  4. Backup von InfluxDB scheitert [gelöst]
    6.7k
117 Beiträge 6 Kommentatoren 16.1k Aufrufe 4 Beobachtet
  • simatecS simatec
    @legro Und deine Config von Backitup?
    legro
    schrieb am zuletzt editiert von legro
    @simatec sagte in Backup von InfluxDB scheitert:
    Was benötigst über die NAS-Einstellungen in diesem Beitrag hinaus?
    Raspberry Pi 5 mit 8GB + 120GB SSD + Coordinator COD-m + ioBroker ..
    • simatecS simatec
      legro
      @simatec
      Hier das Ergebnis bei einem nanuell angestoßenen Backup ..
      16:56:48.740INFOguiBackup gestartet ...
      [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"192.168.4.1","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"fritz.nas/SanDisk/SmartHomeBackup/piVCCU3","dirMinimal":"fritz.nas/SanDisk/SmartHomeBackup/ioBroker","user":"ioBroker","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false}
      16:56:58.837DEBUGmountcifs-mount command: "sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.4.1/fritz.nas/SanDisk/SmartHomeBackup/piVCCU3 /opt/iobroker/backups"
      16:56:58.908DEBUGmountfirst mount attempt with smb option failed. try next mount attempt without smb option ...
      16:56:58.984DEBUGmountError: Command failed: sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.4.1/fritz.nas/SanDisk/SmartHomeBackup/piVCCU3 /opt/iobroker/backups
      mount error(2): No such file or directory
      Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
      16:57:00.852DEBUGccuCCU-Backup started ...
      16:57:00.966DEBUGccuCCU Version: 3.79.6
      16:57:00.975DEBUGccuRequesting backup from CCU
      [DEBUG] [ccu] start with {"type":"creator","time":"04:30","cronjob":"00 36 01 */3 * *","ownCron":false,"debugging":true,"everyXDays":"4","deleteBackupAfter":0,"signedCertificates":true,"ignoreErrors":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.4.1","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/fritz.nas/SanDisk/SmartHomeBackup/piVCCU3","dirMinimal":"fritz.nas/SanDisk/SmartHomeBackup/ioBroker","user":"ioBroker","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false,"context":{"fileNames":[],"errors":{"mount":{"code":32,"killed":false,"signal":null,"cmd":"sudo mount -t cifs -o username=ioBroker,password=\"!Creative17\",noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.4.1/fritz.nas/SanDisk/SmartHomeBackup/piVCCU3 /opt/iobroker/backups"}},"done":[],"types":[]},"timestamp":1745074608859,"adapter":null,"ccuEvents":[]},"historyHTML":{"enabled":true,"type":"message","entriesNumber":15,"ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":15,"ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longDiscordNotice","target":"","onlyError":false,"discordWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":15,"systemLang":"de"},"host":"192.168.4.91","user":"ioBroker","usehttps":false,"pass":"****","ccuEvents":[],"ccuMulti":false,"backupDir":"/opt/iobroker/backups","timestamp":1745074608859}
      16:57:03.635DEBUGccuCCU-Backup is finish
      16:57:03.643DEBUGccudone
      16:57:04.590DEBUGcifsused copy path: /fritz.nas/SanDisk/SmartHomeBackup/piVCCU3
      16:57:04.622DEBUGcifsdone
      [DEBUG] [cifs] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.4.1","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/fritz.nas/SanDisk/SmartHomeBackup/piVCCU3","dirMinimal":"fritz.nas/SanDisk/SmartHomeBackup/ioBroker","user":"ioBroker","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","timestamp":1745074608859,"ccuEvents":[],"deleteBackupAfter":0}
      16:57:05.204ERRORcleanBackup files not deleted from /opt/iobroker/backups because some errors.
      16:57:05.230DEBUGcleandone
      16:57:05.346DEBUGhistoryHTMLnew history html values created
      16:57:05.440DEBUGhistoryHTMLdone
      [DEBUG] [historyHTML] start with {"type":"creator","time":"04:30","cronjob":"00 36 01 */3 * *","ownCron":false,"debugging":true,"everyXDays":"4","deleteBackupAfter":0,"signedCertificates":true,"ignoreErrors":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.4.1","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/fritz.nas/SanDisk/SmartHomeBackup/piVCCU3","dirMinimal":"fritz.nas/SanDisk/SmartHomeBackup/ioBroker","user":"ioBroker","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/homematic_2025_04_19-16_57_00_3.79.6_backupiobroker.tar.sbk"],"errors":{"mount":{"code":32,"killed":false,"signal":null,"cmd":"sudo mount -t cifs -o username=ioBroker,password=\"!Creative17\",noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.4.1/fritz.nas/SanDisk/SmartHomeBackup/piVCCU3 /opt/iobroker/backups"}},"done":["ccu"],"types":["homematic"]},"timestamp":1745074608859,"adapter":null,"ccuEvents":[]},"historyHTML":{"enabled":true,"type":"message","entriesNumber":15,"ignoreErrors":false,"systemLang":"de","time":"19. April 2025 um 16:57 Uhr"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":15,"ignoreErrors":false,"systemLang":"de"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longDiscordNotice","target":"","onlyError":false,"discordWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":15,"systemLang":"de"},"host":"192.168.4.91","user":"ioBroker","usehttps":false,"pass":"****","ccuEvents":[],"ccuMulti":false,"backupDir":"/opt/iobroker/backups","timestamp":1745074608859}
      16:57:05.704DEBUGhistoryJSONnew history json values created
      16:57:05.730DEBUGhistoryJSONdone
      [DEBUG] [historyJSON] start with {"type":"creator","time":"04:30","cronjob":"00 36 01 */3 * *","ownCron":false,"debugging":true,"everyXDays":"4","deleteBackupAfter":0,"signedCertificates":true,"ignoreErrors":false,"cifs":{"enabled":true,"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.4.1","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/fritz.nas/SanDisk/SmartHomeBackup/piVCCU3","dirMinimal":"fritz.nas/SanDisk/SmartHomeBackup/ioBroker","user":"ioBroker","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false,"context":{"fileNames":["/opt/iobroker/backups/homematic_2025_04_19-16_57_00_3.79.6_backupiobroker.tar.sbk"],"errors":{"mount":{"code":32,"killed":false,"signal":null,"cmd":"sudo mount -t cifs -o username=ioBroker,password=\"!Creative17\",noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.4.1/fritz.nas/SanDisk/SmartHomeBackup/piVCCU3 /opt/iobroker/backups"}},"done":["ccu"],"types":["homematic"]},"timestamp":1745074608859,"adapter":null,"ccuEvents":[]},"historyHTML":{"enabled":true,"type":"message","entriesNumber":15,"ignoreErrors":false,"systemLang":"de"},"historyJSON":{"enabled":true,"type":"message","entriesNumber":15,"ignoreErrors":false,"systemLang":"de","time":"19. April 2025 um 16:57 Uhr"},"telegram":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"telegram.0","SilentNotice":false,"NoticeType":"longTelegramNotice","User":"allTelegramUsers","onlyError":false,"telegramWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"email":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longEmailNotice","emailReceiver":"xxx@xxx.com","emailSender":"xxx@xxx.com","onlyError":false,"emailWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"pushover":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"pushover.0","SilentNotice":false,"NoticeType":"longPushoverNotice","deviceID":"","onlyError":false,"pushoverWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"whatsapp":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longWhatsappNotice","onlyError":false,"whatsappWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"gotify":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longGotifyNotice","onlyError":false,"gotifyWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"signal":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longSignalNotice","onlyError":false,"signalWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"matrix":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longMatrixNotice","onlyError":false,"matrixWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"discord":{"enabled":true,"notificationsType":"Telegram","type":"message","instance":"","NoticeType":"longDiscordNotice","target":"","onlyError":false,"discordWaiting":0,"hostName":"Gro","ignoreErrors":false,"systemLang":"de"},"notification":{"type":"message","ignoreErrors":false,"bashDir":"/opt/iobroker/iobroker-data/backitup","entriesNumber":15,"systemLang":"de"},"host":"192.168.4.91","user":"ioBroker","usehttps":false,"pass":"****","ccuEvents":[],"ccuMulti":false,"backupDir":"/opt/iobroker/backups","timestamp":1745074608859}
      [DEBUG] [umount] start with {"mountType":"CIFS","type":"storage","source":"cifs","mount":"//192.168.4.1","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","wolPort":"9","wolExtra":false,"smb":"vers=3.1.1","sudo":true,"cifsDomain":"","clientInodes":true,"cacheLoose":true,"deleteOldBackup":true,"ownDir":true,"dir":"/fritz.nas/SanDisk/SmartHomeBackup/piVCCU3","dirMinimal":"fritz.nas/SanDisk/SmartHomeBackup/ioBroker","user":"ioBroker","pass":"****","expertMount":"sudo mount -t cifs -o username=<username>,password=\"<password>\",noserverino,cache=loose,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.0.1/NAS/BACKUP /opt/iobroker/backups","ignoreErrors":false,"backupDir":"/opt/iobroker/backups","timestamp":1745074608859,"ccuEvents":[]}
      • L legro
        @simatec
        @legro sagte in Backup von InfluxDB scheitert:
        Da stimmt vermutlich auf dem Server was nicht. Schau dir die Freigaben auf der FritzBox an.
        L 1 Antwort Letzte Antwort
          legro
          Die Freigaben sind alle vorhanden. Von meinem MacBook aus kann ich problemlos darauf zugreifen.
          • L legro
            @legro
            Jedenfalls wird da was nicht gefunden.
              @legro
              legro
              Ganz offensichtlich scheitert der Zugriff auf diese Freigaben bei BackItUp. Daher habe ich mir das Ganze von meinem MacBook aus angeschaut. So sieht's im Finder aus ..
              • L legro
                @legro
                Dann mounte mal von Hand. Dann kannst du besser it den Pfaden usw. spielen.
                  @legro
                  legro
                  @thomas-braun sagte in Backup von InfluxDB scheitert:
                  Dann mounte mal von Hand. ..
                  Jetzt hast du mich erwischt. Ohne nachzulesen, wie das geht, krieg ich das als jahrzehntelanger Windows-Anwender nicht hin.
                  Kannst du mir bitte auf die Sprünge helfen?
                  Hier meine (erster) Versuch ..
                  sudo mount -t cifs //192.168.4.1/SanDisk/SmartHomeBackup /mnt/test -o username=ioBroker,password='<Passwort mit Sonderzeichen>'
                  Derselbe Fehler: no such .. 😕
                  In Windows sieht's bei mir so aus, wenn ich mich mit den Anmeldedaten mit der Freigabe verbinde ..
                  Für mich sieht das alles o.k. aus.
                  • L legro
                    @legro
                    sudo umount /opt/iobroker/backups
                    sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 192.168.4.1/fritz.nas/SanDisk/SmartHomeBackup/piVCCU3 /opt/iobroker/backups
                    Dann würde ich empfehlen, das nachzulesen...
                    Ist z. B. im ubuntu wiki sehr gut erklärt.
                    • L Offline
                      legro
                      Ich habe mich soweit mir das möglich war eingelesen. Dein Vorschlag ist für mich so komplex, dass ich ihn - wenn überhaupt - nur mit äußerster Anstrengung nachvollzogen bekomme. Aber selbst ein einfaches mount, wie hier probiert, funktioniert bereits nicht.
                      Wenn ich das richtig erinnert bekomme, besteht das Problem seit auf meiner Fritz!Box 7590 das neueste Update eingespielt wurde. Wenn dem so ist, suchen wir ggf. an der falschen Stelle, wir müssen wohl danach suchen, was sich in der Fritz!Box wohl mögliche verändert hat.🤔
                      Ich bin nach wie vor komplett ratlos.
                      HomoranH simatecS 2 Antworten Letzte Antwort
                      • L legro
                        @legro und was passiert, mit dem von @thomas-braun vorbereiteten Befehl?
                        • L legro
                          simatecS Offline
                          simatecS Offline
                          simatec
                          @legro bevor du weiter im Dunkeln tappst, schalte mal das NAS Backup aus und teste erstmal lokal.
                          Ich gehe davon aus, dass auch da influx die gleichen Probleme hat.
                          Falls ja, warte ich immer noch auf deine Config von Backitup. Gerade der Teil für Influx ist wichtig
                          • Besuche meine Github Seite
                          • HowTo Restore ioBroker
                          • Thomas BraunT Online
                            Konkret? Was ist da an welcher Stelle komplex?
                            Ich vermute, dass sich da das Volume des Datenträgers auf der FritzBox geändert haben könnte.
                            Das kann man aber irgendwo in der FritzBox ansehen. Weiß nur gerade nicht wo. Steht aber im Wiki des Backitup-Adapters drin.
                            https://wiki.ubuntuusers.de/mount/
                            und
                            https://github.com/simatec/ioBroker.backitup/wiki/Diverse-Anleitungen-für-ioBroker.backitup
                              und
                              legro
                              @thomas-braun @simatec
                              Erst einmal viele Dank für eure Unterstützung.
                              Heute an Ostern ist Familie angesagt.🙂 Vermutlich komme ich erst übermorgen dazu, dem Ganzen nachzugehen.
                              Bevor ich jedoch das Problem mit InfluxDB angehen kann, sollte das Problem mit dem Mounten der Verzeichnisse auf der Fritz!Box geklärt sein.
                              • L legro
                                Deswegen sollst du ja den von @thomas-braun zusammengeklöppelten mount Befehl ausführen und es einmal loksl versuchen, um die Ursache einzugrenzen
                                  legro
                                  @homoran sagte in Backup von InfluxDB scheitert:
                                  Das hatte ich doch gemacht und auch oben geschrieben.
                                  Seit dieser Woche werkelt bei mir eine Synology 923+ NAS. Da alle Daten künftig nur noch darauf landen sollen, werde ich mit Sicherheit mir keinen Knoten in den Kopf machen, um die Fritz!Box erneut dazu zu bewegen, die Backups zu speichern. Das Ganze ist sozusagen bloß noch von akademischem Interesse, will ich doch verstehen, was da plötzlich los ist.
                                  • L legro
                                    wo?
                                    Der Befehl wurde hier
                                    https://forum.iobroker.net/post/1266471
                                    gepostet.
                                    Ab da finde ich von dir keine Konsolenoutputs
                                    und hier https://forum.iobroker.net/post/1266563 hatte @simatec dich gebeten ein lokales Backup zu versuchen.
                                    Auch dazu finde ich von dir nichts
                                      wo?
                                      gepostet.
                                      legro
                                      Bitte sehr das Ganze nunmehr en detail ..
                                      pi@raspiBullseye:~ $ sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 192.168.4.1/fritz.nas/SanDisk/SmartHomeBackup/piVCCU3 /opt/iobroker/backups
                                      mount.cifs: bad UNC (192.168.4.1/fritz.nas/SanDisk/SmartHomeBackup/piVCCU3)
                                      In dieser direkt darunter sich befindenden Antwort habe ich dazu Stellung bezogen, dass u.a. nicht einmal einfachere Beispiele funktionieren.
                                      • L legro
                                        und wegen des verlinkten, nicht funktionierenden, wurde extra für deine Bedingungen (soweit sie aus dem bisherigen ersichtlich waren) dieser eine Befehl zusammengeklöppelt.
                                        Der anschließende erneute Verweis auf das nicht funktionietende ist daher nicht hilfreich gewesen.
                                          Wobei der Befehl auch nur 'Rohmasse' ist. Muss/soll natürlich auf die tatsächlichen Gegebenheiten angepasst werden.
                                          L 2 Antworten Letzte Antwort
