  3. Einsteigerfragen
  4. Warnungen im Log - was bedeuten die ?
    5.3k
57 Beiträge 6 Kommentatoren 7.4k Aufrufe 2 Beobachtet
  • dogfight76D dogfight76
    ich habe ich Log wiederkehrende Einträge:
    javascript.0 	2025-05-09 14:51:51.910	warn	at processImmediate (node:internal/timers:483:21)
    javascript.0 	2025-05-09 14:51:51.909	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
    javascript.0 	2025-05-09 14:51:51.909	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
    javascript.0 	2025-05-09 14:51:51.909	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
    javascript.0 	2025-05-09 14:51:51.907	warn	at processImmediate (node:internal/timers:483:21)
    Was bedeuten die ? Sind markiert als "warn"
    @dogfight76 Da steht bestimmt noch etwas davor.
    Und die Chronologie ist bei dir flasch herum.
    dogfight76D 1 Antwort Letzte Antwort
      dogfight76D Offline
      dogfight76D Offline
      dogfight76
      wenn ich das Log herunterlade dann erscheint die Chronologie so herum:
      2025-05-09 18:08:54.344 - warn: javascript.0 (788) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.23" not found (3)
      2025-05-09 18:08:54.345 - warn: javascript.0 (788) at Object. (script.js.common.Meine_Geraete.Heizung.Akt_VL:9:21)
      2025-05-09 18:08:54.345 - warn: javascript.0 (788) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
      2025-05-09 18:08:54.345 - warn: javascript.0 (788) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2025-05-09 18:08:54.345 - warn: javascript.0 (788) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
      2025-05-09 18:08:54.346 - warn: javascript.0 (788) at processImmediate (node:internal/timers:483:21)
      2025-05-09 18:08:54.346 - warn: javascript.0 (788) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.23" not found (3)
      2025-05-09 18:08:54.347 - warn: javascript.0 (788) at Object. (script.js.common.Meine_Geraete.Heizung.Akt_VL:10:137)
      2025-05-09 18:08:54.347 - warn: javascript.0 (788) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
      2025-05-09 18:08:54.347 - warn: javascript.0 (788) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2025-05-09 18:08:54.347 - warn: javascript.0 (788) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
      2025-05-09 18:08:54.347 - warn: javascript.0 (788) at processImmediate (node:internal/timers:483:21)
      2025-05-09 18:10:59.436 - warn: javascript.0 (788) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.22" not found (3)
      2025-05-09 18:10:59.439 - warn: javascript.0 (788) at Object. (script.js.common.Meine_Geraete.Heizung.Akt_VL:9:21)
      2025-05-09 18:10:59.439 - warn: javascript.0 (788) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
      2025-05-09 18:10:59.439 - warn: javascript.0 (788) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2025-05-09 18:10:59.440 - warn: javascript.0 (788) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
      2025-05-09 18:10:59.440 - warn: javascript.0 (788) at processImmediate (node:internal/timers:483:21)
      2025-05-09 18:10:59.440 - warn: javascript.0 (788) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.22" not found (3)
      2025-05-09 18:10:59.442 - warn: javascript.0 (788) at Object. (script.js.common.Meine_Geraete.Heizung.Akt_VL:10:137)
      2025-05-09 18:10:59.443 - warn: javascript.0 (788) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
      2025-05-09 18:10:59.444 - warn: javascript.0 (788) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2025-05-09 18:10:59.444 - warn: javascript.0 (788) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
      2025-05-09 18:10:59.444 - warn: javascript.0 (788) at processImmediate (node:internal/timers:483:21)
      2025-05-09 18:20:24.537 - warn: javascript.0 (788) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.21" not found (3)
      2025-05-09 18:20:24.539 - warn: javascript.0 (788) at Object. (script.js.common.Meine_Geraete.Heizung.Akt_VL:9:21)
      2025-05-09 18:20:24.540 - warn: javascript.0 (788) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
      2025-05-09 18:20:24.540 - warn: javascript.0 (788) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2025-05-09 18:20:24.541 - warn: javascript.0 (788) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
      2025-05-09 18:20:24.541 - warn: javascript.0 (788) at processImmediate (node:internal/timers:483:21)
      2025-05-09 18:20:24.541 - warn: javascript.0 (788) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.21" not found (3)
      2025-05-09 18:20:24.543 - warn: javascript.0 (788) at Object. (script.js.common.Meine_Geraete.Heizung.Akt_VL:10:137)
      2025-05-09 18:20:24.544 - warn: javascript.0 (788) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
      2025-05-09 18:20:24.544 - warn: javascript.0 (788) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2025-05-09 18:20:24.544 - warn: javascript.0 (788) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
      2025-05-09 18:20:24.545 - warn: javascript.0 (788) at processImmediate (node:internal/timers:483:21)
      Und die Einträge
      sind komisch weil die Heizkurve von -15 bis +20 Grad geht, weiß nicht was da nach Temperaturen oberhalb von 20 Grad sucht.
      paul53P HomoranH 2 Antworten Letzte Antwort
        Und die Einträge
        @dogfight76 sagte: weiß nicht was da nach Temperaturen oberhalb von 20 Grad sucht.
        Dann prüfe mal die Schleife im Skript.
        Oder hast du bei der ID-Konstruktion keine Begrenzung vorgesehen?
          dogfight76D Offline
          dogfight76D Offline
          dogfight76
          Das Script der Heizkurve ist das:
          Heizkurve.txt
            Und die Einträge
            @dogfight76 da muss vorher ein ERROR stehen
              dogfight76D Offline
              dogfight76D Offline
              dogfight76
              @homoran Ist kein "Error" Eintrag im Protokoll, nur die "normalen" Meldungen und die "warn"
                @dogfight76 sagte in Warnungen im Log - was bedeuten die ?:
                gar keiner, oder nur nicht bei javascript?
                  @dogfight76
                  Das Thema hatten wir doch schon!!
                  https://forum.iobroker.net/post/1262976
                  mcm1957M dogfight76D 2 Antworten Letzte Antwort
                    dogfight76D Offline
                    dogfight76D Offline
                    dogfight76
                    Kein einziger Error !
                    Aber immer die gleichen warn:
                    Der Eintrag verweist auf das Script: Akt_VL , richtig ?
                    2025-05-09 18:20:24.539 warn at Object.<anonymous> (script.js.common.Meine_Geraete.Heizung.Akt_VL:9:21)
                    Auf die Zeile 9 in dem Script ?
                    var Temp;
                    on({ id: [].concat(['mqtt.0.Waermepumpe.main.Outside_Temp']).concat(['0_userdata.0.Waermepumpe.Empf_VL_Temp']).concat(['mqtt.0.Waermepumpe.commands.SetZ1HeatRequestTemperature']).concat(['0_userdata.0.Waermepumpe.Heizkurve.Neigung']).concat(['0_userdata.0.Waermepumpe.Parallelverschiebung']).concat(['0_userdata.0.Waermepumpe.Nachtabsenkung']), change: 'ne' }, async (obj) => {
                      if (getState('0_userdata.0.Waermepumpe.Nachtabsenkung_EinAus').val == false) {
                        if (!(getState('mqtt.0.Waermepumpe.commands.SetOperationMode').val == 4)) {
                          Temp = '0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.' + String(getState('mqtt.0.Waermepumpe.main.Outside_Temp').val);
                          console.debug(getState(Temp).val);
                          setState('mqtt.0.Waermepumpe.commands.SetZ1HeatRequestTemperature' /* mqtt.0.Waermepumpe.commands.SetZ1HeatRequestTemperature */, getState(Temp).val);
                    Da steht:
                    Aber was hat das (wenn ich überhaupt richtig liege mit meiner Vermutung) mit dem Ordner der VL-Temperaturen in dem Pfad 0_userdat_0........... zu tun ?
                      @dogfight76
                      mcm1957M Offline
                      mcm1957M Offline
                      mcm1957
                      Seh ich das falsch oder bedeuten die Meldung
                      nicht ganz klar:
                      Der State 0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.23 wird nicht gefunden und zwar vom Script an der Stelle script.js.common.Meine_Geraete.Heizung.Akt_VL:9:2 ?
                      Support Repositoryverwaltung.
                      LESEN - gute Forenbeitrage
                        @dogfight76
                        dogfight76D Offline
                        dogfight76D Offline
                        dogfight76
                        Da hast du recht, aber weil da soviel durcheinader gekommen ist dachte ich das ich es einfacher halt.
                        Sonst gerne einfach da anhängen, wenn ein Admin das kann. Danke
                        • mcm1957M mcm1957
                          nicht ganz klar:
                          dogfight76D Offline
                          dogfight76D Offline
                          dogfight76
                          @mcm1957
                          Darum habe ich die Zeile des Script Akt_VL ja gepostet. Weil ich das auch so verstehe.....
                            @mcm1957
                            mcm1957M Offline
                            mcm1957M Offline
                            mcm1957
                            @dogfight76
                            Und was ist dann noch das Problem?
                            Gibts den State? Oder gibts ihn nicht?
                            Die Zeilen mit "at" sind ein Traceback damit man die entsprechende Stelle im Code finden kann.
                            • mcm1957M mcm1957
                              @dogfight76
                              mcm1957M Offline
                              mcm1957M Offline
                              mcm1957
                              @mcm1957
                              Am Ende der ZEILE 9 hast du ein gestState und das versucht von 0_userdata_0 zu lesen. SChau mal wie TEMP zusammengesetzt wird (2 Zeilen weiter oben)
                              und der debug Output versucht das auch. Bei mehr als 21 Grad außentremperatur dürftem die 0_userdate_0 Werte fehlen. Oder du musst die Außentemperatur begrenzen ...
                                Heizkurve.txt
                                @dogfight76 sagte: Das Script der Heizkurve ist das:
                                Die Variable Temp, die eine ID enthält, hat keine Begrenzung, sondern verwendet direkt den Wert der Außentemperatur, die zudem auch noch in ganzen Grad auflösen muss.
                                • mcm1957M mcm1957
                                  @mcm1957
                                  dogfight76D Offline
                                  dogfight76D Offline
                                  dogfight76
                                  @mcm1957 said in Warnungen im Log - was bedeuten die ?:
                                  Ok, weil ich für die Steuerung über die Heizkurve nur die Temp von -15 bis +20 Grad benötige, (weil ab 21 Grad Aussentemp schaltet die Wärmepumpoe ja ab) würde die Begrenzung ab 21 Grad ja helfen damit die Warn-Meldung nicht mehr erscheinen, weil im Pfad:
                                  dann nicht mehr nach Temp oberhalb von 20 Grad gesucht werden, Korrekt ?
                                  Und die warn-Meldungen tauchen nicht mehr auf ?!
                                    dogfight76D Offline
                                    dogfight76D Offline
                                    dogfight76
                                    @paul53 said in Warnungen im Log - was bedeuten die ?:
                                    Wie bekomme ich das Script die Begrnezung rein ?
                                      mcm1957M Offline
                                      mcm1957M Offline
                                      mcm1957
                                      @dogfight76
                                      Die (Einzahl) Warnmeldung besagt dass du versuchst einen State zu lesen den es nicht gibt. Die Zeilen mit at sind untrennbare Fortsetzungszeilen der Warnmeldung ohne 'at' die dazu dienen die betreffende Codezeile zu identifizieren.
                                      Wenn du dein Script so korrigierts dass es keine nicht existenten State versucht zu lsene ist die getStte Warnung und die nachfolgenden at's weg.
                                        @dogfight76 sagte: Wie bekomme ich das Script die Begrnezung rein ?
                                        Z.B. so:
                                          Z.B. so:
                                          dogfight76D Offline
                                          dogfight76D Offline
                                          dogfight76
                                          Der gesamte Baustein vom Screenshot muss an welche Stelle in meinem Script ?
