  4. keine Updates möglich
    1.0k
    6.1k
8 Beiträge 5 Kommentatoren 772 Aufrufe 5 Beobachtet
  • NegaleinN Offline
    NegaleinN Offline
    Negalein
    • js-controller Version: 7.0.6
    • Admin Version: 7.6.14
    • Nodejs-Version: 20.19.1
    • NPM-Version: 10.8.2
    Hallo
    Wollte gerade den Rest-API von 2.0.3 auf 2.1.0 updaten.
    Läuft normal durch, aber es bleibt bei 2.0.3 und das Update wird mir immer wieder vorgeschlagen.
    Selbes Spiel mit Sourceanalytix von 0.4.14 auf 0.4.15-alpha.
    $ iobroker upgrade rest-api@2.1.0 --debug
    Update rest-api from @2.0.3 to @2.1.0
    host.ioBroker Adapter "system.adapter.rest-api.0" is stopped.
    Installing iobroker.rest-api@2.1.0... (System call)
    npm error code ETARGET
    npm error notarget No matching version found for iobroker.rest-api@2.1.0.npm error notarget In most cases you or one of your dependencies are requestingnpm error notarget a package version that doesn't exist.
    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-04-24T08_59_50_444Z-debug-0.log
    Updating objects from io-package.json for adapter "rest-api" with version "2.0.3"
    upload [11] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [10] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [9] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [8] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [7] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [6] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [4] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [3] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [2] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [1] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/jsonConfig.json jsonConfig.json application/json
    upload [0] rest-api.admin /opt/iobroker/node_modules/iobroker.rest-api/admin/rest-api.png rest-api.png image/png
    host.ioBroker Adapter "system.adapter.rest-api.0" is started
    Process exited with code 0
    bash
    Script v.2025-02-23
    *** BASE SYSTEM ***
     Static hostname: ioBroker
           Icon name: computer-container
             Chassis: container
      Virtualization: lxc
    Operating System: Ubuntu 22.04.5 LTS
              Kernel: Linux 5.15.30-2-pve
        Architecture: x86-64
    OS is similar to: debian
    model name      : Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
    Docker          : false
    Virtualization  : lxc
    Kernel          : x86_64
    Userland        : 64 bit
    Systemuptime and Load:
     11:13:42 up 23 min,  2 users,  load average: 0.93, 0.72, 0.90
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
    *** TIME AND TIMEZONES ***
                   Local time: Thu 2025-04-24 11:13:42 CEST
               Universal time: Thu 2025-04-24 09:13:42 UTC
                     RTC time: n/a
                    Time zone: Europe/Vienna (CEST, +0200)
                  NTP service: inactive
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    nega
    HOME=/home/nega
    GROUPS=nega adm dialout sudo users iobroker
    iobroker
    HOME=/home/iobroker
    GROUPS=iobroker tty dialout audio video plugdev
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:             10G        4.7G        4.5G        0.0K        867M        5.4G
    Swap:           3.1G          0B        3.1G
    Total:           13G        4.7G        7.6G
    Active iob-Instances:   67
            10048 M total memory
             4668 M used memory
              389 M active memory
             4914 M inactive memory
             4512 M free memory
                0 M buffer memory
              867 M swap cache
             3072 M total swap
                0 M used swap
             3072 M free swap
    top - 11:13:43 up 23 min,  2 users,  load average: 0.93, 0.72, 0.90
    Tasks: 102 total,   1 running, 101 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  6.2 us,  1.5 sy,  0.0 ni, 90.8 id,  0.0 wa,  0.0 hi,  1.5 si,  0.0 st
    MiB Mem :  10048.0 total,   4511.6 free,   4669.0 used,    867.4 buff/cache
    MiB Swap:   3072.0 total,   3072.0 free,      0.0 used.   5379.0 avail Mem
    *** FAILED SERVICES ***
      UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
    * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
    1 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    dmesg: read kernel buffer failed: Operation not permitted
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                       Type   Size  Used Avail Use% Mounted on
    /dev/mapper/pve-vm--100--disk--0 ext4    45G   29G   14G  68% /
    10.0.1.21:/volume1/Backups       nfs4    14T   12T  2.2T  85% /opt/iobroker/backups
    none                             tmpfs  492K  4.0K  488K   1% /dev
    tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
    tmpfs                            tmpfs  3.2G  144K  3.2G   1% /run
    tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
    tmpfs                            tmpfs  1.6G     0  1.6G   0% /run/user/1001
    Show mounted filesystems:
    TARGET                  SOURCE                           FSTYPE OPTIONS
    /                       /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
    `-/opt/iobroker/backups 10.0.1.21:/volume1/Backups       nfs4   rw,relatime,vers=4.1,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=10.0.1.201,local_lock=none,addr=10.0.1.21
    /var:
    3.1G    /var/
    2.5G    /var/log
    2.4G    /var/log/journal/b354c482f7cc342776f020ee5ea440c3
    372M    /var/lib
    Archived and active journals take up 2.3G in the file system.
    /opt/iobroker/backups:
    2.6G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    6.1G    /opt/iobroker/iobroker-data/
    3.9G    /opt/iobroker/iobroker-data/history
    1.6G    /opt/iobroker/iobroker-data/files
    323M    /opt/iobroker/iobroker-data/backup-objects
    299M    /opt/iobroker/iobroker-data/files/vis.0
    68M     /opt/iobroker/iobroker-data/states.jsonl
    39M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/files/meteoalarm.admin/geocodes.json
    32M     /opt/iobroker/iobroker-data/files/vis.0/VIS/Background/Starfield 7.mp4
    32M     /opt/iobroker/iobroker-data/files/vis-2.0/VIS/Background/Starfield 7.mp4
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.1
    /usr/bin/node           v20.19.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.31.0
    nodejs:
      Installed: 20.19.1-1nodesource1
      Candidate: 20.19.1-1nodesource1
      Version table:
     *** 20.19.1-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
         20.19.0-1nodesource1 1001
         20.18.3-1nodesource1 1001
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         12.22.9~dfsg-1ubuntu3.6 500
            500 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
            500 http://archive.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
         12.22.9~dfsg-1ubuntu3 500
            500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    ioBroker            ioBroker (version: 7.0.6, hostname: ioBroker      , alive, uptime: 1384)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.14
    javascript:     8.9.1
    nodejs modules from github:     11
    +-- iobroker.e-control-at-fuel@0.1.6-beta.2 (git+ssh://git@github.com/xXBJXx/ioBroker.e-control-at-fuel.git#a9e5d6999622e789e01cac85f27a771fb41dc566)
    +-- iobroker.enigma2@2.2.3 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.enigma2.git#fc9f068008e05aabb09683728e17cedb4d79fbd0)
    +-- iobroker.fitbit-fitness@0.5.0 (git+ssh://git@github.com/Chris-656/ioBroker.fitbit-fitness.git#36a426abe0f6999aed316dd1bc6aba0d21150f4a)
    +-- iobroker.ford@1.0.5 (git+ssh://git@github.com/TA2k/ioBroker.ford.git#b205174cf0485a3751dbaaf31bed79a5345a19f8)
    +-- iobroker.linux-control@1.1.6 (git+ssh://git@github.com/Scrounger/ioBroker.linux-control.git#59f578f3402850684ba8767a24a9ff288b05a3f0)
    +-- iobroker.samsung@0.6.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.samsung.git#43d8a6ef3b5af0d6dfe276870f560353d52d0838)
    | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
    +-- iobroker.switchbot-hub@0.1.2 (git+ssh://git@github.com/arteck/ioBroker.switchbot-hub.git#375dc3d6d53d8322071e7d172137fef1f5849370)
    | +-- syno@3.0.0 (git+ssh://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    +-- iobroker.tapo@0.4.8 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#615315d4bae5c77b153ac5067bdca8ba3ad3996f)
    +-- iobroker.vis-knob@0.0.1 (git+ssh://git@github.com/ioBroker/ioBroker.vis-knob.git#a1dc9e3758987a921c893c0d63497e742d5c3526)
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.alexa2.0                 : alexa2                : ioBroker                                 -  enabled
    + system.adapter.alexa2.1                 : alexa2                : ioBroker                                 -  enabled
      system.adapter.alias-manager.0          : alias-manager         : ioBroker                                 - disabled
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.bayernluft.0             : bayernluft            : ioBroker                                 -  enabled
      system.adapter.birthdays.0              : birthdays             : ioBroker                                 -  enabled
      system.adapter.bring.0                  : bring                 : ioBroker                                 - disabled
      system.adapter.cloud.0                  : cloud                 : ioBroker                                 - disabled
      system.adapter.daswetter.0              : daswetter             : ioBroker                                 -  enabled
    + system.adapter.denon.0                  : denon                 : ioBroker                                 -  enabled
      system.adapter.device-watcher.0         : device-watcher        : ioBroker                                 - disabled
      system.adapter.devices.0                : devices               : ioBroker                                 - disabled
      system.adapter.discovery.0              : discovery             : ioBroker                                 - disabled
    + system.adapter.doorbird.0               : doorbird              : ioBroker                                 -  enabled
      system.adapter.dwd.0                    : dwd                   : ioBroker                                 -  enabled
    + system.adapter.email.0                  : email                 : ioBroker                                 -  enabled
    + system.adapter.energiefluss.0           : energiefluss          : ioBroker                                 -  enabled
    + system.adapter.enigma2.0                : enigma2               : ioBroker                                 -  enabled
      system.adapter.enigma2.1                : enigma2               : ioBroker                                 - disabled
    + system.adapter.eventlist.0              : eventlist             : ioBroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : ioBroker                                 - disabled
      system.adapter.fitbit-fitness.0         : fitbit-fitness        : ioBroker                                 - disabled
      system.adapter.flot.0                   : flot                  : ioBroker                                 - disabled
    + system.adapter.followthesun.0           : followthesun          : ioBroker                                 -  enabled
      system.adapter.fontui.0                 : fontui                : ioBroker                                 -  enabled
      system.adapter.ford.0                   : ford                  : ioBroker                                 - disabled
    + system.adapter.fronius.0                : fronius               : ioBroker                                 -  enabled
      system.adapter.fuelpricemonitor.0       : fuelpricemonitor      : ioBroker                                 -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : ioBroker                                 -  enabled
    + system.adapter.harmony.1                : harmony               : ioBroker                                 -  enabled
    + system.adapter.history.0                : history               : ioBroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : ioBroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker                                 -  enabled, port: 0
    + system.adapter.hs100.0                  : hs100                 : ioBroker                                 -  enabled
    + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 80
      system.adapter.ical.0                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.1                   : ical                  : ioBroker                                 -  enabled
      system.adapter.ical.2                   : ical                  : ioBroker                                 -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: ioBroker                                 - disabled
      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : ioBroker                                 - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : ioBroker                                 - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : ioBroker                                 - disabled
      system.adapter.icons-material-svg.0     : icons-material-svg    : ioBroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : ioBroker                                 - disabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : ioBroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: ioBroker                                 -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : ioBroker                                 - disabled
    + system.adapter.influxdb.0               : influxdb              : ioBroker                                 -  enabled, port: 32543
    + system.adapter.influxdb.1               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.influxdb.2               : influxdb              : ioBroker                                 -  enabled, port: 8086
    + system.adapter.iot.0                    : iot                   : ioBroker                                 -  enabled
    + system.adapter.iot.1                    : iot                   : ioBroker                                 -  enabled
      system.adapter.iqontrol.0               : iqontrol              : ioBroker                                 - disabled
    + system.adapter.javascript.0             : javascript            : ioBroker                                 -  enabled
    + system.adapter.javascript.1             : javascript            : ioBroker                                 -  enabled
    + system.adapter.lg-thinq.0               : lg-thinq              : ioBroker                                 -  enabled
    + system.adapter.linkeddevices.0          : linkeddevices         : ioBroker                                 -  enabled
    + system.adapter.linux-control.0          : linux-control         : ioBroker                                 -  enabled
    + system.adapter.logparser.0              : logparser             : ioBroker                                 -  enabled
      system.adapter.meteoalarm.0             : meteoalarm            : ioBroker                                 - disabled
      system.adapter.mytime.0                 : mytime                : ioBroker                                 - disabled
    + system.adapter.nina.0                   : nina                  : ioBroker                                 -  enabled
    + system.adapter.node-red.0               : node-red              : ioBroker                                 -  enabled, port: 1880, bind: 0.0.0.0
    + system.adapter.notification-manager.0   : notification-manager  : ioBroker                                 -  enabled
    + system.adapter.nut.0                    : nut                   : ioBroker                                 -  enabled
      system.adapter.octoprint.0              : octoprint             : ioBroker                                 - disabled
    + system.adapter.parser.0                 : parser                : ioBroker                                 -  enabled
      system.adapter.pegelalarm.0             : pegelalarm            : ioBroker                                 -  enabled
      system.adapter.pegelalarm.1             : pegelalarm            : ioBroker                                 -  enabled
    + system.adapter.pi-hole.0                : pi-hole               : ioBroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : ioBroker                                 -  enabled
      system.adapter.places.0                 : places                : ioBroker                                 - disabled
    + system.adapter.pollenflug.0             : pollenflug            : ioBroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : ioBroker                                 -  enabled, port: 8006
      system.adapter.proxy.0                  : proxy                 : ioBroker                                 -  enabled
    + system.adapter.rest-api.0               : rest-api              : ioBroker                                 -  enabled, port: 8093, bind: 0.0.0.0 (SSL), run as: rest
    + system.adapter.samsung.0                : samsung               : ioBroker                                 -  enabled
    + system.adapter.schedule-switcher.0      : schedule-switcher     : ioBroker                                 -  enabled
    + system.adapter.seq.0                    : seq                   : ioBroker                                 -  enabled, port: 443
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.shrdzm.0                 : shrdzm                : ioBroker                                 - disabled
    + system.adapter.shuttercontrol.0         : shuttercontrol        : ioBroker                                 -  enabled
    + system.adapter.simple-api.0             : simple-api            : ioBroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.snmp.0                   : snmp                  : ioBroker                                 -  enabled
    + system.adapter.socketio.0               : socketio              : ioBroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sourceanalytix.0         : sourceanalytix        : ioBroker                                 -  enabled
    + system.adapter.switchbot-hub.0          : switchbot-hub         : ioBroker                                 -  enabled
    + system.adapter.synology.0               : synology              : ioBroker                                 -  enabled, port: 5001
    + system.adapter.tapo.0                   : tapo                  : ioBroker                                 -  enabled
    + system.adapter.telegram-menu.0          : telegram-menu         : ioBroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : ioBroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.telegram.1               : telegram              : ioBroker                                 - disabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tractive-gps.0           : tractive-gps          : ioBroker                                 -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : ioBroker                                 -  enabled
    + system.adapter.unifi.0                  : unifi                 : ioBroker                                 -  enabled
      system.adapter.vesync.0                 : vesync                : ioBroker                                 - disabled
      system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: ioBroker                                 -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : ioBroker                                 -  enabled
      system.adapter.vis-bars.0               : vis-bars              : ioBroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : ioBroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : ioBroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : ioBroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : ioBroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : ioBroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : ioBroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : ioBroker                                 -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : ioBroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : ioBroker                                 - disabled
      system.adapter.vis-knob.0               : vis-knob              : ioBroker                                 - disabled
      system.adapter.vis-map.0                : vis-map               : ioBroker                                 - disabled
      system.adapter.vis-material.0           : vis-material          : ioBroker                                 - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : ioBroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : ioBroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : ioBroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : ioBroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker                                 - disabled
      system.adapter.vis-weather.0            : vis-weather           : ioBroker                                 - disabled
      system.adapter.vis.0                    : vis                   : ioBroker                                 -  enabled
    + system.adapter.weather-warnings.0       : weather-warnings      : ioBroker                                 -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : ioBroker                                 -  enabled
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : ioBroker                                 -  enabled
    + system.adapter.wireguard.0              : wireguard             : ioBroker                                 -  enabled
      system.adapter.xbox.0                   : xbox                  : ioBroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    │ (index) │ name               │ url                                                     │ auto upgrade │
    │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
    │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
    Active repo(s): Beta (latest)
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: Beta (latest)
    Adapter    "admin"        : 7.6.14   , installed 7.6.14
    Adapter    "alexa2"       : 3.26.7   , installed 3.26.7
    Adapter    "alias-manager": 2.0.0    , installed 2.0.0
    Adapter    "backitup"     : 3.2.0    , installed 3.2.0
    Adapter    "bayernluft"   : 3.0.0    , installed 3.0.0
    Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
    Adapter    "bring"        : 1.9.1    , installed 1.9.1
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
    Adapter    "devices"      : 1.2.1    , installed 1.2.1
    Adapter    "doorbird"     : 3.0.0    , installed 3.0.0
    Adapter    "email"        : 2.0.4    , installed 2.0.4
    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
    Adapter    "enigma2"      : 2.2.3    , installed 2.2.3
    Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "fitbit-fitness": 0.5.0   , installed 0.5.0
    Adapter    "followthesun" : 0.5.2    , installed 0.5.2
    Adapter    "ford"         : 1.0.4    , installed 1.0.5
    Adapter    "fronius"      : 2.1.1    , installed 2.1.1
    Adapter    "fronius-solarweb": 0.1.1 , installed 0.1.1
    Adapter    "fuelpricemonitor": 0.4.2 , installed 0.4.2
    Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
    Adapter    "harmony"      : 1.5.0    , installed 1.5.0
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "hs100"        : 3.0.4    , installed 3.0.4
    Adapter    "hue"          : 3.16.2   , installed 3.16.2
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "icons-mfd-png": 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "iot"          : 3.5.0    , installed 3.5.0
    Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
    Adapter    "jarvis"       : 3.2.0-rc.5, installed 3.2.0-rc.5
    Adapter    "javascript"   : 8.9.1    , installed 8.9.1
    Controller "js-controller": 7.0.7    , installed 7.0.6  [Updatable]
    Adapter    "lg-thinq"     : 1.1.0    , installed 1.1.0
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "linux-control": 1.1.5    , installed 1.1.6
    Adapter    "logparser"    : 2.3.0    , installed 2.3.0
    Adapter    "meteoalarm"   : 3.0.3    , installed 3.0.3
    Adapter    "mytime"       : 1.4.0    , installed 1.4.0
    Adapter    "nina"         : 0.0.26   , installed 0.0.26
    Adapter    "node-red"     : 6.0.7    , installed 6.0.7
    Adapter    "notification-manager": 1.3.0, installed 1.3.0
    Adapter    "nut"          : 1.6.0    , installed 1.6.0
    Adapter    "octoprint"    : 6.0.0    , installed 6.0.0
    Adapter    "parser"       : 2.3.1    , installed 2.3.1
    Adapter    "pegelalarm"   : 1.3.8    , installed 1.3.8
    Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
    Adapter    "ping"         : 1.7.9    , installed 1.7.9
    Adapter    "places"       : 1.2.0    , installed 1.2.0
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
    Adapter    "proxy"        : 1.3.2    , installed 1.3.2
    Adapter    "rest-api"     : 2.1.0    , installed 2.0.3  [Updatable]
    Adapter    "samsung"      : 0.6.1    , installed 0.6.1
    Adapter    "schedule-switcher": 0.0.10, installed 0.0.10
    Adapter    "seq"          : 0.3.0    , installed 0.3.0
    Adapter    "shelly"       : 9.4.1    , installed 9.4.1
    Adapter    "shrdzm"       : 0.2.0    , installed 0.2.0
    Adapter    "shuttercontrol": 2.0.1   , installed 2.0.1
    Adapter    "simple-api"   : 3.0.6    , installed 3.0.6
    Adapter    "snmp"         : 3.2.0    , installed 3.2.0
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "sourceanalytix": 0.4.15-alpha.1, installed 0.4.14 [Updatable]
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tapo"         : 0.4.8    , installed 0.4.8
    Adapter    "telegram-menu": 2.2.4    , installed 2.2.4
    Adapter    "tractive-gps" : 2.1.0    , installed 2.1.0
    Adapter    "trashschedule": 4.0.0    , installed 4.0.0
    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
    Adapter    "vesync"       : 0.0.9    , installed 0.0.9
    Adapter    "vis-2"        : 2.11.2   , installed 2.11.2
    Adapter    "vis-2-widgets-collection": 1.7.9, installed 1.7.9
    Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
    Adapter    "vis-material" : 0.2.0    , installed 0.2.0
    Adapter    "vis-materialdesign": 0.5.9, installed 0.5.5 [Updatable]
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.11   , installed 2.5.11
    Adapter    "weather-warnings": 0.7.4 , installed 0.7.4
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.9    , installed 7.0.9
    Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
    Adapter    "wireguard"    : 1.8.0    , installed 1.8.0
    Adapter    "ws"           : 3.0.19   , installed 3.0.19
    Adapter    "xbox"         : 1.1.2    , installed 1.1.2
    Objects and States
    Objects:        36188
    States:         35113
    Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
    Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 10.0.1.202:8100         0.0.0.0:*               LISTEN      1000       1408917016 1455/io.doorbird.0
    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1408899876 297/master
    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      106        1408900266 114/systemd-resolve
    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1000       1408905785 695/node-red
    tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1000       1408909335 915/io.hm-rpc.0
    tcp        0      0 0.0.0.0:2001            0.0.0.0:*               LISTEN      1000       1408908487 941/io.hm-rpc.1
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       1408900552 120/iobroker.js-con
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       1408902180 120/iobroker.js-con
    tcp        0      0 0.0.0.0:8701            0.0.0.0:*               LISTEN      1000       1408909571 967/io.hm-rpc.2
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1408899774 146/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1408896938 1/init
    tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1001       1409029962 2649/sshd: nega@pts
    tcp6       0      0 ::1:6010                :::*                    LISTEN      1001       1409029961 2649/sshd: nega@pts
    tcp6       0      0 :::61991                :::*                    LISTEN      1000       1408906194 863/io.harmony.1
    tcp6       0      0 :::8093                 :::*                    LISTEN      1000       1408955646 2174/io.rest-api.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1000       1408923940 1615/io.socketio.0
    tcp6       0      0 :::8087                 :::*                    LISTEN      1000       1408922961 1600/io.simple-api.
    tcp6       0      0 :::8081                 :::*                    LISTEN      1000       1408903253 415/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1000       1408925317 1698/io.web.0
    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1408899877 297/master
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1408899785 146/sshd: /usr/sbin
    tcp6       0      0 :::111                  :::*                    LISTEN      0          1408896940 1/init
    tcp6       0      0 :::3000                 :::*                    LISTEN      1000       1408916152 1347/io.fullybrowse
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1000       1408911979 1172/io.shelly.0
    udp        0      0 0.0.0.0:40715           0.0.0.0:*                           1000       1408911080 1135/io.snmp.0
    udp        0      0 127.0.0.53:53           0.0.0.0:*                           106        1408900265 114/systemd-resolve
    udp        0      0 10.0.1.202:68           0.0.0.0:*                           105        1408898780 102/systemd-network
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1408896939 1/init
    udp        0      0 0.0.0.0:35909           0.0.0.0:*                           1000       1408911081 1135/io.snmp.0
    udp        0      0 0.0.0.0:37009           0.0.0.0:*                           1000       1408909103 1135/io.snmp.0
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       1408906195 863/io.harmony.1
    udp6       0      0 :::111                  :::*                                0          1408896941 1/init
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) rssi: -78
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) fwMainController: Rev2.0
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) fwWiFi: WS32240427
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) on: true
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) temperatureIn: 30.0
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) temperatureOut: 31.1
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) temperatureFresh: 17.3
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) relativeHumidityIn: 27.0
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) relativeHumidityOut: 29.6
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) absoluteHumidityIn: 8.2
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) absoluteHumidityOut: 9.5
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) efficiency: 92.1
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) humidityTransport: -371
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) fanSpeedIn: 05
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) fanSpeedOut: 05
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) fanSpeedAntiFreeze: 00
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) isAntiFreezeActive: false
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) isFixedSpeedActive: false
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) isDefrostModeActive: false
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) isLandlordModeActive: false
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) isCrossVentilationActive: false
    2025-04-24 11:13:47.786  - debug: bayernluft.0 (1410) isTimerActive: false
    2025-04-24 11:14:11.886  - debug: shuttercontrol.0 (1118) outsidetemperature changed: 0_userdata.0.Wetterstation.Aussentemperatur | Value: 9.61°C
    2025-04-24 11:14:11.935  - info: simple-api.0 (1600) State value to set for "0_userdata.0.Wetterstation.Regen_Woche" has to be type "number" but received type "string"
    2025-04-24 11:14:12.015  - info: simple-api.0 (1600) State value to set for "0_userdata.0.Wetterstation.Regen_Event" has to be type "number" but received type "string"
    ° Fixer ---> iob fix
    • NegaleinN Negalein
      Hallo
      bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
               Chassis: container
        Virtualization: lxc
      Docker          : false
      Kernel          : x86_64
      Userland        : 64 bit
      CPU threads: 4
                       RTC time: n/a
                RTC in local TZ: no
      nega
      HOME=/home/nega
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           3.1G          0B        3.1G
               4668 M used memory
                389 M active memory
               4512 M free memory
                  0 M buffer memory
                867 M swap cache
               3072 M total swap
                  0 M used swap
               3072 M free swap
      *** FILESYSTEM ***
      /var:
      3.1G    /var/
      2.5G    /var/log
      372M    /var/lib
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin:          7.6.14
      javascript:     8.9.1
      Adapter State
      + instance is alive
      Objects and States
      Objects:        36188
      States:         35113
      Pending Updates: 0
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @negalein
      Die 2.1.0 ist laut npmjs auf NPM nicht veröffentlicht.
      Da würde mich interessieren was du als Kanal für Deine Update-Vorschläge eingestellt hast.
      A.
      • AsgothianA Asgothian
        @negalein
        A.
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @asgothian sagte in keine Updates möglich:
        den Beta
          den Beta
          Interessant. Heute morgen hatte ich was ähnliches mit dem sainlogic-Adapter. Hängt auch in einem Update-Loop.
          Kann aber erst heute abend mal genauer schauen.
          Fahre auch das Beta-Repo.
          Edit:
          Hängt evtl. damit zusammen:
          https://forum.iobroker.net/topic/80841/beschreibung-bei-einigen-adaptern-verschwunden/8
          • haus-automatisierungH Offline
            Im Falle der rest-api ist die Deploy-Action nicht ausgeführt worden: https://github.com/ioBroker/ioBroker.rest-api/actions/runs/13568640534
            Das heißt, auf GitHub steht zwar 2.1.0, aber das Paket ist nie auf npm angekommen.
            FYI @mcm1957
            📚 Meine Dokumentation
            mcm1957M 2 Antworten Letzte Antwort
              FYI @mcm1957
              mcm1957M Online
              mcm1957M Online
              mcm1957
              Bitte einmal auf "NACH UPDATES SUCHEN" klicken um das Repo neu zu laden.
              Der morgendliche Repobuild hatte Probleme (GitHub Workflow konnte auf Github Repos nicht zugreifen bzw. hat diese nicht gefunden :-( ) und hat dabei offensichtlich tw. Schrott ins Repo gestellt.
              Ich habe ca. 11:45 einen neuen Build durchgeführt. Die aktuellen Repodaten sollten wieder OK sein.
              Support Repositoryverwaltung.
              LESEN - gute Forenbeitrage
              • mcm1957M mcm1957
                NegaleinN Offline
                NegaleinN Offline
                Negalein
                @mcm1957 sagte in keine Updates möglich:
                Rest-Api 2.1.0 und Sourceanalytix 0.4.15-alpha scheinen nun nicht mehr auf.
                Rest blieb bei 2.0.3 & SA bei 0.4.14
                  FYI @mcm1957
                  mcm1957M Online
                  mcm1957M Online
                  mcm1957
                  @haus-automatisierung said in keine Updates möglich:
                  FYI @mcm1957
                  Dake,
                  Muss sich @Bluefox ansehen. Hab ihn gepingt.
