  4. Falsche admin Version obwohl aktuell
25 Beiträge 5 Kommentatoren 3.2k Aufrufe 3 Beobachtet
  • J jwerlsdf
    ```bash
    Script v.2025-02-23
    *** BASE SYSTEM ***
     Static hostname: iobroker-master
           Icon name: computer
              Kernel: Linux 6.6.74+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     22:29:18 up 23:16,  3 users,  load average: 0.71, 0.89, 0.92
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Mon 2025-03-10 22:29:18 CET
               Universal time: Mon 2025-03-10 21:29:18 UTC
                     RTC time: Mon 2025-03-10 21:29:18
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    pi
    HOME=/home/pi
    GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin docker gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            8.4G        3.2G        1.7G        6.8M        3.6G        5.2G
    Swap:           209M          0B        209M
    Total:          8.7G        3.2G        1.9G
    Active iob-Instances:   43
             8052 M total memory
             3058 M used memory
             3550 M active memory
             2294 M inactive memory
             1629 M free memory
              237 M buffer memory
             3227 M swap cache
              199 M total swap
                0 M used swap
              199 M free swap
    top - 22:29:18 up 23:16,  3 users,  load average: 0.71, 0.89, 0.92
    Tasks: 242 total,   2 running, 240 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   8052.2 total,   1628.2 free,   3060.1 used,   3465.0 buff/cache
    MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4992.1 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    Filesystem                        Type      Size  Used Avail Use% Mounted on
    udev                              devtmpfs  3.9G     0  3.9G   0% /dev
    tmpfs                             tmpfs     806M  6.3M  799M   1% /run
    /dev/sda2                         ext4       55G   19G   34G  36% /
    tmpfs                             tmpfs     4.0G     0  4.0G   0% /dev/shm
    tmpfs                             tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/sda1                         vfat      510M   76M  435M  15% /boot/firmware
    //192.168.178.39/Sicherungskopien cifs       15T  5.4T  9.1T  38% /Sicherungskopien
    //192.168.178.39/video            cifs       15T  5.4T  9.1T  38% /video
    //192.168.178.39/Küche           cifs       15T  5.4T  9.1T  38% /Kueche
    //192.168.178.39/music            cifs       15T  5.4T  9.1T  38% /music
    tmpfs                             tmpfs     806M  160K  806M   1% /run/user/1000
    [Sun Mar  9 23:12:32 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:2F:B4:2F vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=eb2f63c1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
    [Sun Mar  9 23:12:33 2025] EXT4-fs (sda2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
    [Sun Mar  9 23:12:33 2025] EXT4-fs (sda2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET              SOURCE                            FSTYPE OPTIONS
    /                   /dev/sda2                         ext4   rw,noatime
    |-/boot/firmware    /dev/sda1                         vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    |-/music            //192.168.178.39/music            cifs   rw,relatime,vers=1.0,cache=strict,username=pi,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.178.39,soft,unix,posixpaths,serverino,mapposix,acl,reparse=nfs,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
    |-/video            //192.168.178.39/video            cifs   rw,relatime,vers=1.0,cache=strict,username=pi,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.178.39,soft,unix,posixpaths,serverino,mapposix,acl,reparse=nfs,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
    |-/Sicherungskopien //192.168.178.39/Sicherungskopien cifs   rw,relatime,vers=1.0,cache=strict,username=pi,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.178.39,soft,unix,posixpaths,serverino,mapposix,acl,reparse=nfs,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
    `-/Kueche           //192.168.178.39/K\xc3\xbcche     cifs   rw,relatime,vers=1.0,cache=strict,username=pi,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.178.39,soft,unix,posixpaths,serverino,mapposix,acl,reparse=nfs,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
    /var:
    2.8G    /var/
    1.3G    /var/lib
    1.1G    /var/lib/docker/overlay2
    785M    /var/log
    Archived and active journals take up 783.8M in the file system.
    /opt/iobroker/backups:
    2.2G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    890M    /opt/iobroker/iobroker-data/
    665M    /opt/iobroker/iobroker-data/files
    196M    /opt/iobroker/iobroker-data/files/vis-2
    120M    /opt/iobroker/iobroker-data/files/vis
    118M    /opt/iobroker/iobroker-data/backup-objects
    33M     /opt/iobroker/iobroker-data/objects.jsonl
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    16M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.41623696.js.map
    16M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
    15M     /opt/iobroker/iobroker-data/files/vis-2/static/js/118.cf753117.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.3
    /usr/bin/node           v20.18.3
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.30.0
    nodejs:
      Installed: 20.18.3-1nodesource1
      Candidate: 20.18.3-1nodesource1
      Version table:
     *** 20.18.3-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.18.2-1nodesource1 600
         20.18.1-1nodesource1 600
         20.18.0-1nodesource1 600
         20.17.0-1nodesource1 600
         20.16.0-1nodesource1 600
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker-master     iobroker-master (version: 7.0.6, hostname: iobroker-master, alive, uptime: 633)
    iobroker-slave      iobroker-slave (version: 7.0.6, hostname: iobroker-slave, alive, uptime: 1173)
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.6.2
    javascript:     8.9.1
    nodejs modules from github:     1
    | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-master                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker-master                          -  enabled
    + system.adapter.bring.0                  : bring                 : iobroker-master                          -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker-master                          -  enabled
    + system.adapter.deconz.0                 : deconz                : iobroker-master                          -  enabled, port: 6060
    + system.adapter.denon.0                  : denon                 : iobroker-master                          -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker-master                          -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker-master                          -  enabled
    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-master                          -  enabled
    + system.adapter.eusec.0                  : eusec                 : iobroker-master                          -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker-master                          -  enabled
    + system.adapter.firetv.0                 : firetv                : iobroker-master                          -  enabled
      system.adapter.flot.0                   : flot                  : iobroker-master                          - disabled
    + system.adapter.fullybrowser.0           : fullybrowser          : iobroker-master                          -  enabled
    + system.adapter.heos.0                   : heos                  : iobroker-master                          -  enabled
      system.adapter.history.0                : history               : iobroker-master                          - disabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker-master                          -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-master                          -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-master                          -  enabled, port: 0
    + system.adapter.homeconnect.0            : homeconnect           : iobroker-master                          -  enabled
      system.adapter.ical.0                   : ical                  : iobroker-master                          -  enabled
      system.adapter.ical.1                   : ical                  : iobroker-master                          -  enabled
      system.adapter.ical.2                   : ical                  : iobroker-master                          -  enabled
      system.adapter.ical.3                   : ical                  : iobroker-master                          -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-master                          - disabled
    + system.adapter.javascript.0             : javascript            : iobroker-master                          -  enabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker-master                          -  enabled, port: 54321
    + system.adapter.modbus.0                 : modbus                : iobroker-master                          -  enabled
    + system.adapter.modbus.1                 : modbus                : iobroker-master                          -  enabled
    + system.adapter.modbus.2                 : modbus                : iobroker-master                          -  enabled
    + system.adapter.mpd.0                    : mpd                   : iobroker-master                          -  enabled, port: 6600
    + system.adapter.netatmo.0                : netatmo               : iobroker-master                          -  enabled
    + system.adapter.nina.0                   : nina                  : iobroker-master                          -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : iobroker-master                          -  enabled
    + system.adapter.radar2.0                 : radar2                : iobroker-master                          -  enabled
    + system.adapter.rssfeed.0                : rssfeed               : iobroker-master                          -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker-master                          -  enabled, port: 1882, bind: 192.168.178.70
    + system.adapter.smartgarden.0            : smartgarden           : iobroker-master                          -  enabled
    + system.adapter.sonos.0                  : sonos                 : iobroker-master                          -  enabled
    + system.adapter.synochat.0               : synochat              : iobroker-master                          -  enabled
    + system.adapter.synology.0               : synology              : iobroker-master                          -  enabled, port: 5000
    + system.adapter.synology.1               : synology              : iobroker-master                          -  enabled, port: 5000
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-master                          -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker-master                          -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.time-switch.0            : time-switch           : iobroker-master                          -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobroker-master                          -  enabled
    + system.adapter.trashschedule.0          : trashschedule         : iobroker-master                          -  enabled
    + system.adapter.trashschedule.1          : trashschedule         : iobroker-master                          -  enabled
      system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker-master                          -  enabled
      system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker-master                          -  enabled
      system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker-master                          -  enabled
      system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker-master                          -  enabled
      system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: iobroker-master                          -  enabled
    + system.adapter.vis-2.0                  : vis-2                 : iobroker-master                          -  enabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-master                          - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker-master                          - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-master                          - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-master                          - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-master                          - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker-master                          - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker-master                          - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-master                          - disabled
      system.adapter.vis.0                    : vis                   : iobroker-master                          -  enabled
    + system.adapter.weather-warnings.0       : weather-warnings      : iobroker-master                          -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : iobroker-master                          -  enabled
    + system.adapter.web.0                    : web                   : iobroker-master                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : iobroker-master                          -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: beta
    Adapter    "admin"        : 7.6.2    , installed 7.6.2
    Adapter    "backitup"     : 3.1.0    , installed 3.1.0
    Adapter    "bring"        : 1.9.1    , installed 1.9.1
    Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
    Adapter    "deconz"       : 1.6.4    , installed 1.6.4
    Adapter    "denon"        : 1.15.12  , installed 1.15.12
    Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
    Adapter    "eusec"        : 1.3.3    , installed 1.3.3
    Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
    Adapter    "firetv"       : 2.1.0    , installed 2.1.0
    Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
    Adapter    "heos"         : 2.2.4    , installed 2.2.4
    Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
    Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
    Adapter    "ical"         : 1.16.1   , installed 1.16.1
    Adapter    "javascript"   : 8.9.1    , installed 8.9.1
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "mihome-vacuum": 5.2.0    , installed 4.2.0  [Updatable]
    Adapter    "modbus"       : 6.4.0    , installed 6.4.0
    Adapter    "mpd"          : 2.2.0    , installed 2.2.0
    Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
    Adapter    "nina"         : 0.0.26   , installed 0.0.26
    Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
    Adapter    "radar2"       : 2.2.0    , installed 2.2.0
    Adapter    "rssfeed"      : 3.4.1    , installed 3.4.1
    Adapter    "shelly"       : 9.1.0    , installed 9.1.0
    Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
    Adapter    "socketio"     : 7.0.8    , installed 7.0.8
    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
    Adapter    "synochat"     : 1.3.3    , installed 1.3.3
    Adapter    "synology"     : 3.1.0    , installed 3.1.0
    Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
    Adapter    "telegram"     : 4.0.0    , installed 4.0.0
    Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
    Adapter    "trashschedule": 4.0.0    , installed 3.4.1  [Updatable]
    Adapter    "vis-2"        : 2.11.2   , installed 2.11.2
    Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
    Adapter    "vis-2-widgets-gauges": 1.1.1, installed 1.1.1
    Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
    Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
    Adapter    "vis-2-widgets-weather-and-heating": 0.10.0, installed 0.10.0
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "weather-warnings": 0.7.4 , installed 0.7.4
    Adapter    "weatherunderground": 3.7.0, installed 3.7.0
    Adapter    "web"          : 7.0.6    , installed 7.0.6
    Adapter    "wled"         : 0.7.3    , installed 0.7.3
    Adapter    "ws"           : 3.0.19   , installed 3.0.19
    Objects and States
    Objects:        28973
    States:         25586
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://download.docker.com/linux/debian bookworm InRelease
    Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 3
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8000            0.0.0.0:*               LISTEN      0          6896       1485/docker-proxy
    tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       1139990    47089/adb
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          66615      4529/cupsd
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       1138522    46787/iobroker.js-c
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       1138527    46787/iobroker.js-c
    tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      1000       9834       1618/node
    tcp        0      0 0.0.0.0:5004            0.0.0.0:*               LISTEN      0          17409      2630/node
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8478       944/sshd: /usr/sbin
    tcp        0      0 0.0.0.0:9443            0.0.0.0:*               LISTEN      0          6898       1497/docker-proxy
    tcp        0      0 192.168.178.70:2010     0.0.0.0:*               LISTEN      1001       1140107    47229/io.hm-rpc.1
    tcp        0      0 192.168.178.70:2001     0.0.0.0:*               LISTEN      1001       1139642    47214/io.hm-rpc.0
    tcp        0      0 192.168.178.70:1882     0.0.0.0:*               LISTEN      1001       1140290    47385/io.shelly.0
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          66614      4529/cupsd
    tcp6       0      0 :::3000                 :::*                    LISTEN      1001       1141895    47141/io.fullybrows
    tcp6       0      0 :::8000                 :::*                    LISTEN      0          6897       1491/docker-proxy
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1145040    47812/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1138562    46805/io.admin.0
    tcp6       0      0 :::3502                 :::*                    LISTEN      1001       1142215    47400/io.sonos.0
    tcp6       0      0 :::3501                 :::*                    LISTEN      1000       10351      1618/node
    tcp6       0      0 :::3500                 :::*                    LISTEN      0          17411      2630/node
    tcp6       0      0 :::22                   :::*                    LISTEN      0          8480       944/sshd: /usr/sbin
    tcp6       0      0 :::8555                 :::*                    LISTEN      1001       1143323    47595/go2rtc
    tcp6       0      0 :::8554                 :::*                    LISTEN      1001       1143322    47595/go2rtc
    tcp6       0      0 :::5900                 :::*                    LISTEN      992        8491       906/wayvnc
    tcp6       0      0 :::1984                 :::*                    LISTEN      1001       1140542    47595/go2rtc
    tcp6       0      0 :::9443                 :::*                    LISTEN      0          6899       1504/docker-proxy
    udp        0      0 0.0.0.0:57268           0.0.0.0:*                           1001       1139624    46847/io.javascript
    udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       1142167    47349/io.radar2.0
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1143144    47508/io.mihome-vac
    udp        0      0 0.0.0.0:37608           0.0.0.0:*                           1001       1139614    47184/io.heos.0
    udp        0      0 0.0.0.0:41971           0.0.0.0:*                           1001       1139625    46847/io.javascript
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1145884    47827/io.wled.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7643       710/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       1139410    46915/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       1139406    46915/io.deconz.0
    udp        0      0 0.0.0.0:55930           0.0.0.0:*                           1001       1139613    47184/io.heos.0
    udp        0      0 0.0.0.0:52219           0.0.0.0:*                           1001       1142496    47569/io.eusec.0
    udp        0      0 0.0.0.0:52298           0.0.0.0:*                           104        7645       710/avahi-daemon: r
    udp6       0      0 :::8555                 :::*                                1001       1143324    47595/go2rtc
    udp6       0      0 fe80::2188:5528:66b:546 :::*                                0          6676       831/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        7644       710/avahi-daemon: r
    udp6       0      0 :::55035                :::*                                104        7646       710/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       1139412    46915/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       1139411    46915/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       1139409    46915/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       1139408    46915/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       1139407    46915/io.deconz.0
    2025-03-10 22:21:59.781  - info: vis-2.0 (47857) vis-2 license is OK.
    2025-03-10 22:22:00.486  - info: weather-warnings.0 (47842) Refresh Interval: 15 minutes
    2025-03-10 22:22:00.557  - info: weather-warnings.0 (47842) [telegram] Create notification service telegram adapter: telegram.0.
    2025-03-10 22:22:00.558  - info: weather-warnings.0 (47842) DWD 106631000 activated. Retrieve data.
    2025-03-10 22:22:00.563  - info: weather-warnings.0 (47842) UWZ activated. Retrieve data.
    2025-03-10 22:22:01.806  - info: host.iobroker-master instance system.adapter.energiefluss-erweitert.0 in version "0.6.2" started with pid 47877
    2025-03-10 22:22:02.317  - info: wled.0 (47827) WLED initialisation finalized, ready to do my job have fun !
    2025-03-10 22:22:02.528  - info: web.0 (47812) ==> Connected system.user.admin from ::ffff:192.168.178.52
    2025-03-10 22:22:03.550  - info: energiefluss-erweitert.0 (47877) starting. Version 0.6.2 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v20.18.3, js-controller: 7.0.6
    2025-03-10 22:22:03.603  - info: energiefluss-erweitert.0 (47877) Adapter started. Loading config!
    2025-03-10 22:22:04.394  - info: energiefluss-erweitert.0 (47877) Configuration loaded!
    2025-03-10 22:22:04.395  - info: energiefluss-erweitert.0 (47877) Requesting the following states: energiefluss-erweitert.0.configuration,modbus.1.inputRegisters.1.13033_Total_active_power,modbus.1.inputRegisters.1.13021_Battery_power,modbus.1.inputRegisters.1.13022_Battery_level,modbus.1.inputRegisters.1.13001_Daily_PV_Generation,modbus.1.inputRegisters.1.13002_Total_PV_Generation,modbus.1.inputRegisters.1.5016_Total_DC_Power,modbus.1.inputRegisters.1.13004_Daily_export_energy_from_PV,modbus.1.inputRegisters.1.13005_Total_export_energy_from_PV,modbus.1.inputRegisters.1.13009_Export_power,modbus.1.inputRegisters.1.13007_Load_power,modbus.1.inputRegisters.1.13035_Daily_Import_Energy,modbus.1.inputRegisters.1.13036_Total_Import_Energy,modbus.1.inputRegisters.1.13044_Daily_export_energy,modbus.1.inputRegisters.1.13045_Total_export_energy
    2025-03-10 22:24:25.847  - info: host.iobroker-master iobroker del admin --debug
    2025-03-10 22:24:26.748  - info: host.iobroker-master iobroker Delete adapter "admin"
    2025-03-10 22:24:26.796  - info: host.iobroker-master iobroker host.iobroker-master Counted 1 instances of admin
    2025-03-10 22:24:26.864  - info: host.iobroker-master iobroker Cannot remove adapter "admin", because instance "backitup" depends on it!
    2025-03-10 22:24:26.898  - info: homeconnect.0 (47244) 484030535042007636/programs/selected/options: There is no program selected.
    2025-03-10 22:24:27.880  - info: host.iobroker-master iobroker exit 47
    2025-03-10 22:24:33.319  - info: admin.0 (46805) <== Disconnect system.user.admin from ::ffff:192.168.178.86 admin
    2025-03-10 22:24:33.833  - info: admin.0 (46805) ==> Connected system.user.admin from ::ffff:192.168.178.86
    2025-03-10 22:24:41.165  - info: admin.0 (46805) <== Disconnect system.user.admin from ::ffff:192.168.178.86 admin
    2025-03-10 22:25:14.011  - info: host.iobroker-master instance system.adapter.dwd.0 in version "2.8.5" started with pid 48041
    2025-03-10 22:25:15.071  - info: dwd.0 (48041) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.3, js-controller: 7.0.6
    2025-03-10 22:25:15.499  - info: dwd.0 (48041) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-03-10 22:25:16.010  - info: host.iobroker-master instance system.adapter.dwd.0 having pid 48041 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    iob diag has finished.
    @jwerlsdf
    Am Rande: Deine CIFS-Freigaben hängen da falsch und SMB=1.0 ist hoffentlich falsch.
    iob update
    iob upgrade all
    • J jwerlsdf
      Hallo, ich kann keinen neuen Adapter mehr installieren, da der Admin wohl zu alt ist.
      Ich bekomme folgenden Fehler
      Invalid version of admin. Required >=7.4.10. Current 6.17.14
      Installiert ist aber folgendes:
      Verfügbare Version:
      7.6.2
      Installierte Version:
      7.6.2
      Iob fix funktioniert leider nicht. Was kann ich noch machen?
      BananaJoeB Offline
      BananaJoeB Offline
      BananaJoe
      @jwerlsdf sagte in Falsche admin Version obwohl aktuell:
      Verfügbare Version:
      7.6.2
      7.6.2
      Welchen Adapter versuchst du denn zu installieren?
      Dein diag sah - für mich - erst einmal ok aus.
      • BananaJoeB BananaJoe
        Verfügbare Version:
        7.6.2
        7.6.2
        jwerlsdf
        @bananajoe
        Schulferien
        Jetzt klappt es auf einmal. Keine Ahnung woran es genau gelegen hat. Danke trotzdem für die Hilfe. Hoffentlich bleibt es auch dabei, dass es funktioniert.
        • J jwerlsdf
          ```bash
          Script v.2025-02-23
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Kernel          : aarch64
          Userland        : 64 bit
          CPU threads: 4
          Current issues:
                        NTP service: active
                    RTC in local TZ: no
          pi
          HOME=/home/pi
          iobroker
          HOME=/home/iobroker
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:           209M          0B        209M
                   8052 M total memory
                   3058 M used memory
                   1629 M free memory
                    237 M buffer memory
                   3227 M swap cache
                    199 M total swap
                      0 M used swap
                    199 M free swap
          *** FILESYSTEM ***
          /var:
          2.8G    /var/
          1.3G    /var/lib
          785M    /var/log
          USB-Devices by-id:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          admin:          7.6.2
          javascript:     8.9.1
          Adapter State
          + instance is alive
          Objects and States
          Objects:        28973
          States:         25586
          Pending Updates: 3
          hast du multihost?
          wie ist die admin version auf dem slave?
            hast du multihost?
            jwerlsdf
            Oh danke. Habe tatsächlich die 6er Version installiert gehabt. Habe dort das upgrade ebenfalls durchgeführt. Ich benutze den slave so selten, dass ich es total vergessen habe.
            • J jwerlsdf
              @jwerlsdf
              Ein Slave hat auch keinen eigenen Admin. Der wird 'leer' an die Hauptinstallation angekoppelt und dann über dessen Admin-Instanz verwaltet.
                wieder ein Grund mehr, den Slave ohne jede Instanz aufzusetzen.
                  jwerlsdf
                  Wird nicht der admin beim slave mit installiert? War bei mir so gewesen...
                  • J jwerlsdf
                    @jwerlsdf
                    Jein. Zunächst ist das ja erstmal eine volle Installation mit den vorinstallierten Adaptern.
                    Wenn diese Installation zum Nebensystem 'degradiert' wird schmeißt man alle Adapter raus und dockt dann diese leere Hülle an das führende System an. Und dann kann man die Instanzen verscheiben oder bei Neuinstallationen direkt das Nebensystem als Ziel angeben.
                    • J jwerlsdf
                      und backitup und discovery.
                      Die kann man aber wieder vor der Kopplung löschen.
                      Das mache ich schon lange so.
                      • J Offline
                        jwerlsdf
                        Ergo kann ich über den Befehl iobroker del adapter alle löschen einschließlich admin?
                        • J jwerlsdf
                          ja!
                          Aber nur auf dem zukünftigen Slave vor der Kopplung
