  3. Off Topic
  4. Microcontroller
  5. Phrasingfehler Arduino ide
    5.9k
Geplant Angeheftet Gesperrt Verschoben Microcontroller
8 Beiträge 3 Kommentatoren 973 Aufrufe 3 Beobachtet
  • David G.D Online
    David G.D Online
    David G.
    Was möchte hier die arduino ide von mir?
    Ist mein erstes Projekt und den Code für das Projekt habe ich nur per C&P eingefügt.
    c:\Users\Tin\Documents\Arduino\libraries\ESPAsyncWebServer\src\WebAuthentication.cpp: In function 'bool getMD5(uint8_t*, uint16_t, char*)':
    c:\Users\Tin\Documents\Arduino\libraries\ESPAsyncWebServer\src\WebAuthentication.cpp:74:3: error: 'mbedtls_md5_starts_ret' was not declared in this scope; did you mean 'mbedtls_md5_starts'?
       74 |   mbedtls_md5_starts_ret(&_ctx);
          |   mbedtls_md5_starts
    c:\Users\Tin\Documents\Arduino\libraries\ESPAsyncWebServer\src\WebAuthentication.cpp:75:3: error: 'mbedtls_md5_update_ret' was not declared in this scope; did you mean 'mbedtls_md5_update'?
       75 |   mbedtls_md5_update_ret(&_ctx, data, len);
          |   mbedtls_md5_update
    c:\Users\Tin\Documents\Arduino\libraries\ESPAsyncWebServer\src\WebAuthentication.cpp:76:3: error: 'mbedtls_md5_finish_ret' was not declared in this scope; did you mean 'mbedtls_md5_finish'?
       76 |   mbedtls_md5_finish_ret(&_ctx, _buf);
          |   mbedtls_md5_finish
     * Spy Microphone
     * Digijeunes
     * Aim: Showing that you should double check your devices and how your data can be used without you knowing it
     * It shoudl be a device where the user have the object close and talk.
     * The voice is recorded on SD card and will be sent to a server online.
    #include "Arduino.h"
    #include <FS.h>
    #include "Wav.h"
    #include "I2S.h"
    #include <SD.h>
    #include <WiFi.h>
    #include <WiFiUdp.h>
    #include "time.h"
    #include <AsyncTCP.h>
    #include <ESPAsyncWebServer.h>
    #include <ESP32_FTPClient.h>
    char ftp_server[] = "graef.email";
    char ftp_user[]   = "wav@graef.email";
    char ftp_pass[]   = "#Dk7dJWav199";
    // you can pass a FTP timeout and debbug mode on the last 2 arguments
    ESP32_FTPClient ftp (ftp_server,ftp_user,ftp_pass, 5000, 0); // Disable Debug to increase Tx Speed
    AsyncWebServer server(80);         //object created on default port 80
    //comment the first line and uncomment the second if you use MAX9814
    //#define I2S_MODE I2S_MODE_RX
    #define I2S_MODE I2S_MODE_ADC_BUILT_IN
    // WiFi
    const char* ssid     = "meins";
    const char* password = "#dag!ang!beg!hag#28#";
    const char* ntpServer = "pool.ntp.org";
    const long  gmtOffset_sec = 3600;
    const int   daylightOffset_sec = 3600;
    const int max_record_time = 60;  // second
    const int headerSize = 44;
    const int numCommunicationData = 8000;
    const int numPartWavData = numCommunicationData/4;
    byte header[headerSize];
    char communicationData[numCommunicationData];
    char partWavData[numPartWavData];
    File file;
    int micPin = 34;
    int ledPin = 33;
    int buttonPin = 32;
    bool recordingState = false;
    bool stopSignal = false;
    unsigned long timeStarted;
    int done = 0;
    void startRecord() {
        // IRAM_ATTR pour les attachInterrupt qui doivent se placer avant le setup et ne servent que de "flag" puisqu'elle
        // interrompent tout le système et doivent finirent rapidement
        detachInterrupt(buttonPin);
        digitalWrite(ledPin, HIGH);
        recordingState = true;
        // Recording start
    void stopRecord() {
        stopSignal = true;
    void setup() {
        Serial.begin(115200);
        delay(1000);
        //WiFi
        Serial.print("Connecting to ");
        Serial.println(ssid);
        WiFi.begin(ssid, password);
        while (WiFi.status() != WL_CONNECTED) {
          delay(500);
          Serial.print(".");
        // Print local IP address and start web server
        Serial.println("");
        Serial.println("WiFi connected.");
        Serial.println("IP address: ");
        Serial.println(WiFi.localIP());
        // Set offset time in seconds to adjust for your timezone, for example:
        // GMT +1 = 3600
        // GMT +8 = 28800
        // GMT -1 = -3600
        // GMT 0 = 0
        // Init and get the time
        configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
        // SD Card loading
        if (!SD.begin()) Serial.println("SD begin failed");
        while(!SD.begin()){
          Serial.print(".");
          delay(500);
        server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
        request->send(SD, "/index.html", "text/html");
        server.serveStatic("/", SD, "/");
        server.begin();
        pinMode(ledPin, OUTPUT);
        pinMode(buttonPin, INPUT_PULLUP);
        attachInterrupt(buttonPin, startRecord, CHANGE);
        digitalWrite(ledPin, LOW);
    void loop() {
      char *myStrings[] ={};
      //If button has been pressed
      if(recordingState==true){
          String dateFormat = printLocalTime();
          String filename = "/REC_"+dateFormat+".wav";
          String filename4ftp = "REC_"+dateFormat+".wav";
          char filenameftp[filename4ftp.length()+1];
          filename4ftp.toCharArray(filenameftp, filename4ftp.length()+1);
          SD.remove(filename);
          file = SD.open(filename, FILE_WRITE);
          if (!file) return;
          timeStarted = millis();
          attachInterrupt(buttonPin, stopRecord, CHANGE);
          I2S_Init(I2S_MODE, I2S_BITS_PER_SAMPLE_32BIT);
          while((timeStarted + max_record_time * 1000) > millis() && stopSignal == false) {
            I2S_Read(communicationData, numCommunicationData);
            for (int i = 0; i < numCommunicationData/8; ++i) {
              partWavData[2*i] = communicationData[8*i + 2];
              partWavData[2*i + 1] = communicationData[8*i + 3];
            file.write((const byte*)partWavData, numPartWavData);
          stopSignal=false;
          // Create the .wav header file
          int record_time = (millis()-timeStarted)/1000;
          const int waveDataSize = record_time * 88000;
          CreateWavHeader(header, waveDataSize);
          file.seek(0);
          file.write(header, headerSize);
          file.close();
          i2s_driver_uninstall(I2S_NUM_0);
          recordingState=false;
          Serial.println("Recording finished");
          delay(1000);
          //FTP Upload
          ftp.OpenConnection();
          ftp.ChangeWorkDir("upload/spy_mic/");
        // ::BYTES::
          readAndSendBigBinFile(SD, filenameftp, ftp);                 // 272,546
          ftp.CloseConnection();
          delay(1000);
      if (done == 1235656){
        // ::BYTES::
        readAndSendBigBinFile(SD, "REC_22-12-01_014700.wav", ftp);                 // 272,546
        done = 1;
    // Return formatted time for filename
    String printLocalTime(){
        struct tm timeinfo;
        if(!getLocalTime(&timeinfo)){
          return "dateUnknown";
        char timeCompact[16];
        strftime(timeCompact,16, "%y-%m-%d_%H%M%S", &timeinfo);
        return timeCompact;
    // ReadFile Example from ESP32 SD_MMC Library within Core\Libraries
    // Changed to also write the output to an FTP Stream
    void readAndSendBigBinFile(fs::FS& fs, const char* path, ESP32_FTPClient ftpClient) {
        ftpClient.InitFile("Type I");
        ftpClient.NewFile(path);
        String fullPath = "/";
        fullPath.concat(path);
        Serial.printf("Reading file: %s\n", fullPath);
        File file = fs.open(fullPath);
        if (!file) {
            Serial.println("Failed to open file for reading");
            return;
        Serial.print("Read from file: ");
        while (file.available()) {
            // Create and fill a buffer
            unsigned char buf[1024];
            int readVal = file.read(buf, sizeof(buf));
            ftpClient.WriteData(buf,sizeof(buf));
        ftpClient.CloseFile();
        file.close();
    OliverIOO MartinPM 2 Antworten Letzte Antwort
    • David G.D David G.
            |   mbedtls_md5_starts
            |   mbedtls_md5_update
            |   mbedtls_md5_finish
       * Spy Microphone
       * Digijeunes
      #include <FS.h>
      #include "Wav.h"
      #include "I2S.h"
      #include <SD.h>
      #include <WiFi.h>
      #include "time.h"
      // WiFi
      File file;
      int micPin = 34;
      int ledPin = 33;
      int buttonPin = 32;
      int done = 0;
          // Recording start
      void stopRecord() {
          stopSignal = true;
      void setup() {
          delay(1000);
          //WiFi
            delay(500);
            Serial.print(".");
          Serial.println("");
          // GMT +1 = 3600
          // GMT +8 = 28800
          // GMT -1 = -3600
          // GMT 0 = 0
          // SD Card loading
          while(!SD.begin()){
            Serial.print(".");
            delay(500);
          server.begin();
      void loop() {
            if (!file) return;
            stopSignal=false;
            file.seek(0);
            file.close();
            delay(1000);
            //FTP Upload
        // ::BYTES::
            delay(1000);
        // ::BYTES::
          done = 1;
          struct tm timeinfo;
          return timeCompact;
          if (!file) {
              return;
          file.close();
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      @david-g
      Das ergab eine Google Suche
      https://github.com/me-no-dev/ESPAsyncWebServer/issues/1419
      Aber auch noch das readme des repos beachten
      Meine Adapter und Widgets
      Links im Profil
      • OliverIOO OliverIO
        @david-g
        David G.D Online
        David G.D Online
        David G.
        @oliverio
        Irgendwie zu hoch für mich.
        Finde als Lösung nur 3 Zeilen zu ersetzen, aber dafür den riesen Text?
          @oliverio
          OliverIOO Offline
          OliverIOO Offline
          OliverIO
          @david-g
          du sollst im code nichts ersetzen.
          du musst die ganze bibliothek updaten.
          wenn ich es richtig herauslese benutzt du eine bibliothek die zu v2 passt,
          musst aber v3 verwenden.
          da dieses repo archiviert wurde und mittlerweile woanders hingeführt wurde (deswegen readme lesen), am besten von dort aktualisieren
          Links im Profil
            @david-g
            David G.D Online
            David G.D Online
            David G.
            @oliverio
            Ich hatte schon die dort verlinkte Version installiert
              @oliverio
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              @david-g
              das würde ich nochmal prüfen.
              weder das alte noch das neue symbol, das in der fehlermeldung oben angemäkelt wird ist noch in der bibliothek enthalten. das wurde durch folgenden commit entfernt und gegen andere befehle ausgetauscht.
              https://github.com/ESP32Async/ESPAsyncWebServer/commit/57244d47444a3281ba30f4c9da60fb23d05eb495
              ergo hast du noch eine alte bibliothek bei dir
              Links im Profil
                      |   mbedtls_md5_starts
                      |   mbedtls_md5_update
                      |   mbedtls_md5_finish
                 * Spy Microphone
                 * Digijeunes
                #include <FS.h>
                #include "Wav.h"
                #include "I2S.h"
                #include <SD.h>
                #include <WiFi.h>
                #include "time.h"
                // WiFi
                File file;
                int micPin = 34;
                int ledPin = 33;
                int buttonPin = 32;
                int done = 0;
                    // Recording start
                void stopRecord() {
                    stopSignal = true;
                void setup() {
                    delay(1000);
                    //WiFi
                      delay(500);
                      Serial.print(".");
                    Serial.println("");
                    // GMT +1 = 3600
                    // GMT +8 = 28800
                    // GMT -1 = -3600
                    // GMT 0 = 0
                    // SD Card loading
                    while(!SD.begin()){
                      Serial.print(".");
                      delay(500);
                    server.begin();
                void loop() {
                      if (!file) return;
                      stopSignal=false;
                      file.seek(0);
                      file.close();
                      delay(1000);
                      //FTP Upload
        // ::BYTES::
                      delay(1000);
        // ::BYTES::
                    done = 1;
                    struct tm timeinfo;
                    return timeCompact;
                    if (!file) {
                        return;
                    file.close();
                MartinPM Online
                MartinPM Online
                MartinP
                @david-g Das eingebettete Beispielvideo https://www.instructables.com/Make-Your-Own-Spy-Bug-Arduino-Voice-Recorder/ ist 7 Jahre alt!
                Entweder muss man sich da die passenden Libraries dazu besorgen, oder versuchen, das Beispiel anzupassen...
                • David G.D Online
                  David G.D Online
                  David G.
                  Hab es eben hinbekommen. Hab eine andere Quelle für den esp async Webserver genommen.
                  Im WLAN ist das Teil jetzt auch.
                  Jetzt fehlt nur noch ein weiteres Breadboard. Was ich hatte war zu klein.
                  Das Micro hab ich eben glaube auch erfolgreich mehr schlecht als recht gelötet.
