  4. Kein Zugriff mehr auf Admin Oberfläche
    6.7k
19 Beiträge 4 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • M Mr.X
    @Thomas-Braun
    permitted by applicable law.
    Last login: Tue Jun  3 18:57:02 2025 from 192.168.178.28
    tadek@ioBrokerVM:~$ iob diag
    [sudo] Passwort für tadek:
    /usr/bin/iob: Zeile 21: /home/iobroker/iob_diag.log: Keine Berechtigung
    tadek@ioBrokerVM:~$
    @mr-x Ist der tadek in der Gruppe iobroker?
    Wie sehen die Rechte an /home/iobroker aus?
    id
    ls -l /home/
    anschauen.
      id
      ls -l /home/
      anschauen.
      Mr.X
      schrieb am zuletzt editiert von Mr.X
      Nach iob fix ging es
      ```bash
      Script v.2025-03-08
      *** BASE SYSTEM ***
       Static hostname: ioBrokerVM
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-35-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
      OS is similar to:
      model name      : QEMU Virtual CPU version 2.5+
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       19:01:31 up 2 days, 12 min,  2 users,  load average: 0.43, 0.21, 0.07
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
                     Local time: Tue 2025-06-03 19:01:31 CEST
                 Universal time: Tue 2025-06-03 17:01:31 UTC
                       RTC time: Tue 2025-06-03 17:01:31
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      tadek
      HOME=/home/tadek
      GROUPS=tadek cdrom floppy sudo audio dip video plugdev users netdev iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.1G        1.1G        2.1G        548K        1.1G        3.0G
      Swap:           1.0G          0B        1.0G
      Total:          5.1G        1.1G        3.1G
      Active iob-Instances:   3
               3914 M total memory
               1072 M used memory
                475 M active memory
               1167 M inactive memory
               2008 M free memory
                253 M buffer memory
                840 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      top - 19:01:31 up 2 days, 12 min,  2 users,  load average: 0.43, 0.21, 0.07
      Tasks: 113 total,   1 running, 112 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3914.7 total,   2008.4 free,   1072.9 used,   1094.2 buff/cache
      MiB Swap:    975.0 total,    975.0 free,      0.0 used.   2841.8 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  1.9G     0  1.9G   0% /dev
      tmpfs          tmpfs     392M  544K  391M   1% /run
      /dev/sda1      ext4       62G  4.5G   55G   8% /
      tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
      [Sun Jun  1 18:48:43 2025] EXT4-fs (sda1): mounted filesystem with ordered data        mode. Quota mode: none.
      [Sun Jun  1 18:48:44 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      512M    /var/
      249M    /var/cache
      241M    /var/cache/apt
      173M    /var/lib
      165M    /var/cache/apt/archives
      Archived and active journals take up 12.1M in the file system.
      /opt/iobroker/backups:
      30M     /opt/iobroker/backups/
      696K    /opt/iobroker/backups/jarvis_0
      /opt/iobroker/iobroker-data:
      352M    /opt/iobroker/iobroker-data/
      269M    /opt/iobroker/iobroker-data/files
      59M     /opt/iobroker/iobroker-data/backup-objects
      48M     /opt/iobroker/iobroker-data/files/iot.admin
      47M     /opt/iobroker/iobroker-data/files/iot.admin/static/js
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.m        ap
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.j        s.map
      12M     /opt/iobroker/iobroker-data/objects.jsonl
      9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
      USB-Devices by-id:
      USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_2e66e30c326cef1192        d399adc169b110-if00-port0
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyUSB0
      HINT:
      Your zigbee.1 COM-Port is NOT matching 'by-id'. Please check your setting:
      tcp
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.2
      /usr/bin/node           v20.19.2
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.31.0
      nodejs:
        Installed: 20.19.2-1nodesource1
        Candidate: 20.19.2-1nodesource1
        Version table:
       *** 20.19.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
           20.19.1-1nodesource1 1001
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main am        d64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      ioBrokerVM          ioBrokerVM (version: 7.0.6, hostname: ioBrokerVM    , alive,        uptime: 16)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.17
      javascript:     8.9.2
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : ioBrokerVM        -  enabled, port: 8081, bind: 127.0.0.1, run as: ad        min
        system.adapter.alexa2.0                 : alexa2                : ioBrokerVM        -  enabled
        system.adapter.backitup.0               : backitup              : ioBrokerVM        -  enabled
        system.adapter.cloud.0                  : cloud                 : ioBrokerVM        -  enabled
        system.adapter.cloud.1                  : cloud                 : ioBrokerVM        - disabled
        system.adapter.discovery.0              : discovery             : ioBrokerVM        -  enabled
        system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: ioBrokerVM        - disabled
        system.adapter.eusec.0                  : eusec                 : ioBrokerVM        - disabled
        system.adapter.flot.0                   : flot                  : ioBrokerVM        -  enabled
        system.adapter.history.0                : history               : ioBrokerVM        -  enabled
        system.adapter.hm-rega.0                : hm-rega               : ioBrokerVM        -  enabled
        system.adapter.hm-rpc.0                 : hm-rpc                : ioBrokerVM        -  enabled, port: 2010
        system.adapter.iot.0                    : iot                   : ioBrokerVM        -  enabled
        system.adapter.jarvis.0                 : jarvis                : ioBrokerVM        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
      + system.adapter.javascript.0             : javascript            : ioBrokerVM        -  enabled
        system.adapter.netatmo-crawler.0        : netatmo-crawler       : ioBrokerVM        - disabled
        system.adapter.openweathermap.0         : openweathermap        : ioBrokerVM        -  enabled
        system.adapter.scenes.0                 : scenes                : ioBrokerVM        -  enabled
        system.adapter.shelly.0                 : shelly                : ioBrokerVM        -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.shelly.1                 : shelly                : ioBrokerVM        -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.sun2000.0                : sun2000               : ioBrokerVM        -  enabled, port: 502
        system.adapter.tankerkoenig.0           : tankerkoenig          : ioBrokerVM        -  enabled
        system.adapter.telegram.0               : telegram              : ioBrokerVM        -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.tr-064.0                 : tr-064                : ioBrokerVM        -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : ioBrokerVM        - disabled
        system.adapter.web.0                    : web                   : ioBrokerVM        -  enabled, port: 8082, bind: 0.0.0.0, run as: admi        n
        system.adapter.zigbee.0                 : zigbee                : ioBrokerVM        -  enabled, port: /dev/ttyUSB0
        system.adapter.zigbee.1                 : zigbee                : ioBrokerVM        -  enabled, port: tcp://192.168.178.185:20108
      + instance is alive
      ioBroker-Repositories
      │ (index) │ name     │ url                                                     │        auto upgrade │
      │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │        false        │
      │ 1       │ 'beta'   │ 'http://download.iobroker.net/sources-dist-latest.json' │        false        │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.2.2    , installed 3.2.2
      Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
      Adapter    "eusec"        : 1.3.3    , installed 1.3.3
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 9.5.1    , installed 9.5.1
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "sun2000"      : 1.4.0    , installed 1.4.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
      Objects and States
      Objects:        8962
      States:         6439
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 13
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1077023    7042/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1077028    7042/iobroker.js-co
      tcp        0      0 127.0.0.1:8081          0.0.0.0:*               LISTEN      1001       1077064    7060/io.admin.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          238        1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          493        545/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          14467      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          495        545/sshd: /usr/sbin
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       1079572    7600/io.shelly.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14705      466/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          15764      1/init
      udp6       0      0 :::111                  :::*                                0          239        1/init
      2025-06-03 19:01:30.466  - info: history.0 (7246) enabled logging of shelly.1.shellypro3em#3c8a1fd2c26c#1.EM0.TotalActivePower (Count=1), Alias=false
      2025-06-03 19:01:33.743  - info: host.ioBrokerVM instance system.adapter.scenes.0 in version "3.2.3" started with pid 7450
      2025-06-03 19:01:34.521  - info: scenes.0 (7450) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.scenes, node: v20.19.2, js-controller: 7.0.6
      2025-06-03 19:01:37.740  - info: host.ioBrokerVM instance system.adapter.backitup.0 in version "3.2.2" started with pid 7514
      2025-06-03 19:01:38.485  - info: backitup.0 (7514) starting. Version 3.2.2 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.19.2, js-controller: 7.0.6
      2025-06-03 19:01:38.507  - info: backitup.0 (7514) [iobroker] backup will be activated at 02:48 every 1 day(s)
      2025-06-03 19:01:38.536  - info: backitup.0 (7514) [ccu] backup will be activated at 01:36 every 3 day(s)
      2025-06-03 19:01:41.731  - info: host.ioBrokerVM instance system.adapter.cloud.0 in version "5.0.1" started with pid 7569
      2025-06-03 19:01:42.554  - info: cloud.0 (7569) starting. Version 5.0.1 in /opt/iobroker/node_modules/iobroker.cloud, node: v20.19.2, js-controller: 7.0.6
      2025-06-03 19:01:42.572  - info: cloud.0 (7569) Connecting with https://iobroker.pro:10555 with "@pro_tadeksk@gmail.com_28768570-cd4e-11e9-abcf-a57554a6b8ea"
      2025-06-03 19:01:42.641  - error: cloud.0 (7569) Cannot activate admin.0 for cloud, because authentication is enabled. Please create extra instance for cloud
      2025-06-03 19:01:42.644  - info: cloud.0 (7569) Trying to connect as system.user.admin to cloud
      2025-06-03 19:01:42.754  - info: cloud.0 (7569) Adapter redirected temporally to "https://iobroker.pro:10556" in 30 seconds. Reason: command from server
      2025-06-03 19:01:42.755  - info: cloud.0 (7569) Connection changed: disconnect
      2025-06-03 19:01:45.725  - info: host.ioBrokerVM instance system.adapter.shelly.0 in version "9.5.1" started with pid 7600
      2025-06-03 19:01:46.773  - info: shelly.0 (7600) starting. Version 9.5.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v20.19.2, js-controller: 7.0.6
      2025-06-03 19:01:47.029  - info: shelly.0 (7600) Starting in CoAP mode. Listening on 0.0.0.0:5683
      2025-06-03 19:01:47.048  - info: shelly.0 (7600) [CoAP Server] Listening for packets in the network
      2025-06-03 19:01:48.867  - info: shelly.0 (7600) [CoAP] Device 192.168.178.48 (shelly1 / shelly1-1D954F / SHSW-1#1D954F#1) connected! Polltime set to 14 sec.
      2025-06-03 19:01:49.762  - info: host.ioBrokerVM instance scheduled system.adapter.openweathermap.0 15 * * * *
      2025-06-03 19:01:49.765  - info: host.ioBrokerVM instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 7651
      2025-06-03 19:01:50.116  - info: shelly.0 (7600) [CoAP] Device 192.168.178.54 (shellyplug-s / shellyplug-s-8D03D8 / SHPLG-S#8D03D8#1) connected! Polltime set to 14 sec.
      2025-06-03 19:01:50.127  - info: shelly.0 (7600) [CoAP] Device 192.168.178.91 (shelly1 / shelly1-058E3C / SHSW-1#058E3C#1) connected! Polltime set to 14 sec.
      2025-06-03 19:01:50.144  - info: shelly.0 (7600) [CoAP] Device 192.168.178.55 (shellyplug-s / shellyplug-s-B4DF65 / SHPLG-S#B4DF65#1) connected! Polltime set to 14 sec.
      2025-06-03 19:01:50.762  - info: openweathermap.0 (7651) starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v20.19.2, js-controller: 7.0.6
        Mr.X
        tadek@ioBrokerVM:~$ id
        ls -l /home/
        uid=1000(tadek) gid=1000(tadek) Gruppen=1000(tadek),24(cdrom),25(floppy),27(sudo),29(audio),30(dip),44(video),46(plugdev),100(users),106(netdev),1001(iobroker)
        insgesamt 8
        drwxr-xr-x 3 iobroker iobroker 4096  3. Jun 19:01 iobroker
        drwx------ 7 tadek    tadek    4096  3. Jun 19:01 tadek
        • M Mr.X
          ```bash
          Script v.2025-03-08
          *** BASE SYSTEM ***
                   Chassis: vm 🖴
            Virtualization: kvm
          OS is similar to:
          Docker          : false
          Kernel          : x86_64
          Userland        : 64 bit
          CPU threads: 4
                        NTP service: active
                    RTC in local TZ: no
          tadek
          HOME=/home/tadek
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           1.0G          0B        1.0G
                   3914 M total memory
                   1072 M used memory
                    475 M active memory
                   2008 M free memory
                    253 M buffer memory
                    840 M swap cache
                    974 M total swap
                      0 M used swap
                    974 M free swap
          *** FILESYSTEM ***
          /var:
          512M    /var/
          249M    /var/cache
          241M    /var/cache/apt
          173M    /var/lib
          USB-Devices by-id:
          HINT:
          /dev/ttyUSB0
          HINT:
          tcp
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.6.17
          javascript:     8.9.2
          Adapter State
          + instance is alive
          Objects and States
          Objects:        8962
          States:         6439
          Pending Updates: 13
          @mr-x sagte in Kein Zugriff mehr:
          Das ist auch nie eine schlechte Idee.
          Der Fixer biegt die Rechte wieder gerade.
          Setz den tadek in die Gruppe adm rein.
          Und verwende ein gescheites Terminal oder zieh den puTTY wenigstens auf Breit.
          Da ist der Fehler:
          + system.adapter.admin.0                  : admin                 : ioBrokerVM -  enabled, port: 8081, bind: 127.0.0.1, run as: admin
          Du hast den admin.0 an den localhost gebunden.
          Auf meiner Kiste z. B. sieht das so aus:
          + system.adapter.admin.0                  : admin                 : chet                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          Stell das auf 0.0.0.0 um, ich hab nur gerade den genauen Befehl nicht parat.
          Pending Updates: 13
          Updates einspielen.
          • Meister MopperM Online
            Meister Mopper
            @mr-x
            iobroker set admin.0 --bind 0.0.0.0
            Proxmox und HA ...
              @mr-x
              @meister-mopper
              Danke für's aushelfen. :-)
                @meister-mopper
                Mr.X
                Hammer, hat geklappt.
                Ihr seid die BESTEN
                • M Mr.X
                  Ihr seid die BESTEN
                  @mr-x
                  Dann kannst du ja jetzt die anderen Hausaufgaben erledigen.
                  Dein zigbee.0 würde ich z. B. auch anders einstellen.
                  /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_2e66e30c326cef1192d399adc169b110-if00-port0
                  HINT:
                  /dev/ttyUSB0
                    Mr.X
                    @thomas-braun sagte in Kein Zugriff mehr auf Admin Oberfläche:
                    @mr-x
                    Das wundert mich, da ich mit @Asgothian den Adapter eingerichtet hat.
                    Aber vielleicht hat er es ja übersehen, was ich da fabriziert habe.
                    Pending Updates: 13
                    Updates einspielen.
                    Adapter updates? in der Oberfläche werden mir für keine Adapter updates angezeigt.
                    Damit ich nicht wieder was verkehrt mache, wie kann ich den tadek den zum admin hinzufügen.
                    Und dann noch für den Lernfaktor.
                    ich habe ioBroker anhand der offiziellen Anleitung aufgesetzt.
                    Habe ich was übersehen, oder ist es da nicht erläutert?
                    Samson71S Thomas BraunT 2 Antworten Letzte Antwort
                    • M Mr.X
                      @mr-x
                      Pending Updates: 13
                      Updates einspielen.
                      Samson71S Offline
                      Samson71S Offline
                      Samson71
                      @mr-x sagte in Kein Zugriff mehr auf Admin Oberfläche:
                      Nein, OS-Updates. Hat mit Adaptern nix zu tun.
                      Pending Updates: 13
                      Markus
                      Bitte beachten:
                      • M Mr.X
                        @mr-x
                        Pending Updates: 13
                        Updates einspielen.
                        Asgothian sieht das an der Stelle ggfls. etwas anders als ich.
                        Wobei die offizielle Lesart ist, nach Möglichkeit die Gerätedateien 'by-id' anzupacken. Das ist nämlich stabil, /dev/usbXYZ kann sich ändern, die id eher nicht.
                        Das sind Updates des Betriebssystems. Die sollten allerdings auch im Admin als 'ausstehend' gemeldet werden.
                        sudo apt update
                        sudo apt full-upgrade
                        sudo usermod -a -G adm tadek
                        Danach den tadek einmal ab- und wieder anmelden oder besser gleich das ganze System einmal komplett durchstarten.
                          Mr.X
                          Wird zu Hause erledigt.
                          THX!
                            Da ist der Fehler:
                            Pending Updates: 13
                            Updates einspielen.
                            Mr.X
                            Was benutzen die Profis denn aktuell so.
                            ich habe nie nach was anderem gesucht, weil ich irgendwann mit puTTY angefangen habe
                            • M Mr.X
                              @mr-x
                              Auf welchem System bist du denn unterwegs?
                              Die Powershell ist soweit ich das sehe mittlerweile wohl ganz brauchbar auf Windows.
                              Zumindest behandelt die Zeilenumbrüche richtig.
                                @mr-x
                                Mr.X
                                Danke, werde ich mir anschauen.
                                Nach
                                und reboot bekomme ich immer noch:
                                insgesamt 8
                                Die Rechte sehen aber immer noch so aus wie vorher, oder?
                                Die anderen Hausaufgaben habe ich auch erledigt:
                                Pending Updates: 0
                                Danke für ALLES,
                                War ein langer Weg, aber jetzt läuft das neue System (bis auf den kack Szenen-Adapter)
                                • M Mr.X
                                  Nach
                                  insgesamt 8
                                  Pending Updates: 0
                                  Danke für ALLES,
                                  Jedenfalls dürfen jetzt auch Mitglieder der Gruppe 'iobroker' das Heimverzeichnis des Users 'iobroker' betreten.
