  4. [geklärt] History Adapter viele Fehlermeldungen
    6.6k
29 Beiträge 4 Kommentatoren 3.8k Aufrufe 3 Beobachtet
    @peter-c
    Weil Debian 11 'Bullseye' im Upstream das EndOfLife erreicht hat.
    Weil du da im Userland 32Bit fährst.
    Weil du da so einen Quark wie CUPS aktiv hast.
    Weil du da komische Fehlerbilder hast.
    Peter c
    @thomas-braun said in History Adapter viele Fehlermeldungen:
    Ich nutze keine Printfunktion über den IOB
    • P Peter c
      Dann ist dein System nicht auf Stand.
      Hier die Diagnose
      ```bash
      Script v.2025-02-02
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer
        Operating System: Raspbian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      OS is similar to: debian
      Model		: Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 32 bit
      Systemuptime and Load:
       12:59:07 up  1:14,  2 users,  load average: 0.65, 0.68, 8.43
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Unknown release codenamed 'bullseye'. Please check yourself if the Operating System is actively maintained.
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      *** TIME AND TIMEZONES ***
                     Local time: Sat 2025-02-22 12:59:07 CET
                 Universal time: Sat 2025-02-22 11:59:07 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pt
      HOME=/home/pt
      GROUPS=pt adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Mem:            3.8G        942M        2.5G        0.0K        374M        2.8G
      Swap:            99M         28M         71M
      Total:          3.9G        970M        2.5G
      Active iob-Instances: 	20
               3794 M total memory
                942 M used memory
                980 M active memory
                208 M inactive memory
               2477 M free memory
                 48 M buffer memory
                326 M swap cache
                 99 M total swap
                 28 M used swap
                 71 M free swap
      top - 12:59:08 up  1:14,  2 users,  load average: 0.65, 0.68, 8.43
      Tasks: 186 total,   1 running, 185 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  4.2 sy,  0.0 ni, 95.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3794.3 total,   2476.6 free,    942.6 used,    375.1 buff/cache
      MiB Swap:    100.0 total,     71.5 free,     28.5 used.   2776.5 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      /dev/root      ext4       29G   13G   16G  45% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     759M  1.2M  758M   1% /run
      /dev/mmcblk0p1 vfat      255M   51M  205M  20% /boot
      tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
      [Sat Feb 22 11:45:01 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.7G	/var/
      969M	/var/log
      961M	/var/log/journal/061ea1674ff8454f9e4d5c7dfa8e6e06
      458M	/var/cache
      Archived and active journals take up 960.2M in the file system.
      /opt/iobroker/backups:
      83M	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      3.8G	/opt/iobroker/iobroker-data/
      2.9G	/opt/iobroker/iobroker-data/history
      927M	/opt/iobroker/iobroker-data/files
      617M	/opt/iobroker/iobroker-data/files/javascript.admin
      560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
      24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
      19M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
      13M	/opt/iobroker/iobroker-data/objects.jsonl
      9.3M	/opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
      USB-Devices by-id:
      No Devices found 'by-id'
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v20.18.3
      /usr/bin/node 		v20.18.3
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      /usr/bin/corepack 	0.30.0
      nodejs:
        Installed: 20.18.3-1nodesource1
        Candidate: 20.18.3-1nodesource1
        Version table:
       *** 20.18.3-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u5 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 1610)
      Core adapters versions
      js-controller: 	7.0.6
      admin: 		7.4.10
      javascript: 	8.8.3
      nodejs modules from github: 	1
      `-- tibber-api@5.1.9 (git+ssh://git@github.com/bisand/tibber-api.git#c288a93c2f4d4989dc8214f9e3549477fd1b5acd)
      Adapter State
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.bmw.0                    : bmw                   : iobroker                                 - disabled
        system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
      + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
        system.adapter.history.0                : history               : iobroker                                 - disabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 192.168.178.94
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
        system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
      + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.text2command.0           : text2command          : iobroker                                 - disabled
      + system.adapter.tibberlink.0             : tibberlink            : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 - disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.4.10   , installed 7.4.10
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "email"        : 1.3.1    , installed 1.3.1
      Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
      Adapter    "shelly"       : 8.5.1    , installed 8.5.1
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tibberlink"   : 4.2.3    , installed 4.2.3
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "web"          : 6.2.5    , installed 6.2.5
      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
      Objects and States
      Objects: 	4957
      States: 	4074
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1909       561/sshd: /usr/sbin
      tcp        0      0 192.168.178.94:1883     0.0.0.0:*               LISTEN      1001       89012      32415/io.mqtt.0
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       86010      32217/node-red
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       89868      32385/io.shelly.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       87431      32050/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       85718      32050/iobroker.js-c
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15383      532/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15079      561/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       87566      32168/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       92298      32644/io.web.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15382      532/cupsd
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       92237      32571/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       92238      32571/io.tuya.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1823       398/avahi-daemon: r
      udp        0      0 0.0.0.0:52477           0.0.0.0:*                           108        1825       398/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14048      476/dhcpcd
      udp6       0      0 :::47601                :::*                                108        1826       398/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          14060      476/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        1824       398/avahi-daemon: r
      2025-02-22 12:54:58.082  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
      2025-02-22 12:54:58.088  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
      2025-02-22 12:54:58.095  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
      2025-02-22 12:54:58.105  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
      2025-02-22 12:55:11.466  - warn: mqtt.0 (32415) Client [SOYO_3b2107] Message 519 deleted after 11 retries
      2025-02-22 12:55:12.580  - info: mqtt.0 (32415) Client [SOYO_3b2107] reconnected. Old secret 1740225297871_6311. New secret 1740225312579_2546
      2025-02-22 12:55:12.596  - info: mqtt.0 (32415) Client [SOYO_3b2107] subscribes on "mqtt.0.Soyosource.SOYO_3b2107.L1L2L3"
      2025-02-22 12:55:12.609  - info: mqtt.0 (32415) Client [SOYO_3b2107] subscribes on "mqtt.0.Soyosource.SOYO_3b2107.NotAus"
      2025-02-22 12:55:12.620  - info: mqtt.0 (32415) Client [SOYO_3b2107] subscribes on "mqtt.0.Soyosource.SOYO_3b2107.WaitSekunden"
      2025-02-22 12:55:12.637  - info: mqtt.0 (32415) Client [SOYO_3b2107] subscribes on "mqtt.0.Soyosource.SOYO_3b2107.MaxPower"
      2025-02-22 12:55:12.796  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
      2025-02-22 12:55:12.810  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
      2025-02-22 12:55:12.820  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
      2025-02-22 12:55:12.838  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
      2025-02-22 12:59:57.435  - info: mqtt.0 (32415) Client [SOYO_3b2107] connection closed: Error: read ECONNRESET
      2025-02-22 12:59:57.908  - info: mqtt.0 (32415) Client [SOYO_3b2107] connected with secret 1740225597907_7518
      2025-02-22 12:59:57.918  - info: mqtt.0 (32415) Client [SOYO_3b2107] subscribes on "mqtt.0.Soyosource.SOYO_3b2107.L1L2L3"
      2025-02-22 12:59:57.927  - info: mqtt.0 (32415) Client [SOYO_3b2107] subscribes on "mqtt.0.Soyosource.SOYO_3b2107.NotAus"
      2025-02-22 12:59:57.933  - info: mqtt.0 (32415) Client [SOYO_3b2107] subscribes on "mqtt.0.Soyosource.SOYO_3b2107.WaitSekunden"
      2025-02-22 12:59:57.941  - info: mqtt.0 (32415) Client [SOYO_3b2107] subscribes on "mqtt.0.Soyosource.SOYO_3b2107.MaxPower"
      2025-02-22 12:59:58.118  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
      2025-02-22 12:59:58.128  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
      2025-02-22 12:59:58.133  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
      2025-02-22 12:59:58.142  - info: mqtt.0 (32415) Client [SOYO_3b2107] publishOnSubscribe
      2025-02-22 13:00:00.096  - info: javascript.0 (32228) script.js.Skript_Shelly_Verbrauch: Shelly Verbrauch: Verbrauchswerte aktualisiert: 1 | Reboots korrigiert: 0 | Unveränderte Werte: 6
      @peter-c sagte in History Adapter viele Fehlermeldungen:
      da reicht wohl das Netzteil nicht.
      wo liegen deine History Daten?
      • P Offline
        Peter c
        schrieb am zuletzt editiert von Peter c
        @homoran said in History Adapter viele Fehlermeldungen:
        so weit ich weiß auf der SD Karte.
        Das Netzteil hatte ich nicht geändert.
        • P Peter c
          dann ist es wohl von Anfang an zu schwach gewesen
          P 1 Antwort Letzte Antwort
            Peter c
            Kann es sein, dass eine Netzunterbrechnung den Eintrag auslöst?
            Das ist vorgekommen.
            Soll ich den History adapter neu aufsetzen oder wirklich das System komplett neu aufsetzen?
            • P Peter c
              alles andere ergibt keinen Sinn!
              Nimm eine neue Karte, darauf bookworm lite 64bit, dann iob installieren und neuestes Backup zurückspielen.
              fertig!
              • P Peter c
                Ja.
                  @peter-c
                  So:
                  https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                  Peter c
                  @thomas-braun said in [geklärt] History Adapter viele Fehlermeldungen:
                  So:
                  Da ich etwas unsicher bin hab ich dazu Fragen bevor ich das mache.
                  Wenn ich das richtig verstanden habe ändere ich ja das OS des raspi.
                  Bleibt der iob daher erstmal auf dem Gerät erhalten?
                  Muss ich nicht bevor ich die SD Karte in den raspi stecke ein backup des iob machen?
                  Wie starte ich den raspi neu wenn ich die SD karte eingesteckt habe?
                  Kann ich den bisherigen Anmeldenamen und pw weiternutzen?
                  • P Peter c
                    So:
                    @peter-c sagte in [geklärt] History Adapter viele Fehlermeldungen:
                    Nein. Dafür hast du aber ja ein Backup des ioBrokers.
                    Neuinstallation so:
                    Du vergibst beides ja neu bei der Installation.
                      Neuinstallation so:
                      Peter c
                      Wo ist dieses Backup?
                      Und wie starte ich des raspi nachdem die Karte drin ist richtig?
                      • P Peter c
                        Da, wo du es hinlegst. Kann ein NAS sein, kann sowas die GoogleDrive sein oder oder oder.
                        Schau dir die Optionen im Backitup-Adapter an. Zu dem Adapter gibt es auch sehr gute Dokumentation.
                        Strom einschalten? Der Raspi bootet dann vom Boot-Medium.
