  4. Falsche admin Version obwohl aktuell
25 Beiträge 5 Kommentatoren 3.2k Aufrufe 3 Beobachtet
  • J jwerlsdf
     Static hostname: iobroker-master
           Icon name: computer
              Kernel: Linux 6.6.74+rpt-rpi-2712
        Architecture: arm64
    Kernel:                 aarch64
    Userland:               64 bit
    Timezone:               Europe/Berlin (CET, +0100)
    User-ID:                1000
    Display-Server:         false
    Boot Target:            multi-user.target
    Pending OS-Updates:     3
    Pending iob updates:    2
    Nodejs-Installation:
    /usr/bin/nodejs         v20.18.3
    /usr/bin/node           v20.18.3
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.30.0
    Recommended versions are nodejs 20.18.3 and npm 10.8.2
    nodeJS installation is correct
    MEMORY:
    Mem:            8.4G        3.1G        1.8G        6.8M        3.6G        5.3G
    Swap:           209M          0B        209M
    Total:          8.7G        3.1G        2.0G
    Active iob-Instances:   43
    Upgrade policy: none
    ioBroker Core:          js-controller           7.0.6
                            admin                   7.6.2
    Objects type: jsonl
    States  type: jsonl
    + system.adapter.admin.0                  : admin                 : iobroker-master                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.web.0                    : web                   : iobroker-master                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    Objects:                28973
    States:                 25586
    Size of iob-Database:
    33M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/states.jsonl
    Operating System is the current Debian stable version codenamed 'bookworm'!
    @jwerlsdf
    Das ist nicht die Langfassung, nicht mal die Zusammenfassung vollständig.
      @jwerlsdf
      jwerlsdf
      ```bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 5 Model B Rev 1.0
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       22:29:18 up 23:16,  3 users,  load average: 0.71, 0.89, 0.92
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Mon 2025-03-10 22:29:18 CET
                 Universal time: Mon 2025-03-10 21:29:18 UTC
                       RTC time: Mon 2025-03-10 21:29:18
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin docker gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.4G        3.2G        1.7G        6.8M        3.6G        5.2G
      Swap:           209M          0B        209M
      Total:          8.7G        3.2G        1.9G
               8052 M total memory
               3058 M used memory
               3550 M active memory
               2294 M inactive memory
               1629 M free memory
                237 M buffer memory
               3227 M swap cache
                199 M total swap
                  0 M used swap
                199 M free swap
      top - 22:29:18 up 23:16,  3 users,  load average: 0.71, 0.89, 0.92
      Tasks: 242 total,   2 running, 240 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   8052.2 total,   1628.2 free,   3060.1 used,   3465.0 buff/cache
      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   4992.1 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                        Type      Size  Used Avail Use% Mounted on
      udev                              devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs                             tmpfs     806M  6.3M  799M   1% /run
      /dev/sda2                         ext4       55G   19G   34G  36% /
      tmpfs                             tmpfs     4.0G     0  4.0G   0% /dev/shm
      tmpfs                             tmpfs     5.0M   48K  5.0M   1% /run/lock
      /dev/sda1                         vfat      510M   76M  435M  15% /boot/firmware
      //192.168.178.39/Sicherungskopien cifs       15T  5.4T  9.1T  38% /Sicherungskopien
      //192.168.178.39/video            cifs       15T  5.4T  9.1T  38% /video
      //192.168.178.39/Küche           cifs       15T  5.4T  9.1T  38% /Kueche
      //192.168.178.39/music            cifs       15T  5.4T  9.1T  38% /music
      tmpfs                             tmpfs     806M  160K  806M   1% /run/user/1000
      [Sun Mar  9 23:12:32 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:2F:B4:2F vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=eb2f63c1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
      [Sun Mar  9 23:12:33 2025] EXT4-fs (sda2): mounted filesystem fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 ro with ordered data mode. Quota mode: none.
      [Sun Mar  9 23:12:33 2025] EXT4-fs (sda2): re-mounted fc7a1f9e-4967-4f41-a1f5-1b5927e6c5f9 r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET              SOURCE                            FSTYPE OPTIONS
      /                   /dev/sda2                         ext4   rw,noatime
      |-/boot/firmware    /dev/sda1                         vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      |-/music            //192.168.178.39/music            cifs   rw,relatime,vers=1.0,cache=strict,username=pi,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.178.39,soft,unix,posixpaths,serverino,mapposix,acl,reparse=nfs,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
      |-/video            //192.168.178.39/video            cifs   rw,relatime,vers=1.0,cache=strict,username=pi,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.178.39,soft,unix,posixpaths,serverino,mapposix,acl,reparse=nfs,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
      |-/Sicherungskopien //192.168.178.39/Sicherungskopien cifs   rw,relatime,vers=1.0,cache=strict,username=pi,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.178.39,soft,unix,posixpaths,serverino,mapposix,acl,reparse=nfs,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
      `-/Kueche           //192.168.178.39/K\xc3\xbcche     cifs   rw,relatime,vers=1.0,cache=strict,username=pi,uid=1000,forceuid,gid=1000,forcegid,addr=192.168.178.39,soft,unix,posixpaths,serverino,mapposix,acl,reparse=nfs,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1
      /var:
      2.8G    /var/
      1.3G    /var/lib
      1.1G    /var/lib/docker/overlay2
      785M    /var/log
      Archived and active journals take up 783.8M in the file system.
      /opt/iobroker/backups:
      2.2G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      890M    /opt/iobroker/iobroker-data/
      665M    /opt/iobroker/iobroker-data/files
      196M    /opt/iobroker/iobroker-data/files/vis-2
      120M    /opt/iobroker/iobroker-data/files/vis
      118M    /opt/iobroker/iobroker-data/backup-objects
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      16M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.41623696.js.map
      16M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
      15M     /opt/iobroker/iobroker-data/files/vis-2/static/js/118.cf753117.chunk.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      *** NodeJS-Installation ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Installed: 20.18.3-1nodesource1
        Candidate: 20.18.3-1nodesource1
        Version table:
       *** 20.18.3-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
           20.18.2-1nodesource1 600
           20.18.1-1nodesource1 600
           20.18.0-1nodesource1 600
           20.17.0-1nodesource1 600
           20.16.0-1nodesource1 600
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main arm64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker-master     iobroker-master (version: 7.0.6, hostname: iobroker-master, alive, uptime: 633)
      iobroker-slave      iobroker-slave (version: 7.0.6, hostname: iobroker-slave, alive, uptime: 1173)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.2
      javascript:     8.9.1
      nodejs modules from github:     1
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      Adapter State
      + system.adapter.backitup.0               : backitup              : iobroker-master                          -  enabled
      + system.adapter.bring.0                  : bring                 : iobroker-master                          -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker-master                          -  enabled
      + system.adapter.deconz.0                 : deconz                : iobroker-master                          -  enabled, port: 6060
      + system.adapter.denon.0                  : denon                 : iobroker-master                          -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker-master                          -  enabled
        system.adapter.dwd.0                    : dwd                   : iobroker-master                          -  enabled
      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-master                          -  enabled
      + system.adapter.eusec.0                  : eusec                 : iobroker-master                          -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker-master                          -  enabled
      + system.adapter.firetv.0                 : firetv                : iobroker-master                          -  enabled
        system.adapter.flot.0                   : flot                  : iobroker-master                          - disabled
      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker-master                          -  enabled
      + system.adapter.heos.0                   : heos                  : iobroker-master                          -  enabled
        system.adapter.history.0                : history               : iobroker-master                          - disabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker-master                          -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-master                          -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-master                          -  enabled, port: 0
      + system.adapter.homeconnect.0            : homeconnect           : iobroker-master                          -  enabled
        system.adapter.ical.0                   : ical                  : iobroker-master                          -  enabled
        system.adapter.ical.1                   : ical                  : iobroker-master                          -  enabled
        system.adapter.ical.2                   : ical                  : iobroker-master                          -  enabled
        system.adapter.ical.3                   : ical                  : iobroker-master                          -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-master                          - disabled
      + system.adapter.javascript.0             : javascript            : iobroker-master                          -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker-master                          -  enabled, port: 54321
      + system.adapter.modbus.0                 : modbus                : iobroker-master                          -  enabled
      + system.adapter.modbus.1                 : modbus                : iobroker-master                          -  enabled
      + system.adapter.modbus.2                 : modbus                : iobroker-master                          -  enabled
      + system.adapter.mpd.0                    : mpd                   : iobroker-master                          -  enabled, port: 6600
      + system.adapter.netatmo.0                : netatmo               : iobroker-master                          -  enabled
      + system.adapter.nina.0                   : nina                  : iobroker-master                          -  enabled
      + system.adapter.pollenflug.0             : pollenflug            : iobroker-master                          -  enabled
      + system.adapter.radar2.0                 : radar2                : iobroker-master                          -  enabled
      + system.adapter.rssfeed.0                : rssfeed               : iobroker-master                          -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker-master                          -  enabled, port: 1882, bind: 192.168.178.70
      + system.adapter.smartgarden.0            : smartgarden           : iobroker-master                          -  enabled
      + system.adapter.sonos.0                  : sonos                 : iobroker-master                          -  enabled
      + system.adapter.synochat.0               : synochat              : iobroker-master                          -  enabled
      + system.adapter.synology.0               : synology              : iobroker-master                          -  enabled, port: 5000
      + system.adapter.synology.1               : synology              : iobroker-master                          -  enabled, port: 5000
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-master                          -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker-master                          -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.time-switch.0            : time-switch           : iobroker-master                          -  enabled
      + system.adapter.tr-064.0                 : tr-064                : iobroker-master                          -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker-master                          -  enabled
      + system.adapter.trashschedule.1          : trashschedule         : iobroker-master                          -  enabled
        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker-master                          -  enabled
        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker-master                          -  enabled
        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker-master                          -  enabled
        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker-master                          -  enabled
        system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: iobroker-master                          -  enabled
      + system.adapter.vis-2.0                  : vis-2                 : iobroker-master                          -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-master                          - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker-master                          - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-master                          - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-master                          - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-master                          - disabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker-master                          - disabled
        system.adapter.vis-players.0            : vis-players           : iobroker-master                          - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-master                          - disabled
        system.adapter.vis.0                    : vis                   : iobroker-master                          -  enabled
      + system.adapter.weather-warnings.0       : weather-warnings      : iobroker-master                          -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker-master                          -  enabled
      + system.adapter.wled.0                   : wled                  : iobroker-master                          -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Adapters
      Used repository: beta
      Adapter    "admin"        : 7.6.2    , installed 7.6.2
      Adapter    "backitup"     : 3.1.0    , installed 3.1.0
      Adapter    "bring"        : 1.9.1    , installed 1.9.1
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "deconz"       : 1.6.4    , installed 1.6.4
      Adapter    "denon"        : 1.15.12  , installed 1.15.12
      Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
      Adapter    "eusec"        : 1.3.3    , installed 1.3.3
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "firetv"       : 2.1.0    , installed 2.1.0
      Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
      Adapter    "heos"         : 2.2.4    , installed 2.2.4
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "javascript"   : 8.9.1    , installed 8.9.1
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "mihome-vacuum": 5.2.0    , installed 4.2.0  [Updatable]
      Adapter    "modbus"       : 6.4.0    , installed 6.4.0
      Adapter    "mpd"          : 2.2.0    , installed 2.2.0
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "nina"         : 0.0.26   , installed 0.0.26
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "radar2"       : 2.2.0    , installed 2.2.0
      Adapter    "rssfeed"      : 3.4.1    , installed 3.4.1
      Adapter    "shelly"       : 9.1.0    , installed 9.1.0
      Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
      Adapter    "socketio"     : 7.0.8    , installed 7.0.8
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "synochat"     : 1.3.3    , installed 1.3.3
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 4.0.0    , installed 4.0.0
      Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
      Adapter    "trashschedule": 4.0.0    , installed 3.4.1  [Updatable]
      Adapter    "vis-2"        : 2.11.2   , installed 2.11.2
      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
      Adapter    "vis-2-widgets-gauges": 1.1.1, installed 1.1.1
      Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
      Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
      Adapter    "vis-2-widgets-weather-and-heating": 0.10.0, installed 0.10.0
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "weather-warnings": 0.7.4 , installed 0.7.4
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 7.0.6    , installed 7.0.6
      Adapter    "wled"         : 0.7.3    , installed 0.7.3
      Adapter    "ws"           : 3.0.19   , installed 3.0.19
      Objects and States
      Objects:        28973
      States:         25586
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://download.docker.com/linux/debian bookworm InRelease
      Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 3
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:8000            0.0.0.0:*               LISTEN      0          6896       1485/docker-proxy
      tcp        0      0 127.0.0.1:5037          0.0.0.0:*               LISTEN      1001       1139990    47089/adb
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          66615      4529/cupsd
      tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       1138522    46787/iobroker.js-c
      tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       1138527    46787/iobroker.js-c
      tcp        0      0 0.0.0.0:5005            0.0.0.0:*               LISTEN      1000       9834       1618/node
      tcp        0      0 0.0.0.0:5004            0.0.0.0:*               LISTEN      0          17409      2630/node
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          8478       944/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:9443            0.0.0.0:*               LISTEN      0          6898       1497/docker-proxy
      tcp        0      0 192.168.178.70:2010     0.0.0.0:*               LISTEN      1001       1140107    47229/io.hm-rpc.1
      tcp        0      0 192.168.178.70:2001     0.0.0.0:*               LISTEN      1001       1139642    47214/io.hm-rpc.0
      tcp        0      0 192.168.178.70:1882     0.0.0.0:*               LISTEN      1001       1140290    47385/io.shelly.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          66614      4529/cupsd
      tcp6       0      0 :::3000                 :::*                    LISTEN      1001       1141895    47141/io.fullybrows
      tcp6       0      0 :::8000                 :::*                    LISTEN      0          6897       1491/docker-proxy
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1145040    47812/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1138562    46805/io.admin.0
      tcp6       0      0 :::3502                 :::*                    LISTEN      1001       1142215    47400/io.sonos.0
      tcp6       0      0 :::3501                 :::*                    LISTEN      1000       10351      1618/node
      tcp6       0      0 :::3500                 :::*                    LISTEN      0          17411      2630/node
      tcp6       0      0 :::22                   :::*                    LISTEN      0          8480       944/sshd: /usr/sbin
      tcp6       0      0 :::8555                 :::*                    LISTEN      1001       1143323    47595/go2rtc
      tcp6       0      0 :::8554                 :::*                    LISTEN      1001       1143322    47595/go2rtc
      tcp6       0      0 :::5900                 :::*                    LISTEN      992        8491       906/wayvnc
      tcp6       0      0 :::1984                 :::*                    LISTEN      1001       1140542    47595/go2rtc
      tcp6       0      0 :::9443                 :::*                    LISTEN      0          6899       1504/docker-proxy
      udp        0      0 0.0.0.0:57268           0.0.0.0:*                           1001       1139624    46847/io.javascript
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       1142167    47349/io.radar2.0
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1143144    47508/io.mihome-vac
      udp        0      0 0.0.0.0:37608           0.0.0.0:*                           1001       1139614    47184/io.heos.0
      udp        0      0 0.0.0.0:41971           0.0.0.0:*                           1001       1139625    46847/io.javascript
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1145884    47827/io.wled.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        7643       710/avahi-daemon: r
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       1139410    46915/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       1139406    46915/io.deconz.0
      udp        0      0 0.0.0.0:55930           0.0.0.0:*                           1001       1139613    47184/io.heos.0
      udp        0      0 0.0.0.0:52219           0.0.0.0:*                           1001       1142496    47569/io.eusec.0
      udp        0      0 0.0.0.0:52298           0.0.0.0:*                           104        7645       710/avahi-daemon: r
      udp6       0      0 :::8555                 :::*                                1001       1143324    47595/go2rtc
      udp6       0      0 fe80::2188:5528:66b:546 :::*                                0          6676       831/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        7644       710/avahi-daemon: r
      udp6       0      0 :::55035                :::*                                104        7646       710/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1001       1139412    46915/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       1139411    46915/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       1139409    46915/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       1139408    46915/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       1139407    46915/io.deconz.0
      2025-03-10 22:21:59.781  - info: vis-2.0 (47857) vis-2 license is OK.
      2025-03-10 22:22:00.486  - info: weather-warnings.0 (47842) Refresh Interval: 15 minutes
      2025-03-10 22:22:00.557  - info: weather-warnings.0 (47842) [telegram] Create notification service telegram adapter: telegram.0.
      2025-03-10 22:22:00.558  - info: weather-warnings.0 (47842) DWD 106631000 activated. Retrieve data.
      2025-03-10 22:22:00.563  - info: weather-warnings.0 (47842) UWZ activated. Retrieve data.
      2025-03-10 22:22:01.806  - info: host.iobroker-master instance system.adapter.energiefluss-erweitert.0 in version "0.6.2" started with pid 47877
      2025-03-10 22:22:02.317  - info: wled.0 (47827) WLED initialisation finalized, ready to do my job have fun !
      2025-03-10 22:22:02.528  - info: web.0 (47812) ==> Connected system.user.admin from ::ffff:192.168.178.52
      2025-03-10 22:22:03.550  - info: energiefluss-erweitert.0 (47877) starting. Version 0.6.2 in /opt/iobroker/node_modules/iobroker.energiefluss-erweitert, node: v20.18.3, js-controller: 7.0.6
      2025-03-10 22:22:03.603  - info: energiefluss-erweitert.0 (47877) Adapter started. Loading config!
      2025-03-10 22:22:04.394  - info: energiefluss-erweitert.0 (47877) Configuration loaded!
      2025-03-10 22:22:04.395  - info: energiefluss-erweitert.0 (47877) Requesting the following states: energiefluss-erweitert.0.configuration,modbus.1.inputRegisters.1.13033_Total_active_power,modbus.1.inputRegisters.1.13021_Battery_power,modbus.1.inputRegisters.1.13022_Battery_level,modbus.1.inputRegisters.1.13001_Daily_PV_Generation,modbus.1.inputRegisters.1.13002_Total_PV_Generation,modbus.1.inputRegisters.1.5016_Total_DC_Power,modbus.1.inputRegisters.1.13004_Daily_export_energy_from_PV,modbus.1.inputRegisters.1.13005_Total_export_energy_from_PV,modbus.1.inputRegisters.1.13009_Export_power,modbus.1.inputRegisters.1.13007_Load_power,modbus.1.inputRegisters.1.13035_Daily_Import_Energy,modbus.1.inputRegisters.1.13036_Total_Import_Energy,modbus.1.inputRegisters.1.13044_Daily_export_energy,modbus.1.inputRegisters.1.13045_Total_export_energy
      2025-03-10 22:24:25.847  - info: host.iobroker-master iobroker del admin --debug
      2025-03-10 22:24:26.748  - info: host.iobroker-master iobroker Delete adapter "admin"
      2025-03-10 22:24:26.796  - info: host.iobroker-master iobroker host.iobroker-master Counted 1 instances of admin
      2025-03-10 22:24:26.864  - info: host.iobroker-master iobroker Cannot remove adapter "admin", because instance "backitup" depends on it!
      2025-03-10 22:24:26.898  - info: homeconnect.0 (47244) 484030535042007636/programs/selected/options: There is no program selected.
      2025-03-10 22:24:27.880  - info: host.iobroker-master iobroker exit 47
      2025-03-10 22:24:33.319  - info: admin.0 (46805) <== Disconnect system.user.admin from ::ffff:192.168.178.86 admin
      2025-03-10 22:24:33.833  - info: admin.0 (46805) ==> Connected system.user.admin from ::ffff:192.168.178.86
      2025-03-10 22:24:41.165  - info: admin.0 (46805) <== Disconnect system.user.admin from ::ffff:192.168.178.86 admin
      2025-03-10 22:25:14.011  - info: host.iobroker-master instance system.adapter.dwd.0 in version "2.8.5" started with pid 48041
      2025-03-10 22:25:15.071  - info: dwd.0 (48041) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.3, js-controller: 7.0.6
      2025-03-10 22:25:15.499  - info: dwd.0 (48041) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-03-10 22:25:16.010  - info: host.iobroker-master instance system.adapter.dwd.0 having pid 48041 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      iob diag has finished.
      • J jwerlsdf
        ```bash
        Script v.2025-02-23
        *** BASE SYSTEM ***
               Icon name: computer
            Architecture: arm64
        OS is similar to:
        Docker          : false
        Kernel          : aarch64
        Userland        : 64 bit
        CPU threads: 4
        Current issues:
                      NTP service: active
                  RTC in local TZ: no
        pi
        HOME=/home/pi
        iobroker
        HOME=/home/iobroker
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:           209M          0B        209M
                 8052 M total memory
                 3058 M used memory
                 1629 M free memory
                  237 M buffer memory
                 3227 M swap cache
                  199 M total swap
                    0 M used swap
                  199 M free swap
        *** FILESYSTEM ***
        /var:
        2.8G    /var/
        1.3G    /var/lib
        785M    /var/log
        USB-Devices by-id:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        admin:          7.6.2
        javascript:     8.9.1
        Adapter State
        + instance is alive
        Objects and States
        Objects:        28973
        States:         25586
        Pending Updates: 3
        @jwerlsdf
        Am Rande: Deine CIFS-Freigaben hängen da falsch und SMB=1.0 ist hoffentlich falsch.
        iob update
        iob upgrade all
        • J jwerlsdf
          Hallo, ich kann keinen neuen Adapter mehr installieren, da der Admin wohl zu alt ist.
          Ich bekomme folgenden Fehler
          Invalid version of admin. Required >=7.4.10. Current 6.17.14
          Installiert ist aber folgendes:
          Verfügbare Version:
          7.6.2
          Installierte Version:
          7.6.2
          Iob fix funktioniert leider nicht. Was kann ich noch machen?
          BananaJoeB Offline
          BananaJoeB Offline
          BananaJoe
          @jwerlsdf sagte in Falsche admin Version obwohl aktuell:
          Verfügbare Version:
          7.6.2
          7.6.2
          Welchen Adapter versuchst du denn zu installieren?
          Dein diag sah - für mich - erst einmal ok aus.
          • BananaJoeB BananaJoe
            Verfügbare Version:
            7.6.2
            7.6.2
            jwerlsdf
            @bananajoe
            Schulferien
            Jetzt klappt es auf einmal. Keine Ahnung woran es genau gelegen hat. Danke trotzdem für die Hilfe. Hoffentlich bleibt es auch dabei, dass es funktioniert.
            • J jwerlsdf
              ```bash
              Script v.2025-02-23
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Docker          : false
              Kernel          : aarch64
              Userland        : 64 bit
              CPU threads: 4
              Current issues:
                            NTP service: active
                        RTC in local TZ: no
              pi
              HOME=/home/pi
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:           209M          0B        209M
                       8052 M total memory
                       3058 M used memory
                       1629 M free memory
                        237 M buffer memory
                       3227 M swap cache
                        199 M total swap
                          0 M used swap
                        199 M free swap
              *** FILESYSTEM ***
              /var:
              2.8G    /var/
              1.3G    /var/lib
              785M    /var/log
              USB-Devices by-id:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              admin:          7.6.2
              javascript:     8.9.1
              Adapter State
              + instance is alive
              Objects and States
              Objects:        28973
              States:         25586
              Pending Updates: 3
              hast du multihost?
              wie ist die admin version auf dem slave?
                hast du multihost?
                jwerlsdf
                Oh danke. Habe tatsächlich die 6er Version installiert gehabt. Habe dort das upgrade ebenfalls durchgeführt. Ich benutze den slave so selten, dass ich es total vergessen habe.
                • J jwerlsdf
                  @jwerlsdf
                  Ein Slave hat auch keinen eigenen Admin. Der wird 'leer' an die Hauptinstallation angekoppelt und dann über dessen Admin-Instanz verwaltet.
                    wieder ein Grund mehr, den Slave ohne jede Instanz aufzusetzen.
                      jwerlsdf
                      Wird nicht der admin beim slave mit installiert? War bei mir so gewesen...
                      • J jwerlsdf
                        @jwerlsdf
                        Jein. Zunächst ist das ja erstmal eine volle Installation mit den vorinstallierten Adaptern.
                        Wenn diese Installation zum Nebensystem 'degradiert' wird schmeißt man alle Adapter raus und dockt dann diese leere Hülle an das führende System an. Und dann kann man die Instanzen verscheiben oder bei Neuinstallationen direkt das Nebensystem als Ziel angeben.
                        • J jwerlsdf
                          und backitup und discovery.
                          Die kann man aber wieder vor der Kopplung löschen.
                          Das mache ich schon lange so.
                          • J Offline
                            jwerlsdf
                            Ergo kann ich über den Befehl iobroker del adapter alle löschen einschließlich admin?
                            • J jwerlsdf
                              ja!
                              Aber nur auf dem zukünftigen Slave vor der Kopplung
