  4. HM RPC (HM IP) - Keine Verbindung HM RPC & CCU3
ccu3homematic ccu3iobroker ccu ccu3raspberrymatic
133 Beiträge 9 Kommentatoren 24.5k Aufrufe 4 Beobachtet
  • Gurke258G Gurke258
    Das hier ist die Langfassung
    Script v.2025-02-23
    *** BASE SYSTEM ***
     Static hostname: HomePi
           Icon name: computer
              Kernel: Linux 6.6.74+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     18:03:52 up 2 days,  8:53,  4 users,  load average: 3.57, 4.37, 2.49
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2025-03-16 18:03:52 CET
               Universal time: Sun 2025-03-16 17:03:52 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** DISPLAY-SERVER SETUP ***
    Display-Server: true
    Desktop:
    Terminal:       tty
    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
    *** MEMORY ***
    Mem:            4.0G        1.9G        612M        134M        1.7G        2.0G
    Swap:           524M        330M        193M
    Total:          4.5G        2.3G        806M
    Active iob-Instances:   21
             3791 M total memory
             1844 M used memory
             1514 M active memory
             1017 M inactive memory
              583 M free memory
              133 M buffer memory
             1441 M swap cache
              499 M total swap
              315 M used swap
              184 M free swap
    top - 18:03:53 up 2 days,  8:53,  4 users,  load average: 3.57, 4.37, 2.49
    Tasks: 255 total,   1 running, 254 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 14.3 sy,  0.0 ni, 85.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   3791.9 total,    583.3 free,   1844.3 used,   1575.8 buff/cache
    MiB Swap:    500.0 total,    185.0 free,    315.0 used.   1947.6 avail Mem
    2 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    162 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    Filesystem                                 Type      Size  Used Avail Use% Mounted on
    udev                                       devtmpfs  1.6G     0  1.6G   0% /dev
    tmpfs                                      tmpfs     380M  1.4M  378M   1% /run
    /dev/mmcblk0p2                             ext4      117G   18G   94G  16% /
    tmpfs                                      tmpfs     1.9G   16M  1.9G   1% /dev/shm
    tmpfs                                      tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1                             vfat      510M   76M  435M  15% /boot/firmware
    tmpfs                                      tmpfs     380M   48K  380M   1% /run/user/1000
    /var:
    5.7G    /var/
    2.5G    /var/log/journal/75097676347f40a48169ebd6234811d1
    2.5G    /var/log
    2.5G    /var/cache/apt
    Archived and active journals take up 2.4G in the file system.
    /opt/iobroker/backups:
    67M     /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.5G    /opt/iobroker/iobroker-data/
    1.4G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
    35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
    24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
    USB-Devices by-id:
    *** ZigBee Settings ***
    HINT:
    Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
    /dev/ttyACM0
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.19.0
    /usr/bin/node           v20.19.0
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.31.0
    nodejs:
      Installed: 20.19.0-1nodesource1
      Candidate: 20.19.0-1nodesource1
      Version table:
     *** 20.19.0-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.18.3-1nodesource1 600
         20.18.2-1nodesource1 600
         20.18.1-1nodesource1 600
         20.18.0-1nodesource1 600
         20.17.0-1nodesource1 600
         20.16.0-1nodesource1 600
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.4.10
    javascript:     8.8.3
    ioBroker-Repositories
    Active repo(s): stable
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: stable
    Objects and States
    Objects:        14544
    States:         12306
    W: https://phoscon.de/apt/deconz/dists/bookworm/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Get:5 https://download.docker.com/linux/debian bookworm InRelease [43.3 kB]
    Hit:6 https://phoscon.de/apt/deconz bookworm InRelease
    Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
    Fetched 43.3 kB in 2s (21.8 kB/s)
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    Meister MopperM Offline
    Meister Mopper
    #66
    @gurke258 sagte in HM RPC (HM IP) - Keine Verbindung HM RPC & CCU3:
    Gib auch mal sudo dmesg --level=emerg,alert,crit -T ein.
    Das könnte weiteren Aufschluss bringen.
    Proxmox und HA ...
    Gurke258G 1 Antwort Letzte Antwort
      Gurke258G Offline
      Gurke258G Offline
      Gurke258
      schrieb am zuletzt editiert von Gurke258
      #67
      @meister-mopper sagte in HM RPC (HM IP) - Keine Verbindung HM RPC & CCU3:
      Hatte ich oben schon angehängt:
      [So Mär 16 18:22:40 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 102276 ms
      [So Mär 16 18:22:41 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 102344 ms
      [So Mär 16 18:22:42 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 104292 ms
      [So Mär 16 18:22:43 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 104348 ms
      [So Mär 16 18:22:44 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 106276 ms
      [So Mär 16 18:22:45 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 106352 ms
      [So Mär 16 18:22:46 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 108292 ms
      [So Mär 16 18:22:47 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 108356 ms
      [So Mär 16 18:22:48 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 110276 ms
      [So Mär 16 18:22:49 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 110360 ms
      [So Mär 16 18:22:50 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 112292 ms
      [So Mär 16 18:22:51 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 112364 ms
      [So Mär 16 18:22:52 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 114276 ms
      [So Mär 16 18:22:53 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 114368 ms
      [So Mär 16 18:22:54 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 116292 ms
      [So Mär 16 18:22:55 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 116372 ms
      [So Mär 16 18:22:56 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 118276 ms
      [So Mär 16 18:22:57 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 118376 ms
      [So Mär 16 18:22:58 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 120292 ms
      [So Mär 16 18:22:59 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 120380 ms
      [So Mär 16 18:23:00 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 122276 ms
      [So Mär 16 18:23:01 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 122384 ms
      [So Mär 16 18:23:02 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 124292 ms
      [So Mär 16 18:23:03 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 124388 ms
      [So Mär 16 18:23:04 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 126276 ms
      [So Mär 16 18:23:05 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 126392 ms
      [So Mär 16 18:23:06 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 128292 ms
      [So Mär 16 18:23:07 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 128396 ms
      [So Mär 16 18:23:08 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 130276 ms
      [So Mär 16 18:23:09 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 130400 ms
      [So Mär 16 18:23:10 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 132292 ms
      [So Mär 16 18:23:11 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 132404 ms
      [So Mär 16 18:23:12 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 134276 ms
      [So Mär 16 18:23:13 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 134408 ms
      [So Mär 16 18:23:14 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 136292 ms
      [So Mär 16 18:23:15 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 136412 ms
      [So Mär 16 18:23:16 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 138276 ms
      [So Mär 16 18:23:17 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 138416 ms
      [So Mär 16 18:23:18 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 140292 ms
      [So Mär 16 18:23:19 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 140420 ms
      [So Mär 16 18:23:20 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 142276 ms
      [So Mär 16 18:23:21 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 142424 ms
      [So Mär 16 18:23:22 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 144292 ms
      [So Mär 16 18:23:23 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 144428 ms
      [So Mär 16 18:23:24 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 146276 ms
      [So Mär 16 18:23:25 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 146432 ms
      [So Mär 16 18:23:26 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 148292 ms
      [So Mär 16 18:23:27 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 148436 ms
      [So Mär 16 18:23:28 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 150276 ms
      [So Mär 16 18:23:29 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 150440 ms
      [So Mär 16 18:23:30 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 152292 ms
      [So Mär 16 18:23:31 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 152444 ms
      [So Mär 16 18:23:32 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 154276 ms
      [So Mär 16 18:23:33 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 154448 ms
      [So Mär 16 18:23:34 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 156292 ms
      [So Mär 16 18:23:35 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 156452 ms
      [So Mär 16 18:23:36 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 158276 ms
      [So Mär 16 18:23:37 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 158456 ms
      [So Mär 16 18:23:38 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 160292 ms
      [So Mär 16 18:23:39 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 160460 ms
      [So Mär 16 18:23:40 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 162276 ms
      [So Mär 16 18:23:41 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 162464 ms
      [So Mär 16 18:23:42 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 164292 ms
      [So Mär 16 18:23:43 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 164468 ms
      [So Mär 16 18:23:44 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 166276 ms
      [So Mär 16 18:23:45 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 166472 ms
      [So Mär 16 18:23:46 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 168292 ms
      [So Mär 16 18:23:47 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 168476 ms
      [So Mär 16 18:23:48 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 170276 ms
      [So Mär 16 18:23:49 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 170480 ms
      [So Mär 16 18:23:50 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 172292 ms
      [So Mär 16 18:23:51 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 172484 ms
      [So Mär 16 18:23:52 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 174276 ms
      [So Mär 16 18:23:53 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 174488 ms
      [So Mär 16 18:23:54 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 176292 ms
      [So Mär 16 18:23:55 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 176492 ms
      [So Mär 16 18:23:56 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 178276 ms
      [So Mär 16 18:23:57 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 178496 ms
      [So Mär 16 18:23:58 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 180292 ms
      [So Mär 16 18:23:59 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 180500 ms
      [So Mär 16 18:24:00 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 182276 ms
      [So Mär 16 18:24:01 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 182504 ms
      [So Mär 16 18:24:02 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 184292 ms
      [So Mär 16 18:24:03 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 184508 ms
      [So Mär 16 18:24:04 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 186276 ms
      [So Mär 16 18:24:05 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 186512 ms
      [So Mär 16 18:24:06 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 188292 ms
      [So Mär 16 18:24:07 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 188516 ms
      [So Mär 16 18:24:08 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 190276 ms
      [So Mär 16 18:24:10 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 191300 ms
      [So Mär 16 18:24:10 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 192292 ms
      [So Mär 16 18:24:11 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 193284 ms
      [So Mär 16 18:24:12 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 194276 ms
      [So Mär 16 18:24:14 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 195300 ms
      [So Mär 16 18:24:14 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 196292 ms
      [So Mär 16 18:24:15 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 197284 ms
      [So Mär 16 18:24:16 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 198276 ms
      [So Mär 16 18:24:18 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 199300 ms
      [So Mär 16 18:24:18 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 200292 ms
      [So Mär 16 18:24:19 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 201284 ms
      [So Mär 16 18:24:20 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 202276 ms
      [So Mär 16 18:24:22 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 203300 ms
      [So Mär 16 18:24:22 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 204292 ms
      [So Mär 16 18:24:23 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 205284 ms
      [So Mär 16 18:24:24 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 206276 ms
      [So Mär 16 18:24:26 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 207300 ms
      [So Mär 16 18:24:26 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 208292 ms
      [So Mär 16 18:24:27 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 209284 ms
      [So Mär 16 18:24:28 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 210276 ms
      [So Mär 16 18:24:30 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 211300 ms
      [So Mär 16 18:24:30 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 212292 ms
      [So Mär 16 18:24:31 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 213284 ms
      [So Mär 16 18:24:32 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 214276 ms
      [So Mär 16 18:24:34 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 215300 ms
      [So Mär 16 18:24:34 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 216292 ms
      [So Mär 16 18:24:35 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 217284 ms
      [So Mär 16 18:24:36 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 218276 ms
      [So Mär 16 18:24:38 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 219300 ms
      [So Mär 16 18:24:38 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 220292 ms
      [So Mär 16 18:24:39 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 221284 ms
      [So Mär 16 18:24:40 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 222276 ms
      [So Mär 16 18:24:42 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 223300 ms
      [So Mär 16 18:24:42 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 224292 ms
      [So Mär 16 18:24:43 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 225284 ms
      [So Mär 16 18:24:44 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 226276 ms
      [So Mär 16 18:24:46 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 227300 ms
      [So Mär 16 18:24:46 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 228292 ms
      [So Mär 16 18:24:47 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 229284 ms
      [So Mär 16 18:24:48 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 230276 ms
      [So Mär 16 18:24:50 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 231300 ms
      [So Mär 16 18:24:50 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 232292 ms
      [So Mär 16 18:24:51 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 233284 ms
      [So Mär 16 18:24:52 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 234276 ms
      [So Mär 16 18:24:54 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 235300 ms
      [So Mär 16 18:24:54 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 236292 ms
      [So Mär 16 18:24:55 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 237288 ms
      [So Mär 16 18:24:56 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 238276 ms
      [So Mär 16 18:24:58 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 239300 ms
      [So Mär 16 18:24:58 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 240292 ms
      [So Mär 16 18:24:59 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 241284 ms
      [So Mär 16 18:25:00 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 242276 ms
      [So Mär 16 18:25:02 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 243300 ms
      [So Mär 16 18:25:02 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 244292 ms
      [So Mär 16 18:25:03 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 245284 ms
      [So Mär 16 18:25:04 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 246276 ms
      [So Mär 16 18:25:06 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 247300 ms
      [So Mär 16 18:25:06 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 248292 ms
      [So Mär 16 18:25:07 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 249284 ms
      [So Mär 16 18:25:08 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 250276 ms
      [So Mär 16 18:25:10 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 251300 ms
      [So Mär 16 18:25:10 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 252292 ms
      [So Mär 16 18:25:11 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 253284 ms
      [So Mär 16 18:25:12 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 254276 ms
      [So Mär 16 18:25:14 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 255300 ms
      [So Mär 16 18:25:14 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 256292 ms
      [So Mär 16 18:25:15 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 257284 ms
      [So Mär 16 18:25:16 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 258276 ms
      [So Mär 16 18:25:18 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 259300 ms
      [So Mär 16 18:25:18 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 260292 ms
      [So Mär 16 18:25:19 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 261284 ms
      [So Mär 16 18:25:20 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 262276 ms
      [So Mär 16 18:25:22 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 263300 ms
      [So Mär 16 18:25:22 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 264292 ms
      [So Mär 16 18:25:23 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 265284 ms
      [So Mär 16 18:25:24 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 266276 ms
      [So Mär 16 18:25:26 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 267300 ms
      [So Mär 16 18:25:26 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 268292 ms
      [So Mär 16 18:25:27 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 269284 ms
      [So Mär 16 18:25:28 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 270276 ms
      [So Mär 16 18:25:30 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 271300 ms
      [So Mär 16 18:25:30 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 272292 ms
      [So Mär 16 18:25:31 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 273284 ms
      [So Mär 16 18:25:32 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 274276 ms
      [So Mär 16 18:25:34 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 275300 ms
      [So Mär 16 18:25:34 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 276292 ms
      [So Mär 16 18:25:35 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 277284 ms
      [So Mär 16 18:25:36 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 278276 ms
      [So Mär 16 18:25:38 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 279300 ms
      [So Mär 16 18:25:38 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 280292 ms
      [So Mär 16 18:25:39 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 281284 ms
      [So Mär 16 18:25:40 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 282276 ms
      [So Mär 16 18:25:42 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 283300 ms
      [So Mär 16 18:25:42 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 284292 ms
      [So Mär 16 18:25:43 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 285284 ms
      [So Mär 16 18:25:44 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 286276 ms
      [So Mär 16 18:25:46 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 287300 ms
      [So Mär 16 18:25:46 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 288292 ms
      [So Mär 16 18:25:47 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 289284 ms
      [So Mär 16 18:25:48 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 290276 ms
      [So Mär 16 18:25:50 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 291300 ms
      [So Mär 16 18:25:50 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 292292 ms
      [So Mär 16 18:25:51 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 293284 ms
      [So Mär 16 18:25:52 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 294276 ms
      [So Mär 16 18:25:54 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 295300 ms
      [So Mär 16 18:25:54 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 296292 ms
      [So Mär 16 18:25:55 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 297284 ms
      [So Mär 16 18:25:56 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 298276 ms
      [So Mär 16 18:25:58 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 299300 ms
      [So Mär 16 18:25:58 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 300292 ms
      [So Mär 16 18:25:59 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 301284 ms
      [So Mär 16 18:26:00 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 302276 ms
      [So Mär 16 18:26:02 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 303300 ms
      [So Mär 16 18:26:02 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 304292 ms
      [So Mär 16 18:26:03 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 305284 ms
      [So Mär 16 18:26:04 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 306276 ms
      [So Mär 16 18:26:06 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 307300 ms
      [So Mär 16 18:26:06 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 308292 ms
      [So Mär 16 18:26:07 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 309284 ms
      [So Mär 16 18:26:08 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 310276 ms
      [So Mär 16 18:26:10 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 311300 ms
      [So Mär 16 18:26:10 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 312292 ms
      [So Mär 16 18:26:11 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 313284 ms
      [So Mär 16 18:26:12 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 314276 ms
      [So Mär 16 18:26:14 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 315300 ms
      [So Mär 16 18:26:14 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 316292 ms
      [So Mär 16 18:26:15 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 317284 ms
      [So Mär 16 18:26:16 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 318276 ms
      [So Mär 16 18:26:18 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 319300 ms
      [So Mär 16 18:26:18 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 320292 ms
      [So Mär 16 18:26:19 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 321284 ms
      [So Mär 16 18:26:20 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 322276 ms
      [So Mär 16 18:26:22 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 323300 ms
      [So Mär 16 18:26:22 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 324292 ms
      [So Mär 16 18:26:23 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 325284 ms
      [So Mär 16 18:26:24 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 0: transmit queue 2 timed out 326276 ms
        Script v.2025-02-23
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        Desktop:
        Terminal:       tty
        *** MEMORY ***
                 3791 M total memory
                 1844 M used memory
                  583 M free memory
                  133 M buffer memory
                 1441 M swap cache
                  499 M total swap
                  315 M used swap
                  184 M free swap
        *** FILESYSTEM ***
        /var:
        5.7G    /var/
        2.5G    /var/log
        2.5G    /var/cache/apt
        USB-Devices by-id:
        HINT:
        /dev/ttyACM0
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          7.4.10
        javascript:     8.8.3
        Objects and States
        Objects:        14544
        States:         12306
        Pending Updates: 0
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        #68
        @gurke258
        Das ist mir aufgefallen:
        Fazit:
        Irgendwie sind da doch einige Fehler drin.
        Aber vielleicht kann @Thomas-Braun mal drüber schauen.
        Danke.
          NetworkManager-wait-online.service loaded failed failed Network Manager Wait Online
          läuft nicht!
          Gurke258G Offline
          Gurke258G Offline
          Gurke258
          #69
          ich versteh auch nicht warum :/
          • bahnuhrB bahnuhr
            @gurke258
            Fazit:
            Gurke258G Offline
            Gurke258G Offline
            Gurke258
            #70
            @bahnuhr sagte in HM RPC (HM IP) - Keine Verbindung HM RPC & CCU3:
            Ja der Stick ist aktuell nicht drin.
              #71
              @gurke258
              schau dir die an.
                @gurke258
                schau dir die an.
                Gurke258G Offline
                Gurke258G Offline
                Gurke258
                #72
                @thomas-braun sagte in HM RPC (HM IP) - Keine Verbindung HM RPC & CCU3:
                @gurke258
                schau dir die an.
                [So Mär 16 19:16:34 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2179868 ms
                [So Mär 16 19:16:35 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2180856 ms
                [So Mär 16 19:16:36 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2181848 ms
                [So Mär 16 19:16:37 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2182840 ms
                [So Mär 16 19:16:38 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2183864 ms
                [So Mär 16 19:16:39 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2184856 ms
                [So Mär 16 19:16:40 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2185848 ms
                [So Mär 16 19:16:41 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2186840 ms
                [So Mär 16 19:16:42 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2187864 ms
                [So Mär 16 19:16:43 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2188856 ms
                [So Mär 16 19:16:44 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2189848 ms
                [So Mär 16 19:16:45 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2190840 ms
                [So Mär 16 19:16:46 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2191864 ms
                [So Mär 16 19:16:47 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2192856 ms
                [So Mär 16 19:16:48 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2193848 ms
                [So Mär 16 19:16:49 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2194840 ms
                [So Mär 16 19:16:50 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2195864 ms
                [So Mär 16 19:16:51 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2196856 ms
                [So Mär 16 19:16:52 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2197848 ms
                [So Mär 16 19:16:53 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2198840 ms
                [So Mär 16 19:16:54 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2199864 ms
                [So Mär 16 19:16:55 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2200856 ms
                [So Mär 16 19:16:56 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2201848 ms
                [So Mär 16 19:16:57 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2202840 ms
                [So Mär 16 19:16:58 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2203864 ms
                [So Mär 16 19:16:59 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2204856 ms
                [So Mär 16 19:17:00 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2205848 ms
                [So Mär 16 19:17:01 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2206840 ms
                [So Mär 16 19:17:02 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2207864 ms
                [So Mär 16 19:17:03 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2208856 ms
                [So Mär 16 19:17:04 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2209848 ms
                [So Mär 16 19:17:05 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2210840 ms
                [So Mär 16 19:17:06 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2211864 ms
                [So Mär 16 19:17:07 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2212856 ms
                [So Mär 16 19:17:08 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2213848 ms
                [So Mär 16 19:17:09 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2214840 ms
                [So Mär 16 19:17:10 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2215864 ms
                [So Mär 16 19:17:11 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2216856 ms
                [So Mär 16 19:17:12 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2217852 ms
                [So Mär 16 19:17:13 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2218840 ms
                [So Mär 16 19:17:14 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2219864 ms
                [So Mär 16 19:17:15 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2220856 ms
                [So Mär 16 19:17:16 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2221848 ms
                [So Mär 16 19:17:17 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2222840 ms
                [So Mär 16 19:17:18 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2223864 ms
                [So Mär 16 19:17:19 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2224856 ms
                [So Mär 16 19:17:20 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2225848 ms
                [So Mär 16 19:17:21 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2226840 ms
                [So Mär 16 19:17:22 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2227864 ms
                [So Mär 16 19:17:23 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2228856 ms
                [So Mär 16 19:17:24 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2229848 ms
                [So Mär 16 19:17:25 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2230840 ms
                [So Mär 16 19:17:26 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2231864 ms
                [So Mär 16 19:17:27 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2232856 ms
                [So Mär 16 19:17:28 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2233848 ms
                [So Mär 16 19:17:29 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2234840 ms
                [So Mär 16 19:17:30 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2235864 ms
                [So Mär 16 19:17:31 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2236856 ms
                [So Mär 16 19:17:32 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2237848 ms
                [So Mär 16 19:17:33 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2238840 ms
                [So Mär 16 19:17:34 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2239864 ms
                [So Mär 16 19:17:35 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2240856 ms
                [So Mär 16 19:17:36 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2241848 ms
                [So Mär 16 19:17:37 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2242840 ms
                [So Mär 16 19:17:38 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2243864 ms
                [So Mär 16 19:17:39 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2244856 ms
                [So Mär 16 19:17:40 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2245848 ms
                [So Mär 16 19:17:41 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2246840 ms
                [So Mär 16 19:17:42 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2247864 ms
                [So Mär 16 19:17:43 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2248856 ms
                [So Mär 16 19:17:44 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2249848 ms
                [So Mär 16 19:17:45 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2250840 ms
                [So Mär 16 19:17:46 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2251864 ms
                [So Mär 16 19:17:47 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2252856 ms
                [So Mär 16 19:17:48 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2253848 ms
                [So Mär 16 19:17:49 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2254840 ms
                [So Mär 16 19:17:50 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2255864 ms
                [So Mär 16 19:17:51 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2256856 ms
                [So Mär 16 19:17:52 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2257848 ms
                [So Mär 16 19:17:53 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2258840 ms
                [So Mär 16 19:17:54 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2259864 ms
                [So Mär 16 19:17:55 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2260856 ms
                [So Mär 16 19:17:56 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2261848 ms
                [So Mär 16 19:17:57 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2262840 ms
                [So Mär 16 19:17:58 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2263864 ms
                [So Mär 16 19:17:59 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2264856 ms
                [So Mär 16 19:18:00 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2265848 ms
                [So Mär 16 19:18:01 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2266840 ms
                [So Mär 16 19:18:02 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2267864 ms
                [So Mär 16 19:18:03 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2268856 ms
                [So Mär 16 19:18:04 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2269848 ms
                [So Mär 16 19:18:05 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2270840 ms
                [So Mär 16 19:18:06 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2271864 ms
                [So Mär 16 19:18:07 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2272856 ms
                [So Mär 16 19:18:08 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2273848 ms
                [So Mär 16 19:18:09 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2274840 ms
                [So Mär 16 19:18:10 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2275864 ms
                [So Mär 16 19:18:11 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2276856 ms
                [So Mär 16 19:18:12 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2277848 ms
                [So Mär 16 19:18:13 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2278840 ms
                [So Mär 16 19:18:14 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2279864 ms
                [So Mär 16 19:18:15 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2280856 ms
                [So Mär 16 19:18:16 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2281848 ms
                [So Mär 16 19:18:17 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2282840 ms
                [So Mär 16 19:18:18 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2283864 ms
                [So Mär 16 19:18:19 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2284856 ms
                [So Mär 16 19:18:20 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2285848 ms
                [So Mär 16 19:18:21 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2286840 ms
                [So Mär 16 19:18:22 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2287864 ms
                [So Mär 16 19:18:23 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2288856 ms
                [So Mär 16 19:18:24 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2289848 ms
                [So Mär 16 19:18:25 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2290840 ms
                [So Mär 16 19:18:26 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2291864 ms
                [So Mär 16 19:18:27 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2292856 ms
                [So Mär 16 19:18:28 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2293848 ms
                [So Mär 16 19:18:29 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2294840 ms
                [So Mär 16 19:18:30 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2295864 ms
                [So Mär 16 19:18:31 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2296856 ms
                [So Mär 16 19:18:32 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2297848 ms
                [So Mär 16 19:18:33 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2298840 ms
                [So Mär 16 19:18:34 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2299864 ms
                [So Mär 16 19:18:35 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2300856 ms
                [So Mär 16 19:18:36 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2301848 ms
                [So Mär 16 19:18:37 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2302840 ms
                [So Mär 16 19:18:38 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2303864 ms
                [So Mär 16 19:18:39 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2304856 ms
                [So Mär 16 19:18:40 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2305848 ms
                [So Mär 16 19:18:41 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2306844 ms
                [So Mär 16 19:18:42 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2307864 ms
                [So Mär 16 19:18:43 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2308860 ms
                [So Mär 16 19:18:44 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2309852 ms
                [So Mär 16 19:18:45 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2310840 ms
                [So Mär 16 19:18:46 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2311864 ms
                [So Mär 16 19:18:47 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2312856 ms
                [So Mär 16 19:18:48 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2313848 ms
                [So Mär 16 19:18:49 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2314840 ms
                [So Mär 16 19:18:50 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2315864 ms
                [So Mär 16 19:18:51 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2316856 ms
                [So Mär 16 19:18:52 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2317848 ms
                [So Mär 16 19:18:53 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2318840 ms
                [So Mär 16 19:18:54 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2319864 ms
                [So Mär 16 19:18:55 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2320860 ms
                [So Mär 16 19:18:56 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2321848 ms
                [So Mär 16 19:18:57 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2322844 ms
                [So Mär 16 19:18:58 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2323864 ms
                [So Mär 16 19:18:59 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2324856 ms
                [So Mär 16 19:19:00 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2325852 ms
                [So Mär 16 19:19:01 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2326840 ms
                [So Mär 16 19:19:02 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2327864 ms
                [So Mär 16 19:19:03 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2328856 ms
                [So Mär 16 19:19:04 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2329852 ms
                [So Mär 16 19:19:05 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2330840 ms
                [So Mär 16 19:19:06 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2331864 ms
                [So Mär 16 19:19:07 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2332856 ms
                [So Mär 16 19:19:08 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2333848 ms
                [So Mär 16 19:19:09 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2334840 ms
                [So Mär 16 19:19:10 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2335864 ms
                [So Mär 16 19:19:11 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2336856 ms
                [So Mär 16 19:19:12 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2337848 ms
                [So Mär 16 19:19:13 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2338840 ms
                [So Mär 16 19:19:14 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2339864 ms
                [So Mär 16 19:19:15 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2340856 ms
                [So Mär 16 19:19:16 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2341848 ms
                [So Mär 16 19:19:17 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2342840 ms
                [So Mär 16 19:19:18 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2343864 ms
                [So Mär 16 19:19:19 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2344856 ms
                [So Mär 16 19:19:20 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2345848 ms
                [So Mär 16 19:19:21 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2346840 ms
                [So Mär 16 19:19:22 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2347864 ms
                [So Mär 16 19:19:23 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2348856 ms
                [So Mär 16 19:19:24 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2349848 ms
                [So Mär 16 19:19:25 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2350840 ms
                [So Mär 16 19:19:26 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2351864 ms
                [So Mär 16 19:19:27 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2352856 ms
                [So Mär 16 19:19:28 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2353848 ms
                [So Mär 16 19:19:29 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2354840 ms
                [So Mär 16 19:19:30 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2355864 ms
                [So Mär 16 19:19:31 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2356856 ms
                [So Mär 16 19:19:32 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2357848 ms
                [So Mär 16 19:19:33 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2358840 ms
                [So Mär 16 19:19:34 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2359864 ms
                [So Mär 16 19:19:35 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2360856 ms
                [So Mär 16 19:19:36 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2361848 ms
                [So Mär 16 19:19:37 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2362840 ms
                [So Mär 16 19:19:38 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2363868 ms
                [So Mär 16 19:19:39 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2364856 ms
                [So Mär 16 19:19:40 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2365852 ms
                [So Mär 16 19:19:41 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2366840 ms
                [So Mär 16 19:19:42 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2367864 ms
                [So Mär 16 19:19:43 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2368856 ms
                [So Mär 16 19:19:44 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2369848 ms
                [So Mär 16 19:19:45 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2370840 ms
                [So Mär 16 19:19:46 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2371864 ms
                [So Mär 16 19:19:47 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2372856 ms
                [So Mär 16 19:19:48 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2373848 ms
                [So Mär 16 19:19:49 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2374840 ms
                [So Mär 16 19:19:50 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2375864 ms
                [So Mär 16 19:19:51 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2376856 ms
                [So Mär 16 19:19:52 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2377848 ms
                [So Mär 16 19:19:53 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2378840 ms
                [So Mär 16 19:19:54 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2379864 ms
                [So Mär 16 19:19:55 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2380856 ms
                [So Mär 16 19:19:56 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2381848 ms
                [So Mär 16 19:19:57 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2382840 ms
                [So Mär 16 19:19:58 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2383864 ms
                [So Mär 16 19:19:59 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2384856 ms
                [So Mär 16 19:20:00 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2385848 ms
                [So Mär 16 19:20:01 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2386840 ms
                [So Mär 16 19:20:02 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2387864 ms
                [So Mär 16 19:20:03 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2388856 ms
                [So Mär 16 19:20:04 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2389848 ms
                [So Mär 16 19:20:05 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2390840 ms
                [So Mär 16 19:20:06 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2391864 ms
                [So Mär 16 19:20:07 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2392856 ms
                [So Mär 16 19:20:08 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2393848 ms
                [So Mär 16 19:20:09 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2394840 ms
                [So Mär 16 19:20:10 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2395864 ms
                [So Mär 16 19:20:11 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2396856 ms
                [So Mär 16 19:20:12 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2397852 ms
                [So Mär 16 19:20:13 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2398840 ms
                [So Mär 16 19:20:14 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2399864 ms
                [So Mär 16 19:20:15 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2400856 ms
                [So Mär 16 19:20:16 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2401848 ms
                [So Mär 16 19:20:17 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2402840 ms
                [So Mär 16 19:20:18 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2403864 ms
                [So Mär 16 19:20:19 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2404856 ms
                [So Mär 16 19:20:20 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2405848 ms
                [So Mär 16 19:20:21 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2406840 ms
                [So Mär 16 19:20:22 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2407864 ms
                [So Mär 16 19:20:23 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2408856 ms
                [So Mär 16 19:20:24 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2409848 ms
                [So Mär 16 19:20:25 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2410840 ms
                [So Mär 16 19:20:26 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2411864 ms
                [So Mär 16 19:20:27 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2412856 ms
                [So Mär 16 19:20:28 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2413848 ms
                [So Mär 16 19:20:29 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2414840 ms
                [So Mär 16 19:20:30 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2415864 ms
                [So Mär 16 19:20:31 2025] bcmgenet fd580000.ethernet eth0: NETDEV WATCHDOG: CPU: 2: transmit queue 2 timed out 2416856 ms
                gerne hier nochmal ^^ leider kann ich nicht so viel damit anfangen
                Ich denke das evtl hiermit zusammenhängt:
                × NetworkManager-wait-online.service - Network Manager Wait Online
                     Loaded: loaded (/lib/systemd/system/NetworkManager-wait-online.service; enabled; preset: enabled)
                     Active: failed (Result: exit-code) since Sun 2025-03-16 18:40:10 CET; 44min ago
                       Docs: man:nm-online(1)
                   Main PID: 820 (code=exited, status=1/FAILURE)
                        CPU: 132ms
                Mär 16 18:38:47 HomePi systemd[1]: Starting NetworkManager-wait-online.service - Network Manager Wait Online...
                Mär 16 18:40:10 HomePi systemd[1]: NetworkManager-wait-online.service: Main process exited, code=exited, status=1/FAILURE
                Mär 16 18:40:10 HomePi systemd[1]: NetworkManager-wait-online.service: Failed with result 'exit-code'.
                Mär 16 18:40:10 HomePi systemd[1]: Failed to start NetworkManager-wait-online.service - Network Manager Wait Online.
                • Gurke258G Gurke258
                  @gurke258
                  162 CRITICAL ERRORS DETECTED!
                  Check 'sudo dmesg --level=emerg,alert,crit -T' for details
                  schau dir die an.
                          CPU: 132ms
                  wendy2702W Online
                  wendy2702W Online
                  #73
                  @gurke258 wie sieht das Netzwerk aus?
                  Verkabelung?
                  Switch?
                  Router?
                  Power LAN?
                  • wendy2702W wendy2702
                    Verkabelung?
                    Switch?
                    Router?
                    Power LAN?
                    Gurke258G Offline
                    Gurke258G Offline
                    Gurke258
                    #74
                    @wendy2702 sagte in HM RPC (HM IP) - Keine Verbindung HM RPC & CCU3:
                    Verkabelung?
                    Switch?
                    Router?
                    Power LAN?
                    So ich habe mein WLAN Repeater gefixt ^^
                    Also Netzwerk ist aktuell so:
                    Fritzbox sendet WLAN
                    Repeater im Flur (TPLink-R365 inkl. Steckdose (gerade gefixt das Ethernet wieder geht)) dann per LAN an den Raspberry mit Iobroker
                    Repeater im Wohnzimmer (Fritz 2400) -> LAN zum Switch & dann per LAN zur CCU3
                    Anders leider nicht möglich ohne zu viel Kabel zuziehen in der MIetswohnung :(
                    Nach dem der LAN-Port wieder geht funktioniert auch der NetzwerkManager wieder
                    ● NetworkManager-wait-online.service - Network Manager Wait Online
                         Active: active (exited) since Sun 2025-03-16 19:40:48 CET; 5min ago
                       Main PID: 824 (code=exited, status=0/SUCCESS)
                            CPU: 123ms
                    gibt auch keine Fehler mehr aus
                    Hab jetzt auch theoretisch wieder LAN zur verfügung:
                      Verkabelung?
                      Switch?
                      Router?
                      Power LAN?
                              CPU: 123ms
                      #75
                      @gurke258 sagte in HM RPC (HM IP) - Keine Verbindung HM RPC & CCU3:
                      und auch die CCU?
                      Gurke258G 1 Antwort Letzte Antwort
                      • wendy2702W Online
                        wendy2702W Online
                        #76
                        @Gurke258 kenne natürlich eure Wohnung nicht aber warum stellst du CCU und Iob nicht so auf das beide ohne WLAN gedöns dazwischen auskommen und fest per Kabel direkt an der Fritte hängen?
                          und auch die CCU?
                          Gurke258G Offline
                          Gurke258G Offline
                          Gurke258
                          #77
                          @homoran sagte in HM RPC (HM IP) - Keine Verbindung HM RPC & CCU3:
                          und auch die CCU?
                          Leider nicht :(
                          Immer noch ist der RPC gelb...
                          Hier die aktuelle Config:
                          2025-03-16 19_53_48-Window.png 2025-03-16 19_53_44-Window.png 2025-03-16 19_53_35-Window.png 2025-03-16 19_52_48-Window.png 2025-03-16 19_51_23-Window.png 2025-03-16 19_51_17-Window.png 2025-03-16 19_51_02-Window.png
                            Gurke258G Offline
                            Gurke258G Offline
                            Gurke258
                            #78
                            Das ist leider nicht so einfach möglich.
                            Ich könnte maximal die CCU in nähe des Iob RPi4 stellen aber dann kann ich leider nicht per Kabel an die Fritzbox dran :/
                            HomoranH wendy2702W 2 Antworten Letzte Antwort
                              #79
                              @gurke258 warum machst du nicht was man sagt?
                              hast du noch die ports für https
                              ändere das!
                                ändere das!
                                Gurke258G Offline
                                Gurke258G Offline
                                Gurke258
                                #80
                                ändere das!
                                Okay ich habe jetzt statt 42001 -> 2001 eingetragen und bei 42010 -> 2010 eingetragen, die Haken aber bei HTTPS in beiden Adaptern gelassen.
                                Jetzt ist auch der RPC.1 von Homematic IP gelb
                                hm-rpc.1
                                2025-03-16 20:24:17.391	error	Init not possible, going to stop: write EPROTO 40A035AC7F000000:error:0A00010B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:354:
                                hm-rpc.0
                                2025-03-16 20:24:06.943	error	Init not possible, going to stop: write EPROTO 40D01CAC7F000000:error:0A00010B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:354:
                                hm-rpc.1
                                2025-03-16 20:23:42.077	error	Cannot call init: [http://192.168.178.75:2010, ""] write EPROTO 40D0ABB07F000000:error:0A00010B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:354:
                                hm-rpc.1
                                2025-03-16 20:23:42.040	error	Init not possible, going to stop: write EPROTO 40D0ABB07F000000:error:0A00010B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:354:
                                hm-rpc.0
                                2025-03-16 20:23:31.309	error	Cannot call init: [http://192.168.178.75:2001, ""] write EPROTO 406013977F000000:error:0A00010B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:354:
                                hm-rpc.0
                                2025-03-16 20:23:31.288	error	Init not possible, going to stop: write EPROTO 406013977F000000:error:0A00010B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:354:
                                hm-rpc.1
                                2025-03-16 20:23:12.051	error	Init not possible, going to stop: write EPROTO 40D0ABB07F000000:error:0A00010B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:354:
                                hm-rpc.0
                                2025-03-16 20:23:01.289	error	Init not possible, going to stop: write EPROTO 406013977F000000:error:0A00010B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:354:
                                hm-rpc.1
                                2025-03-16 20:22:37.126	error	Cannot call init: [http://192.168.178.75:2010, ""] write EPROTO 40C024977F000000:error:0A00010B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:354:
                                hm-rpc.1
                                2025-03-16 20:22:37.105	error	Init not possible, going to stop: write EPROTO 40C024977F000000:error:0A00010B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:354:
                                hm-rpc.0
                                2025-03-16 20:22:26.502	error	Cannot call init: [http://192.168.178.75:2001, ""] write EPROTO 4050908D7F000000:error:0A00010B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:354:
                                hm-rpc.0
                                2025-03-16 20:22:26.481	error	Init not possible, going to stop: write EPROTO 4050908D7F000000:error:0A00010B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:354:
                                hm-rpc.1
                                2025-03-16 20:22:07.105	error	Init not possible, going to stop: write EPROTO 40C024977F000000:error:0A00010B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:354:
                                hm-rpc.0
                                2025-03-16 20:21:56.481	error	Init not possible, going to stop: write EPROTO 4050908D7F000000:error:0A00010B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:354:
                                hm-rpc.0
                                2025-03-16 20:21:49.769	error	Cannot call init: [http://192.168.178.75:42001, ""] Unknown XML-RPC tag 'TITLE'
                                hm-rpc.0
                                2025-03-16 20:21:49.746	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                                hm-rpc.0
                                2025-03-16 20:21:19.688	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                                hm-rpc.0
                                2025-03-16 20:20:34.833	error	Cannot call init: [http://192.168.178.75:42001, ""] Unknown XML-RPC tag 'TITLE'
                                hm-rpc.0
                                2025-03-16 20:20:34.415	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                                hm-rpc.0
                                2025-03-16 20:20:04.809	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                                hm-rpc.0
                                2025-03-16 20:19:19.350	error	Cannot call init: [http://192.168.178.75:42001, ""] Unknown XML-RPC tag 'TITLE'
                                hm-rpc.0
                                2025-03-16 20:19:19.317	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                                  ändere das!
                                  hm-rpc.1
                                  hm-rpc.0
                                  hm-rpc.1
                                  hm-rpc.1
                                  hm-rpc.0
                                  hm-rpc.0
                                  hm-rpc.1
                                  hm-rpc.0
                                  hm-rpc.1
                                  hm-rpc.1
                                  hm-rpc.0
                                  hm-rpc.0
                                  hm-rpc.1
                                  hm-rpc.0
                                  hm-rpc.0
                                  hm-rpc.0
                                  hm-rpc.0
                                  hm-rpc.0
                                  hm-rpc.0
                                  hm-rpc.0
                                  hm-rpc.0
                                  hm-rpc.0
                                  #81
                                  nein!
                                  wieso?
                                  was soll das bezwecken?
                                    nein!
                                    wieso?
                                    Gurke258G Offline
                                    Gurke258G Offline
                                    Gurke258
                                    #82
                                    nein!
                                    wieso?
                                    ändere das!
                                    Hatte nur das gemacht was du gesagt hattest. Sorry :/
                                    Haken sind draußen und Ports wie oben beschrieben. RPC.1 Adapter ist wieder grün. aber der RPC.0 bleibt gelb und es kommen die selben fehlermeldungen im Log:
                                    hm-rpc.0
                                    2025-03-16 20:30:59.917	error	Cannot call init: [http://192.168.178.75:2001, ""] Unknown XML-RPC tag 'TITLE'
                                    hm-rpc.0
                                    2025-03-16 20:30:59.666	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                                    hm-rpc.0
                                    2025-03-16 20:30:29.902	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                                    hm-rpc.0
                                    2025-03-16 20:29:45.338	error	Cannot call init: [http://192.168.178.75:2001, ""] Unknown XML-RPC tag 'TITLE'
                                    hm-rpc.0
                                    2025-03-16 20:29:44.517	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                                    hm-rpc.0
                                    2025-03-16 20:29:15.314	error	Init not possible, going to stop: Unknown XML-RPC tag 'TITLE'
                                    HomoranH haselchenH 2 Antworten Letzte Antwort
                                      nein!
                                      wieso?
                                      ändere das!
                                      hm-rpc.0
                                      hm-rpc.0
                                      hm-rpc.0
                                      hm-rpc.0
                                      hm-rpc.0
                                      hm-rpc.0
                                      #83
                                      und das war
                                      @gurke258
                                      Dann mal schrittweise!
                                      erstmal Umleitung auf https aktivieren!
                                      und sonst nichts!
                                        und das war
                                        @gurke258
                                        und sonst nichts!
                                        Gurke258G Offline
                                        Gurke258G Offline
                                        Gurke258
                                        #84
                                        tut mir leid.
                                        hm-rpc.0
                                        2025-03-16 20:32:45.099	error	Error: DB closed
                                        Dieser Fehler kam jetzt neu dazu, den kannte ich noch nicht
                                          nein!
                                          wieso?
                                          ändere das!
                                          hm-rpc.0
                                          hm-rpc.0
                                          hm-rpc.0
                                          hm-rpc.0
                                          hm-rpc.0
                                          hm-rpc.0
                                          haselchenH Offline
                                          haselchenH Offline
                                          haselchen
                                          #85
                                          @gurke258
                                          Hast Du jetzt mal die CCU3 neu gestartet?
                                          HomoranH Gurke258G 2 Antworten Letzte Antwort
