  4. Node-Red
  5. Hilfe bei NodeRed wegen Status Fenster/Türen - GELÖST
    6.4k
16 Beiträge 2 Kommentatoren 1.9k Aufrufe 2 Beobachtet
  • mickymM Offline
    mickymM Offline
    mickym
    So ich habe Dir mit Deinen Daten folgendes gebastelt:
    Du siehst in der 1. Node werden alle geschlossenen Fenster selektiert. In der 2. Node alle offenen Fenster.
    Hier der Flow zum Import:
           "id": "3da931fb6f59da6d",
           "type": "inject",
           "z": "7e6af0015415146d",
           "name": "Daten von zigbee2mqtt",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "{\"0x54ef44100025b758\":{\"item\":{\"definition\":{\"description\":\"Door and window sensor E1\",\"exposes\":[{\"access\":1,\"description\":\"Indicates if the contact is closed (= true) or open (= false)\",\"label\":\"Contact\",\"name\":\"contact\",\"property\":\"contact\",\"type\":\"binary\",\"value_off\":true,\"value_on\":false},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Remaining battery in %, can take up to 24 hours before reported\",\"label\":\"Battery\",\"name\":\"battery\",\"property\":\"battery\",\"type\":\"numeric\",\"unit\":\"%\",\"value_max\":100,\"value_min\":0},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Indicates if the battery of this device is almost empty\",\"label\":\"Battery low\",\"name\":\"battery_low\",\"property\":\"battery_low\",\"type\":\"binary\",\"value_off\":false,\"value_on\":true},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Voltage of the battery in millivolts\",\"label\":\"Voltage\",\"name\":\"voltage\",\"property\":\"voltage\",\"type\":\"numeric\",\"unit\":\"mV\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Link quality (signal strength)\",\"label\":\"Linkquality\",\"name\":\"linkquality\",\"property\":\"linkquality\",\"type\":\"numeric\",\"unit\":\"lqi\",\"value_max\":255,\"value_min\":0}],\"icon\":\"data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAgAAAAIACAYAAAD0eNT6AAAABGdBTUEAALGPC/xhBQAAACBjSFJNAAB6JgAAgIQAAPoAAACA6AAAdTAAAOpgAAA6mAAAF3CculE8AAAABmJLR0QA/wD/AP+gvaeTAAAACXBIWXMAAAsSAAALEgHS3X78AAABhXpUWHRSYXcgcHJvZmlsZSB0eXBlIHhtcAAAOI2VVFtugzAQ/N9T9Ahmn/ZxKNh/lfrZ43fXUB4BFBUrJLFnZ2ZHtuHn6xs+4pFSgCbLNFrW2ZLOKsY6YIr/Omk1ijWaEXVQ1qaoQuMyv6EbIibYaXzyM0ok8ywJE5M280JMpFgp9Q9STSOmGG4BnVxpFGQG1hf9ZTE8ZGMfiUbXbNYfrOYgrF3CsNFAJQY2oEToE+jveSHxb7LitG7bMs4hEMu7l1dHzCpgpOQTpbdWPIXqDleA54Ku7UmEQw/iRHQcluHQVBDpXVvdU93j9t+en87e8FoTrQ09xHa1vjXwJzByL7dwLN4+LR1Q9aQm2Fmfge8EJAtClDh8iiQ2hUh3OkoE9A65S8CDRrkvvJFYkfCs8ZBT7KCism6PrQ4iqFNOD8B3AiBJswZRW85OpyFeNqQYrtGfSC/tOQf8l+TJGWysN+GKN+h7nm88XNBwhL+eJWzH03Q9TMebAHZwXAassdgpLrdUrMAvbhQcoxzYWVIAAAABb3JOVAHPoneaAAB8D0lEQVR42u39eZxkWVbfCf7Ove+ZmZvvsWVk5FK5VGVVVgIFimJRCYmIGWZKI0GxqD3YVUULFd108xH6SCC1+EjhMZ8ZNDNaWqNGS43UCKmhYTwQtARCIBpFIJUaWmQAVUVlLVmVS2XGHh6+mbuZvffuPf3He8/8mbmZufkabua/b34s3cOW5+7v3XfP75x77jkAIYQQQgghhBBCCCGEEEIIIYQQQgghhBBCCCGEEEIIIYQQQgghhB...\",\"model\":\"MCCGQ14LM\",\"options\":[],\"supports_ota\":false,\"vendor\":\"Aqara\"},\"disabled\":false,\"endpoints\":{\"1\":{\"bindings\":[],\"clusters\":{\"input\":[\"genBasic\",\"genPowerCfg\",\"genIdentify\",\"ssIasZone\",\"manuSpecificLumi\"],\"output\":[\"genIdentify\",\"genOta\"]},\"configured_reportings\":[],\"scenes\":[]}},\"friendly_name\":\"Küche FensterR Contact\",\"ieee_address\":\"0x54ef44100025b758\",\"interview_completed\":true,\"interviewing\":false,\"manufacturer\":\"LUMI\",\"model_id\":\"lumi.magnet.acn001\",\"network_address\":1783,\"power_source\":\"Battery\",\"supported\":true,\"type\":\"EndDevice\",\"current_values\":{\"battery\":89,\"battery_low\":false,\"contact\":true,\"last_seen\":\"2025-02-18T16:46:47+01:00\",\"linkquality\":98,\"power_outage_count\":0,\"tamper\":false,\"voltage\":2983},\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":89,\"StatusLowBattery\":0}},\"format\":{}},\"topic\":\"zigbee2mqtt/Küche FensterR Contact\",\"selector\":\"zigbee2mqtt_KcheFensterRContact\",\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":89,\"StatusLowBattery\":0}},\"payload\":{\"battery\":89,\"battery_low\":false,\"contact\":true,\"last_seen\":\"2025-02-18T16:46:47+01:00\",\"linkquality\":98,\"power_outage_count\":0,\"tamper\":false,\"voltage\":2983},\"format\":{}},\"0x54ef44100025b3ff\":{\"item\":{\"definition\":{\"description\":\"Door and window sensor E1\",\"exposes\":[{\"access\":1,\"description\":\"Indicates if the contact is closed (= true) or open (= false)\",\"label\":\"Contact\",\"name\":\"contact\",\"property\":\"contact\",\"type\":\"binary\",\"value_off\":true,\"value_on\":false},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Remaining battery in %, can take up to 24 hours before reported\",\"label\":\"Battery\",\"name\":\"battery\",\"property\":\"battery\",\"type\":\"numeric\",\"unit\":\"%\",\"value_max\":100,\"value_min\":0},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Indicates if the battery of this device is almost empty\",\"label\":\"Battery low\",\"name\":\"battery_low\",\"property\":\"battery_low\",\"type\":\"binary\",\"value_off\":false,\"value_on\":true},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Voltage of the battery in millivolts\",\"label\":\"Voltage\",\"name\":\"voltage\",\"property\":\"voltage\",\"type\":\"numeric\",\"unit\":\"mV\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Link quality (signal strength)\",\"label\":\"Linkquality\",\"name\":\"linkquality\",\"property\":\"linkquality\",\"type\":\"numeric\",\"unit\":\"lqi\",\"value_max\":255,\"value_min\":0}],\"icon\":\"data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAgAAAAIACAYAAAD0eNT6AAAABGdBTUEAALGPC/xhBQAAACBjSFJNAAB6JgAAgIQAAPoAAACA6AAAdTAAAOpgAAA6mAAAF3CculE8AAAABmJLR0QA/wD/AP+gvaeTAAAACXBIWXMAAAsSAAALEgHS3X78AAABhXpUWHRSYXcgcHJvZmlsZSB0eXBlIHhtcAAAOI2VVFtugzAQ/N9T9Ahmn/ZxKNh/lfrZ43fXUB4BFBUrJLFnZ2ZHtuHn6xs+4pFSgCbLNFrW2ZLOKsY6YIr/Omk1ijWaEXVQ1qaoQuMyv6EbIibYaXzyM0ok8ywJE5M280JMpFgp9Q9STSOmGG4BnVxpFGQG1hf9ZTE8ZGMfiUbXbNYfrOYgrF3CsNFAJQY2oEToE+jveSHxb7LitG7bMs4hEMu7l1dHzCpgpOQTpbdWPIXqDleA54Ku7UmEQw/iRHQcluHQVBDpXVvdU93j9t+en87e8FoTrQ09xHa1vjXwJzByL7dwLN4+LR1Q9aQm2Fmfge8EJAtClDh8iiQ2hUh3OkoE9A65S8CDRrkvvJFYkfCs8ZBT7KCism6PrQ4iqFNOD8B3AiBJswZRW85OpyFeNqQYrtGfSC/tOQf8l+TJGWysN+GKN+h7nm88XNBwhL+eJWzH03Q9TMebAHZwXAassdgpLrdUrMAvbhQcoxzYWVIAAAABb3JOVAHPoneaAAB8D0lEQVR42u39eZxkWVbfCf7Ove+ZmZvvsWVk5FK5VGVVVgIFimJRCYmIGWZKI0GxqD3YVUULFd108xH6SCC1+EjhMZ8ZNDNaWqNGS43UCKmhYTwQtARCIBpFIJUaWmQAVUVlLVmVS2XGHh6+mbuZvffuPf3He8/8mbmZufkabua/b34s3cOW5+7v3XfP75x77jkAIYQQQgghhBBCCCGEEEIIIYQQQgghhBBCCCGEEEIIIYQQQgghhB...\",\"model\":\"MCCGQ14LM\",\"options\":[],\"supports_ota\":false,\"vendor\":\"Aqara\"},\"disabled\":false,\"endpoints\":{\"1\":{\"bindings\":[],\"clusters\":{\"input\":[\"genBasic\",\"genPowerCfg\",\"genIdentify\",\"ssIasZone\",\"manuSpecificLumi\"],\"output\":[\"genIdentify\",\"genOta\"]},\"configured_reportings\":[],\"scenes\":[]}},\"friendly_name\":\"Küche FensterL Contact\",\"ieee_address\":\"0x54ef44100025b3ff\",\"interview_completed\":true,\"interviewing\":false,\"manufacturer\":\"LUMI\",\"model_id\":\"lumi.magnet.acn001\",\"network_address\":30725,\"power_source\":\"Battery\",\"supported\":true,\"type\":\"EndDevice\",\"current_values\":{\"battery\":78,\"battery_low\":false,\"contact\":true,\"last_seen\":\"2025-02-18T16:53:33+01:00\",\"linkquality\":76,\"power_outage_count\":1,\"tamper\":false,\"voltage\":2967},\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":78,\"StatusLowBattery\":0}},\"format\":{}},\"topic\":\"zigbee2mqtt/Küche FensterL Contact\",\"selector\":\"zigbee2mqtt_KcheFensterLContact\",\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":78,\"StatusLowBattery\":0}},\"payload\":{\"battery\":78,\"battery_low\":false,\"contact\":true,\"last_seen\":\"2025-02-18T16:53:33+01:00\",\"linkquality\":76,\"power_outage_count\":1,\"tamper\":false,\"voltage\":2967},\"format\":{}},\"0x00158d0006bd1963\":{\"item\":{\"definition\":{\"description\":\"Door and window sensor\",\"exposes\":[{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Remaining battery in %, can take up to 24 hours before reported\",\"label\":\"Battery\",\"name\":\"battery\",\"property\":\"battery\",\"type\":\"numeric\",\"unit\":\"%\",\"value_max\":100,\"value_min\":0},{\"access\":1,\"description\":\"Indicates if the contact is closed (= true) or open (= false)\",\"label\":\"Contact\",\"name\":\"contact\",\"property\":\"contact\",\"type\":\"binary\",\"value_off\":true,\"value_on\":false},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Temperature of the device\",\"label\":\"Device temperature\",\"name\":\"device_temperature\",\"property\":\"device_temperature\",\"type\":\"numeric\",\"unit\":\"°C\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Voltage of the battery in millivolts\",\"label\":\"Voltage\",\"name\":\"voltage\",\"property\":\"voltage\",\"type\":\"numeric\",\"unit\":\"mV\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Number of power outages\",\"label\":\"Power outage count\",\"name\":\"power_outage_count\",\"property\":\"power_outage_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Indicates how many times the sensor was triggered (since last scheduled report)\",\"label\":\"Trigger count\",\"name\":\"trigger_count\",\"property\":\"trigger_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Link quality (signal strength)\",\"label\":\"Linkquality\",\"name\":\"linkquality\",\"property\":\"linkquality\",\"type\":\"numeric\",\"unit\":\"lqi\",\"value_max\":255,\"value_min\":0}],\"icon\":\"data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAgAAAAIACAYAAAD0eNT6AAAABGdBTUEAALGPC/xhBQAAACBjSFJNAAB6JgAAgIQAAPoAAACA6AAAdTAAAOpgAAA6mAAAF3CculE8AAAABmJLR0QA/wD/AP+gvaeTAAAACXBIWXMAAAsSAAALEgHS3X78AAABhXpUWHRSYXcgcHJvZmlsZSB0eXBlIHhtcAAAOI2VVFtugzAQ/N9T9Ahmn/ZxKNh/lfrZ43fXUB4BFBUrJLFnZ2ZHtuHn6xs+4pFSgCbLNFrW2ZLOKsY6YIr/Omk1ijWaEXVQ1qaoQuMyv6EbIibYaXzyM0ok8ywJE5M280JMpFgp9Q9STSOmGG4BnVxpFGQG1hf9ZTE8ZGMfiUbXbNYfrOYgrF3CsNFAJQY2oEToE+jveSHxb7LitG7bMs4hEMu7l1dHzCpgpOQTpbdWPIXqDleA54Ku7UmEQw/iRHQcluHQVBDpXVvdU93j9t+en87e8FoTrQ09xHa1vjXwJzByL7dwLN4+LR1Q9aQm2Fmfge8EJAtClDh8iiQ2hUh3OkoE9A65S8CDRrkvvJFYkfCs8ZBT7KCism6PrQ4iqFNOD8B3AiBJswZRW85OpyFeNqQYrtGfSC/tOQf8l+TJGWysN+GKN+h7nm88XNBwhL+eJWzH03Q9TMebAHZwXAassdgpLrdUrMAvbhQcoxzYWVIAAAABb3JOVAHPoneaAAB8D0lEQVR42u39eZxkWVbfCf7Ove+ZmZvvsWVk5FK5VGVVVgIFimJRCYmIGWZKI0GxqD3YVUULFd108xH6SCC1+EjhMZ8ZNDNaWqNGS43UCKmhYTwQtARCIBpFIJUaWmQAVUVlLVmVS2XGHh6+mbuZvffuPf3He8/8mbmZufkabua/b34s3cOW5+7v3XfP75x77jkAIYQQQgghhBBCCCGEEEIIIYQQQgghhBBCCCGEEEIIIYQQQgghhB...\",\"model\":\"MCCGQ11LM\",\"options\":[{\"access\":2,\"description\":\"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.\",\"label\":\"Device temperature calibration\",\"name\":\"device_temperature_calibration\",\"property\":\"device_temperature_calibration\",\"type\":\"numeric\"}],\"supports_ota\":false,\"vendor\":\"Aqara\"},\"disabled\":false,\"endpoints\":{\"1\":{\"bindings\":[],\"clusters\":{\"input\":[],\"output\":[]},\"configured_reportings\":[],\"scenes\":[]}},\"friendly_name\":\"Studio FensterR Contact\",\"ieee_address\":\"0x00158d0006bd1963\",\"interview_completed\":true,\"interviewing\":false,\"manufacturer\":\"LUMI\",\"model_id\":\"lumi.sensor_magnet.aq2\",\"network_address\":39306,\"power_source\":\"Battery\",\"supported\":true,\"type\":\"EndDevice\",\"current_values\":{\"battery\":100,\"contact\":true,\"device_temperature\":16,\"last_seen\":\"2025-02-18T16:47:16+01:00\",\"linkquality\":105,\"power_outage_count\":73,\"trigger_count\":0,\"voltage\":3005},\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"format\":{}},\"topic\":\"zigbee2mqtt/Studio FensterR Contact\",\"selector\":\"zigbee2mqtt_StudioFensterRContact\",\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"payload\":{\"battery\":100,\"contact\":true,\"device_temperature\":16,\"last_seen\":\"2025-02-18T16:47:16+01:00\",\"linkquality\":105,\"power_outage_count\":73,\"trigger_count\":0,\"voltage\":3005},\"format\":{}},\"0x00158d00019f3819\":{\"item\":{\"definition\":{\"description\":\"Door and window sensor\",\"exposes\":[{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Remaining battery in %, can take up to 24 hours before reported\",\"label\":\"Battery\",\"name\":\"battery\",\"property\":\"battery\",\"type\":\"numeric\",\"unit\":\"%\",\"value_max\":100,\"value_min\":0},{\"access\":1,\"description\":\"Indicates if the contact is closed (= true) or open (= false)\",\"label\":\"Contact\",\"name\":\"contact\",\"property\":\"contact\",\"type\":\"binary\",\"value_off\":true,\"value_on\":false},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Temperature of the device\",\"label\":\"Device temperature\",\"name\":\"device_temperature\",\"property\":\"device_temperature\",\"type\":\"numeric\",\"unit\":\"°C\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Voltage of the battery in millivolts\",\"label\":\"Voltage\",\"name\":\"voltage\",\"property\":\"voltage\",\"type\":\"numeric\",\"unit\":\"mV\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Number of power outages\",\"label\":\"Power outage count\",\"name\":\"power_outage_count\",\"property\":\"power_outage_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Indicates how many times the sensor was triggered (since last scheduled report)\",\"label\":\"Trigger count\",\"name\":\"trigger_count\",\"property\":\"trigger_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Link quality (signal strength)\",\"label\":\"Linkquality\",\"name\":\"linkquality\",\"property\":\"linkquality\",\"type\":\"numeric\",\"unit\":\"lqi\",\"value_max\":255,\"value_min\":0}],\"icon\":\"data:image/png;base64,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...\",\"model\":\"MCCGQ11LM\",\"options\":[{\"access\":2,\"description\":\"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.\",\"label\":\"Device temperature calibration\",\"name\":\"device_temperature_calibration\",\"property\":\"device_temperature_calibration\",\"type\":\"numeric\"}],\"supports_ota\":false,\"vendor\":\"Aqara\"},\"disabled\":false,\"endpoints\":{\"1\":{\"bindings\":[],\"clusters\":{\"input\":[],\"output\":[]},\"configured_reportings\":[],\"scenes\":[]}},\"friendly_name\":\"Bad Fenster Contact\",\"ieee_address\":\"0x00158d00019f3819\",\"interview_completed\":true,\"interviewing\":false,\"manufacturer\":\"LUMI\",\"model_id\":\"lumi.sensor_magnet.aq2\",\"network_address\":30025,\"power_source\":\"Battery\",\"supported\":true,\"type\":\"EndDevice\",\"current_values\":{\"battery\":100,\"contact\":true,\"device_temperature\":18,\"last_seen\":\"2025-02-18T17:08:11+01:00\",\"linkquality\":160,\"power_outage_count\":241,\"trigger_count\":0,\"voltage\":3005},\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"format\":{}},\"topic\":\"zigbee2mqtt/Bad Fenster Contact\",\"selector\":\"zigbee2mqtt_BadFensterContact\",\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"payload\":{\"battery\":100,\"contact\":true,\"device_temperature\":18,\"last_seen\":\"2025-02-18T17:08:11+01:00\",\"linkquality\":160,\"power_outage_count\":241,\"trigger_count\":0,\"voltage\":3005},\"format\":{}},\"0x00158d0006b7d36c\":{\"item\":{\"definition\":{\"description\":\"Door and window sensor\",\"exposes\":[{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Remaining battery in %, can take up to 24 hours before reported\",\"label\":\"Battery\",\"name\":\"battery\",\"property\":\"battery\",\"type\":\"numeric\",\"unit\":\"%\",\"value_max\":100,\"value_min\":0},{\"access\":1,\"description\":\"Indicates if the contact is closed (= true) or open (= false)\",\"label\":\"Contact\",\"name\":\"contact\",\"property\":\"contact\",\"type\":\"binary\",\"value_off\":true,\"value_on\":false},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Temperature of the device\",\"label\":\"Device temperature\",\"name\":\"device_temperature\",\"property\":\"device_temperature\",\"type\":\"numeric\",\"unit\":\"°C\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Voltage of the battery in millivolts\",\"label\":\"Voltage\",\"name\":\"voltage\",\"property\":\"voltage\",\"type\":\"numeric\",\"unit\":\"mV\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Number of power outages\",\"label\":\"Power outage count\",\"name\":\"power_outage_count\",\"property\":\"power_outage_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Indicates how many times the sensor was triggered (since last scheduled report)\",\"label\":\"Trigger count\",\"name\":\"trigger_count\",\"property\":\"trigger_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Link quality (signal strength)\",\"label\":\"Linkquality\",\"name\":\"linkquality\",\"property\":\"linkquality\",\"type\":\"numeric\",\"unit\":\"lqi\",\"value_max\":255,\"value_min\":0}],\"icon\":\"data:image/png;base64,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...\",\"model\":\"MCCGQ11LM\",\"options\":[{\"access\":2,\"description\":\"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.\",\"label\":\"Device temperature calibration\",\"name\":\"device_temperature_calibration\",\"property\":\"device_temperature_calibration\",\"type\":\"numeric\"}],\"supports_ota\":false,\"vendor\":\"Aqara\"},\"disabled\":false,\"endpoints\":{\"1\":{\"bindings\":[],\"clusters\":{\"input\":[\"genBasic\",\"genIdentify\",\"65535\",\"genOnOff\"],\"output\":[\"genBasic\",\"genGroups\",\"65535\"]},\"configured_reportings\":[],\"scenes\":[]}},\"friendly_name\":\"Schlafzimmer Fenster Contact\",\"ieee_address\":\"0x00158d0006b7d36c\",\"interview_completed\":true,\"interviewing\":false,\"manufacturer\":\"LUMI\",\"model_id\":\"lumi.sensor_magnet.aq2\",\"network_address\":61288,\"power_source\":\"Battery\",\"supported\":true,\"type\":\"EndDevice\",\"current_values\":{\"battery\":100,\"contact\":true,\"device_temperature\":18,\"last_seen\":\"2025-02-18T17:23:11+01:00\",\"linkquality\":109,\"power_outage_count\":103,\"trigger_count\":0,\"voltage\":3025},\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"format\":{}},\"topic\":\"zigbee2mqtt/Schlafzimmer Fenster Contact\",\"selector\":\"zigbee2mqtt_SchlafzimmerFensterContact\",\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"payload\":{\"battery\":100,\"contact\":true,\"device_temperature\":18,\"last_seen\":\"2025-02-18T17:23:11+01:00\",\"linkquality\":109,\"power_outage_count\":103,\"trigger_count\":0,\"voltage\":3025},\"format\":{}},\"0x00158d0006b7ccb9\":{\"item\":{\"date_code\":\"20161128\",\"definition\":{\"description\":\"Door and window sensor\",\"exposes\":[{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Remaining battery in %, can take up to 24 hours before reported\",\"label\":\"Battery\",\"name\":\"battery\",\"property\":\"battery\",\"type\":\"numeric\",\"unit\":\"%\",\"value_max\":100,\"value_min\":0},{\"access\":1,\"description\":\"Indicates if the contact is closed (= true) or open (= false)\",\"label\":\"Contact\",\"name\":\"contact\",\"property\":\"contact\",\"type\":\"binary\",\"value_off\":true,\"value_on\":false},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Temperature of the device\",\"label\":\"Device temperature\",\"name\":\"device_temperature\",\"property\":\"device_temperature\",\"type\":\"numeric\",\"unit\":\"°C\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Voltage of the battery in millivolts\",\"label\":\"Voltage\",\"name\":\"voltage\",\"property\":\"voltage\",\"type\":\"numeric\",\"unit\":\"mV\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Number of power outages\",\"label\":\"Power outage count\",\"name\":\"power_outage_count\",\"property\":\"power_outage_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Indicates how many times the sensor was triggered (since last scheduled report)\",\"label\":\"Trigger count\",\"name\":\"trigger_count\",\"property\":\"trigger_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Link quality (signal strength)\",\"label\":\"Linkquality\",\"name\":\"linkquality\",\"property\":\"linkquality\",\"type\":\"numeric\",\"unit\":\"lqi\",\"value_max\":255,\"value_min\":0}],\"icon\":\"data:image/png;base64,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...\",\"model\":\"MCCGQ11LM\",\"options\":[{\"access\":2,\"description\":\"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.\",\"label\":\"Device temperature calibration\",\"name\":\"device_temperature_calibration\",\"property\":\"device_temperature_calibration\",\"type\":\"numeric\"}],\"supports_ota\":false,\"vendor\":\"Aqara\"},\"disabled\":false,\"endpoints\":{\"1\":{\"bindings\":[],\"clusters\":{\"input\":[\"genBasic\",\"genIdentify\",\"65535\",\"genOnOff\"],\"output\":[\"genBasic\",\"genGroups\",\"65535\"]},\"configured_reportings\":[],\"scenes\":[]}},\"friendly_name\":\"Lina Fenster Contact\",\"ieee_address\":\"0x00158d0006b7ccb9\",\"interview_completed\":true,\"interviewing\":false,\"manufacturer\":\"LUMI\",\"model_id\":\"lumi.sensor_magnet.aq2\",\"network_address\":30017,\"power_source\":\"Battery\",\"software_build_id\":\"3000-0001\",\"supported\":true,\"type\":\"EndDevice\",\"current_values\":{\"battery\":100,\"contact\":true,\"device_temperature\":23,\"last_seen\":\"2025-02-18T17:00:27+01:00\",\"linkquality\":160,\"power_outage_count\":24,\"trigger_count\":0,\"voltage\":3005},\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"format\":{}},\"topic\":\"zigbee2mqtt/Lina Fenster Contact\",\"selector\":\"zigbee2mqtt_LinaFensterContact\",\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"payload\":{\"battery\":100,\"contact\":true,\"device_temperature\":23,\"last_seen\":\"2025-02-18T17:00:27+01:00\",\"linkquality\":160,\"power_outage_count\":24,\"trigger_count\":0,\"voltage\":3005},\"format\":{}},\"0x00158d0001dd431f\":{\"item\":{\"date_code\":\"20161128\",\"definition\":{\"description\":\"Door and window sensor\",\"exposes\":[{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Remaining battery in %, can take up to 24 hours before reported\",\"label\":\"Battery\",\"name\":\"battery\",\"property\":\"battery\",\"type\":\"numeric\",\"unit\":\"%\",\"value_max\":100,\"value_min\":0},{\"access\":1,\"description\":\"Indicates if the contact is closed (= true) or open (= false)\",\"label\":\"Contact\",\"name\":\"contact\",\"property\":\"contact\",\"type\":\"binary\",\"value_off\":true,\"value_on\":false},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Temperature of the device\",\"label\":\"Device temperature\",\"name\":\"device_temperature\",\"property\":\"device_temperature\",\"type\":\"numeric\",\"unit\":\"°C\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Voltage of the battery in millivolts\",\"label\":\"Voltage\",\"name\":\"voltage\",\"property\":\"voltage\",\"type\":\"numeric\",\"unit\":\"mV\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Number of power outages\",\"label\":\"Power outage count\",\"name\":\"power_outage_count\",\"property\":\"power_outage_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Indicates how many times the sensor was triggered (since last scheduled report)\",\"label\":\"Trigger count\",\"name\":\"trigger_count\",\"property\":\"trigger_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Link quality (signal strength)\",\"label\":\"Linkquality\",\"name\":\"linkquality\",\"property\":\"linkquality\",\"type\":\"numeric\",\"unit\":\"lqi\",\"value_max\":255,\"value_min\":0}],\"icon\":\"data:image/png;base64,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...\",\"model\":\"MCCGQ11LM\",\"options\":[{\"access\":2,\"description\":\"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.\",\"label\":\"Device temperature calibration\",\"name\":\"device_temperature_calibration\",\"property\":\"device_temperature_calibration\",\"type\":\"numeric\"}],\"supports_ota\":false,\"vendor\":\"Aqara\"},\"disabled\":false,\"endpoints\":{\"1\":{\"bindings\":[],\"clusters\":{\"input\":[\"genBasic\",\"genIdentify\",\"65535\",\"genOnOff\"],\"output\":[\"genBasic\",\"genGroups\",\"65535\"]},\"configured_reportings\":[],\"scenes\":[]}},\"friendly_name\":\"WC Fenster Contact\",\"ieee_address\":\"0x00158d0001dd431f\",\"interview_completed\":true,\"interviewing\":false,\"manufacturer\":\"LUMI\",\"model_id\":\"lumi.sensor_magnet.aq2\",\"network_address\":50753,\"power_source\":\"Battery\",\"software_build_id\":\"3000-0001\",\"supported\":true,\"type\":\"EndDevice\",\"current_values\":{\"battery\":100,\"contact\":true,\"device_temperature\":12,\"last_seen\":\"2025-02-18T16:47:38+01:00\",\"linkquality\":160,\"power_outage_count\":55,\"trigger_count\":0,\"voltage\":3045},\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"format\":{}},\"topic\":\"zigbee2mqtt/WC Fenster Contact\",\"selector\":\"zigbee2mqtt_WCFensterContact\",\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"payload\":{\"battery\":100,\"contact\":true,\"device_temperature\":12,\"last_seen\":\"2025-02-18T16:47:38+01:00\",\"linkquality\":160,\"power_outage_count\":55,\"trigger_count\":0,\"voltage\":3045},\"format\":{}},\"0x00158d0001ddef66\":{\"item\":{\"definition\":{\"description\":\"Door and window sensor\",\"exposes\":[{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Remaining battery in %, can take up to 24 hours before reported\",\"label\":\"Battery\",\"name\":\"battery\",\"property\":\"battery\",\"type\":\"numeric\",\"unit\":\"%\",\"value_max\":100,\"value_min\":0},{\"access\":1,\"description\":\"Indicates if the contact is closed (= true) or open (= false)\",\"label\":\"Contact\",\"name\":\"contact\",\"property\":\"contact\",\"type\":\"binary\",\"value_off\":true,\"value_on\":false},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Temperature of the device\",\"label\":\"Device temperature\",\"name\":\"device_temperature\",\"property\":\"device_temperature\",\"type\":\"numeric\",\"unit\":\"°C\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Voltage of the battery in millivolts\",\"label\":\"Voltage\",\"name\":\"voltage\",\"property\":\"voltage\",\"type\":\"numeric\",\"unit\":\"mV\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Number of power outages\",\"label\":\"Power outage count\",\"name\":\"power_outage_count\",\"property\":\"power_outage_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Indicates how many times the sensor was triggered (since last scheduled report)\",\"label\":\"Trigger count\",\"name\":\"trigger_count\",\"property\":\"trigger_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Link quality (signal strength)\",\"label\":\"Linkquality\",\"name\":\"linkquality\",\"property\":\"linkquality\",\"type\":\"numeric\",\"unit\":\"lqi\",\"value_max\":255,\"value_min\":0}],\"icon\":\"data:image/png;base64,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...\",\"model\":\"MCCGQ11LM\",\"options\":[{\"access\":2,\"description\":\"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.\",\"label\":\"Device temperature calibration\",\"name\":\"device_temperature_calibration\",\"property\":\"device_temperature_calibration\",\"type\":\"numeric\"}],\"supports_ota\":false,\"vendor\":\"Aqara\"},\"disabled\":false,\"endpoints\":{\"1\":{\"bindings\":[],\"clusters\":{\"input\":[],\"output\":[]},\"configured_reportings\":[],\"scenes\":[]}},\"friendly_name\":\"Dachbodenfenster Contact\",\"ieee_address\":\"0x00158d0001ddef66\",\"interview_completed\":true,\"interviewing\":false,\"manufacturer\":\"LUMI\",\"model_id\":\"lumi.sensor_magnet.aq2\",\"network_address\":42946,\"power_source\":\"Battery\",\"supported\":true,\"type\":\"EndDevice\",\"current_values\":{\"battery\":100,\"contact\":true,\"device_temperature\":13,\"last_seen\":\"2025-02-18T17:26:36+01:00\",\"linkquality\":109,\"power_outage_count\":450,\"trigger_count\":0,\"voltage\":3005},\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"format\":{}},\"topic\":\"zigbee2mqtt/Dachbodenfenster Contact\",\"selector\":\"zigbee2mqtt_DachbodenfensterContact\",\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"payload\":{\"battery\":100,\"contact\":false,\"device_temperature\":13,\"last_seen\":\"2025-02-18T17:26:36+01:00\",\"linkquality\":109,\"power_outage_count\":450,\"trigger_count\":0,\"voltage\":3005},\"format\":{}},\"0x00158d0001ddc8e5\":{\"item\":{\"date_code\":\"20161128\",\"definition\":{\"description\":\"Door and window sensor\",\"exposes\":[{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Remaining battery in %, can take up to 24 hours before reported\",\"label\":\"Battery\",\"name\":\"battery\",\"property\":\"battery\",\"type\":\"numeric\",\"unit\":\"%\",\"value_max\":100,\"value_min\":0},{\"access\":1,\"description\":\"Indicates if the contact is closed (= true) or open (= false)\",\"label\":\"Contact\",\"name\":\"contact\",\"property\":\"contact\",\"type\":\"binary\",\"value_off\":true,\"value_on\":false},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Temperature of the device\",\"label\":\"Device temperature\",\"name\":\"device_temperature\",\"property\":\"device_temperature\",\"type\":\"numeric\",\"unit\":\"°C\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Voltage of the battery in millivolts\",\"label\":\"Voltage\",\"name\":\"voltage\",\"property\":\"voltage\",\"type\":\"numeric\",\"unit\":\"mV\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Number of power outages\",\"label\":\"Power outage count\",\"name\":\"power_outage_count\",\"property\":\"power_outage_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Indicates how many times the sensor was triggered (since last scheduled report)\",\"label\":\"Trigger count\",\"name\":\"trigger_count\",\"property\":\"trigger_count\",\"type\":\"numeric\"},{\"access\":1,\"category\":\"diagnostic\",\"description\":\"Link quality (signal strength)\",\"label\":\"Linkquality\",\"name\":\"linkquality\",\"property\":\"linkquality\",\"type\":\"numeric\",\"unit\":\"lqi\",\"value_max\":255,\"value_min\":0}],\"model\":\"MCCGQ11LM\",\"options\":[{\"access\":2,\"description\":\"Calibrates the device_temperature value (absolute offset), takes into effect on next report of device.\",\"label\":\"Device temperature calibration\",\"name\":\"device_temperature_calibration\",\"property\":\"device_temperature_calibration\",\"type\":\"numeric\"}],\"supports_ota\":false,\"vendor\":\"Aqara\"},\"disabled\":false,\"endpoints\":{\"1\":{\"bindings\":[],\"clusters\":{\"input\":[\"genBasic\",\"genIdentify\",\"65535\",\"genOnOff\"],\"output\":[\"genBasic\",\"genGroups\",\"65535\"]},\"configured_reportings\":[],\"scenes\":[]}},\"friendly_name\":\"Studio FensterL Contact\",\"ieee_address\":\"0x00158d0001ddc8e5\",\"interview_completed\":true,\"interviewing\":false,\"manufacturer\":\"LUMI\",\"model_id\":\"lumi.sensor_magnet.aq2\",\"network_address\":16276,\"power_source\":\"Battery\",\"software_build_id\":\"3000-0001\",\"supported\":true,\"type\":\"EndDevice\",\"current_values\":{\"battery\":100,\"contact\":true,\"device_temperature\":12,\"last_seen\":\"2025-02-18T16:32:29+01:00\",\"linkquality\":76,\"power_outage_count\":160,\"trigger_count\":0,\"voltage\":3125},\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"format\":{}},\"topic\":\"zigbee2mqtt/Studio FensterL Contact\",\"selector\":\"zigbee2mqtt_StudioFensterLContact\",\"homekit\":{\"ContactSensor\":{\"ContactSensorState\":0},\"ContactSensor_Inverse\":{\"ContactSensorState\":1},\"Battery\":{\"BatteryLevel\":100,\"StatusLowBattery\":0}},\"payload\":{\"battery\":100,\"contact\":true,\"device_temperature\":12,\"last_seen\":\"2025-02-18T16:32:29+01:00\",\"linkquality\":76,\"power_outage_count\":160,\"trigger_count\":0,\"voltage\":3125},\"format\":{}}}",
           "payloadType": "json",
           "x": 300,
           "y": 7060,
           "wires": [
                   "e29d13e39355375d",
                   "6c6901822b24f320",
                   "3aa357dca689ad3f"
           "id": "e29d13e39355375d",
           "type": "debug",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "payload",
           "targetType": "msg",
           "statusVal": "",
           "statusType": "auto",
           "x": 570,
           "y": 7000,
           "wires": []
           "id": "6c6901822b24f320",
           "type": "change",
           "name": "Fenster zu",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload.*[payload.contact=true].topic",
                   "tot": "jsonata"
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload ? payload : \"Alle Fenster geöffnet\"",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 550,
           "y": 7060,
           "wires": [
                   "5960a47fef812439"
           "id": "5960a47fef812439",
           "type": "debug",
           "name": "Fenster geschlossen",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 800,
           "y": 7060,
           "wires": []
           "id": "3aa357dca689ad3f",
           "type": "change",
           "name": "Fenster offen",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload.*[payload.contact=false].topic",
                   "tot": "jsonata"
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload ? payload : \"Alle Fenster geschlossen\"",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 550,
           "y": 7120,
           "wires": [
                   "da1365a7f5a03cfc"
           "id": "da1365a7f5a03cfc",
           "type": "debug",
           "name": "Fenster geöffnet",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 780,
           "y": 7120,
           "wires": []
    Ich habe mal ein Dachboden-Fenster virtuell geöffnet, damit ein Ergebnis rauskommt.
    Mit
    kannst Du also die Objekte leicht selektieren und somit auch gleich das topic ausgeben lassen.
    Um das für Dich selbst auszuprobieren und die verschiedenen Contact Sensoren auf true zu stellen, nutz am Besten auch einfach den JSONATA Exerciser:
    https://try.jsonata.org/uEEVBxn2i
    Links siehst Du Deine Quelldaten:
    rechts oben den Code - der gleich das Ergebnis im unteren Fenster rechts anzeigt.
    Ach so und wenn Du Dir statt des topics gleich die friendly_names in Deinem Array ausgeben lassen willst, dann brauchst Du es in dem Objekt nur selektieren.
    Also dann einfach:
    payload.*[payload.contact=false].item.friendly_name
    Und wenn Du auch bei einem Ergebnis ein Array und keinen skalaren Text haben willst, dann halt das ganze in eckige Klammer setzen. Diese einfach Anhängen funktioniert nicht.
    So erhälst Du also immer ein Array - auch mit nur EINEM Element.
    [payload.*[payload.contact=false].item.friendly_name]
    • mac89mucM mac89muc
      ich benötige bitte mal einen Gedankenanstoss bei folgendem Vorhaben.
      Wenn ich das Haus verlasse bzw. abends wenn ich schlafen gehe, möchte ich eine Benachrichtigung mit dem Status der Fenster und Türen bekommen.
      Also Türen geschlossen, Fenster Bad auf etc..
      Meine Tür- und Fensterkontakte sind über zigbee2mqtt node eingebunden - hier gibt es eine Gruppe Fenster und eine Gruppe Türen die ich in der node definiert habe.
      Ich kann den Status der jeweiligen Gruppen über die get zigbee2mqtt node abfragen und erhalte eine payload mit den einzelnen Kontaktsensoren und den jeweiligen Stati.
      Wie kann ich jetzt eine Kontrolle der jeweiligen Sensoren auf den Status von msg.payload.*.payload.contact === false prüfen - also das ich nicht für jeden Sensor eine separate Überprüfung machen muss?
      Den Platzhalter bzw. * funktioniert in der function node ja nicht - muss ich das über eine loop Funktion in der function Node abwickeln, oder wie komme ich meinem Ziel näher? Ich würde es auch Platzgründen gerne über eine function Node abwickeln.
      In Blockly hatte ich das damals so geregelt
      Hab gegoogelt und ein paar Beispiele probiert die aber nicht zum Ziel führen mangels korrekter Herangehensweise oder syntax - bin was javascript angeht nicht der Experte, kleinere Grundlagen bekomme ich hin bzw. hab ich mir in Eigenregie selbst beigebracht.
      Danke für Tipps.
      mickymM Offline
      mickymM Offline
      mickym
      @mac89muc sagte in Hilfe bei NodeRed wegen Status Fenster/Türen:
      Verstehe ich zwar nicht - ein function Node - ist meines Erachtens viel umständlicher und braucht auch nicht mehr oder weniger Platz als eine Change Node???
      Und ehrlich gesagt, habe ich wenig Lust wieder x-Zeilen Code zu schreiben, weil in dem Fall das Javascript einfach viel umständlicher ist und JSONATA einfach für diese Art abfragen gemacht wurde und JSONATA in NodeRed sehr gut unterstützt ist.
      Wird auch in Blockly viel zuwenig genutzt.
      • mickymM Offline
        mickymM Offline
        mickym
        Hier die relevanten Nodes nochmal zum Import (letzter Stand mit immer Array):
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "[payload.*[payload.contact=true].item.friendly_name]",
                       "tot": "jsonata"
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 550,
               "y": 7060,
               "wires": [
                       "5960a47fef812439"
               "type": "debug",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 800,
               "y": 7060,
               "wires": []
               "type": "change",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "[payload.*[payload.contact=false].item.friendly_name]",
                       "tot": "jsonata"
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 550,
               "y": 7120,
               "wires": [
                       "da1365a7f5a03cfc"
               "type": "debug",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 780,
               "y": 7120,
               "wires": []
        mac89mucM 1 Antwort Letzte Antwort
        • mickymM mickym
                 "type": "change",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "tot": "jsonata"
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "tot": "jsonata"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 550,
                 "y": 7060,
                 "wires": [
                         "5960a47fef812439"
                 "type": "debug",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 800,
                 "y": 7060,
                 "wires": []
                 "type": "change",
                 "rules": [
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "tot": "jsonata"
                         "t": "set",
                         "p": "payload",
                         "pt": "msg",
                         "tot": "jsonata"
                 "action": "",
                 "property": "",
                 "from": "",
                 "to": "",
                 "reg": false,
                 "x": 550,
                 "y": 7120,
                 "wires": [
                         "da1365a7f5a03cfc"
                 "type": "debug",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 780,
                 "y": 7120,
                 "wires": []
          mac89mucM Offline
          mac89mucM Offline
          mac89muc
          @mickym Wow - vielen Dank. Probiere ich die nächsten Tage aus und melde mich wieder. So, oder so schon mal vielen Dank
          • mickymM Offline
            mickymM Offline
            mickym
            Falls Du doch lieber mit Javascript programmieren willst, habe ich Dir noch eine function Node gebastelt mit 2 Ausgängen, für Fenster offen und geschlossen.
            Hier zum Import:
                   "type": "inject",
                   "props": [
                           "p": "payload"
                   "repeat": "",
                   "crontab": "",
                   "once": false,
                   "onceDelay": 0.1,
                   "topic": "",
                   "x": 260,
                   "y": 7160,
                   "wires": [
                           "e29d13e39355375d",
                           "6c6901822b24f320",
                           "3aa357dca689ad3f",
                           "c7b9a3945149aaa6"
                   "type": "debug",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 550,
                   "y": 7080,
                   "wires": []
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "topic",
                           "pt": "msg",
                           "to": "Fenster geschlossen",
                           "tot": "str"
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "jsonata"
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "jsonata"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 510,
                   "y": 7260,
                   "wires": [
                           "5960a47fef812439"
                   "type": "debug",
                   "name": "Fenster geschlossen (JSONATA)",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 780,
                   "y": 7260,
                   "wires": []
                   "type": "change",
                   "rules": [
                           "t": "set",
                           "p": "topic",
                           "pt": "msg",
                           "to": "Fenster geöffnet",
                           "tot": "str"
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "jsonata"
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "tot": "jsonata"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 510,
                   "y": 7300,
                   "wires": [
                           "da1365a7f5a03cfc"
                   "type": "debug",
                   "name": "Fenster geöffnet (JSONATA)",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 760,
                   "y": 7300,
                   "wires": []
                   "id": "c7b9a3945149aaa6",
                   "type": "function",
                   "func": "var arrOpened=[];\nvar arrClosed=[];\nfor (var key in msg.payload){\n    var obj;\n    obj = msg.payload[key];\n    obj.payload.contact ? arrClosed.push(obj.item.friendly_name) : arrOpened.push(obj.item.friendly_name)\n}\n \nreturn [{ topic: \"Fenster geschlossen\", payload: arrClosed.length > 0 ? arrClosed : \"Alle Fenster geöffnet\"  },\n    {topic: \"Fenster geöffnet\", payload: arrOpened.length > 0 ? arrOpened : \"Alle Fenster geschlossen !\" }];",
                   "outputs": 2,
                   "timeout": 0,
                   "noerr": 0,
                   "initialize": "",
                   "finalize": "",
                   "libs": [],
                   "x": 510,
                   "y": 7160,
                   "wires": [
                           "2f4bbe40257a37f3"
                           "041a44ac252bbd51"
                   "id": "2f4bbe40257a37f3",
                   "type": "debug",
                   "name": "Fenster geschlossen (Javascript)",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 780,
                   "y": 7140,
                   "wires": []
                   "id": "041a44ac252bbd51",
                   "type": "debug",
                   "name": "Fenster geöffnet (Javascript)",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 760,
                   "y": 7180,
                   "wires": []
            Der Code mit Javascript ist natürlich länger:
            var arrOpened=[];
            var arrClosed=[];
                var obj;
            return [{ topic: "Fenster geschlossen", payload: arrClosed.length > 0 ? arrClosed : "Alle Fenster geöffnet"  },
                {topic: "Fenster geöffnet", payload: arrOpened.length > 0 ? arrOpened : "Alle Fenster geschlossen !" }];
            Aber ich habe die function Node gleich mit 2 Ausgängen gebastelt, so dass oben die geschlossenen Fenster und unten die offenen Fenster ausgegeben werden.
            Ich würde Dir aber trotzdem raten auf function Nodes so lange wie möglich zu verzichten - da Du sonst leicht wieder in Versuchung kommst, herkömmlichen Code zu schreiben - mit Schleifen etc.
            • mickymM mickym
              Hier zum Import:
                     "type": "inject",
                     "props": [
                             "p": "payload"
                     "repeat": "",
                     "crontab": "",
                     "once": false,
                     "onceDelay": 0.1,
                     "topic": "",
                     "x": 260,
                     "y": 7160,
                     "wires": [
                             "e29d13e39355375d",
                             "6c6901822b24f320",
                             "3aa357dca689ad3f",
                             "c7b9a3945149aaa6"
                     "type": "debug",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 550,
                     "y": 7080,
                     "wires": []
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "topic",
                             "pt": "msg",
                             "tot": "str"
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 510,
                     "y": 7260,
                     "wires": [
                             "5960a47fef812439"
                     "type": "debug",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 780,
                     "y": 7260,
                     "wires": []
                     "type": "change",
                     "rules": [
                             "t": "set",
                             "p": "topic",
                             "pt": "msg",
                             "tot": "str"
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "jsonata"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 510,
                     "y": 7300,
                     "wires": [
                             "da1365a7f5a03cfc"
                     "type": "debug",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 760,
                     "y": 7300,
                     "wires": []
                     "type": "function",
                     "outputs": 2,
                     "timeout": 0,
                     "noerr": 0,
                     "initialize": "",
                     "finalize": "",
                     "libs": [],
                     "x": 510,
                     "y": 7160,
                     "wires": [
                             "2f4bbe40257a37f3"
                             "041a44ac252bbd51"
                     "type": "debug",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 780,
                     "y": 7140,
                     "wires": []
                     "type": "debug",
                     "active": true,
                     "tosidebar": true,
                     "console": false,
                     "tostatus": false,
                     "statusVal": "",
                     "x": 760,
                     "y": 7180,
                     "wires": []
              var arrOpened=[];
              var arrClosed=[];
                  var obj;
              mac89mucM Offline
              mac89mucM Offline
              mac89muc
              @mickym vielen lieben Dank für Deine Mühe!!! - hab ich importiert und funktioniert wie gewünscht. 👍 ☺
              In dem Fall bin ich komplett deiner Meinung mit dem Verzicht auf die Function node, ich dachte das wird etwas umfangreicher was die Anzahl der nodes angeht und da ist mir dann normalerweise eine Function node immer lieber. Aber in dem Beispiel sehe ich das genauso wie Du.
              Beim Thema JSONATA muss ich mich mal einarbeiten, ich glaube das ist genau das was ich für ein paar Themen brauchen kann als Ansatz - Danke dafür.
              Hast Du ggf. noch einen kurzen Tipp für mich, wenn ich die geöffneten Fenster nicht in einem Array ausgegeben haben möchte, sondern in einem einzigen getrennt durch Kommas? Muss ich das Array danach nochmal anfassen und zusammenfassen? Das müsste dann doch bestimmt mit JSONATA auch schon in einem Aufwasch direkt funktionieren, oder??
              Viele Grüße
                Viele Grüße
                mickymM Offline
                mickymM Offline
                mickym
                Viele Grüße
                Einfach das Array in eine Join Funktion geben.
                https://docs.jsonata.org/string-functions#join
                1. Du kannst entweder die letzte Regel nehmen - wenn sonst ausgegeben wird, dass Alle Fenster geschlossen sind
                1. oder falls Du keine Ausgabe und die letzte Regel nicht brauchst(falls alle Fenster geschlossen sind) wünschst kannst Du auch einfach das Ergebnis weitergeben
                Dann brauchst natürlich auch die eckige Klammer nicht, wenn nur ein Element vorhanden ist.
                • mickymM mickym
                  Viele Grüße
                  mac89mucM Offline
                  mac89mucM Offline
                  mac89muc
                  @mickym perfekt - eine letzte minimale Optimierung ist mir gerade noch aufgefallen...
                  Ich habe zwecks Organisation und Übersicht bei meinen Zigbee Kontaktsensoren im Namen immer Contact mit am Schluss stehen. Das hätte ich in der Aufzählung gerne entfernt - wie bekomme ich das noch integriert also ->
                  friendly_name.slice(0, -8)
                  Wenn ich das direkt dranhänge
                  payload.*[payload.contact=false].item.friendly_name.slice(0, -8)~>$join(", ")
                  bekomme ich einen Fehler
                  Invalid JSONata expression: Attempted to invoke a non-function
                  Kann ich mich für Deine Hilfe irgendwo mit einer Kaffeespende revanchieren?
                  Danke & Gruß
                    Danke & Gruß
                    mickymM Offline
                    mickymM Offline
                    mickym
                    slice ist keine JSONATA Funktion sondern eine Javascript Funktion
                    Danke & Gruß
                    Nein - brauchst Du nicht, mache ich gerne
                    In JSONATA machst Du das so:
                    payload.*[payload.contact=false].$substringBefore(item.friendly_name," Contact")~>$join(", ")
                    • mickymM Offline
                      mickymM Offline
                      mickym
                      Falls Du zigbee2mqtt verwendest, was Du auch tust - soweit ich mich erinnere, kannst Du als friendly Name auch Hierarchien bilden und dann brauchst Du diese Konstrukte mit den Namen nicht.
                      Also einfach die Gerätenamen entsprechend mqtt topics in der Hierarchie benennen:
                      Im friendlyName wird das mqtt topic dann entsprechend eingetragen:
                      • mickymM mickym
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @mickym Vorteil für Dich ist, dass Du diese Nodes eigentlich dann nicht brauchst, sondern über die mqtt Hierachien selektieren kannst.
                        In meinem Fall selektiere (subscribe) ich alle Kontakte mit
                        zigbee2mqtt/kontakt/#
                        • mickymM mickym
                          mac89mucM Offline
                          mac89mucM Offline
                          mac89muc
                          @mickym
                          Vielen Dank ich probiere jetzt mal ein bisschen rum und passe meine Flows an. Ich habe noch 2-3 andere Themen bzgl. Node-Red und würde mich dann mit einem separaten Thread nochmal melden, vielleicht hast Du dann ja nochmal Zeit & Lust mir weiterzuhelfen. Vielen Dank nochmals für die schnelle und ausführliche Hilfe.
