  4. über Port 8081 und 8082 kann ich ioBroker nicht aufrufen
77 Beiträge 5 Kommentatoren 9.7k Aufrufe 4 Beobachtet
  • T Thorsten4-71
    @thomas-braun ```
    Script v.2024-12-09 Raspbian+zigbee diag+masking
    *** BASE SYSTEM ***
     Static hostname: raspberrypi
           Icon name: computer
              Kernel: Linux 6.6.62+rpt-rpi-2712
        Architecture: arm64
    OS is similar to:
    Model           : Raspberry Pi 5 Model B Rev 1.0
    Docker          : false
    Virtualization  : none
    Kernel          : aarch64
    Userland        : 64 bit
    Systemuptime and Load:
     09:13:01 up  9:19,  3 users,  load average: 1.31, 2.24, 1.90
    CPU threads: 4
    *** LIFE CYCLE STATUS ***
    Operating System is the current Debian stable version codenamed 'bookworm'!
    *** RASPBERRY THROTTLING ***
    Current issues:
    ~ Under-voltage detected
    ~ Arm frequency capped
    Previously detected issues:
    ~ Under-voltage has occurred
    ~ Arm frequency capping has occurred
    *** TIME AND TIMEZONES ***
                   Local time: Sun 2025-02-02 09:13:01 CET
               Universal time: Sun 2025-02-02 08:13:01 UTC
                     RTC time: Sun 2025-02-02 08:13:01
                  NTP service: active
              RTC in local TZ: no
    *** Users and Groups ***
    User that called 'iob diag':
    shthorsten
    HOME=/home/shthorsten
    GROUPS=shthorsten adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
    js-controller is not running
    *** DISPLAY-SERVER SETUP ***
    Display-Server: true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            4.2G        518M        1.8G         24M        2.0G        3.7G
    Swap:            60M          0B         60M
    Total:          4.3G        518M        1.9G
    Active iob-Instances:   0
             4045 M total memory
              494 M used memory
              663 M active memory
             1231 M inactive memory
             1731 M free memory
              254 M buffer memory
             1653 M swap cache
               57 M total swap
                0 M used swap
               57 M free swap
    top - 09:13:01 up  9:19,  3 users,  load average: 1.31, 2.24, 1.90
    Tasks: 202 total,   1 running, 201 sleeping,   0 stopped,   0 zombie
    %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
    MiB Mem :   4045.0 total,   1729.1 free,    496.3 used,   1908.4 buff/cache
    MiB Swap:     57.7 total,     57.7 free,      0.0 used.   3548.7 avail Mem
    *** FAILED SERVICES ***
    0 loaded units listed.
    *** DMESG CRITICAL ERRORS ***
    1332 CRITICAL ERRORS DETECTED!
    Check 'sudo dmesg --level=emerg,alert,crit -T' for details
    *** FILESYSTEM ***
    udev           devtmpfs  2.0G     0  2.0G   0% /dev
    tmpfs          tmpfs     405M  5.9M  399M   2% /run
    /dev/mmcblk0p2 ext4       15G   14G     0 100% /
    tmpfs          tmpfs     2.0G  288K  2.0G   1% /dev/shm
    tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
    /dev/mmcblk0p1 vfat      510M   76M  435M  15% /boot/firmware
    tmpfs          tmpfs     405M  192K  405M   1% /run/user/1000
    Show mounted filesystems:
    TARGET               SOURCE         FSTYPE      OPTIONS
    /                    /dev/mmcblk0p2 ext4        rw,noatime
    |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    2.3G    /var/
    1.1G    /var/log/journal/404274c0b2bb418589be89042d5b9a67
    1.1G    /var/log
    995M    /var/cache
    Archived and active journals take up 1.0G in the file system.
    /opt/iobroker/backups:
    859M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.4G    /opt/iobroker/iobroker-data/
    1.2G    /opt/iobroker/iobroker-data/files
    617M    /opt/iobroker/iobroker-data/files/javascript.admin
    560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
    558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
    37M     /opt/iobroker/iobroker-data/files/radar-trap.admin/build/index.js.map
    27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
    26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
    24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
    USB-Devices by-id:
    No Devices found 'by-id'
    zigbee.X
    Extended Pan ID:
    *** MASKED ***
    Pan ID:
    *** MASKED ***
    Channel:
    *** MASKED ***
    Network Key:
    *** MASKED ***
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v20.18.1
    /usr/bin/node           v20.18.1
    /usr/bin/npm            10.8.2
    /usr/bin/npx            10.8.2
    /usr/bin/corepack       0.29.4
    nodejs:
      Installed: 20.18.1-1nodesource1
      Candidate: 20.18.2-1nodesource1
      Version table:
         20.18.2-1nodesource1 600
            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
     *** 20.18.1-1nodesource1 600
         20.18.0-1nodesource1 600
         20.17.0-1nodesource1 600
         20.16.0-1nodesource1 600
         20.15.1-1nodesource1 600
         20.15.0-1nodesource1 600
         20.14.0-1nodesource1 600
         20.13.1-1nodesource1 600
         20.13.0-1nodesource1 600
         20.12.2-1nodesource1 600
         20.12.1-1nodesource1 600
         20.12.0-1nodesource1 600
         20.11.1-1nodesource1 600
         20.11.0-1nodesource1 600
         20.10.0-1nodesource1 600
         20.9.0-1nodesource1 600
         20.8.1-1nodesource1 600
         20.8.0-1nodesource1 600
         20.7.0-1nodesource1 600
         20.6.1-1nodesource1 600
         20.6.0-1nodesource1 600
         20.5.1-1nodesource1 600
         20.5.0-1nodesource1 600
         20.4.0-1nodesource1 600
         20.3.1-1nodesource1 600
         20.3.0-1nodesource1 600
         20.2.0-1nodesource1 600
         20.1.0-1nodesource1 600
         20.0.0-1nodesource1 600
         18.19.0+dfsg-6~deb12u2 500
            500 http://deb.debian.org/debian bookworm/main arm64 Packages
         18.19.0+dfsg-6~deb12u1 500
            500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
    Temp directories causing deletion problem: 10
    Some problems detected, please run iob fix
    Errors in npm tree: 0
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
    Hosts:
    Core adapters versions
    js-controller:  7.0.6
    admin:          7.4.10
    javascript:     8.8.3
    nodejs modules from github:     0
    Adapter State
    ioBroker-Repositories
    Installed ioBroker-Instances
    Objects and States
    Objects:        1
    States:         1
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://deb.debian.org/debian bookworm InRelease: Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_InRelease into data and signature failed
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://deb.debian.org/debian-security bookworm-security InRelease: Splitting up /var/lib/apt/lists/deb.debian.org_debian-security_dists_bookworm-security_InRelease into data and signature failed
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://deb.debian.org/debian bookworm-updates InRelease: Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_InRelease into data and signature failed
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://deb.nodesource.com/node_20.x nodistro InRelease: Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f20.x_dists_nodistro_InRelease into data and signature failed
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://archive.raspberrypi.com/debian bookworm InRelease: Splitting up /var/lib/apt/lists/archive.raspberrypi.com_debian_dists_bookworm_InRelease into data and signature failed
    W: Failed to fetch http://deb.debian.org/debian/dists/bookworm/InRelease  Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_InRelease into data and signature failed
    W: Failed to fetch http://deb.debian.org/debian-security/dists/bookworm-security/InRelease  Splitting up /var/lib/apt/lists/deb.debian.org_debian-security_dists_bookworm-security_InRelease into data and signature failed
    W: Failed to fetch http://deb.debian.org/debian/dists/bookworm-updates/InRelease  Splitting up /var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_InRelease into data and signature failed
    W: Failed to fetch https://deb.nodesource.com/node_20.x/dists/nodistro/InRelease  Splitting up /var/lib/apt/lists/deb.nodesource.com_node%5f20.x_dists_nodistro_InRelease into data and signature failed
    W: Failed to fetch http://archive.raspberrypi.com/debian/dists/bookworm/InRelease  Splitting up /var/lib/apt/lists/archive.raspberrypi.com_debian_dists_bookworm_InRelease into data and signature failed
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Err:1 http://deb.debian.org/debian bookworm InRelease
    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Err:2 http://deb.debian.org/debian-security bookworm-security InRelease
    Err:3 http://deb.debian.org/debian bookworm-updates InRelease
    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Err:4 http://archive.raspberrypi.com/debian bookworm InRelease
    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Err:5 https://deb.nodesource.com/node_20.x nodistro InRelease
    Reading package lists... Done
    Pending Updates: 92
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       471316     49074/iobroker.js-c
    tcp        1      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       470381     49074/iobroker.js-c
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17901      3284/cupsd
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5987       888/sshd: /usr/sbin
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17900      3284/cupsd
    tcp6       0      0 :::3389                 :::*                    LISTEN      112        1983       952/xrdp
    tcp6       0      0 :::22                   :::*                    LISTEN      0          5989       888/sshd: /usr/sbin
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          1917       878/xrdp-sesman
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4678       676/avahi-daemon: r
    udp        0      0 0.0.0.0:56703           0.0.0.0:*                           104        4680       676/avahi-daemon: r
    udp6       0      0 fe80::2c7c:a66:e1e9:546 :::*                                0          457635     821/NetworkManager
    udp6       0      0 :::5353                 :::*                                104        4679       676/avahi-daemon: r
    udp6       0      0 :::54800                :::*                                104        4681       676/avahi-daemon: r
    2025-02-02 09:14:30.067  - info: host.raspberrypi starting 32 instances
    2025-02-02 09:14:30.287  - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeCurrent"
    2025-02-02 09:14:30.317  - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewest"
    2025-02-02 09:14:30.321  - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.nodeNewestNext"
    2025-02-02 09:14:30.326  - info: host.raspberrypi instance system.adapter.history.0 in version "3.0.1" started with pid 49110
    2025-02-02 09:14:30.330  - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmCurrent"
    2025-02-02 09:14:30.383  - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewest"
    2025-02-02 09:14:30.388  - info: host.raspberrypi Delete state "system.host.raspberrypi.versions.npmNewestNext"
    2025-02-02 09:14:30.393  - info: host.raspberrypi Some obsolete host states deleted.
    2025-02-02 09:14:31.418  - error: host.raspberrypi could not store process id list in /opt/iobroker/node_modules/iobroker.js-controller/pids.txt! Please check permissions and user ownership of this file. Was ioBroker started as a different user? Please also check left over processes when stopping ioBroker!
    Error: ENOSPC: no space left on device, write
    2025-02-02 09:14:31.418  - error: host.raspberrypi Please consider running the installation fixer when on Linux.
    2025-02-02 09:14:31.642  - info: history.0 (49110) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.history, node: v20.18.1, js-controller: 7.0.6
    2025-02-02 09:14:31.724  - info: history.0 (49110) enabled logging of hm-rpc.0.info.connection (Count=1), Alias=false
    2025-02-02 09:14:34.297  - error: host.raspberrypi Caught by controller[0]: [Error: ENOSPC: no space left on device, write] {
    2025-02-02 09:14:34.297  - error: host.raspberrypi Caught by controller[0]:   errno: -28,
    2025-02-02 09:14:34.297  - error: host.raspberrypi Caught by controller[0]:   code: 'ENOSPC',
    2025-02-02 09:14:34.297  - error: host.raspberrypi Caught by controller[0]:   syscall: 'write'
    2025-02-02 09:14:34.298  - error: host.raspberrypi Caught by controller[0]: }
    2025-02-02 09:14:34.298  - error: host.raspberrypi instance system.adapter.history.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2025-02-02 09:14:34.298  - info: host.raspberrypi Restart adapter system.adapter.history.0 because enabled
    2025-02-02 09:14:34.334  - info: host.raspberrypi instance system.adapter.javascript.0 in version "8.8.3" started with pid 49134
    2025-02-02 09:14:35.300  - error: host.raspberrypi could not store process id list in /opt/iobroker/node_modules/iobroker.js-controller/pids.txt! Please check permissions and user ownership of this file. Was ioBroker started as a different user? Please also check left over processes when stopping ioBroker!
    2025-02-02 09:14:35.301  - error: host.raspberrypi Please consider running the installation fixer when on Linux.
    iob diag has finished.
    #67
    @thorsten4-71 sagte in über Port 8081 und 8082 kann ich ioBroker nicht aufrufen:
    immer noch!
    Was hängt alles am Netzteil/Raspi?
    dito!
    Pending Updates: 92
    und Probleme mit den Repos.
    Alles wahrscheinlich weil
    die ist rappelvoll
    • T Thorsten4-71
      @thomas-braun ```
      *** BASE SYSTEM ***
             Icon name: computer
          Architecture: arm64
      OS is similar to:
      Docker          : false
      Kernel          : aarch64
      Userland        : 64 bit
      CPU threads: 4
      Current issues:
                    NTP service: active
                RTC in local TZ: no
      shthorsten
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            60M          0B         60M
               4045 M total memory
                494 M used memory
                663 M active memory
               1731 M free memory
                254 M buffer memory
               1653 M swap cache
                 57 M total swap
                  0 M used swap
                 57 M free swap
      *** FILESYSTEM ***
      /var:
      2.3G    /var/
      1.1G    /var/log
      995M    /var/cache
      USB-Devices by-id:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      nodejs:
        Version table:
      ioBroker Status
      Hosts:
      admin:          7.4.10
      javascript:     8.8.3
      Adapter State
      Objects and States
      Objects:        1
      States:         1
      Pending Updates: 92
      #68
      Current issues:
      Die Spannungsversorgung ist zu schwach. Vernünftiges Netzteil verwenden.
      Der muss halt laufen.
      Ausschalten...
      Das sind 1332 Fehler zu viel.
      Pending Updates: 92
      Das sind 92 Updates zu viel. Wobei auch bei deinen Quellen irgendwas krumm ist. Die Meldungen hab ich aber noch nie gesehen.
      Dein Dateisystem ist zu. Kein Platz mehr für irgendwas.
        immer noch!
        dito!
        Pending Updates: 92
        die ist rappelvoll
        Thorsten4-71
        #69
        @homoran Ich habe das netzteil getauscht (Kein Handy Netzteil) 4,5 A hängt nur der Raspberry dran.
        Thomas BraunT T HomoranH 3 Antworten Letzte Antwort
        • T Thorsten4-71
          #70
          @thorsten4-71
          Installier es neu, diesmal direkt OHNE Desktop und dem ganzen Zinnober in der 64Bit-Lite-Version.
          Die braucht auch weniger Platz auf dem Datenträger. Ich würde da aber auch einen größeren verwenden.
          • T Thorsten4-71
            Thorsten4-71
            #71
            @thorsten4-71 Wie bekomme ich den js-controller zum laufen? Soll ich mir eine neue Karte holen - welche würdest Du mir empfehlen - und neu aufsetzen?😧
            • T Thorsten4-71
              #72
              Hab ich gerade im Post davor geschrieben.
              Neben neuer Karte brauchst du aber auch ein gescheites Netzteil.
              Das originale von Raspberry ist zu empfehlen. Hab ich hier an meinen Kisten auch ausschließlich im Einsatz.
              • T Thorsten4-71
                #73
                das offizielle pi 5 Netzteil hat höhere Spezifikationen
                Am pi selber hängen keine USB Geräte?
                  Thorsten4-71
                  #74
                  @thomas-braun hatte ich übersehen, war gerade am schreiben. OK Dank dir. Welche Größe würdest Du mir empfehlen?
                    Thorsten4-71
                    #75
                    @homoran nein, da hängt nichts dran. Vielen Dank, werde ich mir zulegen und alles neu machen. grrr
                    • T Thorsten4-71
                      #76
                      Kann man so generell nicht sagen.
                      Ich verwende hier 32 - 64 GB SD-Karten, SSDs sind deutlich größer.
                      Und halt keine Platzfresser wie einen graphischen Desktop, ein Office-Paket und sonstigen Blödsinn.
                      • T Thorsten4-71
                        #77
                        unter 32GB bekommst du eh kaum noch was.
                        Ich würde aber auf 64 GB gehen.
                        Sieh zu, dass du was vernünftiges bekommst, mindestens mit pro, ultra, besser mit endurance im Namen
