  4. Test Adapter sureflap v3.4.2
154 Beiträge 17 Kommentatoren 44.5k Aufrufe 19 Beobachtet
  • Sickboy78S Sickboy78
    Hallo @stefi ,
    kannst du bitte mal die Ausgabe vom Adapter auf debug stellen und mir das gesamte Log vom Start bis zum Fehler kopieren?
    Stefi
    #119
    @sickboy78 Aber sicher. Hoffe, hab alles erwischt :)
    2024-12-29 22:22:38.755 - info: host.39e083369edf "system.adapter.sureflap.0" enabled
    2024-12-29 22:22:39.741 - info: host.39e083369edf instance system.adapter.sureflap.0 in version "2.3.2" started with pid 735
    2024-12-29 22:22:41.633 - debug: sureflap.0 (735) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2024-12-29 22:22:41.688 - debug: sureflap.0 (735) Objects client ready ... initialize now
    2024-12-29 22:22:41.691 - debug: sureflap.0 (735) Objects create System PubSub Client
    2024-12-29 22:22:41.693 - debug: sureflap.0 (735) Objects create User PubSub Client
    2024-12-29 22:22:41.775 - debug: sureflap.0 (735) Objects client initialize lua scripts
    2024-12-29 22:22:41.786 - debug: sureflap.0 (735) Objects connected to redis: 127.0.0.1:9001
    2024-12-29 22:22:41.844 - debug: sureflap.0 (735) Redis States: Use Redis connection: 127.0.0.1:9000
    2024-12-29 22:22:41.870 - debug: sureflap.0 (735) States create System PubSub Client
    2024-12-29 22:22:41.872 - debug: sureflap.0 (735) States create User PubSub Client
    2024-12-29 22:22:41.967 - debug: sureflap.0 (735) States connected to redis: 127.0.0.1:9000
    2024-12-29 22:22:42.295 - info: sureflap.0 (735) starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.sureflap, node: v20.18.1, js-controller: 7.0.6
    2024-12-29 22:22:42.322 - info: sureflap.0 (735) checking adapter configuration...
    2024-12-29 22:22:42.323 - info: sureflap.0 (735) API host: app-api.production.surehub.io
    2024-12-29 22:22:42.324 - info: sureflap.0 (735) sureflap battery voltage full: 6.1
    2024-12-29 22:22:42.325 - info: sureflap.0 (735) sureflap battery voltage empty: 5.1
    2024-12-29 22:22:42.325 - info: sureflap.0 (735) surefeed battery voltage full: 6.2
    2024-12-29 22:22:42.326 - info: sureflap.0 (735) surefeed battery voltage empty: 5.2
    2024-12-29 22:22:42.326 - info: sureflap.0 (735) felaqua battery voltage full: 6.2
    2024-12-29 22:22:42.328 - info: sureflap.0 (735) felaqua battery voltage empty: 5.2
    2024-12-29 22:22:42.330 - info: sureflap.0 (735) history enabled: false
    2024-12-29 22:22:42.331 - info: sureflap.0 (735) number of history entries: 10
    2024-12-29 22:22:42.332 - info: sureflap.0 (735) adapter configuration ok
    2024-12-29 22:22:42.334 - debug: sureflap.0 (735) starting SureFlap Adapter v2.3.2
    2024-12-29 22:22:42.336 - info: sureflap.0 (735) connecting...
    2024-12-29 22:22:42.337 - debug: sureflap.0 (735) json: {"email_address":"******","password":"******","device_id":"******"}
    2024-12-29 22:22:42.337 - debug: sureflap.0 (735) login count: 1
    2024-12-29 22:22:43.392 - info: sureflap.0 (735) connected
    2024-12-29 22:22:43.393 - info: sureflap.0 (735) starting update loop...
    2024-12-29 22:22:43.396 - info: sureflap.0 (735) update loop started
    2024-12-29 22:22:47.370 - debug: sureflap.0 (735) creating device hierarchy...
    2024-12-29 22:22:47.373 - debug: sureflap.0 (735) searching and removing of obsolete objects
    2024-12-29 22:22:47.381 - debug: sureflap.0 (735) deleting event history from adapter
    2024-12-29 22:22:47.440 - debug: sureflap.0 (735) searching and removing of obsolete objects complete
    2024-12-29 22:22:47.441 - debug: sureflap.0 (735) searching and removing of deleted and renamed pets
    2024-12-29 22:22:47.581 - debug: sureflap.0 (735) deleted or renamed pet sureflap.0.Wir.Flur.Abwasserkanal.assigned_pets.Katze1 (Pet 'Katze1' ('429176')) found. trying to delete (state)
    2024-12-29 22:22:47.582 - debug: sureflap.0 (735) deleted or renamed pet sureflap.0.Wir.Flur.Abwasserkanal.assigned_pets.Katze2 (Pet 'Katze2' ('429175')) found. trying to delete (state)
    2024-12-29 22:22:47.725 - debug: sureflap.0 (735) searching and removing of deleted and renamed pets complete
    2024-12-29 22:22:47.896 - error: sureflap.0 (735) uncaught exception: Cannot read properties of undefined (reading 'type')
    2024-12-29 22:22:47.898 - error: sureflap.0 (735) TypeError: Cannot read properties of undefined (reading 'type')
    at Immediate. (/opt/iobroker/node_modules/iobroker.sureflap/main.js:2845:68)
    at process.processImmediate (node:internal/timers:485:21)
    2024-12-29 22:22:47.898 - error: sureflap.0 (735) Cannot read properties of undefined (reading 'type')
    2024-12-29 22:22:47.906 - info: sureflap.0 (735) everything cleaned up
    2024-12-29 22:22:47.907 - info: sureflap.0 (735) terminating
    2024-12-29 22:22:47.909 - warn: sureflap.0 (735) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2024-12-29 22:22:47.911 - error: sureflap.0 (735) uncaught exception: Cannot read properties of undefined (reading 'type')
    2024-12-29 22:22:47.912 - error: sureflap.0 (735) TypeError: Cannot read properties of undefined (reading 'type')
    2024-12-29 22:22:47.913 - error: sureflap.0 (735) Cannot read properties of undefined (reading 'type')
    2024-12-29 22:22:48.411 - info: sureflap.0 (735) terminating
    2024-12-29 22:22:48.513 - error: host.39e083369edf instance system.adapter.sureflap.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2024-12-29 22:22:48.514 - info: host.39e083369edf Restart adapter system.adapter.sureflap.0 because enabled
    2024-12-29 22:23:04.710 - info: host.39e083369edf "system.adapter.sureflap.0" disabled
    Sickboy78S 1 Antwort Letzte Antwort
    • S Stefi
      Sickboy78S Offline
      Sickboy78S Offline
      Sickboy78
      #120
      Hallo @stefi,
      installier mal bitte den aktuellen Stand von Github, habe gerade was eingecheckt.
      Du hast einen oder zwei Futterautomaten?
        Hallo @stefi,
        Stefi
        #121
        @sickboy78 Oh man, jetzt wo du es erwähnst. Ich habe zwei Futterautomaten, die ich heute außer Betrieb genommen habe. Kam die Fehlermeldung aus dieser Ecke? Mit deinem Update hat es auf jeden Fall geklappt 👏
        • S Stefi
          Sickboy78S Offline
          Sickboy78S Offline
          Sickboy78
          #122
          Hallo @stefi ,
          ja normalerweise hat ein Futterautomat in seinen Daten ein Object 'bowls' das wiederum einen 'type' hat (1 oder 2 Futterschüsseln). In deinem Fall, wahrscheinlich weil du die Futterautomaten außer Betrieb genommen hast, gab es das object 'bowls' nicht und beim Zugriff auf 'bowls.type' hat es dann gekracht. Hab jetzt eine zusätzliche Prüfung eingebaut, ob das Object 'bowls' auch existiert.
          Guten Rutsch!
          Sebastian
            Hallo @stefi ,
            Guten Rutsch!
            Sebastian
            Stefi
            #123
            @sickboy78 Super, danke für die Anpassung :)
            • S Stefi
              Sickboy78S Offline
              Sickboy78S Offline
              Sickboy78
              #124
              Version 3.0.0 ist da und enthält hauptsächlich Änderungen unter der Haube. Zwar habe ich mit Version 2.x auf die neue URL umgestellt, aber teilweise noch Schnittstellen der alten API/App verwendet. Leider sind nach und nach einige Daten wie z.B. die Position der Tiere aus den alten Schnittstellen entfernt worden, so dass es zu Funktionseinschränkungen im Adapter kam und ich regelmäßig nachbessern musste.
              Um das zukünftig zu vermeiden, habe ich den kompletten API-Code überarbeitet und verwende nur noch Schnittstellen, die auch von der neuen App verwendet werden, in der Hoffnung, dass sich diese nicht so schnell ändern.
              Ansonsten habe ich, wie von ioBroker empfohlen, die Admin-Seite auf jsonConfig umgestellt.
              Und ein neuer Datenpunkt offline_devices ist hinzugekommen, der alle aktuell nicht mit dem Hub verbundenen Geräte auflistet.
              English:
              Version 3.0.0 is here and mainly contains changes under the hood. Although I switched to the new API-URL with version 2.x, I still used some of the interfaces of the old API/app. Unfortunately, some data, such as the position of the pets, was gradually removed from the old interfaces, which led to functional restrictions in the adapter and I had to make regular adaptions.
              To avoid this situation in future, I have refactored the entire API code to use only interfaces that are also used by the new App, in the hope that these will not change so quickly.
              Otherwise, as recommended by ioBroker, I have changed the admin page to jsonConfig.
              And a new data point offline_devices has been added, which lists all devices not currently connected to the hub.
                Matt77CHE
                schrieb am zuletzt editiert von Matt77CHE
                #125
                Habe gerade festgestellt, dass zB die Werte ob die Klappe nach Zeitplan gesperrt ist, nicht richtig angezeigt werden (Klappe ist gesperrt, Objekt-ID steht auf "open") - in der App wird gesperrt angezeigt und die Klappe ist auch gesperrt.
                War auf 3.0.0; bin runter auf 2.3.3, das Selbe Ergebnis, auch mit der 2.3.2.
                Ob die Katzen draussen oder drinnen sind, wird richtig angezeigt und aktualisiert....
                Edit: Ich habe den Objektbaum gelöscht, nun habe ich noch eine warn im Log, dass die Seriennummer der Klappe nicht gefunden werde.... (wiederholend)
                • M Matt77CHE
                  Sickboy78S Offline
                  Sickboy78S Offline
                  Sickboy78
                  #126
                  Hallo @matt77che ,
                  was meinst du mit Objekt-ID?
                  Der control.lockmode Datenpunkt ändert sich nicht, wenn die Ausgangssperre aktiv ist, da er unabhängig von der Ausgangssperre gesetzt werden kann. Wohingegen der Datenpunkt curfew_active auf true wechseln sollte, wenn eine Ausgangssperre aktiv ist.
                  Kannst du mir bitte die Fehlermeldung zur Seriennummer aus dem log kopieren? Danke!
                  M 2 Antworten Letzte Antwort
                    Hallo @matt77che ,
                    Matt77CHE
                    #127
                    @sickboy78 sagte in Test Adapter sureflap v1.0.x GitHub:
                    Hallo @matt77che ,
                    Da war es wohl zu späht für mich gestern Abend.... ich habe mich auf den falschen Datenpunkt eingeschossen - sorry.
                    Hier das Log bezüglich der Seriennummer:
                    sureflap.0
                    2025-01-26 08:03:30.101	warn	no serial number found for 'Buero_neu.
                    sureflap.0
                    2025-01-26 08:03:28.159	info	Got 3 pets
                    sureflap.0
                    2025-01-26 08:03:27.985	info	Got 2 devices
                    sureflap.0
                    2025-01-26 08:03:27.819	info	update loop started
                    sureflap.0
                    2025-01-26 08:03:27.819	info	starting update loop...
                    sureflap.0
                    2025-01-26 08:03:27.818	info	Got 1 household
                    sureflap.0
                    2025-01-26 08:03:27.663	info	connected
                    sureflap.0
                    2025-01-26 08:03:27.108	info	connecting...
                    sureflap.0
                    2025-01-26 08:03:27.107	info	adapter configuration ok
                    sureflap.0
                    2025-01-26 08:03:27.107	info	number of history entries: 10
                    sureflap.0
                    2025-01-26 08:03:27.107	info	history enabled: false
                    sureflap.0
                    2025-01-26 08:03:27.107	info	felaqua battery voltage empty: 5.2
                    sureflap.0
                    2025-01-26 08:03:27.107	info	felaqua battery voltage full: 6.2
                    sureflap.0
                    2025-01-26 08:03:27.106	info	surefeed battery voltage empty: 5.2
                    sureflap.0
                    2025-01-26 08:03:27.106	info	surefeed battery voltage full: 6.2
                    sureflap.0
                    2025-01-26 08:03:27.106	info	sureflap battery voltage empty: 5.1
                    sureflap.0
                    2025-01-26 08:03:27.106	info	sureflap battery voltage full: 6.1
                    sureflap.0
                    2025-01-26 08:03:27.106	info	API host: app-api.production.surehub.io
                    sureflap.0
                    2025-01-26 08:03:27.106	info	checking adapter configuration...
                    sureflap.0
                    2025-01-26 08:03:27.058	info	starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.sureflap, node: v20.18.1, js-controller: 7.0.6
                    • M Matt77CHE
                      Hallo @matt77che ,
                      sureflap.0
                      sureflap.0
                      sureflap.0
                      sureflap.0
                      sureflap.0
                      sureflap.0
                      sureflap.0
                      sureflap.0
                      sureflap.0
                      sureflap.0
                      sureflap.0
                      sureflap.0
                      sureflap.0
                      sureflap.0
                      sureflap.0
                      sureflap.0
                      sureflap.0
                      sureflap.0
                      sureflap.0
                      sureflap.0
                      Sickboy78S Offline
                      Sickboy78S Offline
                      Sickboy78
                      #128
                      Hi @matt77che ,
                      die Warnung an sich ist schon ok, sollte allerdings nur 1x nach jedem Start des Adapters erscheinen. (Es sei denn, die API liefert mal eine Seriennummer und mal nicht, was ich aber eher für unwahrscheinlich halte.)
                      Wie oft bzw. in welchem Zeitabstand wiederholt sich denn die Warnung bei dir?
                        Hi @matt77che ,
                        Matt77CHE
                        #129
                        @sickboy78
                        Bei mir ebenso nur bei Adapterstart - da ich ihn mehrfach gestartet habe, ist es demnach auch mehrfach im Log erschienen....
                          Hallo @matt77che ,
                          Matt77CHE
                          #130
                          Hallo @matt77che ,
                          Irgend etwas scheint trotzdem im Busch zu sein, habe gerade eben bei mir in der VIS gesehen, dass die Klappe gesperrt sei (DP curfew_active ist auf true) - dies obwohl sie offen ist, auch laut App...
                          Adapter DP last update ist heute, 16:35 Uhr, also aktuell...
                          • M Matt77CHE
                            Hallo @matt77che ,
                            Sickboy78S Offline
                            Sickboy78S Offline
                            Sickboy78
                            #131
                            Hi @matt77che , kannst du mir mal deine aktuelle Konfiguration der Ausgangssperre aus control.current_curfew kopieren? Danke!
                              Matt77CHE
                              #132
                              [{"enabled":true,"lock_time":"09:00 PM","unlock_time":"05:30 AM"}]
                              • M Matt77CHE
                                Sickboy78S Offline
                                Sickboy78S Offline
                                Sickboy78
                                #133
                                Hi @matt77che ,
                                ich seh schon wo der Hase im Pfeffer liegt. 12h Zeitformat berücksichtige ich aktuell im Adapter noch nicht.
                                Im Moment wird das als 9:00 Uhr morgens bis 05:30 morgens interpretiert und da liegt 16:45 drin, weshalb curfew_active auf true gesetzt wird.
                                Ich muss mir das bei Gelegenheit genauer ansehen.
                                Evtl. könnte es helfen, wenn du in der App unter Konto - Einstellungen das Zeitformat auf 24h stellst.
                                Allerdings hab ich es bei mir nicht geschafft, die Ausgangssperre auf 12h Fomat umzustellen. Auch nach Änderung des Zeitformat blieb sie 24h.
                                  Hi @matt77che ,
                                  Matt77CHE
                                  #134
                                  @sickboy78
                                  war bei mir bereits auf 24h eingestellt - das scheint jedoch nicht weitergegeben zu werden...
                                  • M Matt77CHE
                                    @sickboy78
                                    Sickboy78S Offline
                                    Sickboy78S Offline
                                    Sickboy78
                                    #135
                                    Hi @matt77che ,
                                    das ist echt merkwürdig, dass er die Zeiten bei dir im 12h Format ausgibt.
                                    Kannst du mir noch sagen, welche Einstellungen du sonst hast? (Konto - Einstellungen - Sprache, Einheiten, Land)
                                    Und welche Zeitzone? (Haushalt - Einstellungen - Zeitzone)
                                      Hi @matt77che ,
                                      Matt77CHE
                                      #136
                                      Hi @matt77che ,
                                      Deutsch
                                      Metrisch
                                      Schweiz
                                      Zurich, Europe (UTC+01:00)
                                      • M Matt77CHE
                                        Hi @matt77che ,
                                        Deutsch
                                        Metrisch
                                        Schweiz
                                        Sickboy78S Offline
                                        Sickboy78S Offline
                                        Sickboy78
                                        #137
                                        Hi @matt77che ,
                                        danke für die Rückmeldung, das sieht soweit gut aus.
                                        Aber ich glaub, ich hab das Problem gefunden und es hat wahrscheinlich nichts mit den Einstellungen in der App zu tun.
                                        Da die Surepet-API die Zeiten immer in britischer Zeitzone liefert (UTC), wandele ich sie mit toLocaleTimeString() in die Zeitzone des User um. Dies Funktion benutzt dazu die Locale des Systems, also des OS auf dem ioBroker läuft.
                                        Ich vermute, du hast in deinem OS eine locale eingestellt, die 12h Zeitformat verwendet.
                                        Ich hab gestern bei der Funktion toLocaleTimeString() die Option "hour12: false" hinzugefügt, so dass sie unabhängig von der Locale des Systems immer 24h Zeitformat erzeugt.
                                        Bitte installier mal die letzte Version direkt von Github und sag Bescheid, ob deine Asugangssperre dann 24h Zeitformat hat.
                                          Hi @matt77che ,
                                          Matt77CHE
                                          #138
                                          Hi @matt77che ,
                                          [{"enabled":true,"lock_time":"21:00","unlock_time":"05:30"}]
                                          So funktioniert wieder alles.
                                          Vielen Dank für deine Arbeit!
