  4. Blockly Schleife am GPIO Pin vom RPI.
    5.4k
19 Beiträge 3 Kommentatoren 3.4k Aufrufe
  • rantanplanR Online
    rantanplanR Online
    rantanplan
    Hallo knopers1
    Probiere es mal so.
    Export:
    <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on" id=";q/.LTbkOqHb5{2bWJS8" x="88" y="37"><field name="OID">Object ID</field>
    <field name="CONDITION">true</field>
    <statement name="STATEMENT"><block type="variables_set" id="8)*UM%ssIY4]cl?JG{RJ"><field name="VAR">zaehler</field>
        <value name="VALUE"><block type="math_number" id="]ef5SYV26!4mP{{{-l^^"><field name="NUM">0</field></block></value>
        <next><block type="comment" id=";dB-iJCvrFX#Nti|VduR"><field name="COMMENT">jede Sekunde ausführen</field>
            <next><block type="schedule_create" id="7YW(GFC|3w8At73kH9Ll"><field name="NAME">schedule</field>
                <value name="SCHEDULE"><shadow type="field_cron" id="iCv]P/jck;daB8PHsv:N"><field name="CRON">* * * * * *</field></shadow></value>
                <statement name="STATEMENT"><block type="comment" id="h4gP}9C#%.[%2y=kbF`]"><field name="COMMENT">10x blinken</field>
                    <next><block type="math_change" id="DoL@{K#@7,~o##`!l^+}"><field name="VAR">zaehler</field>
                        <value name="DELTA"><shadow type="math_number" id="dCStYpx.|_{]0akWy}lp"><field name="NUM">1</field></shadow></value>
                        <next><block type="controls_if" id="*qr+b2)!djax20P_:#t."><mutation else="1"></mutation>
                            <value name="IF0"><block type="logic_compare" id="JH[#Spr1hlZ;6jM5pQt."><field name="OP">GT</field>
                                <value name="A"><block type="variables_get" id="/9-D?8rl),9h^`HKdVP("><field name="VAR">zaehler</field></block></value>
                                <value name="B"><block type="math_number" id=")3MuM(dan%|N6VLx(D4~"><field name="NUM">10</field></block></value></block></value>
                            <statement name="DO0"><block type="schedule_clear" id="A:#M8^UIxz5mF+m12%!`"><field name="NAME">schedule</field></block></statement>
                            <statement name="ELSE"><block type="comment" id="4?c%{LmnK7`}3VRAc2]3"><field name="COMMENT">einschalten</field>
                                <next><block type="control" id="jU:X1l:_T?rouW=h+vHA"><mutation delay_input="false"></mutation>
                                    <value name="VALUE"><block type="logic_boolean" id="J!]au?B|bA]l@C;DG/2o"><field name="BOOL">TRUE</field></block></value>
                                    <next><block type="comment" id="0Sqs}3}^}Mm%Zd14!hn="><field name="COMMENT">ausschalten</field>
                                        <next><block type="comment" id="PL12o02P`Tl7~17/(1*`"><field name="COMMENT">Verzögerung kleiner 1 Sekunde</field>
                                            <next><block type="control" id="8gj)ckTtkjj+p.K8t|T_"><mutation delay_input="true"></mutation>
                                                <field name="DELAY_MS">500</field>
                                                <field name="UNIT">ms</field>
                                                <value name="VALUE"><block type="logic_boolean" id="SQ}g@Kp`vB:S*^TU%ze3"><field name="BOOL">FALSE</field></block></value></block></next></block></next></block></next></block></next></block></statement></block></next></block></next></block></statement></block></next></block></next></block></statement></block></xml>
    ! Grüße
    Rantanplan
      knopers1
      @rantaplan
      bist für mich der Blockly Gott :)
      Ich teste es mal sobald ich zu Hause bin und berichte….
      • AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        Das ist in etwa das was ich vorgeschlagen hab, nur mit Zähler statt Uhrzeit und Schedule statt Intervall ;)
        Würde allerdings tatsächlich ein Intervall verwenden, da das etwas weniger Overhead hat.
          rantanplanR Online
          rantanplan
          @AlCalzone:
          Würde allerdings tatsächlich ein Intervall verwenden, da das etwas weniger Overhead hat. `
          Ja, hast Recht.
          Ich war gerade mit dem Schedule am "spielen" und hatte da die Idee.
          Und warum einfach wenn es auch kompliziert geht :D :D
          Rantanplan
            rantanplanR Online
            rantanplan
            Hier die einfachere (und bessere :oops: ) Version von AlCalzone.
            Export:
            <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on" id=";q/.LTbkOqHb5{2bWJS8" x="38" y="-13"><field name="OID">Object ID</field>
                <next><block type="comment" id=";dB-iJCvrFX#Nti|VduR"><field name="COMMENT">Intervall starten</field>
                    <next><block type="timeouts_setinterval" id="HWQqXWP|VsT+Fz*Ab+|@"><field name="NAME">Intervall</field>
                        <field name="INTERVAL">1000</field>
                                    <statement name="DO0"><block type="timeouts_clearinterval" id="H-qSL3prj3YmbW5`kn+w"><field name="NAME">Intervall</field></block></statement>
                                                <next><block type="comment" id="PL12o02P`Tl7~17/(1*`"><field name="COMMENT">Verzögerung kleiner Intervall Zeit!!!</field>
            Rantanplan
              knopers1
              kann später ausprobieren und werde berichten…. Danke Euch beiden dafür!
                knopers1
                wie vermutet, es geht….. Leider prellt mein Taster ein wenig. Dies hat zu folge, dass die Intervalle zu oft ausgelöst werden. Dann blinkt es nur noch etweder zu kurz, oder ungleichmäßig... Für den Schalterbetrieb wird hierbei ein Pulldown benötigt. Aber wenn ich ein BM als trigger nehme, sollte es keine Probleme bereiten.
                  AlCalzoneA Offline
                  AlCalzone
                  @knopers1:
                  wie vermutet, es geht….. Leider prellt mein Taster ein wenig. Dies hat zu folge, dass die Intervalle zu oft ausgelöst werden. `
                  Ein "stoppe Intervall" zu Beginn des Triggers könnte das beheben. Wobei dann der Zähler zu oft zurückgesetzt wird. Sauber wäre:
                  Wenn Intervall NICHT läuft, dann:
                  • setze Zähler auf 0
                  • starte Intervall
                  Aber kein Plan wie das mit Klickibunti geht, das kann ich nur in Textform ;)
                    knopers1
                    Wo meinst Du es genau? Soll ich es oben drauf packen? :lol: :lol: :mrgreen: :mrgreen: :mrgreen: hehe, gut gelacht hab ich…...
                      rantanplanR Online
                      rantanplan
                      @AlCalzone:
                      • starte Intervall `
                        Bei "KlickiBunti" geht das leider (noch) nicht. ;)
                      "KlickiBunti-Leute" müssen da schon mal nachdenken. :D
                      So sollte die Taste entprellt werden.
                      Export:
                      <xml xmlns="http://www.w3.org/1999/xhtml"><block type="comment" id="#{k%e[{to01DQ.UohMC" x="37" y="-62"><field name="COMMENT">Initialisierung bei Scriptstart</field> <next><block type="variables_set" id="cY|8twokXAk|tCx52]m"><field name="VAR">zaehler</field>
                      <value name="VALUE"><block type="math_number" id="~hs.|8i{sszJUGJb!~Sg"><field name="NUM">0</field></block></value>
                      <next><block type="variables_set" id="(=M+iT3_#LPC4PRUFOj"><field name="VAR">TimerOn</field> <value name="VALUE"><block type="logic_boolean" id="LN,C1@WJT0|UKvUNmWB"><field name="BOOL">FALSE</field></block></value>
                      <next><block type="comment" id="Bvitj`3,WuzK:vgIZwr{"><field name="COMMENT">Triggern</field>
                      <next><block type="on" id=";q/.LTbkOqHb5{2bWJS8"><field name="OID">Object ID</field>
                                      <statement name="STATEMENT"><block type="controls_if" id="/:PVKStC^F(xsisHri7k"><value name="IF0"><block type="logic_compare" id="?I-0QT~eAMMB6h.@06o4"><field name="OP">EQ</field>
                                              <value name="A"><block type="variables_get" id="6Vye,dz+3CM#t#}Q,9MG"><field name="VAR">TimerOn</field></block></value>
                                              <value name="B"><block type="logic_boolean" id="]D},%3E65Tf%jDYJC3!x"><field name="BOOL">FALSE</field></block></value></block></value>
                                          <statement name="DO0"><block type="comment" id=";dB-iJCvrFX#Nti|VduR"><field name="COMMENT">Intervall starten</field>
                                              <next><block type="variables_set" id="XMkaY]a71BOr=x[%kJPo"><field name="VAR">TimerOn</field>
                                                  <value name="VALUE"><block type="logic_boolean" id="R?wJI^Ea|BLUFdk[?`PB"><field name="BOOL">TRUE</field></block></value>
        <statement name="DO0"><block type="variables_set" id=",NvX2rG]TWUe?lDK#7?f"><field name="VAR">zaehler</field>
        <value name="VALUE"><block type="math_number" id="J12u.l:9VqNV+A@%LrH8"><field name="NUM">0</field></block></value>
        <next><block type="variables_set" id="FAv+kZB=iiO_HMV2ADXi"><field name="VAR">TimerOn</field>
        <value name="VALUE"><block type="logic_boolean" id=",}mPhyQ=*S=vmo1n!w`k"><field name="BOOL">FALSE</field></block></value>
        <next><block type="timeouts_clearinterval" id="H-qSL3prj3YmbW5`kn+w"><field name="NAME">Intervall</field></block></next></block></next></block></statement>
        <value name="VALUE"><block type="logic_boolean" id="SQ}g@Kp`vB:S*^TU%ze3"><field name="BOOL">FALSE</field></block></value></block></next></block></next></block></next></block></next></block></statement></block></next></block></next></block></statement></block></next></block></next></block></statement></block></statement></block></next></block></next></block></next></block></next></block></xml>
                      Rantanplan
                        knopers1
                        bin gespannt :mrgreen:
                        ich berichte später ob es geht. :)
                          knopers1
                          @rantaplan
                          DANKE, läuft Top ohne wenn und aber….
