088/io.web.0
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20753      3157/iobroker.js-co
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       21764      3157/iobroker.js-co
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12971      1192/cupsd
        tcp        0      0 192.168.0.7:8701        0.0.0.0:*               LISTEN      1001       21301      3412/io.hm-rpc.1
        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      998        14605      1314/influxd
        tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      131        12755      973/motion
        tcp        0      0 127.0.0.1:8080          0.0.0.0:*               LISTEN      131        12756      973/motion
        tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      101        9565       627/systemd-resolve
        tcp        0      0 192.168.0.7:2001        0.0.0.0:*               LISTEN      1001       22493      3384/io.hm-rpc.0
        tcp        0      0 192.168.0.7:2010        0.0.0.0:*               LISTEN      1001       22551      3432/io.hm-rpc.2
        tcp        0      0 192.168.0.7:1884        0.0.0.0:*               LISTEN      1001       22609      3462/io.mqtt.0
        tcp        0      0 192.168.0.7:1883        0.0.0.0:*               LISTEN      1001       22608      3462/io.mqtt.0
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          4368       1/init
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12970      1192/cupsd
        tcp6       0      0 :::8086                 :::*                    LISTEN      998        13766      1314/influxd
        tcp6       0      0 :::3389                 :::*                    LISTEN      126        13241      1242/xrdp
        tcp6       0      0 :::3000                 :::*                    LISTEN      130        14666      1309/grafana-server
        tcp6       0      0 ::1:3350                :::*                    LISTEN      0          12122      1211/xrdp-sesman
        tcp6       0      0 :::111                  :::*                    LISTEN      0          3464       1/init
        tcp6       0      0 :::22                   :::*                    LISTEN      0          11402      1/init
        udp        0      0 0.0.0.0:56542           0.0.0.0:*                           115        12502      967/avahi-daemon: r
        udp        0      0 0.0.0.0:36259           0.0.0.0:*                           1001       27044      4037/io.upnp.0
        udp        0      0 127.0.0.54:53           0.0.0.0:*                           101        9564       627/systemd-resolve
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        9562       627/systemd-resolve
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          3463       1/init
        udp        0      0 0.0.0.0:57914           0.0.0.0:*                           1001       27045      4037/io.upnp.0
        udp        0      0 0.0.0.0:1194            0.0.0.0:*                           0          13520      1312/openvpn
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       25786      3922/io.chromecast.
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        12500      967/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       24083      3693/io.shelly.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       28942      4037/io.upnp.0
        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       28941      4037/io.upnp.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       25459      3798/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       25460      3798/io.tuya.0
        udp6       0      0 :::52477                :::*                                115        12503      967/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          3465       1/init
        udp6       0      0 fe80::2c46:71a9:c02:546 :::*                                0          14637      1041/NetworkManager
        udp6       0      0 :::5353                 :::*                                115        12501      967/avahi-daemon: r
        2025-06-30 10:02:27.849  - error: daswetter.0 (3967) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_2.day_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.day_value": Connection is closed.]
        2025-06-30 10:02:27.850  - error: daswetter.0 (3967) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.symbol_desc2": Connection is closed.
        2025-06-30 10:02:27.863  - error: daswetter.0 (3967) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_2.symbol_desc2: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.symbol_desc2": Connection is closed.]
        2025-06-30 10:02:27.863  - error: daswetter.0 (3967) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.symbol_value2": Connection is closed.
        2025-06-30 10:02:27.864  - error: daswetter.0 (3967) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_2.symbol_value2: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.symbol_value2": Connection is closed.]
        2025-06-30 10:02:27.871  - error: daswetter.0 (3967) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.symbol_desc": Connection is closed.
        2025-06-30 10:02:27.874  - error: daswetter.0 (3967) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_2.symbol_desc: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.symbol_desc": Connection is closed.]
        2025-06-30 10:02:27.882  - error: daswetter.0 (3967) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.symbol_value": Connection is closed.
        2025-06-30 10:02:27.887  - error: daswetter.0 (3967) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_2.symbol_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.symbol_value": Connection is closed.]
        2025-06-30 10:02:27.894  - error: daswetter.0 (3967) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.iconURL": Connection is closed.
        2025-06-30 10:02:27.903  - error: daswetter.0 (3967) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_2.iconURL: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.iconURL": Connection is closed.]
        2025-06-30 10:02:27.904  - error: daswetter.0 (3967) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.tempmin_value": Connection is closed.
        2025-06-30 10:02:27.904  - error: daswetter.0 (3967) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_2.tempmin_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.tempmin_value": Connection is closed.]
        2025-06-30 10:02:27.905  - error: daswetter.0 (3967) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.tempmax_value": Connection is closed.
        2025-06-30 10:02:27.905  - error: daswetter.0 (3967) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_2.tempmax_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.tempmax_value": Connection is closed.]
        2025-06-30 10:02:27.920  - error: daswetter.0 (3967) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.wind_symbolB": Connection is closed.
        2025-06-30 10:02:27.921  - error: daswetter.0 (3967) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_2.wind_symbolB: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.wind_symbolB": Connection is closed.]
        2025-06-30 10:02:27.921  - error: daswetter.0 (3967) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.wind_symbol": Connection is closed.
        2025-06-30 10:02:27.930  - error: daswetter.0 (3967) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_2.wind_symbol: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.wind_symbol": Connection is closed.]
        2025-06-30 10:02:27.931  - error: daswetter.0 (3967) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.wind_value": Connection is closed.
        2025-06-30 10:02:27.931  - error: daswetter.0 (3967) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_2.wind_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.wind_value": Connection is closed.]
        2025-06-30 10:02:27.938  - error: daswetter.0 (3967) Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.windIconURL": Connection is closed.
        2025-06-30 10:02:27.943  - error: daswetter.0 (3967) exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_2.windIconURL: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.windIconURL": Connection is closed.]
        2025-06-30 10:02:28.167  - info: javascript.0 (3255) received all states
        2025-06-30 10:02:28.405  - error: host.martin-ENNS11HR instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
        Bitte schön :-)
        • M mwendt84
          Hallo Zusammen.
          Seit einiger Zeit lässt sich der Admin-Adapter nicht mehr aktualisieren.
          Nach kurzer Zeit kommt die Meldung. Dann friert ioBroker für ein paar Minuten ein und geht dann wieder.
          Was kann ich tun? Im LOG finde ich leider keine Hinweise. Die Suche hat auch keine vergleichbaren Probleme ergeben.
          Vielen Dank im Voraus.
          Martin
          wendy2702W Offline
          wendy2702W Offline
          @mwendt84 wie lange wartest du wenn das passiert?
          Ich hatte das auch schon mal beim Update über GUI.
          Im Hintergrund hat er das Update trotzdem gemacht.
          Dazu solltest du was im log finden.
          • wendy2702W wendy2702
            mwendt84
            @wendy2702 schon ne ganze Weile. Das Problem besteht auch schon länger, hat bisher aber nicht wirklich gestört.
            Würde das Update im Hintergrund doch laufen, sollte die Option auf das Update ja verschwinden, oder?
            • M mwendt84
              ```bash
              Script v.2025-03-08
              *** BASE SYSTEM ***
                       Chassis: laptop 💻
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
              CPU threads: 2
                            NTP service: active
                        RTC in local TZ: no
              martin
              HOME=/home/martin
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:           2.1G          0B        2.1G
                       7753 M total memory
                       2572 M used memory
                       3442 M free memory
                        109 M buffer memory
                       1925 M swap cache
                       2047 M total swap
                          0 M used swap
                       2047 M free swap
              *** FILESYSTEM ***
              /var:
              17G     /var/
              12G     /var/lib
              5.3G    /var/lib/snapd
              4.7G    /var/log
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.1.5
              javascript:     8.8.3
              Adapter State
              + instance is alive
              Objects and States
              Objects:        17526
              States:         14072
              Pending Updates: 0
              Bitte schön :-)
              @mwendt84
              Leg dir die nodesource-Quelle richtig an.
              iob nodejs-update 20
              sollte das tun.
              Und dann den ganzen Sums auf einen aktuellen Stand bringen.
              iob update
              iob stop
              iob upgrade self
              iob upgrade all
              iob start
              Und schalt die graphische Oberfläche aus.
                @mwendt84
                sollte das tun.
                iob update
                iob stop
                iob upgrade self
                iob upgrade all
                iob start
                mwendt84
                Danke sehr. Nun läuft wieder alles :-)
                Aber was meinst du mit: graphischer Oberfläche ausschalten?
                • M mwendt84
                  @mwendt84
                  Damit ist das gemeint:
                  Eigentlich sollte da auch noch ein Text dazu erscheinen, das man Server immer ohne DisplayServer betreibt.
                  Und auch ohne RemoteDesktop.
                  nodesource-Quelle ist jetzt angelegt?
                    @mwendt84
                    mwendt84
                    ich denke ja. Die Befehl ist ohne Fehler durchgelaufen.
                    • M mwendt84
                      ich denke ja.
                      Schau nach. Steht in
                      iob diag
                      drin.
                      • M mwendt84
                        ich denke
                        dann zeig den aktuellen iob diag, dann weiss man es
                          ich denke
                          mwendt84
                          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                          Falls es das nicht ist, hier der komplette Auszug:
                          ```bash
                          Script v.2025-03-08
                          *** BASE SYSTEM ***
                                   Chassis: laptop 💻
                              Firmware Age: 13y 3month 1w 5d
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                           21:18:30 up 11:20,  2 users,  load average: 0.81, 0.41, 0.45
                          CPU threads: 2
                                         Local time: Mon 2025-06-30 21:18:30 CEST
                                     Universal time: Mon 2025-06-30 19:18:30 UTC
                                           RTC time: Mon 2025-06-30 19:18:30
                                        NTP service: active
                                    RTC in local TZ: no
                          martin
                          HOME=/home/martin
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            8.1G        3.8G        294M        110M        4.2G        4.4G
                          Swap:           2.1G          0B        2.1G
                          Total:           10G        3.8G        2.4G
                          Active iob-Instances:   27
                                   7753 M total memory
                                   3594 M used memory
                                   4096 M active memory
                                   2628 M inactive memory
                                    281 M free memory
                                    809 M buffer memory
                                   3206 M swap cache
                                   2047 M total swap
                                      0 M used swap
                                   2047 M free swap
                          top - 21:18:30 up 11:20,  2 users,  load average: 0.81, 0.41, 0.45
                          Tasks: 252 total,   1 running, 251 sleeping,   0 stopped,   0 zombie
                          %Cpu(s): 20.0 us, 12.0 sy,  0.0 ni, 68.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :   7753.6 total,    281.3 free,   3594.7 used,   4016.5 buff/cache
                          MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   4158.9 avail Mem
                                  ACTIVE -> The high-level unit activation state, i.e. generalization of S        UB.
                                  SUB    -> The low-level unit activation state, values depend on unit typ        e.
                          *** FILESYSTEM ***
                          /dev/sda2      ext4      117G   39G   72G  36% /
                          [Mon Jun 30 10:04:20 2025] EXT4-fs (sda2): mounted filesystem 70f30a5c-5bfd-4b52        -aa43-9d41c3f2e7fa ro with ordered data mode. Quota mode: none.
                          [Mon Jun 30 10:04:21 2025] EXT4-fs (sda2): re-mounted 70f30a5c-5bfd-4b52-aa43-9d        41c3f2e7fa r/w. Quota mode: none.
                          |-/run/user/1000/doc                     portal                         fuse.por        tal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                          |-/boot/efi                              /dev/sda1                      vfat        rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname        =mixed,errors=remount-ro
                          `-/snap/snapd-desktop-integration/315    /dev/loop27                    squashfs        ro,nodev,relatime,errors=continue,threads=single
                          /var:
                          17G     /var/
                          12G     /var/lib
                          5.3G    /var/lib/snapd
                          4.9G    /var/log
                          4.1G    /var/log/journal/92ed3414d92e43bdaa0a2562ec0ab83f
                          Archived and active journals take up 4.0G in the file system.
                          478M    /opt/iobroker/iobroker-data/
                          311M    /opt/iobroker/iobroker-data/files
                          117M    /opt/iobroker/iobroker-data/backup-objects
                          48M     /opt/iobroker/iobroker-data/files/iot.admin
                          47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
                          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.m        ap
                          24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.j        s.map
                          23M     /opt/iobroker/iobroker-data/objects.jsonl
                          19M     /opt/iobroker/iobroker-data/files/cameras.admin/static/js/main.b371dc6f.        js.map
                          USB-Devices by-id:
                          USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                           *** 20.19.3-1nodesource1 1001
                                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                               20.19.2-1nodesource1 1001
                               20.19.1-1nodesource1 1001
                               20.19.0-1nodesource1 1001
                               20.18.3-1nodesource1 1001
                               20.18.2-1nodesource1 1001
                               20.18.1-1nodesource1 1001
                               20.18.0-1nodesource1 1001
                               20.17.0-1nodesource1 1001
                               20.16.0-1nodesource1 1001
                               20.15.1-1nodesource1 1001
                               20.15.0-1nodesource1 1001
                               20.14.0-1nodesource1 1001
                               20.13.1-1nodesource1 1001
                               20.13.0-1nodesource1 1001
                               20.12.2-1nodesource1 1001
                               20.12.1-1nodesource1 1001
                               20.12.0-1nodesource1 1001
                               20.11.1-1nodesource1 1001
                               20.11.0-1nodesource1 1001
                               20.10.0-1nodesource1 1001
                               20.9.0-1nodesource1 1001
                               20.8.1-1nodesource1 1001
                               20.8.0-1nodesource1 1001
                               20.7.0-1nodesource1 1001
                               20.6.1-1nodesource1 1001
                               20.6.0-1nodesource1 1001
                               20.5.1-1nodesource1 1001
                               20.5.0-1nodesource1 1001
                               20.4.0-1nodesource1 1001
                               20.3.1-1nodesource1 1001
                               20.3.0-1nodesource1 1001
                               20.2.0-1nodesource1 1001
                               20.1.0-1nodesource1 1001
                               20.0.0-1nodesource1 1001
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          martin-ENNS11HR     martin-ENNS11HR (version: 7.0.6, hostname: martin-ENNS11HR, alive, uptime: 35569)
                          js-controller:  7.0.6
                          admin:          7.6.17
                          javascript:     8.9.2
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : martin-ENNS11HR                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.backitup.0               : backitup              : martin-ENNS11HR                          -  enabled
                          + system.adapter.cameras.0                : cameras               : martin-ENNS11HR                          -  enabled, port: 8200, bind: 127.0.0.1
                          + system.adapter.chromecast.0             : chromecast            : martin-ENNS11HR                          -  enabled
                          + system.adapter.deyeidc.0                : deyeidc               : martin-ENNS11HR                          -  enabled, port: 8899
                          + system.adapter.discovery.0              : discovery             : martin-ENNS11HR                          -  enabled
                          + system.adapter.followthesun.0           : followthesun          : martin-ENNS11HR                          -  enabled
                          + system.adapter.hm-rega.0                : hm-rega               : martin-ENNS11HR                          -  enabled
                          + system.adapter.hm-rpc.0                 : hm-rpc                : martin-ENNS11HR                          -  enabled, port: 0
                          + system.adapter.hm-rpc.1                 : hm-rpc                : martin-ENNS11HR                          -  enabled, port: 0
                          + system.adapter.hm-rpc.2                 : hm-rpc                : martin-ENNS11HR                          -  enabled, port: 0
                          + system.adapter.iot.0                    : iot                   : martin-ENNS11HR                          -  enabled
                          + system.adapter.javascript.0             : javascript            : martin-ENNS11HR                          -  enabled
                          + system.adapter.modbus.0                 : modbus                : martin-ENNS11HR                          -  enabled
                          + system.adapter.mqtt.0                   : mqtt                  : martin-ENNS11HR                          -  enabled, port: 1883, bind: 192.168.0.7
                          + system.adapter.ping.0                   : ping                  : martin-ENNS11HR                          -  enabled
                          + system.adapter.pollenflug.0             : pollenflug            : martin-ENNS11HR                          -  enabled
                          + system.adapter.shelly.0                 : shelly                : martin-ENNS11HR                          -  enabled, port: 1882, bind: 0.0.0.0
                          + system.adapter.smartthings.0            : smartthings           : martin-ENNS11HR                          -  enabled
                          + system.adapter.tankerkoenig.0           : tankerkoenig          : martin-ENNS11HR                          -  enabled
                          + system.adapter.tuya.0                   : tuya                  : martin-ENNS11HR                          -  enabled
                          + system.adapter.upnp.0                   : upnp                  : martin-ENNS11HR                          -  enabled
                          + system.adapter.vw-connect.0             : vw-connect            : martin-ENNS11HR                          -  enabled
                          + system.adapter.web.0                    : web                   : martin-ENNS11HR                          -  enabled, port: 8083, bind: 192.168.0.7, run as: admin
                          + instance is alive
                          Adapter    "admin"        : 7.6.17   , installed 7.6.17
                          Adapter    "backitup"     : 3.2.2    , installed 3.2.2
                          Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                          Adapter    "email"        : 2.0.4    , installed 2.0.4
                          Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                          Controller "js-controller": 7.0.6    , installed 7.0.6
                          Adapter    "shelly"       : 9.5.1    , installed 9.5.1
                          Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
                          Adapter    "web"          : 7.0.8    , installed 7.0.8
                          Objects and States
                          Objects:        17760
                          States:         14309
                          Hit:1 http://security.ubuntu.com/ubuntu noble-security InRelease
                          Hit:2 http://de.archive.ubuntu.com/ubuntu noble InRelease
                          Hit:3 http://de.archive.ubuntu.com/ubuntu noble-updates InRelease
                          Hit:4 http://de.archive.ubuntu.com/ubuntu noble-backports InRelease
                          Pending Updates: 3
                          tcp        0      0 127.0.0.1:8200          0.0.0.0:*               LISTEN      1001       116833     11411/io.cameras.0
                          tcp        0      0 192.168.0.7:8083        0.0.0.0:*               LISTEN      1001       116174     11351/io.web.0
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       112401     10818/iobroker.js-c
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       113421     10818/iobroker.js-c
                          tcp        0      0 192.168.0.7:8701        0.0.0.0:*               LISTEN      1001       113873     10975/io.hm-rpc.1
                          tcp        0      0 192.168.0.7:2001        0.0.0.0:*               LISTEN      1001       113857     10959/io.hm-rpc.0
                          tcp        0      0 192.168.0.7:2010        0.0.0.0:*               LISTEN      1001       113914     11001/io.hm-rpc.2
                          tcp        0      0 192.168.0.7:1884        0.0.0.0:*               LISTEN      1001       113989     11035/io.mqtt.0
                          tcp        0      0 192.168.0.7:1883        0.0.0.0:*               LISTEN      1001       113988     11035/io.mqtt.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       136076     12379/io.admin.0
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       115725     11251/io.chromecast
                          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       115019     11122/io.shelly.0
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       116763     11318/io.upnp.0
                          udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       116762     11318/io.upnp.0
                          udp        0      0 0.0.0.0:39033           0.0.0.0:*                           1001       115470     11318/io.upnp.0
                          udp        0      0 0.0.0.0:39268           0.0.0.0:*                           1001       115469     11318/io.upnp.0
                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       114535     11176/io.tuya.0
                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       114538     11176/io.tuya.0
                          udp6       0      0 fe80::2c46:71a9:c02:546 :::*                                0          257391     1041/NetworkManager
                          2025-06-30 21:17:59.672  - warn: modbus.0 (37536) [DevID_0] Poll error count: 2 code: "App Timeout"
                          2025-06-30 21:18:01.004  - warn: modbus.0 (37536) [DevID_0] Poll error count: 3 code: "App Timeout"
                          2025-06-30 21:18:04.494  - warn: modbus.0 (37536) Error: undefined
                          2025-06-30 21:18:04.494  - error: modbus.0 (37536) Request timed out.
                          2025-06-30 21:18:04.494  - error: modbus.0 (37536) Client in error state.
                          2025-06-30 21:18:04.495  - warn: modbus.0 (37536) [DevID_0] Poll error count: 1 code: {"err":"timeout","timeout":999}
                          2025-06-30 21:18:05.223  - warn: modbus.0 (37536) [DevID_0] Poll error count: 2 code: "App Timeout"
                          2025-06-30 21:18:06.744  - warn: modbus.0 (37536) [DevID_0] Poll error count: 3 code: "App Timeout"
                          2025-06-30 21:18:28.710  - info: javascript.0 (10872) script.js.common.Rolladen.Rolladen-Beschattung-Buli: Verschattung Buli Verschattung = wahr
                          2025-06-30 21:18:28.710  - info: javascript.0 (10872) script.js.common.Rolladen.Rolladen-Beschattung-Buli: Beschattung-Buli azimut = 130
                          2025-06-30 21:18:28.710  - info: javascript.0 (10872) script.js.common.Rolladen.Rolladen-Beschattung-Garten: Verschattung = wahr
                          2025-06-30 21:18:28.710  - info: javascript.0 (10872) script.js.common.Rolladen.Rolladen-Beschattung-Garten: Sonne azimut > 80
                          2025-06-30 21:18:28.717  - info: javascript.0 (10872) script.js.common.VIS.material_design_wetter: Material Design Widgets: Wetter Skript triggered by 'hm-rpc.2.0017DD89B04E5C.1.ACTUAL_TEMPERATURE'
                          2025-06-30 21:18:41.004  - warn: modbus.0 (37536) Error: undefined
                          2025-06-30 21:18:41.004  - error: modbus.0 (37536) Request timed out.
                          2025-06-30 21:18:41.005  - error: modbus.0 (37536) Client in error state.
                          2025-06-30 21:18:41.005  - warn: modbus.0 (37536) [DevID_0] Poll error count: 1 code: {"err":"timeout","timeout":999}
                          2025-06-30 21:18:58.403  - warn: modbus.0 (37536) Error: undefined
                          2025-06-30 21:18:58.403  - error: modbus.0 (37536) Request timed out.
                          2025-06-30 21:18:58.404  - error: modbus.0 (37536) Client in error state.
                          2025-06-30 21:18:58.405  - warn: modbus.0 (37536) [DevID_0] Poll error count: 1 code: {"err":"timeout","timeout":999}
                          2025-06-30 21:19:03.034  - warn: modbus.0 (37536) Error: undefined
                          2025-06-30 21:19:03.035  - error: modbus.0 (37536) Request timed out.
                          2025-06-30 21:19:03.035  - error: modbus.0 (37536) Client in error state.
                          2025-06-30 21:19:03.035  - warn: modbus.0 (37536) [DevID_0] Poll error count: 1 code: {"err":"timeout","timeout":999}
                          • M mwendt84
                            ```bash
                            Script v.2025-03-08
                            *** BASE SYSTEM ***
                                     Chassis: laptop 💻
                            Docker          : false
                            Kernel          : x86_64
                            Userland        : 64 bit
                            CPU threads: 2
                                          NTP service: active
                                      RTC in local TZ: no
                            martin
                            HOME=/home/martin
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:           2.1G          0B        2.1G
                                     7753 M total memory
                                     3594 M used memory
                                      281 M free memory
                                      809 M buffer memory
                                     3206 M swap cache
                                     2047 M total swap
                                        0 M used swap
                                     2047 M free swap
                            *** FILESYSTEM ***
                            /var:
                            17G     /var/
                            12G     /var/lib
                            5.3G    /var/lib/snapd
                            4.9G    /var/log
                            USB-Devices by-id:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            admin:          7.6.17
                            javascript:     8.9.2
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        17760
                            States:         14309
                            Pending Updates: 3
                            @mwendt84
                            Eigentlich sollte da bei dir dies erscheinen:
                            System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                            Würde dir auch den ganzen gnome, firefox, thunderbird usw. Quark auf einem Server ersparen.
                            Pending Updates: 3
                            Spiel die ein.
