  4. iobroker startet nach Wiederherstellung nicht mehr
15 Beiträge 5 Kommentatoren 1.5k Aufrufe 3 Beobachtet
  • L Lothron
    @homoran said in iobroker startet nach Wiederherstellung nicht mehr:
    Da steht u.a. drin, was wir an Informationen brauchen, allem voran die Ausgabe der Langfassung von iob diag
    ```bash
    Script v.2025-02-23
    *** BASE SYSTEM ***
     Static hostname: iobroker
           Icon name: computer
              Kernel: Linux 6.6.74+rpt-rpi-v8
        Architecture: arm64
    OS is similar to:
    Model		: Raspberry Pi 4 Model B Rev 1.5
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     12:53:35 up 16 min,  2 users,  load average: 0.48, 0.15, 0.07
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    Previously detected issues:
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2025-03-09 12:53:35 CET
               Universal time: Sun 2025-03-09 11:53:35 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    admin
    HOME=/home/admin
    GROUPS=admin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    iobroker
    HOME=/home/iobroker
    *** DISPLAY-SERVER SETUP ***
    Display-Server: false
    Desktop:
    Terminal: 	tty
    *** MEMORY ***
    Mem:            1.9G        354M        1.4G        1.2M        260M        1.6G
    Swap:           536M          0B        536M
    Total:          2.5G        354M        1.9G
    Active iob-Instances: 	2
             1846 M total memory
              338 M used memory
              354 M active memory
               88 M inactive memory
             1320 M free memory
               32 M buffer memory
              215 M swap cache
              511 M total swap
                0 M used swap
              511 M free swap
    top - 12:53:35 up 16 min,  2 users,  load average: 0.48, 0.15, 0.07
    Tasks: 170 total,   1 running, 169 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   1846.8 total,   1319.4 free,    339.1 used,    248.3 buff/cache
    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1507.7 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    No critical errors detected
    *** FILESYSTEM ***
    udev           devtmpfs  662M     0  662M   0% /dev
    tmpfs          tmpfs     185M  1.2M  184M   1% /run
    /dev/mmcblk0p2 ext4       14G  4.3G  8.7G  34% /
    tmpfs          tmpfs     924M     0  924M   0% /dev/shm
    tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   56M  455M  11% /boot/firmware
    tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
    [Sun Mar  9 12:37:01 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:D6:9B:1B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a53e817e-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
    [Sun Mar  9 12:37:02 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
    [Sun Mar  9 12:37:03 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
    Show mounted filesystems:
    TARGET           SOURCE         FSTYPE OPTIONS
    /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.1G	/var/
    316M	/var/cache
    311M	/var/cache/apt
    198M	/var/cache/apt/archives
    168M	/var/lib
    Archived and active journals take up 76.0M in the file system.
    /opt/iobroker/backups:
    8.0M	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    274M	/opt/iobroker/iobroker-data/
    256M	/opt/iobroker/iobroker-data/files
    158M	/opt/iobroker/iobroker-data/files/admin.admin
    157M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    17M	/opt/iobroker/iobroker-data/objects.jsonl
    7.4M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
    7.0M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
    7.0M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
    7.0M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v20.18.3
    /usr/bin/node 		v20.18.3
    /usr/bin/npm 		10.8.2
    /usr/bin/npx 		10.8.2
    /usr/bin/corepack 	0.30.0
    nodejs:
      Installed: 20.18.3-1nodesource1
      Candidate: 20.18.3-1nodesource1
      Version table:
     *** 20.18.3-1nodesource1 1001
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
         20.18.2-1nodesource1 1001
         20.18.1-1nodesource1 1001
         20.18.0-1nodesource1 1001
         20.17.0-1nodesource1 1001
         20.16.0-1nodesource1 1001
         20.15.1-1nodesource1 1001
         20.15.0-1nodesource1 1001
         20.14.0-1nodesource1 1001
         20.13.1-1nodesource1 1001
         20.13.0-1nodesource1 1001
         20.12.2-1nodesource1 1001
         20.12.1-1nodesource1 1001
         20.12.0-1nodesource1 1001
         20.11.1-1nodesource1 1001
         20.11.0-1nodesource1 1001
         20.10.0-1nodesource1 1001
         20.9.0-1nodesource1 1001
         20.8.1-1nodesource1 1001
         20.8.0-1nodesource1 1001
         20.7.0-1nodesource1 1001
         20.6.1-1nodesource1 1001
         20.6.0-1nodesource1 1001
         20.5.1-1nodesource1 1001
         20.5.0-1nodesource1 1001
         20.4.0-1nodesource1 1001
         20.3.1-1nodesource1 1001
         20.3.0-1nodesource1 1001
         20.2.0-1nodesource1 1001
         20.1.0-1nodesource1 1001
         20.0.0-1nodesource1 1001
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    No problems detected
    Errors in npm tree: 0
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Hosts:
    iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 995)
    Core adapters versions
    js-controller: 	7.0.6
    admin: 		6.3.5
    javascript: 	6.1.4
    nodejs modules from github: 	0
    Adapter State
      system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      system.adapter.cloud.0                  : cloud                 : iobroker                                 - disabled
      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
      system.adapter.e3dc-rscp.0              : e3dc-rscp             : iobroker                                 - disabled
      system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
      system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
      system.adapter.loxone.0                 : loxone                : iobroker                                 - disabled, port: 50220
      system.adapter.melcloud.0               : melcloud              : iobroker                                 - disabled
      system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 0.0.0.0
      system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
      system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
      system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
      system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.yahka.0                  : yahka                 : iobroker                                 - disabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): beta
    Upgrade policy: none
    Installed ioBroker-Adapters
    Used repository: beta
    Adapter    "admin"        : 7.6.1    , installed 6.3.5  [Updatable]
    Adapter    "backitup"     : 3.1.0    , installed 2.6.23 [Updatable]
    Adapter    "cloud"        : 5.0.1    , installed 4.4.1  [Updatable]
    Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
    Adapter    "e3dc-rscp"    : 1.4.1    , installed 1.2.2  [Updatable]
    Adapter    "influxdb"     : 4.0.2    , installed 3.2.0  [Updatable]
    Adapter    "javascript"   : 8.9.1    , installed 6.1.4  [Updatable]
    Controller "js-controller": 7.0.6    , installed 7.0.6
    Adapter    "loxone"       : 3.0.1    , installed 3.0.1
    Adapter    "melcloud"     : 2.0.5    , installed 1.4.1  [Updatable]
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "ping"         : 1.7.9    , installed 1.5.3  [Updatable]
    Adapter    "shelly"       : 9.1.0    , installed 6.4.1  [Updatable]
    Adapter    "socketio"     : 7.0.8    , installed 4.2.0  [Updatable]
    Adapter    "unifi"        : 0.7.0    , installed 0.5.10 [Updatable]
    Adapter    "web"          : 7.0.4    , installed 4.3.0  [Updatable]
    Adapter    "ws"           : 3.0.19   , installed 1.3.0  [Updatable]
    Adapter    "yahka"        : 1.0.9    , installed 1.0.3  [Updatable]
    Objects and States
    Objects: 	11617
    States: 	9557
    Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:2 http://deb.debian.org/debian bookworm InRelease
    Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
    Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       4956       552/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       4951       552/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1635       561/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          1637       561/sshd: /usr/sbin
    udp        0      0 0.0.0.0:37075           0.0.0.0:*                           104        3664       429/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3662       429/avahi-daemon: r
    udp6       0      0 :::52268                :::*                                104        3665       429/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                104        3663       429/avahi-daemon: r
    2025-03-09 12:37:00.652  - info: host.iobroker ip addresses:
    2025-03-09 12:37:02.446  - info: host.iobroker connected to Objects and States
    2025-03-09 12:37:02.474  - info: host.iobroker added notifications configuration of host
    2025-03-09 12:37:03.282  - info: host.iobroker 15 instances found
    2025-03-09 12:37:03.314  - info: host.iobroker starting 2 instances
    2025-03-09 12:37:04.244  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
    2025-03-09 12:37:04.329  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
    2025-03-09 12:37:04.342  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
    2025-03-09 12:37:04.356  - info: host.iobroker instance system.adapter.admin.0 in version "6.3.5" started with pid 633
    2025-03-09 12:37:04.366  - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
    2025-03-09 12:37:04.416  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
    2025-03-09 12:37:04.424  - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
    2025-03-09 12:37:04.431  - info: host.iobroker Some obsolete host states deleted.
    2025-03-09 12:37:07.206  - info: admin.0 (633) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.3, js-controller: 7.0.6
    2025-03-09 12:37:07.396  - info: admin.0 (633) requesting all states
    2025-03-09 12:37:07.397  - info: admin.0 (633) requesting all objects
    2025-03-09 12:37:09.683  - info: host.iobroker instance system.adapter.backitup.0 in version "2.6.23" started with pid 660
    2025-03-09 12:37:09.877  - info: admin.0 (633) received all objects
    2025-03-09 12:37:10.010  - error: admin.0 (633) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
    2025-03-09 12:37:10.012  - info: admin.0 (633) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2025-03-09 12:37:10.596  - info: admin.0 (633) terminating https server on port 8081
    2025-03-09 12:37:10.696  - info: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    2025-03-09 12:37:10.697  - info: host.iobroker Do not restart adapter system.adapter.admin.0 because desired by instance
    2025-03-09 12:37:12.291  - info: backitup.0 (660) starting. Version 2.6.23 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.18.3, js-controller: 7.0.6
    2025-03-09 12:37:12.358  - info: backitup.0 (660) [iobroker] backup will be activated at 02:40 every 1 day(s)
    Lothron
    iob list adapters:
    │ (index) │ id                          │ name         │ version  │ upgrade policy │
    │ 0       │ 'system.adapter.admin'      │ 'admin'      │ '6.3.5'  │ 'none'         │
    │ 1       │ 'system.adapter.backitup'   │ 'backitup'   │ '2.6.23' │ 'none'         │
    │ 2       │ 'system.adapter.cloud'      │ 'cloud'      │ '4.4.1'  │ 'none'         │
    │ 3       │ 'system.adapter.discovery'  │ 'discovery'  │ '3.1.0'  │ 'none'         │
    │ 4       │ 'system.adapter.e3dc-rscp'  │ 'e3dc-rscp'  │ '1.2.2'  │ 'none'         │
    │ 5       │ 'system.adapter.influxdb'   │ 'influxdb'   │ '3.2.0'  │ 'none'         │
    │ 6       │ 'system.adapter.javascript' │ 'javascript' │ '6.1.4'  │ 'none'         │
    │ 7       │ 'system.adapter.loxone'     │ 'loxone'     │ '3.0.1'  │ 'none'         │
    │ 8       │ 'system.adapter.melcloud'   │ 'melcloud'   │ '1.4.1'  │ 'none'         │
    │ 9       │ 'system.adapter.mihome'     │ 'mihome'     │ '1.4.0'  │ 'none'         │
    │ 10      │ 'system.adapter.ping'       │ 'ping'       │ '1.5.3'  │ 'none'         │
    │ 11      │ 'system.adapter.shelly'     │ 'shelly'     │ '6.4.1'  │ 'none'         │
    │ 12      │ 'system.adapter.unifi'      │ 'unifi'      │ '0.5.10' │ 'none'         │
    │ 13      │ 'system.adapter.web'        │ 'web'        │ '4.3.0'  │ 'none'         │
    │ 14      │ 'system.adapter.yahka'      │ 'yahka'      │ '1.0.3'  │ 'none'         │
    • L Lothron
      ```bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      admin
      HOME=/home/admin
      iobroker
      HOME=/home/iobroker
      Desktop:
      Terminal: 	tty
      *** MEMORY ***
      Swap:           536M          0B        536M
               1846 M total memory
                338 M used memory
                354 M active memory
               1320 M free memory
                 32 M buffer memory
                215 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      *** FILESYSTEM ***
      /var:
      1.1G	/var/
      316M	/var/cache
      311M	/var/cache/apt
      168M	/var/lib
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      admin: 		6.3.5
      javascript: 	6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects: 	11617
      States: 	9557
      Pending Updates: 0
      @lothron sagte in iobroker startet nach Wiederherstellung nicht mehr:
      wie bereits geschrieben läuft hier nichts.
      ist gesicherte Verbindung gewollt?
      Ebenfalls geschrieben wurde auch, dass noch updatestau besteht
      L 1 Antwort Letzte Antwort
      • L Lothron
        iob list adapters:
        @lothron
        Stell das Repo auf stable um.
          Lothron
          Ja, ich habe versucht eine Frage nach der anderen abzuarbeiten.
          Repo habe ich auf stable umgestellt und ich mache gerade die ganzen Updates.
          Ich habe auch versuch den Adapter admin manuell zu starten, bekam aber folgende Meldung:
          admin@iobroker:/opt/iobroker $ sudo iobroker start admin
          ***For security reasons ioBroker should not be run or administrated as root.***
          By default only a user that is member of iobroker group can execute ioBroker commands.
          Please read the Documentation on how to set up such a user, if not done yet.
          Only in very special cases you can run iobroker commands by adding the --allow-root option at the end of the command line.
          Please note that this option may be disabled in the future, so please change your setup accordingly now.
            @lothron
            Lothron
            @thomas-braun said in iobroker startet nach Wiederherstellung nicht mehr:
            @lothron
            ja, ist gemacht. Das kam aus dem Backup, weil ich einen Adapter aus dem Beta Repo brauchte.
            • L Lothron
              haselchenH Offline
              haselchenH Offline
              haselchen
              @lothron
              Iobroker Befehle werden nicht mit sudo begonnen!
              iobroker start admin.0
              • haselchenH haselchen
                @lothron
                Lothron
                Nachdem die Updates durchgelaufen sind, hat sich auch der admin Adapter wieder gestartet. Und ich komme wieder auf die Weboberfläche. Danke!
                • L Lothron
                  Deswegen: Halt die Kiste permanent auf einem aktuellen Stand.
                  Dann sparst du dir auch eher
                  Da man System schon etwas veraltet war, habe ich es komplett neu aufgesetzt
                    Lothron
                    @thomas-braun Ja, die Adapter versuche ich immer mal zu Update. Das ging dann aber alles nicht mehr, weil JS nicht aktuell war, und das hatte ich nicht geschafft zu updaten. Deshalb bin in den Weg über eine komplett neue Installation gegangen...
                    • L Lothron
                      @lothron
                      Die Systempflege muss natürlich auch dein Betriebssystem umfassen, nicht nur den ioBroker.
